GVT71128D32T-5
GVT71128D32T-5
    ROCHESTER(罗切斯特)
    TQFP100
    IC SRAM 4MBIT 100MHZ
GVT71128D32T-5 数据手册
GALVANTECH, GVT71128D32 128K X 32 SYNCHRONOUS BURST SRAM SYNCHRONOUS BURST SRAM PIPELINED OUTPUT 128K x 32 SRAM +3.3V SUPPLY, PIPELINED, SINGLE CYCLE DESELECT, BURST COUNTER FEATURES GENERAL DESCRIPTION • • • • • The Galvantech Synchronous Burst SRAM family employs high-speed, low power CMOS designs using advanced triple-layer polysilicon, double-layer metal technology. Each memory cell consists of four transistors and two high valued resistors. The GVT71128D32 SRAM integrates 131,072x32 SRAM cells with advanced synchronous peripheral circuitry and a 2-bit counter for internal burst operation. All synchronous inputs are gated by registers controlled by a positive-edge-triggered clock input (CLK). The synchronous inputs include all addresses, all data inputs, address-pipelining chip enable (CE#), depth-expansion chip enables (CE2# and CE2), burst control inputs (ADSC#, ADSP#, and ADV#), write enables (BW1#, BW2#, BW3#, BW4#,and BWE#), and global write (GW#). Asynchronous inputs include the output enable (OE#) and burst mode control (MODE). The data outputs (Q), enabled by OE#, are also asynchronous. Addresses and chip enables are registered with either address status processor (ADSP#) or address status controller (ADSC#) input pins. Subsequent burst addresses can be internally generated as controlled by the burst advance pin (ADV#). Address, data inputs, and write controls are registered onchip to initiate self-timed WRITE cycle. WRITE cycles can be one to four bytes wide as controlled by the write control inputs. Individual byte write allows individual byte to be written. BW1# controls DQ1-DQ8. BW2# controls DQ9DQ16. BW3# controls DQ17-DQ24. BW4# controls DQ25DQ32. BW1#, BW2# BW3#, and BW4# can be active only with BWE# being LOW. GW# being LOW causes all bytes to be written. This device also incorporates pipelined enable circuit for easy depth expansion without penalizing system performance. The GVT71128D32 operates from a +3.3V power supply. All inputs and outputs are TTL-compatible. The device is ideally suited for 486, Pentium TM , 680x0, and PowerPCTM systems and for systems that are benefited from a wide synchronous data bus. • • • • • • • • • • • • • • Fast access times: 4.8, 5, 6, and 7ns Fast clock speed: 100, 83, and 66MHz Provide high performance 3-1-1-1 access rate Fast OE# access times: 5, 6, and 7ns Optimal for depth expansion (one cycle chip deselect to eliminate bus contention) Single +3.3V -5% and +10%power supply Support +2.5V I/O 5V tolerant inputs except I/O’s Clamp diodes to VSSQ at all outputs Common data inputs and data outputs BYTE WRITE ENABLE and GLOBAL WRITE control Three chip enables for depth expansion and address pipeline Address, control, input, and output pipeline registers Internally self-timed WRITE CYCLE Burst control pins (interleaved or linear burst sequence) Automatic power-down for portable applications High density, high speed packages Low capacitive bus loading High 30pF output drive capability at rated access time OPTIONS • • • MARKING Timing 4.8ns access/10ns cycle 5ns access/10ns cycle 6ns access/12ns cycle 7ns access/15ns cycle -4 -5 -6 -7 Packages 100-pin TQFP T Temperature Commercial Industrial None I (0°C to 70°C) (-40°C to 85°C) Galvantech, Inc. 3080 Oakmead Village Drive, Santa Clara, CA 95051 Tel (408) 566-0688 Fax (408) 566-0699 