PTFA080551E-V4-R0
PTFA080551E-V4-R0
    WOLFSPEED
    H-36265-2
    PTFA080551E-V4-R0
PTFA080551E-V4-R0 数据手册
48*%) 48*%* 'SRJMHIRXMEP0MQMXIH-RXIVREP(MWXVMFYXMSR 8LIVQEPP])RLERGIH ,MKL 4S[IV 6* 0(137 *)8W ;z1,^ (IWGVMTXMSR 8LI 48*%) ERH 48*%* EVI [EXX 0(137 *)8W HIWMKRIHJSV)(+)ERH'(1%TS[IVEQTPMJMIVETTPMGEXMSRWMRXLI XS1,^FERH*IEXYVIWMRGPYHIMRTYXQEXGLMRKERHXLIVQEPP] IRLERGIHTEGOEKIW [MXL WPSXXIH SVIEVPIWW JPERKIW 1ERYJEGXYVIH [MXL -RJMRISR W EHZERGIH 0(137 TVSGIWW XLIWI HIZMGIW TVSZMHI I\GIPPIRXXLIVQEPTIVJSVQERGI ERHWYTIVMSVVIPMEFMPMX] 48*%* 4EGOEKI , *IEXYVIW Three-carrier CDMA2000 Performance VDD = 28 V, IDQ = 450 mA, ƒ = 960 MHz 40 48*%) 4EGOEKI , y &VSEHFERH MRXIVREP QEXGLMRK y 8]TMGEP)(+)TIVJSVQERGI %ZIVEKISYXTYXTS[IV!; +EMR!H& )JJMGMIRG]! y 8]TMGEP';TIVJSVQERGI 3YXTYXTS[IVEX4zH&!; +EMR!H& )JJMGMIRG]! y -RXIKVEXIH)7(TVSXIGXMSR,YQER&SH]1SHIP 'PEWW QMRMQYQ y )\GIPPIRXXLIVQEPWXEFMPMX]PS[,'-HVMJX y 'ETEFPISJLERHPMRK:7;6$:; '; SYXTYXTS[IV y 4FJVIIERH6S,7GSQTPMERX -35 Efficiency 35 -40 30 -45 25 ACP Low 20 -50 -55 ACP Up 15 10 -60 ALT Up -65 5 0 -70 29 31 33 35 37 39 41 43 Output Power, Avg. (dBm) 6*'LEVEGXIVMWXMGW )(+)1IEWYVIQIRXW RSXWYFNIGXXSTVSHYGXMSRXIWX{ZIVMJMIHF]HIWMKRGLEVEGXIVM^EXMSRMR-RJMRISRXIWXJM\XYVI :((!:-(5!Q%4398!;%:+g!1,^ 'LEVEGXIVMWXMG 7]QFSP 1MR 8]T 1E\ 9RMX ):1 617 {  { 1SHYPEXMSR7TIGXVYQ$O,^ %'46 { z { H&G 1SHYPEXMSR7TIGXVYQ$O,^ %'46 { z { H&G +TW {  { H& {  { )VVSV:IGXSV1EKRMXYHI +EMR K( (VEMR)JJMGMIRG] All published data at TCASE = 25°C unless otherwise indicated *See Infineon distributor for future availability. )7()PIGXVSWXEXMGHMWGLEVKIWIRWMXMZIHIZMGI{SFWIVZILERHPMRKTVIGEYXMSRW (EXE7LIIX SJ 6IZ     48*%) 48*%* 'SRJMHIRXMEP0MQMXIH-RXIVREP(MWXVMFYXMSR 8]TMGEP4IVJSVQERGI HEXEXEOIRMRETVSHYGXMSRXIWXJM\XYVI Edge EVM and Modulation Spectrum vs. Quiescent Current EDGE Modulation Spectrum Performance VDD = 28 V, IDQ = 450 mA, ƒ = 959.8 MHz VDD = 28 V, ƒ = 959.8 MHz, POUT = 22 W 2.1 0 -20 1.9 Efficiency -30 EVM 1.7 -40 1.5 -50 400 kHz 1.3 1.1 55 -60 -20 45 -40 35 400 kHz -60 25 -70 0.9 600 kHz 0.7 0.35 0.40 0.45 0.50 0.55 -80 -80 15 600 kHz -100 -90 0.60 5 32 34 36 38 40 42 44 46 Output Power (dBm) Quiescent Current (A) EDGE EVM Performance Intermodulation Distortion vs. Output Power VDD = 28 V, IDQ = 450 mA, ƒ = 959.8 MHz (as measured in a broadband circuit) VDD = 28 V, IDQ = 450 mA, ƒ1 = 959 MHz, ƒ2 = 960 MHz 10 55 -20 8 45 -30 35 -40 4 25 -50 2 15 -60 5 -70 6 Efficiency 3rd Order 5th EVM 7th 0 32 34 36 38 40 42 44 46 30 Output Power (dBm) (EXE7LIIX 33 36 39 42 45 48 Output Power, Avg. (dBm) SJ 