STK14C88
32Kx8 AutoStore nvSRAM
FEATURES
DESCRIPTION
• 25, 35, 45 ns Read Access & R/W Cycle Time
The Simtek STK14C88 is a 256Kb fast static RAM
with a non-volatile Quantum Trap storage element
included with each memory cell.
• Unlimited Read/Write Endurance
• Automatic Non-volatile STORE on Power Loss
The SRAM provides the fast access & cycle times,
ease of use and unlimited read & write endurance of
a normal SRAM.
• Non-Volatile STORE Under Hardware or
Software Control
• Automatic RECALL to SRAM on Power Up
Data transfers automatically to the non-volatile storage cells when power loss is detected (the STORE
operation). On power up, data is automatically
restored to the SRAM (the RECALL operation). Both
STORE and RECALL operations are also available
under software control.
• Unlimited RECALL Cycles
• 1 Million STORE Cycles
• 100-Year Non-volatile Data Retention
• Single 5V +10% Power Supply
• Commercial, Industrial, Military Temperatures
The Simtek nvSRAM is the first monolithic non-volatile memory to offer unlimited writes and reads. It is
the highest performance, most reliable non-volatile
memory available.
• 32-Pin 300 mil SOIC (RoHS-Compliant)
• 32-pin CDIP and LCC Packages
BLOCK DIAGRAM
VCCX
DQ0
DQ1
DQ2
DQ3
DQ4
DQ5
DQ6
DQ7
INPUT BUFFERS
A5
A6
A7
A8
A9
A11
A12
A13
A14
ROW DECODER
Quantum Trap
512 x 512
VCAP
POWER
CONTROL
STORE
STATIC RAM
ARRAY
512 x 512
RECALL
STORE/
RECALL
CONTROL
SOFTWARE
DETECT
COLUMN I/O
HSB
A0 - A13
COLUMN DEC
A0 A1 A2 A3 A4 A10
G
E
W
This product conforms to specifications per the
terms of Simtek standard warranty. The product
has completed Simtek internal qualification testing
and has reached production status.
1
Document Control #ML0014 Rev 2.0
Feb, 2008
STK14C88
31
HSB
3
30
4
A6
W
A13
A8
W
2
A12
A7
HSB
A14
VCap
VCC
VCCx
32
A14
1
A7
VCAP
A12
PIN CONFIGURATIONS
5
29
28
A6
A13
A5
A4
A3
6
27
A9
A5
A8
A4
26
A11
A9
A3
A11
25
NC
NC
A2
9
24
G
NC
A2
NC
10
23
A10
A1
A10
A1
A0
11
22
12
21
DQ0
13
DQ1
DQ2
14
19
DQ6
DQ5
15
18
DQ4
VSS
16
17
DQ3
(TOP)
G
A0
E
DQ7
E
DQ0
DQ6
DQ5
DQ4
DQ7
DQ3
8
DQ2
VSS
(TOP)
DQ1
7
32-Pin 450 mil LCC
32-Pin 300 mil SOIC
32-Pin 300 mil CDIP
PIN DESCRIPTIONS
Pin Name
I/O
Description
A14-A0
Input
Address: The 15 address inputs select one of 32,768 bytes in the nvSRAM array
DQ7-DQ0
I/O
Data: Bi-directional 8-bit data bus for accessing the nvSRAM
E
Input
Chip Enable: The active low E input selects the device
W
Input
Write Enable: The active low W enables data on the DQ pins to be written to the address
location latched by the falling edge of E
G
Input
Output Enable: The active low G input enables the data output buffers during read cycles.
De-asserting G high caused the DQ pins to tri-state.
VCC
Power Supply
Power: 5.0V, +10%
HSB
I/O
Hardware Store Busy: When low this output indicates a Store is in progress. When pulled
low external to the chip, it will initiate a nonvolatile STORE operation. A weak pull up resistor
keeps this pin high if not connected. (Connection Optional).
VCAP
Power Supply
AutoStore Capacitor: Supplies power to nvSRAM during power loss to store data from
SRAM to nonvolatile storage elements.
VSS
Power Supply
Ground
Feb, 2008
2
STK14C88
ABSOLUTE MAXIMUM
RATINGSa
Voltage on Input Relative to Ground . . . . . . . . . . . . . –0.5V to 7.0V
Voltage on Input Relative to VSS . . . . . . . . . .–0.6V to (VCC + 0.5V)
Voltage on DQ0-7 or HSB . . . . . . . . . . . . . . . .–0.5V to (VCC + 0.5V)
Temperature under Bias. . . . . . . . . . . . . . . . . . . . . .–55°C to 125°C
Storage Temperature . . . . . . . . . . . . . . . . . . . . . . . .–65°C to 150°C
Power Dissipation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1W
DC Output Current (1 output at a time, 1s duration) . . . . . . . 15mA
Note a: Stresses greater than those listed under “Absolute Maximum
Ratings” may cause permanent damage to the device. This is a
stress rating only, and functional operation of the device at conditions above those indicated in the operational sections of this
specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect reliability.
