NJM2740M-TE1
NJM2740M-TE1
    JRC(⽇本无线)
    DMP8_5X5MM
    IC OPAMP GP 2 CIRCUIT 8DMP
NJM2740M-TE1 数据手册
NJM2740 Dual Operational Amplifier FEATURES (V+/V-=±2.5V, typical value) ●Low Noise ●High Slew Rate ●Wide Bandwidth ●Low Distortion ●Supply Voltage Dual Supply Single Supply ●Low Saturation (RL=2.5kΩ) ●Operating Temperature ●Bipolar Technology ●Package Outline DESCRIPTION 6.5n/√Hz 4V/μs 12MHz 0.002% The NJM2740 is a dual low saturation output operational amplifier featuring low noise of 6.5nV/√Hz. ±1.1V to ±3.5V 2.2V to 7V ±2.2V typ. -40°C to 125°C Low operating voltage single 2.2V to 7V or dual ±1.1V to ±3.5V and low saturation output performance makes NJM2740 suitable for Battery-powered instruments, portable audio devices that require a low voltage and low saturation output. DMP8, SSOP8, MSOP8 (TVSP8)* *meet JEDEC MO-187-DA / thin type It can be used both single supply and dual supply, by using proper bias voltage. The NJM2740 is available in 8-pin DMP, SSOP and MSOP(TVSP): meet JEDEC MO-187-DA / thin type package. APPLICATIONS ●Portable Audio ●PC Audio ●AD/DA Converter Buffer ●Active Filter TYPICAL CHARACTERISTICS EQUIVALENT CIRCUIT Equivalent Input Noise Voltage [nV/√Hz] Voltage Noise Density vs. Frequency V+=5V, Ta=25°C 24 18 12 6 - 0 1 Ver.02 10 100 1k Frequency [Hz] 10k 100k http://www.njr.com/ -1- NJM2740 ■ PIN CONFIGURATION (Top View) A OUTPUT 1 8 V+ A -INPUT 2 7 B OUTPUT A +INPUT 3 6 B -INPUT V- 4 5 B +INPUT Pin Function Package DMP8 SSOP8 MSOP8(TVSP8) Product Name NJM2740M NJM2740V NJM2740RB1 ■ PRODUCT NAME INFORMATION NJM2740 RB1 Part Number (TE1) Package Taping Form ■ ORDER INFORMATION Package Part Number Outline RoHS Halogen- Terminal Free Finish Marking Weight MOQ (mg) (pcs) NJM2740M DMP8 ○ ○ Sn2Bi 2740 95 2000 NJM2740V SSOP8 ○ ○ Sn2Bi 2740 42 2000 MSOP8(TVSP8) ○ ○ Sn2Bi 2740 18 2000 NJM2740RB1 ■ ABSOLUTE MAXIMUM RATINGS (Ta=25°C) PARAMETER Supply Voltage (1) Input Voltage (1)(2) Differential Input Voltage (3) Input Current SYMBOL RATING UNIT + V /V ±4 V VIN ±4 V VID ±8 V 1 mA - IIN (4) Power Dissipation DMP8 SSOP8 MSOP8(TVSP8) Storage Temperature Range (2-Layer / 4-Layer) PD 470 / 600 410 / 510 510 / 680 mW Tstg -40 to +150 °C (1) For supply voltage less than ±4V (8V), the absolute maximum rating is equal to the supply voltage. (2) Differential voltage is the voltage difference between +INPUT and -INPUT. (3) Input voltages outside the supply voltage will be clamped by ESD protection diodes. If the input voltage exceeds the supply voltage, the input current must be limited 1mA or less by using a restriction resistance. (4) Power dissipation is the power that can be consumed by the IC at Ta=25°C, and is the typical measured value based on JEDEC condition. 