S-93L66AD0I-K8T3U
S-93L66AD0I-K8T3U
    ABLIC(艾普凌科)
    TMSOP8_2.9X2.8MM
    IC EEPROM 4KBIT SPI 2MHZ 8TMSOP
S-93L66AD0I-K8T3U 数据手册
S-93L46A/56A/66A N LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM DE SI G www.ablicinc.com Rev.8.1_02 © ABLIC Inc., 2004-2015 W The S-93L46A/56A/66A is a low voltage operation, high speed, low current consumption, 3-wire serial E2PROM with a wide operating voltage range. The S-93L46A/56A/66A has the capacity of 1 K-bit, 2 K-bit and 4 K-bit, and the organization is 64word 16-bit, 128-word 16-bit, and 256-word 16-bit. It is capable of sequential read, at which time addresses are automatically incremented in 16-bit blocks. The communication method is by the Microwire bus.  Features Read Write 1.6 V to 5.5 V 1.8 V to 5.5 V (WRITE, ERASE) 2.7 V to 5.5 V (WRAL, ERAL) 2.0 MHz (VCC = 4.5 V to 5.5 V) 8.0 ms max. NE  Operating voltage range: EN DE D FO R  Operation frequency:  Write time:  Sequential read capable  Write protect function during the low power supply voltage  Function to protect against write due to erroneous instruction recognition  Endurance: 106 cycles / word*1 (Ta = 85C)  Data retention: 100 years (Ta = 25C) 20 years (Ta = 85C)  Memory capacity: S-93L46A: 1 K-bit S-93L56A: 2 K-bit S-93L66A: 4 K-bit  Initial delivery state: FFFFh  Operation temperature range: Ta = 40°C to 85C  Lead-free, Sn 100%, halogen-free*2 M *1. For each address (Word: 16-bit) *2. Refer to “ Product Name Structure” for details. OM  Packages This product is intended to use in general electronic devices such as consumer electronics, office equipment, and communications devices. Before using the product in medical equipment or automobile equipment including car audio, keyless entry and engine control unit, contact to ABLIC Inc. is indispensable. NO T Caution RE C  8-Pin SOP (JEDEC)  8-Pin TSSOP  TMSOP-8  SNT-8A 1 LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L46A/56A/66A Rev.8.1_02 8-Pin SOP (JEDEC) 8-Pin SOP (JEDEC) Top view Table 1 Pin No. 8 2 7 3 6 4 5 1 CS Chip select input 2 SK Serial clock input 3 DI Serial data input 4 DO Serial data output 5 GND Ground TEST*1 6 Test 7 NC No connection 8 VCC Power supply *1. Connect to GND or VCC. Even if this pin is not connected, performance is not affected so long as the absolute maximum rating is not exceeded. NE Figure 1 8-Pin SOP (JEDEC) (Rotated) Top view Pin No. 7 3 6 4 5 1 NC No connection 2 VCC Power supply 3 CS Chip select input 4 SK Serial clock input 5 DI Serial data input 6 DO Serial data output 7 GND Ground TEST*1 8 Test *1. Connect to GND or VCC. Even if this pin is not connected, performance is not affected so long as the absolute maximum rating is not exceeded. M OM S-93L46AR0I-J8T1x S-93L56AR0I-J8T1x S-93L66AR0I-J8T1x Description D 2 Table 2 DE 8 Symbol EN 1 FO R S-93L46AD0I-J8T1x S-93L56AD0I-J8T1x S-93L66AD0I-J8T1x Figure 2 Description W 1 Symbol DE SI G 1. N  Pin Configurations NO T RE C Remark 1. Refer to the “Package drawings” for the details. 2. x: G or U 3. Please select products of environmental code = U for Sn 100%, halogen-free products. 2 LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L46A/56A/66A Rev.8.1_02 N 8-Pin TSSOP 8-Pin TSSOP Top view Table 3 Pin No. 1 2 3 4 W NE S-93L46AD0I-T8T1x S-93L56AD0I-T8T1x S-93L66AD0I-T8T1x Pin No. 8 7 6 5 DE EN OM SNT-8A Top view RE C 8 7 6 5 Figure 5 T S-93L46AD0I-I8T1U S-93L56AD0I-I8T1U S-93L66AD0I-I8T1U NO Description M SNT-8A 1 2 3 4 Symbol 1 CS Chip select input 2 SK Serial clock input 3 DI Serial data input 4 DO Serial data output 5 GND Ground TEST*1 6 Test 7 NC No connection 8 VCC Power supply *1. Connect to GND or VCC. Even if this pin is not connected, performance is not affected so long as the absolute maximum rating is not exceeded. Figure 4 S-93L46AD0I-K8T3U S-93L56AD0I-K8T3U S-93L66AD0I-K8T3U Table 4 D 1 2 3 4 FO R TMSOP-8 TMSOP-8 Top view 4. Description 1 CS Chip select input 2 SK Serial clock input 3 DI Serial data input 4 DO Serial data output 5 GND Ground TEST*1 6 Test 7 NC No connection 8 VCC Power supply *1. Connect to GND or VCC. Even if this pin is not connected, performance is not affected so long as the absolute maximum rating is not exceeded. 8 7 6 5 Figure 3 3. Symbol DE SI G 2. Table 5 Pin No. Symbol Description 1 CS Chip select input 2 SK Serial clock input 3 DI Serial data input 4 DO Serial data output 5 GND Ground TEST*1 6 Test 7 NC No connection 8 VCC Power supply *1. Connect to GND or VCC. Even if this pin is not connected, performance is not affected so long as the absolute maximum rating is not exceeded. Remark 1. Refer to the “Package drawings” for the details. 2. x: G or U 3. Please select products of environmental code = U for Sn 100%, halogen-free products. 