S-1317A33-M5T1U4
S-1317A33-M5T1U4
    ABLIC(艾普凌科)
    SOT23-5
    IC REG LINEAR 3.3V 100MA SOT23-5
S-1317A33-M5T1U4 数据手册
S-1317 Series www.ablic.com www.ablicinc.com 5.5 V INPUT, 100 mA CMOS VOLTAGE REGULATOR WITH 0.35 A SUPER LOW CURRENT CONSUMPTION © ABLIC Inc., 2016 Rev.1.0_01 The S-1317 Series, developed by using the CMOS technology, is a positive voltage regulator IC, which features super low current consumption and low dropout voltage. This IC has low current consumption of 0.35 A typ. and high-accuracy output voltage of 1.0%. It is most suitable for use in portable equipment and battery-powered devices.  Features  Output voltage:  Input voltage:  Output voltage accuracy:  Dropout voltage:  Current consumption during operation:  Output current:  Input capacitor:  Output capacitor:  Built-in overcurrent protection circuit:  Operation temperature range:  Lead-free (Sn 100%), halogen-free 1.0 V to 3.5 V, selectable in 0.05 V step 1.5 V to 5.5 V 1.0% (1.0 V to 1.45 V output product: 15 mV) (Ta = 25°C) 20 mV typ. (2.5 V output product, at IOUT = 10 mA) (Ta = 25°C) 0.35 A typ. (Ta = 25°C) Possible to output 100 mA (at VIN  VOUT(S)1.0 V)*1 A ceramic capacitor can be used. (1.0 F or more) A ceramic capacitor can be used. (1.0 F to 100 F) Limits overcurrent of output transistor. Ta = 40°C to 85°C *1. Please make sure that the loss of the IC will not exceed the power dissipation when the output current is large.  Applications  Constant-voltage power supply for battery-powered device  Constant-voltage power supply for portable communication device, digital camera, and digital audio player  Constant-voltage power supply for home electric appliance  Packages  SOT-23-5  HSNT-4(1010) 1 5.5 V INPUT, 100 mA CMOS VOLTAGE REGULATOR WITH 0.35 A SUPER LOW CURRENT CONSUMPTION Rev.1.0_01 S-1317 Series  Block Diagram *1 VIN VOUT Overcurrent protection circuit Reference voltage circuit   VSS *1. Parasitic diode Figure 1 2 5.5 V INPUT, 100 mA CMOS VOLTAGE REGULATOR WITH 0.35 A SUPER LOW CURRENT CONSUMPTION Rev.1.0_01 S-1317 Series  Product Name Structure Users can select output voltage and package type for the S-1317 Series. Refer to "1. Product name" regarding the contents of product name, "2. Packages" regarding the package drawings and "3. Product name list" regarding details of the product name. 1. Product name S-1317 A xx - xxxx U 4 Environmental code U: Lead-free (Sn 100%), halogen-free Package abbreviation and IC packing specifications*1 M5T1: SOT-23-5, Tape A4T2: HSNT-4(1010), Tape Output voltage*2 10 to 35 (e.g., when the output voltage is 1.0 V, it is expressed as 10.) Product type *1. *2. 2. Refer to the tape drawing. Contact our sales office when the product which has 0.05 V step is necessary. Packages Table 1 Package Name SOT-23-5 HSNT-4(1010) Dimension MP005-A-P-SD PL004-A-P-SD Package Drawing Codes Tape MP005-A-C-SD PL004-A-C-SD Reel MP005-A-R-SD PL004-A-R-SD Land  PL004-A-L-SD 3 5.5 V INPUT, 100 mA CMOS VOLTAGE REGULATOR WITH 0.35 A SUPER LOW CURRENT CONSUMPTION Rev.1.0_01 S-1317 Series 3. Product name list Table 2 Output Voltage SOT-23-5 HSNT-4(1010) 1.0 V  15 mV S-1317A10-M5T1U4 S-1317A10-A4T2U4 1.2 V  15 mV S-1317A12-M5T1U4 S-1317A12-A4T2U4 1.8 V  1.0% S-1317A18-M5T1U4 S-1317A18-A4T2U4 2.5 V  1.0% S-1317A25-M5T1U4 S-1317A25-A4T2U4 3.0 V  1.0% S-1317A30-M5T1U4 S-1317A30-A4T2U4 Remark Please contact our sales office for products with specifications other than the above. 