Web Site www.galvantech.com Rev. 11/9 9 Pentium is a trademark of Intel Corporation. PowerPC is a trademark of IBM Corporation. Galvantech, Inc. reserves the right to change products or specifications without notice. GVT71128D32 128K X 32 SYNCHRONOUS BURST SRAM GALVANTECH, FUNCTIONAL BLOCK DIAGRAM BYTE 1 WRITE BW1# BWE# D Q CLK BYTE 2 WRITE BW2# D Q GW# BYTE 3 WRITE BW3# D Q BYTE 4 WRITE ENABLE D CE2 Q D Q byte 2 write byte 1 write CE# Q byte 3 write D byte 4 write BW4# CE2# OE# Power Down Logic A16-A2 Address Register ADSC# CLR ADV# A1-A0 Binary Counter & Logic OUTPUT REGISTER D Q Output Buffers Input Register ADSP# 128K x 8 x 4 SRAM Array ZZ DQ1-DQ32 MODE NOTE: November 20, 1999 Rev. 11/9 9 The Functional Block Diagram illustrates simplified device operation. See Truth Table, pin descriptions and timing diagrams for detailed information. 2 Galvantech, Inc. reserves the right to change products or specifications without notice. GVT71128D32 128K X 32 SYNCHRONOUS BURST SRAM GALVANTECH, A6 A7 CE# CE2 BW4# BW3# BW2# BW1# CE2# VCC VSS CLK GW# BWE# OE# ADSC# ADSP# ADV# A8 A9 PIN ASSIGNMENT (Top View) 100 99 NC DQ17 DQ18 VCCQ VSSQ DQ19 DQ20 DQ21 DQ22 VSSQ VCCQ DQ23 DQ24 NC VCC NC VSS DQ25 DQ26 VCCQ VSSQ DQ27 DQ28 DQ29 DQ30 VSSQ VCCQ DQ31 DQ32 NC 98 97 96 95 94 93 92 91 90 89 88 87 86 85 84 83 82 81 1 80 2 79 3 78 4 77 5 76 6 75 7 74 8 73 9 72 10 71 11 70 12 69 13 68 14 67 100-pin PQFP or 100-pin TQFP 15 16 17 66 65 64 18 63 19 62 20 61 21 60 22 59 23 58 24 57 25 56 26 55 27 54 28 53 29 52 30 51 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 MODE A5 A4 A3 A2 A1 A0 NC NC VSS VCC NC NC A10 A11 A12 A13 A14 A15 A16 31 NC DQ16 DQ15 VCCQ VSSQ DQ14 DQ13 DQ12 DQ11 VSSQ VCCQ DQ10 DQ9 VSS NC VCC ZZ DQ8 DQ7 VCCQ VSSQ DQ6 DQ5 DQ4 DQ3 VSSQ VCCQ DQ2 DQ1 NC PIN DESCRIPTIONS QFP PINS 37, 32, 44, 49, 36, 35, 34, 33, 100, 99, 82, 81, 45, 46, 47, 48, 50 93,94,95,96 87 SYMBOL TYPE DESCRIPTION A0-A16 Input- Addresses: These inputs are registered and must meet the setup and hold times around the rising edge of CLK. The burst counter generates internal addresses associated with A0 and A1, during burst cycle and wait cycle . Synchronous BW1#, BW2#, BW3#, BW4# BWE# InputSynchronous InputSynchronous 88 GW# InputSynchronous 89 CLK InputSynchronous 98 CE# Input- Byte Write: A byte write is LOW for a WRITE cycle and HIGH for a READ cycle. BW1# controls DQ1-DQ8. BW2# controls DQ9-DQ16. BW3# controls DQ17-DQ24. BW4# controls DQ25-DQ32. Data I/O are high impedance if either of these inputs are LOW, conditioned by BWE# being LOW. Write Enable: This active LOW input gates byte write operations and must meet the setup and hold times around the rising edge of CLK. Global Write: This active LOW input allows a full 32-bit WRITE to occur independent of the BWE# and BWn# lines and must meet the setup and hold times around the rising edge of CLK. Clock: This signal registers the addresses, data, chip enables, write control and burst control inputs on its rising edge. All synchronous inputs must meet setup and hold times around the clock’s rising edge. Chip Enable: This active LOW input is used to enable the device and to gate ADSP#. Synchronous 92 CE2# Input- Chip Enable: This active LOW input is used to enable the device. Synchronous November 20, 1999 Rev. 11/9 9 3 Galvantech, Inc. reserves the right to change products or specifications without notice. GVT71128D32 128K X 32 SYNCHRONOUS BURST SRAM GALVANTECH, PIN DESCRIPTIONS (continued) QFP PINS SYMBOL TYPE 97 CE2 input- DESCRIPTION 86 OE# Input Output Enable: This active LOW asynchronous input enables the data output drivers. 