S-1740C10-A6T2U4
S-1740C10-A6T2U4
    ABLIC(艾普凌科)
    SMD6
    IC REG LINEAR 1V 100MA HSNT6-B
S-1740C10-A6T2U4 数据手册
S-1740/1741 Series www.ablic.com www.ablicinc.com 5.5 V INPUT, 100 mA VOLTAGE REGULATOR WITH SUPPLY VOLTAGE DIVIDED OUTPUT Rev.1.3_00 © ABLIC Inc., 2016-2018 The S-1740/1741 Series, developed using CMOS technology, is a positive voltage regulator with the supply voltage divided output, which features super low current consumption and low dropout voltage. The regulator block has low current consumption of 0.35 μA typ. and high-accuracy output voltage of ±1.0%. The function of the supply voltage divided output is prepared in the S-1740/1741 Series. The supply voltage divided output is a function that divides the input voltage (VIN) of the regulator into VIN/2 or VIN/3 and outputs the voltage. For example, this function makes it possible that the IC connects to a low voltage microcontroller A/D converter directly and the microcontroller monitors a battery voltage.  Features Regulator block • Output voltage: • Input voltage: • Output voltage accuracy: • Dropout voltage: • Current consumption during operation: • Output current: • Input capacitor: • Output capacitor: • Built-in overcurrent protection circuit: Supply voltage divider block • Output voltage: • Current consumption during operation: • Output capacitor: • Built-in enable circuit: Overall • Operation temperature range: • Lead-free (Sn 100%), halogen-free VOUT = 1.0 V to 3.5 V, selectable in 0.05 V step VIN = 1.5 V to 5.5 V ±1.0% (1.0 V to 1.45 V output product: ±15 mV) (Ta = +25°C) 20 mV typ. (2.5 V output product, at IOUT = 10 mA) (Ta = +25°C) ISS1 = 0.35 μA typ. (Ta = +25°C) Possible to output 100 mA ( at VIN ≥ VOUT(S) + 1.0 V)*1 A ceramic capacitor can be used. (1.0 μF or more) A ceramic capacitor can be used. (1.0 μF to 100 μF) Limits overcurrent of output transistor. VPMOUT = VIN/2 (S-1740 Series) VPMOUT = VIN/3 (S-1741 Series) ISS1P = 0.15 μA typ. (Ta = +25°C) A ceramic capacitor can be used. (100 nF to 220 nF) Ensures long battery life. Ta = −40°C to +85°C *1. Please make sure that the loss of the IC will not exceed the power dissipation when the output current is large.  Applications • Constant-voltage power supply and battery voltage monitoring support for battery-powered device • Constant-voltage power supply for portable communication device, digital camera, and digital audio player • Constant-voltage power supply for home electric appliance  Packages • SOT-23-5 • HSNT-6(1212) • HSNT-4(1010) 1 5.5 V INPUT, 100 mA VOLTAGE REGULATOR WITH SUPPLY VOLTAGE DIVIDED OUTPUT Rev.1.3_00 S-1740/1741 Series  Block Diagram 1. S-1740/1741 Series A / C type (SOT-23-5, HSNT-6(1212)) *1 VOUT VIN SW Overcurrent protection circuit + PMOUT − + Enable circuit PMEN − Reference voltage circuit VSS Product Type S-1740 Series A type S-1740 Series C type S-1741 Series A type S-1741 Series C type *1. Output Voltage (VPMOUT) VIN/2 VIN/3 Parasitic diode Figure 1 2 PMEN Pin Logic Active "H" Active "L" Active "H" Active "L" 5.5 V INPUT, 100 mA VOLTAGE REGULATOR WITH SUPPLY VOLTAGE DIVIDED OUTPUT Rev.1.3_00 S-1740/1741 Series 2. S-1740/1741 Series G type (HSNT-4(1010)) *1 VOUT VIN Overcurrent protection circuit + PMOUT − + − Reference voltage circuit VSS Product Type S-1740 Series G type S-1741 Series G type *1. Output Voltage (VPMOUT) VIN/2 VIN/3 PMEN Pin Logic Without PMEN pin Parasitic diode Figure 2 3 5.5 V INPUT, 100 mA VOLTAGE REGULATOR WITH SUPPLY VOLTAGE DIVIDED OUTPUT Rev.1.3_00 S-1740/1741 Series  Product Name Structure Users can select supply voltage divider block output voltage, product type, regulator block output voltage, and package type for the S-1740/1741 Series. Refer to "1. Product name" regarding the contents of product name, "2. Function list of product type" regarding the product type, "3. Packages" regarding the package drawings and "4. Product name list" for details of product names. 1. Product name S-174x x xx - xxxx U 4 Environmental code U: Lead-free (Sn 100%), halogen-free Package abbreviation and IC packing specifications*1 M5T1: SOT-23-5, Tape A6T2: HSNT-6(1212), Tape A4T2: HSNT-4(1010), Tape*2 Regulator block output voltage*3 10 to 35 (e.g., when the output voltage is 1.0 V, it is expressed as 10.) *4 Product type A, C, G Supply voltage divider block output voltage*4 0: VIN/2 1: VIN/3 *1. *2. *2. *3. 2. Refer to the tape drawing. Only S-1740/1741 Series G type Contact our sales office when the product which has 0.05 V step is necessary. Refer to "2. Function list of product type" and "2. 2 PMEN pin" in "2. block" in " Operation". Supply voltage divider Function list of product type Table 1 Product Type S-1740 Series A type S-1740 Series C type S-1740 Series G type S-1741 Series A type S-1741 Series C type S-1741 Series G type 3. Output Voltage (VPMOUT) VIN/2 VIN/3 Active "H" Active "L" Without PMEN pin Active "H" Active "L" Without PMEN pin Package HSNT-6(1212), SOT-23-5 HSNT-4(1010) HSNT-6(1212), SOT-23-5 HSNT-4(1010) Packages Table 2 Package Name SOT-23-5 HSNT-6(1212) HSNT-4(1010) 4 PMEN Pin Logic Dimension MP005-A-P-SD PM006-A-P-SD PL004-A-P-SD Package Drawing Codes Tape MP005-A-C-SD PM006-A-C-SD PL004-A-C-SD Reel MP005-A-R-SD PM006-A-R-SD PL004-A-R-SD Land − PM006-A-L-SD PL004-A-L-SD 5.5 V INPUT, 100 mA VOLTAGE REGULATOR WITH SUPPLY VOLTAGE DIVIDED OUTPUT Rev.1.3_00 S-1740/1741 Series 4. Product name list 4. 1 S-1740 Series 4. 1. 1 A type PMEN pin logic: Output Voltage (VPMOUT): Active "H" VIN/2 Table 3 SOT-23-5 HSNT-6(1212) Output Voltage (VOUT) 1.0 V ± 15 mV S-1740A10-M5T1U4 S-1740A10-A6T2U4 1.7 V ± 1.0% S-1740A17-M5T1U4 S-1740A17-A6T2U4 1.8 V ± 1.0% S-1740A18-M5T1U4 S-1740A18-A6T2U4 2.0 V ± 1.0% S-1740A20-M5T1U4 S-1740A20-A6T2U4 2.1 V ± 1.0% S-1740A21-M5T1U4 S-1740A21-A6T2U4 3.0 V ± 1.0% S-1740A30-M5T1U4 S-1740A30-A6T2U4 Remark Please contact our sales office for products with specifications other than the above. 4. 1. 2 C type PMEN pin logic: Output Voltage (VPMOUT): Active "L" VIN/2 Table 4 SOT-23-5 HSNT-6(1212) Output Voltage (VOUT) 1.0 V ± 15 mV S-1740C10-M5T1U4 S-1740C10-A6T2U4 1.7 V ± 1.0% S-1740C17-M5T1U4 S-1740C17-A6T2U4 1.8 V ± 1.0% S-1740C18-M5T1U4 S-1740C18-A6T2U4 2.0 V ± 1.0% S-1740C20-M5T1U4 S-1740C20-A6T2U4 2.1 V ± 1.0% S-1740C21-M5T1U4 S-1740C21-A6T2U4 3.0 V ± 1.0% S-1740C30-M5T1U4 S-1740C30-A6T2U4 Remark Please contact our sales office for products with specifications other than the above. 