3 LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L46A/56A/66A  Block Diagram decoder Data register W NE Mode decode logic CS Clock pulse monitoring circuit R Voltage detector FO Clock generator NO T RE C OM M EN DE D Figure 6 4 GND Output buffer DI SK VCC DE SI G Address Memory array N Rev.8.1_02 DO LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L46A/56A/66A Rev.8.1_02 1. N  Instruction Sets S-93L46A DE SI G Table 6 Remark x: Don’t care 2. S-93L56A Table 7 Operation Code Address FO Start Bit Instruction SK input clock R NE W Operation Address Data Start Bit Instruction Code SK input clock 1 2 3 4 5 6 7 8 9 10 to 25 D15 to D0 Output*1 READ (Read data) 1 1 0 A5 A4 A3 A2 A1 A0 WRITE (Write data) 1 0 1 A5 A4 A3 A2 A1 A0 D15 to D0 Input ERASE (Erase data) 1 1 1 A5 A4 A3 A2 A1 A0  WRAL (Write all) 1 0 0 0 1 x x x x D15 to D0 Input ERAL (Erase all) 1 0 0 1 0 x x x x  EWEN (Write enable) 1 0 0 1 1 x x x x  EWDS (Write disable) 1 0 0 0 0 x x x x  *1. When the 16-bit data in the specified address has been output, the data in the next address is output. Data EN DE D 1 2 3 4 5 6 7 8 9 10 11 12 to 27 D15 to D0 Output*1 READ (Read data) 1 1 0 x A6 A5 A4 A3 A2 A1 A0 WRITE (Write data) 1 0 1 x A6 A5 A4 A3 A2 A1 A0 D15 to D0 Input ERASE (Erase data) 1 1 1 x A6 A5 A4 A3 A2 A1 A0  WRAL (Write all) 1 0 0 0 1 x x x x x x D15 to D0 Input ERAL (Erase all) 1 0 0 1 0 x x x x x x  EWEN (Write enable) 1 0 0 1 1 x x x x x x  EWDS (Write disable) 1 0 0 0 0 x x x x x x  *1. When the 16-bit data in the specified address has been output, the data in the next address is output. M Remark x: Don’t care Instruction SK input clock OM 3. S-93L66A Start Bit 1 Table 8 Operation Code 2 Address Data 3 NO T RE C 4 5 6 7 8 9 10 11 12 to 27 D15 to D0 Output*1 READ (Read data) 1 1 0 A7 A6 A5 A4 A3 A2 A1 A0 WRITE (Write data) 1 0 1 A7 A6 A5 A4 A3 A2 A1 A0 D15 to D0 Input ERASE (Erase data) 1 1 1 A7 A6 A5 A4 A3 A2 A1 A0  WRAL (Write all) 1 0 0 0 1 x x x x x x D15 to D0 Input ERAL (Erase all) 1 0 0 1 0 x x x x x x  EWEN (Write enable) 1 0 0 1 1 x x x x x x  EWDS (Write disable) 1 0 0 0 0 x x x x x x  *1. When the 16-bit data in the specified address has been output, the data in the next address is output. Remark x: Don’t care 5 LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L46A/56A/66A Rev.8.1_02 N  Absolute Maximum Ratings Table 9 DE SI G Item Symbol Ratings Unit Power supply voltage VCC 0.3 to 7.0 V Input voltage VIN 0.3 to VCC 0.3 V Output voltage VOUT 0.3 to VCC V Operation ambient temperature Topr 40 to 85 C Storage temperature Tstg 65 to 150 C Caution The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions. W  Recommended Operating Conditions Item Symbol VCC High level input voltage VIH Low level input voltage VIL Ta = 40C to 85C Min. Max. 1.6 5.5 1.8 5.5 2.7 5.5 2.0 VCC 0.8  VCC VCC 0.8  VCC VCC 0.0 0.8 0.0 0.2  VCC 0.0 0.15  VCC Conditions READ, EWDS WRITE, ERASE, EWEN WRAL, ERAL VCC = 4.5 V to 5.5 V VCC = 2.7 V to 4.5 V VCC = 1.6 V to 2.7 V VCC = 4.5 V to 5.5 V VCC = 2.7 V to 4.5 V VCC = 1.6 V to 2.7 V DE D FO R Power supply voltage NE Table 10  Pin Capacitance Unit V V V V V V V V V Table 11 Symbol OM Symbol Endurance Conditions VIN = 0 V VOUT = 0 V M CIN COUT  Endurance Item (Ta = 25C, f = 1.0 MHz, VCC = 5.0 V) Min. Max. Unit  8 pF  10 pF EN Item Input Capacitance Output Capacitance NW Table 12 Operation Ambient Temperature Min. 6 Ta = 40C to 85C 10 Max. Unit  Cycles / word*1 Max.   Unit year year RE C *1. For each address (Word: 16-bit)  Data Retention Item NO T Data Retention 6 Symbol  Table 13 Operation Ambient Temperature Ta = 25C Ta = 40C to 85C Min. 100 20 LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L46A/56A/66A Rev.8.1_02 N  DC Electrical Characteristics Table 14 Symbol Current consumption ICC1 (READ) Conditions VCC = 4.5 V to 5.5 V Min. Max. Ta = 40C to 85C VCC = 4.5 V to 5.5 V VCC = 1.8 V to 4.5 V Min. Max. Min. Max. Unit  DO no load Table 16 VOH Data hold voltage of write enable latch VDH VOUT = GND to VCC  FO R Ta = 40C to 85C VCC = 2.5 V to 4.5 V Min. Max. 1.5 mA VCC = 1.6 V to 2.5 V Min. Max. Unit 1.5  1.5  1.5 A  1.0  1.0  1.0 A  1.0  1.0  1.0 A 0.4 0.1       VCC0.3 VCC0.2  0.1        VCC0.2  0.1    V V V V V  1.5  1.5  V  IOL = 2.1 mA  IOL = 100 A  IOH = 400 A 2.4 IOH = 100 A VCC0.3 IOH = 10 A VCC0.2 Only program disable 1.5 mode NO T RE C OM High level output voltage CS = GND, DO = Open, Other input pins are VCC or GND VIN = GND to VCC D Input leakage current ILI Output leakage ILO current Low level output VOL voltage Conditions DE ISB VCC = 4.5 V to 5.5 V Min. Max. EN Standby current consumption Symbol M Item 2.0 W Current consumption ICC2 (WRITE) Conditions  0.5 NE Symbol Unit mA  0.8 Table 15 Item VCC = 1.6 V to 2.5 V Min. Max. 0.4  DO no load Ta = 40C to 85C VCC = 2.5 V to 4.5 V Min. Max. DE SI G Item 7 LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L46A/56A/66A Rev.8.1_02 Measurement Conditions 0.1  VCC to 0.9  VCC 0.5  VCC 100 pF Input pulse voltage Output reference voltage Output load DE SI G Table 17 N  AC Electrical Characteristics Table 18 DE D FO R NE W Ta = 40C to 85C VCC = 4.5 V to 5.5 V VCC = 2.5 V to 4.5 V VCC = 1.6 V to 2.5 V Unit Item Symbol Min. Max. Min. Max. Min. Max. CS setup time tCSS 0.2 — 0.4 — 1.0 — s CS hold time tCSH 0 — 0 — 0 — s CS deselect time tCDS 0.2 — 0.2 — 0.4 — s Data setup time tDS 0.1 — 0.2 — 0.4 — s Data hold time tDH 0.1 — 0.2 — 0.4 — s Output delay time tPD — 0.4 — 0.8 — 2.0 s Clock frequency*1 0 2.0 0 1.0 0 0.25 MHz fSK SK clock time “L” *1 0.1 — 0.25 — 1.0 — s tSKL *1 SK clock time “H” 0.1 — 0.25 — 1.0 — s tSKH Output disable time tHZ1, tHZ2 0 0.15 0 0.5 0 1.0 s Output enable time tSV 0 0.15 0 0.5 0 1.0 s *1. The clock cycle of the SK clock (frequency: fSK) is 1 / fSK s. This clock cycle is determined by a combination of several AC characteristics, so be aware that even if the SK clock cycle time is minimized, the clock cycle (1 / fSK) cannot be made equal to tSKL (min.)  tSKH (min.). Item Symbol tPR NO T RE C OM M Write time EN Table 19 8 Ta = 40C to 85C VCC = 1.8 V to 5.5 V Min Typ. Max. — 4.0 8.0 Unit ms LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L46A/56A/66A tCSS tCDS *2 1 / fSK N Rev.8.1_02 CS tSKL tCSH SK tDS DI tPD tPD High-Z High-Z tSV (READ) W DO tHZ2 NE High-Z (VERIFY) tHZ1 High-Z R Indicates high impedance. 1 / fSK is the SK clock cycle. This clock cycle is determined by a combination of several AC characteristics, so be aware that even if the SK clock cycle time is minimized, the clock cycle (1 / fSK) cannot be made equal to tSKL (min.)  tSKH (min.). Timing Chart NO T RE C OM M EN DE D Figure 7 FO *1. *2. tDH Valid data Valid data *1 DO tDS tDH DE SI G tSKH 9 LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L46A/56A/66A Rev.8.1_02 N  Initial Delivery State DE SI G Initial delivery state of all addresses is “FFFFh”.  Operation All instructions are executed by inputting DI in synchronization with the rising edge of SK after CS goes high. An instruction set is input in the order of start bit, instruction, address, and data. Instruction input finishes when CS goes low. A low level must be input to CS between commands during tCDS. While a low level is being input to CS, the S-93L46A/56A/66A is in standby mode, so the SK and DI inputs are invalid and no instructions are allowed. W  Start Bit 1. NE A start bit is recognized when the DI pin goes high at the rise of SK after CS goes high. After CS goes high, a start bit is not recognized even if the SK pulse is input as long as the DI pin is low. Dummy clock 2. FO R SK clocks input while the DI pin is low before a start bit is input are called dummy clocks. Dummy clocks are effective when aligning the number of instruction sets (clocks) sent by the CPU with those required for serial memory operation. For example, when a CPU instruction set is 16 bits, the number of instruction set clocks can be adjusted by inserting a 7-bit dummy clock for the S-93L46A and a 5-bit dummy clock for the S-93L56A/66A. Start bit input failure DE D  When the output status of the DO pin is high during the verify period after a write operation, if a high level is input to the DI pin at the rising edge of SK, the S-93L46A/56A/66A recognizes that a start bit has been input. To prevent this failure, input a low level to the DI pin during the verify operation period (refer to “4. 1 Verify operation”). NO T RE C OM M EN  When a 3-wire interface is configured by connecting the DI input pin and DO output pin, a period in which the data output from the CPU and the serial memory collide may be generated, preventing successful input of the start bit. Take the measures described in “ 3-Wire Interface (Direct Connection between DI and DO)”. 10 LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L46A/56A/66A Rev.8.1_02 Reading (READ) N 3. DE SI G The READ instruction reads data from a specified address. After CS has gone high, input an instruction in the order of the start bit, read instruction, and address. Since the last input address (A0) has been latched, the output status of the DO pin changes from high impedance (High-Z) to low, which is held until the next rise of SK. 16-bit data starts to be output in synchronization with the next rise of SK. W 3. 1 Sequential read After the 16-bit data at the specified address has been output, inputting SK while CS is high automatically increments the address, and causes the 16-bit data at the next address to be output sequentially. The above method makes it possible to read the data in the whole memory space. The last address (An  A1 A0 = 1  1 1) rolls over to the top address (An  A1 A0 = 0  0 0). DI 2 1 3 4 0 A5 5 A4 6 A3 7 A2 8 A1 11 12 23 24 25 26 A0 High-Z DO 10 9 D15 0 D14 D13 D2 27 R 1 D1 D0 D15 D14 28 39 D13 40 D2 41 D1 FO SK NE CS ADRINC D15 43 D14 44 D13 High-Z ADRINC Read Timing (S-93L46A) CS DI 1 2 1 3 4 0 5 A6 6 7 8 9 A5 A4 A3 A2 A1 A7: S-93L66A 12 13 14 24 25 26 27 28 29 40 41 42 43 44 45 A0 0 OM DO 11 M x: S-93L56A High-Z 10 EN SK DE D Figure 8 D0 42 D15 D14 D13 D1 D0 D15 D14 D13 ADRINC D2 D1 D0 D15 D14 D13 High-Z ADRINC Read Timing (S-93L56A, S-93L66A) NO T RE C Figure 9 D2 11 LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L46A/56A/66A Writing (WRITE, ERASE, WRAL, ERAL) N 4. Rev.8.1_02 Verify operation A write operation executed by any instruction is completed within 8 ms (write time tPR: typically 4 ms), so if the completion of the write operation is recognized, the write cycle can be minimized. A sequential operation to confirm the status of a write operation is called a verify operation. NE W 4. 