NJW4161R-B-TE1
NJW4161R-B-TE1
    NJR(新日本无线)
    LSSOP8
    MOSFET DRIVE SWITCHING REGULATOR
NJW4161R-B-TE1 数据手册
NJW4161 MOSFET Drive Switching Regulator IC for Buck Converter GENERAL DESCRIPTION ■ PACKAGE OUTLINE The NJW4161 is a MOSFET Drive switching regulator IC for Buck Converter that operates wide input range from 3.1V to 40V. It can provide large current application because of built-in highly effective Pch MOSFET 10V drive circuit. There are two types, Hiccup type and Latch type, of over current protection version. It is suitable for logic voltage generation from high voltage that Car Accessory, Office Automation Equipment, Industrial Instrument and so on. NJW4161R (MSOP8(VSP8)) NJW4161D (DIP8) FEATURES Pch MOSFET Driving Driving Voltage V+-10V(typ.) Wide Operating Voltage Range 3.1V to 40V PWM Control Automatic PWM/PFM Control improves power efficiency at light load. (C ver.) Wide Oscillating Frequency 50kHz to 1MHz Soft Start Function 15ms (typ.) Over Current Protection Hiccup type (A, C ver.) Latch type (B ver.) Thermal Shutdown Protection UVLO (Under Voltage Lockout) Standby Function Package Outline NJW4161R: MSOP8(VSP8) *MEETJEDEC MO-187-DA NJW4161D: DIP8 PRODUCT CLASSFICATION Part Number Version Controller Over Current Protection Package NJW4161R-A A PWM control Hiccup type MSOP8 (VSP8) NJW4161D-A A PWM control Hiccup type DIP8 NJW4161R-B B PWM control Latch type NJW4161R-C C PWM/PFM control Hiccup type Ver.2016-03-22 MSOP8 (VSP8) MSOP8 (VSP8) Operating Temperature Range General Spec. -40 C to +125 C General Spec. -40 C to +125 C General Spec. -40 C to +125 C General Spec. -40 C to +125 C -1- NJW4161 PIN CONFIGURATION REGH 1 8 GND SI 2 7 RT OUT 3 6 FB + 5 IN- V 4 NJW4161R-A NJW4161R-B NJW4161R-C NJW4161D-A PIN DESCRIPTIONS PIN NAME PIN NUMBER REGH 1 SI 2 OUT 3 V+ 4 IN- 5 FB 6 RT 7 GND 8 -2- FUNCTION Output pin of the high side regulator. Connect a bypass capacitor to stabilize a driver circuit. Current Sensing pin When difference voltage between the V+ pin and the SI pin exceeds 120mV(typ.), over current protection operates. Output pin for Power MOSFET Driving The OUT pin Voltage is clamped with V+ -10V(typ.) at the time of Low level, in order to protect a gate of Pch MOSFET. Power Supply pin Output Voltage Detecting pin Connects output voltage through the resistor divider tap to this pin in order to voltage of the IN- pin become 0.8V. Feedback Setting pin The feedback resistor and capacitor are connected between the FB pin and the IN- pin. Oscillating Frequency Setting pin by Timing Resistor. Oscillating Frequency should set between 50kHz and 1MHz. NJW4161 becomes the standby mode when make RT pin open. GND pin Ver.2016-03-22 NJW4161 BLOCK DIAGRAM V+ Enable Control VREG SI UVLO VIPK Soft Start Pulse by Pulse 10V Regulator 500k PWM Comparator OSC Error AMP 0.8V VREF Driver OUT REGH PWM/PFM Control TSD *C version only IN- RT FB GND RT State ON: Connect timing resistor to GND OFF (Stand-by): RT terminal open Ver.2016-03-22 -3- NJW4161 ABSOLUTE MAXIMUM RATINGS PARAMETER SYMBOL Supply Voltage V+ OUT pin Voltage VOUT SI pin Voltage VSI REGH pin Voltage VREGH IN- pin Voltage VINRT pin Voltage VRT IO_PEAK+ OUT pin Peak Current IO_PEAKPower Dissipation Operating Temperature Range Storage Temperature Range PD MAXIMUM RATINGS -0.3 to +45 V+-11 to V+ (*1) V+-5 to V+ (*2) V+-11 to V+ (*1) -0.3 to +6 -0.3 to +6 (*3) 1,700 (Source) 1,100 (Sink) MSOP8 (VSP8) 595 (*4) 805 (*5) DIP8 700 (Device itself) Topr Tstg -40 to +125 -50 to +150 (Ta=25°C) UNIT V V V V V V mA mW C C (*1): When Supply voltage is less than +11V, the absolute maximum rating is -0.3 to V+. (*2): When Supply voltage is less than +5V, the absolute maximum rating is -0.3 to V+. (*3): When Supply voltage is less than +6V, the absolute maximum voltage is equal to the Supply voltage. (*4): Mounted on glass epoxy board. (76.2×114.3×1.6mm:based on EIA/JDEC standard, 2Layers) (*5): Mounted on glass epoxy board. (76.2×114.3×1.6mm:based on EIA/JDEC standard, 4Layers), internal Cu area: 74.2×74.2mm RECOMMENDED OPERATING CONDITIONS PARAMETER SYMBOL MIN. + Supply Voltage V 3.1 Timing Resistor RT 1.5 Oscillating Frequency fOSC 50 REGH Capacitor CREGH 0.01 -4- TYP. – – – 0.1 MAX. 40 43 1,000 1 UNIT V k kHz F Ver.2016-03-22 NJW4161 ELECTRICAL CHARACTERISTICS (Unless otherwise noted, V+=12V, RT=10k , CREGH=0.1 F, Ta=25 C) PARAMETER Oscillator Block Oscillating Frequency 1 Oscillating Frequency 2 SYMBOL fOSC1 fOSC2 TEST CONDITION RT=3.6k RT=10k MIN. TYP. MAX. UNIT 450 180 500 200 550 220 kHz kHz -1.0% -0.1 0.8 – +1.0% 0.1 V A Error Amplifier Block Reference Voltage Input Bias Current VB IB Output Source Current IOM+ VFB=1V, VIN-=0.7V 50 90 140 A Output