(VCC = 5.0V ± 10%)e
DC CHARACTERISTICS
INDUSTRIAL/
Military
COMMERCIAL
SYMBOL
PARAMETER
MIN
MAX
MIN
UNITS
NOTES
MAX
ICC1b
Average VCC Current
97
80
70
100
85
70
mA
mA
mA
ICC2c
Average VCC Current during STORE
3
3
mA
All Inputs Don’t Care, VCC = max
ICC3b
Average VCC Current at tAVAV = 200ns
5V, 25°C, Typical
10
10
mA
W ≥ (V CC – 0.2V)
All Others Cycling, CMOS Levels
Average VCAP Current during AutoStore
Cycle
2
2
mA
30
25
22
31
26
23
mA
mA
mA
tAVAV = 25ns, E ≥ VIH
tAVAV = 35ns, E ≥ VIH
tAVAV = 45ns, E ≥ VIH
1.5
1.5
mA
E ≥ (V CC – 0.2V)
All Others VIN ≤ 0.2V or ≥ (VCC – 0.2V)
ICC4
c
tAVAV = 25ns
tAVAV = 35ns
tAVAV = 45ns
ISB1d
Average VCC Current
(Standby, Cycling TTL Input Levels)
ISB2d
VCC Standby Current
(Standby, Stable CMOS Input Levels)
IILK
Input Leakage Current
±1
±1
μA
VCC = max
VIN = VSS to VCC
IOLK
Off-State Output Leakage Current
±5
±5
μA
VCC = max
VIN = VSS to VCC, E or G ≥ VIH
VIH
Input Logic “1” Voltage
2.2
VCC + .5
2.2
VCC + .5
V
All Inputs
VIL
Input Logic “0” Voltage
VSS – .5
0.8
VSS – .5
0.8
V
All Inputs
VOH
Output Logic “1” Voltage
V
IOUT = – 4mA except HSB
VOL
Output Logic “0” Voltage
0.4
0.4
V
IOUT = 8mA except HSB
VBL
Logic “0” Voltage on HSB Output
0.4
0.4
V
IOUT = 3mA
TA
Operating Temperature
85/125
°C
Note b:
Note c:
Note d:
Note e:
2.4
70
-40/-55
ICC1 and ICC3 are dependent on output loading and cycle rate. The specified values are obtained with outputs unloaded.
ICC2 and ICC4 are the average currents required for the duration of the respective STORE cycles (tSTORE ) .
E ≥ VIH will not produce standby current levels until any nonvolatile cycle in progress has timed out.
VCC reference levels throughout this datasheet refer to VCC if that is where the power supply connection is made, or VCAP if VCC is connected
to ground.
AC TEST CONDITIONS
5.0V
Input Pulse Levels . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0V to 3V
Input Rise and Fall Times. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ≤ 5ns
Input and Output Timing Reference Levels . . . . . . . . . . . . . . . 1.5V
Output Load . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . See Figure 1
CAPACITANCEf
SYMBOL
(TA = 25°C, f = 1.0MHz)
PARAMETER
MAX
UNITS
CONDITIONS
CIN
Input Capacitance
5
pF
ΔV = 0 to 3V
COUT
Output Capacitance
7
pF
ΔV = 0 to 3V
Note f:
OUTPUT
255 Ohms
30 pF
INCLUDING
SCOPE AND
FIXTURE
Figure 1: AC Output Loading
These parameters are guaranteed but not tested.
Feb, 2008
480 Ohms
3
STK14C88
(VCC = 5.0V ± 10%)e
SRAM READ CYCLES #1 & #2
SYMBOLS
NO.
STK14C88-25
STK14C88-35
STK14C88-45
MIN
MIN
MIN
PARAMETER
#1, #2
UNITS
Alt.
MAX
MAX
25
1
tELQV
tACS
Chip Enable Access Time
2
tAVAVg, tELEHg
tRC
Read Cycle Time
3
tAVQVh
tAA
Address Access Time
25
35
45
4
tGLQV
tOE
Output Enable to Data Valid
10
15
tAXQXh
tOH
Output Hold after Address Change
5
6
tELQX
tLZ
Address Change or Chip Enable to Output Active
5
7
tEHQZi
tHZ
Address Change or Chip Disable to Output Inactive
8
tGLQX
tOLZ
Output Enable to Output Active
25
9
tGHQZi
tOHZ
Output Disable to Output Inactive
tELICCHf
tPA
Chip Enable to Power Active
11
tEHICCLf
tPS
Chip Disable to Power Standby
45
35
45
5
5
Note g: W and HSB must be high during SRAM READ cycles.
Note h: I/O state assumes E and G < VIL and W > VIH; device is continuously selected.