83 ADV # Input- Address Advance: This active LOW input is used to control the internal burst counter. A HIGH on this pin generates wait cycle (no address advance). Chip enable: This active HIGH input is used to enable the device. Synchronous Synchronous 84 ADSP# InputSynchronous 85 ADSC# InputSynchronous Address Status Processor: This active LOW input, along with CE# being LOW, causes a new external address to be registered and a READ cycle is initiated using the new address . Address Status Controller: This active LOW input causes device to be de-selected or selected along with new external address to be registered. A READ or WRITE cycle is initiated depending upon write control inputs. 31 MODE InputStatic Mode: This input selects the burst sequence. A LOW on this pin selects LINEAR BURST. A NC or HIGH on this pin selects INTERLEAVED BURST . 64 ZZ InputAsynchro-nous Snooze: This active HIGH input puts the device in low power consumption standby mode. For normal operation, this input has to be either LOW or NC (No Connect). 52, 53, 56, 57, 58, 59, 62, 63, 68, 69, 72-75, 78, 79, 2, 3, 6-9, 12, 13, 18, 19, 22-25, 28, 29 DQ1-DQ32 Input/ Outpu t Data Inputs/Outputs: First Byte is DQ1-DQ8. Second Byte is DQ9-DQ16. Third Byte is DQ17-DQ24. Fourth Byte is DQ25-DQ32. Input data must meet setup and hold times around the rising edge of CLK. 15, 41, 65, 9 1 VCC Supply Power Supply: +3.3V -5% to +10%. Pin 14 does not have to be connected directly to VCCas long as it is greater than VIH . Ground: GN D 17, 40, 67, 9 0 VSS Ground 4, 11, 20, 27, 54, 61, 70, 77 VCCQ I/O Supply Output Buffer Supply: +3.3V -5% to +10%. For 2.5V I/O: 2.375V to VCC. 5, 10, 21, 26, 55, 60, 71, 76 VSSQ I/O Ground Output Buffer Ground: GND 1, 14, 16, 30, 38, 39, 42, 43, 50, 51, 66, 80 NC - No Connect: These signals are not internally connected. BURST ADDRESS TABLE (MODE = NC/VCC ) First Address (external) Second Address (internal) Third Address (internal) Fourth Address (internal) A...A00 A...A01 A...A10 A...A11 A...A01 A...A00 A...A11 A...A10 A...A10 A...A11 A...A00 A...A01 A...A11 A...A10 A...A01 A...A00 BURST ADDRESS TABLE (MODE = GND) First Address (external) Second Address (internal) Third Address (internal) Fourth Address (internal) A...A00 A...A01 A...A10 A...A11 A...A01 A...A10 A...A11 A...A00 A...A10 A...A11 A...A00 A...A01 A...A11 A...A00 A...A01 A...A10 PARTIAL TRUTH TABLE FOR READ/WRIT E FUNCTION GW# BWE# BW1# BW2# BW3# BW4# READ H H X X X X READ H L H H H H WRITE one byte H L L H H H WRITE all bytes H L L L L L WRITE all bytes L X X X X X November 20, 1999 Rev. 11/9 9 4 Galvantech, Inc. reserves the right to change products or specifications without notice. GVT71128D32 128K X 32 SYNCHRONOUS BURST SRAM GALVANTECH, TRUTH TABLE ADDRESS USED CE# CE2# CE2 Deselected Cycle, Power Down None H X X X Deselected Cycle, Power Down None L X L L Deselected Cycle, Power Down None L H X Deselected Cycle, Power Down None L X Deselected Cycle, Power Down None L READ Cycle, Begin Burs t External READ Cycle, Begin Burs t OPERATION ADV# WRITE# OE# CLK DQ L X X X L-H High-Z X X X X L-H High-Z L X X X X L-H High-Z L H L X X X L-H High-Z H X H L X X X L-H High-Z L L H L X X X L L-H Q External L L H L X X X H L-H High-Z WRITE Cycle, Begin Burst External L L H H L X L X