Sink Current IOM- VFB=1V, VIN-=0.9V 6 13 20 mA Soft Start Block Soft Start Time tSS VB=0.75V 7.5 15 24 ms VT_0 VT_50 MAXDUTY Duty=0%, VIN-=0.6V Duty=50%, VIN-=0.6V VFB=1.2V 0.32 0.63 100 0.4 0.7 – 0.48 0.77 – V V % PFMDUTY C version 5 10 15 % PWM Comparate Block Input Threshold Voltage (FB pin) Maximum Duty Cycle PWM/PFM Change Duty Cycle Current Limit Detection Block Current Limit Detection Voltage Delay Time VIPK 110 120 130 mV tDELAY – 80 – ns Over Current Protection Block Cool Down Time Timer Latch Time tCOOL tLATCH A, C version B version – – 60 10 – – ms ms ROH IO= -50mA – 3.5 7 ROL IO= +50mA – 3.5 7 50 V+-11 – 150 V+-10 500 250 V+-9 – mA V k 2.9 2.6 3.0 2.7 3.1 2.8 V V Output Block Output High Level ON Resistance Output Low Level ON Resistance REGH Output Current OUT pin Limiting Voltage OUT pin Pull-Up Resistance IO_REGH VOLIM ROUT REGH pin=V+-8V Under Voltage Lockout Block ON Threshold Voltage OFF Threshold Voltage VT_ON VT_OFF V+= L → H V+= H → L Ver.2016-03-22 -5- NJW4161 ELECTRICAL CHARACTERISTICS PARAMETER SYMBOL RT pin Enable Control Block RT pin Current at Standby IRT_STB (Unless otherwise noted, V+=12V, RT=10k , CREGH=0.1 F, Ta=25 C) TEST CONDITION MIN. TYP. MAX. UNIT 5.0 – – A – 1.5 3 mA – 2 10 A General Characteristics Quiescent Current IDD Standby Current IDD_STB RL=no load, VIN-=0.7V, VFB=0.7V VRT=OPEN POWER DISSIPATION vs. AMBIENT TEMPERATURE NJW4161R (VSP8 Package) Power Dissipation vs. Ambient Temperature (Tj=~150°C) NJW4161D (DIP8 Package) Power Dissipation vs. Ambient Temperature (Tj=~150°C) 1000 At on 4 layer PC Board (*7) At on 2 layer PC Board (*6) 800 Power Dissipation PD (mW) Power Dissipation PD (mW) 1000 600 400 200 0 800 Device itself 600 400 200 0 -50 -25 0 25 50 75 100 Ambient Temperature Ta (°C) 125 150 -50 -25 0 25 50 75 100 125 150 Ambient Temperature Ta (°C) (*6): Mounted on glass epoxy board. (76.2×114.3×1.6mm:based on EIA/JDEC standard, 2Layers) (*7): Mounted on glass epoxy board. (76.2×114.3×1.6mm:based on EIA/JDEC standard, 4Layers), internal Cu area: 74.2×74.2mm -6- Ver.2016-03-22 NJW4161 TYPICAL APPLICATIONS Non-isolated Buck Converter VIN RSENSE Q1 CIN1 4 3 2 1 V+ OUT SI REGH VOUT L CREGH CIN2 SBD COUT CFB R2 RFB NJW4161 IN- FB RT GND 5 6 7 8 R1 RT RNF CNF Q2 Ver.2016-03-22 Enable Control -7- NJW4161 TYPICAL CHARACTERISTICS 520 Oscillating Frequency 1 fOSC1 (kHz) 100 1 10 Timing Registor RT (kW) 510 505 500 495 490 485 0 100 Oscillating Frequency 2 vs. Supply Voltage (RT=10kW, Ta=25ºC) 10 20 30 Supply Voltage V+ (V) 40 Reference Voltage vs. Supply Voltage (Ta=25ºC) 0.81 208 Reference Voltage VB (V) Oscillating Frequency 2 fOSC2 (kHz) 515 480 10 210 Oscillating Frequency 1 vs. Supply Voltage (RT=3.6kW, Ta=25ºC) 206 204 202 200 198 196 194 0.805 0.8 0.795 192 190 0.79 0 40 Quiescent Current vs. Supply Voltage (RT=10kW, RL=no load, VIN-=VFB=0.7V, Ta=25ºC) 10 20 30 Supply Voltage V+ (V) Error Amplifier Block Voltage Gain, Phase vs. Frequency (V+=12V, Gain=40dB, Ta=25ºC) 60 40 180 Phase 2.5 2 1.5 1 45 135 Gain 30 90 15 45 0.5 0 0 0 -8- 0 Voltage Gain AV (dB) Quiescent Current IDD (mA) 3 10 20 30 Supply Voltage V+ (V) Phase F (deg) Oscillating Frequency fOSC (kHz) 1000 Oscillating Frequency vs. Timing Registor (V+=12V, Ta=25ºC) 10 20 30 Supply Voltage V+ (V) 40 100 1k 10k 100k Frequency f (Hz) 1M 0 10M Ver.2016-03-22 NJW4161 TYPICAL CHARACTERISTICS 220 Oscillating Frequency 2 fOSC2 (kHz) Oscillating Frequency 1 fOSC1 (kHz) 550 Oscillating Frequency 1 vs. Temperature (V+=12V, RT=3.6kW) 540 530 520 510 500 490 480 470 460 450 210 205 200 195 190 185 0.805 0.8 0.795 0.79 -50 -50 Current Limit Detection Voltage VIPK (mV) -25 0 25 50 75 100 125 150 Ambient Temperature Ta (ºC) Reference Voltage vs. Temperature (V+=12V) 0.81 Reference Voltage VB (V) 215 180 -50 135 130 125 120 115 110 105 100 -50 11 OUT pin Limited Voltage VOLIM (V) 22 20 18 16 14 12 10 8 6 -25 0 25 50 75 100 125 150 Ambient Temperature Ta (ºC) Current Limit Detection Votage vs.Temperature (V+=12V) 140 -25 0 25 50 75 100 125 150 Ambient Temperature Ta (ºC) Soft Start Time vs. Temperature (V+=12V, VB=0.75V) 24 Soft Start Time tSS (ms) Oscillating Frequency 2 vs. Temperature (V+=12V, RT=10kW) -25 0 25 50 75 100 125 150 Ambient Temperature Ta (ºC) OUT pin Limiting Voltage vs.Temperature (V+=12V) 10.5 10 9.5 9 -50 Ver.2016-03-22 -25 0 25 50 75 100 125 150 Ambient Temperature Ta (ºC) -50 -25 0 25 50 75 100 125 150 Ambient Temperature Ta (ºC) -9- NJW4161 TYPICAL CHARACTERISTICS 10 8 V+=3.1V 6 4 V+=12V, 40V 2 Output Low Level ON Resistance vs.Temperature (Io=+50mA) 30 Output Low Level ON Resistance ROL (W) Output High Level ON Resistance ROH (W) Output High Level ON Resistance vs.Temperature (Io=-50mA) 12 0 10 