Note i: Measured ± 200mV from steady state output voltage.
SRAM READ CYCLE #1: Address Controlledg, h
2
tAVAV
ADDRESS
3
tAVQV
5
tAXQX
DQ (DATA OUT)
DATA VALID
SRAM READ CYCLE #2: E and G Controlledg
ADDR ESS
2
E
27
t E LE H
1
tEL Q V
6
29
t EHAX
11
t EHI CC L
t ELQ X
7
t EHQ Z
3
t AV QV
G
8
tG L Q X
9
t GH Q Z
4
t G L QV
DQ (D ATA OUT)
DAT A VAL ID
10
t ELI CC H
AC T IVE
I CC
ST AND BY
Feb, 2008
4
ns
ns
15
ns
45
ns
ns
ns
15
ns
ns
5
13
ns
ns
5
10
35
MAX
ns
STK14C88
(VCC = 5.0V ± 10%)e
SRAM WRITE CYCLES #1 & #2
SYMBOLS
STK14C88-25
NO.
STK14C88-35
STK14C88-45
PARAMETER
#1
#2
Alt.
UNITS
MIN
MAX
MIN
MAX
MIN
MAX
12
tAVAV
tAVAV
tWC
Write Cycle Time
25
35
45
ns
13
tWLWH
tWLEH
tWP
Write Pulse Width
30
ns
ns
14
tELWH
tELEH
tCW
Chip Enable to End of Write
30
15
tDVWH
tDVEH
tDW
Data Set-up to End of Write
10
12
15
ns
16
tWHDX
tEHDX
tDH
Data Hold after End of Write
ns
17
tAVWH
tAVEH
tAW
Address Set-up to End of Write
30
ns
18
tAVWL
tAVEL
tAS
Address Set-up to Start of Write
ns
19
tWHAX
tEHAX
tWR
Address Hold after End of Write
t WLQZ i, j
tWZ
Write Enable to Output Disable
21
tWHQX
tOW
Output Active after End of Write
5
13
5
5
Note j: If W is low when E goes low, the outputs remain in the high-impedance state.
Note k: E or W must be ≥ VIH during address transitions.
Note l: HSB must be high during SRAM WRITE cycles.
SRAM WRITE CYCLE #1: W Controlledk, l
12
tAVAV
ADDRESS
19
tWHAX
14
tELWH
E
17
tAVWH
18
tAVWL
13
tWLWH
W
15
tDVWH
DATA IN
DATA VALID
tWLQZ
DATA OUT
16
tWHDX
21
tWHQX
HIGH IMPEDANCE
PREVIOUS DATA
SRAM WRITE CYCLE #2: E Controlledk, l
12
tAVAV
ADDRESS
18
tAVEL
14
tELEH
19
tEHAX
E
17
tAVEH
13
tWLEH
W
15
tDVEH
DATA IN
DATA OUT
Feb, 2008
16
tEHDX
DATA VALID
HIGH IMPEDANCE
5
ns
15
ns
ns
STK14C88
HARDWARE MODE SELECTION
E
W
HSB
A13 - A0 (hex)
H
X
H
X
L
H
H
L
L
H
X
X
L
X
MODE
I/O
POWER
Not Selected
Output High Z
Standby
X
Read SRAM
Output Data
Active
X
Write SRAM
Input Data
Active
Nonvolatile STORE
Output High Z
lCC2
NOTES
t
m
Note m: HSB STORE operation occurs only if an SRAM WRITE has been done since the last nonvolatile cycle. After the STORE (if any) completes,
the part will go into standby mode, inhibiting all operations until HSB rises.
(VCC = 5.0V ± 10%)e
HARDWARE STORE CYCLE
SYMBOLS
STK14C88
NO.
PARAMETER
Standard
Alternate
MIN
22
tSTORE
tHLHZ
STORE Cycle Duration
23
tDELAY
tHLQZ
Time Allowed to Complete SRAM Cycle
24
tRECOVER
tHHQX
Hardware STORE High to Inhibit Off
25
tHLHX
Hardware STORE Pulse Width
26
tHLBL
Hardware STORE Low to STORE Busy
UNITS
NOTES
ms
n
MAX
10
1
700
15
μs
n
ns
n, o
ns
300
ns
Note n: E and G low and W high for output behavior.
Note o: tRECOVER is only applicable after tSTORE is complete.
25
tHLHX
HSB (IN)
24
tRECOVER
22
tSTORE
26
tHLBL
HSB (OUT)
HIGH IMPEDANCE
HIGH IMPEDANCE
23
tDELAY
DQ (DATA OUT)
DATA VALID
DATA VALID
Feb, 2008
6
STK14C88
(VCC = 5.0V ± 10%)e
AutoStore™/POWER-UP RECALL
SYMBOLS
STK14C88
NO.
