NJM8513BV-TE1
NJM8513BV-TE1
    JRC(⽇本无线)
    LSSOP14
    IC OPAMP JFET 4 CIRCUIT 14SSOP
NJM8513BV-TE1 数据手册
NJM8512/NJM8513 Precision, JFET Input Operational Amplifier ■ FEATURES ■GENERAL DESCRIPTION ●Low Input Offset Voltage VIO=400μV max. VIO=700μV max. (Ta= -40°C to +125°C) ●Low Input Offset Voltage Drift ΔVIO/ΔT=5μV/°C max. (Ta= -40°C to +125°C) ●Low Supply Current Icc=1.3mA /ch typ. ●High Slew Rate SR=20V/μs typ. ●Wide Bandwidth ft=7MHz typ. ●Low Noise en=10nV/Hz typ. (at f=1kHz ) ●Low Input Bias Current IB=80pA max. (at Ta=25°C) ●No Phase Reversal ●RF noise Immunity ●Guaranteed Temperature Topr= -40°C to +125°C ●Operating Voltage Vopr=±4.5V to ±16V ●Package NJM8512 MSOP8 (VSP8) The NJM8512/NJM8513 are Dual/Quad high precision JFET input operational amplifier featuring low offset, low offset drift,low bias current, high slew rate, low noise and wide operating temperature range. The precision performance, high speed and low noise make the NJM8512/NJM8513 especially suitable for filter and amplification of high speed and small signal in instruments, automated test equipment, sensors and other precision applications. ■APPLICATIONS ●Current Sensor ●Photodiode Amplification ●Reference Voltage Circuit ●Automatic Test Equipment meet JEDEC MO-187-DA SOP8 JEDEC 150 mil NJM8513 SSOP14 ■ ELECTRICAL CHARACTERISTICS Input Offset Voltage vs. Temperature Input Offset Voltage Drift Distribution V+/V-=±15V, VICM=0V, N=196 800 V+/V-=±15V, Ta=-40ºC to 125ºC 70 60 Number of Amplifiers Input Offset Voltage [μV] 600 400 200 0 -200 -400 N=196 50 40 30 20 10 -600 -800 0 -50 -25 0 25 50 75 100 125 150 Temperature [ºC] -5 -4 -3 -2 -1 0 1 2 3 4 Input Offset Voltage Drift [μV/ºC] 5 ■PIN CONFIGURATION Pin Function Package Outline PART NUMBER Ver.04 MSOP8 SOP8 SSOP14 NJM8512AR NJM8512BR NJM8512AE NJM8512BE NJM8513AV NJM8513BV -1- NJM8512/NJM8513 ■ ABSOLUTE MAXIMUM RATINGS (Ta=25ºC, unless otherwise noted.) PARAMETER SYMBOL + Supply Voltage - V /V Differential Input Voltage VID Input Voltage VIN Input Current IIN Power Dissipation MSOP8 (VSP8) SOP8 SSOP14 Output Short-Circuit Duration PD - RATING UNIT ±18 V ±36 (Note1) V + V - 0.3 to V + 0.3(Note2) V ±10(Note3) mA (2-layer / 4-layer ) 595(Note4) / 805 (Note4) 690 (Note4) / 1000 (Note4) 490 (Note4) / 630 (Note4) Infinete(Ta≦25℃) (Note4) mW Operating Temperature Range Topr -40 to +125 ºC Junction Temperature Tjmax +150 ºC Storage Temperature Range Tstg -65 to +150 ºC (Note1) (Note2) (Note3) (Note4) Differential Input Voltage is the voltage difference between +INPUT and -INPUT. The normal operation will establish when any input is within the Common Mode Input Voltage Range of electrical characteristics. If the input voltage exceeds the supply voltage,the input current must be limited 10 mA or less by using a restriction resistance. 