ICL7665S
Data Sheet
CMOS Micropower Over/Under Voltage
Detector
The ICL7665S Super CMOS Micropower Over/Under
Voltage Detector contains two low power, individually
programmable Voltage detectors on a single CMOS chip.
Requiring typically 3µA for operation, the device is intended
for battery-operated systems and instruments which require
high or low voltage warnings, settable trip points, or fault
monitoring and correction. The trip points and hysteresis of
the two voltage detectors are individually programmed via
external resistors. An internal bandgap-type reference
provides an accurate threshold voltage while operating from
any supply in the 1.6V to 16V range.
The ICL7665S, Super Programmable Over/Under Voltage
Detector is a direct replacement for the industry standard
ICL7665B offering wider operating voltage and temperature
ranges, improved threshold accuracy (ICL7665SA), and
temperature coefficient, and guaranteed maximum supply
current. All improvements are highlighted in the electrical
characteristics section. All critical parameters are
guaranteed over the entire commercial and industrial
temperature ranges.
April 5, 2006
FN3182.8
Features
• Guaranteed 10µA Maximum Quiescent Current Over
Temperature
• Guaranteed Wider Operating Voltage Range Over Entire
Operating Temperature Range
• 2% Threshold Accuracy (ICL7665SA)
• Dual Comparator with Precision Internal Reference
• 100ppm/°C Temperature Coefficient of Threshold Voltage
• 100% Tested at 2V
• Output Current Sinking Ability . . . . . . . . . . . . Up to 20mA
• Individually Programmable Upper and Lower Trip Voltages
and Hysteresis Levels
• Pb-Free Plus Anneal Available (RoHS Compliant)
Applications
• Pocket Pagers
• Portable Instrumentation
• Charging Systems
• Memory Power Back-Up
Pinout
• Battery Operated Systems
ICL7665S
(SOIC, PDIP)
TOP VIEW
• Portable Computers
• Level Detectors
OUT 1
1
8
V+
HYST 1
2
7
OUT 2
SET 1
3
6
SET 2
GND
4
5
HYST 2
1
CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures.
1-888-INTERSIL or 1-888-468-3774 | Intersil (and design) is a registered trademark of Intersil Americas Inc.
Copyright GE/Intersil 1983-84, GE/RCA 1987, Harris Corp. 1994, Intersil Americas Inc. 1999, 2004-2006. All Rights Reserved
All other trademarks mentioned are the property of their respective owners.
ICL7665S
Ordering Information
PART NUMBER
PART MARKING
TEMP.
RANGE (°C)
PKG.
DWG. #
PACKAGE
ICL7665SACBA*
7665SACBA
0 to 70
8 Ld SOIC (N)
M8.15
ICL7665SACBAZ* (Note)
7665SACBAZ
0 to 70
8 Ld SOIC (N) (Pb-free)
M8.15
ICL7665SACBAZA* (Note)
7665SACBAZ
0 to 70
M8.15
ICL7665SACPA
7665SACPA
0 to 70
8 Ld PDIP
E8.3
ICL7665SACPAZ (Nore)
7665SACPAZ
0 to 70
8 Ld PDIP** (Pb-free)
E8.3
ICL7665SAIBA*
7665SAIBA
-40 to 85
8 Ld SOIC (N)
M8.15
ICL7665SAIBAZA* (Note)
7665SAIBAZ
-40 to 85
M8.15
ICL7665SAIPA
7665SAIPA
-40 to 85
8 Ld PDIP
E8.3
ICL7665SAIPAZ (Note)
7665SAIPAZ
-40 to 85
E8.3
ICL7665SCBA*
7665SCBA
0 to 70
8 Ld SOIC (N)
M8.15
ICL7665SCBAZ* (Note)
7665SCBAZ
0 to 70
M8.15
ICL7665SCBAZA* (Note)
7665SCBAZ
0 to 70
M8.15
ICL7665SCPA
7665SCPA
0 to 70
8 Ld PDIP
E8.3
ICL7665SCPAZ (Note)
7665SCPAZ
0 to 70
E8.3
ICL7665SIBA*
7665SIBA
-40 to 85
8 Ld SOIC (N)
M8.15
ICL7665SIBAZ* (Note)
7665SIBAZ
-40 to 85
M8.15
ICL7665SIBAZA* (Note)
7665SIBAZ
-40 to 85
M8.15
*Add “-T” suffix for tape and reel.
**Pb-free PDIPs can be used for through hole wave solder processing only. They are not intended for use in Reflow solder processing applications.