4 5.5 V INPUT, 100 mA CMOS VOLTAGE REGULATOR WITH 0.35 A SUPER LOW CURRENT CONSUMPTION Rev.1.0_01 S-1317 Series  Pin Configurations 1. SOT-23-5 Table 3 Top view 5 4 1 2 3 Pin No. 1 2 3 4 5 Symbol VIN VSS NC*1 NC*1 VOUT Description Input voltage pin GND pin No connection No connection Output voltage pin Figure 2 *1. The NC pin is electrically open. The NC pin can be connected to the VIN pin or the VSS pin. 2. HSNT-4(1010) Table 4 Top view 1 2 4 3 Bottom view 4 3 Pin No. 1 2 3 4 Symbol VOUT VSS NC*2 VIN Description Output voltage pin GND pin No connection Input voltage pin 1 2 *1 Figure 3 *1. Connect the heat sink of backside at shadowed area to the board, and set electric potential open or GND. However, do not use it as the function of electrode. *2. The NC pin is electrically open. The NC pin can be connected to the VIN pin or the VSS pin. 5 5.5 V INPUT, 100 mA CMOS VOLTAGE REGULATOR WITH 0.35 A SUPER LOW CURRENT CONSUMPTION Rev.1.0_01 S-1317 Series  Absolute Maximum Ratings Table 5 Item (Ta = 25C unless otherwise specified) Absolute Maximum Rating Unit Symbol Input voltage VIN VSS  0.3 to VSS  6.0 Output voltage VOUT VSS  0.3 to VIN  0.3 Output current IOUT 120 Operation ambient temperature Topr 40 to 85 Storage temperature Tstg 40 to 125 Caution The absolute maximum ratings are rated values exceeding which the product could suffer damage. These values must therefore not be exceeded under any conditions. V V mA C C physical  Thermal Resistance Value Table 6 Item Junction-to-ambient thermal resistance*1 *1. JA Condition Board A Board B SOT-23-5 Board C Board D Board E Board A Board B HSNT-4(1010) Board C Board D Board E Test environment: compliance with JEDEC STANDARD JESD51-2A Remark 6 Symbol Refer to " Power Dissipation" and "Test Board" for details. Min.           Typ. 192 160    378 317    Max.           Unit C/W C/W C/W C/W C/W C/W C/W C/W C/W C/W 5.5 V INPUT, 100 mA CMOS VOLTAGE REGULATOR WITH 0.35 A SUPER LOW CURRENT CONSUMPTION Rev.1.0_01 S-1317 Series  Electrical Characteristics Table 7 Item Output voltage*1 Output current *2 Symbol Condition VOUT(E) VIN = VOUT(S)  1.0 V, IOUT = 10 mA IOUT VIN  VOUT(S)  1.0 V 1.0 V  VOUT(S) < 1.5 V 1.5 V  VOUT(S)  3.5 V 1.0 V  VOUT(S) < 1.1 V 1.1 V  VOUT(S) < 1.2 V 1.2 V  VOUT(S) < 1.3 V 1.3 V  VOUT(S) < 1.4 V 1.4 V  VOUT(S) < 1.5 V 1.5 V  VOUT(S) < 1.7 V 1.7 V  VOUT(S) < 1.8 V 1.8 V  VOUT(S) < 2.0 V 2.0 V  VOUT(S) < 2.5 V 2.5 V  VOUT(S) < 2.8 V 2.8 V  VOUT(S) < 3.0 V 3.0 V  VOUT(S)  3.5 V (Ta =25C unless otherwise specified) Test Min. Typ. Max. Unit Circuit VOUT(S) VOUT(S) VOUT(S) V 1 0.015 0.015 VOUT(S) VOUT(S) VOUT(S) V 1  0.99 1.01 *5 100   mA 3 0.50   V 1 0.40   V 1 0.30   V 1 0.20   V 1 0.10   V 1  0.050 0.080 V 1  0.040 0.060 V 1  0.040 0.050 V 1  0.030 0.040 V 1  0.020 0.030 V 1  0.019 0.021 V 1  0.018 0.020 V 1 Dropout voltage*3 Vdrop IOUT = 10 mA Line regulation VOUT1 VINVOUT VOUT(S)  0.5 V  VIN  5.5 V, IOUT = 10 mA  0.05 0.2 %/V 1 VOUT2 VOUT TaVOUT VIN = VOUT(S)  1.0 V, 1 A  IOUT  50 mA VIN = VOUT(S)  1.0 V, IOUT = 10 mA, 40C  Ta  85C  20 40 mV 1  130  ppm/C 1 ISS1 VIN = VOUT(S)  1.0 V, no load  0.35 0.53 A 2 1.5  5.5 V   60  mA 3 Load regulation Output voltage temperature coefficient*4 Current consumption during operation Input voltage Short-circuit current VIN Ishort  VIN = VOUT(S) 1.0 V, VOUT = 0 V *1. VOUT(S): Set output voltage VOUT(E): Actual output voltage Output voltage when fixing IOUT (= 10 mA) and inputting VOUT(S)  1.0 V *2. The output current at which the output voltage becomes 95% of VOUT(E) after gradually increasing the output current. *3. Vdrop = VIN1(VOUT3  0.98) VIN1 is the