S-93C86BD4I-T8T1G
S-93C86BD4I-T8T1G
    ABLIC(艾普凌科)
    TSSOP-8
    IC EEPROM 16KBIT SPI 2MHZ 8TSSOP
S-93C86BD4I-T8T1G 数据手册
N S-93C86B 3-WIRE SERIAL E2PROM DE SI G www.ablicinc.com Rev.5.0_03 © ABLIC Inc., 2003-2015 W The S-93C86B is a high speed, low current consumption, 3-wire serial E2PROM with a wide operating voltage range. The S93C86B has the capacity of 16 K-bit, and the organization is 1024-word  16 bit. It is capable of sequential read, at which time addresses are automatically incremented in 16-bit blocks. The communication method is by the Microwire bus.  Operating voltage range: Read 1.8 V to 5.5 V Write 2.7 V to 5.5 V 2.0 MHz (VCC = 4.5 V to 5.5 V) 4.0 ms max. NE  Features DE D FO R  Operation frequency:  Write time:  Sequential read capable  Write protect function during the low power supply voltage  Function to protect against write due to erroneous instruction recognition  Endurance: 106 cycles / word*1 (Ta = 85C)  Data retention: 100 years (Ta = 25C) 20 years (Ta = 85C)  Memory capacity: 16 K-bit  Initial delivery state: FFFFh  Operation temperature range: Ta = 40°C to 85C  Lead-free, Sn 100%, halogen-free*2  Packages This product is intended to use in general electronic devices such as consumer electronics, office equipment, and communications devices. Before using the product in medical equipment or automobile equipment including car audio, keyless entry and engine control unit, contact to ABLIC Inc. is indispensable. NO T RE C Caution OM  8-Pin SOP (JEDEC)  8-Pin TSSOP M EN *1. For each address (Word: 16-bit) *2. Refer to “ Product Name Structure” for details. 1 3-WIRE SERIAL E2PROM S-93C86B Rev.5.0_03 8-Pin SOP (JEDEC) Table 1 8-Pin SOP (JEDEC) Top view 8 7 3 6 4 5 Chip select input 2 SK Serial clock input 3 DI Serial data input 4 DO Serial data output 5 FO R S-93C86BD4I-J8T1x 8-Pin TSSOP Chip select input 2 SK Serial clock input 3 DI Serial data input 4 DO Serial data output 5 GND D OM S-93C86BD4I-T8T1x Symbol CS Description Ground *1 6 TEST Test 7 NC No connection 8 VCC Power supply *1. Connect to GND or VCC. Even if this pin is not connected, performance is not affected so long as the absolute maximum rating is not exceeded. M Figure 2 Pin No. 1 EN 8 7 6 5 Table 2 DE 8-Pin TSSOP Top view 1 2 3 4 Description GND Ground *1 6 TEST Test 7 NC No connection 8 VCC Power supply *1. Connect to GND or VCC. Even if this pin is not connected, performance is not affected so long as the absolute maximum rating is not exceeded. Figure 1 2. Symbol CS NE 2 Pin No. 1 W 1 DE SI G 1. N  Pin Configurations NO T RE C Remark 1. Refer to the “package drawings” for the details. 2. x: G or U 3. Please select products of environmental code = U for Sn 100%, halogen-free products. 2 3-WIRE SERIAL E2PROM S-93C86B Rev.5.0_03 VCC Address Memory array decoder Data register GND Output buffer DO W DI NE Mode decode logic CS Clock pulse monitoring circuit FO R Voltage detector Clock generator D SK DE SI G N  Block Diagram NO T RE C OM M EN DE Figure 3 3 3-WIRE SERIAL E2PROM S-93C86B Rev.5.0_03 Table 3 Operation Code Start Bit SK input clock 1 2 3 READ (Read data) 1 1 0 A9 A8 A7 A6 A5 A4 A3 A2 A1 A0 D15 to D0 Output*1 WRITE (Write data) 1 0 1 A9 A8 A7 A6 A5 A4 A3 A2 A1 A0 D15 to D0 Input ERASE (Erase data) 1 1 1 A9 A8 A7 A6 A5 A4 A3 A2 A1 A0 WRAL (Write all) 1 0 0 0 1 x x x x ERAL (Erase all) 1 0 0 1 0 x x x x EWEN (Write enable) 1 0 0 1 1 x x x x EWDS (Write disable) 1 0 0 0 0 x x *1. 