L-H D READ Cycle, Begin Burs t External L L H H L X H L L-H Q READ Cycle, Begin Burs t External L L H H L X H H L-H High-Z READ Cycle, Continue Burst Next X X X H H L H L L-H Q READ Cycle, Continue Burst Next X X X H H L H H L-H High-Z READ Cycle, Continue Burst Next H X X X H L H L L-H Q READ Cycle, Continue Burst Next H X X X H L H H L-H High-Z WRITE Cycle, Continue Burst Next X X X H H L L X L-H D WRITE Cycle, Continue Burst Next H X X X H L L X L-H D READ Cycle, Suspend Burs t Current X X X H H H H L L-H Q READ Cycle, Suspend Burs t Current X X X H H H H H L-H High-Z READ Cycle, Suspend Burs t Current H X X X H H H L L-H Q READ Cycle, Suspend Burs t Current H X X X H H H H L-H High-Z WRITE Cycle, Suspend Burst Current X X X H H H L X L-H D WRITE Cycle, Suspend Burst Current H X X X H H L X L-H D Note: 1. 2. 3. 4. 5. 6. 7. November 20, 1999 Rev. 11/9 9 ADSP # ADSC# X means “don’t care.” H means logic HIGH. L means logic LOW. WRITE# = L means [BWE# + BW1#*BW2#*BW3#*BW4#]*GW# equals LOW. WRITE# = H means [BWE# + BW1#*BW2#*BW3#*BW4#]*GW# equals HIGH. BW1# enables write to DQ1-DQ8. BW2# enables write to DQ9-DQ16. BW3# enables write to DQ17-DQ24. BW4# enables write to DQ25-DQ32. All inputs except OE# must meet setup and hold times around the rising edge (LOW to HIGH) of CLK. Suspending burst generates wait cycle. For a write operation following a read operation, OE# must be HIGH before the input data required setup time plus High-Z time for OE# and staying HIGH throughout the input data hold time. This device contains circuitry that will ensure the outputs will be in High-Z during power-up. ADSP# LOW along with chip being selected always initiates an READ cycle at the L-H edge of CLK. A WRITE cycle can be performed by setting WRITE# LOW for the CLK L-H edge of the subsequent wait cycle. Refer to WRITE timing diagram for clarification. 5 Galvantech, Inc. reserves the right to change products or specifications without notice. GALVANTECH, GVT71128D32 128K X 32 SYNCHRONOUS BURST SRAM *Stresses greater than those listed uunder “Absolute Maximum Ratings” may cause permanent damage to the device.This is a stress rating only and functional operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect reliability. ABSOLUTE MAXIMUM RATINGS* Voltage on VCC Supply Relative to VSS........-0.5V to +4.6V VIN ...........................................................-0.5V to VCC+0.5V Storage Temperature (plastic) .........................-55o C to +150 o Junction Temperature .....................................................+150 o Power Dissipation ...........................................................1.0W Short Circuit Output Current .........................................50mA DC ELECTRICAL CHARACTERISTICS AND RECOMMENDED OPERATING CONDITIONS (All Temperature Ranges; VCC = 3.3V -5 to +10% unless otherwise noted) DESCRIPTION CONDITIONS Input High (Logic 1) Voltage SYMBOL MIN MAX UNITS NOTES Data Inputs (DQxx) V I HD 2.0 VCCQ+0.3 V 1,2 All Other Inputs V IH 2.0 4.6 V 1,2 V Il -0.3 0.8 V 1, 2 14 Input Low (Logic 0) Voltage Input Leakage Current 0V < V IN < VCC IL I -2 2 uA Output Leakage Current Output(s) disabled, 0V < V OUT < VCC IL O -2 2 uA Output High Voltage IOH = -4.0mA V OH 2.4 Output Low Voltage IOL = 8.0mA V OL Supply Voltage V 1, 11 0.4 V 1, 11 VCC 3.1 3.6 V 1 I/O Supply Voltage (3.3V I/O) VCCQ 3.1 3.6 V 1 I/O Supply Voltage (2.5V I/O) VCCQ 2.375 VCC V 1 DESCRIPTION CONDITIONS SYM