6IZ     48*%) 48*%* 'SRJMHIRXMEP0MQMXIH-RXIVREP(MWXVMFYXMSR 8]TMGEP4IVJSVQERGI GSRX IM3 vs. Output Power at Selected Biases Linear Broadband Performance VDD = 28 V, ƒ1 = 959, ƒ 2 = 960 MHz VDD = 28 V, IDQ = 600 mA, POUT Avg = 44.39 dBm 51 -20 300 mA 450 m A -30 40 50 600 mA 49 20 48 -40 -50 10 Efficiency 47 0 46 -10 45 31 33 35 37 39 41 43 45 47 -20 Return Los s 44 860 -60 29 30 Gain 880 900 920 940 -30 960 Frequency (MHz) Output Power, Avg. (dBm) Power Sweep Gain & Efficiency vs. Output Power VDD = 28 V, ƒ = 960 MHz VDD = 28 V, IDQ = 600 mA, ƒ = 960 MHz 19 IDQ = 600 m A 18 21 70 20 60 19 Gain 50 18 17 40 IDQ = 450 mA 17 IDQ = 300 m A 30 16 16 Efficiency 15 15 20 14 36 38 40 42 44 46 48 50 Output Power (dBm ) (EXE7LIIX 10 36 38 40 42 44 46 48 50 Output Power (dBm) SJ 6IZ     48*%) 48*%* 'SRJMHIRXMEP0MQMXIH-RXIVREP(MWXVMFYXMSR 8]TMGEP4IVJSVQERGI GSRX Output Power (P–1dB) vs. Drain Voltage IS-95 CDMA Performance IDQ = 600 m A, ƒ = 960 MHz VDD = 28 V, IDQ = 450 mA, ƒ = 960 MHz 51 TCASE = 25°C 45 0 TCASE = 90°C 40 50 49 35 -20 30 -30 25 48 47 46 24 26 28 30 -40 ACP FC – 0.75 MHz 20 -50 15 -60 10 -70 5 45 -10 Efficiency -80 ACPR FC + 1.98 MHz 0 32 -90 29 Drain Voltage (V) 31 33 35 37 39 41 43 Output Power, Avg. (dBm) Bias Voltage vs. Temperature Voltage normalized to typical gate voltage, series show current 0.778 A 1.03 1.55 A 1.02 3.11 A 1.01 3.88 A 4.66 A 1.00 5.44 A 0.99 6.22 A 0.98 7.00 A 0.97 0.96 -20 0 20 40 60 80 100 Case Temperature (°C) (EXE7LIIX SJ 6IZ     48*%) 48*%* 'SRJMHIRXMEP0MQMXIH-RXIVREP(MWXVMFYXMSR &VSEHFERH'MVGYMX-QTIHERGI D Z Source Z Load G S *VIUYIRG] >7SYVGI; >0SEH; 1,^ 6 N< 6 N<   z  z   z  z   z     z  z   z   7IIRI\XTEKIJSVGMVGYMXMRJSVQEXMSR (EXE7LIIX SJ 6IZ     48*%) 48*%* 'SRJMHIRXMEP0MQMXIH-RXIVREP(MWXVMFYXMSR 6IJIVIRGI'MVGYMX C1 0.001µF R2 1.3K 1 R1 1.2K 1 QQ1 LM7805 Q1 BCP56 V DD C2 0.001µF C3 0.001µF R3 2K 1 R4 2K 1 R5 5.1 1 R6 10 1 L1 V DD C4 10µF 35V C5 0.1µF R7 5.1K C6 0.1µF C7 0.01µF C8 33pF C12 33pF C14 10µF 50V C13 1µF "5 R8 10 1 C9 33pF R F_IN "1 "3 "4 C10 3.3pF C11 1.0pF C16 10µF 50V "6 C23 33pF DUT "2 C15 0.1µF "8 "9 "10 "11 R F_OUT C22 0.3pF "7 L2 C17 33µF C18 1µF C19 10µF 50V C20 0.1µF C21 10µF 50V Reference circuit schematic diagram for ƒ = 960 MHz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in_01 A080551out_01 a080551ef_assy- 06-03-14 Reference circuit assembly diagram (not to scale)* 'SQTSRIRX (IWGVMTXMSR 7YKKIWXIH1ERYJEGXYVIV 42SV'SQQIRX ''' ' '''' '''' ' ' ' ' ' ' '''' ' 00 5 55 6 6 6 6 66 66 'ETEGMXSV™* 8ERXEPYQGETEGMXSV™*: 'ETEGMXSV™* 