5 6 7 8 x 9 x 10 11 12 13 x x x W 4 x 14 to 29  D15 to D0 Input x x x x  x x x x  x x  x x When the 16-bit data in the specified address has been output, the data in the next address is output. NO T RE C OM M EN DE D FO R Remark x: Don’t care 4 Data Instruction NE Address DE SI G N  Instruction Sets 3-WIRE SERIAL E2PROM S-93C86B Rev.5.0_03 N  Absolute Maximum Ratings Item DE SI G Table 4 Symbol Ratings Unit  Recommended Operating Conditions Table 5 High level input voltage VIH Low level input voltage VIL EN  Pin Capacitance Symbol CIN COUT RE C OM M Item Input Capacitance Output Capacitance  Endurance READ, EWDS WRITE, ERASE, WRAL, ERAL, EWEN VCC = 4.5 V to 5.5 V VCC = 2.7 V to 4.5 V VCC = 1.8 V to 2.7 V VCC = 4.5 V to 5.5 V VCC = 2.7 V to 4.5 V VCC = 1.8 V to 2.7 V FO VCC D Power supply voltage Conditions R Symbol DE Item NE W Power supply voltage VCC 0.3 to 7.0 V Input voltage VIN 0.3 to VCC  0.3 V Output voltage VOUT 0.3 to VCC V Operation ambient temperature Topr 40 to 105 C Storage temperature Tstg 65 to 150 C Caution The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions. Ta = 40C to 85C Min. Max. 1.8 5.5 Unit V 2.7 5.5 V 2.0 0.8  VCC 0.8  VCC 0.0 0.0 0.0 VCC VCC VCC 0.8 0.2  VCC 0.15  VCC V V V V V V Table 6 (Ta = 25C, f = 1.0 MHz, VCC = 5.0 V) Conditions VIN = 0 V VOUT = 0 V Min.   Max. 8 10 Unit pF pF Table 7 Item Symbol Operation Ambient Temperature Endurance NW Ta = 40°C to 85C *1. For each address (Word: 16-bit) Min. 106 Max.  Unit Cycles / word*1 NO T  Data Retention Item Data retention Table 8 Symbol  Operation Ambient Temperature Ta = 25°C Ta = 40°C to 85°C Min. 100 20 Max.   Unit year year 5 3-WIRE SERIAL E2PROM S-93C86B Rev.5.0_03 Table 9 Item Symbol Current consumption ICC1 (READ) Ta = 40C to 85C Conditions VCC = 4.5 V to 5.5 V VCC = 2.5 V to 4.5 V VCC = 1.8 V to 2.5 V Unit Min. Max. Min. Max. Min. Max. DO no load   0.8 0.5 Table 10 Current consumption ICC2 (WRITE) W  DO no load 1.5 mA FO Ta = 40C to 85C VCC = VCC = VCC = Unit 4.5 V to 5.5 V 2.5 V to 4.5 V 1.8 V to 2.5 V Min. Max. Min. Max. Min. Max. 1.5  1.5  1.5 A ILI VIN = GND to VCC  1.0  1.0  1.0 A ILO VOUT = GND to VCC  1.0  1.0  1.0 A   2.4 VCC0.3 VCC0.2 0.4 0.1       VCC0.3 VCC0.2   0.1       VCC0.2  0.1    V V V V V 1.5  1.5   V VOL VOH DE D  IOL = 2.1 mA IOL = 100 A IOH = 400 A IOH = 100 A IOH = 10 A Only program disable mode OM RE C T NO Unit CS = GND, DO = Open, Other inputs to VCC or GND Data hold voltage V of write enable latch DH 6 mA ISB EN High level output voltage Conditions M Standby current consumption Input leakage current Output leakage current Low level output voltage Symbol  2.0 Table 11 Item 0.4 Ta = 40C to 85C VCC = 4.5 V to 5.5 V VCC = 2.7 V to 4.5 V Min. Max. Min. Max. Conditions NE Symbol  R Item DE SI G N  DC Electrical Characteristics 1.5 3-WIRE SERIAL E2PROM S-93C86B Rev.5.0_03 Table 12 Measurement Conditions 0.1  VCC to 0.9  VCC Input pulse voltage 0.5  VCC Output reference voltage Output load 100 pF Table 13 Symbol VCC = 4.5 V to 5.5 V VCC = 2.5 V to 4.5 V VCC = 1.8 V to 2.5 V Max. Min. Max. Min. Unit Max. NE Min. W Ta = 40C to 85C Item DE SI G N  AC Electrical Characteristics DE D FO R CS setup time tCSS 0.2  0.4  1.0  s CS hold time tCSH 0  0  0  s CS deselect time tCDS 0.2  0.2  0.4  s Data setup time tDS 0.1  0.2  0.4  s Data hold time tDH 0.1  0.2  0.4  s Output delay time tPD  0.4  0.8  2.0 s Clock frequency*1 0 2.0 0 0.5 0 0.25 MHz fSK SK clock time “L” *1 0.1  0.5  1.0  s tSKL SK clock time “H” *1 0.1  0.5  1.0  s tSKH Output disable time tHZ1, tHZ2 0 0.15 0 0.5 0 1.0 s Output enable time tSV 0 0.15 0 0.5 0 1.0 s *1. The clock cycle of the SK clock (frequency: fSK) is 1 / fSK s. This clock cycle is determined by a combination of several AC characteristics, so be aware that even if the SK clock cycle time is minimized, the clock cycle (1 / fSK) cannot be made to equal tSKL (min.)  tSKH (min.). Item EN Table 14 Symbol tPR Unit Max. 4.0 ms NO T RE C OM M Write time Min.  Ta = 40C to 85C VCC = 2.7 V to 5.5 V Typ. 2.0 7 3-WIRE SERIAL E2PROM S-93C86B 1 / fSK tCSS *2 tCDS tSKH tCSH tSKL SK tDS DI tDH tDS Valid data tPD (READ) DO tSV W *1 tHZ2 NE High-Z tDH Valid data tPD DO DE SI G CS N Rev.5.0_03 High-Z tHZ1 High-Z R (VERIFY) High-Z Indicates high impedance. *2. 1 / fSK is the SK clock cycle. This clock cycle is determined by a combination of several AC characteristics, FO *1. so be aware that even if the SK clock cycle time is minimized, the clock cycle (1 / fSK) cannot be made to D equal tSKL (min.)  tSKH (min.). Timing Chart NO T RE C OM M EN DE Figure 4 8 3-WIRE SERIAL E2PROM S-93C86B Rev.5.0_03 N  Initial Delivery State DE SI G Initial delivery state of all addresses is “FFFFh”.  