input voltage at which the output voltage becomes 98% of VOUT3 after gradually decreasing the input voltage. VOUT3 is the output voltage when VIN = VOUT(S)  1.0 V and IOUT = 10 mA. *4. A change in the temperature of the output voltage [mV/°C] is calculated using the following equation. VOUT VOUT [mV/°C]*1 = VOUT(S) [V]*2  TaV [ppm/°C]*3  1000 Ta OUT *1. Change in temperature of output voltage *2. Set output voltage *3. Output voltage temperature coefficient *5. Due to limitation of the power dissipation, this value may not be satisfied. Attention should be paid to the power dissipation when the output current is large. This specification is guaranteed by design. 7 5.5 V INPUT, 100 mA CMOS VOLTAGE REGULATOR WITH 0.35 A SUPER LOW CURRENT CONSUMPTION Rev.1.0_01 S-1317 Series  Test Circuits VIN  VOUT V VSS Figure 4  A  Test Circuit 1 VIN VOUT VSS Figure 5 Test Circuit 2 VIN VOUT VSS Figure 6 8 Test Circuit 3  A V  A 5.5 V INPUT, 100 mA CMOS VOLTAGE REGULATOR WITH 0.35 A SUPER LOW CURRENT CONSUMPTION Rev.1.0_01 S-1317 Series  Standard Circuit Input CIN VOUT VIN *1 Output CL *2 VSS Single GND *1. *2. GND CIN is a capacitor for stabilizing the input. CL is a capacitor for stabilizing the output. Figure 7 Caution The above connection diagram and constants will not guarantee successful operation. Perform thorough evaluation including the temperature characteristics with an actual application to set the constants.  Condition of Application Input capacitor (CIN): Output capacitor (CL): Caution A ceramic capacitor with capacitance of 1.0 F or more is recommended. A ceramic capacitor with capacitance of 1.0 F to 100 F is recommended. Generally, in a voltage regulator, an oscillation may occur depending on the selection of the external parts. Perform thorough evaluation including the temperature characteristics with an actual application using the above capacitors to confirm no oscillation occurs.  Selection of Input Capacitor (CIN) and Output Capacitor (CL) The S-1317 Series requires CL between the VOUT pin and the VSS pin for phase compensation. The operation is stabilized by a ceramic capacitor with capacitance of 1.0 F to 100 F. When using an OS capacitor, a tantalum capacitor or an aluminum electrolytic capacitor, the capacitance must also be 1.0 F to 100 F. However, an oscillation may occur depending on the equivalent series resistance (ESR). Moreover, the S-1317 Series requires CIN between the VIN pin and the VSS pin for a stable operation. Generally, an oscillaiton may occur when a voltage regulator is used under the conditon that the impedance of the power supply is high. Note that the output voltage transient characteristics vary depending on the capacitance of CIN and CL and the value of ESR. Caution Perform thorough evaluation including the temperature characteristics with an actual application to select CIN and CL. 9 5.5 V INPUT, 100 mA CMOS VOLTAGE REGULATOR WITH 0.35 A SUPER LOW CURRENT CONSUMPTION Rev.1.0_01 S-1317 Series  Explanation of Terms 1. Output voltage (VOUT) This voltage is output at an accuracy of 1.0% or 15 mV*2 when the input voltage, the output current and the temperature are in a certain condition*1. *1. *2. Differs depending on the product. When VOUT < 1.5 V: 15 mV, when VOUT  1.5 V: 1.0% Caution 2. If the certain condition is not satisfied, the output voltage may exceed the accuracy range of 1.0% or 15 mV. Refer to " Electrical Characteristics" for details. VOUT1  VINVOUT  Line regulation  Indicates the dependency of the output voltage against the input voltage. The value shows how much the output voltage changes due to a change in the input voltage after fixing output current constant. 