4. 1. 3 G type PMEN pin logic: Output Voltage (VPMOUT): Without PMEN pin VIN/2 Table 5 HSNT-4(1010) Output Voltage (VOUT) 1.0 V ± 15 mV S-1740G10-A4T2U4 1.7 V ± 1.0% S-1740G17-A4T2U4 1.8 V ± 1.0% S-1740G18-A4T2U4 2.0 V ± 1.0% S-1740G20-A4T2U4 2.1 V ± 1.0% S-1740G21-A4T2U4 3.0 V ± 1.0% S-1740G30-A4T2U4 Remark Please contact our sales office for products with specifications other than the above. 5 5.5 V INPUT, 100 mA VOLTAGE REGULATOR WITH SUPPLY VOLTAGE DIVIDED OUTPUT Rev.1.3_00 S-1740/1741 Series 4. 2 S-1741 Series 4. 2. 1 A type PMEN pin logic: Output Voltage (VPMOUT): Active "H" VIN/3 Table 6 SOT-23-5 HSNT-6(1212) Output Voltage (VOUT) 1.0 V ± 15 mV S-1741A10-M5T1U4 S-1741A10-A6T2U4 1.7 V ± 1.0% S-1741A17-M5T1U4 S-1741A17-A6T2U4 1.8 V ± 1.0% S-1741A18-M5T1U4 S-1741A18-A6T2U4 2.0 V ± 1.0% S-1741A20-M5T1U4 S-1741A20-A6T2U4 2.1 V ± 1.0% S-1741A21-M5T1U4 S-1741A21-A6T2U4 3.0 V ± 1.0% S-1741A30-M5T1U4 S-1741A30-A6T2U4 Remark Please contact our sales office for products with specifications other than the above. 4. 2. 2 C type PMEN pin logic: Output Voltage (VPMOUT): Active "L" VIN/3 Table 7 SOT-23-5 HSNT-6(1212) Output Voltage (VOUT) 1.0 V ± 15 mV S-1741C10-M5T1U4 S-1741C10-A6T2U4 1.7 V ± 1.0% S-1741C17-M5T1U4 S-1741C17-A6T2U4 1.8 V ± 1.0% S-1741C18-M5T1U4 S-1741C18-A6T2U4 2.0 V ± 1.0% S-1741C20-M5T1U4 S-1741C20-A6T2U4 2.1 V ± 1.0% S-1741C21-M5T1U4 S-1741C21-A6T2U4 3.0 V ± 1.0% S-1741C30-M5T1U4 S-1741C30-A6T2U4 Remark Please contact our sales office for products with specifications other than the above. 4. 2. 3 G type PMEN pin logic: Output Voltage (VPMOUT): Without PMEN pin VIN/3 Table 8 HSNT-4(1010) Output Voltage (VOUT) S-1741G10-A4T2U4 1.0 V ± 15 mV S-1741G17-A4T2U4 1.7 V ± 1.0% S-1741G18-A4T2U4 1.8 V ± 1.0% S-1741G20-A4T2U4 2.0 V ± 1.0% S-1741G21-A4T2U4 2.1 V ± 1.0% S-1741G30-A4T2U4 3.0 V ± 1.0% Remark Please contact our sales office for products with specifications other than the above. 6 5.5 V INPUT, 100 mA VOLTAGE REGULATOR WITH SUPPLY VOLTAGE DIVIDED OUTPUT Rev.1.3_00 S-1740/1741 Series  Pin Configurations 1. SOT-23-5 Table 9 Top view 5 4 1 2 3 Pin No. 1 2 3 4 5 S-1740/1741 Series A / C type Symbol VIN VSS PMEN PMOUT VOUT Description Input voltage pin GND pin Supply voltage divided output enable pin Supply voltage divided output pin Output voltage pin Figure 3 2. HSNT-6(1212) Table 10 Top view 1 2 3 6 5 4 Bottom view 6 5 4 1 2 3 Pin No. 1 2 3 4 5 6 Symbol VOUT VSS PMOUT PMEN NC*2 VIN S-1740/1741 Series A / C type Description Output voltage pin GND pin Supply voltage divided output pin Supply voltage divided output enable pin No connection Input voltage pin *1 Figure 4 *1. Connect the heat sink of backside at shadowed area to the board, and set electric potential GND. However, do not use it as the function of electrode. *2. The NC pin is electrically open. The NC pin can be connected to the VIN pin or the VSS pin. 3. HSNT-4(1010) Table 11 Top view 1 2 4 3 Bottom view 4 3 Pin No. 1 2 3 4 Symbol VOUT VSS PMOUT VIN S-1740/1741 Series G type Description Output voltage pin GND pin Supply voltage divided output pin Input voltage pin 1 2 *1 Figure 5 *1. Connect the heat sink of backside at shadowed area to the board, and set electric potential GND. However, do not use it as the function of electrode. 7 5.5 V INPUT, 100 mA VOLTAGE REGULATOR WITH SUPPLY VOLTAGE DIVIDED OUTPUT Rev.1.3_00 S-1740/1741 Series  Absolute Maximum Ratings Table 12 Item Symbol (Ta = +25°C unless otherwise specified) Absolute Maximum Rating Unit VSS − 0.3 to VSS + 6.0 V VIN Input voltage VPMEN VSS − 0.3 to VSS + 6.0 V VSS − 0.3 to VIN + 0.3 V VOUT Output voltage VPMOUT VSS − 0.3 to VIN + 0.3 V Output current IOUT 120 mA Operation ambient temperature Topr −40 to +85 °C Storage temperature Tstg −40 to +125 °C Caution The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions. Regulator block Supply voltage divider block Regulator block Supply voltage divider block  Thermal Resistance Value Table 13 Item Symbol Condition Board A Board B SOT-23-5 Board C Board D Board E Board A Board B Junction-to-ambient thermal resistance*1 θJA HSNT-6(1212) Board C Board D Board E Board A Board B HSNT-4(1010) Board C Board D Board E *1. Test environment: compliance with JEDEC STANDARD JESD51-2A Remark Refer to " Power Dissipation" and "Test Board" for details. 8 Min. − − − − − − − − − − − − − − − Typ. 192 160 − − − 234 193 − − − 378 317 − − − Max. − − − − − − − − − − − − − − − Unit °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W 5.5 V INPUT, 100 mA VOLTAGE REGULATOR WITH SUPPLY VOLTAGE DIVIDED OUTPUT Rev.1.3_00 S-1740/1741 Series  Electrical Characteristics 1. Regulator block Table 14 Item Output voltage*1 *2 Output current Symbol VOUT(E) IOUT Condition 1.0 V ≤ VOUT(S) < 1.5 V VIN = VOUT(S) + 1.0 V, IOUT = 10 mA 1.5 V ≤ VOUT(S) ≤ 3.5 V VIN ≥ VOUT(S) + 1.0 V 1.0 V ≤ VOUT(S) < 1.1 V 1.1 V ≤ VOUT(S) < 1.2 V 1.2 V ≤ VOUT(S) < 1.3 V 1.3 V ≤ VOUT(S) < 1.4 V 1.4 V ≤ VOUT(S) < 1.5 V 1.5 V ≤ VOUT(S) < 1.7 V 1.7 V ≤ VOUT(S) < 1.8 V 1.8 V ≤ VOUT(S) < 2.0 V 2.0 V ≤ VOUT(S) < 2.5 V 2.5 V ≤ VOUT(S) < 2.8 V 2.8 V ≤ VOUT(S) < 3.0 V 3.0 V ≤ VOUT(S) ≤ 3.5 V (Ta = +25°C unless otherwise specified) Test Min. Typ. Max. Unit Circuit VOUT(S) VOUT(S) VOUT(S) V 1 − 0.015 + 0.015 VOUT(S) VOUT(S) VOUT(S) V 1 × 0.99 × 1.01 *5 100 − − mA 3 0.50 − − V 1 0.40 − − V 1 0.30 − − V 1 0.20 − − V 1 0.10 − − V 1 − 0.050 0.080 V 1 − 0.040 0.060 V 1 − 0.040 0.050 V 1 − 0.030 0.040 V 1 − 0.020 0.030 V 1 − 0.019 0.021 V 1 − 0.018 0.020 V 1 Dropout voltage*3 Vdrop IOUT = 10 mA Line regulation ΔVOUT1 ΔVIN•VOUT VOUT(S) + 0.5 V ≤ VIN ≤ 5.5 V, IOUT = 10 mA − 0.05 0.2 %/V 1 ΔVOUT2 ΔVOUT ΔTa•VOUT VIN = VOUT(S) + 1.0 V, 1 μA ≤ IOUT ≤ 50 mA VIN = VOUT(S) + 1.0 V, IOUT = 10 mA, −40°C ≤ Ta ≤ +85°C − 20 40 mV 1 − ±130 − ppm/°C 1 ISS1 VIN = VOUT(S) + 1.0 V, no load − 0.35 0.53 μA 2 1.5 − 5.5 V − − 60 − mA 3 Load regulation Output voltage temperature coefficient*4 Current consumption during operation Input voltage VIN Short-circuit current Ishort − VIN = VOUT(S) + 1.0 V, VOUT = 0 V *1. VOUT(S): Set output voltage VOUT(E): Actual output voltage Output voltage when fixing IOUT (= 10 mA) and inputting VOUT(S) + 1.0 V *2. The output current at which the output voltage becomes 95% of VOUT(E) after gradually increasing the output current. *3. Vdrop = VIN1 − (VOUT3 × 0.98) VIN1 is the input voltage at which the output voltage becomes 98% of VOUT3 after gradually decreasing the input voltage. VOUT3 is the output voltage when VIN = VOUT(S) + 1.0 V and IOUT = 10 mA. *4. A change in the temperature of the output voltage [mV/°C] is calculated using the following equation. ΔVOUT ΔVOUT [mV/°C]*1 = VOUT(S) [V]*2 × ΔTa•V [ppm/°C]*3 ÷ 1000 ΔTa OUT *1. Change in temperature of output voltage *2. Set output voltage *3. Output voltage temperature coefficient *5. Due to limitation of the power dissipation, this value may not be satisfied. Attention should be paid to the power dissipation when the output current is large. This specification is guaranteed by design. 