SX008L
SX008L
    SMCDIODESOLUTIONS(桑德斯)
    SOT-23
    SCR 600V 800MA SOT23-3
SX008L 数据手册
SX008L SX008N2 SX008U Technical Data Data Sheet N2027, Rev.- SX008 Series 0.8A Sensitive SCRs Description The SX008 SCR series provide high dv/dt rate with strong resistance to electromagnetic interface. They are especially recommended for use on residual current circuit breaker, straight hair, igniter etc. SX008L SX008N2 SX008U SOT-23-3L SOT-89-2L TO-92 Maximum Ratings: Characteristics Symbol Condition Max. Units Storage junction temperature range TJ - -40 to +110 C Operating junction temperature range Repetitive peak off-state voltage Tstg - -40 to +150 C VDRM - 600 V Repetitive peak reverse voltage VRRM - 600 V 0.8 A 8 A 0.32 A2S RMS on-state current Non repetitive surge peak on-state current(tp=10ms) I2t value for fusing (tp=10ms) Critical rate of rise of on-state current Peak gate current (tp=20μs, Tj=110℃) Peak gate power (tp=20μs, Tj=110℃) Average gate power dissipation(Tj=110℃) I(TRMS) ITSM TO-92/ SOT-23-3L(TC=65℃) SOT-89-2L(TC=70℃) - I2t - dI/dt - 50 A/us IGM 0.2 A PGM - 0.5 W PG(AV) - 0.1 W  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SX008L SX008N2 SX008U Technical Data Data Sheet N2027, Rev.- Electrical Characteristics(Tj=25℃ unless otherwise specified) Symbol IGT VGT VGD IL IH dv/dt Condition Min. Typ. Max. 20 50 200 A - 0.6 0.8 V 0.2 100 - 6 5 - V mA mA VD=12V RL=33Ω VD=VDRM Tj=110℃ IG=1.2 IGT IT=0.05A VD=2/3VDRM Tj=110℃ RGK=1KΩ * Pulse width < 300 µs, duty cycle < 2% Units V/s Static Characteristics Symbol VTM IDRM IRRM Condition Max. IT=1.1A tp=380μs,Tj=25℃ VD=VDRM VR=VRRM, Tj=25℃ VD=VDRM VR=VRRM, Tj=110℃ Units 1.5 5 100 V uA uA Value Units Thermal Resistances Symbol Rth(j-c) Condition Junction to case TO-92/ SOT-23-3L 75 SOT-89-2L 38 ℃/W Ordering Information S X 008 U SMC Diode Solutions N2:SOT-89-2L U:TO-92 L:SOT-23-3L Sensitive gate SCRs IT(RMS):0.8A Device Package Shipping SX008L SOT-23-3L 30000pcs/ reel SX008LTR SOT-23-3L 30000pcs/ reel SX008N2 SOT-89-2L 8000pcs/ reel SX008N2TR SOT-89-2L 8000pcs/ reel SX008U TO-92 2000pcs/ reel SX008UTR TO-92 2000pcs/ reel  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SX008L SX008N2 SX008U Technical Data Data Sheet N2027, Rev.- Ratings and Characteristics Curves FIG.1 Maximum power dissipation versus RMS on-state current IT(RMS) (A) 1.2 P(w) α=180° 1.0 1.0 0.8 0.8 0.6 0.6 0.4 0.4 0.2 0.2 ↓ 1.2 FIG.2: RMS on-state current versus case temperature SOT-89-2L TO-92/ SOT-23-3L ↓ 0 0 IT(RMS) (A) 0.4 0.6 0.2 0.8 1.0 FIG.3: Surge peak on-state current versus number of cycles 0 Tc (℃) 0 25 50 75 100 125 FIG.4: On-state characteristics (maximum values) ITSM (A) 8 ITM (A) tp=10ms One cycle 8 Tj=Tjmax 6 1 4 2 Tj=25℃ 0 1 10 Number of cycles 100 1000 FIG.5: Non-repetitive surge peak on-state current for a sinusoidal pulse with width tp
SX008L
物料型号: - SX008L - SX008N2 - SX008U
器件简介: SX008系列敏感型SCR提供高dv/dt率和强大的电磁干扰抵抗能力,特别推荐用于剩余电流断路器、直发器、点火器等。
引脚分配: - SX008L和SX008U:A(2)为阴极,K(1)为门极,G(3)为阳极 - SX008N2:SOT-89-2L封装,引脚未明确标注
参数特性: - 存储结温范围:-40至+110摄氏度 - 工作结温范围:-40至+150摄氏度 - 重复峰值关断电压:600V - 重复峰值反向电压:600V - RMS通态电流:0.8A(TO-92/SOT-23-3L, TC=65°C)和SOT-89-2L(TC=70°C) - 非重复浪涌峰值通态电流(tp=10ms):8A - 12t值(tp=10ms):0.32A²s - 关断电流上升率临界值:50A/us - 峰值门极电流(tp=20s, Tj=110°C):0.2A - 峰值门极功率(tp=20s, Tj=110°C):0.5W - 平均门极功率耗散(Tj=110°C):0.1W
功能详解: 文档提供了电气特性和静态特性的详细表格,包括门极触发电流、门极电压、阳极电流、阴极电流、电压变化率等参数。
应用信息: 适用于高dv/dt应用,如剩余电流断路器、直发器、点火器等。
封装信息: - SX008L和SX008U:SOT-23-3L和TO-92封装 - SX008N2:SOT-89-2L封装 - 提供了详细的机械尺寸数据
SX008L 价格&库存
很抱歉,暂时无法提供与“SX008L”相匹配的价格&库存,您可以联系我们找货
SX008L
  • 3000+1.661323000+0.20780
  • 6000+1.524066000+0.19063
  • 9000+1.454139000+0.18188
  • 15000+1.3755415000+0.17205
  • 21000+1.3290121000+0.16623
  • 30000+1.2865730000+0.16092
库存:27899
SX008L
  • 1+7.030301+0.87933
  • 10+4.3562410+0.54487
  • 100+2.81287100+0.35183
  • 500+2.14807500+0.26868
  • 1000+1.933791000+0.24188
库存:27899