3. Load regulation (VOUT2) Indicates the dependency of the output voltage against the output current. The value shows how much the output voltage changes due to a change in the output current after fixing input voltage constant. 4. Dropout voltage (Vdrop) Indicates the difference between input voltage (VIN1) and the output voltage when the output voltage becomes 98% of the output voltage value (VOUT3) at VIN = VOUT(S)  1.0 V after the input voltage (VIN) is decreased gradually. Vdrop = VIN1  (VOUT3  0.98) 10 5.5 V INPUT, 100 mA CMOS VOLTAGE REGULATOR WITH 0.35 A SUPER LOW CURRENT CONSUMPTION Rev.1.0_01 S-1317 Series 5. VOUT  Output voltage temperature coefficient  TaVOUT  The shaded area in Figure 8 is the range where VOUT varies in the operation temperature range when the output voltage temperature coefficient is 130 ppm/C. Example of S-1317A10 typ. product VOUT [V] 0.13 mV/C *1 VOUT(E) 0.13 mV/C 40 *1. 25 85 Ta [C] VOUT(E) is the value of the output voltage measured at Ta = 25C. Figure 8 A change in the temperature of the output voltage [mV/°C] is calculated using the following equation. VOUT VOUT [mV/°C]*1 = VOUT(S) [V]*2  TaV [ppm/°C]*3  1000 Ta OUT *1. Change in temperature of output voltage *2. Set output voltage *3. Output voltage temperature coefficient 11 5.5 V INPUT, 100 mA CMOS VOLTAGE REGULATOR WITH 0.35 A SUPER LOW CURRENT CONSUMPTION Rev.1.0_01 S-1317 Series  Operation 1. Basic operation Figure 9 shows the block diagram of the S-1317 Series to describe the basic operation. The error amplifier compares the feedback voltage (Vfb) whose output voltage (VOUT) is divided by the feedback resistors (Rs and Rf) with the reference voltage (Vref). The error amplifier controls the output transistor, consequently, the regulator starts the operation that holds VOUT constant without the influence of the input voltage (VIN). VIN *1 Current Supply Error amplifier Vref VOUT  Rf  Vfb Reference voltage circuit Rs VSS *1. Parasitic diode Figure 9 2. Output transistor In the S-1317 Series, a low on-resistance P-channel MOS FET is used between the VIN pin and the VOUT pin as the output transistor. In order to keep VOUT constant, the ON resistance of the output transistor varies appropriately according to the output current (IOUT). Caution Since a parasitic diode exists between the VIN pin and the VOUT pin due to the structure of the transistor, the IC may be damaged by a reverse current if VOUT becomes higher than VIN. Therefore, be sure that VOUT does not exceed VIN0.3 V. 3. Overcurrent protection circuit The S-1317 Series has a built-in overcurrent protection circuit to limit the overcurrent of the output transistor. When the VOUT pin is shorted to the VSS pin, that is, at the time of the output short-circuit, the output current is limited to 60 mA typ. due to the overcurrent protection circuit operation. The S-1317 Series restarts regulating when the output transistor is released from the overcurrent status. Caution This overcurrent protection circuit does not work as for thermal protection. If this IC long keeps short circuiting inside, pay attention to the conditions of input voltage and load current so that, under the usage conditions including short circuit, the loss of the IC will not exceed power dissipation. 