9 5.5 V INPUT, 100 mA VOLTAGE REGULATOR WITH SUPPLY VOLTAGE DIVIDED OUTPUT Rev.1.3_00 S-1740/1741 Series 2. Supply voltage divider block Table 15 Item Symbol Output voltage*1 VPMOUT(S) Load current Output offset voltage Output impedance IPMOUT VPOF RPS Set-up time tPU Current consumption *2 during operation Input voltage VIN PMEN pin input voltage "H" VPSH PMEN pin input voltage "L" VPSL PMEN pin input current "H" PMEN pin input current "L" IPSH IPSL Discharge shunt resistance during power-off RPLOW ISS1P Condition (Ta = +25°C unless otherwise specified) Test Min. Typ. Max. Unit Circuit S-1740 Series VIN = 3.6 V, −10 μA ≤ IPMOUT ≤ 10 μA S-1741 Series VIN = 3.6 V VIN = 3.6 V, −10 μA ≤ IPMOUT ≤ 10 μA VIN = 3.6 V, −10 μA ≤ IPMOUT ≤ 10 μA S-1740/1741 Series A / C type, VIN = 3.6 V, CPM = 220 nF, no load VIN = 3.6 V, when supply voltage divided output is enabled, no load − VIN = 3.6 V, determined by VPMOUT output level VIN = 3.6 V, determined by S-1740/1741 Series A / C type VPMOUT output level VIN = 3.6 V, VPMEN = VIN VIN = 3.6 V, VPMEN = 0 V S-1740/1741 Series A / C type, VIN = 3.6 V, when supply voltage divided output is disabled, VPMOUT = 0.1 V − − −10 −30 − VIN/2 VIN/3 − − − − − 10 30 1000 V V μA mV Ω 4 4 − 4 4 − 5 10 ms 4 − 0.15 0.23 μA 5 1.5 − 5.5 V − 1.0 − − V 6 − − 0.25 V 6 −0.1 −0.1 − − 0.1 0.1 μA μA 6 6 − 2.8 − kΩ 7 *1. VPMOUT(S): Set output voltage VPMOUT(S) + VPOF: Actual output voltage *2. Increased current value from the current consumption during operation (ISS1) of the regulator block when the supply voltage divided output is enabled. 10 5.5 V INPUT, 100 mA VOLTAGE REGULATOR WITH SUPPLY VOLTAGE DIVIDED OUTPUT Rev.1.3_00 S-1740/1741 Series  Test Circuits + VOUT VIN PMEN *1 PMOUT V VSS A + Set to Disable Figure 6 + A Test Circuit 1 VOUT VIN PMEN*1 PMOUT VSS Set to Disable Figure 7 Test Circuit 2 VOUT VIN PMEN *1 + A PMOUT V + VSS Set to Disable Figure 8 Test Circuit 3 VIN PMEN VOUT *1 VSS Set to Enable Figure 9 + A V A + Test Circuit 4 VIN PMEN + PMOUT VOUT *1 PMOUT VSS Set to Enable Figure 10 *1. Test Circuit 5 Only S-1740/1741 Series A / C type 11 5.5 V INPUT, 100 mA VOLTAGE REGULATOR WITH SUPPLY VOLTAGE DIVIDED OUTPUT Rev.1.3_00 S-1740/1741 Series VOUT VIN + A PMEN *1 PMOUT VSS Figure 11 V + Test Circuit 6 VOUT VIN PMEN *1 + PMOUT A VSS V Set to Enable Figure 12 *1. + Test Circuit 7 Only S-1740/1741 Series A / C type  Standard Circuit Input CIN *1 Output for regulator block VOUT VIN CL *4 PMEN PMOUT VSS *2 CPM Single GND *3 Output for supply voltage divider block GND *1. CIN is a capacitor for stabilizing the input. *2. CL is a capacitor for stabilizing the output. *3. CPM is a capacitor for stabilizing the output. *4. Only S-1740/1741 Series A / C type Figure 13 Caution 12 The above connection diagram and constants will not guarantee successful operation. Perform thorough evaluation including the temperature characteristics with an actual application to set the constants. 5.5 V INPUT, 100 mA VOLTAGE REGULATOR WITH SUPPLY VOLTAGE DIVIDED OUTPUT Rev.1.3_00 S-1740/1741 Series  Condition of Application Input capacitor (CIN): Output capacitor (CL): Output capacitor (CPM): Caution A ceramic capacitor with capacitance of 1.0 μF or more is recommended. A ceramic capacitor with capacitance of 1.0 μF to 100 μF is recommended. A ceramic capacitor with capacitance of 100 nF to 220 nF is recommended. Generally, in a voltage regulator, an oscillation may occur depending on the selection of the external parts. Perform thorough evaluation including the temperature characteristics with an actual application using the above capacitors to confirm no oscillation occurs.  Selection of Regulator Block Input Capacitor (CIN) and Output Capacitor (CL) The S-1740/1741 Series requires CL between the VOUT pin and the VSS pin for regulator phase compensation. The operation is stabilized by a ceramic capacitor with capacitance of 1.0 μF to 100 μF. When using an OS capacitor, a tantalum capacitor or an aluminum electrolytic capacitor, the capacitance must also be 1.0 μF to 100 μF. However, an oscillation may occur depending on the equivalent series resistance (ESR). Moreover, the S-1740/1741 Series requires CIN between the VIN pin and the VSS pin for a stable operation. Generally, an oscillaiton may occur when a voltage regulator is used under the conditon that the impedance of the power supply is high. Note that the output voltage transient characteristics vary depending on the capacitance of CIN and CL and the value of ESR. Caution Perform thorough evaluation including the temperature characteristics with an actual application to select CIN, CL.  Selection of Supply Voltage Divider Block Output Capacitor (CPM) The S-1740/1741 Series requires CPM between the PMOUT pin and the VSS pin for supply voltage divider phase compensation. The operation is stabilized by a ceramic capacitor with capacitance of 100 nF to 220 nF. When using an OS capacitor, a tantalum capacitor or an aluminum electrolytic capacitor, the capacitance must also be 100 nF to 220 nF. However, an oscillation may occur depending on ESR. Note that the output voltage transient characteristics vary depending on the capacitance of CPM and the value of ESR. Caution Perform thorough evaluation including the temperature characteristics with an actual application to select CPM. 13 5.5 V INPUT, 100 mA VOLTAGE REGULATOR WITH SUPPLY VOLTAGE DIVIDED OUTPUT Rev.1.3_00 S-1740/1741 Series  Explanation of Terms 1. Regulator block 1. 