1 DE SI G A write operation includes four write instructions: data write (WRITE), data erase (ERASE), chip write (WRAL), and chip erase (ERAL). A write instruction (WRITE, ERASE, WRAL, ERAL) starts a write operation to the memory cell when a low level is input to CS after a specified number of clocks have been input. The SK and DI inputs are invalid during the write period, so do not input an instruction. Input an instruction while the output status of the DO pin is high or high impedance (High-Z). A write operation is valid only in program enable mode (refer to “5. Write enable (EWEN) and write disable (EWDS)”). Operation After the write operation has started (CS = low), the status of the write operation can be verified by confirming the output status of the DO pin by inputting a high level to CS again. This sequence is called a verify operation, and the period that a high level is input to the CS pin after the write operation has started is called the verify operation period. The relationship between the output status of the DO pin and the write operation during the verify operation period is as follows.  DO pin = low: Writing in progress (busy)  DO pin = high: Writing completed (ready) 4. 1. 2 Operation example There are two methods to perform a verify operation: Waiting for a change in the output status of the DO pin while keeping CS high, or suspending the verify operation (CS = low) once and then performing it again to verify the output status of the DO pin. The latter method allows the CPU to perform other processing during the wait period, allowing an efficient system to be designed. DE D FO R 4. 1. 1 NO T RE C OM M EN Caution 1. Input a low level to the DI pin during a verify operation. 2. If a high level is input to the DI pin at the rise of SK when the output status of the DO pin is high, the S-93L46A/56A/66A latches the instruction assuming that a start bit has been input. In this case, note that the DO pin immediately enters a high-impedance (High-Z) state. 12 LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L46A/56A/66A Rev.8.1_02 Writing data (WRITE) To write 16-bit data to a specified address, change CS to high and then input the WRITE instruction, address, and 16-bit data following the start bit. The write operation starts when CS goes low. There is no need to set the data to 1 before writing. If the clocks more than the specified number have been input, the clock pulse monitoring circuit cancels the WRITE instruction. For details of the clock pulse monitoring circuit, refer to “ Function to Protect Against Write due to Erroneous Instruction Recognition”. DE SI G N 4. 2 tCDS CS Standby Verify 1 DI 2 0 3 1 4 5 6 7 8 9 10 A5 A4 A3 A2 A1 A0 D15 25 D0 High-Z DO W SK tSV Busy tHZ1 Ready NE tPR Data Write Timing (S-93L46A) CS 2 0 3 4 1 5 6 7 8 9 A6 A5 A4 A3 A2 High-Z DO tCDS 11 12 27 A1 A0 D15 D0 tSV x : S-93L56A A7: S-93L66A tHZ1 Busy tPR Ready High-Z Data Write Timing (S-93L56A, S-93L66A) NO T RE C OM M EN Figure 11 Standby Verify 10 DE DI 1 D SK FO R Figure 10 High-Z 13 LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L46A/56A/66A Erasing data (ERASE) To erase 16-bit data at a specified address, set all 16 bits of the data to 1, change CS to high, and then input the ERASE instruction and address following the start bit. There is no need to input data. The data erase operation starts when CS goes low. If the clocks have been input more than the specified number, the clock pulse monitoring circuit cancels the ERASE instruction. For details of the clock pulse monitoring circuit, refer to “ Function to Protect Against Write due to Erroneous Instruction Recognition”. DE SI G N 4. 3 Rev.8.1_02 tCDS CS 1 2 DI 1 3 1 4 5 6 7 8 A5 A4 A3 A2 A1 tSV Busy tHZ1 Ready High-Z NE tPR 1 2 DI 1 3 4 1 5 6 7 A6 A5 A4 8 9 A3 A2 D SK FO R Data Erase Timing (S-93L46A) CS High-Z DE DO x : S-93L56A A7: S-93L66A M OM RE C 10 A1 tCDS Standby Verify 11 A0 tSV Busy tPR Data Erase Timing (S-93L56A, S-93L66A) EN Figure 13 T A0 High-Z Figure 12 NO 9 W SK DO 14 Standby Verify tHZ1 Ready High-Z LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L46A/56A/66A Rev.8.1_02 Writing to chip (WRAL) To write the same 16-bit data to the entire memory address space, change CS to high, and then input the WRAL instruction, an address, and 16-bit data following the start bit. Any address can be input. The write operation starts when CS goes low. There is no need to set the data to 1 before writing. If the clocks more than the specified number have been input, the clock pulse monitoring circuit cancels the WRAL instruction. For details of the clock pulse monitoring circuit, refer to “ Function to Protect Against Write due to Erroneous Instruction Recognition”. tCDS CS DE SI G N 4. 