MCR100-3 - MCR100-8
Taiwan Semiconductor
Small Signal Product
CREAT BY ART
Thyristors
FEATURES
- Epitaxial planar die construction
- Moisture sensitivity level 1
- Matte Tin (Sn) lead finish with Nickel (Ni) underplate
- Packing code with suffix "G" means
Green compound (Halogen free)
TO-92
MECHANICAL DATA
- Case : TO-92 plastic package
- Terminal : Matte tin plated, lead free, solderable
en
de
d
per MIL-STD-202, method 208 guaranteed
- High temperature soldering guaranteed : 260°C/10s
- Weight : 0.19 gram (approximately)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25°C unless otherwise noted)
PARAMETER
SYMBOL
Peak Repetitive Forward and Reverse
Blocking Voltage(TJ=25°C to 125°C,
RGK=1KΩ)
IT(RMS)
mm
Forward Current RMS (All Conduction Angles)
VALUE
UNIT
0.8
A
MCR100-3
100
MCR100-4
200
MCR100-5
300
VDRM
VRRM
MCR100-6
MCR100-7
eco
500
MCR100-8
Peak Forward Surge Current,TA=25°C
V
400
600
ITSM
10
A
I2t
PGM
0.415
0.1
A2s
W
PGF(AV)
0.01
W
Forward Peak Gate Current(TA=25°C,PW≤1 μs)
IGFM
1
A
Reverse Peak Gate Current(TA=25°C,PW ≤ 1 μs)
VGRM
5
V
TJ
-40 ~ +125
°C
TSTG
-40 ~ +150
°C
(1/2 Cycle,Sine Wave,60Hz)
tR
Circuit Fusing Considerations(t= 8.3 ms)
Forward Peak Gate Power (TA=25°C,PW≤1 μs)
No
Forward Average Gate Power(TA=25°C)
Operating junction temperature range
Storage temperature range
Notes: 1. Valid provided that electrodes are kept at ambient temperature
PARAMETER
Peak Forward or Reverse Blocking Current
at VAK= Rated VDRM or VRRM
Peak Forward On-State Voltage
at ITM=1A Peak, TA=25oC
Gate Trigger Current (Continous dc)
at Anode Voltage = 7 Vdc., RL=100Ω
SYMBOL
MIN
MAX
UNIT
IDRM
IRRM
10
μA
VTM
1.7
V
IGT
200
μA
VGT
0.8
V
IH
5
mA
at Anode Voltage = Rated VDRM , RL=100Ω)
Holding Current at Anode Voltage =7 Vdc, Initiating Current=20mA
Document Number: DS_S1412032
Version: D15
MCR100-3 - MCR100-8
CREAT BY ART
RATINGS AND CHARACTERISTICS CURVES
100
1
0.9
80
Gate Trigger Voltage(Volts)
Gate Trigger Current (μA)
90
70
60
50
40
30
-40
-25
-10
5
50
65
80
95
0.8
0.7
0.6
0.5
0.4
0.3
0.2
110
-40
-25
TJ , Junction Temperature (OC)
50
65
80
95
110
(OC)
d
TJ . Junction Temperature
de
1000
mm
Latching Current(μA)
en
1000
-40
-25
-10
5
e co
100
10
50
65
80
95
100
10
-40
110
-25
-10
tR
100
DC
180OC
70
60
60OC
120OC
90OC
40
0.2
0.3
IT(RMS), RMS On-State Current (AMPS)
65
80
95
110
Maximum @ TJ=25oC
80
30OC
50
10
90
50
35
Fig. 6 Typical On-State Characteristics
IT,Instantaneous On-State Current (A)
No
Fig. 5 Typical RMS Current Derating
110
Fig. 4 Typical Lacthing Curent VS.
Fig. 3 Typical Holding Curent VS.
120
5
TJ, Junction Temperature (OC)
TC , Maximum Allowable Case Temperature(OC)
5
Fig. 2 Typical Gate Trigger Voltage
VS. Junction Temperature
Fig. 1 Typical Gate Trigger Curent VS.
Holding Current(μA)
-10
0.4
0.5
Maximum @ TJ=110oC
1
0.1
0.5
0.8
1.1
1.4
1.7
2
2.3
2.6
2.9
3.2
3.5
VT,Instantaneous On-State Voltage (volts)
Version: D15
MCR100-3 - MCR100-8
CREAT BY ART
ORDER INFORMATION (EXAMPLE)
MCR100‐3 A1G
Green compound code
Packing code
Part no.
PACKAGE OUTLINE DIMENSIONS
TO-92 (Ammo)
A
F
Unit (mm)
DIM.
C
Max
Min
Max
A
4.30
5.10
0.169
0.201
B
4.30
4.70
0.169
0.185
12.50
0.492
2.20
2.80
0.087
0.110
0.35
0.55
0.014
0.022
F
0.59
1.40
0.023
0.055
G
0.29
0.51
0.011
0.020
H
3.30
4.10
0.130
0.161
C
D
mm
G
e co
H
TO-92 (Bulk)
en
E
E
D
No
tR
DIM.
d
Min
de
B
Unit (inch)
A
Unit (mm)
Unit (inch)
Min
Max
Min
Max
4.30
5.10
0.169
0.201
B
4.30
4.70
0.169
0.185
C
12.50
14.50
0.492
0.571
D
1.17
1.37
0.046
0.054
E
0.35
0.55
0.014
0.022
F
1.17
1.37
0.046
0.054
G
0.59
1.40
0.023
0.055
H
0.29
0.51
0.011
0.020
I
3.30
4.10
0.130
0.161
Version: D15
MCR100-3 - MCR100-8
CREAT BY ART
MARKING DIAGRAM
No
tR
e co
mm
en
de
d
x = Device P/N from 3~8
Version: D15
MCR100-3 - MCR100-8
No
tR
e co
mm
en
de
d
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
Version: D15
很抱歉,暂时无法提供与“MCR100-6 A1G”相匹配的价格&库存,您可以联系我们找货