NOTE: Intersil Pb-free plus anneal products employ special Pb-free material sets; molding compounds/die attach materials and 100% matte tin plate
termination finish, which are RoHS compliant and compatible with both SnPb and Pb-free soldering operations. Intersil Pb-free products are MSL
classified at Pb-free peak reflow temperatures that meet or exceed the Pb-free requirements of IPC/JEDEC J STD-020.
2
FN3182.8
April 5, 2006
ICL7665S
Absolute Maximum Ratings
Thermal Information
Supply Voltage (Note 2) . . . . . . . . . . . . . . . . . . . . . . . . . -0.3 to +18V
Output Voltages OUT1 and OUT2 . . . . . . . . . . . . . . . . . -0.3V to 18V
(with respect to GND) (Note 2)
Output Voltages HYST1 and HYST2 . . . . . . . . . . . . . . -0.3V to +18V
(with respect to V+) (Note 2)
Input Voltages SET1 and SET2 . . . . . (GND -0.3V) to (V+ V- +0.3V)
(Note 2)
Maximum Sink Output OUT1 and OUT2 . . . . . . . . . . . . . . . . . 25mA
Maximum Source Output Current
HYST1 and HYST2 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . -25mA
Thermal Resistance (Typical, Note 1)
Operating Conditions
θJA (°C/W)
PDIP Package* . . . . . . . . . . . . . . . . . . . . . . . . . . . .
115
SOIC Package . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
160
Maximum Junction Temperature (Plastic) . . . . . . . . . . . . . . . . 150°C
Maximum Junction Temperature (CERDIP). . . . . . . . . . . . . . . 175°C
Maximum Storage Temperature Range . . . . . . . . . . . -65°C to 150°C
Maximum Lead Temperature (Soldering 10s) . . . . . . . . . . . . . 300°C
(SOIC - Lead Tips Only)
applications.
Temperature Range
ICL7665SC. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0°C to 70°C
ICL7665SI . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .-40°C to 85°C
CAUTION: Stresses above those listed in “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress only rating and operation of the
device at these or any other conditions above those indicated in the operational sections of this specification is not implied.
NOTES:
1. θJA is measured with the component mounted on an evaluation PC board in free air.
2. Due to the SCR structure inherent in the CMOS process used to fabricate these devices, connecting any terminal to voltages greater than (V+
+0.3V) or less than (GND - 0.3V) may cause destructive device latchup. For these reasons, it is recommended that no inputs from external
sources not operating from the same power supply be applied to the device before its supply is established, and that in multiple supply systems,
the supply to the ICL7665S be turned on first. If this is not possible, current into inputs and/or outputs must be limited to ±0.5mA and voltages
must not exceed those defined above.
Electrical Specifications
PARAMETER
The specifications below are applicable to both the ICL7665S and ICL7665SA. V+ = 5V, TA = 25°C,