PARAMETER
Standard
27
tRESTORE
28
tSTORE
Alternate
tHLHZ
UNITS
MIN
Power-up RECALL Duration
550
μs
p
10
ms
n, q
29
tVSBL
30
tDELAY
31
VSWITCH
Low Voltage Trigger Level
32
VRESET
Low Voltage Reset Level
Low Voltage Trigger (VSWITCH) to HSB Low
tBLQZ
NOTES
MAX
300
1
4.0
ns
l
μs
n
4.5
V
3.6
V
Note p: tRESTORE starts from the time VCC rises above VSWITCH.
Note q: HSB is asserted low for 1μs when VCAP drops through VSWITCH. If an SRAM WRITE has not taken place since the last nonvolatile cycle, HSB
will be released and no STORE will take place.
VCC
31
VSWITCH
32
VRESET
AutoStore
POWER-UP RECALL
29
tVSBL
27
tRESTORE
28
tSTORE
HSB
30
tDELAY
W
DQ (DATA OUT)
POWER-UP
RECALL
BROWN OUT
NO STORE
(NO SRAM WRITES)
BROWN OUT
AutoStore
BROWN OUT
AutoStore
NO RECALL
(VCC DID NOT GO
BELOW VRESET)
NO RECALL
(VCC DID NOT GO
BELOW VRESET)
RECALL WHEN
VCC RETURNS
ABOVE VSWITCH
Feb, 2008
7
STK14C88
SOFTWARE STORE/RECALL MODE SELECTION
E
L
L
W
A13 - A0 (hex)
MODE
I/O
POWER
NOTES
H
0E38
31C7
03E0
3C1F
303F
Read SRAM
Read SRAM
Read SRAM
Read SRAM
Read SRAM
Output Data
Output Data
Output Data
Output Data
Output Data
Active
n, r, s, t
0FC0
Nonvolatile STORE
Output High Z
ICC2
0E38
31C7
03E0
3C1F
303F
0C63
Read SRAM
Read SRAM
Read SRAM
Read SRAM
Read SRAM
Nonvolatile RECALL
Output Data
Output Data
Output Data
Output Data
Output Data
Output High Z
Active
H
(VCC = 5.0V ± 10%)e
SOFTWARE-CONTROLLED STORE/RECALL CYCLEv
SYMBOLS
STK14C88-25
NO.
STK14C88-35
STK14C88-45
PARAMETER
Standard
Alternate
n, r, s, t
UNITS NOTES
MIN
MAX
MIN
MAX
MIN
MAX
33
tAVAV
tRC
STORE/RECALL Initiation Cycle Time
25
35
45
ns
n
34
tAVEL
tAS
Address Set-up Time
ns
u,v
35
tELEH
tCW
Clock Pulse Width
30
ns
u,v
36
tELAX
Address Hold Time
ns
u, v
37
tRECALL
RECALL Duration
Note r:
μs
The six consecutive addresses must be in the order listed. W must be high during all six consecutive E controlled cycles to enable a nonvolatile
cycle.
Note s: While there are 15 addresses on the STK14C88, only the lower 14 are used to control software modes.
Note t: I/O state assumes G < VIL. Activation of nonvolatile cycles does not depend on state of G.
Note u: The software sequence is clocked on the falling edge of E controlled READs without involving G (double clocking will abort the sequence). See
application note: MA0002 http://www.simtek.com/attachments/appNote02.pdf.
Note v: The six consecutive addresses must be in the order listed in the Software STORE/RECALL Mode Selection Table: (0E38, 31C7, 03E0, 3C1F,
303F, 0FC0) for a STORE cycle or (0E38, 31C7, 03E0, 3C1F, 303F, 0C63) for a RECALL cycle. W must be high during all six consecutive
cycles.
SOFTWARE STORE/RECALL CYCLE: E CONTROLLEDv
33
33
tAVAV
ADDRESS
tAVAV
ADDRESS #1
34
tAVEL
ADDRESS #6
35
tELEH
E
36
tELAX
28
tSTORE
DQ (DATA
DATA VALID
DATA VALID
Feb, 2008
8
37
/ tRECALL
HIGH IMPEDANCE
STK14C88
nvSRAM OPERATION
The STK14C88 has two separate modes of operation: SRAM mode and nonvolatile mode. In SRAM
mode, the memory operates as a standard fast
static RAM. In nonvolatile mode, data is transferred
from SRAM to nonvolatile elements (the STORE
operation) or from nonvolatile elements to SRAM
(the RECALL operation). In this mode SRAM functions are disabled.
NOISE CONSIDERATIONS
The STK14C88 is a high-speed memory and so
must have a high-frequency bypass capacitor of
approximately 0.1μF connected between VCAP and
VSS, using leads and traces that are as short as possible. As with all high-speed CMOS ICs, normal careful routing of power, ground and signals will help
prevent noise problems.