V+=40V 5 V+=12V 3 VT_ON 2.9 2.8 VT_OFF 2.7 -25 0 25 50 75 100 125 150 Ambient Temperature Ta (ºC) Quiescent Current vs. Temperature (RT=10kW, RL=no load, VIN-=VFB=0.7V) 3 Quiescent Current IDD (mA) Threshold Voltage (V) 15 -50 2.6 2.5 2 V+=40V 1.5 V+=12V V+=3.1V 1 0.5 0 -50 -25 0 25 50 75 100 125 150 Ambient Temperature Ta (ºC) -50 RT pin Current at Standby vs. Temperature (V+=12V) 9 8 7 6 5 -25 0 25 50 75 100 125 150 Ambient Temperature Ta (ºC) Standby Current vs. Temperature (VRT=Open) 10 Standby Current IDD_STB (μA) RT pin Current at Standby IRT_STB (μA) V+=3.1V -25 0 25 50 75 100 125 150 Ambient Temperature Ta (ºC) Under Voltage Lockout Voltage vs. Temperature 3.1 9 8 7 6 V+=40V 5 4 V+=12V V+=3.1V 3 2 1 4 0 -50 - 10 - 20 0 -50 10 25 -25 0 25 50 75 100 125 150 Ambient Temperature Ta (ºC) -50 -25 0 25 50 75 100 125 150 Ambient Temperature Ta (ºC) Ver.2016-03-22 NJW4161 ApplicationNJW4161 Manual Technical Information Description of Block Features 1. Basic Functions / Features Error Amplifier Section (Error AMP) 0.8V±1% precise reference voltage is connected to the non-inverted input of this section. To set the output voltage, connects converter's output to inverted input of this section (IN- pin). If requires output voltage over 0.8V, inserts resistor divider. This AMP section has high gain and external feedback pin (FB pin). It is easy to insert a feedback resistor and a capacitor between the FB pin and the IN- pin, making possible to set optimum loop compensation for each type of application. Oscillating Circuit Section (OSC) Oscillating frequency can be set by inserting resistor between the RT pin and GND. Referring to the sample characteristics in "Timing Resistor and Oscillating Frequency", set oscillation between 50kHz and 1MHz. NJW4161 becomes the standby mode when make RT pin open. Refer to the description of the standby function PWM Comparator Section (PWM) PWM comparator receives the signal of the error amplifier and the triangular wave, and controls the duty ratio between 0% and 100%. The timing chart is shown in Fig.1. FB pin Voltage OSC Waveform (IC internal) High OUT pin Low GND Fig. 1. Timing Chart PWM Comparator and SW pin PWM/PFM Control Feature (PWM/PFM Control: Only C version) NJW4161 C version features automatic PWM/PFM control, improving power efficiency at light load. Most of the application circuit loss occurs when the switching element performs, and therefore, the switching pulse is skipped to minimize unnecessary switching loss at times of low load. When PWM comparator duty is no greater than 10% typ., switching output is stopped and switching is skipped to next period. In the case of high step-down ratio applications, a duty of steady operation may fall to 10% or less. Under such conditions, the PWM/PFM switch feature always operates. Therefore for high step-down ratio applications, use the PWM control type (A version or B version). Power Supply, GND pin (V+ and GND) In line with MOSFET drive, current flows into the IC according to frequency. If the power supply impedance provided to the power supply circuit is high, it will not be possible to take advantage of IC performance due to input voltage fluctuation. Therefore insert a bypass capacitor more than 0.1 F close to the V+ pin – the GND pin connection in order to lower high frequency impedance. Ver.2016-03-22 - 11 - NJW4161 NJW4161Application Manual Technical Information Description of Block Features (Continued) Driver Section , 10V Regulator Section (Driver, 10V Regulator) The output driver circuit is configured a totem pole type, it can efficiently drive a Pch MOSFET switching device. When the output is low level, the OUT pin voltage is clamped with V+ -10V (typ.) by the internal regulator to protect gate of Pch MOSFET. (Ref. Fig.2. OUT pin) V+ V+ VIN CREGH 10V Regulator CIN2 500kW VGS From PWM Comparator OUT Driver RG REGH To turn off Pch MOSFET High Level Output V+ V+-10V GND To turn on Pch MOSFET Low Level Output OFF ON OFF ON Fig. 2. Driver Circuit and the OUT pin Voltage OUT pin Differential Voltage V+-VOUT (V) When supply voltage is decreasing, gate drive voltage output from the OUT pin is also decreasing. Fig.3. shows the example of the “OUT pin Differential Voltage vs. supply voltage” characteristic The optimum drive ability of MOSFET depends on the oscillating frequency and the gate capacitance of MOSFET. OUT pin Differential Voltage vs. Supply Voltage (IO=0mA, Ta=25ºC) 12 10 8 6 4 2 0 0 2 4 6 8 10 Supply Voltage V+ (V) 12 14 Fig. 3. OUT pin Differential Voltage vs. Supply Voltage Characteristic - 12 - Ver.2016-03-22 NJW4161 ApplicationNJW4161 Manual Technical Information Description of Block Features (Continued) 