Test Circuit Figure 7. Unless Otherwise Specified
SYMBOL
Operating Supply Voltage
V+
TEST CONDITIONS
MIN
TYP
MAX
UNITS
TA = 25°C
1.6
16
V
0°C ≤ TA ≤ 70°C
1.8
16
V
-25°C ≤ TA ≤ 85°C
1.8
16
V
0°C ≤ TA ≤ 70°C
1.8
16
V
-25°C ≤ TA ≤ 85°C
1.8
16
V
V+ = 2V
2.5
10
µA
V+ = 9V
2.6
10
µA
V+ = 15V
2.9
10
µA
V+ = 2V
2.5
10
µA
V+ = 9V
2.6
10
µA
V+ = 15V
2.9
10
µA
1.20
1.30
1.40
V
1.20
1.30
1.40
V
1.275
1.30
1.325
V
1.275
1.30
1.325
V
ICL7665S
200
ppm
ICL7665SA
100
ppm
ROUT1, ROUT2, RHYST1, R2HYST2 = 1MΩ,
2V ≤ V+ ≤ 10V
0.03
%/V
ICL7665S
ICL7665SA
Supply Current
I+
GND ≤ VSET1, VSET2 ≤ V+, All Outputs Open Circuit
0°C ≤ TA ≤ 70°C
-40°C ≤ TA ≤ 85°C
Input Trip Voltage
VSET1
ICL7665S
VSET2
VSET1
ICL7665SA
VSET2
VSET
∆VSET
Supply Voltage Sensitivity of
VSET1, VSET2
∆VSET
∆T
∆VS
3
FN3182.8
April 5, 2006
ICL7665S
PARAMETER
Test Circuit Figure 7. Unless Otherwise Specified (Continued)
SYMBOL
Output Leakage Currents of
OUT and HYST
IOLK
TEST CONDITIONS
MIN
TYP
MAX
UNITS
10
200
nA
-10
-100
nA
2000
nA
-500
nA
V+ = 2V
0.2
0.5
V
V+ = 5V
0.1
0.3
V
V+ = 15V
0.06
0.2
V
V+ = 2V
-0.15
-0.30
V
V+ = 5V
-0.05
-0.15
V
V+ = 15V
-0.02
-0.10
V
V+ = 2V
0.2
0.5
V
V+ = 5V
0.15
0.3
V
V+ = 15V
0.11
0.25
V
V+ = 2V, IHYST2 = -0.2mA
-0.25
-0.8
V
V+ = 5V, IHYST2 = -0.5mA
-0.43
-1.0
V
V+ = 15V, IHYST2 = -0.5mA
-0.35
-0.8
V
0.01
10
nA
ICL7665S
1.0
mV
ICL7665SA
0.1
mV
±5
±50
mV
ICL7665S
±1
mV
ICL7665SA
±0.1
mV
VSET = 0V or VSET ≥ 2V
IHLK
IOLK
V+ = 15V
IHLK
Output Saturation Voltages
VOUT1
VHYST1
VOUT2
VHYST2
VSET1 = 2V,
IOUT1 = 2mA
VSET1 = 2V,
IHYST1 = -0.5mA
VSET2 = 0V,
IOUT2 = 2mA
VSET2 = 2V
VSET Input Leakage Current
ISET
GND ≤ VSET ≤ V+
∆ Input for Complete Output
Change
∆VSET
ROUT = 4.7kΩ,
RHYST = 20kΩ,
VOUTLO = 1% V+,
VOUTHI = 99% V+
Difference in Trip Voltages
VSET1 VSET2
Output/Hysteresis
Difference
ROUT, RHYST = 1mW
ROUT, RHYST = 1mW
NOTES:
3. Derate above 25°C ambient temperature at 4mW/°C.
4. All significant improvements over the industry standard ICL7665 are highlighted.
4
FN3182.8
April 5, 2006
ICL7665S
AC Electrical Specifications
PARAMETER
SYMBOL
TEST CONDITIONS
MIN
TYP
MAX
UNITS
85
µs
90
µs
t SO2D
55
µs
t SH2D
55
µs
75
µs
80
µs
t SO2D
60
µs
t SH2D
60
µs
0.6
µs
0.8
µs
t H1R
7.5
µs
t H2R
0.7
µs
0.6
µs
0.7
µs
t H1F
4.0
µs
t H2F
1.8
µs
OUTPUT DELAY TIMES
Input Going HI
t SO1D
t SH1D
Input Going LO
t SO1D
t SH1D
Output Rise Times
t O1R
t O2R
Output Fall Times
t O1F
t O2F
VSET Switched between 1.0V to 1.6V
ROUT = 4.7kΩ, CL = 12pF
RHYST = 20kΩ, CL = 12pF
VSET Switched between 1.6V to 1.0V
Functional Block Diagram
V+
SET1
HYST2
HYST1
REF
SET2
OUT2
OUT1
GND
CONDITIONS (Note 5)
VSET1 > 1.3V, OUT1 Switch ON, HYST1 Switch ON
VSET1 < 1.3V, OUT1 Switch OFF, HYST1 Switch OFF
VSET2 > 1.3V, OUT2 Switch OFF, HYST2 Switch ON
VSET2 < 1.3V, OUT2 Switch ON, HYST2 Switch OFF
NOTE:
