CD4049UBM96
CD4049UBM96
    L3HARRIS
    SOIC-16
    IC BUFFER INVERT 18V 16SOIC
CD4049UBM96 数据手册
Dat asheet Rochest erEl ect r oni cs Manuf act ur edComponent s Rochest er br anded component s ar e manuf act ur ed usi ng ei t herdi e/ waf er s pur chased f r om t he or i gi nalsuppl i er s or Rochest er waf er sr ecr eat ed f r om t he or i gi nal I P. Al lr ecr eat i ons ar e donewi t ht heappr ovaloft heOCM. Par t sar et est ed usi ngor i gi nalf act or y t estpr ogr amsorRochest erdevel oped t est sol ut i ons t o guar ant ee pr oduct meet sorexceedt heOCM dat asheet . Qual i t yOver vi ew •I SO9001 • AS9120cer t icat i on • Qual iedManuf act ur er sLi st( QML)MI LPRF35835 •Cl assQ Mi l i t ar y •Cl assVSpaceLevel • Qual iedSuppl i er sLi stofDi st r i but or s( QSLD) •Rochest eri sacr i t i calsuppl i ert oDLA and meet sal li ndust r yandDLA st andar ds. Rochest erEl ect r oni cs,LLC i scommi t t edt o suppl yi ngpr oduct st hatsat i sf ycust omerexpect at i onsf orqual i t yandar eequalt ot hoseor i gi nal l y suppl i edbyi ndust r ymanuf act ur er s. Theor i gi nalmanuf act ur er ’ sdat asheetaccompanyi ngt hi sdocumentr e ect st heper f or mance andspecicat i onsoft heRochest ermanuf act ur edver si onoft hi sdevi ce.Rochest erEl ect r oni csguar ant eest heper f or manceofi t ssemi conduct orpr oduct st ot heor i gi nalOEM specicat i ons.‘ Typi cal ’val uesar ef orr ef er encepur posesonl y.Cer t ai nmi ni mum ormaxi mum r at i ngs maybebasedonpr oductchar act er i zat i on,desi gn,si mul at i on,orsampl et est i ng. © 2013Roc hes t erEl ec t r oni c s ,LLC.Al lRi ght sRes er v ed07112013 Tol ear nmor e,pl eas ev i s i twww. r oc el ec . c om CD4049UB, CD4050B August 1998 - Revised May 2004 Data sheet acquired from Harris Semiconductor SCHS046I CMOS Hex Buffer/Converters Applications The CD4049UB and CD4050B devices are inverting and non-inverting hex buffers, respectively, and feature logiclevel conversion using only one supply voltage (VCC). The input-signal high level (VIH) can exceed the VCC supply voltage when these devices are used for logic-level conversions. These devices are intended for use as CMOS to DTL/TTL converters and can drive directly two DTL/TTL loads. (VCC = 5V, VOL ≤ 0.4V, and IOL ≥ 3.3mA.) • CMOS to DTL/TTL Hex Converter • CMOS Current “Sink” or “Source” Driver • CMOS High-To-Low Logic Level Converter [ /Title (CD40 49UB, CD405 The CD4049UB and CD4050B are designated as 0B) replacements for CD4009UB and CD4010B, respectively. Because the CD4049UB and CD4050B require only one /Subpower supply, they are preferred over the CD4009UB and ject CD4010B and should be used in place of the CD4009UB (CMO and CD4010B in all inverter, current driver, or logic-level S Hex conversion applications. In these applications the Buffer/ CD4049UB and CD4050B are pin compatible with the CD4009UB and CD4010B respectively, and can be Consubstituted for these devices in existing as well as in new verters) designs. Terminal No. 16 is not connected internally on the /Autho CD4049UB or CD4050B, therefore, connection to this terminal is of no consequence to circuit operation. For r () applications not requiring high sink-current or voltage /Keyconversion, the CD4069UB Hex Inverter is recommended. words (Harris Features Semi- • CD4049UB Inverting con• CD4050B Non-Inverting ductor, • High Sink Current for Driving 2 TTL Loads CD400 • High-To-Low Level Logic Conversion • 100% Tested for Quiescent Current at 20V 0, • Maximum Input Current of 1µA at 18V Over Full Package metal Temperature Range; 100nA at 18V and 25oC gate, • 5V, 10V and 15V Parametric Ratings CMOS Ordering Information PART NUMBER TEMP. RANGE (oC) PACKAGE CD4049UBF3A -55 to 125 16 Ld CERDIP CD4050BF3A -55 to 125 16 Ld CERDIP CD4049UBD -55 to 125 16 Ld SOIC CD4049UBDR -55 to 125 16 Ld SOIC CD4049UBDT -55 to 125 16 Ld SOIC CD4049UBDW -55 to 125 16 Ld SOIC CD4049UBDWR -55 to 125 16 Ld SOIC CD4049UBE -55 to 125 16 Ld PDIP CD4049UBNSR -55 to 125 16 Ld SOP CD4049UBPW -55 to 125 16 Ld TSSOP CD4049UBPWR -55 to 125 16 Ld TSSOP CD4050BD -55 to 125 16 Ld SOIC CD4050BDR -55 to 125 16 Ld SOIC CD4050UBDT -55 to 125 16 Ld SOIC CD4050BDW -55 to 125 16 Ld SOIC CD4050BDWR -55 to 125 16 Ld SOIC CD4050BE -55 to 125 16 Ld PDIP CD4050NSR -55 to 125 16 Ld SOP CD4050BPW -55 to 125 16 Ld TSSOP CD4050BPWR -55 to 125 16 Ld TSSOP NOTE: When ordering, use the entire part number. The suffix R denotes tape and reel. The suffix T denotes a small-quantity reel of 250. Pinouts CD4049UB (PDIP, CERDIP, SOIC, SOP, TSSOP) TOP VIEW 16 NC VCC 1 15 L = F G=A 2 14 F A 3 13 NC H=B 4 B 5 12 K = E 11 E I=C 6 10 J = D C 7 9 D VSS 8 1 CD4050B (PDIP, CERDIP, SOIC, SOP) TOP VIEW VCC 1 G=A 2 A 3 H=B 4 B 5 I=C 6 C 7 VSS 8 16 NC 15 L = F 14 F 13 NC 12 K = E 11 E 10 J = D 9 D CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Copyright © 2004, Texas Instruments Incorporated CD4049UB, CD4050B Functional Block Diagrams CD4049UB A B C D E F 3 2 5 4 7 6 9 10 11 12 14 15 VCC VSS CD4050B G=A A H=B B I=C C J=D D K=E E L=F F 1 3 2 5 4 7 6 9 10 11 12 14 15 VCC 8 VSS NC = 13 NC = 16 G=A H=B I=C J=D K=E L=F 1 8 NC = 13 NC = 16 Schematic Diagrams VCC VCC P OUT R IN P P N N R IN N VSS FIGURE 1A. SCHEMATIC DIAGRAM OF CD4049UB, 1 OF 6 IDENTICAL UNITS 2 OUT VSS FIGURE 1B. SCHEMATIC DIAGRAM OF CD4050B, 1 OF 6 IDENTICAL UNITS CD4049UB, CD4050B Absolute Maximum Ratings Thermal Information Supply Voltage (V+ to V-). . . . . . . . . . . . . . . . . . . . . . . -0.5V to 20V DC Input Current, Any One Input. . . . . . . . . . . . . . . . . . . . . . ±10mA Package Thermal Impedance, θJA (see Note1): E (PDIP) Package . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 67oC/W D (SOIC) Package . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 73oC/W DW (SOIC) Package . . . . . . . . . . . . . . . . . . . . . . . . . . . . 57oC/W NS (SOP) Package . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 64oC/W PW (TSSOP) Package . . . . . . . . . . . . . . . . . . . . . . . . . . 108oC/W Maximum Junction Temperature (Plastic Package) . . . . . . . . .150oC Maximum Storage Temperature Range . . . . . . . . . . . 65oC to 150oC Maximum Lead Temperature (Soldering 10s) . . . . . . . . . . . . .265oC SOIC - Lead Tips Only Operating Conditions Temperature Range . . . . . . . . . . . . . . . . . . . . . . . . . -55oC to 125oC CAUTION: Stresses above those listed in “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress only rating and operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. NOTE: 1. The package thermal impedance is calculated in accordance with JESD 51-7. DC Electrical Specifications LIMITS AT INDICATED TEMPERATURE (oC) TEST CONDITIONS PARAMETER Quiescent Device Current IDD (Max) Output Low (Sink) Current IOL (Min) Output High (Source) Current IOH (Min) Out Voltage Low Level VOL (Max) Output Voltage High Level VOH (Min) Input Low Voltage, VIL (Max) CD4049UB Input Low Voltage, VIL (Max) CD4050B 3 25 VO (V) VIN (V) VCC (V) -55 -40 85 125 MIN TYP MAX UNITS - 0,5 5 1 1 30 30 - 0.02 1 µA - 0,10 10 2 2 60 60 - 0.02 2 µA - 0,15 15 4 4 120 120 - 0.02 4 µA - 0,20 20 20 20 600 600 - 0.04 20 µA 0.4 0,5 4.5 3.3 3.1 2.1 1.8 2.6 5.2 - mA 0.4 0,5 5 4 3.8 2.9 2.4 3.2 6.4 - mA 0.5 0,10 10 10 9.6 6.6 5.6 8 16 - mA 1.5 0,15 15 26 25 20 18 24 48 - mA 4.6 0,5 5 -0.81 -0.73 -0.58 -0.48 -0.65 -1.2 - mA 2.5 0,5 5 -2.6 -2.4 -1.9 -1.55 -2.1 -3.9 - mA 9.5 0,10 10 -2.0 -1.8 -1.35 -1.18 -1.65 -3.0 - mA 13.5 0,15 15 -5.2 -4.8 -3.5 -3.1 -4.3 -8.0 - mA - 0,5 5 0.05 0.05 0.05 0.05 - 0 0.05 V - 0,10 10 0.05 0.05 0.05 0.05 - 0 0.05 V - 0,15 15 0.05 0.05 0.05 0.05 - 0 0.05 V - 0,5 5 4.95 4.95 4.95 4.95 4.95 5 - V - 0,10 10 9.95 9.95 9.95 9.95 9.95 10 - V - 0,15 15 14.95 14.95 14.95 14.95 14.95 15 - V 4.5 - 5 1 1 1 1 - - 1 V 9 - 10 2 2 2 2 - - 2 V 13.5 - 15 2.5 2.5 2.5 2.5 - - 2.5 V 0.5 - 5 1.5 1.5 1.5 1.5 - - 1.5 V 1 - 10 3 3 3 3 - - 3 V 1.5 - 15 4 4 4 4 - - 4 V CD4049UB, CD4050B DC Electrical Specifications (Continued) LIMITS AT INDICATED TEMPERATURE (oC) 25 TEST CONDITIONS PARAMETER Input High Voltage, VIH Min CD4049UB Input High Voltage, VIH Min CD4050B Input Current, IIN Max VO (V) VIN (V) VCC (V) -55 -40 85 125 MIN TYP MAX UNITS 0.5 - 5 4 4 4 4 4 - - V 1 - 10 8 8 8 8 8 - - V 1.5 - 15 12.5 12.5 12.5 12.5 12.5 - - V 4.5 - 5 3.5 3.5 3.5 3.5 3.5 - - V 9 - 10 7 7 7 7 7 - - V 13.5 - 15 11 11 11 11 11 - - V - ±10-5 ±0.1 µA - AC Electrical Specifications 0,18 18 ±0.1 Propagation Delay Time Low to High, tPLH CD4049UB Propagation Delay Time Low to High, tPLH CD4050B Propagation Delay Time High to Low, tPHL CD4049UB Propagation Delay Time High to Low, tPHL CD4050B Transition Time, Low to High, tTLH Transition Time, High to Low, tTHL 4 ±1 ±1 TA = 25oC, Input tr , tf = 20ns, CL = 50pF, RL = 200kΩ TEST CONDITIONS PARAMETER ±0.1 LIMITS (ALL PACKAGES) VIN VCC TYP MAX UNITS 5 5 60 120 ns 10 10 32 65 ns 10 5 45 90 ns 15 15 25 50 ns 15 5 45 90 ns 5 5 70 140 ns 10 10 40 80 ns 10 5 45 90 ns 15 15 30 60 ns 15 5 40 80 ns 5 5 32 65 ns 10 10 20 40 ns 10 5 15 30 ns 15 15 15 30 ns 15 5 10 20 ns 5 5 55 110 ns 10 10 22 55 ns 10 5 50 100 ns 15 15 15 30 ns 15 5 50 100 ns 5 5 80 160 ns 10 10 40 80 ns 15 15 30 60 ns 5 5 30 60 ns 10 10 20 40 ns 15 15 15 30 ns CD4049UB, CD4050B AC Electrical Specifications TA = 25oC, Input tr , tf = 20ns, CL = 50pF, RL = 200kΩ (Continued) TEST CONDITIONS LIMITS (ALL PACKAGES) VIN VCC TYP MAX UNITS Input Capacitance, CIN CD4049UB - - 15 22.5 pF Input Capacitance, CIN CD4050B - - 5 7.5 pF PARAMETER TA = 25oC TA = 25oC SUPPLY VOLTAGE (VCC) = 5V SUPPLY VOLTAGE (VCC) = 5V VO , OUTPUT VOLTAGE (V) VO , OUTPUT VOLTAGE (V) Typical Performance Curves 5 4 MINIMUM MAXIMUM 3 2 5 MINIMUM 4 MAXIMUM 3 2 1 1 0 1 2 3 0 4 1 2 VI , INPUT VOLTAGE (V) 3 4 FIGURE 2. MINIMUM AND MAXIMUM VOLTAGE TRANSFER CHARACTERISTICS FOR CD4049UB FIGURE 3. MINIMUM AND MAXIMUM VOLTAGE TRANSFER CHARACTERISTICS FOR CD4050B IOL, OUTPUT LOW (SINK) CURRENT (mA) IOL, OUTPUT LOW (SINK) CURRENT (mA) VI , INPUT VOLTAGE (V) TA = 25oC 70 15V 60 10V 50 40 30 GATE TO SOURCE VOLTAGE (VGS) = 5V 20 10 0 1 2 3 4 5 6 7 8 VDS , DRAIN TO SOURCE