ZL40122
High Speed, Current Feedback
Quad Operational Amplifier
Data Sheet
Features
March 2006
450 MHz small signal bandwidth
1500 V/µs slew rate
Ordering Information
5.2 mA/channel static supply current
ZL40122/DCA
ZL40122/DCB
ZL40122DCF1
14 lead SOIC
14 lead SOIC
14 lead SOIC*
65 mA output current
ZL40122DCE1
14 lead SOIC*
120 MHz gain flatness to +/- 0. 1dB
14 pin SOIC
Tubes
Tape & Reel
Tape & Reel,
Bake & Drypack
Tubes, Bake & Drypack
*Pb Free Matte Tin
-40°C to +85°C
the ideal choice where a high density of high speed
devices is required.
Applications
Video switchers/routers
Video line drivers
Twisted pair driver/receiver
Active filters
The flat gain response to 120 MHz, 450 MHz small
signal bandwidth and 1500 V/µs slew rate make the
device an excellent solution for video applications such
as driving video signals down significant cable lengths.
Other applications which may take advantage of the
ZL40122 superior dynamic performance features
include low cost high order active filters and twisted pair
driver/receivers.
Description
The ZL40122 is a high speed, quad, current feedback
operational amplifier offering high performance at a
low cost. The device has a very high output current
drive capability of 65 mA while requiring only 5.2 mA of
static supply current. This feature makes the ZL40122
Out_1
14 Out_4
1
In_n_1 2
13 In_n_4
1
4
In_p_1 3
12 In_p_4
ZL40122
V+ 4
11 V-
In_p_2 5
10 In_p_3
2
3
In_n_2 6
9 In_n_3
Out_2 7
8 Out_3
Figure 1 - Functional Block Diagram and Pin Connection
1
Zarlink Semiconductor Inc.
Zarlink, ZL and the Zarlink Semiconductor logo are trademarks of Zarlink Semiconductor Inc.
Copyright 2003-2006, Zarlink Semiconductor Inc. All Rights Reserved.
ZL40122
Data Sheet
Change Summary
Changes from November 2004 Issue to March 2006 Issue. Page, section, figure and table numbers refer to this
current issue.
Page
Item
1
Change
Updated Ordering Information
Application Notes
Current Feedback Op Amps
Current feedback op amps offer several advantages over voltage feedback amplifiers:
AC bandwidth not dependent on closed loop gain
High Slew Rate
Fast settling time
The architecture of the current feedback opamp consists of a high impedance non-inverting input and a low
impedance inverting input which is always feedback connected. The error current is amplified by a transimpedance
amplifier which can be considered to have gain
Z( f ) =
Zo
f
1 + j
fo
where Zo is the DC gain.
It can be shown that the closed loop non-inverting gain is given by
Vout
Vin
Av
fR f
1 + j
f
Z
o o
where Av is the DC closed loop gain, Rf is the feedback resistor. The closed loop bandwidth is therefore given by
BWCL =
f o Z o GBOL
Rf
Rf
and for low values of closed loop gain Av depends only on the feedback resistor Rf and not the closed loop gain.
Increasing the value of Rf
Increases closed loop stability
Decreases loop gain
Decreases bandwidth
Reduces gain peaking
Reduces overshoot
Using a resistor value of Rf=510 Ω for Av=+2 V/V gives good stability and bandwidth. However since requirements
for stability and bandwidth vary it may be worth experimentation to find the optimal Rf for a given application.
2
ZL40122
Data Sheet
Layout Considerations
Correct high frequency operation requires a considered PCB layout as stray capacitances have a strong influence
over high frequency operation for this de0ice. The Zarlink evaluation board serves as a good example layout that
should be copied. The following guidelines should be followed:
Include 6.8 uF tantalum and 0.1 uF ceramic capacitors on both positive and negative supplies
Remove the ground plane under and around the part, especially near the input and output pins to reduce
parasitic capacitances
Minimize all trace lengths to reduce series inductance
3
ZL40122
Data Sheet
Application Diagrams
Vcc
6.8uF
0.1uF
Vin
Vout
¼ ZL40122
Rf
Rin
Ra
0.1uF
Vout
Rf
= Av = 1 +
Vin
Ra
6.8uF
Vee
Figure 2 - Non-inverting Gain
Vcc
6.8uF
Rb
0.1uF
Vout
¼ ZL40122
Rf
Vin
Ra
Rin
0.1uF
Vout
Rf
= Av = −
Vin
Ra
6.8uF
Vee
Figure 3 - Inverting Gain
4
ZL40122
Data Sheet
Absolute Maximum Ratings
Parameter
Symbol
Min.