2-layer: Mounted on glass epoxy board. (76.2×114.3×1.6mm: based on EIA/JDEC standard, 2Layers FR4) 4-layer: Mounted on glass epoxy board. (76.2×114.3×1.6mm: based on EIA/JDEC standard, 4Layers FR4), internal Cu area: 74.2 x 74.2mm Ver.02 http://www.njr.com/ -2- NJM2740 ■ THERMAL CHARACTERISTICS Package SYMBOL Junction-to-ambient thermal resistance VALUE UNIT (2-layer / 4-Layer) DMP8 SSOP8 TVSP8 262 / 206 288 / 230 244 / 185 Θja Junction-to-top of package characterization parameter °C/W (2-layer / 4-Layer) DMP8 SSOP8 TVSP8 72 / 65 46 /45 51 /45 °C/W SYMBOL VALUE UNIT V /V + V -V + ±1.1 to ±3.5 2.2 to 7 V V Topr -40 to 125 °C Ψjt ■ RECOMMENDED OPERATING CONDITIONS (Ta=25°C) PARAMETER Supply Voltage Dual Supply Single Supply Operating Temperature Range + - - ■ ELECTRICAL CHARACTERISTICS (V /V =±2.5V, Ta=25°C) PARAMETER SYMBOL TEST CONDITION MIN. TYP. MAX. UNIT - 1 6 mV DC CHARACTERISTICS Input Offset Voltage VIO RS≤10kΩ Input Bias Current IB - 100 300 nA Input Offset Current IIO - 5 100 nA 60 60 -1.4 /+1.5 80 74 - dB dB - - V Open-Loop Voltage Gain Common-Mode Rejection Ratio Common-Mode Input Voltage Range AV CMR RL≥10kΩ VICM RL≥2.5kΩ ±2 ±2.2 - V Supply Current (All Amplifiers) Supply Voltage Rejection Ratio AC CHARACTERISTICS Slew Rate Gain Bandwidth Product ISUPPLY SVR No Signal, RL=∞ + V /V =±1.1V to ±3.5V 60 3.5 80 5 - mA dB SR GBW AV=1, VIN=±1V f=10kHz - 4 12 - V/μs MHz Total Harmonic Distortion + Noise THD+N f=1kHz, VO=1Vrms - 0.002 - % f=1kHz - 6.5 - nV/√Hz Maximum Output Voltage Equivalent Input Noise Voltage Ver.02 VOM en http://www.njr.com/ -3- NJM2740 ■ TYPICAL CHARACTERISTICS Supply Current (All Amplifiers) vs. Supply Voltage Supply Current (All Amplifiers) [mA] Supply Current (All Amplifiers) vs. Temperature RL= 7 Ta=25°C 6 5 4 Ta=125°C 3 2 VCOM=V+/2, RL= 8 Supply Current (All Amplifiers) [mA] VCOM 8 =V+/2, Ta=-40°C 1 0 7 V+=7V 6 5 V+=5V 4 3 2 V+=2.2V 1 0 0 1 2 3 4 5 6 Supply Voltage V+ [V] 7 8 -50 Input Offset Voltage vs. Temperature 4 V+=2.2V 3 Input Offset Voltage [mV] Input Offset Voltage [mV] VCOM=V+/2 5 4 V+=5V 2 1 0 V+=7V -1 -2 Ta=-40°C 3 Ta=25°C 2 1 0 -1 Ta=125°C -2 -3 -3 -50 -25 0 25 50 75 100 125 150 Ambient Temperature [°C] 0 Input Offset Voltage vs. Common-Mode Input Voltage 2 3 4 5 6 Supply Voltage V+ [V] 7 8 V+=5V 5 4 Input Offset Voltage [mV] 4 Input Offset Voltage [mV] 1 Input Offset Voltage vs. Common-Mode Input Voltage V+=2.2V 5 3 2 1 0 Ta=-40°C Ta=125°C Ta=25°C -1 -2 Ta=-40°C 3 2 1 0 -1 Ta=125°C Ta=25°C -2 -3 -3 0.5 Ver.02 0 25 50 75 100 125 150 Ambient Temperature [°C] Input Offset Voltage vs. Supply Voltage VCOM=V+/2 5 -25 0.7 0.9 1.1 1.3 1.5 1.7 Common-Mode Input Voltage [V] 1.9 0.5 http://www.njr.com/ 1 1.5 2 2.5 3 3.5 4 4.5 Common-Mode Input Voltage [V] 5 -4- NJM2740 ■ TYPICAL CHARACTERISTICS Input Offset Voltage vs. Common-Mode Input Voltage V+=7V 120 Common-Mode and Supply Voltage Rejection Ratio [dB] 5 Input Offset Voltage [mV] 4 Ta=25°C 3 Ta=-40°C 2 1 0 -1 Common-Mode and Supply Voltage Rejection