5. See Electrical Specifications for exact thresholds.
5
FN3182.8
April 5, 2006
ICL7665S
Typical Performance Curves
2.0
2.0
V+ = 2V
VOLTAGE SATURATION (V)
V+ = 2V
1.5
V+ = 5V
1.0
V+ = 9V
0.5
V+ = 15V
1.5
1.0
V+ = 5V
V+ = 9V
0.5
V+ = 15V
10
15
IOUTOUT1 (mA)
FIGURE 1. OUT1 SATURATION VOLTAGE AS A FUNCTION
OF OUTPUT CURRENT
-16
-12
-8
-4
TA = 25°C
-0.4
V+ = 15V
-0.8
-1.2
V+ = 9V
-1.6
V+ = 2V
V+ = 5V
-2.0
-5.0
-4.0
-1.0
V+ = 15V
-2.0
V+ = 9V
-3.0
-4.0
V+ = 2V
V+ = 5V
-5.0
FIGURE 4. HYST2 OUTPUT SATURATION VOLTAGE vs
HYST2 OUTPUT CURRENT
5.0
0V ≤ VSET1, VSET2 ≤ V+
4.5
4.0
V+ = 15V
4.5
SUPPLY CURRENT (µA)
SUPPLY CURRENT (µA)
-2.0
-1.0
5.0
V+ = 9V
3.0
2.5
V+ = 2V
1.5
1.0
0.5
-3.0
HYST2 OUTPUT CURRENT (mA)
FIGURE 3. HYST1 OUTPUT SATURATION VOLTAGE vs
HYST1 OUTPUT CURRENT
2.0
TA = 25°C
HYST1 OUTPUT CURRENT (mA)
3.5
15
FIGURE 2. OUT2 SATURATION VOLTAGE AS A FUNCTION
OF OUTPUT CURRENT
HYST1 OUTPUT SATURATION VOLTAGE (V)
-20
10
IOUTOUT2 (mA)
HYST2 OUTPUT SATURATION VOLTAGE (V)
TA = -20°C
4.0
3.5
TA = 25°C
3.0
2.5
2.0
TA = 70°C
1.5
1.0
0.5
+40
+60
AMBIENT TEMPERATURE (°C)
FIGURE 5. SUPPLY CURRENT AS A FUNCTION OF AMBIENT
TEMPERATURE
6
4
6
8
10
12
14
16
SUPPLY VOLTAGE (V+)
FIGURE 6. SUPPLY CURRENT AS A FUNCTION OF SUPPLY
VOLTAGE
FN3182.8
April 5, 2006
ICL7665S
Detailed Description
As shown in the Functional Diagram, the ICL7665S consists
of two comparators which compare input voltages on the
SET1 and SET2 terminals to an internal 1.3V bandgap
reference. The outputs from the two comparators drive
open-drain N-channel transistors for OUT1 and OUT2, and
open-drain P-channel transistors for HYST1 and HYST2
outputs. Each section, the Undervoltage Detector and the
Overvoltage Detector, is independent of the other, although
both use the internal 1.3V reference. The offset voltages of
the two comparators will normally be unequal so VSET1 will
generally not quite equal VSET2.
The input impedance of the SET1 and SET2 pins are
extremely high, and for most practical applications can be
ignored. The four outputs are open-drain MOS transistors,
and when ON behave as low resistance switches to their
respective supply rails. This minimizes errors in setting up
the hysteresis, and maximizes the output flexibility. The
operating currents of the bandgap reference and the
comparators are around 100nA each.
V+
INPUT
OUT1
1.6V
1.0V
t O1R
t SO1D
t O1F
V+
(5V)
GND
t SO1D
t H1F
HYST1
V+
(5V)
GND
t SH1D
t SO2D
t O2R
t SO2D
t O2F
t SH2D
t H2R
t SH2D
t H2F
V+
(5V)
GND
V+
(5V)
GND
HYST2
4.7
kΩ
V+ 8
VSET1,
VSET2
t SH1D
t H1R
OUT1
HYST1
INPUT
If the SET voltages must be applied before the supply
voltage V+, the input current should be limited to less than
0.5mA by appropriate external resistors, usually required for
voltage setting anyway. A similar precaution should be taken
with the outputs if it is likely that they will be driven by other
circuits to levels outside the supplies at any time.
OUT2
4.7kΩ
1 OUT1
can be used to reduce the rate-of-rise of the supply voltage
in battery applications. In line operated systems, the rate-ofrise of the supply is limited by other considerations, and is
normally not a problem.
FIGURE 8. SWITCHING WAVEFORMS
OUT2
2 HYST1OUT2 7
3 SET1 SET2 6
HYST2
4 GND HYST2 5
kΩ
kΩ
12
pF
12
pF
12
pF
12
pF
1.6V
1.0V
FIGURE 7. TEST CIRCUITS
Simple Threshold Detector
Figure 9 shows the simplest connection of the ICL7665S for
threshold detection. From the graph 9B, it can be seen that
at low input voltage OUT1 is OFF, or high, while OUT2 is
ON, or low. As the input rises (e.g., at power-on) toward
VNOM (usually the eventual operating voltage), OUT2 goes
high on reaching VTR2. If the voltage rises above VNOM as
much as VTR1, OUT1 goes low. The equation giving VSET1
and VSET2 are from Figure 9A:
R 11
V SET1 = V IN -------------------------------( R 11 + R 21 )
Precautions
Junction isolated CMOS devices like the ICL7665S have an
inherent SCR or 4-layer PNPN structure distributed
throughout the die. Under certain circumstances, this can be
triggered into a potentially destructive high current mode.