Max.
Units
VIN
±1.2
V
1
Vin Differential
2
Output Short Circuit Protection
VOS/C
See Apps
Note in this
data sheet
3
Supply voltage
V+, V-
±6.5
V
4
Voltage at Input Pins
5
Voltage at Output Pins
6
EDS Protection
(HBM Human Body Model)
(see Note 2)
7
Storage Temperature
8
9
V(+IN), V(-IN)
V-
V+
V
VO
V-
V+
V
2
(see Note 3)
kV
-55
+150
°C
Latch-up test
±100 mA
for 100 ms
(see Note 4)
Supply transient test
20% pulse
for 100 ms
(see Note 5)
Note 1:
Absolute Maximum Ratings indicate limits beyond which damage to the device may occur. Operating Ratings indicate
conditions for which the device is intended to be functional, but specific performance is not guaranteed. For guaranteed
specifications and the test conditions, see the Electrical Characteristics.
Note 2:
Human body model, 1.5 kΩ in series with 100 pF. Machine model, 20 Ωin series with 100 pF.
Note 3:
0.8 kV between the pairs of +INA, -INA and +INB pins only. 2 kV between supply pins, OUTA or OUTB pins and any input pin.
Note 4:
±100 mA applied to input and output pins to force the device to go into "latch-up". The device passes this test to JEDEC spec
17.
Note 5:
Positive and Negative supply transient testing increases the supplies by 20% for 100 ms.
Operating Range
Characteristic
Min.
Typ.
Max.
Units
Supply Voltage (Vcc)
±4.0
±6.0
V
Operating Temperature (Ambient)
-40
+85
°C
Junction to Ambient resistance
Rth(j-a)
150
°C
4 layer
FR4 board
Junction to Case resistance
Rth(j-c)
60
°C
4 layer
FR4 board
5
Comments
ZL40122
Data Sheet
Electrical Characteristics - Vcc=±5 V, Tamb=25C(typ.),Tamb=-40C to +85C(min-max), Av=+2V/V, Rf=510 Ω,
Rload=100 Ω unless specified.
Characteristic
Conditions
Typ
25C
Min/
Max
25C
Min/
Max
–40 to
Units
Test
Type1
+85C
Frequency Domain Response
-3 dB Bandwidth
Av=+1; Vo < 0.5 Vp-p;
Rf=1.5 kΩ
450
MHz
C
Av=+2; Vo < 0.5 Vp-p;
Rf=510 Ω
380
MHz
C
Av=+2; Vo < 5 Vp-p;
Rf=510 Ω
170
MHz
C
+/- 0.1 dB Flatness
Rf=510 Ω
120
MHz
C
Differential Gain (NTSC)
Rload=150 Ω
0.01
C
Differential Phase (NTSC)
Rload=150 Ω
0.015
deg.