SRAM READ
The STK14C88 performs a READ cycle whenever E
and G are low and W and HSB are high. The
address specified on pins A0-14 determines which of
the 32,768 data bytes will be accessed. When the
READ is initiated by an address transition, the outputs will be valid after a delay of tAVQV (READ cycle
#1). If the READ is initiated by E or G, the outputs will
be valid at tELQV or at tGLQV, whichever is later (READ
cycle #2). The data outputs will repeatedly respond to
address changes within the tAVQV access time without
the need for transitions on any control input pins, and
will remain valid until another address change or until
E or G is brought high, or W or HSB is brought low.
SRAM WRITE
A WRITE cycle is performed whenever E and W are
low and HSB is high. The address inputs must be
stable prior to entering the WRITE cycle and must
remain stable until either E or W goes high at the
end of the cycle. The data on the common I/O pins
DQ0-7 will be written into the memory if it is valid tDVWH
before the end of a W controlled WRITE or tDVEH
before the end of an E controlled WRITE.
It is recommended that G be kept high during the
entire WRITE cycle to avoid data bus contention on
common I/O lines. If G is left low, internal circuitry
will turn off the output buffers tWLQZ after W goes low.
Feb, 2008
9
POWER-UP RECALL
During power up, or after any low-power condition
(VCAP < VRESET), an internal RECALL request will be
latched. When VCAP once again exceeds the sense
voltage of VSWITCH, a RECALL cycle will automatically
be initiated and will take tRESTORE to complete.
If the STK14C88 is in a WRITE state at the end of
power-up RECALL, the SRAM data will be corrupted.
To help avoid this situation, a 10K Ohm resistor
should be connected either between W and system
VCC or between E and system VCC.
SOFTWARE NONVOLATILE STORE
The STK14C88 software STORE cycle is initiated by
executing sequential E controlled READ cycles from
six specific address locations. During the STORE
cycle an erase of the previous nonvolatile data is
first performed, followed by a program of the nonvolatile elements. The program operation copies the
SRAM data into nonvolatile memory. Once a STORE
cycle is initiated, further input and output are disabled until the cycle is completed.
Because a sequence of READs from specific
addresses is used for STORE initiation, it is important that no other READ or WRITE accesses intervene in the sequence, or the sequence will be
aborted and no STORE or RECALL will take place.
To initiate the software STORE cycle, the following
READ sequence must be performed:
1.
2.
3.
4.
5.
6.
Read address
Read address
Read address
Read address
Read address
Read address
0E38 (hex)
31C7 (hex)
03E0 (hex)
3C1F (hex)
303F (hex)
0FC0 (hex)
Valid READ
Valid READ
Valid READ
Valid READ
Valid READ
Initiate STORE cycle
The software sequence must be clocked with E controlled READs.
Once the sixth address in the sequence has been
entered, the STORE cycle will commence and the
chip will be disabled. It is important that READ cycles
and not WRITE cycles be used in the sequence,
although it is not necessary that G be low for the
sequence to be valid. After the tSTORE cycle time has
been fulfilled, the SRAM will again be activated for
READ and WRITE operation.
STK14C88
SOFTWARE NONVOLATILE RECALL
A software RECALL cycle is initiated with a sequence
of READ operations in a manner similar to the software STORE initiation. To initiate the RECALL cycle,
the following sequence of E controlled READ operations must be performed:
1.
2.
3.
4.
5.
6.
Read address
Read address
Read address
Read address
Read address
Read address
0E38 (hex)
31C7 (hex)
03E0 (hex)
3C1F (hex)
303F (hex)
0C63 (hex)
Valid READ
Valid READ
Valid READ
Valid READ
Valid READ
Initiate RECALL cycle
Internally, RECALL is a two-step procedure. First, the
SRAM data is cleared, and second, the nonvolatile
information is transferred into the SRAM cells. After
the tRECALL cycle time the SRAM will once again be
ready for READ and WRITE operations. The RECALL
operation in no way alters the data in the nonvolatile
elements. The nonvolatile data can be recalled an
unlimited number of times.
AutoStore MODE
The STK14C88 can be powered in one of three
modes.
During normal AutoStore operation, the STK14C88
will draw current from VCC to charge a capacitor connected to the VCAP pin. This stored charge will be
used by the chip to perform a single STORE operation. After power up, when the voltage on the VCAP
pin drops below VSWITCH, the part will automatically
disconnect the VCAP pin from VCC and initiate a
STORE operation.
Figure 1 shows the proper connection of capacitors
for automatic store operation. A charge storage
capacitor having a capacity of between 68μF and
220μF (± 20%) rated at 6V should be provided.
In system power mode, both VCC and VCAP are connected to the + 5V power supply without the 68μF
capacitor. In this mode the AutoStore function of the
STK14C88 will operate on the stored system charge
as power goes down. The user must, however,
guarantee that VCC does not drop below 3.6V during
the 10ms STORE cycle.