'IVEQMGGETEGMXSVT* (MKM/I] (MKM/I] (MKM/I] %8' 4'''82( 2( 4''&'82( &  'ETEGMXSV™* 'IVEQMGGETEGMXSVT* 'IVEQMGGETEGMXSVT* 'ETEGMXSV™* 8ERXEPYQGETEGMXSV™*: 'IVEQMGGETEGMXSVT* *IVVMXIQQ 8VERWMWXSV :SPXEKI VIKYPEXSV 'LMT6IWMWXSVOSLQW 'LMT6IWMWXSVOSLQW 'LMT6IWMWXSVOSLQW 4SXIRXMSQIXIVOSLQW 'LMT6IWMWXSVOSLQW 'LMT6IWMWXSVSLQW %8' %8' %8' %8' +EVVIXX)PIGXVSRMGW %8' )PRE 1EKRIXMGW -RJMRISR 8IGLRSPSKMIW 2EXMSREP 7IQMGSRHYGXSV (MKM/I] (MKM/I] (MKM/I] (MKM/I] (MKM/I] (MKM/I] &  & 6 & 6 ' 847)/6 & 6 &(77 &'4 01 4/+'82( 4/+'82( 4/)'82( ;)862( 4/)'82( 4)'82( *Gerber Files for this circuit available on request (EXE7LIIX SJ 6IZ     48*%) 48*%* 'SRJMHIRXMEP0MQMXIH-RXIVREP(MWXVMFYXMSR 4EGOEKI3YXPMRI7TIGMJMGEXMSRW 4EGOEKI, 45° X 2.03 [.080] 6. 2X 7.11 [.280] ALL FOUR CORNERS 2.66±.51 [.105±.020] D S FLANGE 9.78 [.385] 3.05 [.120] LID 10.16±.25 [.400±.010] CL G 2X R1.52 [R.060] 4X R0.63 [R.025] MAX SPH 1.57 [.062] 15.49±.51 [.610±.020] C66065- A2326-C001- 01-0027 H-36265-2.dwg CL 4X R1.52 [R.060] 15.23 [.600] 10.16±.25 [.400±.010] 3.61±.38 [.142±.015] 0.0381 [.0015] -A1.02 [.040] 20.31 [.800] 6. (MEKVEQ2SXIW{YRPIWWSXLIV[MWI WTIGMJMIH  -RXIVTVIXHMQIRWMSRWERHXSPIVERGIWTIV%71)=1  4VMQEV]HMQIRWMSRWEVIQQ%PXIVREXIHMQIRWMSRWEVIMRGLIW  %PPXSPIVERGIW•?AYRPIWWWTIGMJMIHSXLIV[MWI  4MRW(!HVEMR7!WSYVGI+!KEXI  0IEHXLMGORIWWz?zA  )\TSWIHQIXEPTPERISRXSTERHFSXXSQSJGIVEQMGMRWYPEXSV  +SPHTPEXMRKXLMGORIWW 7(+JPERKI PIEHW•QMGVSR?•QMGVSMRGLA (EXE7LIIX SJ 6IZ     48*%) 48*%* 'SRJMHIRXMEP0MQMXIH-RXIVREP(MWXVMFYXMSR 4EGOEKI3YXPMRI7TIGMJMGEXMSRW GSRX 4EGOEKI, 2X 7.11 [.280] D FLANGE 10.16 [.400] ALL FOUR CORNERS 6. 45° X 2.03 [.080] 2.66±.51 [.105±.020] LID 10.16±.25 [.400±.010] CL 15.49±.51 [.610±.020] G 4X R0.63 [R.025] MAX C66 065-A2327-C001- 01- 0027 H-3 726 5-2. dwg CL 10.16±.25 [.400±.010] SPH 1.57 [.062] 3.61±.38 [.142±.015] 0.0381 [.0015] -A1.02 [.040] S 10.16 [.400] (MEKVEQ2SXIW{YRPIWWSXLIV[MWI WTIGMJMIH  -RXIVTVIXHMQIRWMSRWERHXSPIVERGIWTIV%71)=1  4VMQEV]HMQIRWMSRWEVIQQ%PXIVREXIHMQIRWMSRWEVIMRGLIW  %PPXSPIVERGIW•?AYRPIWWWTIGMJMIHSXLIV[MWI  4MRW(!HVEMR7!WSYVGI+!KEXI  0IEHXLMGORIWWz?zA  )\TSWIHQIXEPTPERISRXSTERHFSXXSQSJGIVEQMGMRWYPEXSV  +SPHTPEXMRKXLMGORIWW 7(+JPERKI PIEHW•QMGVSR?•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’MWEVIKMWXIVIHXVEHIQEVOSJ-RJMRISR8IGLRSPSKMIW%+ )HMXMSR 4YFPMWLIHF] -RJMRISR8IGLRSPSKMIW%+ 1YRMGL+IVQER] 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
PTFA080551E-V4-R0 价格&库存
很抱歉,暂时无法提供与“PTFA080551E-V4-R0”相匹配的价格&库存,您可以联系我们找货
PTFA080551E-V4-R0
    • 1+1039.68360
    • 200+414.84960
    • 500+400.98240
    • 1000+394.13520