4 Standby Verify 1 2 DI 0 3 0 4 0 5 6 7 9 1 10 25 D0 D15 4Xs tSV NE High-Z DO 8 W SK tHZ1 Busy Ready High-Z tPR Chip Write Timing (S-93L46A) CS 2 DI 0 3 0 4 0 5 1 High-Z DO 6 7 8 9 D 1 10 11 tCDS 12 27 D15 D0 tSV tHZ1 Busy tPR Ready High-Z Chip Write Timing (S-93L56A, S-93L66A) NO T RE C OM M EN Figure 15 Standby Verify 6Xs DE SK FO R Figure 14 15 LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L46A/56A/66A Erasing chip (ERAL) To erase the data of the entire memory address space, set all the data to 1, change CS to high, and then input the ERAL instruction and an address following the start bit. Any address can be input. There is no need to input data. The chips erase operation starts when CS goes low. When the clocks more than the specified number have been input, the clock pulse monitoring circuit cancels the ERAL instruction. For details of the clock pulse monitoring circuit, refer to “ Function to Protect Against Write due to Erroneous Instruction Recognition”. CS DE SI G N 4. 5 Rev.8.1_02 1 2 3 4 DI 0 0 1 5 6 7 8 9 W SK 0 4Xs tHZ1 NE tSV High-Z DO Standby Verify tCDS Busy Ready High-Z Chip Erase Timing (S-93L46A) FO Figure 16 R tPR CS 2 3 4 DI 0 0 1 5 0 6 D 1 7 8 DE SK M DO EN 6Xs High-Z NO T RE C OM Figure 17 16 9 10 Standby Verify tCDS 11 tHZ1 tSV Busy tPR Chip Erase Timing (S-93L56A, S-93L66A) Ready High-Z LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L46A/56A/66A Rev.8.1_02 Write enable (EWEN) and write disable (EWDS) N 5. DE SI G The EWEN instruction is an instruction that enables a write operation. The status in which a write operation is enabled is called the program enable mode. The EWDS instruction is an instruction that disables a write operation. The status in which a write operation is disabled is called the program disable mode. After CS goes high, input an instruction in the order of the start bit, EWEN or EWDS instruction, and address (optional). Each mode becomes valid by inputting a low level to CS after the last address (optional) has been input. Standby CS 1 DI 2 3 4 5 6 7 8 0 0 11 = EWEN 00 = EWDS NE Write Enable / Disable Timing (S-93L46A) CS 1 DI 2 0 3 4 5 0 8 9 10 11 6Xs Write Enable / Disable Timing (S-93L56A, S-93L66A) EN Figure 19 7 DE 11 = EWEN 00 = EWDS 6 Standby D SK FO R Figure 18 4Xs 9 W SK NO T RE C OM M Remark It is recommended to execute an EWDS instruction for preventing an incorrect write operation if a write instruction is erroneously recognized when executing instructions other than write instruction, and immediately after power-on and before power-off. 17 LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L46A/56A/66A  Write Protect Function during the Low Power Supply Voltage N Rev.8.1_02 W DE SI G The S-93L46A/56A/66A provides a built-in detection circuit to detect a low power supply voltage. When the power supply voltage is low or at power-on, the write instructions (WRITE, ERASE, WRAL, and ERAL) are cancelled, and the write disable state (EWDS) is automatically set. The detection voltage and the release voltage are 1.4 V typ. (refer to Figure 20). Therefore, when a write operation is performed after the power supply voltage has dropped and then risen again up to the level at which writing is possible, a write enable instruction (EWEN) must be sent before a write instruction (WRITE, ERASE, WRAL, or ERAL) is executed. When the power supply voltage drops during a write operation, the data being written to an address at that time is not guaranteed. NE Power supply voltage Release voltage (VDET) 1.4 V typ. R Detection voltage (VDET) 1.4 V typ. Operation during Low Power Supply Voltage NO T RE C OM M EN DE D Figure 20 FO Write instructions are cancelled Write disable state (EWDS) is automatically set 18 LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L46A/56A/66A Rev.8.1_02 N  Function to Protect Against Write due to Erroneous Instruction Recognition DE SI G The S-93L46A/56A/66A provides a built-in clock pulse monitoring circuit which is used to prevent an erroneous write operation by canceling write instructions (WRITE, ERASE, WRAL, and ERAL) recognized erroneously due to an erroneous clock count caused by the application of noise pulses or double counting of clocks. Instructions are cancelled if a clock pulse more or less than specified number decided by each write operation (WRITE, ERASE, WRAL, or ERAL) is detected. Erroneous recognition of program disable instruction (EWDS) as erase instruction (ERASE) Example of S-93L46A W Noise pulse 1 2 3 4 SK 5 6 7 8 9 1 0 Erroneous recognition as ERASE instruction due to noise pulse 1 1 10 0 0 0 0 0 0 0 0 0 00 0 0 0 0 DE D Input EWDS instruction FO R DI NE CS M EN In products that do not include a clock pulse monitoring circuit, FFFFh is mistakenly written on address 00h. However the S-93L46A detects the overcount and cancels the instruction without performing a write operation. Example of Clock Pulse Monitoring Circuit Operation NO T RE C OM Figure 21 19 LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L46A/56A/66A Rev.8.1_02 N  3-Wire Interface (Direct Connection between DI and DO) DE SI G There are two types of serial interface configurations: a 4-wire interface configured using the CS, SK, DI, and DO pins, and a 3-wire interface that connects the DI input pin and DO output pin. When the 3-wire interface is employed, a period in which the data output from the CPU and the data output from the serial memory collide may occur, causing a malfunction. To prevent such a malfunction, connect the DI and DO