12 5.5 V INPUT, 100 mA CMOS VOLTAGE REGULATOR WITH 0.35 A SUPER LOW CURRENT CONSUMPTION Rev.1.0_01 S-1317 Series  Precautions  Generally, when a voltage regulator is used under the condition that the load current value is small (1 A or less), the output voltage may increase due to the leakage current of an output transistor.  Generally, when a voltage regulator is used under the condition that the temperature is high, the output voltage may increase due to the leakage current of an output transistor.  Generally, when a voltage regulator is used under the condition that the impedance of the power supply is high, an oscillation may occur. Perform thorough evaluation including the temperature characteristics with an actual application to select CIN.  Generally, in a voltage regulator, an oscillation may occur depending on the selection of the external parts. The following use conditions are recommended in the S-1317 Series, however, perform thorough evaluation including the temperature characteristics with an actual application to select CIN and CL. Input capacitor (CIN): Output capacitor (CL): A ceramic capacitor with capacitance of 1.0 F or more is recommended. A ceramic capacitor with capacitance of 1.0 F to 100 F is recommended.  Generally, in a voltage regulator, the values of an overshoot and an undershoot in the output voltage vary depending on the variation factors of input voltage start-up, input voltage fluctuation and load fluctuation etc., or the capacitance of CIN or CL and the value of the equivalent series resistance (ESR), which may cause a problem to the stable operation. Perform thorough evaluation including the temperature characteristics with an actual application to select CIN and CL.  Generally, in a voltage regulator, if the VOUT pin is steeply shorted with GND, a negative voltage exceeding the absolute maximum ratings may occur in the VOUT pin due to resonance phenomenon of the inductance and the capacitance including CL on the application. The resonance phenomenon is expected to be weakened by inserting a series resistor into the resonance path, and the negative voltage is expected to be limited by inserting a protection diode between the VOUT pin and the VSS pin.  Make sure of the conditions for the input voltage, output voltage and the load current so that the internal loss does not exceed the power dissipation.  Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit.  When considering the output current value that the IC is able to output, make sure of the output current value specified in Table 7 in " Electrical Characteristics" and footnote *5 of the table.  Wiring patterns on the application related to the VIN pin, the VOUT pin and the VSS pin should be designed so that the impedance is low. When mounting CIN between the VIN pin and the VSS pin and CL between the VOUT pin and the VSS pin, connect the capacitors as close as possible to the respective destination pins of the IC.  In the package equipped with heat sink of backside, mount the heat sink firmly. Since the heat radiation differs according to the condition of the application, perform thorough evaluation with an actual application to confirm no problems happen.  ABLIC Inc. claims no responsibility for any disputes arising out of or in connection with any infringement by products including this IC of patents owned by a third party. 13 5.5 V INPUT, 100 mA CMOS VOLTAGE REGULATOR WITH 0.35 A SUPER LOW CURRENT CONSUMPTION Rev.1.0_01 S-1317 Series  Characteristics (Typical Data) Output voltage vs. Output current (When load current increases) (Ta = 25C) 1. 1. 1 VOUT = 1.0 V 1. 