Operation W All instructions are executed by inputting DI in synchronization with the rising edge of SK after CS goes high. An instruction set is input in the order of start bit, instruction, address, and data. Instruction input finishes when CS goes low. A low level must be input to CS between commands during tCDS. While a low level is being input to CS, the S-93C86B is in standby mode, so the SK and DI inputs are invalid and no instructions are allowed.  Start Bit 1. NE A start bit is recognized when the DI pin goes high at the rise of SK after CS goes high. After CS goes high, a start bit is not recognized even if the SK pulse is input as long as the DI pin is low. Dummy clock 2. FO R SK clocks input while the DI pin is low before a start bit is input are called dummy clocks. Dummy clocks are effective when aligning the number of instruction sets (clocks) sent by the CPU with those required for serial memory operation. For example, when a CPU instruction set is 16 bits, the number of instruction set clocks can be adjusted by inserting a 3-bit dummy clock for the S-93C86B. Start bit input failure D  When the output status of the DO pin is high during the verify period after a write operation, if a high level is input to the DI pin at the rising edge of SK, the S-93C86B recognizes that a start bit has been input. To prevent this failure, input a low level to the DI pin during the verify operation period (refer to “4.1 Verify operation”). NO T RE C OM M EN DE  When a 3-wire interface is configured by connecting the DI input pin and DO output pin, a period in which the data output from the CPU and the serial memory collide may be generated, preventing successful input of the start bit. Take the measures described in “ 3-Wire Interface (Direct Connection between DI and DO)”. 9 3-WIRE SERIAL E2PROM S-93C86B Reading (READ) N 3. Rev.5.0_03 DE SI G The READ instruction reads data from a specified address. After CS has gone high, input an instruction in the order of the start bit, read instruction, and address. Since the last input address (A0) has been latched, the output status of the DO pin changes from high impedance (High-Z) to low, which is held until the next rise of SK. 16-bit data starts to be output in synchronization with the next rise of SK. Sequential read After the 16-bit data at the specified address has been output, inputting SK while CS is high automatically increments the address, and causes the 16-bit data at the next address to be output sequentially. The above method makes it possible to read the data in the whole memory space. The last address (A9  A1 A0 = 1  1 1) rolls over to the top address (A9  A1 A0 = 0  0 0). W 3. 1 2 1 3 0 4 A9 5 A8 6 A7 7 A6 8 A5 9 A4 10 A3 11 A2 12 A1 High-Z DO 13 14 15 16 26 27 28 A0 0 29 30 31 R DI 1 D15 D14 D13 D2 D1 D0 D15 D14 D13 FO SK NE CS ADRINC Read Timing NO T RE C OM M EN DE D Figure 5 10 42 43 D2 44 D1 45 46 47 D0 D15 D14 D13 ADRINC High-Z 3-WIRE SERIAL E2PROM S-93C86B Rev.5.0_03 Writing (WRITE, ERASE, WRAL, ERAL) N 4. Verify operation A write operation executed by any instruction is completed within 4 ms (write time tPR: typically 2 ms), so if the completion of the write operation is recognized, the write cycle can be minimized. A sequential operation to confirm the status of a write operation is called a verify operation. NE W 4. 1 DE SI G A write operation includes four write instructions: data write (WRITE), data erase (ERASE), chip write (WRAL), and chip erase (ERAL). A write instruction (WRITE, ERASE, WRAL, ERAL) starts a write operation to the memory cell when a low level is input to CS after a specified number of clocks have been input. The SK and DI inputs are invalid during the write period, so do not input an instruction. Input an instruction while the output status of the DO pin is high or high impedance (High-Z). A write operation is valid only in program enable mode (refer to “5. Write enable (EWEN) and write disable (EWDS)”). Operation After the write operation has started (CS = low), the status of the write operation can be verified by confirming the output status of the DO pin by inputting a high level to CS again. This sequence is called a verify operation, and the period that a high level is input to the CS pin after the write operation has started is called the verify operation period. The relationship between the output status of the DO pin and the write operation during the verify operation period is as follows.  