Ratio vs. Temperature Ta=125°C -2 110 100 CMR(V+/V-=±2.5V) 90 80 70 60 SVR 50 40 -3 0 1 2 3 4 5 6 Common-Mode Input Voltage [V] -50 7 Open-Loop Voltage Gain vs. Temperature V+/V-=±2.5V, GV=OPEN, RL=10kΩ 180 110 100 90 80 70 60 120 80 60 40 0 0 25 50 75 100 125 150 Ambient Temperature [°C] V+=5V V+=7V 10 0 -10 V+=2.2V -20 -30 -40 -25 0 25 50 75 100 125 150 Ambient Temperature [°C] Maximum Output Voltage vs. Output Resistance V+/V-=±2.5V, GV=OPEN 3.0 Maximum Output Voltage [V] 20 V+=2.2V -50 Input Offset Current vs. Temperature 30 V+=5V 100 20 -25 V+=7V 140 40 40 Input Offset Current [nA] 160 50 -50 Ta=-40°C 2.0 +VOM Ta=25°C Ta=125°C 1.0 0.0 -1.0 -2.0 -VOM -3.0 -50 Ver.02 0 25 50 75 100 125 150 Ambient Temperature [°C] Input Bias Currentvs. Temperature 200 Input Bias Current [nA] Open-Loop Voltage Gain [dB] 120 -25 -25 0 25 50 75 100 125 150 Ambient Temperature [°C] 0.1 http://www.njr.com/ 1 10 Output Resistance [kΩ] 100 -5- NJM2740 ■ TYPICAL CHARACTERISTICS Maximum Output Voltage vs. Temperature +VOM 1.0 0.0 -1.0 -VOM -2.0 -3.0 -50 -25 3 Ta=125°C +VOM 2 1 Ta=25°C 0 Ta=-40°C -1 -2 Ta=125°C -4 ±0.5 0 25 50 75 100 125 150 Ambient Temperature [°C] 40dB Gain/Phase vs. Frequency Gain Ta=-40°C 40 Phase 0 -20 -60 Ta=-40°C Voltage Gain [dB] Ta=125°C 20 -40 Ta=25°C Ta=125°C 20 Phase 0 0 -20 -120 -40 -180 100M -60 Ta=25°C -60 Ta=-40°C Ta=25°C 1k 10k 100k 1M Frequency [Hz] 10M 1k 40dB Gain/Phase vs. Frequency Gain 100k 1M Frequency [Hz] 10M -180 100M RL=2.5kΩ, CL=0pF, Ta=25°C 60 Gain Ta=-40°C 40 10k 40dB Gain/Phase vs. Frequency V+=7V, RL=2.5kΩ, CL=0pF 60 -120 Ta=125°C Ta=125°C -60 ±4.0 V+=5V, RL=2.5kΩ, CL=0pF Gain Ta=-40°C Ta=25°C 0 ±1.5 ±2.0 ±2.5 ±3.0 ±3.5 Supply Voltage V+/V- [V] 60 Phase [deg] Voltage Gain [dB] 40 ±1.0 40dB Gain/Phase vs. Frequency V+=2.2V, RL=2.5kΩ, CL=0pF 60 -VOM -3 Phase [deg] 2.0 GV=OPEN, RL=2.5kΩ 4 Maximum Output Voltage [V] Maximum Output Voltage [V] Maximum Output Voltage vs. Supply Voltage V+/V-=±2.5V, GV=OPEN, RL=2.5kΩ 3.0 V+-2.2V 40 Ta=25°C -20 -60 Ta=-40°C Ta=25°C -40 20 V+=7V Phase 0 0 -20 -120 -40 -180 100M -60 Ver.02 10k 100k 1M Frequency [Hz] -120 V+=5V Ta=125°C V+=7V -60 1k -60 V+=2.2V Phase [deg] 0 Voltage Gain [dB] Phase 0 Phase [deg] Voltage Gain [dB] V+-5V Ta=125°C 20 10M 1k http://www.njr.com/ 10k 100k 1M Frequency [Hz] 10M -180 100M -6- NJM2740 ■ TYPICAL CHARACTERISTICS Pulse Response THD+N vs. Output Voltage V+/V-=±2.5V, Gain=0dB, f=100kHz, RL=10kΩ, CL=0pF V+=5V, GV=10dB, RL=4.7kΩ, Filter=10Hz~80kHz, Ta=25°C 1 Ta=125°C Ta=25°C OUTPUT 0.1 THD+N [%] Voltage [1V/div] INPUT f=20Hz f=1kHz 0.01 Ta=-40°C f=20kHz 0.001 0.01 Time [1μs/div] Equivalent Input Noise Voltage [µV] Equivalent Input Noise Voltage [nV/√Hz] V+/V-=±3.0V ,RF=100kΩ,RG=100Ω,JIS A,Ta=25°C V+=5V, Ta=25°C 18 12 6 0 1 10 100 1k Frequency [Hz] 10k 100k 10 1 0.1 0.01 CL=470pF 5 CL=100pF 0 CL=0pF Phase Margin [deg] Voltage