1 Output voltage (VOUT) This voltage is output at an accuracy of ±1.0% or ±15 mV*2 when the input voltage, the output current and the temperature are in a certain condition*1. *1. *2. Differs depending on the product. When VOUT < 1.5 V: ±15 mV, when VOUT ≥ 1.5 V: ±1.0% Caution 1. 2 If the certain condition is not satisfied, the output voltage may exceed the accuracy range of ±1.0% or ±15 mV. Refer to Table 14 in " Electrical Characteristics" for details. Line regulation  ΔVOUT1  ΔVIN•VOUT  Indicates the dependency of the output voltage against the input voltage. The value shows how much the output voltage changes due to a change in the input voltage after fixing output current constant. 1. 3 Load regulation (ΔVOUT2) Indicates the dependency of the output voltage against the output current. The value shows how much the output voltage changes due to a change in the output current after fixing input voltage constant. 1. 4 Dropout voltage (Vdrop) Indicates the difference between input voltage (VIN1) and the output voltage when the output voltage becomes 98% of the output voltage value (VOUT3) at VIN = VOUT(S) + 1.0 V after the input voltage (VIN) is decreased gradually. Vdrop = VIN1 − (VOUT3 × 0.98) 14 5.5 V INPUT, 100 mA VOLTAGE REGULATOR WITH SUPPLY VOLTAGE DIVIDED OUTPUT Rev.1.3_00 S-1740/1741 Series 1. 5 Output voltage temperature coefficient  ΔVOUT  ΔTa•VOUT  The shaded area in Figure 14 is the range where VOUT varies in the operation temperature range when the output voltage temperature coefficient is ±130 ppm/°C. Example of S-1740/1741A10 typ. product VOUT [V] +0.13 mV/°C *1 VOUT(E) −0.13 mV/°C −40 *1. +25 +85 Ta [°C] VOUT(E) is the value of the output voltage measured at Ta = +25°C. Figure 14 A change in the temperature of the output voltage [mV/°C] is calculated using the following equation. ΔVOUT ΔVOUT [mV/°C]*1 = VOUT(S) [V]*2 × ΔTa•V [ppm/°C]*3 ÷ 1000 ΔTa OUT *1. Change in temperature of output voltage *2. Set output voltage *3. Output voltage temperature coefficient 15 5.5 V INPUT, 100 mA VOLTAGE REGULATOR WITH SUPPLY VOLTAGE DIVIDED OUTPUT Rev.1.3_00 S-1740/1741 Series 2. Supply voltage divider block 2. 1 Supply voltage divided output This is a function that divides the input voltage (VIN) of the regulator into VIN/2 or VIN/3 and outputs the voltage. For example, a microcontroller can monitor a battery voltage by inputting output voltage (VPMOUT) to the microcontroller A/D converter. 2. 2 Output voltage (VPMOUT) This is the voltage of the divided VIN, which is VIN/2 in the S-1740 Series and VIN/3 in the S-1741 Series. 2. 3 Output offset voltage (VPOF) This is the supply voltage divider block offset voltage when VIN, the load current and the temperature are in a certain condition. Caution If the certain condition is not satisfied, the output voltage may exceed the accuracy range of ±30 mV. Refer to " Electrical Characteristics" for details. 2. 4 Output impedance (RPS) This is the supply voltage divider block impedance. It shows how much VPMOUT changes when the load current changes. For example, the output impedance can be used in sampling rate calculation as signal source impedance when VPMOUT from the PMOUT pin is input to the A/D converter as a microcontroller input signal. 2. 5 Set-up time (tPU) (S-1740/1741 Series A / C type) This is the time from when the supply voltage divided output is enabled until VPMOUT stabilizes. VPMOUT, VPOF and RPS are not guaranteed until the set-up time elapses. 2. 6 Discharge shunt resistance during power-off (RPLOW) (S-1740/1741 Series A / C type) The ON resistance of the N-channel transistor built into the supply voltage divider block. When the supply voltage divided output is disabled, VPMOUT is set to the VSS level by the built-in N-channel transistor. 16 5.5 V INPUT, 100 mA VOLTAGE REGULATOR WITH SUPPLY VOLTAGE DIVIDED OUTPUT Rev.1.3_00 S-1740/1741 Series  Operation 1. Regulator block 1. 1 Basic operation Figure 15 shows the block diagram of the regulator block to describe the basic operation. The error amplifier compares the feedback voltage (Vfb) whose output voltage (VOUT) is divided by the feedback resistors (Rs and Rf) with the reference voltage (Vref). The error amplifier controls the output transistor, consequently, the regulator starts the operation that holds VOUT constant without the influence of the input voltage (VIN). VIN *1 Current Supply Error amplifier Vref VOUT − Rf + Vfb Reference voltage circuit Rs VSS *1. Parasitic diode Figure 15 1. 2 Output transistor In the S-1740/1741 Series, a low on-resistance P-channel MOS FET is used between the VIN pin and the VOUT pin as the output transistor. In order to keep VOUT constant, the ON resistance of the output transistor varies appropriately according to the output current (IOUT). Caution Since a parasitic diode exists between the VIN pin and the VOUT pin due to the structure of the transistor, the IC may be damaged by a reverse current if VOUT becomes higher than VIN. Therefore, be sure that VOUT does not exceed VIN + 0.3 V. 1. 3 Overcurrent protection circuit The S-1740/1741 Series has a built-in overcurrent protection circuit to limit the overcurrent of the output transistor. When the VOUT pin is shorted to the VSS pin, that is, at the time of the output short-circuit, the output current is limited to 60 mA typ. due to the overcurrent protection circuit operation. The S-1740/1741 Series restarts regulating when the output transistor is released from the overcurrent status. Caution This overcurrent protection circuit does not work as for thermal protection. For example, when the output transistor keeps the overcurrent status long at the time of output shortcircuit or due to other reasons, pay attention to the conditions of the input voltage and the load current so as not to exceed the power dissipation. 17 5.5 V INPUT, 100 mA VOLTAGE REGULATOR WITH SUPPLY VOLTAGE DIVIDED OUTPUT Rev.1.3_00 S-1740/1741 Series 2. Supply voltage divider block 2. 1 Basic operation 2. 1. 