SX011U
SX011U
    SMCDIODESOLUTIONS(桑德斯)
    TO92-3
    SX011U
SX011U 数据手册
SX011V SX011U Technical Data Data Sheet N2033, Rev.- SX011 Series Sensitive gate SCRs Description The SX011 SCR series provide high dv/dt rate with strong resistance to electromagnetic interface. They are especially recommended for use on residual current circuit breaker, straight hair, igniter etc. SX011V SX011U SOT-223 TO-92 Maximum Ratings: Characteristics Symbol Condition Max. Storage junction temperature range Operating junction temperature range Repetitive peak off-state voltage Tstg - -40 to +150 C VDRM - 800 V Repetitive peak reverse voltage VRRM - 800 V 1 A 12 A 0.72 A2 s RMS on-state current Non repetitive surge peak on-state current(tp=10ms) I2t value for fusing (tp=10ms) Critical rate of rise of on-state current I(TRMS) ITSM - -40 to +110 Units TJ TO-92(TC=65℃) SOT-223(TC=75℃) - 2 It - C dI/dt - 50 A/us Peak gate current (tp=20μs, Tj=110℃) IGM 0.3 A Peak gate power (tp=20μs, Tj=110℃) PGM - 0.5 W PG(AV) - 0.1 W Average gate power dissipation(Tj=110℃)  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SX011V SX011U Technical Data Data Sheet N2033, Rev.- Electrical Characteristics(Tj=25℃ unless otherwise specified) Symbol IGT VGT VGD Condition Min. VD=12V RL=33Ω VD=VDRM Tj=110℃ Typ. Max. Units - 40 200 μA - 0.6 0.8 V 0.2 - - V IL IG=1.2 IGT - - 5 mA IH IT=0.05A VD=2/3VDRM Tj=110℃ RGK=1KΩ - - 4 mA 100 200 - V/μs dV/dt * Pulse width < 300 µs, duty cycle < 2% Static Characteristics Symbol VTM IDRM IRRM Condition Max. IT=2A tp=380μs,Tj=25℃ VD=VDRM VR=VRRM, Tj=25℃ VD=VDRM VR=VRRM, Tj=110℃ Units 1.7 5 100 V uA uA Value Units Thermal Resistances Symbol Rth(j-c) Condition Junction to case TO-92 70 SOT-223 25 ℃/W Ordering Information S X 011 U SMC Diode Solutions V:SOT-223 U:TO-92 Sensitive gate SCRs IT(RMS):1A Device Package Shipping SX011V SOT-223 8000pcs/ reel SX011VTR SOT-223 8000pcs/ reel SX011U TO-92 2000pcs/ reel SX011UTR TO-92 2000pcs/ reel  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SX011V SX011U Technical Data Data Sheet N2033, Rev.- Ratings and Characteristics Curves FIG.1: Maximum power dissipation versus RMS on-state current 1.5 FIG.2: RMS on-state current versus case temperature IT(RMS) (A) 1.5 P(w) α=180° 1.0 1.0 SOT-223 TO-92 0.5 0.5 0 0 IT(RMS) (A) 0.4 0.6 0.2 0.8 0 1.0 FIG.3: Surge peak on-state current versus number of cycles 12 Tc (℃) 0 25 50 75 100 125 FIG.4: On-state characteristics (maximum values) ITM(A) 10 ITSM (A) tp=10ms One cycle 9 1 6 Tj=Tjmax 3 Number of cycles 0 1 10 100 1000 FIG.5: Non-repetitive surge peak on-state current for a sinusoidal pulse with width tp
SX011U
物料型号: - SX011V:封装为SOT-223,适用于要求高dv/dt和强电磁兼容性的应用。 - SX011U:封装为TO-92,同样适用于类似应用。
器件简介: - SX011系列敏感门控SCR,提供高dv/dt率和强烈的电磁干扰抗性,特别推荐用于剩余电流断路器、直发器、点火器等。
引脚分配: - SX011V和SX011U的引脚分配在文档中有图示,但未直接提供中文描述。
参数特性: - 存储结温范围:-40至+110°C - 工作结温范围:-40至+150°C - 重复峰值关断电压:800V - 重复峰值反向电压:800V - RMS导通电流:TO-92封装在65°C时为1A,SOT-223封装在75°C时为1A - 非重复浪涌峰值导通电流(10ms):12A
功能详解: - 敏感门控SCR允许使用较小的门极电流触发,具有快速响应和高可靠性。 - 器件具有高dv/dt耐受性和良好的电磁兼容性。
应用信息: - 推荐用于剩余电流断路器、直发器、点火器等。
封装信息: - SX011V:SOT-223封装,每卷8000件。 - SX011U:TO-92封装,每卷2000件。
SX011U 价格&库存
很抱歉,暂时无法提供与“SX011U”相匹配的价格&库存,您可以联系我们找货
SX011U
    • 1+1.57626
    • 200+0.62900
    • 500+0.60794
    • 1000+0.59757