2-layer : EIA/JEDEC STANDARD Test board (76.2 x 114.3 x 1.6mm, 2layers, FR-4) mounting. 4-layer : EIA/JEDEC STANDARD Test board (76.2 x 114.3 x 1.6mm, 4layers, FR-4) mounting. See Figure “Fig.1-1 : Power Dissipation Curve” when ambient temperature is over 25°C. Figure1-A: Power Dissipation Derating Curve Figure1-B: Power Dissipation Derating Curve ■RECOMMENDED OPERATING VOLTAGE (Ta=25ºC) PARAMETER Supply Voltage -2- SYMBOL + - V /V RATING MIN. TYP. MAX. UNIT ±4.5 - ±16 V Ver.04 NJM8512/NJM8513 + - ■ ELECTRICAL CHARACTERISTICS (V /V =±15V, Ta=25°C, VICM=0V, unless otherwise noted.) PARAMETER Input Characteristics Input Offset Voltage NJM8512Bx / NJM8513Bx NJM8512Ax / NJM8513Ax Input Offset Voltage Drift NJM8512Bx / NJM8513Bx NJM8512Ax / NJM8513Ax Input Bias Current Input Offset Current Common Mode Input Voltage Range SYMBOL VIO1 VIO2 VIO1 VIO2 ΔVio/ΔT ΔVio/ΔT IB1 IB2 IIO1 IIO2 VICM1 VICM2 Common Mode Rejection Ratio CMR1 CMR2 Voltage Gain CMR3 AV1 AV2 Input capacitance Channel Separation Output Characteristics Maximum Output Voltage Supply Characteristics Supply Current (ALL Amps) : NJM8512 Supply Current (ALL Amps) : NJM8513 Supply Voltage Rejection Ratio AV3 CIN CS Settling Time Phase Margin Total Harmonic Distortion Noise Performance Input Voltage Noise Density Ta = -40ºC to 125ºC Ta = -40ºC to 125ºC Ta = -40ºC to 125ºC Ta = -40ºC to 125ºC Ta = -40ºC to 125ºC Ta = -40ºC to 125ºC CMR ≧ 86dB CMR ≧ 80dB, Ta = -40ºC to 125ºC VCM=-12.5V to +12.5V VCM=-12.5V to +12.5V, Ta = -40ºC to 125ºC VCM=-10V to +10V RL=2kΩ, VO=-13.5V to +13.5V RL=2kΩ, VO=-13.5V to +13.5V, Ta = -40ºC to 125ºC RL=10kΩ, VO=-13.5V to +13.5V DC VOH1 VOL1 VOH2 VOL2 VOH31 VOH32 VOL41 VOL42 RL=10kΩ, Ta = -40ºC to 125ºC RL=10kΩ, Ta = -40ºC to 125ºC RL=2kΩ, Ta = -40ºC to 125ºC RL=2kΩ, Ta = -40ºC to 125ºC RL=600Ω RL=600Ω, Ta = -40ºC to 125ºC RL=600Ω RL=600Ω, Ta = -40ºC to 125ºC ICC1 ICC2 ICC1 ICC2 SVR1 GV=+1, RL=∞ GV=+1, RL=∞, Ta = -40ºC to 125ºC GV=+1, RL=∞ GV=+1, RL=∞, Ta = -40ºC to 125ºC + V / V = ±4.5V to ±16V + V / V = ±4.5V to ±16V, Ta = -40ºC to 125ºC SVR2 Dynamic Performance Unity Gain Frequency Slew Rate TEST CONDITION fT +SR -SR ts1 ts2 ΦM THD GV=+100, RL=2kΩ, CL=10pF RISE, GV=+1, VIN=2Vpp, RL=2kΩ FALL, GV=+1, VIN=2Vpp, RL=2kΩ To 0.1%, 0V to 10V step, Gv=+1 To 0.01%, 0V to 10V step, Gv=+1 