1 S-1740/1741 Series A / C type Figure 16 shows the block diagram of the S-1740/1741 Series A / C type to describe basic operation. Reference voltage (Vrefpm) is generated by dividing the input voltage (VIN) to VIN/2 or VIN/3 using the dividing resistance (Rpm1 and Rpm2). Since the buffer amplifier constitutes a voltage follower, it can perform the feedback control so that the output voltage (VPMOUT) and Vrefpm are the same. Low output impedance is realized by the buffer amplifier, while outputting VPMOUT according to VIN. When "L" is input to the PMEN pin in the S-1740/1741 Series A type, or "H" is input to the PMEN pin in the C type, the current which flows to Rpm1 and Rpm2 and the current which flows to the buffer amplifier can be stopped. The buffer amplifier output is pulled down to VSS by the built-in N-channel transistor, and VPMOUT is set to the VSS level. VIN SW Rpm1 Buffer amplifier Vrefpm + − Rpm2 PMOUT Enable circuit PMEN VSS Figure 16 2. 1. 2 S-1740/1741 Series G type Figure 17 shows the block diagram of the S-1740/1741 Series G type to describe basic operation. Vrefpm is made by dividing VIN to VIN/2 or VIN/3 using Rpm1 and Rpm2. Since the buffer amplifier constitutes a voltage follower, it can perform the feedback control so that VPMOUT and Vrefpm are the same. Low output impedance is realized by the buffer amplifier, while outputting VPMOUT according to VIN. VIN Rpm1 Vrefpm Buffer amplifier − Rpm2 VSS Figure 17 18 + PMOUT 5.5 V INPUT, 100 mA VOLTAGE REGULATOR WITH SUPPLY VOLTAGE DIVIDED OUTPUT Rev.1.3_00 S-1740/1741 Series 2. 2 PMEN pin 2. 2. 1 S-1740/1741 Series A / C type The PMEN pin controls the enable circuit. When "H" is input to the PMEN pin in the S-1740/1741 Series A type, or "L" is input to the PMEN pin in the C type, the enable circuit operates. This enables the supply voltage divided output and allows for monitoring of the power supply voltage. When "L" is input to the PMEN pin in the S-1740/1741 Series A type, or "H" is input to the PMEN pin in the C type, the enable circuit stops. This disables the supply voltage divided output, reducing the IC current consumption. In addition, the PMEN pin has absolutely no effect on the operation of the regulator block. Table 16 Product Type *1. PMEN Pin Supply Voltage Divided Output A "H" Enable A "L" Disable C "L" Enable C "H" Disable Refer to *1 in Table 15 in " Electrical Characteristics". Output Voltage (VPMOUT) VPMOUT*1 VSS level VPMOUT*1 VSS level Current Consumption ISS1 + ISS1P ISS1 ISS1 + ISS1P ISS1 VOUT Pin Voltage VOUT VOUT VOUT VOUT Figure 18 shows the internal equivalent circuit structure in relation to the PMEN pin. The PMEN pin is neither pulled up nor pulled down, so do not use it in the floating status. When not using the PMEN pin, connect it to the VIN pin. Note that the current consumption increases when a voltage of 0.25 V to VIN − 0.3 V is applied to the PMEN pin. VIN PMEN VSS Figure 18 19 5.5 V INPUT, 100 mA VOLTAGE REGULATOR WITH SUPPLY VOLTAGE DIVIDED OUTPUT Rev.1.3_00 S-1740/1741 Series 2. 3 PMEN pin voltage and output voltage (VPMOUT) 2. 3. 1 S-1740/1741 Series A / C type Figure 19 shows the relation between the PMEN pin voltage and the supply voltage divided output. When "H" is input to the PMEN pin in the S-1740/1741 Series A type, or "L" is input to the PMEN pin in the C type, the supply voltage divided output is enabled. Once set-up time (tPU) = 10 ms max.*1 elapses, the output voltage (VPMOUT) will settle and the power supply voltage can be monitored. When "L" is input to the PMEN pin in the S-1740/1741 Series A type, or "H" is input to the PMEN pin in the C type, the supply voltage divided output is disabled. VPMOUT is set to the VSS level by the built-in N-channel transistor. By inputting "H" and "L" alternately to the PMEN pin, allowing for minimization of current consumption during the period when the power supply voltage is not monitored. *1. When Ta = +25°C, VIN = 3.6 V, CPM = 220 nF, no load Example of active "H" VPMEN tPU tPU VPMOUT(S) + VPOF VPMOUT Figure 19 Remark 20 VPMEN = VIN ↔ VSS VPMOUT(S) + VPOF 5.5 V INPUT, 100 mA VOLTAGE REGULATOR WITH SUPPLY VOLTAGE DIVIDED OUTPUT Rev.1.3_00 S-1740/1741 Series  Typical Application in S-1740/1741 Series A / C Type Figure 20 shows the circuit diagram of the typical application in the S-1740/1741 Series A / C type, and Figure 21 shows the timing chart. As shown in Figure 20, connect the PMOUT pin to an analog input pin (AIN pin) of the A/D converter in the microcontroller. The microcontroller can monitor the battery voltage by inputting the output voltage (VPMOUT) to the A/D converter. The input voltage from the battery is converted to output voltage by the regulator operation, and the microcontroller starts driving with the voltage. The supply voltage divided output can be controlled by inputting "H" and "L" signals output from the microcontroller I/O pin to the PMEN pin. Control the supply voltage divided output according to the A/D converter operation timing. When inputting "H" to the PMEN pin in the S-1740/1741 Series A type, or "L" to the PMEN pin in the C type, the microcontroller monitors the battery voltage. The IC current consumption can be minimized by inputting "L" to the PMEN pin in the S-1740/1741 Series A type, or "H" to the PMEN pin in the C type when battery voltage is not monitored. S-1740/1741 Series A / C type Microcontroller VDD VOUT VIN CL Battery PMOUT PMEN CIN A/D converter AIN VSS CPM I/O VSS Figure 20 Example of active "H" VPMEN tPU tPU tPU VPMOUT(S) + VPOF VPMOUT Voltage monitoring timing Figure 21 21 5.5 V INPUT, 100 mA VOLTAGE REGULATOR WITH SUPPLY VOLTAGE DIVIDED OUTPUT Rev.1.3_00 S-1740/1741 Series  Precautions • Generally, when a voltage regulator is used under the condition that the load current value is small (1.0 μA or less), the output voltage may increase due to the leakage current of an output transistor. • Generally, when a voltage regulator is used under the condition that the temperature is high, the output voltage may increase due to the leakage current of an output transistor. • Generally, when a voltage regulator is used under the condition that the impedance of the power supply is high, an oscillation may occur. Perform thorough evaluation including the temperature characteristics with an actual application to select CIN. • Generally, in