Gain[dB] 100 70 60 50 40 30 20 10 0 -10 1.E+06 1.E+07 1.E+08 1 10 100 1000 10000 Load Capacitance [pF] Frequency [Hz] Ver.02 10 V+/V-=±2.5V ,GV=40dB, RF=100KΩ,RG=1kΩ,RL=2.5kΩ,Ta=+25°C 80 10 1.E+05 1 Phase Margin vs. Load Capacitance V+/V-=2.5V, GV=0dB,RS=50Ω, RL=10KΩ, Ta=+25°C 15 -5 0.1 Input Resistance [kΩ] Peak Gain of Voltege Follower 20 10 Equivalent Input Noise Voltage vs. Input Resistance Voltage Noise Density vs. Frequency 24 0.1 1 Output Voltage [Vrms] http://www.njr.com/ -7- NJM2740 ■ TEST CIRCUIT ● Supply current ● Input offset voltage V+ 50kΩ A V+ 50Ω VO 50Ω V- V- 50kΩ ● Maximum output voltage ● GBW +Vom; Vin+ = 1V, Vin- = -1V -Vom; Vin+ = -1V, Vin- = 1V 100kΩ V+ V+ 1kΩ VO VO RL Vin+ Vin- 50Ω V- V- 2.5kΩ CL ● Slew rate 90% V+ Vo VO 50Ω Ver.02 V- RL 90% ΔV ΔV 10% Δt Δt 10% CL http://www.njr.com/ -8- NJM2740 ■ APPLICATION NOTE Single and Dual Supply Voltage Operation The NJM2740 works with both single supply and dual + − supply when the voltage supplied is between V and V . These amplifiers operate from single 2.2 to 7V supply and dual ±1.1V to ±3.5V supply. V+ Current Limit 1mA Vin Vout RLIMIT Common-Mode Input Voltage Range When the supply voltage does not meet the condition of electrical characteristics, the range of common-mode input voltage is as follows: − + VICM (typ.) = V +1.1V to V -1V (Ta = 25°C) Difference of VICM when Temperature change, refer to typical characteristic graph. During designing, consider variations in characteristics for use with allowance. Maximum Output Voltage Range When the supply voltage does not meet the condition of electrical characteristics, the range of the typ. value of the maximum output voltage is as follows: - + VOM (typ.) = V +0.3V to V -0.3V (RL=2.5kΩ to V+/2, Ta=25°C) During designing, consider variations in characteristics and temperature characteristics for use with allowance. In addition, also note that the output voltage range becomes narrow as shown in typical characteristics graph when an output current increases. Input Voltage Exceeding the Supply Voltage Inputs of the NJM2740 are protected by ESD diodes (shown in Figure1) that will conduct if the input voltages exceed the power supplies by more than approximately 300mV. Momentary voltages greater than 300mV beyond the power supply, inputs can be tolerated if the current is limited to 1mA. Figure2 is easily accomplished with an input resistor. If the input voltage exceeds the supply voltage, the input current must be limited 1mA or less by using a restriction resistance (RLIMIT) as shown in figure2. VFigure2. Input Current Protection for Voltages exceeding the Supply Voltage. Capacitive load The NJM2740 can use at unity gain follower, but the unity gain follower is the most sensitive configuration to capacitive loading. The combination of capacitive load placed directly on the output of an