UM823
UM823
    UNION(英联)
    SOT23-5
UM823 数据手册
UM823/824/825 Voltage Supervisory Circuits with Watchdog Timer and Manual Reset Input UM823/824/825 SOT23-5/SOT353 General Description The UM823/824/825 series are cost effective system power supply supervisory circuits designed to monitor the power supplies in digital systems. This family provides circuit initialization and timing supervision. Independent watchdog monitoring circuitry and manual reset input are included. They significantly improve system reliability and accuracy compared to separate ICs or discrete components. The UM823/824/825 are specifically designed to ignore fast transients on VCC. Seven preprogrammed reset threshold voltages are available. All three devices have an active-low reset output, which is guaranteed to be in the correct state for VCC down to 1V. The UM823 also offers a watchdog input and manual reset input. The UM824 offers a watchdog input and a complementary active-high reset. The UM825 offers a manual reset input and a complementary active-high reset. Applications Features z z z z z z z z z z Applications Using DSPs, Microcontrollers or Microprocessors Programmable Controls Computers Embedded Systems Industrial Equipments Intelligent Instruments Wireless Communications Systems z z z z z z Wide Operation Voltage Range of 1V to 7V Correct Logic Output Guaranteed to VCC=1.0V Precision Supply-Voltage Monitor: 2.19V, 2.63V, 2.93V, 3.08V, 4.38V, 4.63V 200ms Reset Pulse Width Independent Watchdog Timer-1.6s Timeout Operating Current: 4µA for L/M 3µA for T/S/R/Z/Y Temperature Range: -40°C to +85°C Power-Supply Transient Immunity SOT23-5 and SOT353 packages Selection Guide Function Active-Low Reset Active-High Reset Watchdog Input Manual Reset Input UM823 √ √ √ UM824 √ √ √ - UM825 √ √ √ Pin Configurations ________________________________________________________________________ http://www.union-ic.com Rev.01 Apr.2019 1/11 UM823/824/825 Ordering Information UM8 XX Z P Z: Reset Threshold (V) =L 4.63 =M 4.38 =T 3.08 =S 2.93 =R 2.63 =Z 2.32 =Y 2.19 P: Package Type =S SOT23-5 =P SOT353 Typical Operating Circuit Functional Diagram ________________________________________________________________________ http://www.union-ic.com Rev.01 Apr.2019 2/11 UM823/824/825 Pin Description Pin Name GND Function Ground Reference for all signals. ______________ RESET Active-Low Reset Output. Pulses low for 200ms when triggered, and remains low _______ whenever VCC is below the reset threshold or when MR is a logic low. It remains low for 200ms after one of the following occurs: VCC rises above the reset ________ threshold, the watchdog triggers a reset, or M R goes low to high. _____________ RESET Active-High Reset Output. Inverse of RESET. Manual-Reset Input triggers a reset pulse when pulled below 0.3VCC. The active-low input has an internal 52kΩ pull-up resistor. It can be driven from a TTL or CMOS logic line as well as shorted to ground with a switch. Leave open or connect to VCC if unused. Watchdog Input. If WDI remains either high or low for longer than the watchdog timeout period, the internal watchdog timer runs out and a reset is triggered. The internal watchdog timer clears whenever reset is asserted, or whenever WDI sees a rising or falling edge. If WDI is left unconnected or is connected to a three-stated buffer output, the watchdog feature is disabled. _______ MR WDI VCC Supply Voltage Absolute Maximum Ratings (Note 1) Symbol VCC Parameter Value Supply Voltage _____________ -0.3 to +8.0 _______ RESET, RESET, MR, WDI ICC -0.3 to (VCC+0.3) _______ Input Current, VCC, MR , WDI _____________ Unit V 20 mA mA mW IO Output Current, RESET, RESET PD Continuous Power Dissipation TA Operating Temperature Range 20 300 247 -40 to +85 Storage Temperature