ICL7660CPA
ICL7660CPA
    L3HARRIS
    DIP8
    SWITCHED CAPACITOR CONVERTER
ICL7660CPA 数据手册
Datasheet ICL7660 CMOS Voltage Converters The Harris ICL7660 and ICL7660A are monolithic CMOS power supply circuits which offer unique performance advan­tages over previously available devices. The ICL7660 per­forms supply voltage conversions from positive to negative for an input range of +1.5V to +10.0V resulting in comple­ mentary output voltages of -1.5V to -10.0V and the ICL7660A does the same conversions with an input range of +1.5V to +12.0V resulting in complementary output voltages of -1.5V to -12.0V. Only two noncritical external capacitors are needed for the charge pump and charge reservoir functions. The ICL7660 and ICL7660A can also be connected to func­tion as voltage doublers and will generate output voltages up to +18.6V with a +10V input. Rochester Electronics Manufactured Components Rochester branded components are manufactured using either die/wafers purchased from the original suppliers or Rochester wafers recreated from the original IP. All re-creations are done with the approval of the Original Component Manufacturer (OCM). Parts are tested using original factory test programs or Rochester developed test solutions to guarantee product meets or exceeds the OCM data sheet. Quality Overview • ISO-9001 • AS9120 certification • Qualified Manufacturers List (QML) MIL-PRF-35835 • Class Q Military • Class V Space Level • Qualified Suppliers List of Distributors (QSLD) • Rochester is a critical supplier to DLA and meets all industry and DLA standards. Rochester Electronics, LLC is committed to supplying products that satisfy customer expectations for quality and are equal to those originally supplied by industry manufacturers. The original manufacturer’s datasheet accompanying this document reflects the performance and specifications of the Rochester manufactured version of this device. Rochester Electronics guarantees the performance of its semiconductor products to the original OCM specifications. ‘Typical’ values are for reference purposes only. Certain minimum or maximum ratings may be based on product characterization, design, simulation, or sample testing. FOR REFERENCE ONLY © 2019 Rochester Electronics, LLC. All Rights Reserved 05062019 To learn more, please visit www.rocelec.com
ICL7660CPA 价格&库存
很抱歉,暂时无法提供与“ICL7660CPA”相匹配的价格&库存,您可以联系我们找货