If an automatic STORE on power loss is not required,
then VCC can be tied to ground and + 5V applied to
VCAP (Figure 2). This is the AutoStore Inhibit mode,
in which the AutoStore function is disabled. If the
STK14C88 is operated in this configuration, references to VCC should be changed to VCAP throughout
this data sheet. In this mode, STORE operations may
be triggered through software control or the HSB
pin. To enable or disable AutoStore using an IO port
pin, see “PREVENTING STORES” on page 12.
In order to prevent unneeded STORE operations,
automatic STOREs as well as those initiated by
externally driving HSB low will be ignored unless at
least one WRITE operation has taken place since the
most recent STORE or RECALL cycle. Softwareinitiated STORE cycles are performed regardless of
whether a WRITE operation has taken place.
If the power supply drops faster than 20 μs/volt
before VCC reaches VSWITCH, then a 2.2 ohm resistor
should be inserted between VCC and the system supply to avoid momentary excess of current between
Vcc and Vcap.
1
32
31
0.1μF
Bypass
68μF
6v, ±20%
30
16
17
Figure 1: AutoStore Mode
Feb, 2008
10
10kΩ
10kΩ∗
STK14C88
AutoStore INHIBIT MODE
1
10KΩ
10K?
10KΩ
10K?
0.1µF
Bypass
required, then VCC can be tied to ground and system power applied to VCAP (Figure 2). This is the
AutoStore Inhibit Mode, in which the AutoStore function is disabled. If the STK14C88 is operated in this
to VCAP throughout this data sheet. In this mode,
STORE operations may be triggered through software control. It is not permissible to change
between these three options “on the fly.”
32
31
be allowed a time, tDELAY, to complete. However, any
SRAM WRITE cycles requested after HSB goes low
will be inhibited until HSB returns high.
The HSB pin can be used to synchronize multiple
STK14C88s while using a single larger capacitor. To
operate in this mode the HSB pin should be connected together to the HSB pins from the other
STK14C88s. An external pull-up resistor to + 5V is
required since HSB acts as an open drain pull down.
The VCAP pins from the other STK14C88 parts can
be tied together and share a single capacitor. The
capacitor size must be scaled by the number of
devices connected to it. When any one of the
STK14C88s detects a power loss and asserts HSB,
the common HSB pin will cause all parts to request
a STORE cycle (a STORE will take place in those
STK14C88s that have been written since the last
nonvolatile cycle).
30
During any STORE operation, regardless of how it
was initiated, the STK14C88 will continue to drive
the HSB pin low, releasing it only when the STORE is
complete. Upon completion of the STORE operation
the STK14C88 will remain disabled until the HSB
pin returns high.
If HSB is not used, it should be left unconnected.
16
17
BEST PRACTICES
Figure 2: AutoStore Inhibit Mode
HSB OPERATION
The STK14C88 provides the HSB pin for controlling
and acknowledging the STORE operations. The HSB
pin can be used to request a hardware STORE cycle.
When the HSB pin is driven low, the STK14C88 will
conditionally initiate a STORE operation after tDELAY;
an actual STORE cycle will only begin if a WRITE to
the SRAM took place since the last STORE or
RECALL cycle. The HSB pin has a very resistive
pullup and is internally driven low to indicate a busy
condition while the STORE (initiated by any means)
is in progress. Pull up this pin with an external 10K
ohm resistor to VCAP if HSB is used as a driver.
SRAM READ and WRITE operations that are in
progress when HSB is driven low by any means are
given time to complete before the STORE operation
is initiated. After HSB goes low, the STK14C88 will
continue SRAM operations for tDELAY. During tDELAY,
multiple SRAM READ operations may take place. If a
WRITE is in progress when HSB is pulled low it will
Feb, 2008
11
nvSRAM products have been used effectively for
over 15 years. While ease-of-use is one of the product’s main system values, experience gained working with hundreds of applications has resulted in the
following suggestions as best practices:
• The non-volatile cells in an nvSRAM are programmed on the test floor during final test and
quality assurance. Incoming inspection routines
at customer or contract manufacturer’s sites will
sometimes reprogram these values. Final NV patterns are typically repeating patterns of AA, 55,
00, FF, A5, or 5A. End product’s firmware should
not assume an NV array is in a set programmed
state. Routines that check memory content values to determine first time system configuration,
cold or warm boot status, etc. should always program a unique NV pattern (e.g., complex 4-byte
pattern of 46 E6 49 53 hex or more random
bytes) as part of the final system manufacturing
test to ensure these system routines work consistently.
STK14C88
PREVENTING STORES
The STORE function can be disabled on the fly by
holding HSB high with a driver capable of sourcing
30mA at a VOH of at least 2.2V, as it will have to overpower the internal pull-down device that drives HSB
low for 20μs at the onset of a STORE. When the
STK14C88 is connected for AutoStore operation
(system VCC connected to VCC and a 68μF capacitor
on VCAP) and VCC crosses VSWITCH on the way down,
the STK14C88 will attempt to pull HSB low; if HSB
doesn’t actually get below VIL, the part will stop trying to pull HSB low and abort the STORE attempt.