amplifier along with the output impedance of the amplifier creates a phase lag which in turn reduces the phase margin of the amplifier. If phase margin is significantly reduced, the response will cause overshoot and ringing in the step response. It is 30 degree phase margin at 1000pF capacitive load. To drive heavy capacitive loads, an isolation resistor, RISO as shown Figure3, should be used. RISO improves the feedback loop’s phase margin by making the output load resistive at higher frequencies. The larger the value of RISO, the more stable the output voltage will be. However, larger values of RISO result in reduced output swing, reduced output current drive and reduced frequency bandwidth. V+ R ISO Vin Vout C L V- V+ Figure3. Isolating capacitive load +INPUT OUTPUT -INPUT V- Figure1. Simplified Schematic Ver.02 http://www.njr.com/ -9- NJM2740 DMP8 Unit: mm ■PACKAGE DIMENSIONS 0 ∼10 ° 5.0 ±0.3 1 4 0.15 +0.1 -0.05 1.27 0.15 ±0.1 1.6 ± 0.15 0.74max 0.5 ± 0.2 6.8 ± 0.3 5 5.0 ±0.2 8 0.1 0.35 ±0.1 0.12 M ■EXAMPLE OF SOLDER PADS DIMENSIONS 1.27 6 .1 0 1 . 27 0.72 3.81 Ver.02 http://www.njr.com/ - 10 - NJM2740 SSOP8 Unit: mm ■PACKAGE DIMENSIONS 3.5 +0.3 -0.1 0 ∼ 10 ° 8 0. 5 ± 0. 2 6. 4 ± 0. 3 4 .4 ±0 .2 5 4 1. 15 ±0 .1 0.65 0.1 0.22 ±0.1 0.1 M 0.15 +0.1 -0.05 0. 1 ±0 . 1 1 0.9max ■EXAMPLE OF SOLDER PADS DIMENSIONS 0.65 5 .9 0 1. 0 0.35 1.95 Ver.02 http://www.njr.com/ - 11 - NJM2740 MSOP8 JEDEC MO-187-DA/THIN TYPE Unit: mm ■PACKAGE DIMENSIONS 2.9 ±0.1 0 ∼10゚ 1 0 .5 5 ±0 .1 4. 0 ±0 .2 5 2. 8 ±0 .1 8 4 0.127 +0.05 -0.03 0.65 0.08 0.2 ±0.05 0.05 M 0. 1 ±0 .0 5 1. 0m ax 0.475 ±0.1 ■EXAMPLE OF SOLDER PADS DIMENSIONS 0.65 3. 5 1 .0 0.23 1.95 Ver.02 http://www.njr.com/ - 12 - NJM2740 DMP8 Unit: mm ■PACKING SPEC TAPING DIMENSIONS φ D0 P1 φD1 SYMBOL A B D0 D1 E F P0 P1 P2 T T2 W W1 T B W1 W F P0 E F ee d d ir e c t io n P2 A T2 DIMENSION 7.1 5.4 1.55±0.05 2.05±0.1 1.75±0.1 7.5±0.1 4.0±0.1 12.0±0.1 2.0±0.1 0.3±0.05 2.3 16.0±0.3 13.5 REMARKS BOTTOM DIMENSION BOTTOM DIMENSION THICKNESS 0.1max REEL DIMENSIONS W1 SYMBOL A B C D E W W1 E A D B C DIMENSION φ330±2 φ 80±1 φ 13±0.2 φ 21±0.8 2±0.5 17.5±0.5 2±0.2 W TAPING STATE Insert direction Sealing with covering tape (TE1) Empty tape Feed direction Empty tape Devices more than 20pitch 2000pcs/reel more than 20pitch Covering tape reel more than 1round PACKING STATE Label Label Put a reel into a box Ver.02 http://www.njr.com/ - 13 - NJM2740 SSOP8 Unit: mm ■PACKING SPEC TAPING DIMENSIONS Fe ed di re ct io n P2 P0 φD0 SYMBOL A B D0 D1 E F P0 P1 P2 T T2 W W1 W1 B W F E T P1 A φD1 T2 DIMENSION 6.7 3.9 1.55±0.05 1.55±0.1 1.75±0.1 5.5±0.05 4.0±0.1 8.0±0.1 2.0±0.05 0.3±0.05 2.2 12.0±0.3 9.5 REMARKS BOTTOM DIMENSION BOTTOM DIMENSION THICKNESS 0.1max REEL DIMENSIONS W1 SYMBOL A B C D E W W1 B D A C E DIMENSION φ254±2 φ100±1 φ 13±0.2 φ 21±0.8 2±0.5 13.5±0.5 2±0.2 W TAPING STATE Insert direction