VOLTAGE (V) FIGURE 4. TYPICAL OUTPUT LOW (SINK) CURRENT CHARACTERISTICS 5 TA = 25oC 70 15V 10V 60 50 40 30 20 GATE TO SOURCE VOLTAGE (VGS) = 5V 10 0 1 2 3 4 5 6 7 8 VDS , DRAIN TO SOURCE VOLTAGE (V) FIGURE 5. MINIMUM OUTPUT LOW (SINK) CURRENT DRAIN CHARACTERISTICS CD4049UB, CD4050B Typical Performance Curves (Continued) VDS, DRAIN TO SOURCE VOLTAGE (V) -8 -7 -6 -5 -4 -3 -2 -1 VDS, DRAIN TO SOURCE VOLTAGE (V) -8 -7 -6 -5 -4 -3 -2 0 -20 -25 -10V -30 -15V -10 VGS = -5V -15 -10V -20 -15V -25 -30 -35 OUTPUT HIGH (SOURCE) -15 GATE TO SOURCE VOLTAGE CURRENT CHARACTERISTICS -10 GATE TO SOURCE VOLTAGE VGS = -5V -35 FIGURE 6. TYPICAL OUTPUT HIGH (SOURCE) CURRENT CHARACTERISTICS FIGURE 7. MINIMUM OUTPUT HIGH (SOURCE) CURRENT CHARACTERISTICS 10 9 VO, OUTPUT VOLTAGE (V) 10 VO, OUTPUT VOLTAGE (V) 0 -5 OUTPUT HIGH (SOURCE) CURRENT CHARACTERISTICS -5 SUPPLY VOLTAGE 8 VCC = 10V 125oC 7 6 TA = -55oC VCC = 5V 5 4 -55oC 3 125oC 2 9 SUPPLY VOLTAGE 125oC 8 VCC = 10V 7 6 VCC = 5V 5 TA = -55oC 4 3 125oC 2 -55oC 1 1 0 0 0 1 2 3 4 0 5 6 7 8 9 10 VI , INPUT VOLTAGE (V) 105 TA = 25oC V C 104 Y PL GE TA L VO 5 =1 VC V 10 V 10 5V P SU 103 LOAD CAPACITANCE CL = 50pF (11pF FIXTURE + 39pF EXT) CL = 15pF (11pF FIXTURE + 4pF EXT) 102 10 10 102 103 104 f, INPUT FREQUENCY (kHz) 105 FIGURE 10. TYPICAL POWER DISSIPATION vs FREQUENCY CHARACTERISTICS 6 1 2 3 4 5 6 7 8 9 10 VI , INPUT VOLTAGE (V) FIGURE 9. TYPICAL VOLTAGE TRANSFER CHARACTERISTICS AS A FUNCTION OF TEMPERATURE FOR CD4050B POWER DISSIPATION PER INVERTER (µW) FIGURE 8. TYPICAL VOLTAGE TRANSFER CHARACTERISTICS AS A FUNCTION OF TEMPERATURE FOR CD4049UB POWER DISSIPATION PER INVERTER (µW) -1 TA = 25oC TA = 25oC TA = 25oC 105 15V; 1MHz 15V; 100kHz 10V; 100kHz 15V; 10kHz 10V; 10kHz 15V; 1kHz 104 103 102 10 SUPPLY VOLTAGE VCC = 5V FREQUENCY (f) = 10kHz 10 102 103 104 105 106 107 tr, tf , INPUT RISE AND FALL TIME (ns) 108 FIGURE 11. TYPICAL POWER DISSIPATION vs INPUT RISE AND FALL TIMES PER INVERTER FOR CD4049UB CD4049UB, CD4050B POWER DISSIPATION PER INVERTER (µW) Typical Performance Curves (Continued) 106 TA = 25oC 105 15V; 1MHz 15V; 100kHz 10V; 100kHz 15V; 10kHz 10V; 10kHz 15V; 1kHz 104 103 102 10 SUPPLY VOLTAGE VCC = 5V FREQUENCY (f) = 10kHz 1 10 102 103 104 105 106 107 tr, tf , INPUT RISE AND FALL TIME (ns) 108 FIGURE 12. TYPICAL POWER DISSIPATION vs INPUT RISE AND FALL TIMES PER INVERTER FOR CD4050B Test Circuits VCC VCC VCC INPUTS INPUTS OUTPUTS VIH VSS + DVM VIL IDD VSS VSS NOTE: Test any one input with other inputs at VCC or VSS. FIGURE 13. QUIESCENT DEVICE CURRENT TEST CIRCUIT FIGURE 14. INPUT VOLTAGE TEST CIRCUIT CMOS 10V LEVEL TO DTL/TTL 5V LEVEL VCC = 5V VCC INPUTS COS/MOS IN OUTPUTS VCC OUTPUT TO DTL/TTL CD4049 INPUTS I 5V = VOH 10V = VIH 0 = VIL VSS VSS NOTE: Measure inputs sequentially, to both VCC and VSS connect all unused inputs to either VCC or VSS. FIGURE 15. INPUT CURRENT TEST CIRCUIT 7 VSS 0 = VOL In Terminal - 3, 5, 7, 9, 11, or 14 Out Terminal - 2, 4, 6, 10, 12 or 15 VCC Terminal - 1 VSS Terminal - 8 FIGURE 16. LOGIC LEVEL CONVERSION APPLICATION CD4049UB, CD4050B (Continued) VDD 0.1µF 500µF CL 10kHz, 100kHz, 1MHz I 1 2 3 4 5 6 7 8 CD4049UB Test Circuits 16 15 14 13 12 11 10 9 CL INCLUDES FIXTURE CAPACITANCE FIGURE 17. DYNAMIC POWER DISSIPATION TEST CIRCUITS 8 CD4049UB, CD4050B 9 PACKAGE OPTION ADDENDUM www.ti.com 15-Oct-2009 PACKAGING INFORMATION Orderable Device Status (1) Package Type Package Drawing Pins Package Eco Plan (2) Qty CD4049UBD ACTIVE SOIC D 16 40 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4049UBDE4 ACTIVE SOIC D 16 40 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4049UBDG4 ACTIVE SOIC D 16 40 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4049UBDR ACTIVE SOIC D 16 2500 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4049UBDRE4 ACTIVE SOIC D 16 2500 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4049UBDRG4 ACTIVE SOIC D 16 2500 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4049UBDT ACTIVE SOIC D 16 250 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4049UBDTE4 ACTIVE SOIC D 16 250 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4049UBDTG4 ACTIVE SOIC D 16 250 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4049UBDW ACTIVE SOIC DW 16 40 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4049UBDWE4 ACTIVE SOIC DW 16 40 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4049UBDWG4 ACTIVE SOIC DW 16 40 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4049UBDWR ACTIVE SOIC DW 16 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4049UBDWRE4 ACTIVE SOIC DW 16 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4049UBDWRG4 ACTIVE SOIC DW 16 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4049UBE ACTIVE PDIP N 16 25 Pb-Free (RoHS) CU NIPDAU N / A for Pkg Type CD4049UBEE4 ACTIVE PDIP N 16 25 Pb-Free (RoHS) CU NIPDAU N / A for Pkg Type Lead/Ball Finish MSL Peak Temp (3) CD4049UBF ACTIVE CDIP J 16 1 TBD A42 N / A for Pkg Type CD4049UBF3A ACTIVE CDIP J 16 1 TBD A42 N / A for Pkg Type CD4049UBF3AS2283 OBSOLETE CDIP J 16 