UM3429S
600mA, 500KHz, Synchronous Step-Up DC-DC Converter
UM3429S SOT23-6
General Description
The UM3429S is synchronous rectified, fixed frequency, step-up DC/DC converter series
delivering high efficiency in low profile SOT23-6 package. It features true output load
disconnection and adjustable output. With an internal NMOS switch, PMOS synchronous rectifier
and high switching frequency of 500KHz, the UM3429S is capable of supplying 3.3V output at
100mA from a single AA cell input or 250mA from a 2-cell AA input using low profile inductors
and ceramic capacitors. Current mode PWM control with internal compensation as well as the
synchronous rectifier and 500KHz high frequency lead to the fewest number of external parts
needed, thereby saving BOM cost and PCB area. At light load, UM3429S automatically enters
into pulse skipping mode to keep high efficiency. An internal resistor will be connected to VIN
when the switch is idle that eliminates switch ringing and reduces EMI interference.
The device also features low shutdown current lower than 1μA, inrush current limit.
Applications
Features
z
z
z
z
z
z
z
z
z
z
z
z
Digital Cameras
LCD Bias Supplies
Handheld Instruments
Wireless Handsets
GPS Receivers
All one cell 、tow cell alkaline
NiCD、NiMH or Li-ion battery
Powered products
z
z
z
z
z
Up to 92% Efficiency
Output Load Disconnection
Internal Synchronous Rectifier
Low Voltage Start-Up: 0.85V
Input Current Limit
Pulse Skipping Mode Operation with
Typical IQ as 20μA
Shutdown Current Lower than 1µA
500KHz Switching Frequency for Low
Profile Inductor/Capacitor
Input Voltage: 0.5V to 5.0V
Output Voltage: 2.5V to 5V
Anti-Ringing Control to Reduce EMI
Typical Application Circuit
Efficiency vs. Output Current
100
95
VOUT=3.3V
90
Efficiency (%)
85
80
75
70
65
VIN=1.2V
VIN=1.5V
VIN=2.4V
VIN=3.0V
60
55
50
1
10
100
1000
Output Current (mA)
________________________________________________________________________
http://www.union-ic.com Rev.04 Aug.2019
1/12
UM3429S
Pin Configurations
Top View
M: Month Code
UM3429S
SOT23-6
Pin Description
Pin Number
Symbol
1
SW
2
GND
3
FB
4
____________
5
VOUT
6
VIN
SHDN
Description
Switch Pin. Connect external inductance to VIN. Keep these
PCB trace lengths as short and wide as possible.
Ground. Provide a short direct PCB path between GND and the
negative electrode of COUT and CIN.
Feedback Input Pin. Connect to the center point of the external
resistor divider and set the output voltage by:
R1
VOUT =0.6V 1+
R2
Logic Controlled Shutdown Input. Low logic active. In
shutdown mode, all functions
are disabled drawing
很抱歉,暂时无法提供与“UM3429S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.56497
- 50+1.22885
- 150+1.08479
- 500+0.90504
- 3000+0.82501
- 6000+0.77700
- 国内价格
- 5+0.71341
- 20+0.70032
- 100+0.67414