TYP -4 -5 -6 -7 Power Supply Current: Operating UNITS NOTES Device selected; all inputs < V IL or > V IH ;cycle time > tKC MIN; VCC =MAX; outputs open Icc 80 225 225 185 120 mA 3, 12, 13 CMOS Standby Device deselected; VCC = MAX; all inputs < VSS +0.2 or >VCC -0.2; all inputs static; CLK frequency = 0 ISB2 0.2 2 2 2 2 mA 12,13 TTL Standby Device deselected; all inputs < V IL or > V IH; all inputs static; VCC = MAX; CLK frequency = 0 ISB3 8 18 18 18 18 mA 12,13 Clock Runnin g Device deselected; all inputs < V IL or > V IH ; VCC = MAX; CLK cycle time > t KC MIN ISB4 12 30 30 25 20 mA 12,13 CAPACITANCE DESCRIPTION CONDITIONS Input Capacitance TA = 25 o C; f = 1 MHz VCC = 3.3V Input/Output Capacitance (DQ) SYMBOL TYP MAX UNITS NOTES CI 3 4 pF 4 CO 6 7 pF 4 THERMAL CONSIDERATIO N DESCRIPTION CONDITIONS Thermal Resistance - Junction to Ambient Still air, soldered on 4.25 x 1.125 inch 4-layer PCB Thermal Resistance - Junction to Case November 20, 1999 Rev. 11/9 9 SYMBOL TQFP TYP 6 UNITS ΘJ A 20 o C/W Θ JC 1 o C/W NOTES Galvantech, Inc. reserves the right to change products or specifications without notice. GVT71128D32 128K X 32 SYNCHRONOUS BURST SRAM GALVANTECH, AC ELECTRICAL CHARACTERISTICS (Note 5) (All Temperature Ranges; VCC = 3.3V -5 to +10% ) -4 DESCRIPTION -5 MAX MIN -6 MAX MIN -7 SY M MIN MAX MIN MAX UNIT S NOTES Clock cycle tim e tKC 10 10 12 15 ns Clock HIGH time tKH 4 4 4 5 ns Clock LOW tim e tKL 4 4 4 5 ns Cloc k Output Times t KQ Clock to output valid 4.8 5 6 7 ns tKQ X 2 2 2 2 Clock to output in Low-Z t KQLZ 3 3 3 3 ns 6,7 Clock to output in High-Z t KQH Z 5 5 5 6 ns 6,7 OE to output valid t OEQ 5 5 6 7 ns 9 OE to output in Low-Z t OELZ ns 6,7 OE to output in High-Z t OEHZ ns 6,7 Clock to output invalid 0 0 0 4 4 ns 0 5 6 Setup Times Address, Controls and Data In tS 2.0 2.5 2.5 2.5 ns 10 tH 0.5 0.5 0.5 0.5 ns 10 Hold Times Address, Controls and Data In CAPACITANCE DERATING DESCRIPTION Clock to output valid November 20, 1999 Rev. 11/9 9 SYMBOL TYP ∆ tKQ 0.016 MAX 7 UNITS NOTES ns / pF 15 Galvantech, Inc. reserves the right to change products or specifications without notice. GVT71128D32 128K X 32 SYNCHRONOUS BURST SRAM GALVANTECH, OUTPUT LOADS FOR 3.3V I/O AC TEST CONDITIONS FOR 3.3V I/O Input pulse levels DQ 0V to 3.0V Z0 = 50 Ω 50Ω 30 pF Input rise and fall times 1.5ns Input timing reference levels 1.5V Output reference levels 1.5V Fig. 1 OUTPUT LOAD EQUIVALENT See Figures 1 and 2 3.3v Output load Vt = 1.5V 317Ω AC TEST CONDITIONS FOR 2.5V I/O Input pulse levels DQ 351Ω 0V to 2.5V Input slew rate 5 pF 1.0V/ns Output rise and fall times(max) 1.8ns Input timing reference levels 1.25V Output reference levels 1.25V Output load Fig. 2 OUTPUT LOAD EQUIVALENT OUTPUT LOADS FOR 2.5V I/O DQ See Figures 3 Z0 = 50Ω 50Ω Vt = 1.25V Fig. 3 OUTPUT LOAD EQUIVALENT 10. This is a synchronous device. All synchronous inputs must meet specified setup and hold time, except for “don’t care” as defined in the truth table. NOTES 1. All voltages referenced to VSS (GND). 2. Overshoot: Undershoot: 3. Ic c is given with no output current. Ic c increases with greater output loading and faster cycle times. 12. “Device Deselected” means the device is in POWER -DOWN mode as defined in the truth table. “Device Selected” means the device is active. 4. This parameter is sampled. 13. Typical values are measured at 3.3V, 25oC and 20ns cycle time. 5. Test conditions as specified with the output loading as shown in Fig. 1 unless otherwise noted. 