TBD Call TI Call TI CD4049UBF3AS2534 OBSOLETE CDIP J 16 TBD Call TI Call TI CD4049UBM OBSOLETE SOIC D 16 TBD Call TI Call TI CD4049UBM96 OBSOLETE SOIC D 16 TBD Call TI Call TI CD4049UBNSR ACTIVE SO NS 16 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4049UBNSRE4 ACTIVE SO NS 16 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4049UBNSRG4 ACTIVE SO NS 16 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4049UBPW ACTIVE TSSOP PW 16 CU NIPDAU Level-1-260C-UNLIM 90 Addendum-Page 1 Green (RoHS & no Sb/Br) PACKAGE OPTION ADDENDUM www.ti.com 15-Oct-2009 Orderable Device Status (1) Package Type Package Drawing Pins Package Eco Plan (2) Qty CD4049UBPWE4 ACTIVE TSSOP PW 16 90 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4049UBPWG4 ACTIVE TSSOP PW 16 90 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4049UBPWR ACTIVE TSSOP PW 16 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4049UBPWRE4 ACTIVE TSSOP PW 16 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4049UBPWRG4 ACTIVE TSSOP PW 16 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4050BD ACTIVE SOIC D 16 40 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4050BDE4 ACTIVE SOIC D 16 40 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4050BDG4 ACTIVE SOIC D 16 40 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4050BDR ACTIVE SOIC D 16 2500 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4050BDRE4 ACTIVE SOIC D 16 2500 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4050BDRG4 ACTIVE SOIC D 16 2500 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4050BDT ACTIVE SOIC D 16 250 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4050BDTE4 ACTIVE SOIC D 16 250 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4050BDTG4 ACTIVE SOIC D 16 250 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4050BDW ACTIVE SOIC DW 16 40 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4050BDWE4 ACTIVE SOIC DW 16 40 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4050BDWG4 ACTIVE SOIC DW 16 40 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4050BDWR ACTIVE SOIC DW 16 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4050BDWRE4 ACTIVE SOIC DW 16 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4050BDWRG4 ACTIVE SOIC DW 16 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4050BE ACTIVE PDIP N 16 25 Pb-Free (RoHS) CU NIPDAU N / A for Pkg Type CD4050BEE4 ACTIVE PDIP N 16 25 Pb-Free (RoHS) CU NIPDAU N / A for Pkg Type Lead/Ball Finish MSL Peak Temp (3) CD4050BF ACTIVE CDIP J 16 1 TBD A42 N / A for Pkg Type CD4050BF3A ACTIVE CDIP J 16 1 TBD A42 N / A for Pkg Type CD4050BF3AS2283 OBSOLETE CDIP J 16 TBD Call TI Call TI CD4050BF3AS2534 OBSOLETE CDIP J 16 TBD Call TI Call TI CD4050BM OBSOLETE SOIC D 16 TBD Call TI Call TI CD4050BNSR ACTIVE SO NS 16 2000 Green (RoHS & no Sb/Br) Addendum-Page 2 CU NIPDAU Level-1-260C-UNLIM PACKAGE OPTION ADDENDUM www.ti.com 15-Oct-2009 Orderable Device Status (1) Package Type Package Drawing Pins Package Eco Plan (2) Qty CD4050BNSRE4 ACTIVE SO NS 16 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4050BNSRG4 ACTIVE SO NS 16 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4050BPW ACTIVE TSSOP PW 16 90 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4050BPWE4 ACTIVE TSSOP PW 16 90 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4050BPWG4 ACTIVE TSSOP PW 16 90 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4050BPWR ACTIVE TSSOP PW 16 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4050BPWRE4 ACTIVE TSSOP PW 16 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM CD4050BPWRG4 ACTIVE TSSOP PW 16 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM JM38510/05553BEA ACTIVE CDIP J 16 1 TBD A42 N / A for Pkg Type JM38510/05554BEA ACTIVE CDIP J 16 1 TBD A42 N / A for Pkg Type Lead/Ball Finish MSL Peak Temp (3) (1) The marketing status values are defined as follows: ACTIVE: Product device recommended for new designs. LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect. NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design. PREVIEW: Device has been announced but is not in production. Samples may or may not be available. OBSOLETE: TI has discontinued the production of the device. (2) Eco Plan - The planned eco-friendly classification: Pb-Free (RoHS), Pb-Free (RoHS Exempt), or Green (RoHS & no Sb/Br) - please check http://www.ti.com/productcontent for the latest availability information and additional product content details. TBD: The Pb-Free/Green conversion plan has not been defined. Pb-Free (RoHS): TI's terms "Lead-Free" or "Pb-Free" mean semiconductor products that are compatible with the current RoHS requirements for all 6 substances, including the requirement that lead not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, TI Pb-Free products are suitable for use in specified lead-free processes. Pb-Free (RoHS Exempt): This component has a RoHS exemption for either 1) lead-based flip-chip solder bumps used between the die and package, or 2) lead-based die adhesive