a voltage regulator, an oscillation may occur depending on the selection of the external parts. The following use conditions are recommended in the S-1740/1741 Series, however, perform thorough evaluation including the temperature characteristics with an actual application to select CIN, CL and CPM. Input capacitor (CIN): Output capacitor (CL): Output capacitor (CPM): A ceramic capacitor with capacitance of 1.0 μF or more is recommended. A ceramic capacitor with capacitance of 1.0 μF to 100 μF is recommended. A ceramic capacitor with capacitance of 100 nF to 220 nF is recommended. • Generally, in a voltage regulator, the values of an overshoot and an undershoot in the output voltage vary depending on the variation factors of input voltage start-up, input voltage fluctuation and load fluctuation etc., or the capacitance of CIN, CL or CPM and the value of the equivalent series resistance (ESR), which may cause a problem to the stable operation. Perform thorough evaluation including the temperature characteristics with an actual application to select CIN, CL and CPM. • Generally, in a voltage regulator, if the VOUT pin is steeply shorted with GND, a negative voltage exceeding the absolute maximum ratings may occur in the VOUT pin due to resonance phenomenon of the inductance and the capacitance including CL on the application. The resonance phenomenon is expected to be weakened by inserting a series resistor into the resonance path, and the negative voltage is expected to be limited by inserting a protection diode between the VOUT pin and the VSS pin. • Make sure of the conditions for the input voltage, output voltage and the load current so that the internal loss does not exceed the power dissipation. • Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit. • When considering the output current value that the IC is able to output, make sure of the output current value specified in Table 14 in " Electrical Characteristics" and footnote *5 of the table. • Wiring patterns on the application related to the VIN pin, the VOUT pin and the VSS pin should be designed so that the impedance is low. When mounting CIN between the VIN pin and the VSS pin and CL between the VOUT pin and the VSS pin, connect the capacitors as close as possible to the respective destination pins of the IC. • In the package equipped with heat sink of backside, mount the heat sink firmly. Since the heat radiation differs according to the condition of the application, perform thorough evaluation with an actual application to confirm no problems happen. • ABLIC Inc. claims no responsibility for any disputes arising out of or in connection with any infringement by products including this IC of patents owned by a third party. 22 5.5 V INPUT, 100 mA VOLTAGE REGULATOR WITH SUPPLY VOLTAGE DIVIDED OUTPUT Rev.1.3_00 S-1740/1741 Series  Characteristics (Typical Data) 1. Regulator block 1. 1 Output voltage vs. Output current (When load current increases) (Ta = +25°C) 1. 1. 1 VOUT = 1.0 V 1. 1. 2 1.2 3.0 2.5 VIN = 1.3 V VIN = 1.5 V VIN = 2.0 V VIN = 3.0 V VIN = 5.5 V 0.8 0.6 0.4 VOUT [V] VOUT [V] 1.0 0.2 VOUT [V] 100 4.0 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0.0 200 300 IOUT [mA] 400 0 500 100 200 300 IOUT [mA] 400 500 VIN = 3.8 V VIN = 4.0 V VIN = 4.5 V VIN = 5.5 V 100 200 300 IOUT [mA] 400 Remark In determining the output current, attention should be paid to the following. 1. The minimum output current value and footnote *5 of Table 14 in " Electrical Characteristics" 2. Power dissipation 500 Output voltage vs. Input voltage (Ta = +25°C) 1. 2. 1 VOUT = 1.0 V 1. 2. 2 1.2 1.1 1.0 0.9 VOUT [V] VOUT [V] 1.0 VOUT = 3.5 V 0 IOUT = 1 mA IOUT = 10 mA IOUT = 50 mA IOUT = 100 mA 0.8 0.7 0.6 0.6 1. 2. 3 VOUT [V] 1.5 0.0 0 1. 2 VIN = 2.8 V VIN = 3.0 V VIN = 3.5 V VIN = 4.5 V VIN = 5.5 V 2.0 0.5 0.0 1. 1. 3 VOUT = 2.5 V 1.0 1.4 1.8 VIN [V] 2.2 2.6 5.0 5.5 VOUT = 2.5 V 2.7 2.6 2.5 2.4 2.3 2.2 2.1 2.0 IOUT = 1 mA IOUT = 10 mA IOUT = 50 mA IOUT = 100 mA 2.0 2.5 3.0 3.5 VIN [V] 4.0 4.5 VOUT = 3.5 V 3.7 3.6 3.5 3.4 3.3 3.2 3.1 3.0 IOUT = 1 mA IOUT = 10 mA IOUT = 50 mA IOUT = 100 mA 3.0 3.5 4.0 4.5 VIN [V] 23 5.5 V INPUT, 100 mA VOLTAGE REGULATOR WITH SUPPLY VOLTAGE DIVIDED OUTPUT Rev.1.3_00 S-1740/1741 Series 1. 3 Dropout voltage vs. Output current 1. 3. 1 VOUT = 1.0 V 1. 3. 2 1.2 Vdrop [V] 0.8 Vdrop [V] Ta = +85C Ta = +25C Ta = 40C 1.0 0.6 0.4 0.2 0.0 Vdrop [V] 1. 3. 3 1. 4 0.40 0.35 0.30 0.25 0.20 0.15 0.10 0.05 0.00 0 20 40 60 IOUT [mA] 80 100 80 100 VOUT = 3.5 V Ta = +85C Ta = +25C Ta = 40C 0 20 40 60 IOUT [mA] Dropout voltage vs. Set output voltage 1.2 Vdrop [V] 1.0 0.8 0.6 0.4 IOUT = 0.1 mA IOUT = 1 mA IOUT = 10 mA IOUT = 50 mA IOUT = 100 mA 0.2 0.0 24 1.0 1.5 2.0 2.5 VOUT(S) [V] 3.0 3.5 VOUT = 2.5 V 0.40 0.35 0.30 0.25 0.20 0.15 0.10 0.05 0.00 Ta = +85C Ta = +25C Ta = 40C 0 20 40 60 IOUT [mA] 80 100 5.5 V INPUT, 100 mA VOLTAGE REGULATOR WITH SUPPLY VOLTAGE DIVIDED OUTPUT Rev.1.3_00 S-1740/1741 Series Output voltage vs. Ambient temperature VOUT [V] 1. 5. 1 VOUT = 1.0 V 1. 5. 2 VOUT = 2.5 V 1.10 2.70 1.05 2.60 VOUT [V] 1. 5 1.00 0.95 0.90 1. 5. 3 2.50 2.40 −40 −25 0 25 Ta [°C] 50 75 85 0 25 Ta [°C] 50 75 85 2.30 −40 −25 0 25 Ta [°C] 50 75 85 VOUT = 3.5 V 3.80 VOUT [V] 3.70 3.60 3.50 3.40 3.30 3.20 Current consumption vs. Input voltage ISS1 [A] 1. 6. 1 VOUT = 1.0 V 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0.0 Ta = +85C Ta = +25C Ta = 40C 0.0 ISS1 [A] 1. 6. 3 1. 6. 2 ISS1 [A] 1. 6 −40 −25 1.0 2.0 3.0 4.0 VIN [V] 5.0 6.0 5.0 6.0 VOUT = 2.5 V 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0.0 Ta = +85C Ta = +25C Ta = 40C 0.0 1.0 2.0 3.0 4.0 VIN [V] 5.0 6.0 VOUT = 3.5 V 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0.0 Ta = +85C Ta = +25C Ta = 40C 0.0 1.0 2.0 3.0 4.0 VIN [V] 25 5.5 V INPUT, 100 mA VOLTAGE REGULATOR WITH SUPPLY VOLTAGE DIVIDED OUTPUT Rev.1.3_00 S-1740/1741 Series Current consumption vs. Ambient temperature 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0.0 ISS1 [A] 1. 7. 3 1. 8 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0.0 ISS1 [A] 40 35 30 25 20 15 10 5 0 1. 8. 3 ISS1 [A] 1. 7. 