2 1.2 3.0 1.0 0.6 0.4 VOUT [V] VOUT [V] 2.5 VIN = 1.3 V VIN = 1.5 V VIN = 2.0 V VIN = 3.0 V VIN = 5.5 V 0.8 0.2 100 1.0 200 300 IOUT [mA] 400 0 500 100 200 300 IOUT [mA] 400 500 VOUT = 3.5 V 4.0 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0.0 VOUT [V] 1.5 0.0 0 VIN = 3.8 V VIN = 4.0 V VIN = 4.5 V VIN = 5.5 V 0 100 200 300 IOUT [mA] 400 Remark In determining the output current, attention should be paid to the following. 1. The minimum output current value and footnote *5 of Table 7 in " Electrical Characteristics" 2. Power dissipation 500 Output voltage vs. Input voltage (Ta = 25C) 2. 2. 1 VOUT = 1.0 V 2. 2 1.2 1.0 0.9 VOUT [V] VOUT [V] 1.1 IOUT = 1 mA IOUT = 10 mA IOUT = 50 mA IOUT = 100 mA 0.8 0.7 0.6 0.6 VOUT [V] 2. 3 1.0 1.4 1.8 VIN [V] 2.2 2.6 5.0 5.5 VOUT = 3.5 V 3.7 3.6 3.5 3.4 3.3 3.2 3.1 3.0 IOUT = 1 mA IOUT = 10 mA IOUT = 50 mA IOUT = 100 mA 3.0 14 VIN = 2.8 V VIN = 3.0 V VIN = 3.5 V VIN = 4.5 V VIN = 5.5 V 2.0 0.5 0.0 1. 3 VOUT = 2.5 V 3.5 4.0 4.5 VIN [V] VOUT = 2.5 V 2.7 2.6 2.5 2.4 2.3 2.2 2.1 2.0 IOUT = 1 mA IOUT = 10 mA IOUT = 50 mA IOUT = 100 mA 2.0 2.5 3.0 3.5 VIN [V] 4.0 4.5 5.5 V INPUT, 100 mA CMOS VOLTAGE REGULATOR WITH 0.35 A SUPER LOW CURRENT CONSUMPTION Rev.1.0_01 S-1317 Series 3. Dropout voltage vs. Output current 3. 1 VOUT = 1.0 V 3. 2 1.2 Vdrop [V] 0.8 Vdrop [V] Ta = +85C Ta = +25C Ta = 40C 1.0 0.6 0.4 0.2 0.0 Vdrop [V] 3. 3 4. 0 20 40 60 IOUT [mA] 80 100 80 100 VOUT = 2.5 V 0.40 0.35 0.30 0.25 0.20 0.15 0.10 0.05 0.00 Ta = +85C Ta = +25C Ta = 40C 0 20 40 60 IOUT [mA] 80 100 VOUT = 3.5 V 0.40 0.35 0.30 0.25 0.20 0.15 0.10 0.05 0.00 Ta = +85C Ta = +25C Ta = 40C 0 20 40 60 IOUT [mA] Dropout voltage vs. Set output voltage 1.2 Vdrop [V] 1.0 0.8 0.6 0.4 IOUT = 0.1 mA IOUT = 1 mA IOUT = 10 mA IOUT = 50 mA IOUT = 100 mA 0.2 0.0 1.0 1.5 2.0 2.5 VOUT(S) [V] 3.0 3.5 15 5.5 V INPUT, 100 mA CMOS VOLTAGE REGULATOR WITH 0.35 A SUPER LOW CURRENT CONSUMPTION Rev.1.0_01 S-1317 Series Output voltage vs. Ambient temperature VOUT [V] 5. 1 VOUT = 1.0 V 5. 2 2.70 1.05 2.60 1.00 0.95 0.90 5. 3 VOUT = 2.5 V 1.10 VOUT [V] 5. 2.50 2.40 −40 −25 0 25 Ta [°C] 50 75 85 0 25 Ta [°C] 50 75 85 2.30 −40 −25 0 25 Ta [°C] 50 75 85 VOUT = 3.5 V 3.80 VOUT [V] 3.70 3.60 3.50 3.40 3.30 3.20 Current consumption vs. Input voltage ISS1 [A] 6. 1 VOUT = 1.0 V 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0.0 Ta = +85C Ta = +25C Ta = 40C 0.0 ISS1 [A] 6. 3 1.0 2.0 3.0 4.0 VIN [V] 5.0 6.0 5.0 6.0 VOUT = 3.5 V 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0.0 Ta = +85C Ta = +25C Ta = 40C 0.0 16 6. 2 ISS1 [A] 6. −40 −25 1.0 2.0 3.0 4.0 VIN [V] VOUT = 2.5 V 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0.0 Ta = +85C Ta = +25C Ta = 40C 0.0 1.0 2.0 3.0 4.0 VIN [V] 5.0 6.0 5.5 V INPUT, 100 mA CMOS VOLTAGE REGULATOR WITH 0.35 A SUPER LOW CURRENT CONSUMPTION Rev.1.0_01 S-1317 Series Current consumption vs. Ambient temperature ISS1 [A] 7. 3 8. VOUT = 1.0 V 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0.0 7. 2 VIN = 2.0 V ISS1 [A] ISS1 [A] 7. 1 VIN = 5.5 V −40 −25 0 25 Ta [C] 50 VOUT = 2.5 V 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0.0 75 85 VIN = 3.5 V VIN = 5.5 V −40 −25 0 25 Ta [C] 50 75 85 VOUT = 3.5 V 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0.0 VIN = 4.5 V VIN = 5.5 V −40 −25 0 25 Ta [C] 50 75 85 Current consumption vs. Output current ISS1 [A] 8. 1 ISS1 [A] 8. 3 VOUT = 1.0 V 40 35 30 25 20 15 10 5 0 8. 