2. Additional and Protection Functions / Features Under Voltage Lockout (UVLO) The UVLO circuit operating is released above V+=3.0V(typ.) and IC operation starts. When power supply voltage is low, IC does not operate because the UVLO circuit operates. There is 300mV width hysteresis voltage at rise and decay of power supply voltage. Hysteresis prevents the malfunction at the time of UVLO operating and releasing. Soft Start Function (Soft Start) The output voltage of the converter gradually rises to a set value by the soft start function. The soft start time is 15ms (typ.). It is defined with the time of the error amplifier reference voltage becoming from 0V to 0.75V. The soft start circuit operates after the release UVLO and/or recovery from thermal shutdown. 0.8V Vref, IN- pin Voltage OSC Waveform (IC internal) High OUT pin Low GND UVLO(3.0V typ.) Release, Standby, Recover from Thermal Shutdown Soft Start time: tSS=15ms(typ.) to VB=0.75V Steady Operaton Soft Start effective period to VB=0.8V Fig. 4. Startup Timing Chart Ver.2016-03-22 - 13 - NJW4161 NJW4161Application Manual Technical Information Description of Block Features (Continued) Over Current Protection Circuit At when the potential difference between the V+ pin and the SI pin becomes 120mV or more, the over current protection circuit is stopped the switch output. The switching current is detected by inserted current sensing resistor (RSENSE) between the V+ pin and the SI pin. There are Hiccup type of the automatic return and Latch type of the switching stop in NJW4161. Hiccup Type: A version, C version Latch Type: B version Hiccup Type (A version, C version) The NJW4161-A and -C output returns automatically along with release from the over current condition. Fig.5. shows the timing chart of the Hiccup type over current protection detection. When the IN- pin voltage is 0.5V or lower(less), the switching operation stops after the overcurrent detection continued 8 pulses. After NJW4161 switching operation was stopped, it restarts by soft start function after the cool down time of approx. 60ms (typ.). IN- pin Voltage 0.8V 0.5V 0V Oscillating Frequency fosc High OUT pin Low GND RSENSE Voltage VIPK 0 Pulse Count :8 pulse Cool Down time tCOOL=60ms typ. Pulse by Pulse Static Status Detect Overcurrent Soft Start After cool-down time, NJW4161 restarts automatically. Fig. 5. Hiccup Type Timing Chart at Over Current Detection (A version, C version) - 14 - Ver.2016-03-22 NJW4161 ApplicationNJW4161 Manual Technical Information Description of Block Features (Continued) Latch Type (B version) When an overcurrent continues, NJW4161-B stops and maintains a stop state. Fig.6. shows the timing chart of the Latch type over current protection detection. When the IN- pin voltage is 0.5V or lower(less), the switching operation stops after the overcurrent detection continued 10ms. After NJW4161 stopped, it restarts with a soft start by UVLO or standby input. It does not latch, when it operation stops by thermal shutdown. IN- pin Voltage 0.8V 0.5V 0V Oscillating Frequency fosc High OUT pin Low GND RSENSE Voltage VIPK 0 Timer Latch time tLATCH=10ms typ. Stop Switching (Latch Mode) Pulse by Pulse Static Status Detect Overcurrent Soft Start Restart by UVLO and Stanby. Fig. 6. Latch Type Timing Chart at Over Current Detection (B version) The current waveform contains high frequency superimposed noises due to the parasitic elements of MOSFET, the inductor and the others. Depending on the application, inserting RC low-pass filter between current sensing resistor (RSENSE) and the SI pin to prevent the malfunction due to such noise. The time constant of RC low-pass filter should be equivalent to the spike width (t RLF CLF) as a rough guide (Fig. 7). Or the insertion is effective with a bypass capacitor near the source pin of the MOSFET, too. Spike Noise Filter V+ Current Limit Detection VIPK CLF VIN RSENSE SI RLF t Pulse by Pulse Current Waveform example CIN3 Bypass Capacitorr OUT RG Fig. 7. Current Waveform and Filter Circuit Ver.2016-03-22 - 15 - NJW4161 NJW4161Application Manual Technical Information Description of Block Features (Continued) Thermal Shutdown Function (TSD) When Junction temperature of the NJW4161 exceeds the 160°C*, internal thermal shutdown circuit function stops SW function. When junction temperature decreases to 145°C* or less, SW operation returns with soft start operation. The purpose of this function is to prevent malfunctioning of IC at the high junction temperature. Therefore it is not something that urges positive use. You should make sure to operate within the junction temperature range rated (150 C). (* Design value) Standby Function To set