pins of the S-93L46A/56A/66A via a resistor (10 k to 100 k) so that the data output from the CPU takes precedence in being input to the DI pin (refer to Figure 22). CPU SIO NE DI DO W S-93L46A/56A/66A R: 10 k to 100 k Figure 22 Connection of 3-Wire Interface Connection of input pins FO 1. R  Input Pin and Output Pin 2. DE D All input pins in S-93L46A/56A/66A have the CMOS structure. Do not set these pins in high impedance during operation when you design. Especially, set the CS pin to “L” at power-on, power-off, and during standby. The error write does not occur as long as the CS pin is “L”. Set the CS pin to GND via a resistor (the pull-down resistor of 10 k to 100 k). To prevent the error for sure, it is recommended to use equivalent pull-down resistors for input pins other than the CS pin. Equivalent circuit of input pin and output pin NO T RE C OM M EN The following shows the equivalent circuits of input pins of the S-93L46A/56A/66A. None of the input pins incorporate pull-up and pull-down resistors, so special care must be taken when designing to prevent a floating status. Output pins are high-level / low-level / high-impedance tri-state outputs. The TEST pin is disconnected from the internal circuit by a switching transistor during normal operation. As long as the absolute maximum rating is satisfied, the TEST pin and internal circuit will never be connected. 20 LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L46A/56A/66A Rev.8.1_02 Input pin CS CS Pin NE Figure 23 W DE SI G N 2. 1 DE D FO R SK, DI SK, DI Pin Figure 25 TEST Pin NO T RE C OM M TEST EN Figure 24 21 LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L46A/56A/66A Output pin N 2. 2 Rev.8.1_02 DE SI G VCC Input pin noise suppression time FO 3. DO Pin R Figure 26 NE W DO DE D This IC has a built-in low-pass filter at the SK pin, the DI pin and the CS pin to suppress noise. If the supply voltage is 5.0 V, noise with a pulse width of 20 ns or less at room temperature can be suppressed by the low-pass filter. Note that noise with a pulse width of more than 20 ns is recognized as a pulse since the noise can not be suppressed if the voltage exceeds VIH / VIL.  Precautions  Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic NO T RE C OM M EN protection circuit.  ABLIC Inc. claims no responsibility for any disputes arising out of or in connection with any infringement by products including this IC of patents owned by a third party. 22 LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L46A/56A/66A Rev.8.1_02 DC Characteristics 1. 2 VCC  3.3 V fSK  500 kHz DATA  0101 VCC  5.5 V fSK  2 MHz DATA  0101 0.4 0.4 ICC1 (mA) ICC1 (mA) 40 0 85 0 1. 4 VCC  1.8 V fSK  10 kHz DATA  0101 0.4 D ICC1 (mA) 0 85 Ta (C) EN 40 OM M Current consumption (READ) ICC1 vs. power supply voltage VCC RE C Ta  25C fSK  100 kHz, 10 kHz DATA  0101 100 kHz 1 MHz 0.2 DE 0.2 ICC1 (mA) Current consumption (READ) ICC1 vs. power supply voltage VCC FO 0.4 0.4 85 Ta  25C fSK  1 MHz, 500 kHz DATA  0101 ICC1 (mA) 1. 5 0 R Current consumption (READ) ICC1 vs. ambient temperature Ta 0 40 Ta (C) Ta (C) 1. 3 W 0.2 0.2 0 Current consumption (READ) ICC1 vs. ambient temperature Ta DE SI G Current consumption (READ) ICC1 vs. ambient temperature Ta  1. 1 NE 1. N  Characteristics (Typical Data) 500 kHz 0 2 3 4 5 6 7 VCC (V) 1. 6 Current consumption (READ) ICC1 vs. Clock frequency fSK VCC  5.0 V Ta  25C 0.4 ICC1 (mA) 0.2 0.2 0 10 kHz 2 NO T 0 3 4 5 6 7 10 k 100 k 1 M 2M 10M fSK (Hz) VCC (V) 23 LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L46A/56A/66A N Current consumption (WRITE) ICC2 vs. ambient temperature Ta DE SI G 1. 8 Current consumption (WRITE) ICC2 vs. ambient temperature Ta VCC  3.3 V VCC  5.5 V 1.0 0.5 ICC2 (mA) 0.5 ICC2 (mA) 0 40 0 0 85 40 Ta (C) 1. 10 Current consumption (WRITE) ICC2 vs. ambient temperature Ta FO VCC  2.7 V 1.0 Ta  25C 1.0 ICC2 (mA) D ICC2 (mA) 40 0 85 Ta (C) 1. 12 Current consumption in standby mode ISB vs. ambient temperature Ta OM VCC  5.5 V CS  GND ISB (A) 0.5 40 0 85 Ta (°C) NO T 0 RE C 1.0 2 3 4 5 6 7 VCC (V) M 1. 11 0.5 0 EN 0 DE 0.5 24 Current consumption (WRITE) ICC2 vs. power supply voltage VCC R 1. 9 0 85 Ta (C) NE 1.0 W 1. 7 Rev.8.1_02 Current consumption in standby mode ISB vs. power supply voltage VCC Ta  25C CS  GND ISB (A) 1.0 0.5 0 2 3 4 5 6 VCC (V) 7 1. 13 1. 14 Input leakage current ILI vs. ambient temperature Ta Input leakage current ILI vs. ambient temperature Ta DE SI G Rev.8.1_02 VCC  5.5 V CS, SK, DI, TEST  0 V VCC  5.5 V CS, SK, DI, TEST  5.5 V 1.0 1.0 ILI (A) ILI (A) 0 0 85 85 1. 16 Output leakage current ILO vs. ambient temperature Ta R Output leakage current ILO vs. ambient temperature Ta FO VCC  5.5 V DO  0 V VCC  5.5 V DO  5.5 V 1.0 1.0 ILO (A) ILO (A) 0.5 0 40 0 DE D 0.5 85 High-level output voltage VOH vs. ambient temperature Ta VCC  4.5 V IOH  400 A OM 4.6 RE C 4.4 4.2 40 0 85 40 0 85 Ta (°C) 1. 18 2.7 VOH (V) High-level output voltage VOH vs. ambient temperature Ta VCC  2.7 V IOH  100 A 2.6 2.5 40 0 85 Ta (C) NO T Ta (C) 0 M 1. 17 EN Ta (C) VOH (V) 0 Ta (C) Ta (C) 1. 