2 VIN = 2.0 V VIN = 5.5 V −40 −25 0 25 Ta [C] 50 VOUT = 2.5 V 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0.0 75 85 VIN = 3.5 V VIN = 5.5 V −40 −25 0 25 Ta [C] 50 75 85 VOUT = 3.5 V VIN = 4.5 V VIN = 5.5 V −40 −25 0 25 Ta [C] 50 75 85 Current consumption vs. Output current 1. 8. 1 26 VOUT = 1.0 V ISS1 [A] ISS1 [A] 1. 7. 1 40 35 30 25 20 15 10 5 0 VOUT = 1.0 V 1. 8. 2 ISS1 [A] 1. 7 VIN = 2.0 V VIN = 5.5 V 0 20 40 60 IOUT [mA] 80 100 VOUT = 3.5 V VIN = 4.5 V VIN = 5.5 V 0 20 40 60 IOUT [mA] 80 100 VOUT = 2.5 V 40 35 30 25 20 15 10 5 0 VIN = 3.5 V VIN = 5.5 V 0 20 40 60 IOUT [mA] 80 100 5.5 V INPUT, 100 mA VOLTAGE REGULATOR WITH SUPPLY VOLTAGE DIVIDED OUTPUT Rev.1.3_00 S-1740/1741 Series Supply voltage divider block 2. 1 Output voltage vs. Load current VPMOUT [V] 2. 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0.0 VPMOUT = VIN/2, VIN = 3.6 V VPMOUT = VIN/3, VIN = 3.6 V VPMOUT [V] Ta = 85C Ta = 25C Ta = 40C 10 5 5 10 2. 2 Output voltage vs. Input voltage (Ta = +25°C) VPMOUT [V] 0 IPMOUT [A] 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0.0 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0.0 Ta = 85C Ta = 25C Ta = 40C 10 5 0 IPMOUT [A] VPMOUT = VIN/2 IPMOUT = 10 A 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 VIN [V] 2. 3 IPMOUT = 0 A IPMOUT = 10 A IPMOUT = 10 A 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 VIN [V] Output voltage vs. Ambient temperature VPMOUT = VIN/2 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0.0 IPMOUT = 10 A IPMOUT = 0 A IPMOUT = 10 A 40 25 0 VPMOUT = VIN/3 VPMOUT [V] VPMOUT [V] 10 VPMOUT = VIN/3 VPMOUT [V] IPMOUT = 0 A IPMOUT = 10 A 5 25 Ta [C] 50 75 85 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0.0 IPMOUT = 10 A IPMOUT = 0 A IPMOUT = 10 A 40 25 0 25 Ta [C] 50 75 85 27 5.5 V INPUT, 100 mA VOLTAGE REGULATOR WITH SUPPLY VOLTAGE DIVIDED OUTPUT Rev.1.3_00 S-1740/1741 Series  Reference Data Characteristics of input transient response (Ta = +25°C) VIN [V] VIN [V] IOUT = 50 mA, CIN = CL = 1 μF, VIN = 3.5 V ↔ 4.5 V, tr = tf = 5.0 μs 3.0 5.5 2.9 5.0 2.8 4.5 2.7 VIN 4.0 2.6 3.5 2.5 3.0 2.4 VOUT 2.5 2.3 2.0 1.5 2.2 −200 0 200 400 600 800 1000 1200 t [s] VIN [V] VIN [V] VOUT [V] VOUT = 3.5 V IOUT = 1 mA, CIN = CL = 1 μF, VIN = 4.5 V ↔ 5.5 V, tr = tf = 5.0 μs 4.0 6.5 3.9 6.0 3.8 5.5 3.7 5.0 VIN 3.6 4.5 3.5 4.0 3.4 VOUT 3.5 3.3 3.0 2.5 3.2 −200 0 200 400 600 800 1000 1200 t [s] IOUT = 50 mA, CIN = CL = 1 μF, VIN = 4.5 V ↔ 5.5 V, tr = tf = 5.0 μs 4.0 6.5 3.9 6.0 3.8 5.5 3.7 5.0 VIN 3.6 4.5 3.5 4.0 3.4 VOUT 3.5 3.3 3.0 2.5 3.2 −200 0 200 400 600 800 1000 1200 t [s] VIN [V] VOUT [V] VOUT [V] IOUT = 50 mA, CIN = CL = 1 μF, VIN = 2.0 V ↔ 3.0 V, tr = tf = 5.0 μs 1.5 4.0 1.4 3.5 1.3 3.0 1.2 VIN 2.5 1.1 2.0 1.0 1.5 0.9 VOUT 1.0 0.8 0.5 0.0 0.7 −200 0 200 400 600 800 1000 1200 t [s] VOUT = 2.5 V IOUT = 1 mA, CIN = CL = 1 μF, VIN = 3.5 V ↔ 4.5 V, tr = tf = 5.0 μs 3.0 5.5 2.9 5.0 2.8 4.5 2.7 VIN 4.0 2.6 3.5 2.5 3.0 2.4 VOUT 2.5 2.3 2.0 1.5 2.2 −200 0 200 400 600 800 1000 1200 t [s] 1. 3 VOUT [V] IOUT = 1 mA, CIN = CL = 1 μF, VIN = 2.0 V ↔ 3.0 V, tr = tf = 5.0 μs 1.5 4.0 1.4 3.5 1.3 3.0 1.2 VIN 2.5 1.1 2.0 1.0 1.5 VOUT 0.9 1.0 0.8 0.5 0.0 0.7 −200 0 200 400 600 800 1000 1200 t [s] 1. 2 28 VOUT = 1.0 V VIN [V] VOUT [V] 1. 1 VOUT [V] 1. 5.5 V INPUT, 100 mA VOLTAGE REGULATOR WITH SUPPLY VOLTAGE DIVIDED OUTPUT Rev.1.3_00 S-1740/1741 Series Characteristics of load transient response (Ta = +25°C) IOUT [mA] VIN = 3.5 V, CIN = CL = 1 μF, IOUT = 10 mA ↔ 50 mA, tr = tf = 5.0 μs 3.0 75 50 2.9 25 2.8 0 2.7 IOUT 25 2.6 50 2.5 75 2.4 VOUT 100 2.3 125 2.2 100 0 100 200 300 400 500 600 t [s] IOUT [mA] VOUT [V] IOUT [mA] VOUT = 3.5 V VIN = 4.5 V, CIN = CL = 1 μF, IOUT = 1 mA ↔ 10 mA, tr = tf = 5.0 μs 4.0 75 3.9 50 3.8 25 3.7 0 IOUT −25 3.6 −50 3.5 3.4 VOUT −75 3.3 −100 −125 3.2 −400 0 400 800 1200 1600 2000 2400 t [s] VIN = 4.5 V, CIN = CL = 1 μF, IOUT = 10 mA ↔ 50 mA, tr = tf = 5.0 μs 4.0 75 50 3.9 25 3.8 0 3.7 IOUT −25 3.6 −50 3.5 −75 3.4 VOUT −100 3.3 −125 3.2 −800 0 800 1600 2400 3200 4000 4800 t [s] IOUT [mA] VOUT [V] VIN = 2.0 V, CIN = CL = 1 μF, IOUT = 10 mA ↔ 50 mA, tr = tf = 5.0 μs 1.5 75 1.4 50 1.3 25 1.2 IOUT 0 25 1.1 50 1.0 0.9 VOUT 75 0.8 100 125 0.7 200 0 200 400 600 800 1000 1200 t [s] VOUT = 2.5 V VIN = 3.5 V, CIN = CL = 1 μF, IOUT = 1 mA ↔ 10 mA, tr = tf = 5.0 μs 3.0 75 2.9 50 2.8 25 2.7 0 IOUT 25 2.6 50 2.5 VOUT 2.4 75 2.3 100 125 2.2 100 0 100 200 300 400 500 600 t [s] 2. 3 VOUT [V] IOUT [mA] VIN = 2.0 V, CIN = CL = 1 μF, IOUT = 1 mA ↔ 10 mA, tr = tf = 5.0 μs 1.5 75 1.4 50 1.3 25 1.2 0 IOUT 1.1 25 1.0 50 VOUT 0.9 75 0.8 100 125 0.7 200 0 200 400 600 800 1000 1200 t [s] 2. 2 VOUT [V] VOUT = 1.0 V IOUT [mA] VOUT [V] 2. 1 VOUT [V] 2. 29 5.5 V INPUT, 100 mA VOLTAGE REGULATOR WITH SUPPLY VOLTAGE DIVIDED OUTPUT Rev.1.3_00 S-1740/1741 Series Transient response characteristics of PMEN pin (Ta = +25°C) VPMOUT = VIN/2 4 6 2 4 0 2 3. 2 0 VPMEN 2 2 VPMOUT 2 0 2 4 6 t [ms] 8 10 VPMEN [V] 8 VIN = 5.5 V, CPM = 220 nF, VPMEN = 0 V ↔ 5.5 V, tr = tf = 1.0 μs 10 6 VPMOUT [V] VPMOUT [V] VIN = 3.6 V, CPM = 220 nF, VPMEN = 0 V ↔ 3.6 V, tr = tf = 1.0 μs 10 6 2 2 0 VPMEN 2 4 VPMOUT 2 0 6 2 0 VPMEN 2 VPMOUT 2 0 2 4 6 t [ms] 8 10 VPMEN [V] 6 2 6 t [ms] 8 10 12 8 4 6 2 4 2 4 0 6 2 12 0 VPMEN 2 4 VPMOUT 2 0 6 2 4 6 t [ms] 8 10 12 Ripple rejection (Ta = +25°C) 4. 1 4. 2 VOUT = 1.0 V VOUT = 2.5 V 100 90 80 70 60 50 40 30 20 10 0 IOUT = 1 mA IOUT = 10 mA IOUT = 50 mA IOUT = 100 mA 10 4. 3 100 1k 10k 100k Frequency [Hz] 1M VOUT = 3.5 V Ripple Rejection [dB] VIN = 4.5 V, CL = 1.0 μF 100 90 80 70 60 50 40 30 20 10 0 IOUT = 1 mA IOUT = 10 mA IOUT = 50 mA IOUT = 100 mA 10 100 1k 10k 100k Frequency [Hz] VIN = 3.5 V, CL = 1.0 μF Ripple Rejection [dB] Ripple Rejection [dB] VIN = 2.0 V, CL = 1.0 μF 30 4 VIN = 5.5 V, CPM = 220 nF, VPMEN = 0 V ↔ 5.5 V, tr = tf = 1.0 μs 10 6 VPMOUT [V] VPMOUT [V] 4 VPMOUT = VIN/3 0 4. 2 6 12 4 2 6 0 8 2 4 4 VIN = 3.6 V, CPM = 220 nF, VPMEN = 0 V ↔ 3.6 V, tr = tf = 1.0 μs 10 6 4 8 VPMEN [V] 3. 1 1M 100 90 80 70 60 50 40 30 20 10 0 IOUT = 1 mA IOUT = 10 mA IOUT = 50 mA IOUT = 100 mA 10 100 1k 10k 100k Frequency [Hz] 1M VPMEN [V] 3. 