HARDWARE PROTECT
The STK14C88 offers hardware protection against
inadvertent STORE operation and SRAM WRITEs during low-voltage conditions. When VCAP < VSWITCH, all
externally initiated STORE operations and SRAM
WRITEs will be inhibited.
AutoStore can be completely disabled by tying VCC
to ground and applying + 5V to VCAP. This is the
AutoStore
Inhibit mode; in this mode STOREs are only
initiated by explicit request using either the software
sequence or the HSB pin.
LOW AVERAGE ACTIVE POWER
The STK14C88 draws significantly less current
when it is cycled at times longer than 50ns. Figure 3
shows the relationship between ICC and READ cycle
Feb, 2008
12
100
Average Active Current (mA)
• The Vcap value specified in this datasheet
includes a minimum and a maximum value size.
Best practice is to meet this requirement and not
exceed the max Vcap value because the nvSRAM
internal algorithm calculates Vcap charge time
based on this max Vcap value. Customers that
want to use a larger Vcap value to make sure
there is extra store charge and store time should
discuss their Vcap size selection with Simtek to
understand any impact on the Vcap voltage level
at the end of a tRECALL period.
time. Worst-case current consumption is shown for
both CMOS and TTL input levels (commercial temperature range, VCC = 5.5V, 100% duty cycle on chip
enable). Figure 4 shows the same relationship for
WRITE cycles. If the chip enable duty cycle is less
than 100%, only standby current is drawn when the
chip is disabled. The overall average current drawn
by the STK14C88 depends on the following items:
1) CMOS vs. TTL input levels; 2) the duty cycle of
chip enable; 3) the overall cycle rate for accesses;
4) the ratio of READs to WRITEs; 5) the operating
temperature; 6) the Vcc level; and 7) I/O loading.
80
60
40
TTL
CMOS
100
150
Cycle Time (ns)
200
Figure 3: Icc (max) Reads
100
• Power up boot firmware routines should rewrite
the nvSRAM into the desired state (autostore
enabled, etc.). While the nvSRAM is shipped in a
preset state, best practice is to again rewrite the
nvSRAM into the desired state as a safeguard
against events that might flip the bit inadvertently
(program bugs, incoming inspection routines,
etc.).
80
60
TTL
40
CMOS
100
150
Cycle Time (ns)
Figure 4: Icc (max) Writes
200
STK14C88
Commercial and Industrial Ordering Information
STK14C88 - N F 45 I TR
Packaging Option
Blank = Tube
TR = Tape and Reel
Temperature Range
Blank = Commercial (0 to 70°C)
I = Industrial (-40 to 85°C)
Access Time
25 = 25ns
35 = 35ns
45 = 45ns
Lead Finish
F = 100% Sn (Matte Tin)
Package
N = Plastic 32-pin 300 mil SOIC
C = Ceramic 32-pin 300 mil CDIP
L = Ceramic 32-pad LCC
Feb, 2008
13
STK14C88
Military Ordering Information
STK14C88 - 5 C 45 M
Temperature Range
M = Military (-55 to 125°C)
Access Time
35 = 35ns
45 = 45ns
Package
L=Ceramic 32-pad LCC
C=Ceramic 32-pin 300 mil CDIP
K=Ceramic 32-pin 300 mil CDIP
with solder dip finish
Retention / Endurance
5 = Military (10 years or 105cycles)
Feb, 2008
14
STK14C88
Part Number
STK14C88-NF25
5V 32Kx8 AutoStore nvSRAM SOP32-300
Description
Access Times
25 ns access time
Commercial
STK14C88-NF35
STK14C88-NF45
35 ns access time
45 ns access time
Commercial
Commercial
STK14C88-NF25TR
STK14C88-NF35TR
25 ns access time
35 ns access time
Commercial
Commercial
STK14C88-NF45TR
STK14C88-NF25I
STK14C88-NF35I
STK14C88-NF45I
STK14C88-NF25ITR
STK14C88-NF35ITR
STK14C88-NF45ITR
STK14C88-C45I
STK14C88-5L35M
STK14C88-5L45M
STK14C88-5C35M
STK14C88-5C45M
STK14C88-5K35M
STK14C88-5K45M
45 ns access time
25 ns access time
35 ns access time
45 ns access time
25 ns access time
35 ns access time
45 ns access time
45 ns access time
35 ns access time
45 ns access time
35 ns access time
45 ns access time
35 ns access time
45 ns access time
Commercial
Industrial
Industrial
Industrial
Industrial
Industrial
Industrial
Industrial