used between the die and leadframe. The component is otherwise considered Pb-Free (RoHS compatible) as defined above. Green (RoHS & no Sb/Br): TI defines "Green" to mean Pb-Free (RoHS compatible), and free of Bromine (Br) and Antimony (Sb) based flame retardants (Br or Sb do not exceed 0.1% by weight in homogeneous material) (3) MSL, Peak Temp. -- The Moisture Sensitivity Level rating according to the JEDEC industry standard classifications, and peak solder temperature. Important Information and Disclaimer:The information provided on this page represents TI's knowledge and belief as of the date that it is provided. TI bases its knowledge and belief on information provided by third parties, and makes no representation or warranty as to the accuracy of such information. Efforts are underway to better integrate information from third parties. TI has taken and continues to take reasonable steps to provide representative and accurate information but may not have conducted destructive testing or chemical analysis on incoming materials and chemicals. TI and TI suppliers consider certain information to be proprietary, and thus CAS numbers and other limited information may not be available for release. In no event shall TI's liability arising out of such information exceed the total purchase price of the TI part(s) at issue in this document sold by TI to Customer on an annual basis. Addendum-Page 3 PACKAGE MATERIALS INFORMATION www.ti.com 19-Mar-2008 TAPE AND REEL INFORMATION *All dimensions are nominal Device Package Package Pins Type Drawing SPQ Reel Reel Diameter Width (mm) W1 (mm) A0 (mm) B0 (mm) K0 (mm) P1 (mm) W Pin1 (mm) Quadrant CD4049UBDR SOIC D 16 2500 330.0 16.4 6.5 10.3 2.1 8.0 16.0 Q1 CD4049UBDWR SOIC DW 16 2000 330.0 16.4 10.75 10.7 2.7 12.0 16.0 Q1 CD4049UBNSR SO NS 16 2000 330.0 16.4 8.2 10.5 2.5 12.0 16.0 Q1 CD4049UBPWR TSSOP PW 16 2000 330.0 12.4 7.0 5.6 1.6 8.0 12.0 Q1 CD4050BDR SOIC D 16 2500 330.0 16.4 6.5 10.3 2.1 8.0 16.0 Q1 CD4050BDWR SOIC DW 16 2000 330.0 16.4 10.75 10.7 2.7 12.0 16.0 Q1 CD4050BNSR SO NS 16 2000 330.0 16.4 8.2 10.5 2.5 12.0 16.0 Q1 CD4050BPWR TSSOP PW 16 2000 330.0 12.4 7.0 5.6 1.6 8.0 12.0 Q1 Pack Materials-Page 1 PACKAGE MATERIALS INFORMATION www.ti.com 19-Mar-2008 *All dimensions are nominal Device Package Type Package Drawing Pins SPQ Length (mm) Width (mm) Height (mm) CD4049UBDR CD4049UBDWR SOIC D 16 2500 333.2 345.9 28.6 SOIC DW 16 2000 346.0 346.0 33.0 CD4049UBNSR SO NS 16 2000 346.0 346.0 33.0 CD4049UBPWR TSSOP PW 16 2000 346.0 346.0 29.0 CD4050BDR SOIC D 16 2500 333.2 345.9 28.6 CD4050BDWR SOIC DW 16 2000 346.0 346.0 33.0 CD4050BNSR SO NS 16 2000 346.0 346.0 33.0 CD4050BPWR TSSOP PW 16 2000 346.0 346.0 29.0 Pack Materials-Page 2 MECHANICAL DATA MTSS001C – JANUARY 1995 – REVISED FEBRUARY 1999 PW (R-PDSO-G**) PLASTIC SMALL-OUTLINE PACKAGE 14 PINS SHOWN 0,30 0,19 0,65 14 0,10 M 8 0,15 NOM 4,50 4,30 6,60 6,20 Gage Plane 0,25 1 7 0°– 8° A 0,75 0,50 Seating Plane 0,15 0,05 1,20 MAX PINS ** 0,10 8 14 16 20 24 28 A MAX 3,10 5,10 5,10 6,60 7,90 9,80 A MIN 2,90 4,90 4,90 6,40 7,70 9,60 DIM 4040064/F 01/97 NOTES: A. B. C. D. All linear dimensions are in millimeters. This drawing is subject to change without notice. Body dimensions do not include mold flash or protrusion not to exceed 0,15. Falls within JEDEC MO-153 POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 PACKAGE OPTION ADDENDUM www.ti.com 24-Jan-2013 PACKAGING INFORMATION Orderable Device Status (1) Package Type Package Pins Package Qty Drawing Eco Plan Lead/Ball Finish (2) MSL Peak Temp Op Temp (°C) (3) Top-Side Markings (4) CD4049UBD ACTIVE SOIC D 16 40 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CD4049UBM CD4049UBDE4 ACTIVE SOIC D 16 40 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CD4049UBM CD4049UBDG4 ACTIVE SOIC D 16 40 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CD4049UBM CD4049UBDR ACTIVE SOIC D 16 2500 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CD4049UBM CD4049UBDRE4 ACTIVE SOIC D 16 2500 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CD4049UBM CD4049UBDRG4 ACTIVE SOIC D 16 2500 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CD4049UBM CD4049UBDT ACTIVE SOIC D 16 250 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CD4049UBM CD4049UBDTE4 ACTIVE SOIC D 16 250 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CD4049UBM CD4049UBDTG4 ACTIVE SOIC D 16 250 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CD4049UBM CD4049UBDW ACTIVE SOIC DW 16 40 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CD4049UBM CD4049UBDWE4 ACTIVE SOIC DW 16 40 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CD4049UBM CD4049UBDWG4 ACTIVE SOIC DW 16 40 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CD4049UBM CD4049UBDWR ACTIVE SOIC DW 16 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CD4049UBM CD4049UBDWRE4 ACTIVE SOIC DW 16 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CD4049UBM CD4049UBDWRG4 ACTIVE SOIC DW 16 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CD4049UBM