DO pin = low: Writing in progress (busy)  DO pin = high: Writing completed (ready) 4. 1. 2 Operation example There are two methods to perform a verify operation: Waiting for a change in the output status of the DO pin while keeping CS high, or suspending the verify operation (CS = low) once and then performing it again to verify the output status of the DO pin. The latter method allows the CPU to perform other processing during the wait period, allowing an efficient system to be designed. DE EN Input a low level to the DI pin during a verify operation. If a high level is input to the DI pin at the rise of SK when the output status of the DO pin is high, the S-93C86B latches the instruction assuming that a start bit has been input. In this case, note that the DO pin immediately enters a high-impedance (High-Z) state. NO T RE C OM M Caution 1. 2. D FO R 4. 1. 1 11 3-WIRE SERIAL E2PROM S-93C86B Writing data (WRITE) To write 16-bit data to a specified address, change CS to high and then input the WRITE instruction, address, and 16-bit data following the start bit. The write operation starts when CS goes low. There is no need to set the data to 1 before writing. When the clocks more than the specified number have been input, the clock pulse monitoring circuit cancels the WRITE instruction. For details of the clock pulse monitoring circuit, refer to “ Function to Protect Against Write due to Erroneous Instruction Recognition”. DE SI G N 4. 2 Rev.5.0_03 tCDS CS Verify 1 DI 2 0 3 1 4 5 6 7 8 9 10 11 12 13 14 29 A9 A8 A7 A6 A5 A4 A3 A2 A1 A0 D15 D0 tSV NE High-Z DO W SK tHZ1 busy ready High-Z tPR Data Write Timing R Figure 6 Standby Erasing data (ERASE) To erase 16-bit data at a specified address, set all 16 bits of the data to 1, change CS to high, and then input the ERASE instruction and address following the start bit. There is no need to input data. The data erase operation starts when CS goes low. When the clocks more than the specified number have been input, the clock pulse monitoring circuit cancels the ERASE instruction. For details of the clock pulse monitoring circuit, refer to “ Function to Protect Against Write due to Erroneous Instruction Recognition”. CS 1 2 DI 1 3 1 4 5 A9 A8 8 9 10 11 12 A7 A6 A5 A4 A3 A2 A1 13 A0 tSV busy tPR Figure 7 Standby Verify M OM RE C T NO 7 tCDS High-Z DO 12 6 EN SK DE D FO 4. 3 Data Erase Timing tHZ1 ready High-Z 3-WIRE SERIAL E2PROM S-93C86B Rev.5.0_03 Writing to chip (WRAL) To write the same 16-bit data to the entire memory address space, change CS to high, and then input the WRAL instruction, an address, and 16-bit data following the start bit. Any address can be input. The write operation starts when CS goes low. There is no need to set the data to 1 before writing. When the clocks more than the specified number been input, the clock pulse monitoring circuit cancels the WRAL instruction. For details of the clock pulse monitoring circuit, refer to “ Function to Protect Against Write due to Erroneous Instruction Recognition”. DE SI G N 4. 4 tCDS CS Verify 2 DI 0 3 0 4 0 5 6 7 9 12 13 14 D15 8Xs 29 tSV NE D0 tHZ1 busy ready High-Z tPR Chip Write Timing FO Figure 8 Erasing chip (ERAL) To erase the data of the entire memory address space, set all the data to 1, change CS to high, and then input the ERAL instruction and an address following the start bit. Any address can be input. There is no need to input data. The chips erase operation starts when CS goes low. When the clocks more than the specified number have been input, the clock pulse monitoring circuit cancels the ERAL instruction. For details of the clock pulse monitoring circuit, refer to “ Function to Protect Against Write due to Erroneous Instruction Recognition”. DE D 4. 