Military
Military
Military
Military
Military
Military
Feb, 2008
15
SOP32-300
SOP32-300
SOP32-300
SOP32-300
SOP32-300
SOP32-300
SOP32-300
CDIP32-300
LCC32-450
LCC32-450
CDIP32-300
CDIP32-300
CDIP32-300
CDIP32-300
Temperature
STK14C88
Package Diagrams
32 Lead 300 mil SOIC Gull Wing
0.292 7.42
0.300 7.60
0.405 10.29
0.419 10.64
Pin 1
Index
.050 (1.27)
0.810 20.57
0.822 20.88
0.026 0.66
0.032 0.81
BSC
0.090 2.29
0.100 2.54
0.086
0.090
0.12
0.22
0.004 0.10
0.010 0.25
0.014 0.36
0.020 0.51
0.006
0.013
( 0.32
8
0.021
0.041
DIM = INCHES
DIM = mm
Feb, 2008
16
MIN
MAX
MIN
( MAX
0.53
( 1.04
o
o
2.18
( 2.29
STK14C88
32 Lead 300 mil Side Braze DIL
1.585
1.615
(40.25
41.02)
.280
.310
( 7.36
7.87 )
Pin 1
Index
PIN
16
----.060 1.52
.124 3.15
.162 4.12
.125 (3.18)
MIN
.016
.020
.048
.052
0.41
0.51
.290
.310
( 7.37
7.87 )
.009
.012
.300
.320
( 7.62
8.13 )
DIM = INCHES
DIM = mm
Feb, 2008
.090
.110
1.22
1.32
MIN
MAX
MIN
( MAX
17
( 0.23
0.30 )
2.29
( 2.79
.040
.060
1.02
1.52
STK14C88
32 Lead 450 mil Ceramic LCC
.080±.008
.060±.006
.550±.005
.020±.002
.020±.002
(.040)
Pad 1
.310±.006
.450±.005
Pad 32
.360±.006
(.020X2)
C.040±.010
C.020±.010
.002
TYP
.050±.005
.450-.010 +.005
1
.0
(R.009)
5M
IN
.050
.300
[P=.050X6]
Pad 1 Index
Pad 32
.085±.008
.350-.010 +.005
(C.004)
.050
.400
[P=.050X8]
Feb, 2008
TYP
.050±.005
.025±.003
18
NOTES:
1. GOLD PLATE 85~220‚ INCHES OVER 50~350 INCHES NICKEL.
2. PADS "A" AND "B" ELECTRICALLY CONNECTED TO THE DIE ATTACH PAD.
3. SEAL RING TO BE ELECTRICALLY ISOLATED FROM ALL LEADS.
4. LEAD RESISTANCE : 800mƒ MAX.
5. LEAD TO LEAD CAPACITANCE NOT TO EXCEED 3pf (1MHz).
6. BLACK ALUMINA CERAMIC.
STK14C88
Document Revision History
Revision
Date
Summary
0.0
December 2002
Removed 20 nsec device; Combined commercial, industrial and military; current limit resistor
added for extreme power-off slew rate.
0.1
September 2003
Added lead-free lead finish
0.2
March 2003
Removed Commercial/Industrial Leaded Lead Finish, Removed “W” DIP package
0.3
February 2007
Add Tape Reel Ordering Options
Add Product Ordering Code Listing
Add Package Drawings
Reformat Entire Document
0.4
July 2007
extend definition of tHZ (#7)
update fig. SRAM READ CYCLE #2, SRAM WRITE CYCLE #1, Note r, Note u and Note v to
clarify product usage
2.0
February 2008
In the block diagramand elsewhere in the document, removed the “x” from Vccx.
Page 4: in Note g below the SRAM Read Cycles #1 and #2 table, revised note g by deleting
“and low during SRAM WRITE cycles; in SRAM Read Cycles #1 & #2 table, revised description for tELQX and changed Symbol #2 to tELEH for Read Cycle Time; updated SRAM Read
Cycle #2 timing diagram and changed title to add G controlled.
Page 6: in Hardware Store Cycle table, removed footnote i for notes 22 and 23.
Page 8: in Software Store/Recall Mode Selection table, added footnote n to both rows.
Page 11: added best practices section. Under HSB Operation, revised first paragraph to
read “The HSB pin has a very resistive pullup...”
Page 15: added access times column to the Ordering codes; removed STK14C88-L45I row
from the Ordering Information page.
SIMTEK STK14C88 Datasheet, February 2008
Copyright 2008, Simtek Corporation. All rights reserved.
This datasheet may only be printed for the expressed use of Simtek Customers. No part of the datasheet may be reproduced in any other
form or means without the express written permission from Simtek Corporation. The information contained in this publication is believed to be
accurate, but changes may be made without notice. Simtek does not assume responsibility for, or grant or imply any warranty, including
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE regarding this information, the product or its use. Nothing herein constitutes a license, grant or transfer of any rights to any Simtek patent, copyright, trademark, or other proprietary right.
Feb, 2008
19