This latchup can be triggered by forward-biasing an input or
output with respect to the power supply, or by applying
excessive supply voltages. In very low current analog
circuits, such as the ICL7665S, this SCR can also be
triggered by applying the input power supply extremely
rapidly (“instantaneously”), e.g., through a low impedance
battery and an ON/OFF switch with short lead lengths. The
rate-of-rise of the supply voltage can exceed 100V/µs in
such a circuit. A low impedance capacitor (e.g., 0.05µF disc
ceramic) between the V+ and GND pins of the ICL7665S
7
R 12
V SET2 = V IN -------------------------------( R 12 + R 22 )
Since the voltage to trip each comparator is nominally 1.3V,
the value VIN for each trip point can be found from
( R 11 + R 21 )
( R 11 + R 21 )
- = 1.3 ---------------------------------- for detector 1
V TR1 = V SET1 --------------------------------R
R
11
11
and
( R 12 + R 22 )
( R 12 + R 22 )
V TR2 = V SET2 --------------------------------- = 1.3 ---------------------------------- for detector 2
R
R
12
12
FN3182.8
April 5, 2006
ICL7665S
VIN
VOUT
OFF
RP2
RP1
OUT1
R21
V+
SET1
OUT2
R22
SET2
R11
R12
ON
VTR2
VNOM
VTR1
DETECTOR 2
DETECTOR 1
FIGURE 9B. TRANSFER CHARACTERISTICS
FIGURE 9A. CIRCUIT CONFIGURATION
FIGURE 9. SIMPLE THRESHOLD DETECTOR
OUT
VIN
ON
R31
R32
V+
HYST1
HYST2
R21
R22
SET1
SET2
OUT1
OUT2
OVERVOLTAGE
OFF
VL2 VU2
R12
FIGURE 10A. CIRCUIT CONFIGURATION
VIN
VNOM
OVERVOLTAGE
R11
VL1 VU1
DETECTOR 2
DETECTOR 1
FIGURE 10B. TRANSFER CHARACTERISTICS
FIGURE 10. THRESHOLD DETECTOR WITH HYSTERESIS
Either detector may be used alone, as well as both together,
in any of the circuits shown here.
When VIN is very close to one of the trip voltage, normal
variations and noise may cause it to wander back and forth
across this level, leading to erratic output ON and OFF
conditions. The addition of hysteresis, making the trip points
slightly different for rising and falling inputs, will avoid this
condition.
Threshold Detector with Hysteresis
Figure 10A shows how to set up such hysteresis, while
Figure 10B shows how the hysteresis around each trip point
produces switching action at different points depending on
whether VIN is rising or falling (the arrows indicated direction
of change. The HYST outputs are basically switches which
short out R31 or R32 when VIN is above the respective trip
point. Thus if the input voltage rises from a low value, the trip
point will be controlled by R1N, R2N, and R3N, until the trip
point is reached. As this value is passed, the detector
changes state, R3N is shorted out, and the trip point
8
becomes controlled by only R1N and R2N, a lower value.
The input will then have to fall to this new point to restore the
initial comparator state, but as soon as this occurs, the trip
point will be raised again.
An alternative circuit for obtaining hysteresis is shown in
Figure 11. In this configuration, the HYST pins put the extra
resistor in parallel with the upper setting resistor. The values
of the resistors differ, but the action is essentially the same.
The governing equations are given in Table 1. These ignore
the effects of the resistance of the HYST outputs, but these
can normally be neglected if the resistor values are above
about 100kΩ.
( R 12 + R 22 )
( R 12 + R 22 )
R
R
12
12
FN3182.8
April 5, 2006
ICL7665S
Applications
VIN
Single Supply Fault Monitor
RP
RP
V+
R21
OUT1
R22
OUT2
R32
R31
HYST1
HYST2
SET1
SET2
R11
Figure 12 shows an over/under voltage fault monitor for a
single supply. The overvoltage trip point is centered around
5.5V and the undervoltage trip point is centered around 4.5V.
Both have some hysteresis to prevent erratic output ON and
OFF conditions. The two outputs are connected in a wired
OR configuration with a pullup resistor to generate a power
OK signal.