the NJW4161 to standby status, insert MOSFET or others between the timing resistor RT and GND in order to set high impedance. (Fig. 8.) It is necessary to make RT pin current less than IRT_STB=5 A to a standby mode, therefore choose MOSFET of the small leak current. If large capacitor is connected to RT pin when using a standby function, it becomes impossible to shift to an operating state from standby. When connect a bypass capacitor to RT pin, use capacitor of 100 pF or less. Moreover, when changing from operation to a standby state, ON time may occur about 2 s by circuit delay. Enable Control OSC RT RT Enable Control Signal RT State ON: Connect timing resistor to GND OFF (Stand-by): RT pin open RONOFF Fig. 8. When using a standby function - 16 - Ver.2016-03-22 NJW4161 ApplicationNJW4161 Manual Technical Information Application Information Inductors Current Peak Current Ipk Large currents flow into inductor, therefore you must provide current capacity that does not Inductor (1) Continuous saturate. Current IL Conduction Mode Reducing L, the size of the inductor can be smaller. However, peak current increases and (2) Critical Mode adversely affecting efficiency. (3) Discontinuous 0 On the other hand, increasing L, peak current Conduction Mode can be reduced at switching time. Therefore Frequency tON tOFF fOSC conversion efficiency improves, and output ripple voltage reduces. Above a certain level, increasing inductance windings increases loss (copper loss) Fig. 9. Inductor Current State Transition due to the resistor element. Ideally, the value of L is set so that inductance current is in continuous conduction mode. However, as the load current decreases, the current waveform changes from (1) CCM: Continuous Conduction Mode (2) Critical Mode (3) DCM: Discontinuous Conduction Mode (Fig. 9.). In discontinuous mode, peak current increases with respect to output current, and conversion efficiency tend to decrease. Depending on the situation, increase L to widen the load current area to maintain continuous mode. Catch Diode When the switch element is in OFF cycle, power stored in the inductor flows via the catch diode to the output capacitor. Therefore during each cycle current flows to the diode in response to load current. Because diode's forward saturation voltage and current accumulation cause power loss, a Schottky Barrier Diode (SBD), which has a low forward saturation voltage, is ideal. An SBD also has a short reverse recovery time. If the reverse recovery time is long, through current flows when the switching transistor transitions from OFF cycle to ON cycle. This current may lower efficiency and affect such factors as noise generation. Switching Element You should use a switching element (Pch MOSFET) that is specified for use as a switch. And select sufficiently low RON MOSFET at less than VGS=10V because the NJW4161 OUT pin voltage is clamped V+-10V (typ.). However, when the supply voltage of the NJW4161 is low, the OUT pin voltage becomes low. You should select a suitable MOSFET according to the supply voltage specification. (Ref. Driver section) Large gate capacitance is a source of decreased efficiency. That is charge and discharge from gate capacitance delays switching rise and fall time, generating switching loss. The spike noise might occur at the time of charge/discharge of gate by the parasitic inductance element. You should insert resistance between the OUT pin and the gate and limit the current for gate protection when gate capacitance is small. However, it should be noted that the efficiency might decrease because the shape of waves may become duller when resistance is too large. The last fine-tuning should be done on the actual device and equipment. Ver.2016-03-22 - 17 - NJW4161 NJW4161Application Manual Technical Information Application Information (Continued) Input Capacitor Transient current flows into the input section of a switching regulator responsive to frequency. If the power supply impedance provided to the power supply circuit is large, it will not be possible to take advantage of the NJW4161 performance due to input voltage fluctuation. Therefore insert an input capacitor as close to the MOSFET as possible. Output Capacitor An output capacitor stores power from the inductor, and stabilizes voltage provided to the output. When selecting an output capacitor, you must consider Equivalent Series Resistance (ESR) characteristics, ripple current, and breakdown voltage. Also, the ambient temperature affects capacitors, decreasing capacitance and increasing ESR (at low temperature), and decreasing lifetime (at high temperature). Concerning capacitor rating, it is advisable to allow