C
1
ns
C
Vout=5 V Step
2.8
ns
C
Settling Time to 0.1%
Vout=2 V Step
6
ns
C
Overshoot
Vout=0.5 V Step
4
C
Slew Rate
Vout=5 V Step
1500
V/µs
C
Time Domain Response
Rise and Fall Time
Vout=0.5 V Step
Noise and Distortion
2nd Harmonic Distortion
Vout=2 Vp-p, 1 MHz
-84
dBc
C
3nd Harmonic Distortion
Vout=2 Vp-p, 1 MHz
-85
dBc
C
Voltage
>1 MHz
5.5
nV
Hz
C
Non-Inverting Current
>1 MHz
1.3
pV
Hz
C
Inverting Current
>1 MHz
11
pA
Hz
C
Input Offset Voltage
2.7
±6.3
±7.7
mV
A
Average Drift
15
µV/deg. C
C
2.6
±5.6
±6
uA
A
6
nA/deg. C
C
Equivalent Input Noise
Static, DC Performance
Input Bias Current – Non-inverting
Average Drift
6
ZL40122
Characteristic
Conditions
Input Bias Current – Inverting
Data Sheet
Typ
25C
Min/
Max
25C
Min/
Max
–40 to
Units
Test
Type1
+85C
7.4
±25
±28
µA
A
15
nA/deg. C
C
Average Drift
Power Supply Rejection Ratio
(+ve)
DC
61
58
57
dB
A
(-ve)
DC
58
56
55
dB
A
Common Mode Rejection Ratio
DC
54
50
49
dB
A
Supply Current (per Channel)
Quiescent
5.2
6.5
6.7
mA
A
Input Resistance (Non-inverting)
8
MΩ
C
Input Capacitance (Non-inverting)
1
pF
C
±2.4
±2.2
±2.0
V
A
±2.8
±2.7
±2.6
V
A
65
mA
C
90
mΩ
C
Miscellaneous Performance
Common Mode Input Range
Output Voltage Range
Rload=100 Ω
Output Current (max)
Output Resistance, Closed Loop
DC
Note: Test Types:
(A) 100% tested at 25°C. Over temperature limits are set by characterization and simulation.
(B) Limits set by characterization or simulation.
(C) Typical value only for information.
7
ZL40122
Typical Performance Characteristics -
Data Sheet
Tamb=25degC, Vsupply=± 5 V, Rload=100 Ω, Av=+2V/V, Rf=510 Ω,
unless otherwise specified.
Non-Inverting Frequency Response
2
200
Gain
Av =+1
Rf = 1k
100
Av =+8
Rf = 150
-4
50
Phase
-6
-50
Av =+4
Rf = 150
-10
Vo=0.5Vp-p
-12
-100
Av =+2
Rf = 510
-14
1
10
100
Frequency (MHz)
8
-150
-200
1000
Phase (deg.)
Normalised Gain (dB)
-2
150
ZL40122
Data Sheet
Non-Inverting Frequency Response varying Rf
2
Rf=390
Rf=250
-2
Rf=700
-4
-6
Rf=510
-8
-10
-12
-14
Vo=0.5Vp-p
-16
-18
10
100
1000
Frequency (MHz)
Open Loop Transimpedance Gain and Phase
120
Transimpedance Gain
100
-60
Transimpedance Phase
90
-90
80
-120
70
-150
60
-180
50
-210
40
1.0E+03
1.0E+04
1.0E+05
1.0E+06
1.0E+07
Frequency (Hz)
9
1.0E+08
-240
1.0E+09
Transimpedance Gain
110
ZL40122
Data Sheet
Large Signal Gain
Vo = 1V p-p
-2
Vo = 5V p-p
-6
Vo = 4V p-p
-8
-10
-12
-14
-16
10
100
1000
Frequency (MHz)
Harmonic Distortion vs Frequency
-40
Vo = 2V p-p
2nd & 3rd Harmonic Distortion (dBc)
Gain (dB)
-4
-50
2nd Harmonic
-60
-70
-80
3rd Harmonic
-90
-100
1
10
Frequency (MHz)
10
100
ZL40122
Data Sheet
CMRR
70
T = - 40 degC
Rejection Ration (dB)
60
50
T = + 25 degC
T = + 85 degC
40
30
1.0E+03
1.0E+04
1.0E+05
1.0E+06
1.0E+07
1.0E+08
1.0E+07
1.0E+08
Frequency (Hz)
PSRR +ve
80
T = - 40 degC
70
60
T = + 25 degC
50
T = + 85 degC
40
30
1.0E+03
1.0E+04
1.0E+05
1.0E+06
Frequency (Hz)
11
ZL40122
Data Sheet
PSRR -ve
70
T = - 40 degC
60
50
T = + 25 degC
T = + 85 degC
40
30
1.0E+03
1.0E+04
1.0E+05
1.0E+06
1.0E+07
1.0E+08
Frequency (Hz)
T
Input Voltage and Current Noise
Current Noise (pA/SQRT(Hz)
Voltage Noise (nV/SQRT(Hz)
100
Inverting Input Current Noise
10
Input Voltage Noise
Non-Inverting Input Current
1
1.0E+01
1.0E+02
1.0E+03
1.0E+04
1.0E+05
Frequency (Hz)
12
1.0E+06
1.0E+07
ZL40122
Data Sheet
Supply Current vs Temperature
5.60
5.50
Supply Current (mA)
5.40
5.30
5.20
5.10
5.00
4.90
4.80
4.70
-40
-20
60
80
100
120
140
120
140
Die Temp (deg. C)
DC Drift Over Temperature
9.00
Input Offset Voltage (mV)
Input Bias Current (uA)
8.00
Input Bias Inv