R12
+5V SUPPLY
FIGURE 11. AN ALTERNATIVE HYSTERESIS CIRCUIT
R21
V+
324kΩ
HYST1
R11 + R21
Overvoltage VTRIP =
R11
R12 + R22
Overvoltage VTRIP =
R12
HYSTERESIS PER FIGURE 10A
VU1 =
R11 + R21 + R31
R11
VU2 =
R11 + R21
R11
R12
R12
x VSET2
x VSET2
HYSTERESIS PER FIGURE 11
VU1 =
R11 + R21
R11
x VSET1
Overvoltage VTRIP
VL1 =
R21R31
R11 +
R21 + R31 x VSET1
R11
VU2 =
R12 + R22
R12
VSET1
VSET2
OUT1
OUT2
7.5MΩ
5%
100kΩ
V+
OPEN VOLTAGE
DETECTOR
VU = 4.55V
VL = 4.45V
1MΩ
POWER
OK
Multiple Supply Fault Monitor
x VSET1
R12 + R22 + R32
R12 + R22
OPEN VOLTAGE
DETECTOR
VU = 5.55V
VL = 5.45V
R32
FIGURE 12. FAULT MONITOR FOR A SINGLE SUPPLY
Undervoltage VTRIP
VL2 =
x VSET2
100kΩ
R22
x VSET1
Overvoltage VTRIP
VL1 =
x VSET1
R31
R12
NO HYSTERESIS
13MΩ
5%
R11
TABLE 1. SET-POINT EQUATIONS
249kΩ
HYST2
The ICL7665S can simultaneously monitor several supplies
when connected as shown in Figure 13. The resistors are
chosen such that the sum of the currents through R21A,
R21B, and R31 is equal to the current through R11 when the
two input voltage are at the desired low voltage detection
point. The current through R11 at this point is equal to
1.3V/R11. The voltage at the VSET input depends on the
voltage of both supplies being monitored. The trip voltage of
one supply while the other supply is at the nominal voltage
will be different that the trip voltage when both supplies are
below their nominal voltages.
The other side of the ICL7665S can be used to detect the
absence of negative supplies. The trip points for OUT1
depend on both the negative supply voltages and the actual
voltage of the +5V supply.
x VSET2
Overvoltage VTRIP
VL2 =
R12 +
R22R32
R22 + R32 x VSET2
R12
9
FN3182.8
April 5, 2006
ICL7665S
V+
HYST1
22MΩ
+5V
HYST2
22
MΩ
R21
49.9kΩ
R11
+15V
VSET1 is greater than 1.3V, OUT1 is low, but when VSET1
drops below 1.3V, OUT1 goes high shutting off the
ICL7663S. OUT2 is used for low battery warning. When
VSET2 is greater than 1.3V, OUT2 is high and the low battery
warning is on. When VSET2 drops below 1.3V, OUT2 is low
and the low battery warning goes off. The trip voltage for low
battery warning can be set higher than the trip voltage for
shutdown to give advance low battery warning before the
battery is disconnected.
+5V
274kΩ
R21A
VSET1
VSET2
OUT1
OUT2
1.02MΩ
R21B
301
kΩ
-5V
100kΩ
787
kΩ
+5V
Power Fail Warning and Powerup/Powerdown
Reset
1MΩ
-15V
Figure 15 shows a power fail warning circuit with
powerup/powerdown reset. When the unregulated DC input
is above the trip point, OUT1 is low. When the DC input
drops below the trip point, OUT1 shuts OFF and the power
fail warning goes high. The voltage on the input of the 7805
will continue to provide 5V out at 1A until VIN is less than
7.3V, this circuit will provide a certain amount of warning
before the 5V output begins to drop.
POWER
OK
FIGURE 13. MULTIPLE SUPPLY FAULT MONITOR
Combination Low Battery Warning and Low
Battery Disconnect
When using rechargeable batteries in a system, it is
important to keep the batteries from being over discharged.
The circuit shown in Figure 14 provides a low battery
warning and also disconnects the low battery from the rest of
the system to prevent damage to the battery. OUT1 is used
to shutdown the ICL7663S when the battery voltage drops to
the value where the load should be disconnected. As long as
R31
The ICL7665S OUT2 is used to prevent a microprocessor
from writing spurious data to a CMOS battery backup
memory by causing OUT2 to go low when the 7805 5V
output drops below the ICL7665S trip point.