fo=1kHz, GV=+1, RL=2kΩ VNI fo=0.1Hz to 10Hz en1 fo=10Hz en2 fo=100Hz en3 fo=1kHz en4 fo=10kHz (Note) Measurement is to be conducted in pulse testing. Ver.04 MIN. TYP. MAX. UNIT - 80 80 - 400 700 800 1400 µV µV µV µV -12.5 0.8 1 25 6 - 5 9 80 35 75 2 +12.5 µV/ºC µV/ºC pA nA pA nA V -12.5 - +12.5 V 86 108 - dB 80 - - dB 100 90 120 100 - dB dB 82 - - dB 98 - 106 10 125 - dB pF dB +14.0 +13.8 +13.5 +11.4 - +14.2 -14.9 +14.1 -14.8 +13.9 -14.3 - -14.6 -14.4 -13.8 -12.1 V V V V V V V V 86 2.6 5.2 110 3.0 3.3 6.0 6.6 - mA mA mA mA dB 80 - - dB - 7 20 20 0.7 1.0 70 0.0004 - MHz V/µs V/µs µs µs deg % - 0.9 20 11 10 9 - µVpp nV/√Hz nV/√Hz nV/√Hz nV/√Hz -3- NJM8512/NJM8513 + - ■ELECTRICAL CHARACTERISTICS (V /V =±5V, Ta=25°C, VICM=0V, unless otherwise noted.) PARAMETER Input Characteristics Input Offset Voltage NJM8512Bx / NJM8513Bx NJM8512Ax / NJM8513Ax Input Offset Voltage Drift NJM8512Bx / NJM8513Bx NJM8512Ax / NJM8513Ax Input Bias Current Input Offset Current Common Mode Input Voltage Range SYMBOL VIO1 VIO2 VIO1 VIO2 ΔVio/ΔT ΔVio/ΔT IB1 IB2 IIO1 IIO2 VICM1 VICM2 Common Mode Rejection Ratio CMR1 CMR2 Voltage Gain CMR3 AV1 AV2 Input capacitance Channel Separation Output Characteristics Maximum Output Voltage Supply Characteristics Supply Current (ALL Amps) : NJM8512 Supply Current (ALL Amps) : NJM8513 Dynamic Performance Unity Gain Frequency Slew Rate Settling Time Phase Margin Total Harmonic Distortion Noise Performance Input Voltage Noise Density AV3 CIN CS VOH1 VOL1 VOH2 VOL2 VOH31 VOH32 VOL41 VOL42 TEST CONDITION Ta = -40ºC to 125ºC Ta = -40ºC to 125ºC Ta = -40ºC to 125ºC Ta = -40ºC to 125ºC Ta = -40ºC to 125ºC Ta = -40ºC to 125ºC CMR ≧ 86dB CMR ≧ 80dB, Ta = -40ºC to 125ºC VCM=-2V to +2.5V VCM=-2V to +2.5V, Ta = -40ºC to 125ºC VCM=-1V to +2V RL=2kΩ, VO=-3V to +3V RL=2kΩ, VO=-3V to +3V, Ta = -40ºC to 125ºC RL=10kΩ, VO=-3V to +3V DC RL=10kΩ, Ta = -40ºC to 125ºC RL=10kΩ, Ta = -40ºC to 125ºC RL=2kΩ, Ta = -40ºC to 125ºC RL=2kΩ, Ta = -40ºC to 125ºC RL=600Ω RL=600Ω, Ta = -40ºC to 125ºC RL=600Ω RL=600Ω, Ta = -40ºC to 125ºC TYP. MAX. UNIT - 80 80 - 400 700 800 1400 µV µV µV µV -2 0.8 1 21 5 - 5 9 75 31 50 2 +2.5 µV/ºC µV/ºC pA nA pA nA V -2 - +2.5 V 86 108 - dB 80 - - dB 92 85 113 93 - dB dB 80 - - dB 90 - 100 10 125 - dB pF dB +4.1 +3.9 +3.7 +3.6 - +4.3 -4.9 +4.2 -4.9 +4.1 -4.8 - -4.7 -4.5 -4.3 -4.2 V V V V V V V V ICC1 ICC2 ICC1 ICC2 GV=+1, RL=∞ GV=+1, RL=∞, Ta = -40ºC to 125ºC GV=+1, RL=∞ GV=+1, RL=∞, Ta = -40ºC to 125ºC - 2.0 4.0 - 3.0 3.3 6.0 6.6 mA mA mA mA fT +SR -SR ts1 ΦM THD GV=+100, RL=2kΩ, CL=10pF