7.00
6.00
5.00
4.00
3.00
2.00
Input Bias Non-Inv
1.00
0.00
-40
-20
60
Die Temp (deg. C)
13
80
100
ZL40122
Data Sheet
Large and Small Signal Pulse Response
3
0.6
Vout = 5V Step
Large Signal Vout (V)
1
0.2
Vout = 0.5V Step
-0.2
-2
-0.4
-3
-0.6
40
50
60
70
Small Signal Vout (V)
0.4
2
80
Time (ns)
Closed Loop Output Impedance
Closed Loop Output Impedance (Ohms)
10
1
0.1
0.01
0.01
0.1
1
Frequency (MHz)
14
10
100
ZL40122
Data Sheet
Differential Gain & Phase ZL40122 / ZL40123
NTSC
RL=150?
Best fit Gain
Best fit Phase
0.07
0.06
0.05
Differential Gain & Phase (?% & ?°)
0.04
0.03
0.02
0.01
-0.02
-0.03
-0.04
-0.05
-0.06
-0.07
-0.7
-0.6
-0.5
-0.4
-0.3
-0.2
-0.1
Bias Voltage
15
0.2
0.3
0.4
0.5
0.6
0.7
Package Code
c Zarlink Semiconductor 2003 All rights reserved.
ISSUE
ACN
DATE
APPRD.
Previous package codes
For more information about all Zarlink products
visit our Web Site at
www.zarlink.com
Information relating to products and services furnished herein by Zarlink Semiconductor Inc. or its subsidiaries (collectively “Zarlink”) is believed to be reliable.
However, Zarlink assumes no liability for errors that may appear in this publication, or for liability otherwise arising from the application or use of any such
information, product or service or for any infringement of patents or other intellectual property rights owned by third parties which may result from such application or
use. Neither the supply of such information or purchase of product or service conveys any license, either express or implied, under patents or other intellectual
property rights owned by Zarlink or licensed from third parties by Zarlink, whatsoever. Purchasers of products are also hereby notified that the use of product in
certain ways or in combination with Zarlink, or non-Zarlink furnished goods or services may infringe patents or other intellectual property rights owned by Zarlink.
This publication is issued to provide information only and (unless agreed by Zarlink in writing) may not be used, applied or reproduced for any purpose nor form part
of any order or contract nor to be regarded as a representation relating to the products or services concerned. The products, their specifications, services and other
information appearing in this publication are subject to change by Zarlink without notice. No warranty or guarantee express or implied is made regarding the
capability, performance or suitability of any product or service. Information concerning possible methods of use is provided as a guide only and does not constitute
any guarantee that such methods of use will be satisfactory in a specific piece of equipment. It is the user’s responsibility to fully determine the performance and
suitability of any equipment using such information and to ensure that any publication or data used is up to date and has not been superseded. Manufacturing does
not necessarily include testing of all functions or parameters. These products are not suitable for use in any medical products whose failure to perform may result in
significant injury or death to the user. All products and materials are sold and services provided subject to Zarlink’s conditions of sale which are available on request.
Purchase of Zarlink’s I2C components conveys a licence under the Philips I2C Patent rights to use these components in and I2C System, provided that the system
conforms to the I2C Standard Specification as defined by Philips.
Copyright Zarlink Semiconductor Inc. All Rights Reserved.
TECHNICAL DOCUMENTATION - NOT FOR RESALE