100Ω
R32
V+
HYST1
R21
1MΩ
HYST2
V+
R22
ICL7665S
SET1
SET2
V+
R11
OUT1
GND
+5V
1A
OUT2
OUT1
OUT2
ICL7663S
SENSE
SHUTDOWN
VSET
GND
R12
1MΩ
LOW BATTERY SHUTDOWN
LOW BATTERY WARNING
FIGURE 14. LOW BATTERY WARNING AND LOW BATTERY DISCONNECT
10
FN3182.8
April 5, 2006
ICL7665S
UNREGULATED
DC INPUT
4700µF
7805
5V REGULATOR
470µF
BACKUP
BATTERY
V+
HYST1
5.86kΩ
715kΩ
HYST2
22MΩ
ICL7665S
VSET1
VSET2
OUT1
OUT2
2.2MΩ
130kΩ
1MΩ
1MΩ
1MΩ
RESET OR
WRITE
ENABLE
POWER
FAIL
WARNING
FIGURE 15. POWER FAIL WARNING AND POWERUP/POWERDOWN RESET
Simple High/Low Temperature Alarm
AC Power Fail and Brownout Detector
Figure 16 illustrates a simple high/low temperature alarm
which uses the ICL7665S with an NPN transistor. The
voltage at the top of R1 is determined by the VBE of the
transistor and the position of R1’s wiper arm. This voltage
has a negative temperature coefficient. R1 is adjusted so
that VSET2 equals 1.3V when the NPN transistor’s
temperature reaches the temperature selected for the high
temperature alarm. When this occurs, OUT2 goes low. R2 is
adjusted so that VSET1 equals 1.3V when the NPN
transistor’s temperature reaches the temperature selected
for the low temperature alarm. When the temperature drops
below this limit, OUT1 goes low.
Figure 17 shows a circuit that detects AC undervoltage by
monitoring the secondary side of the transformer. The
capacitor, C1, is charged through R1 when OUT1 is OFF.
With a normal 100 VAC input to the transformer, OUT1 will
discharge C1 once every cycle, approximately every 16.7ms.
When the AC input voltage is reduced, OUT1 will stay OFF,
so that C1 does not discharge. When the voltage on C1
reaches 1.3V, OUT2 turns OFF and the power fail warning
goes high. The time constant, R1C1, is chosen such that it
takes longer than 16.7ms to charge C1 1.3V.
11
FN3182.8
April 5, 2006
ICL7665S
5V
TEMPERATURE
SENSOR
(GENERAL PURPOSE
NPN TRANSISTOR)
470kΩ
R3
LOW TEMPERATURE
LIMIT ADJUST
V+
HYST1
27kΩ
R4
22kΩ
HYST2
ICL7665S
VSET1
VSET2
OUT1
OUT2
R6
22MΩ
R7
1.5MΩ
R2
1MΩ
R5
R1
10kΩ
HIGH
TEMPERATURE
LIMIT ADJUST
V+
ALARM SIGNAL
FOR DRIVING
LEDS, BELLS,
ETC.
1MΩ
FIGURE 16. SIMPLE HIGH/LOW TEMPERATURE ALARM
7805
5V REGULATOR
110VAC
60Hz
5V, 1A
4700µF
20V
CENTERED
TAPPED
TRANS.
+5V
HYST1
601kΩ
HYST2
100kΩ
1MΩ
1MΩ
R1
1MΩ
ICL7665S
VSET1
VSET2
OUT1
OUT2
POWER FAIL
WARNING
C1
FIGURE 17. AC POWER FAIL AND BROWNOUT DETECTOR
12
FN3182.8
April 5, 2006
ICL7665S
Dual-In-Line Plastic Packages (PDIP)
E8.3 (JEDEC MS-001-BA ISSUE D)
N
8 LEAD DUAL-IN-LINE PLASTIC PACKAGE
E1
INDEX
AREA
1 2 3
INCHES
N/2
-B-
-AD
E
BASE
PLANE
-C-
A2
SEATING
PLANE
A
L
D1
e
B1
D1
A1
eC
B
0.010 (0.25) M
C A B S
MILLIMETERS
SYMBOL
MIN
MAX
MIN
MAX
NOTES
A
0.210
5.33
4
A1
0.015
0.39
4
A2
0.115
0.195
2.93
4.95
B
0.014
0.022
0.356
0.558
C
L
B1
0.045
0.070
1.15
1.77
8, 10
eA
C
0.008
0.014
0.204
C
D
0.355
0.400
9.01
eB
NOTES:
1. Controlling Dimensions: INCH. In case of conflict between
English and Metric dimensions, the inch dimensions control.