Sealing with covering tape (TE1) Empty tape Feed direction more than 20pitch Devices 2000pcs/reel Empty tape Covering tape more than 20pitch reel more than 1round PACKING STATE Label Label Put a reel into a box Ver.02 http://www.njr.com/ - 14 - NJM2740 MSOP8 MEET JEDEC MO-187-DA/THIN TYPE Unit: mm ■PACKING SPEC TAPING DIMENSIONS Feed direction P2 P0 φD0 SYMBOL A B D0 D1 E F P0 P1 P2 T T2 W W1 B W1 W F E T A P1 T2 φD1 DIMENSION 4.4 3.2 1.5 +0.1 0 1.5 +0.1 0 1.75±0.1 5.5±0.05 4.0±0.1 8.0±0.1 2.0±0.05 0.30±0.05 1.75 (MAX.) 12.0±0.3 9.5 REMARKS BOTTOM DIMENSION BOTTOM DIMENSION THICKNESS 0.1max REEL DIMENSIONS W1 SYMBOL A B C D E W W1 B D A C E DIMENSION φ254±2 φ100±1 φ 13±0.2 φ 21±0.8 2±0.5 13.5±0.5 2.0±0.2 W TAPING STATE Insert direction Sealing with covering tape (TE1) Devices Empty tape Feed direction more than 20pitch 2000pcs/reel Empty tape Covering tape more than 20pitch reel more than 1round PACKING STATE Label Label Put a reel into a box Ver.02 http://www.njr.com/ - 15 - NJM2740 ■ RECOMMENDED MOUNTING METHOD INFRARED REFLOW SOLDERING PROFILE f 260°C e 230°C 220°C a d b 180°C c d e f g 150°C Temperature ramping rate Pre-heating temperature Pre-heating time Temperature ramp rate 220°C or higher time 230°C or higher time Peak temperature Temperature ramping rate 1 to 4°C/s 150 to 180°C 60 to 120s 1 to 4°C/s shorter than 60s shorter than 40s lower than 260°C 1 to 6°C/s The temperature indicates at the surface of mold package. Room Temp. a b c g FLOW SOLDERING PROFILE 260°C a b c 120°C d Temperature ramping rate Pre-heating temperature Pre-heating time Peak temperature Peak time Temperature ramping rate 1 to 7°C/s 80 to 120°C 60 to 120s lower than 260°C shorter than 10s 1 to 7°C/s The temperature indicates at the surface of mold package. 80°C Room Temp. a b c d IRON SOLDERING PROFILE Temperature of Iron: not exceeding 350°C Soldering time: within 3s (At 1 lead) Ver.02 http://www.njr.com/ - 16 - NJM2740 [ CAUTION ] 1. New JRC strives to produce reliable and high quality semiconductors. New JRC's semiconductors are intended for specific applications and require proper maintenance and handling. To enhance the performance and service of New JRC's semiconductors, the devices, machinery or equipment into which they are integrated should undergo preventative maintenance and inspection at regularly scheduled intervals. Failure to properly maintain equipment and machinery incorporating these products can result in catastrophic system failures 2. The specifications on this datasheet are only given for information without any guarantee as regards either mistakes or omissions. The application circuits in this datasheet are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. All other trademarks mentioned herein are property of their respective companies. 