CD4049UBE ACTIVE PDIP N 16 25 Pb-Free (RoHS) CU NIPDAU N / A for Pkg Type -55 to 125 CD4049UBE CD4049UBEE4 ACTIVE PDIP N 16 25 Pb-Free (RoHS) CU NIPDAU N / A for Pkg Type -55 to 125 CD4049UBE Addendum-Page 1 Samples PACKAGE OPTION ADDENDUM www.ti.com 24-Jan-2013 Orderable Device Status (1) Package Type Package Pins Package Qty Drawing Eco Plan Lead/Ball Finish (2) MSL Peak Temp Op Temp (°C) Top-Side Markings (3) (4) CD4049UBF ACTIVE CDIP J 16 1 TBD A42 N / A for Pkg Type -55 to 125 CD4049UBF CD4049UBF3A ACTIVE CDIP J 16 1 TBD A42 N / A for Pkg Type -55 to 125 CD4049UBF3A CD4049UBF3AS2283 OBSOLETE CDIP J 16 TBD Call TI Call TI CD4049UBF3AS2534 OBSOLETE CDIP J 16 TBD Call TI Call TI CD4049UBM OBSOLETE SOIC D 16 TBD Call TI Call TI -55 to 125 CD4049UBM96 OBSOLETE SOIC D 16 TBD Call TI Call TI -55 to 125 CD4049UBNSR ACTIVE SO NS 16 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CD4049UB CD4049UBNSRE4 ACTIVE SO NS 16 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CD4049UB CD4049UBNSRG4 ACTIVE SO NS 16 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CD4049UB CD4049UBPW ACTIVE TSSOP PW 16 90 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CM049UB CD4049UBPWE4 ACTIVE TSSOP PW 16 90 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CM049UB CD4049UBPWG4 ACTIVE TSSOP PW 16 90 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CM049UB CD4049UBPWR ACTIVE TSSOP PW 16 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CM049UB CD4049UBPWRE4 ACTIVE TSSOP PW 16 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CM049UB CD4049UBPWRG4 ACTIVE TSSOP PW 16 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CM049UB CD4050BD ACTIVE SOIC D 16 40 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CD4050BM CD4050BDE4 ACTIVE SOIC D 16 40 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CD4050BM CD4050BDG4 ACTIVE SOIC D 16 40 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CD4050BM CD4050BDR ACTIVE SOIC D 16 2500 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CD4050BM CD4050BDRE4 ACTIVE SOIC D 16 2500 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CD4050BM Addendum-Page 2 Samples PACKAGE OPTION ADDENDUM www.ti.com 24-Jan-2013 Orderable Device Status (1) Package Type Package Pins Package Qty Drawing Eco Plan Lead/Ball Finish (2) MSL Peak Temp Op Temp (°C) Top-Side Markings (3) (4) CD4050BDRG4 ACTIVE SOIC D 16 2500 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CD4050BM CD4050BDT ACTIVE SOIC D 16 250 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CD4050BM CD4050BDTE4 ACTIVE SOIC D 16 250 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CD4050BM CD4050BDTG4 ACTIVE SOIC D 16 250 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CD4050BM CD4050BDW ACTIVE SOIC DW 16 40 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CD4050BM CD4050BDWE4 ACTIVE SOIC DW 16 40 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CD4050BM CD4050BDWG4 ACTIVE SOIC DW 16 40 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CD4050BM CD4050BDWR ACTIVE SOIC DW 16 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CD4050BM CD4050BDWRE4 ACTIVE SOIC DW 16 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CD4050BM CD4050BDWRG4 ACTIVE SOIC DW 16 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CD4050BM CD4050BE ACTIVE PDIP N 16 25 Pb-Free (RoHS) CU NIPDAU N / A for Pkg Type -55 to 125 CD4050BE CD4050BEE4 ACTIVE PDIP N 16 25 Pb-Free (RoHS) CU NIPDAU N / A for Pkg Type -55 to 125 CD4050BE CD4050BF ACTIVE CDIP J 16 1 TBD A42 N / A for Pkg Type -55 to 125 CD4050BF CD4050BF3A ACTIVE CDIP J 16 1 TBD A42 N / A for Pkg Type -55 to 125 CD4050BF3A CD4050BF3AS2283 OBSOLETE CDIP J 16 TBD Call TI Call TI CD4050BF3AS2534 OBSOLETE CDIP J 16 TBD Call TI Call TI CD4050BM OBSOLETE SOIC D 16 TBD Call TI Call TI -55 to 125 CD4050BNSR ACTIVE SO NS 16 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CD4050B CD4050BNSRE4 ACTIVE SO NS 16 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CD4050B Addendum-Page 3 Samples PACKAGE OPTION ADDENDUM www.ti.com 24-Jan-2013 Orderable Device Status (1) Package Type Package Pins Package Qty Drawing Eco Plan Lead/Ball Finish (2) MSL Peak Temp Op Temp (°C) Top-Side Markings (3) (4) CD4050BNSRG4 ACTIVE SO NS 16 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CD4050B CD4050BPW ACTIVE TSSOP PW 16 90 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CM050B CD4050BPWE4 ACTIVE TSSOP PW 16 90 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CM050B CD4050BPWG4 ACTIVE TSSOP PW 16 90 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CM050B CD4050BPWR ACTIVE TSSOP PW 16 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CM050B CD4050BPWRE4 ACTIVE TSSOP PW 16 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CM050B CD4050BPWRG4 ACTIVE TSSOP PW 16 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CM050B JM38510/05553BEA ACTIVE CDIP J 16 1 TBD A42 N / A for Pkg Type -55 to 125 JM38510/ 05553BEA JM38510/05554BEA ACTIVE CDIP J 16 1 TBD A42 N / A for Pkg Type -55 to 125 JM38510/ 