Range -65 to +150 °C +300 °C TSTG SOT23-5 SOT353 Lead Temperature (Soldering, 10s) °C Note 1: Stresses beyond those listed under “Absolute maximum Ratings” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications are not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. ESD Ratings Symbol ESD Mode Value HBM Human Body Mode ±2000 CDM Charged Device Mode ±500 Unit V ________________________________________________________________________ http://www.union-ic.com Rev.01 Apr.2019 3/11 UM823/824/825 Electrical Characteristics (VCC=4.75V to 5.5V for L version, VCC=4.5V to 5.5V for M version, VCC=3.15V to 3.6V for T version, VCC=3.0V to 3.6V for S version, VCC=2.7V to 3.6V for R version, VCC=2.38V to 2.75V for Z version, VCC=2.25V to 2.75V for Y version, TA=-40°C to +85°C (SOT353), TA=-40°C to +125°C(SOT23-5),unless otherwise noted. Typical values are at TA=+25°C.) (Note 2) Symbol Parameter Conditions VCC Supply Voltage Range TA=0°C to +70°C TA=TMIN to TMAX WDI and MR unconnected ICC Supply Current MR unconnected L Version M Version T Version VTH+ Reset Threshold S Version R Version Z Version Y Version tRP Reset Threshold Hysteresis Reset Threshold Tempco Reset Timeout Period _____________ VCC to RESET Delay Min Max Unit 1.0 7 V 1.2 7 V UM823L/M UM824L/M UM823T/S/R/Z/Y UM824T/S/R/Z/Y Typ 4 6 3 6 UM825L/M 4 6 UM825T/S/R/Z/Y 3 6 4.63 4.70 TA=+25°C 4.56 TA=TMIN to TMAX 4.50 TA=+25°C 4.31 TA=TMIN to TMAX 4.25 TA=+25°C 3.04 TA=TMIN to TMAX 3.00 TA=+25°C 2.89 TA=TMIN to TMAX 2.85 TA=+25°C 2.59 TA=TMIN to TMAX 2.55 TA=+25°C 2.28 TA=TMIN to TMAX 2.25 TA=+25°C 2.16 TA=TMIN to TMAX 2.13 L/M T/S/R/Z/Y 140 VRST-VCC=100mV μA 4.75 4.38 4.45 4.50 3.08 3.11 3.15 2.93 2.96 3.00 2.63 V 2.66 2.70 2.32 2.35 2.38 2.19 2.22 2.25 20 10 mV 100 ppm/°C 200 20 280 ms μs ________________________________________________________________________ http://www.union-ic.com Rev.01 Apr.2019 4/11 UM823/824/825 Electrical Characteristics (Continued) (VCC=4.75V to 5.5V for L version, VCC=4.5V to 5.5V for M version, VCC=3.15V to 3.6V for T version, VCC=3.0V to 3.6V for S version, VCC=2.7V to 3.6V for R version, VCC=2.38V to 2.75V for Z version, VCC=2.25V to 2.75V for Y version, TA=-40°C to +85°C (SOT353), TA=-40°C to +125°C(SOT23-5),unless otherwise noted. Typical values are at TA=+25°C.) (Note 2) Symbol Parameter VOH Conditions Min VCC=VRST max ISOURCE=1mA 0.8VCC Typ Max Unit _____________ RESET RESET Output Voltage V VCC=VRST min ISINK=4mA VOL 0.3 WATCHDOG INPUT(UM823/824) tWD Watchdog Timeout Period tWDI WDI Pulse Width VIL VIH 1.12 VIL0.85VCC 2.40 s ns 50 0.15VCC WDI Input Voltage (Note 4) WDI Input Current 1.60 0.85VCC WDI=VCC 1 20 WDI=GND -20 -1 V μA MANUAL RESET INPUT(UM823/825) VIL VIH 0.15VCC _______ MR Input Voltage _______ MR Pulse Width 0.85VCC 1.0 V μs _______ MR Noise Immunity(Pulse width with no reset) _______ MR to Reset Delay 100 ns 500 ns _______ MR Pullup Resistamce(internal) 35 52 75 kΩ Note 2: Over temperature limits are guaranteed by design and not production tested. _____________ ______________ Note 3: The RESET short-circuit current is the maximum pullup current when RESET is driven low by a μP bidirectional reset pin. Note 4: WDI is internally serviced within the watchdog period if WDI is left unconnected. ________________________________________________________________________ http://www.union-ic.com Rev.01 Apr.2019 5/11 UM823/824/825 Detailed Description ______________ RESET Output A Microprocessor’s reset input starts the µP in a known state. The UM823/824/825 µP supervisory circuits assert a reset to prevent code-execution errors during power-up, power-down, and brownout _____________ a logic low for VCC down to 1V. Once VCC exceeds the conditions. RESET is guaranteed to be_____________ reset threshold, an internal timer