3. To ensure the highest levels of reliability, New JRC products must always be properly handled. The introduction of external contaminants (e.g. dust, oil or cosmetics) can result in failures of semiconductor products. 4. New JRC offers a variety of semiconductor products intended for particular applications. It is important that you select the proper component for your intended application. You may contact New JRC's Sale's Office if you are uncertain about the products listed in this catalog. 5. Special care is required in designing devices, machinery or equipment which demand high levels of reliability. This is particularly important when designing critical components or systems whose failure can foreseeably result in situations that could adversely affect health or safety. In designing such critical devices, equipment or machinery, careful consideration should be given to amongst other things, their safety design, fail-safe design, back-up and redundancy systems, and diffusion design. 6. The products listed in the catalog may not be appropriate for use in certain equipment where reliability is critical or where the products may be subjected to extreme conditions. You should consult our sales office before using the products in any of the following types of equipment. Aerospace Equipment Equipment Used in the Deep sea Power Generator Control Equipment (Nuclear, Steam, Hydraulic) Life Maintenance Medical Equipment Fire Alarm/Intruder Detector Vehicle Control Equipment (airplane, railroad, ship, etc.) Various Safety devices 7. New JRC's products have been designed and tested to function within controlled environmental conditions. Do not use products under conditions that deviate from methods or applications specified in this catalog. Failure to employ New JRC products in the proper applications can lead to deterioration, destruction or failure of the products. New JRC shall not be responsible for any bodily injury, fires or accident, property damage or any consequential damages resulting from misuse or misapplication of its products. Products are sold without warranty of any kind, either express or implied, including but not limited to any implied warranty of merchantability or fitness for a particular purpose. 8. Warning for handling Gallium and Arsenic(GaAs) Products (Applying to GaAs MMIC, Photo Reflector). This Products uses Gallium(Ga) and Arsenic(As) which are specified as poisonous chemicals by law. For the prevention of a hazard, do not burn, destroy, or process chemically to make them as gas or power. When the product is disposed, please follow the related regulation and do not mix this with general industrial waste or household waste. 9. The product specifications and descriptions listed in this catalog are subject to change at any time, without notice. Ver.02 http://www.njr.com/ - 17 -
NJM2740M-TE1 价格&库存
很抱歉,暂时无法提供与“NJM2740M-TE1”相匹配的价格&库存,您可以联系我们找货