sufficient margin. Output capacitor ESR characteristics have a major influence on output ripple noise. A capacitor with low ESR can further reduce ripple voltage. Be sure to note the following points; when ceramic capacitor is used, the capacitance value decreases with DC voltage applied to the capacitor. - 18 - Ver.2016-03-22 NJW4161 ApplicationNJW4161 Manual Technical Information Application Information (Continued) Board Layout In the switching regulator application, because the current flow corresponds to the oscillating frequency, the substrate (PCB) layout becomes an important. You should attempt the transition voltage decrease by making a current loop area minimize as much as possible. Therefore, you should make a current flowing line thick and short as much as possible. Fig. 10. shows a current loop at step-down converter. SW VIN CIN L SW COUT SBD VIN CIN L COUT SBD NJW4161 NJW4161 (a) Buck Converter SW ON (b) Buck Converter SW OFF Fig. 10. Current Loop at Buck Converter Concerning the GND line, it is preferred to separate the power system and the signal system, and use single ground point. The voltage sensing feedback line should be as far away as possible from the inductance. Because this line has high impedance, it is laid out to avoid the influence noise caused by flux leaked from the inductance. Fig. 11. shows example of wiring at buck converter. Fig. 12 shows the PCB layout example. SW VIN CIN L VOUT SBD COUT RL OUT (Bypass Capacitor) V+ RFB CFB NJW4161 INRT RT R2 GND Separate Digital(Signal) GND from Power GND R1 To avoid the influence of the voltage drop, the output voltage should be detected near the load. Because IN- pin is high impedance, the voltage detection resistance: R1/R2 is put as much as possible near IC(IN-). Fig. 11. Board Layout at Buck Converter Ver.2016-03-22 - 19 - NJW4161 NJW4161Application Manual Technical Information Application Information (Continued) Feed back signal CFB RFB R2 RNF CNF RT R1 Signal GND Area CREGH CIN2 IC CLF RG RLF VIN RSENSE FET L VOUT CSENSE CIN1 SBD GND IN COUT GNDOUT Power GND Area Connect Signal GND line and Power GND line on backside pattern Fig. 12. Layout Example (top view) - 20 - Ver.2016-03-22 NJW4161 ApplicationNJW4161 Manual Technical Information Calculation of Package Power You should consider derating power consumption under using high ambient temperature. Moreover, you should consider the power consumption that occurs in order to drive the switching element. Supply Voltage: Quiescent Current: Oscillating Frequency: Gate charge amount: V+ IDD fOSC Qg The gate of MOSFET has the character of high impedance. The power consumption increases by quickening the switching frequency due to charge and discharge the gate capacitance. Power consumption: PD is calculated as follows. PD = (V+ IDD) + (V+ Qg fOSC) [W] You should consider temperature derating to the calculated power consumption: PD. You should design power consumption in rated range referring to the power dissipation vs. ambient temperature characteristics. Ver.2016-03-22 - 21 - NJW4161 NJW4161Application Manual Technical Information Application Design Examples Step-Down Application Circuit Input Voltage: VIN=12V Output Voltage: VOUT=5V Output Current: IOUT=3A Oscillation frequency: fosc=345kHz VIN=12V RSENSE1 30mW CIN1 10mF/50V, 2pcs. CSENSE 1mF/50V RLF1 22W CLF1 2,200pF RG 0W CREGH 0.1mF CIN2 0.1mF/50V 4 3 2 1 V+ OUT SI REGH NJW4161 IN- FB RT GND 5 6 7 8 Q1 VOUT=5V L1 10mH/6.7A CFB 180pF SBD COUT 47mF/16V RFB 1kW R2 68kW R1 13kW RT 5.6kW RNF 6.8kW Reference IC1 1 NJW4161R Q1 L1 SBD CIN1 CIN2 COUT CREGH CNF1 CFB CLF1 CSENSE R1 R2 RNF RFB RG 1 1 1 2 1 1 1 1 1 1 1 1 1 1 1 1 FDD4243 CLF12555T-100M DE5SC4M UMK325BJ106MM-P 0.1 F GRM32EB31C476KE15L 0.1 F 6,800pF 180pF 2,200pF UMK212BJ105KG-T 13k 68k 6.8k 1k 0 (Short) Description MOSFET Drive Switching Regulator for Buck Converter IC Pch MOSFET 40V, 14A Inductor 10 H, 6.7A Schottky Diode 40V, 5A Ceramic Capacitor 3225 10 F, 50V, X5R Ceramic Capacitor 1608 0.1 F, 50V, B Ceramic Capacitor 3225 47 F, 16V, B Ceramic Capacitor 1608 0.1 F, 25V, B Ceramic Capacitor 1608 6,800pF, 50V, B Ceramic Capacitor 1608 180pF, 50V, CH Ceramic Capacitor 1608 2,200pF, 50V, B Ceramic Capacitor 2012 1 F, 50V, B Resistor 1608 13k , 1%, 0.1W Resistor 1608 68k , 1%, 0.1W Resistor 1608 6.8k , 5%, 0.1W Resistor 1608 1k , 5%, 0.1W Resistor 1608 0 , 0.1W RSENSE1 1 LPS1R030FE Current Sense Resistor 30m , ±1%, 1W RLF1 RT 1 1 22 5.6k Resistor 1608 22 , ±5%, 0.1W Resistor 1608 5.6k , 1%, 0.1W - 22 - Qty. CNF1 6,800pF Part Number Manufacturer New JRC Fairchild TDK Shindengen Taiyo yuden Std. Murata Std. Std. Std. Std. Taiyo yuden Std. Std. Std. Std. Std. Hokuriku Electric