0.005
0.13
5
E
0.300
0.325
7.62
8.25
6
E1
0.240
0.280
6.10
7.11
5
e
0.100 BSC
eA
0.300 BSC
3. Symbols are defined in the “MO Series Symbol List” in Section
2.2 of Publication No. 95.
eB
L
0.115
5. D, D1, and E1 dimensions do not include mold flash or protrusions. Mold flash or protrusions shall not exceed 0.010 inch
(0.25mm).
6. E and eA are measured with the leads constrained to be perpendicular to datum -C- .
5
D1
2. Dimensioning and tolerancing per ANSI Y14.5M-1982.
4. Dimensions A, A1 and L are measured with the package seated
in JEDEC seating plane gauge GS-3.
0.355
10.16
N
8
2.54 BSC
7.62 BSC
0.430
0.150
2.93
8
6
10.92
7
3.81
4
9
Rev. 0 12/93
7. eB and eC are measured at the lead tips with the leads unconstrained. eC must be zero or greater.
8. B1 maximum dimensions do not include dambar protrusions.
Dambar protrusions shall not exceed 0.010 inch (0.25mm).
9. N is the maximum number of terminal positions.
10. Corner leads (1, N, N/2 and N/2 + 1) for E8.3, E16.3, E18.3,
E28.3, E42.6 will have a B1 dimension of 0.030 - 0.045 inch
(0.76 - 1.14mm).
13
FN3182.8
April 5, 2006
ICL7665S
Small Outline Plastic Packages (SOIC)
M8.15 (JEDEC MS-012-AA ISSUE C)
N
INDEX
AREA
8 LEAD NARROW BODY SMALL OUTLINE PLASTIC PACKAGE
H
0.25(0.010) M
B M
INCHES
E
SYMBOL
-B1
2
3
L
SEATING PLANE
-A-
A
D
h x 45°
-C-
e
A1
B
0.25(0.010) M
C
0.10(0.004)
C A M
MIN
MAX
MIN
MAX
NOTES
A
0.0532
0.0688
1.35
1.75
A1
0.0040
0.0098
0.10
0.25
B
0.013
0.020
0.33
0.51
9
C
0.0075
0.0098
0.19
0.25
D
0.1890
0.1968
4.80
5.00
3
E
0.1497
0.1574
3.80
4.00
4
e
α
B S
0.050 BSC
1.27 BSC
H
0.2284
0.2440
5.80
6.20
h
0.0099
0.0196
0.25
0.50
5
L
0.016
0.050
0.40
1.27
6
N
α
NOTES:
MILLIMETERS
8
0°
8
8°
0°
7
8°
1. Symbols are defined in the “MO Series Symbol List” in Section 2.2 of
Publication Number 95.
Rev. 1 6/05
3. Dimension “D” does not include mold flash, protrusions or gate burrs.
Mold flash, protrusion and gate burrs shall not exceed 0.15mm (0.006
inch) per side.
4. Dimension “E” does not include interlead flash or protrusions. Interlead flash and protrusions shall not exceed 0.25mm (0.010 inch) per
side.
5. The chamfer on the body is optional. If it is not present, a visual index
feature must be located within the crosshatched area.
6. “L” is the length of terminal for soldering to a substrate.
7. “N” is the number of terminal positions.
8. Terminal numbers are shown for reference only.
9. The lead width “B”, as measured 0.36mm (0.014 inch) or greater
above the seating plane, shall not exceed a maximum value of
0.61mm (0.024 inch).
10. Controlling dimension: MILLIMETER. Converted inch dimensions
are not necessarily exact.
All Intersil U.S. products are manufactured, assembled and tested utilizing ISO9000 quality systems.
Intersil Corporation’s quality certifications can be viewed at www.intersil.com/design/quality
Intersil products are sold by description only. Intersil Corporation reserves the right to make changes in circuit design, software and/or specifications at any time without
notice. Accordingly, the reader is cautioned to verify that data sheets are current before placing orders. Information furnished by Intersil is believed to be accurate and
reliable. However, no responsibility is assumed by Intersil or its subsidiaries for its use; nor for any infringements of patents or other rights of third parties which may result
from its use. No license is granted by implication or otherwise under any patent or patent rights of Intersil or its subsidiaries.
For information regarding Intersil Corporation and its products, see www.intersil.com
14
FN3182.8
April 5, 2006