keeps RESET low for the specified reset timeout period, after this _____________ interval, RESET returns high. _____________ If a brownout condition occurs(VCC dips below reset threshold), RESET goes low. Each time _____________ reset timeout period. Any time VCC goes below the reset RESET is asserted it stays low for the_____________ threshold the internal timer _____________ restarts. RESET both sources and sinks current, RESET on the UM824/825 is the inverse of RESET . Manual Reset Input (UM823/825) Many µP-based products require manual reset capability allowing the operator, a________ test technician, or external logic circuitry to initiate a reset. On the UM823/825, a logic low on M R asserts reset. ________ ________ Reset remains asserted while M R is low, and for tRP (200ms nominal) after it returns high. M R has an internal 52kΩ pull up resistor, so it can be left open if not used. This input can be driven with CMOS logic ________ levels or with open-drain/collector outputs. Connect a normally open momentary switch from________ M R to GND to create a manual-reset function; external debounce circuitry is not required. If M R is driven ________ from long cables or the device is used in a noisy environment, connect a 0.1µF capacitor from M R to GND to provide additional noise immunity. Watchdog Input (UM823/824) In the UM823/824, the watchdog circuit monitors the µP’s activity. If the µP does not toggle the watchdog input (WDI) within tWD(1.6s), reset asserts. The internal 1.6s timer is cleared by either a reset pulse or by toggling WDI, which detects pulses as short as 50ns. While reset is asserted, the timer remains cleared and does not count. As soon as reset is released, the timer starts counting. Disable the watchdog function by leaving WDI unconnected or by three-stating the driver connected to WDI. Microprocessor with Bidirectional Reset To prevent contention for microprocessor with a bidirectional reset line, a current limiting resistor is _____________ to be inserted between the RESET output pin and the microprocessor reset pin. This limits the current to a safe level if there are conflicting output reset levels. A suitable resistor value is 4.7kΩ. If the reset output is required for other uses, it should be buffered as shown in the figure below. BUFFERED RESET TO OTHER SYSTEM COMPONENTS VCC VCC µP RESET GND 4.7kΩ RESET GND Bidirectional Reset I/O ________________________________________________________________________ http://www.union-ic.com Rev.01 Apr.2019 6/11 UM823/824/825 Typical Operating Characteristics VCC=+5V, TA=25℃,unless otherwise noted. Quiescent Current vs. Input Voltage@Ta=20°C Quiescent Current vs. Temperature @VCC=5V 6 5 Quiescent Current (μA) Quiescent Current (μA) 6 4 3 2 1 0 5 4 3 2 1 1 2 3 4 5 6 -40 7 -20 0 20 Input Voltage (V) RESET Timeout Period vs. Temperature@VCC=5V 60 80 100 240 225 210 195 180 165 150 1.75 1.7 1.65 1.6 1.55 1.5 1.45 1.4 -40 -20 0 20 40 60 80 100 120 -40 -20 0 20 40 60 80 100 Temperature(°C) Temperature(°C) Normalized Input Threshold Voltage vs. Temperature 1.04 Normalized Input Threshold Voltage(V) 120 Watchdog Timeout Period vs. Temperature @VCC=5V 1.8 Watchdog Timeout Period(S) RESET Timeout Period(mS) 255 40 Temperature(°C) 1.03 1.02 1.01 1 0.99 0.98 0.97 0.96 -40 -20 0 20 40 60 80 100 120 Temperature(°C) ________________________________________________________________________ http://www.union-ic.com Rev.01 Apr.2019 7/11 120 UM823/824/825 Package Information UM823S/824S/825S SOT23-5 Outline Drawing Symbol A A1 A2 b c D E E1 e e1 L θ DIMENSIONS MILLIMETERS INCHES Min Typ Max Min Typ Max 1.013 1.15 1.40 0.040 0.045 0.055 0.00 0.05 0.10 0.000 0.002 0.004 1.00 1.10 1.30 0.039 0.043 0.051 0.30 0.50 0.012 0.020 0.10 0.15 0.20 0.004 0.006 0.008 2.82 3.10 0.111 