RISE, GV=+1, VIN=2Vpp, RL=2kΩ FALL, GV=+1, VIN=2Vpp, RL=2kΩ To 0.1%, 0V to 4V step, Gv=+1 - 7 18 18 0.5 65 0.0005 - MHz V/µs V/µs µs deg % - 0.9 20 11 10 9 - µVpp nV/√Hz nV/√Hz nV/√Hz nV/√Hz fo=1kHz, GV=+1, RL=2kΩ VNI fo=0.1Hz to 10Hz en1 fo=10Hz en2 fo=100Hz en3 fo=1kHz en4 fo=10kHz (Note) Measurement is to be conducted in pulse testing. -4- MIN. Ver.04 NJM8512/NJM8513 ■ ELECTRICAL CHARACTERISTICS Input Offset Voltage vs. Temperature Input Offset Voltage vs. Temperature V+/V-=±15V, VICM=0V, N=196 800 600 Input Offset Voltage [μV] 600 Input Offset Voltage [μV] V+/V-=±5V, VICM=0V, N=196 800 400 200 0 -200 -400 -600 400 200 0 -200 -400 -600 -800 -800 -50 -25 0 25 50 75 100 125 150 Temperature [ºC] -50 -25 Input Offset Voltage Distribution N=196 50 Number of Amplifiers Number of Amplifiers V+/V-=±5V, VICM=0V 60 N=196 50 40 30 20 10 40 30 20 10 0 -400 -300 -200 -100 0 100 200 300 400 Input Offset Voltage [μV] 0 -400 -300 -200 -100 0 100 200 300 400 Input Offset Voltage [μV] Input Offset Voltage Drift Distribution Input Offset Voltage Drift Distribution V+/V-=±15V, Ta=-40ºC to 125ºC V+/V-=±5V, Ta=-40ºC to 125ºC 70 70 60 N=196 Number of Amplifiers Number of Amplifiers 60 50 40 30 20 10 N=196 50 40 30 20 10 0 0 -5 Ver.04 25 50 75 100 125 150 Temperature [ºC] Input Offset Voltage Distribution V+/V-=±15V, VICM=0V 60 0 -4 -3 -2 -1 0 1 2 3 4 Input Offset Voltage Drift [μV/ºC] 5 -5 -4 -3 -2 -1 0 1 2 3 4 Input Offset Voltage Drift [μV/ºC] 5 -5- NJM8512/NJM8513 Input Offset Voltage vs. Common-mode Voltage Input Offset Voltage vs. Common-mode Voltage V+/V-=±15V, VICM=-12.5V to +12.5V V+/V-=±5V, VICM=-2V to +2.5V 800 800 600 Ta=-40°C Ta=25°C Input Offset Voltage [μV] Input Offset Voltage [μV] 600 400 200 0 Ta=125°C -200 -400 -600 Ta=-40°C Ta=25°C 400 200 0 Ta=125°C -200 -400 -600 -800 -800 -15 -10 -5 0 5 10 Input Common-mode Voltage [V] 15 -5 -4 -3 -2 -1 0 1 2 3 4 Input Common-mode Voltage [V] Common-mode Rejection Ratio vs. Temperature 5 CMR vs. Frequency Common-mode Rejection Ratio [dB] V+/V-=±15V, VICM=-12.5V to +12.5V 120 100 V+/V-=±5V, VICM=-2V to +2.5V 80 60 40 20 Common Mode Rejection Ratio [dB] Gv=60dB, Ta=25°C 140 0 -50 -25 0 140 120 V+/V-=±15V 100 80 + 60 40 20 0 -20 100 25 50 75 100 125 150 Temperature [°C] Supply Voltage Rejection Ratio vs. Temperature 1k 100 80 60 40 20 0 -50 -6- -25 0 25 50 75 100 125 150 Temperature [°C] 1M 10M + - V /V =±15V, Gv=40dB, Ta=25ºC Supply Voltage Rejection Ratio [dB] Supply Voltage Rejection Ratio [dB] 120 10k 100k Frequency [Hz] Supply Voltage Rejection Ratio vs. Frequency V+/V-=±4.5V