05554BEA M38510/05553BEA ACTIVE CDIP J 16 1 TBD A42 N / A for Pkg Type -55 to 125 JM38510/ 05553BEA M38510/05554BEA ACTIVE CDIP J 16 1 TBD A42 N / A for Pkg Type -55 to 125 JM38510/ 05554BEA (1) The marketing status values are defined as follows: ACTIVE: Product device recommended for new designs. LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect. NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design. PREVIEW: Device has been announced but is not in production. Samples may or may not be available. OBSOLETE: TI has discontinued the production of the device. (2) Eco Plan - The planned eco-friendly classification: Pb-Free (RoHS), Pb-Free (RoHS Exempt), or Green (RoHS & no Sb/Br) - please check http://www.ti.com/productcontent for the latest availability information and additional product content details. TBD: The Pb-Free/Green conversion plan has not been defined. Pb-Free (RoHS): TI's terms "Lead-Free" or "Pb-Free" mean semiconductor products that are compatible with the current RoHS requirements for all 6 substances, including the requirement that lead not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, TI Pb-Free products are suitable for use in specified lead-free processes. Pb-Free (RoHS Exempt): This component has a RoHS exemption for either 1) lead-based flip-chip solder bumps used between the die and package, or 2) lead-based die adhesive used between the die and leadframe. The component is otherwise considered Pb-Free (RoHS compatible) as defined above. Addendum-Page 4 Samples PACKAGE OPTION ADDENDUM www.ti.com 24-Jan-2013 Green (RoHS & no Sb/Br): TI defines "Green" to mean Pb-Free (RoHS compatible), and free of Bromine (Br) and Antimony (Sb) based flame retardants (Br or Sb do not exceed 0.1% by weight in homogeneous material) (3) MSL, Peak Temp. -- The Moisture Sensitivity Level rating according to the JEDEC industry standard classifications, and peak solder temperature. (4) Only one of markings shown within the brackets will appear on the physical device. Important Information and Disclaimer:The information provided on this page represents TI's knowledge and belief as of the date that it is provided. TI bases its knowledge and belief on information provided by third parties, and makes no representation or warranty as to the accuracy of such information. Efforts are underway to better integrate information from third parties. TI has taken and continues to take reasonable steps to provide representative and accurate information but may not have conducted destructive testing or chemical analysis on incoming materials and chemicals. TI and TI suppliers consider certain information to be proprietary, and thus CAS numbers and other limited information may not be available for release. In no event shall TI's liability arising out of such information exceed the total purchase price of the TI part(s) at issue in this document sold by TI to Customer on an annual basis. OTHER QUALIFIED VERSIONS OF CD4049UB, CD4049UB-MIL, CD4050B, CD4050B-MIL : • Catalog: CD4049UB, CD4050B • Military: CD4049UB-MIL, CD4050B-MIL NOTE: Qualified Version Definitions: • Catalog - TI's standard catalog product • Military - QML certified for Military and Defense Applications Addendum-Page 5 PACKAGE MATERIALS INFORMATION www.ti.com 8-Apr-2013 TAPE AND REEL INFORMATION *All dimensions are nominal Device CD4049UBDR Package Package Pins Type Drawing SPQ Reel Reel A0 Diameter Width (mm) (mm) W1 (mm) B0 (mm) K0 (mm) P1 (mm) W Pin1 (mm) Quadrant SOIC D 16 2500 330.0 16.4 6.5 10.3 2.1 8.0 16.0 Q1 CD4049UBDWR SOIC DW 16 2000 330.0 16.4 10.75 10.7 2.7 12.0 16.0 Q1 CD4049UBPWR TSSOP PW 16 2000 330.0 12.4 6.9 5.6 1.6 8.0 12.0 Q1 CD4050BDR SOIC D 16 2500 330.0 16.4 6.5 10.3 2.1 8.0 16.0 Q1 CD4050BDWR SOIC DW 16 2000 330.0 16.4 10.75 10.7 2.7 12.0 16.0 Q1 CD4050BPWR TSSOP PW 16 2000 330.0 12.4 6.9 5.6 1.6 8.0 12.0 Q1 Pack Materials-Page 1 PACKAGE MATERIALS INFORMATION www.ti.com 8-Apr-2013 *All dimensions are nominal Device Package Type Package Drawing Pins SPQ Length (mm) Width (mm) Height (mm) CD4049UBDR SOIC D 16 2500 333.2 345.9 28.6 CD4049UBDWR SOIC DW 16 2000 367.0 367.0 38.0 CD4049UBPWR TSSOP PW 16 2000 367.0 367.0 35.0 CD4050BDR SOIC D 16 2500 333.2 345.9 28.6 CD4050BDWR SOIC DW 16 2000 367.0 367.0 38.0 CD4050BPWR TSSOP PW 16 2000 367.0 367.0 35.0 Pack Materials-Page 2 IMPORTANT NOTICE Texas Instruments Incorporated and its subsidiaries (TI) reserve the right to make corrections, enhancements, improvements and other changes to its semiconductor products and services per JESD46, latest issue, and to discontinue any product or service per JESD48, latest issue. Buyers should obtain the latest relevant information before placing orders and should verify that such information is current and complete. All semiconductor products (also referred to herein as “components”) are sold subject to TI’s terms and conditions of sale supplied at the time of order acknowledgment. TI warrants performance of its components to the specifications applicable at the time