2 ISS1 [A] 7. VIN = 2.0 V VIN = 5.5 V 0 20 40 60 IOUT [mA] 80 100 VOUT = 2.5 V 40 35 30 25 20 15 10 5 0 VIN = 3.5 V VIN = 5.5 V 0 20 40 60 IOUT [mA] 80 100 VOUT = 3.5 V 40 35 30 25 20 15 10 5 0 VIN = 4.5 V VIN = 5.5 V 0 20 40 60 IOUT [mA] 80 100 17 5.5 V INPUT, 100 mA CMOS VOLTAGE REGULATOR WITH 0.35 A SUPER LOW CURRENT CONSUMPTION Rev.1.0_01 S-1317 Series  Reference Data Characteristics of input transient response (Ta = 25C) VIN [V] VIN [V] IOUT = 50 mA, CIN = CL = 1 F, VIN = 3.5 V  4.5 V, tr = tf = 5.0 s 3.0 5.5 2.9 5.0 2.8 4.5 2.7 VIN 4.0 2.6 3.5 2.5 3.0 2.4 VOUT 2.5 2.3 2.0 1.5 2.2 −200 0 200 400 600 800 1000 1200 t [s] VIN [V] VIN [V] VOUT [V] VOUT = 3.5 V IOUT = 1 mA, CIN = CL = 1 F, VIN = 4.5 V  5.5 V, tr = tf = 5.0 s 4.0 6.5 3.9 6.0 3.8 5.5 3.7 5.0 VIN 3.6 4.5 3.5 4.0 3.4 VOUT 3.5 3.3 3.0 2.5 3.2 −200 0 200 400 600 800 1000 1200 t [s] IOUT = 50 mA, CIN = CL = 1 F, VIN = 4.5 V  5.5 V, tr = tf = 5.0 s 4.0 6.5 3.9 6.0 3.8 5.5 3.7 5.0 VIN 3.6 4.5 3.5 4.0 3.4 VOUT 3.5 3.3 3.0 2.5 3.2 −200 0 200 400 600 800 1000 1200 t [s] VIN [V] VOUT [V] VOUT [V] IOUT = 50 mA, CIN = CL = 1 F, VIN = 2.0 V  3.0 V, tr = tf = 5.0 s 1.5 4.0 1.4 3.5 1.3 3.0 1.2 VIN 2.5 1.1 2.0 1.0 1.5 0.9 VOUT 1.0 0.8 0.5 0.0 0.7 −200 0 200 400 600 800 1000 1200 t [s] VOUT = 2.5 V IOUT = 1 mA, CIN = CL = 1 F, VIN = 3.5 V  4.5 V, tr = tf = 5.0 s 3.0 5.5 2.9 5.0 2.8 4.5 2.7 VIN 4.0 2.6 3.5 2.5 3.0 2.4 VOUT 2.5 2.3 2.0 1.5 2.2 −200 0 200 400 600 800 1000 1200 t [s] 1. 3 VOUT [V] IOUT = 1 mA, CIN = CL = 1 F, VIN = 2.0 V  3.0 V, tr = tf = 5.0 s 1.5 4.0 1.4 3.5 1.3 3.0 1.2 VIN 2.5 1.1 2.0 1.0 1.5 VOUT 0.9 1.0 0.8 0.5 0.0 0.7 −200 0 200 400 600 800 1000 1200 t [s] 1. 2 18 VOUT = 1.0 V VIN [V] VOUT [V] 1. 1 VOUT [V] 1. 5.5 V INPUT, 100 mA CMOS VOLTAGE REGULATOR WITH 0.35 A SUPER LOW CURRENT CONSUMPTION Rev.1.0_01 S-1317 Series IOUT [mA] VIN = 3.5 V, CIN = CL = 1 F, IOUT = 10 mA  50 mA, tr = tf = 5.0 s 3.0 75 50 2.9 25 2.8 0 2.7 IOUT 25 2.6 50 2.5 75 2.4 VOUT 100 2.3 125 2.2 100 0 100 200 300 400 500 600 t [s] IOUT [mA] VOUT [V] IOUT [mA] VOUT = 3.5 V VIN = 4.5 V, CIN = CL = 1 F, IOUT = 1 mA  10 mA, tr = tf = 5.0 s 4.0 75 3.9 50 3.8 25 3.7 0 IOUT −25 3.6 −50 3.5 3.4 VOUT −75 3.3 −100 −125 3.2 −400 0 400 800 1200 1600 2000 2400 t [s] VIN = 4.5 V, CIN = CL = 1 F, IOUT = 10 mA  50 mA, tr = tf = 5.0 s 4.0 75 50 3.9 25 3.8 0 3.7 IOUT −25 3.6 −50 3.5 −75 3.4 VOUT −100 3.3 −125 3.2 −800 0 800 1600 2400 3200 4000 4800 t [s] IOUT [mA] VOUT [V] VIN = 2.0 V, CIN = CL = 1 F, IOUT = 10 mA  50 mA, tr = tf = 5.0 s 1.5 75 1.4 50 1.3 25 1.2 IOUT 0 25 1.1 50 1.0 0.9 VOUT 75 0.8 100 125 0.7 200 0 200 400 600 800 1000 1200 t [s] VOUT = 2.5 V VIN = 3.5 V, CIN = CL = 1 F, IOUT = 1 mA  10 mA, tr = tf = 5.0 s 3.0 75 2.9 50 2.8 25 2.7 0 IOUT 25 2.6 50 2.5 VOUT 2.4 75 2.3 100 125 2.2 100 0 100 200 300 400 500 600 t [s] 2. 3 VOUT [V] IOUT [mA] VIN = 2.0 V, CIN = CL = 1 F, IOUT = 1 mA  10 mA, tr = tf = 5.0 s 1.5 75 1.4 50 1.3 25 1.2 0 IOUT 1.1 25 1.0 50 VOUT 0.9 75 0.8 100 125 0.7 200 0 200 400 600 800 1000 1200 t [s] 2. 2 VOUT [V] VOUT = 1.0 V IOUT [mA] VOUT [V] 2. 1 Characteristics of load transient response (Ta = 25C) VOUT [V] 2. 19 5.5 V INPUT, 100 mA CMOS VOLTAGE REGULATOR WITH 0.35 A SUPER LOW CURRENT CONSUMPTION Rev.1.0_01 S-1317 Series 3. Ripple rejection (Ta = 25C) 3. 1 3. 2 VOUT = 1.0 V VOUT = 2.5 V IOUT = 1 mA IOUT = 10 mA IOUT = 50 mA IOUT = 100 mA 10 3. 3 100 VIN = 3.5 V, CL = 1.0 F Ripple Rejection [dB] Ripple Rejection [dB] VIN = 2.0 V, CL = 1.0 F 100 90 80 70 60 50 40 30 20 10 0 1k 10k 100k Frequency [Hz] 100 90 80 70 60 50 40 30 20 10 0 IOUT = 1 mA IOUT = 10 mA IOUT = 50 mA IOUT = 100 mA 10 1M 100 1k 10k 100k Frequency [Hz] 1M VOUT = 3.5 V Ripple Rejection [dB] VIN = 4.5 V, CL = 1.0 F 100 90 80 70 60 50 40 30 20 10 0 IOUT = 1 mA IOUT = 10 mA IOUT = 50 mA IOUT = 100 mA 10 4. 