to ±16V, VICM=0V 140 - V /V =±5V 140 120 100 -SVR 80 60 40 +SVR 20 0 -20 100 1k 10k 100k Frequency [Hz] 1M 10M Ver.04 NJM8512/NJM8513 Gain/Phase vs. Frequency Gain/Phase vs. Frequency V+/V-=±15V, RF=100kΩ, RG=1kΩ, RL=2kΩ, Ta=25ºC V+/V-=±5V, RF=100kΩ, RG=1kΩ, RL=2kΩ, Ta=25ºC 60 180 60 120 40 180 Gain Phase CL=10pF 0 0 CL=100pF -20 -60 CL=10pF CL=100pF -40 120 20 60 CL=1000pF Phase CL=10pF 0 10k 0 CL=100pF -20 -120 -40 -180 100M -60 -60 CL=10pF CL=100pF CL=1000pF -120 CL=1000pF -60 1k Phase [deg] 60 CL=1000pF Phase [deg] Voltage Gain [dB] 20 Voltage Gain [dB] Gain 40 100k 1M Frequency [Hz] 10M 1k 10k 100k 1M Frequency [Hz] 10M -180 100M Input Bias Current vs. Temperature Open-loop Gain vs. Temperature VICM=0V VICM=0V, RL=2kΩ 100n 120 V+/V-=±15V, VO=-13.5V to +13.5V 80 + Input Bias Current [A] Open-loop Gain [dB] 100 - V /V =±5V, VO=-3V to +3V 60 40 10n V+/V-=±15V 1n 100p V+/V-=±5V 10p 20 1p 0 -50 -25 0 -50 25 50 75 100 125 150 Temperature [°C] Quiescent Current vs. Supply Voltage -25 0 25 50 75 100 125 150 Temperature [°C] Quiescent Current vs. Temperature Gv=0dB, VICM=0V GV=0dB, VICM=0V 3.5 3.5 Quiescent Current [mA] Quiescent Current [mA] 3.0 Ta=25°C 2.5 2.0 Ta=125°C Ta=-40°C 1.5 1.0 3.0 V+/V-=±16V V+/V-=±15V 2.5 2.0 V+/V-=±5V + - V /V =±4.5V 1.5 0.5 0.0 1.0 0 Ver.04 2 4 6 8 10 12 + Supply Voltage V /V [V] 14 16 -50 -25 0 25 50 75 100 125 150 Temperature [°C] -7- NJM8512/NJM8513 Maximum Output Voltage vs. Load Resistance Maximum Output Voltage vs. Load Resistance V+/V-=±15V, VIN+=1V/-1V, VIN-=0V V+/V-=±5V, VIN+=1V/-1V, VIN-=0V 15 5 4 Ta=-40°C Maximum Output Voltage [V] Maximum Output Voltage [V] 12.5 10 7.5 Ta=25°C 5 Ta=125°C 2.5 0 -2.5 Ta=125°C -5 Ta=25°C -7.5 -10 Ta=-40°C Ta=25°C 3 2 1 0 -1 Ta=125°C -2 Ta=25°C -3 Ta=-40°C -4 -12.5 -15 100 1k 10k Load Resistance [Ω] -5 100 100k Maximum Output Voltage vs. Temperature 1k 10k Load Resistance [Ω] 100k Maximum Output Voltage vs. Temperature V+/V-=±15V, VIN+=1V/-1V, VIN-=0V V+/V-=±5V, VIN+=1V/-1V, VIN-=0V 15 5 12.5 4 RL=10kΩ 10 Maximum Output Voltage [V] Maximum Output Voltage [V] Ta=-40°C Ta=125°C RL=2kΩ RL=600Ω 7.5 5 2.5 0 -2.5 -5 -7.5 RL=2kΩ -10 RL=600Ω RL=10kΩ RL=10kΩ 3 RL=600Ω 2 1 0 -1 -2 -3 RL=2kΩ -15 RL=600Ω RL=10kΩ -4 -12.5 RL=2kΩ -5 -50 -25 0 25 50 75 100 125 150 Temperature [ºC] -50 0 25 50 75 100 125 150 Temperature [ºC] Maximum Output Voltage vs. Output Current Maximum Output Voltage vs. Output Current V+/V-=±15V, VIN+=1V/-1V, VIN-=0V 15 -25 V+/V-=±5V, VIN+=1V/-1V, VIN-=0V 5 Maximum Output Voltage [V] Maximum Output Voltage [V] 4 10 Ta=125ºC 5 