6. Output loading is specified with CL=5pF as in Fig. 2. 7. At any given temperature and voltage condition, t KQHZ is less than t KQLZ and t OEHZ is less than t OELZ. 8. A READ cycle is defined by byte write enables all HIGH or ADSP# LOW along with chip enables being active for the required setup and hold times. A WRITE cycle is defined by at one byte or all byte WRITE per READ/WRITE TRUTH TABLE. 9. OE# is a “don’t care” when a byte write enable is sampled LOW. November 20, 1999 Rev. 11/9 9 VIH ≤ +6.0V for t ≤ t KC /2. VIL ≤ -2.0V for t ≤ t KC /2 11. AC I/O curves are available upon request. 14. MODE pin has an internal pull-up and ZZ pin has an internal pull-down. These two pins exhibit an input leakage current of +30 µA. 15. Capacitance derating applies to capacitance different from the load capacitance shown in Fig. 1 or Fig. 3, for 3.3V or 2.5V I/O respectively 8 Galvantech, Inc. reserves the right to change products or specifications without notice. GVT71128D32 128K X 32 SYNCHRONOUS BURST SRAM GALVANTECH, READ TIMING t KC t KL CLK t t S KH ADSP# tH ADSC# tS ADDRESS BW1#, BW2#, BW3#, BW4#, BWE#, GW# A1 A2 tH CE# (See Note) t S ADV# t H OE# t tKQLZ DQ tKQ tOEQ KQ tOELZ Q(A1) Q(A2) SINGLE READ Q(A2+1) Q(A2+2) Q(A2+3) Q(A2) Q(A2+1) BURST READ Note: CE# active in this timing diagram means that all chip enables CE#, CE2, and CE2# are active. November 20, 1999 Rev. 11/9 9 9 Galvantech, Inc. reserves the right to change products or specifications without notice. GVT71128D32 128K X 32 SYNCHRONOUS BURST SRAM GALVANTECH, WRITE TIMING CLK t S ADSP# t H ADSC# t ADDRESS S A1 A2 A3 tH BW1#, BW2#, BW3#, BW4#, BWE# GW# CE# (See Note) t S ADV# t H OE# t OEHZ tKQX DQ Q D(A1) D(A2) D(A2+1) SINGLE WRITE D(A2+1) D(A2+2) D(A2+3) D(A3) BURST WRITE D(A3+1) D(A3+2) BURST WRITE Note: CE# active in this timing diagram means that all chip enables CE#, CE2, and CE2# are active. November 20, 1999 Rev. 11/9 9 10 Galvantech, Inc. reserves the right to change products or specifications without notice. GVT71128D32 128K X 32 SYNCHRONOUS BURST SRAM GALVANTECH, READ/WRITE TIMING CLK t S ADSP# t H ADSC# t ADDRESS A1 S A2 t BW1#, BW2#, BW3#, BW4#, BWE#, GW# A3 A4 A5 H CE# (See Note) ADV# OE# DQ Q(A1) Single Reads Q(A2) D(A3) Q(A3) Q(A4) Q(A4+1) Q(A4+2) D(A5) D(A5+1) Pass Through Single Write Burst Read Burst Write Note: CE# active in this timing diagram means that all chip enables CE#, CE2, and CE2# are active. November 20, 1999 Rev. 11/9 9 11 Galvantech, Inc. reserves the right to change products or specifications without notice. GALVANTECH, GVT71128D32 128K X 32 SYNCHRONOUS BURST SRAM 100 Pin TQFP Package Dimensions 16.00 + 0.10 14.00 + 0.10 #1 22.00 + 0.10 20.00 + 0.10 1.40 + 0.05 1.60 Max 0.65 Basic 0.30 + 0.08 0.60 + 0.15 Note: All dimensions in Millimeters November 20, 1999 Rev. 11/9 9 12 Galvantech, Inc. reserves the right to change products or specifications without notice. GALVANTECH, GVT71128D32 128K X 32 SYNCHRONOUS BURST SRAM Ordering Information GVT 71128D32 X - X X Galvantech Prefix Temperature (Blank = Commercial I = Industrial) Part Number Speed (4 = 4.8ns access/10ns cycle 5 = 5ns access/10ns cycle 6 = 6ns access/12ns cycle 7 = 7ns access/15ns cycle) Package (T = 100 PIN TQFP) November 20, 1999 Rev. 11/9 9 13 Galvantech, Inc. reserves the right to change products or specifications without notice.
GVT71128D32T-5 价格&库存
很抱歉,暂时无法提供与“GVT71128D32T-5”相匹配的价格&库存,您可以联系我们找货