100 1k 10k 100k Frequency [Hz] 1M Example of equivalent series resistance vs. Output current characteristics (Ta = 25C) CIN = CL = 1.0 F 100 RESR [] VIN CIN Stable VOUT S-1317 Series CL 0 0.01 VSS 100 *1 RESR IOUT [mA] *1. Figure 10 20 CL: TDK Corporation C3216X7R1H105K160AB Figure 11 5.5 V INPUT, 100 mA CMOS VOLTAGE REGULATOR WITH 0.35 A SUPER LOW CURRENT CONSUMPTION Rev.1.0_01 S-1317 Series  Power Dissipation SOT-23-5 HSNT-4(1010) Tj = 125C max. 0.8 B 0.6 A 0.4 0.2 0.0 0 25 50 75 100 125 150 175 Tj = 125C max. 1.0 Power dissipation (PD) [W] Power dissipation (PD) [W] 1.0 0.8 0.6 0.4 B 0.2 A 0.0 0 25 Ambient temperature (Ta) [C] Board A B C D E Power Dissipation (PD) 0.52 W 0.63 W    50 75 100 125 150 175 Ambient temperature (Ta) [C] Board A B C D E Power Dissipation (PD) 0.26 W 0.32 W    21 SOT-23-3/3S/5/6 Test Board IC Mount Area (1) Board A Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 2 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.070 - (2) Board B Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] Thermal via 1 2 3 4 Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - No. SOT23x-A-Board-SD-2.0 ABLIC Inc. HSNT-4(1010) Test Board IC Mount Area (1) Board A Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 2 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.070 - (2) Board B Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] Thermal via 1 2 3 4 Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - No. HSNT4-B-Board-SD-1.0 ABLIC Inc. 2.9±0.2 1.9±0.2 4 5 1 2 +0.1 0.16 -0.06 3 0.95±0.1 0.4±0.1 No. MP005-A-P-SD-1.3 TITLE SOT235-A-PKG Dimensions No. MP005-A-P-SD-1.3 ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches:40.0±0.2) +0.1 ø1.5 -0 +0.2 ø1.0 -0 2.0±0.05 0.25±0.1 4.0±0.1 1.4±0.2 3.2±0.2 3 2 1 4 5 Feed direction No. MP005-A-C-SD-2.1 TITLE SOT235-A-Carrier Tape No. MP005-A-C-SD-2.1 ANGLE UNIT mm ABLIC Inc. 12.5max. 9.0±0.3 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. MP005-A-R-SD-1.1 SOT235-A-Reel TITLE No. MP005-A-R-SD-1.1 ANGLE QTY. UNIT mm ABLIC Inc. 3,000 0.38±0.02 0.65 3 4 1 2 1.00±0.04 0.20±0.05 +0.05 0.08 -0.02 The heat sink of back side has different electric potential depending on the product. Confirm specifications of each product. Do not use it as the function of electrode. No. PL004-A-P-SD-1.1 TITLE HSNT-4-B-PKG Dimensions No. PL004-A-P-SD-1.1 ANGLE UNIT mm ABLIC Inc. 2.0±0.05 +0.1 ø1.5 -0 4.0±0.05 0.25±0.05 +0.1 1.12±0.05 2 1 3 4 ø0.5 -0 2.0±0.05 0.5±0.05 Feed direction No. PL004-A-C-SD-2.0 TITLE HSNT-4-B-C a r r i e r Tape No. PL004-A-C-SD-2.0 ANGLE UNIT mm ABLIC Inc. +1.0 9.0 - 0.0 11.4±1.0 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. PL004-A-R-SD-1.0 HSNT-4-B-Reel TITLE PL004-A-R-SD-1.0 No. QTY. ANGLE UNIT mm ABLIC Inc. 10,000 Land Pattern 0.30min. 0.38~0.48 0.38~0.48 0.07 0.65±0.02 (1.02) Caution It is recommended to solder the heat sink to a board in order to ensure the heat radiation. PKG Metal Mask Pattern Aperture ratio Aperture ratio Caution Mask aperture ratio of the lead mounting part is 100%. Mask aperture ratio of the heat sink mounting part is 40%. Mask thickness: t0.10mm to 0.12 mm 100% 40% t0.10mm ~ 0.12 mm TITLE No. PL004-A-L-SD-2.0 HSNT-4-B -Land Recommendation PL004-A-L-SD-2.0 No. ANGLE UNIT mm ABLIC Inc. Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-1317A33-M5T1U4 价格&库存
很抱歉,暂时无法提供与“S-1317A33-M5T1U4”相匹配的价格&库存,您可以联系我们找货