Ta=25ºC 0 Ta=-40ºC Ta=-40ºC Ta=25ºC -5 Ta=125ºC -10 3 Ta=125ºC 2 Ta=25ºC 1 Ta=-40ºC 0 Ta=-40ºC -1 Ta=25ºC -2 Ta=125ºC -3 -4 -5 -15 0 -8- 10 20 30 40 50 60 Output Current [mA] 70 80 0 10 20 30 40 50 60 Output Current [mA] 70 80 Ver.04 NJM8512/NJM8513 Small-Signal Step Response (Road Capacitance) Small-Signal Step Response (Temperature) V+/V-=±15V, Gv=0dB, VIN=1VPP, RL=2kΩ, Ta=25ºC V+/V-=±15V, Gv=0dB, VIN=1VPP, RL=2kΩ, CL=10pF INPUT 0.2V/div 0.2V/div INPUT 1000pF -40ºC 125ºC 10pF 25ºC OUTPUT OUTPUT 300pF 100pF 0.1μsec/div 0.1μsec/div Large Signal Step Response V+/V-=±15V, Gv=0dB, VIN=10Vpp, RL=2kΩ 2V/div INPUT OUTPUT 1μsec/div Ver.04 -9- NJM8512/NJM8513 1Hz to 100Hz Input Voltage Noise Input Voltage Noise Density vs. Frequency V+/V-=±15V, 1 to 100Hz BPF Gv=40dB, RG=100Ω, RL=10kΩ, Ta=25°C 100 Input Voltage Noise Density [nV/Hz] 2.0 1.5 Voltage [μV] 1.0 0.5 0.0 -0.5 -1.0 -1.5 -2.0 90 80 70 60 50 V+/V-=±5V 40 30 20 10 V+/V-=±15V 0 0 1 2 3 4 5 6 time [sec] 7 8 9 10 1 THD + Noise vs. Output Voltage Total Harmonic Distortion +Noise [%] 1 0.1 0.01 0.001 f=1kHz 10k 10 1 0.1 0.01 0.001 f = 1kHz 20Hz 20Hz - 10 - 1k V+/V-=±5V, AV=+1, RL=2kΩ, Ta=25ºC 10 0.1 1 10 Output Voltage [Vrms] 100 Frequency [Hz] THD + Noise vs. Output Voltage V+/V-=±15V, AV=+1, RL=2kΩ, Ta=25ºC 0.0001 0.01 10 100 0.0001 0.01 0.1 1 Output Voltage [Vrms] 10 Ver.04 NJM8512/NJM8513 Input Voltage vs. Output Voltage Short Circuit Output Current V+/V-=±15V, VIN+=0V, VO=0V, Ta=25ºC 8 60 V+/V-=±5V, AV=0dB, RL=10kΩ 6 VIN-=‐100mV 40 4 20 2 Voltage [V] Short Circuit Output Current [mA] 80 0 -20 -40 0 -2 -4 -60 VIN-=+100mV VIN VOUT -6 -80 0 20 40 Time [sec] Ver.04 60 -8 Time [200μs/div] - 11 - NJM8512/NJM8513 ■PACKAGE DIMENSIONS MSOP8(VSP8) +0.3 2.9 -0.1 1 0.55 ±0.2 4.0±0.3 5 2.8±0.2 8 0 ∼10 ゚ 4 +0.1 0.127 -0.05 0.65 +0.1 0.1 - 0.05 1.1±0.1 0.6MAX 0.1 0.2±0.1 - 12 - 0.1 UNIT: mm M Ver.04 NJM8512/NJM8513 ■PACKAGE DIMENSIONS SOP8 JEDEC 150 mil 0 ∼10 ゜ 5.0±0.3 0.8±0.2 3.9±0.2 6.0±0.4 5 8 4 1 1.27 +0.1 0.20 -0.05 0.15±0.1 1.5±0.15 0.74MAX 0.1 0.4±0.1 Ver.04 0.12 UNIT:mm M - 13 - NJM8512/NJM8513 ■PACKAGE DIMENSIONS SSOP14 +0.3 5.0 -0.1 0 ~ 10º 0.5±0.2 4.4±0.2 6.4±0.3 8 14 7 1 0.65 +0.1 0.67MAX 0.1±0.1 1.15±0.1 0.15-0.05 0.1 0.22±0.1 0.1 UNIT:mm M [CAUTION] The specifications on this data book are only given for information, without any guarantee as regards either mistakes or omissions. The application circuits in this data book are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. - 14 - Ver.04
NJM8513BV-TE1 价格&库存
很抱歉,暂时无法提供与“NJM8513BV-TE1”相匹配的价格&库存,您可以联系我们找货