0.122 1.50 1.60 1.70 0.059 0.063 0.067 2.60 2.80 3.00 0.102 0.110 0.118 0.95REF 0.037REF 1.90REF 0.075REF 0.30 0.60 0.012 0.024 0° 8° 0° 8° Land Pattern NOTES: 1. Compound dimension: 2.92×1.60; 2. Unit: mm; 3. General tolerance ±0.05mm unless otherwise specified; 4. The layout is just for reference. Tape and Reel Orientation ________________________________________________________________________ http://www.union-ic.com Rev.01 Apr.2019 8/11 UM823/824/825 UM823P/824P/825P SOT353 Outline Drawing D Symbol 5 1 4 3 2 b e Top View Side View c End View A A1 A2 b c D E E1 e L θ DIMENSIONS MILLIMETERS INCHES Min Typ Max Min Typ Max 0.85 1.10 0.033 0.043 0.00 0.10 0.000 0.004 0.80 1.00 0.031 0.039 0.10 0.35 0.004 0.014 0.08 0.22 0.003 0.009 1.80 2.15 2.20 0.071 0.085 0.087 1.15 1.30 1.35 0.045 0.051 0.053 2.00 2.45 0.079 0.096 0.65BSC 0.026REF 0.25 0.46 0.010 0.018 0° 8° 0° 8° Land Pattern NOTES: 1. Compound dimension: 2.15×1.30; 2. Unit: mm; 3. General tolerance ±0.05mm unless otherwise specified; 4. The layout is just for reference. Tape and Reel Orientation ________________________________________________________________________ http://www.union-ic.com Rev.01 Apr.2019 9/11 UM823/824/825 Selection Table Part Number UM823LS UM823MS UM823TS UM823SS UM823RS UM823ZS UM823YS UM823LP UM823MP UM823TP UM823SP UM823RP UM823ZP UM823YP UM824LS UM824MS UM824TS UM824SS UM824RS UM824ZS UM824YS UM824LP UM824MP UM824TP UM824SP UM824RP UM824ZP UM824YP UM825LS UM825MS UM825TS UM825SS UM825RS UM825ZS UM825YS UM825LP UM825MP UM825TP UM825SP UM825RP UM825ZP UM825YP RESET Threshold (V) Top Marking 4.63 4.38 3.08 2.93 2.63 2.32 2.19 4.63 4.38 3.08 2.93 2.63 2.32 2.19 4.63 4.38 3.08 2.93 2.63 2.32 2.19 4.63 4.38 3.08 2.93 2.63 2.32 2.19 4.63 4.38 3.08 2.93 2.63 2.32 2.19 4.63 4.38 3.08 2.93 2.63 2.32 2.19 23L 23M 23T 23S 23R 23Z 23Y 3LP 3MP 3TP 3SP 3RP 3ZP 3YP 24L 24M 24T 24S 24R 24Z 24Y 4LP 4MP 4TP 4SP 4RP 4ZP 4YP 25L 25M 25T 25S 25R 25Z 25Y 5LP 5MP 5TP 5SP 5RP 5ZP 5YP Package Type Shipping Quantity SOT23-5 3000pcs/7Inch Tape Reel SOT353 3000pcs/7Inch Tape Reel SOT23-5 3000pcs/7Inch Tape Reel SOT353 3000pcs/7Inch Tape Reel SOT23-5 3000pcs/7Inch Tape Reel SOT353 3000pcs/7Inch Tape Reel ________________________________________________________________________ http://www.union-ic.com Rev.01 Apr.2019 10/11 UM823/824/825 GREEN COMPLIANCE Union Semiconductor is committed to environmental excellence in all aspects of its operations including meeting or exceeding regulatory requirements with respect to the use of hazardous substances. Numerous successful programs have been implemented to reduce the use of hazardous substances and/or emissions. All Union components are compliant with the RoHS directive, which helps to support customers in their compliance with environmental directives. For more green compliance information, please visit: http://www.union-ic.com/index.aspx?cat_code=RoHSDeclaration IMPORTANT NOTICE The information in this document has been carefully reviewed and is believed to be accurate. Nonetheless, this document is subject to change without notice. Union assumes no responsibility for any inaccuracies that may be contained in this document, and makes no commitment to update or to keep current the contained information, or to notify a person or organization of any update. Union reserves the right to make changes, at any time, in order to improve reliability, function or design and to attempt to supply the best product possible. Union Semiconductor, Inc Add: Unit 606, No.570 Shengxia Road, Shanghai 201210 Tel: 021-51093966 Fax: 021-51026018 Website: www.union-ic.com ________________________________________________________________________ http://www.union-ic.com Rev.01 Apr.2019 11/11
UM823 价格&库存
很抱歉,暂时无法提供与“UM823”相匹配的价格&库存,您可以联系我们找货