5.5 V INPUT, 100 mA VOLTAGE REGULATOR WITH SUPPLY VOLTAGE DIVIDED OUTPUT Rev.1.3_00 S-1740/1741 Series 5. Example of equivalent series resistance vs. Output current characteristics (Ta = +25°C) CIN = CL = 1.0 μF CPM = 0.1 μF RESR [Ω] 100 RESR [Ω] 100 Stable 0 0.01 0 100 IOUT [mA] Figure 23 VIN PMEN *1. *2. VIN S-1740/1741 Series A / C type VSS 10 −10 IPMOUT [μA] Figure 22 CIN Stable PMOUT VOUT RESR CL *1 CPM*2 PMOUT S-1740/1741 Series G type VOUT CL VSS R RESR CL: TDK Corporation C3216X7R1H105K160AB CPM: TDK Corporation C2012X7R1H104K Figure 24 CIN ESR *1. *2. *1 CPM*2 RESR CL: TDK Corporation C3216X7R1H105K160AB CPM: TDK Corporation C2012X7R1H104K Figure 25 31 5.5 V INPUT, 100 mA VOLTAGE REGULATOR WITH SUPPLY VOLTAGE DIVIDED OUTPUT Rev.1.3_00 S-1740/1741 Series  Power Dissipation SOT-23-5 HSNT-6(1212) Tj = 125C max. 0.8 B 0.6 A 0.4 0.2 0.0 0 25 50 75 100 125 150 175 Tj = 125C max. 1.0 Power dissipation (PD) [W] Power dissipation (PD) [W] 1.0 0.8 0.6 B 0.4 A 0.2 0.0 0 25 Ambient temperature (Ta) [C] Board A B C D E Board A B C D E HSNT-4(1010) Tj = 125C max. Power dissipation (PD) [W] 0.8 0.6 0.4 B 0.2 A 0.0 0 25 50 75 100 125 150 Ambient temperature (Ta) [C] Board A B C D E 32 75 100 125 150 Ambient temperature (Ta) [C] Power Dissipation (PD) 0.52 W 0.63 W − − − 1.0 50 Power Dissipation (PD) 0.26 W 0.32 W − − − 175 Power Dissipation (PD) 0.43 W 0.52 W − − − 175 SOT-23-3/3S/5/6 Test Board IC Mount Area (1) Board A Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 2 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.070 - (2) Board B Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] Thermal via 1 2 3 4 Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - No. SOT23x-A-Board-SD-2.0 ABLIC Inc. HSNT-6(1212) Test Board IC Mount Area (1) Board A Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 2 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.070 - (2) Board B Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] Thermal via 1 2 3 4 Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - No. HSNT6-A-Board-SD-1.0 ABLIC Inc. HSNT-4(1010) Test Board IC Mount Area (1) Board A Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 2 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.070 - (2) Board B Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] Thermal via 1 2 3 4 Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - No. HSNT4-B-Board-SD-1.0 ABLIC Inc. 2.9±0.2 1.9±0.2 4 5 1 2 +0.1 0.16 -0.06 3 0.95±0.1 0.4±0.1 No. MP005-A-P-SD-1.3 TITLE SOT235-A-PKG Dimensions No. MP005-A-P-SD-1.3 ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches:40.0±0.2) +0.1 ø1.5 -0 +0.2 ø1.0 -0 2.0±0.05 0.25±0.1 4.0±0.1 1.4±0.2 3.2±0.2 3 2 1 4 5 Feed direction No. MP005-A-C-SD-2.1 TITLE SOT235-A-Carrier Tape No. MP005-A-C-SD-2.1 ANGLE UNIT mm ABLIC Inc. 12.5max. 9.0±0.3 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. MP005-A-R-SD-1.1 SOT235-A-Reel TITLE No. MP005-A-R-SD-1.1 ANGLE QTY. UNIT mm ABLIC Inc. 3,000 0.40 1.00±0.05 0.38±0.02 0.40 4 6 3 1 +0.05 0.08 -0.02 1.20±0.04 The heat sink of back side has different electric potential depending on the product. Confirm specifications of each product. Do not use it as the function of electrode. 0.20±0.05 No. PM006-A-P-SD-1.1 TITLE HSNT-6-B-PKG Dimensions No. PM006-A-P-SD-1.1 ANGLE UNIT mm ABLIC Inc. 2.0±0.05 +0.1 ø1.5 -0 4.0±0.1 0.25±0.05 +0.1 ø0.5 -0 0.50±0.05 4.0±0.1 1.32±0.05 3 1 4 6 Feed direction No. PM006-A-C-SD-2.0 TITLE HSNT-6-B-C a r r i e r Tape No. PM006-A-C-SD-2.0 ANGLE UNIT mm ABLIC Inc. +1.0 9.0 - 0.0 11.4±1.0 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. PM006-A-R-SD-1.0 TITLE HSNT-6-B-Reel No. PM006-A-R-SD-1.0 ANGLE UNIT QTY. mm ABLIC Inc. 5,000 1.04min. Land Pattern 0.24min. 1.02 0.40±0.02 0.40±0.02 (1.22) Caution It is recommended to solder the heat sink to a board in order to ensure the heat radiation. PKG Metal Mask Pattern Aperture ratio Aperture ratio Caution Mask aperture ratio of the lead mounting part is 100%. Mask aperture ratio of the heat sink mounting part is 40%. Mask thickness: t0.10mm to 0.12 mm 100% 40% t0.10mm ~ 0.12 mm TITLE HSNT-6-B -Land Recommendation PM006-A-L-SD-2.0 No. ANGLE No. PM006-A-L-SD-2.0 UNIT mm ABLIC Inc. 0.38±0.02 0.65 3 4 1 2 1.00±0.04 0.20±0.05 +0.05 0.08 -0.02 The heat sink of back side has different electric potential depending on the product. Confirm specifications of each product. Do not use it as the function of electrode. No. PL004-A-P-SD-1.1 TITLE HSNT-4-B-PKG Dimensions No. PL004-A-P-SD-1.1 ANGLE UNIT mm ABLIC Inc. 2.0±0.05 +0.1 ø1.5 -0 4.0±0.05 0.25±0.05 +0.1 1.12±0.05 2 1 3 4 ø0.5 -0 2.0±0.05 0.5±0.05 Feed direction No. PL004-A-C-SD-2.0 TITLE HSNT-4-B-C a r r i e r Tape No. PL004-A-C-SD-2.0 ANGLE UNIT mm ABLIC Inc. +1.0 9.0 - 0.0 11.4±1.0 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. PL004-A-R-SD-1.0 HSNT-4-B-Reel TITLE PL004-A-R-SD-1.0 No. QTY. ANGLE UNIT mm ABLIC Inc. 10,000 Land Pattern 0.30min. 0.38~0.48 0.38~0.48 0.07 0.65±0.02 (1.02) Caution It is recommended to solder the heat sink to a board in order to ensure the heat radiation. PKG Metal Mask Pattern Aperture ratio Aperture ratio Caution Mask aperture ratio of the lead mounting part is 100%. Mask aperture ratio of the heat sink mounting part is 40%. Mask thickness: t0.10mm to 0.12 mm 100% 40% t0.10mm ~ 0.12 mm TITLE No. PL004-A-L-SD-2.0 HSNT-4-B -Land Recommendation PL004-A-L-SD-2.0 No. ANGLE UNIT mm ABLIC Inc. Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-1740C10-A6T2U4
物料型号:S-1740/1741 Series
器件简介: - 这是一款使用CMOS技术开发的正电压调节器,具有分压输出功能。 - 特点包括超低电流消耗和低降额电压。 - 调节器块的典型电流消耗为0.35μA,输出电压精度为±1.0%。
引脚分配: - SOT-23-5封装:VIN(1),VSS(2),PMEN(3),PMOUT(4),VOUT(5) - HSNT-6(1212)封装:VOUT(1),VSS(2),PMOUT(3),PMEN(4),NC(5),VIN(6) - HSNT-4(1010)封装:VOUT(1),VSS(2),PMOUT(3),VIN(4)
参数特性: - 输出电压:1.0 V至3.5 V,步进0.05 V可调 - 输入电压:1.5 V至5.5 V - 输出电压精度:1.0 V至1.45 V输出产品为±15 mV,其他为±1.0% - 降额电压:典型值20 mV(2.5 V输出产品,IOUT = 10 mA,Ta = +25°C) - 工作电流:典型值0.35 μA(Ta = +25°C) - 输出电流:可达100 mA(VIN ≥ VOUT(S) + 1.0 V)
功能详解: - 具有内置的过流保护电路,限制输出晶体管的过流。 - 具有内置的使能电路,确保电池寿命。
应用信息: - 用于电池供电设备的恒压电源和电池电压监测。 - 便携式通信设备、数码相机和数字音频播放器的恒压电源。 - 家用电器的恒压电源。
封装信息: - 提供SOT-23-5、HSNT-6(1212)和HSNT-4(1010)封装。
S-1740C10-A6T2U4 价格&库存
很抱歉,暂时无法提供与“S-1740C10-A6T2U4”相匹配的价格&库存,您可以联系我们找货
S-1740C10-A6T2U4
  • 1+12.583111+1.57362
  • 10+11.2254910+1.40384
  • 25+10.6541825+1.33239
  • 100+8.75064100+1.09434
  • 250+8.17995250+1.02297
  • 500+7.22869500+0.90401
  • 1000+5.706921000+0.71370
  • 2500+5.326462500+0.66612
库存:4400
S-1740C10-A6T2U4
  • 5000+4.708685000+0.58886
库存:4400