15 40 NE 40 W 0.5 0.5 0 N LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L46A/56A/66A 25 LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L46A/56A/66A VCC  2.5 V IOH  100 A 2.5 VOH (V) 2.4 N 1.8 0 85 40 Ta (C) 1. 21 0 85 Ta (C) Low-level output voltage VOL vs. ambient temperature Ta 1. 22 Low-level output voltage VOL vs. ambient temperature Ta VCC  1.8 V IOL  100 A R VCC  4.5 V IOL  2.1 mA 0.03 FO 0.3 W 1.7 40 0.2 VOL 0.02 (V) 40 0 85 EN Ta (C) 1. 23 High-level output current IOH vs. ambient temperature Ta OM 20.0 IOH (mA) 0 RE C 10.0 40 0 NO T Ta (C) 40 85 0 85 Ta (C) 1. 24 High-level output current IOH vs. ambient temperature Ta VCC  2.7 V VOH  2.4 V M VCC  4.5 V VOH  2.4 V 0.01 DE D 0.1 26 VCC  1.8 V IOH  10 A 1.9 2.3 VOL (V) High-level output voltage VOH vs. ambient temperature Ta NE VOH (V) 1. 20 High-level output voltage VOH vs. ambient temperature Ta DE SI G 1. 19 Rev.8.1_02 2 IOH (mA) 1 0 40 0 85 Ta (C) 1. 25 High-level output current IOH vs. ambient temperature Ta 1. 26 High-level output current IOH vs. ambient temperature Ta DE SI G Rev.8.1_02 VCC  2.5 V VOH  2.2 V VCC  1.8 V VOH  1.6 V 2 1.0 IOH (mA) IOH (mA) 1 0 40 0 40 85 Ta (C) 1. 27 W 0.5 0 85 Ta (C) Low-level output current IOL vs. ambient temperature Ta 1. 28 NE 0 N LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L46A/56A/66A Low-level output current IOL vs. ambient temperature Ta VCC  1.8 V VOL  0.1 V R VCC  4.5 V VOL  0.4 V 1.0 FO 20 IOL (mA) IOL (mA) 0.5 Input inverted voltage VINV vs. power supply voltage VCC Ta  25C CS, SK, DI 3.0 OM VINV (V) 0 RE C 1.5 1 2 3 4 5 6 7 0 1. 30 40 0 85 Ta (C) Input inverted voltage VINV vs. ambient temperature Ta VCC  5.0 V CS, SK, DI 3.0 VINV (V) 2.0 0 40 0 Ta (C) 85 NO T VCC (V) DE 0 85 Ta (C) EN 1. 29 40 M 0 D 10 27 LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L46A/56A/66A +VDET (V) 1.0 0 0 85 Ta (C) AC Characteristics Maximum operating frequency fMAX. vs. power supply voltage VCC 2M 1M 4 D tPR (ms) DE 100k 3 4 5 VCC (V) 40 0 NO T Ta (C) 28 2. 4 M RE C 4 OM 6 85 2 3 4 5 6 7 VCC (V) Write time tPR vs. ambient temperature Ta VCC  5.0 V 2 1 EN 2 1 2 Write time tPR vs. power supply voltage VCC Ta  25C 10k tPR (ms) 85 R 2. 2 Ta  25C 2. 3 0 Ta (C) FO 2. 1 -40 NE -40 W 1.0 0 fMAX. (Hz) N 2.0 2.0 -VDET (V) 2. Low power supply release voltage VDET vs. ambient temperature Ta 1. 32 DE SI G Low power supply detection voltage VDET vs. ambient temperature Ta 1. 31 Rev.8.1_02 Write time tPR vs. ambient temperature Ta VCC  3.0 V tPR (ms) 6 4 2 40 0 Ta (C) 85 2. 6 Write time tPR vs. ambient temperature Ta Data output delay time tPD vs. ambient temperature Ta VCC  2.7 V 6 tPD (s) 4 0.3 0.2 2 0.1 40 0 85 40 Ta (C) 2. 7 Data output delay time tPD vs. ambient temperature Ta 2. 8 VCC  2.7 V 85 Data output delay time tPD vs. ambient temperature Ta 0.6 tPD (s) R VCC  1.8 V 1.5 FO tPD (s) 0 Ta (C) NE tPR (ms) VCC  4.5 V W 2. 5 DE SI G Rev.8.1_02 N LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L46A/56A/66A 0.4 1.0 0.2 40 0 DE D 0.5 85 40 0 85 Ta (C) NO T RE C OM M EN Ta (C) 29 LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L46A/56A/66A Rev.8.1_02 Product name 1. 1 8-Pin SOP (JEDEC), 8-Pin TSSOP S-93LxxA x 0I - xxxx DE SI G 1. N  Product Name Structure x Environmental code U: Lead-free (Sn 100%), halogen-free G: Lead-free (for details, please contact our sales office) W Package name (abbreviation) and IC packing specifications J8T1: 8-Pin SOP (JEDEC), Tape T8T1: 8-Pin TSSOP, Tape Fixed NE Pin configurations D: 8-Pin SOP (JEDEC) 8-Pin TSSOP R: 8-Pin SOP (JEDEC) (Rotated) TMSOP-8, SNT-8A S-93LxxA D0I - xxxx U D 1. 2 FO R Product name S-93L46A: 1 K-bit S-93L56A: 2 K-bit S-93L66A: 4 K-bit Packages RE C 2. OM M EN DE Environmental code U: Lead-free (Sn 100%), halogen-free Package Name 8-Pin SOP (JEDEC) 8-Pin TSSOP NO T TMSOP-8 SNT-8A Environmental code = G Environmental code = U Environmental code = G Environmental code = U 30 Package name (abbreviation) and IC packing specifications K8T3: TMSOP-8, Tape I8T1: SNT-8A, Tape Fixed Product name S-93L46A: 1 K-bit S-93L56A: 2 K-bit S-93L66A: 4 K-bit Drawing Code Package Tape Reel FJ008-A-P-SD FJ008-A-P-SD FT008-A-P-SD FT008-A-P-SD FM008-A-P-SD PH008-A-P-SD FJ008-D-C-SD FJ008-D-C-SD FT008-E-C-SD FT008-E-C-SD FM008-A-C-SD PH008-A-C-SD FJ008-D-R-SD FJ008-D-R-S1 FT008-E-R-SD FT008-E-R-S1 FM008-A-R-SD PH008-A-R-SD Land    PH008-A-L-SD 1 4 DE SI G 5 NE W 8 N 5.02±0.2 DE D FO R 0.20±0.05 1.27 NO T RE C OM M EN 0.4±0.05 No. FJ008-A-P-SD-2.2 TITLE SOP8J-D-PKG Dimensions FJ008-A-P-SD-2.2 No. ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches:40.0±0.2) N 2.0±0.05 ø1.55±0.05 2.1±0.1 FO R NE 8.0±0.1 ø2.0±0.05 W DE SI G 0.3±0.05 5 Feed direction NO T RE C OM M 4 8 EN 1 DE D 6.7±0.1 No. FJ008-D-C-SD-1.1 TITLE SOP8J-D-Carrier Tape No. FJ008-D-C-SD-1.1 ANGLE UNIT mm ABLIC Inc. N DE SI G FO R NE W 60° D 13.5±0.5 2±0.5 ø13±0.2 NO T RE C OM M EN ø21±0.8 DE Enlarged drawing in the central part 2±0.5 No. FJ008-D-R-SD-1.1 TITLE SOP8J-D-Reel No. FJ008-D-R-SD-1.1 QTY. ANGLE UNIT mm ABLIC Inc. 2,000 N DE SI G FO R NE W 60° D 13.5±0.5 2±0.5 ø13±0.2 NO T RE C OM M EN ø21±0.8 DE Enlarged drawing in the central part 2±0.5 No. FJ008-D-R-S1-1.0 TITLE SOP8J-D-Reel No. FJ008-D-R-S1-1.0 QTY. ANGLE UNIT mm ABLIC Inc. 4,000 N +0.3 5 1 4 R NE W 8 DE SI G 3.00 -0.2 DE D FO 0.17±0.05 EN 0.2±0.1 NO T RE C OM M 0.65 No. FT008-A-P-SD-1.2 TITLE TSSOP8-E-PKG Dimensions No. FT008-A-P-SD-1.2 ANGLE UNIT mm ABLIC Inc. 4.0±0.1 2.0±0.05 ø1.55±0.05 +0.1 8.0±0.1 NE ø1.55 -0.05 W DE SI G N 0.3±0.05 FO R (4.4) +0.4 EN DE D 6.6 -0.2 8 M 1 4 NO T RE C OM 5 Feed direction No. FT008-E-C-SD-1.0 TITLE TSSOP8-E-Carrier Tape FT008-E-C-SD-1.0 No. ANGLE UNIT mm ABLIC Inc. N DE SI G W NE R FO D 17.5±1.0 2±0.5 ø13±0.5 NO T RE C OM M EN ø21±0.8 DE Enlarged drawing in the central part 13.4±1.0 No. FT008-E-R-SD-1.0 TITLE TSSOP8-E-Reel No. FT008-E-R-SD-1.0 QTY. ANGLE UNIT mm ABLIC Inc. 3,000 N DE SI G W NE R FO D 17.5±1.0 2±0.5 ø13±0.5 NO T RE C OM M EN ø21±0.8 DE Enlarged drawing in the central part 13.4±1.0 No. FT008-E-R-S1-1.0 TITLE TSSOP8-E-Reel FT008-E-R-S1-1.0 No. QTY. ANGLE UNIT mm ABLIC Inc. 4,000 N DE SI G 2.90±0.2 5 1 4 NE W 8 D FO R 0.13±0.1 0.2±0.1 NO T RE C OM M EN DE 0.65±0.1 No. FM008-A-P-SD-1.2 TITLE TMSOP8-A-PKG Dimensions No. FM008-A-P-SD-1.2 ANGLE UNIT mm ABLIC Inc. 2.00±0.05 1.00±0.1 N 4.00±0.1 +0.1 1.5 -0 NE W DE SI G 4.00±0.1 1.05±0.05 FO R 0.30±0.05 1 EN 4 DE D 3.25±0.05 8 Feed direction NO T RE C OM M 5 No. FM008-A-C-SD-2.0 TITLE TMSOP8-A-Carrier Tape FM008-A-C-SD-2.0 No. ANGLE UNIT mm ABLIC Inc. N FO R NE W DE SI G 16.5max. 13±0.2 OM M EN Enlarged drawing in the central part DE D 13.0±0.3 NO T RE C (60°) (60°) No. FM008-A-R-SD-1.0 TITLE TMSOP8-A-Reel No. FM008-A-R-SD-1.0 QTY. ANGLE UNIT mm ABLIC Inc. 4,000 6 5 3 4 DE SI G 7 W 8 N 1.97±0.03 +0.05 0.5 2 0.08 -0.02 NO T RE C OM M EN DE 0.2±0.05 D FO R 0.48±0.02 NE 1 No. PH008-A-P-SD-2.1 TITLE SNT-8A-A-PKG Dimensions No. PH008-A-P-SD-2.1 ANGLE UNIT mm ABLIC Inc. N DE SI G W ø0.5±0.1 4.0±0.1 0.25±0.05 0.65±0.05 D FO R 2.25±0.05 4.0±0.1 2.0±0.05 NE +0.1 ø1.5 -0 DE 4 321 EN 5 6 78 NO T RE C OM M Feed direction No. PH008-A-C-SD-2.0 TITLE SNT-8A-A-Carrier Tape No. PH008-A-C-SD-2.0 ANGLE UNIT mm ABLIC Inc. FO R NE W DE SI G N 12.5max. D 9.0±0.3 DE Enlarged drawing in the central part EN ø13±0.2 (60°) NO T RE C OM M (60°) No. PH008-A-R-SD-1.0 TITLE SNT-8A-A-Reel No. PH008-A-R-SD-1.0 QTY. ANGLE UNIT mm ABLIC Inc. 5,000 DE SI G N 0.52 2 NE W 2.01 FO R 0.52 0.2 0.3 (0.25 mm min. / 0.30 mm typ.) (1.96 mm ~ 2.06 mm) D 1. 2. 1 3. 4. 0.03 mm DE 1. 2. SNT EN 1. Pay attention to the land pattern width (0.25 mm min. / 0.30 mm typ.). 2. Do not widen the land pattern to the center of the package (1.96 mm to 2.06mm). (0.25 mm min. / 0.30 mm typ.) (1.96 mm ~ 2.06 mm) NO T RE C 1. 2. OM M Caution 1. Do not do silkscreen printing and solder printing under the mold resin of the package. 2. The thickness of the solder resist on the wire pattern under the package should be 0.03 mm or less from the land pattern surface. 3. Match the mask aperture size and aperture position with the land pattern. 4. Refer to "SNT Package User's Guide" for details. No. PH008-A-L-SD-4.1 TITLE SNT-8A-A -Land Recommendation PH008-A-L-SD-4.1 No. ANGLE UNIT mm ABLIC Inc. Disclaimers (Handling Precautions) All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not responsible for damages caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not responsible for damages caused by the incorrect information described herein. 4. Be careful to use the products within their specified ranges. Pay special attention to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not responsible for damages caused by failures and / or accidents, etc. that occur due to the use of the products outside their specified ranges. 5. When using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products must not be used or provided (exported) for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not responsible for any provision (export) to those whose purpose is to develop, manufacture, use or store nuclear, biological or chemical weapons, missiles, or other military use. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses. Do not apply the products to the above listed devices and equipments without prior written permission by ABLIC Inc. Especially, the products cannot be used for life support devices, devices implanted in the human body and devices that directly affect human life, etc. Prior consultation with our sales office is required when considering the above uses. ABLIC Inc. is not responsible for damages caused by unauthorized or unspecified use of our products. 9. Semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system must be sufficiently evaluated and applied on customer's own responsibility. EN DE D FO R NE W DE SI G N 1. M 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. OM 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. RE C 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party without the express permission of ABLIC Inc. is strictly prohibited. T 14. For more details on the information described herein, contact our sales office. NO 2.0-2018.01 www.ablicinc.com
S-93L66AD0I-K8T3U 价格&库存
很抱歉,暂时无法提供与“S-93L66AD0I-K8T3U”相匹配的价格&库存,您可以联系我们找货