of sale, in accordance with the warranty in TI’s terms and conditions of sale of semiconductor products. Testing and other quality control techniques are used to the extent TI deems necessary to support this warranty. Except where mandated by applicable law, testing of all parameters of each component is not necessarily performed. TI assumes no liability for applications assistance or the design of Buyers’ products. Buyers are responsible for their products and applications using TI components. To minimize the risks associated with Buyers’ products and applications, Buyers should provide adequate design and operating safeguards. TI does not warrant or represent that any license, either express or implied, is granted under any patent right, copyright, mask work right, or other intellectual property right relating to any combination, machine, or process in which TI components or services are used. Information published by TI regarding third-party products or services does not constitute a license to use such products or services or a warranty or endorsement thereof. Use of such information may require a license from a third party under the patents or other intellectual property of the third party, or a license from TI under the patents or other intellectual property of TI. Reproduction of significant portions of TI information in TI data books or data sheets is permissible only if reproduction is without alteration and is accompanied by all associated warranties, conditions, limitations, and notices. TI is not responsible or liable for such altered documentation. Information of third parties may be subject to additional restrictions. Resale of TI components or services with statements different from or beyond the parameters stated by TI for that component or service voids all express and any implied warranties for the associated TI component or service and is an unfair and deceptive business practice. TI is not responsible or liable for any such statements. Buyer acknowledges and agrees that it is solely responsible for compliance with all legal, regulatory and safety-related requirements concerning its products, and any use of TI components in its applications, notwithstanding any applications-related information or support that may be provided by TI. Buyer represents and agrees that it has all the necessary expertise to create and implement safeguards which anticipate dangerous consequences of failures, monitor failures and their consequences, lessen the likelihood of failures that might cause harm and take appropriate remedial actions. Buyer will fully indemnify TI and its representatives against any damages arising out of the use of any TI components in safety-critical applications. In some cases, TI components may be promoted specifically to facilitate safety-related applications. With such components, TI’s goal is to help enable customers to design and create their own end-product solutions that meet applicable functional safety standards and requirements. Nonetheless, such components are subject to these terms. No TI components are authorized for use in FDA Class III (or similar life-critical medical equipment) unless authorized officers of the parties have executed a special agreement specifically governing such use. Only those TI components which TI has specifically designated as military grade or “enhanced plastic” are designed and intended for use in military/aerospace applications or environments. Buyer acknowledges and agrees that any military or aerospace use of TI components which have not been so designated is solely at the Buyer's risk, and that Buyer is solely responsible for compliance with all legal and regulatory requirements in connection with such use. TI has specifically designated certain components as meeting ISO/TS16949 requirements, mainly for automotive use. In any case of use of non-designated products, TI will not be responsible for any failure to meet ISO/TS16949. Products Applications Audio www.ti.com/audio Automotive and Transportation www.ti.com/automotive Amplifiers amplifier.ti.com Communications and Telecom www.ti.com/communications Data Converters dataconverter.ti.com Computers and Peripherals www.ti.com/computers DLP® Products www.dlp.com Consumer Electronics www.ti.com/consumer-apps DSP dsp.ti.com Energy and Lighting www.ti.com/energy Clocks and Timers www.ti.com/clocks Industrial www.ti.com/industrial Interface interface.ti.com Medical www.ti.com/medical Logic logic.ti.com Security www.ti.com/security Power Mgmt power.ti.com Space, Avionics and Defense www.ti.com/space-avionics-defense Microcontrollers microcontroller.ti.com Video and Imaging www.ti.com/video RFID www.ti-rfid.com OMAP Applications Processors www.ti.com/omap TI E2E Community e2e.ti.com Wireless Connectivity www.ti.com/wirelessconnectivity Mailing Address: Texas Instruments, Post Office Box 655303, Dallas, Texas 75265 Copyright © 2013, Texas Instruments Incorporated
CD4049UBM96 价格&库存
很抱歉,暂时无法提供与“CD4049UBM96”相匹配的价格&库存,您可以联系我们找货