Industry Std. Std. Ver.2016-03-22 NJW4161 ApplicationNJW4161 Manual Technical Information Application Design Examples (Continued) Setting Oscillation Frequency From the Oscillation frequency vs. Timing Resistor Characteristic, RT=5.6 [k ], t=2.9 [ s] at fosc=345kHz. Peak Current: Ipk Inductance Current: IL Step-down converter duty ratio is shown with the following equation: Duty VOUT VF VIN 100 5 0.4 100 12 Output Current: IOUT 45 % 0 Period: t Frequency: fOSC=1/t Therefore, tON=1.31 [ s], tOFF=1.59 [ s] tON tOFF Fig. 13. Inductor Current Waveform Selecting Inductance IL is Inductance ripple current. When to IL= output current 30%: IL = 0.3 IOUT = 0.3 3 = 0.9 [A] This obtains inductance L. VDS_RON is drop voltage by MOSFET on resistance. L VIN VDS RON VOUT IL t ON 12 0.2 5 1.31 0.9 10 [ H] Inductance L is a theoretical value. The optimum value varies according such factors as application specifications and components. Fine-tuning should be done on the actual device. This obtains the peak current Ipk at switching time. IL 0 .9 Ipk I OUT 0 .3 3.45 [ A ] 2 2 The current that flows into the inductance provides sufficient margin for peak current at switching time. In this application circuit example, use L=10 H/6.7A. Setting Over Current Detection In this application circuit example, current limitation value: ILIMIT is set to Ipk=4A. ILIMIT = VIPK / RSC = 120mV / 30m =4 [A] The limit value increases slightly according to the response time between the overcurrent detection with the SI pin and the OUT pin outputs stop signal. ILIMIT _ DELAY Ver.2016-03-22 ILIMIT VIN L t DELAY 4.0 12 10 80n 4.1 [ A ] - 23 - NJW4161 NJW4161Application Manual Technical Information Application Design Examples (Continued) Selecting the Input Capacitor The input capacitor is an important component to decrease power line impedance. The input capacitor selection should be determined by the input ripple current and the maximum input voltage of the capacitor rather than its capacitance value. The effective input current can be expressed by the following formula: IRMS IOUT VOUT VIN VOUT [A] VIN In the above formula, the maximum current is estimated when VIN = 2 VOUT, and the result in this case is: IRMS = IOUT (MAX) 2. When selecting the input capacitor, carry out an evaluation based on the application, and use a capacitor that has adequate margin. Selecting the Output Capacitor The output capacitor is an important component that determines output ripple noise. Equivalent Series Resistance (ESR), ripple current and capacitor breakdown voltage are important in determining the output capacitor. The output ripple noise can be expressed by the following formula: Vripple (p IL p) ESR 1 8 f OSC C OUT [V] When selecting output capacitance, select a capacitor that allows for sufficient ripple current. The effective ripple current that flows in a capacitor (Irms) is calculated by the following equation: Irms IL 0.9 2 3 2 3 260 [mArms ] Considering sufficient margin, use a capacitor that fulfills the above spec. In this application circuit example, use COUT=47 F/16V. Setting Output Voltage The output voltage VOUT is determined by the relative resistances of R1, R2. The current that flows in R1, R2 must be a value that can ignore the bias current that flows in ER AMP. VOUT - 24 - R2 1 R1 VB 68k 13k 1 0.8 4.98 [ V ] Ver.2016-03-22 NJW4161 ApplicationNJW4161 Manual Technical Information Compensation design example A switching regulator requires a feedback circuit for stable output. Because the frequency characteristics of the application change according to an inductance, an output capacitor and so on, the ideal compensation constant is to keep the necessary phase for stable operation and to obtain the maximum band. The tuning with an actual application is important to determine the compensation constants. Therefore, to finally select the constants with measurement in consideration of the application specifications. Pole Gain -20dB/dec Phase 0 -45 -90 fP/10 fP 10fP Frequency Pole Feedback and Stability Basically, the feedback loop should be designed as the open loop phase shift at the point where the loop gain is 0 dB is less than -180 . Furthermore, the loop characteristics should have margin in consideration of ringing and oscillation tolerance caused by load fluctuations. The feedback circuit of the NJW4161 can be arbitrarily be designed. Therefore to enable optimizing the poles and zeros which are important parameters for loop compensation. +20dB/dec Gain Zero Phase +90 +45 0 fZ/10 The characteristics of the poles and zeros are shown in Fig. 14. Poles: The gain has a slope of -20 dB/dec, and the phase shifts -90 . Zeros: The gain has a slope of +20 dB/dec, and the phase shift +90 . fZ 10fZ Frequency Zero Fig. 14. Characteristics of Pole and Zero If the number of factors constituting poles is defined as “n”, the change in the gain and phase will be “n”-fold. This also applies to zeros as well. The poles and zeros are in a reciprocal relationship, so if there is one factor for each pole and zero, they will cancel each other. Configuration of the compensation circuit VIN + PV LC Gain Buffer SW L VOUT RESR CFB R2 COUT ER AMP PWM CFB Vref =0.8V RFB IN- FB R1 CNF RNF C1(option) Fig. 15. Compensation Circuit Configuration Ver.2016-03-22 - 25 - NJW4161 NJW4161Application Manual Technical Information Compensation Design (Continued) Poles and zeros due to the inductance and output capacitor Double poles fP(LC) are generated by the inductance and output capacitor. Simultaneously, single zeros fZ(ESR) are generated by the output capacitor and ESR. Each pole and zero is expressed by the following formula: f Z(ESR ) 1 fP(LC) 2 C OUTR ESR 1 2 LC OUT If the ESR of the output capacitor is high, fZ(ESR) will be located in the vicinity of fP(LC). In such application, the zero fZ(ESR) compensates the double poles fP(LC) and it has tendency for stability accordingly. However, if the ESR of the output capacitor is low, fZ(ESR) shifts to the high frequency and the phase is shifted -180 by fP(LC). The NJW4161 compensation circuit can compensate by using zeros of fZ1 and fZ2. Gain (dB) Poles and zeros due to error amplifier The single poles and zeros generated by the error amplifier LC Gain are obtained using the following formula. Zero Pole 1 fP1 1 f Z1 R1 R2 Loop 2 CNF A V 2 CNFRNF Gain R1 R2 (Av: Amplifier Open Loop Gain=80dB) fZ 2 1 2 CFBR2 Double pole -40dB/dec 0dB frequency * Gain increase due to Zero 1 fP 2 2 C FB R FB fP 3 R1 R2 R1 R2 1 2 C1 R NF -20dB/dec Compensation Gain (Option) fZ1 and fZ2 are located on both sides of fP(LC). Because the inductance and the output capacitor vary, they are each set using the following as a rough guide: fP(LC) 0.5-fold to 0.9-fold fP(LC) 1.1-fold to 2.0-fold fP1 fZ1 or fZ2 fP(LC) fP2 fP3 fZ(ESR) Fig16. Loop Gain examples There is also a method in which fZ1 and fZ2 are located at positions lower than fP(LC). Because there is a tendency to increase the phase shift and the gain becomes high, it can be expected that the response will improve. However, there is a tendency for the phase margin to become insufficient, so care is necessary. The fP1 creates poles in the low frequency band due to the Miller effect of the error amplifier. The stability becomes better as fP1 becomes lower. On the other hand, the frequency characteristics do not improve, so the response is adversely affected. The fP1 is set a frequency gain of fP(LC) is 20dB as a rough guide. If the open loop gain of the error amplifier is made 80 dB, design is carried out using fP1 < fP(LC) 103 (= 60 dB) as a rough guide. Above several 100 kHz, various poles are generated, so the upper limit of the frequency range where the loop gain is 0 dB is set to fifth (1/5) to tenth (1/10) of oscillation frequency. The fZ(ESR) in the high frequency region sometimes causes a loop gain to be generated (See Fig.16 Loop Gain “). Using fP2 and fP3, perform adjustment with the NJW4161 in an actual application, so as to adequately reduce the loop gain in the high frequency region. - 26 - Ver.2016-03-22 NJW4161 ApplicationNJW4161 Manual Technical Information ■Application Characteristics ● PWM control : A version, B version Efficiency vs. Output Current (PWM ver., VOUT=5V, Ta=25ºC) 100 5.2 fOSC=345kHz L=10 H 90 Output Voltage VOUT (V) (%) VIN=6V VIN=18V Efficiency 60 50 fOSC=345kHz L=10 H 5.15 80 70 Output Voltage vs. Output Current (PWM ver., Ta=25ºC) VIN=12V 40 30 20 5.1 VIN=6V, 12V, 18V 5.05 5 4.95 4.9 4.85 10 0 4.8 1 10 100 1000 Output Current IOUT (mA) 10000 1 10 100 1000 Output Current IOUT (mA) 10000 ● PWM/PFM Control : C version Efficiency vs. Output Curent (PWM/PFM ver., VOUT=5V, Ta=25ºC) 100 5.2 fOSC=345kHz L=10 H 90 Output Voltage VOUT (V) (%) VIN=6V VIN=18V Efficiency 60 50 fOSC=345kHz L=10 H 5.15 80 70 Output Voltage vs. Output Current (PWM/PFM ver., Ta=25ºC) VIN=12V 40 30 20 5.1 5.05 VIN=6V, 12V, 18V 5 4.95 4.9 4.85 10 0 4.8 1 Ver.2016-03-22 10 100 1000 Output Current IOUT (mA) 10000 1 10 100 1000 Output Current IOUT (mA) 10000 - 27 - NJW4161 MEMO [CAUTION] The specifications on this databook are only given for information , without any guarantee as regards either mistakes or omissions. The application circuits in this databook are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. - 28 - Ver.2016-03-22
NJW4161R-B-TE1 价格&库存
很抱歉,暂时无法提供与“NJW4161R-B-TE1”相匹配的价格&库存,您可以联系我们找货