5 11 10 1 High-Z DO 8 W 1 R SK Standby 1 2 3 4 DI 0 0 1 High-Z 0 6 7 8 9 Standby Verify tCDS 10 11 12 13 tSV 8Xs tHZ1 busy ready High-Z tPR Figure 9 Chip Erase Timing NO T RE C OM DO 5 M SK EN CS 13 3-WIRE SERIAL E2PROM S-93C86B Write enable (EWEN) and write disable (EWDS) N 5. Rev.5.0_03 DE SI G The EWEN instruction is an instruction that enables a write operation. The status in which a write operation is enabled is called the program enable mode. The EWDS instruction is an instruction that disables a write operation. The status in which a write operation is disabled is called the program disable mode. After CS goes high, input an instruction in the order of the start bit, EWEN or EWDS instruction, and address (optional). Each mode becomes valid by inputting a low level to CS after the last address (optional) has been input. CS Standby DI 2 0 3 4 5 6 8 8Xs 11 12 13 Write Enable/Disable Timing R Figure 10 T RE C OM M EN DE D FO Recommendation for write operation disable instruction It is recommended to implement a design that prevents an incorrect write operation when a write instruction is erroneously recognized by executing the write operation disable instruction when executing instructions other than write instruction, and immediately after power-on and before power off. NO 14 10 9 0 11 = EWEN 00 = EWDS 5. 1 7 W 1 NE SK Rev.5.0_03  Write Protect Function during the Low Power Supply Voltage N 3-WIRE SERIAL E2PROM S-93C86B Hysteresis About 0.3 V Power supply voltage W DE SI G The S-93C86B provides a built-in detector. When the power supply voltage is low or at power application, the write instructions (WRITE, ERASE, WRAL, and ERAL) are cancelled, and the write disable state (EWDS) is automatically set. The detection voltage is 1.75 V typ., the release voltage is 2.05 V typ., and there is a hysteresis of about 0.3 V (refer to Figure 11). Therefore, when a write operation is performed after the power supply voltage has dropped and then risen again up to the level at which writing is possible, a write enable instruction (EWEN) must be sent before a write instruction (WRITE, ERASE, WRAL, or ERAL) is executed. When the power supply voltage drops during a write operation, the data being written to an address at that time is not guaranteed. NE Release voltage (VDET) 2.05 V typ. R Detection voltage (VDET) 1.75 V typ. Operation during Low Power Supply Voltage NO T RE C OM M EN DE D Figure 11 FO Write instruction cancelled Write disable state (EWDS) automatically set 15 3-WIRE SERIAL E2PROM S-93C86B Rev.5.0_03 N  Function to Protect Against Write due to Erroneous Instruction Recognition DE SI G The S-93C86B provides a built-in clock pulse monitoring circuit which is used to prevent an erroneous write operation by canceling write instructions (WRITE, ERASE, WRAL, and ERAL) recognized erroneously due to an erroneous clock count caused by the application of noise pulses or double counting of clocks. Instructions are cancelled if a clock pulse whose count other than the one specified for each write instruction (WRITE, ERASE, WRAL, or ERAL) is detected. Erroneous recognition of program disable instruction (EWDS) as erase instruction (ERASE) Example of S-93C86B CS 1 2 3 4 5 6 7 8 9 10 11 12 0 0 Erroneous recognition as ERASE instruction due to noise pulse 1 1 10 0 0 0 D 1 0 00 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 EN DE Input EWDS instruction FO DI M In products that do not incorporate a clock pulse monitoring circuit, FFFFh is mistakenly written to address 00h. However the S-93C86B detects the over count and cancels the instruction without performing a write operation. Example of Clock Pulse Monitoring Circuit Operation NO T RE C OM Figure 12 16 13 R SK NE W Noise pulse 3-WIRE SERIAL E2PROM S-93C86B Rev.5.0_03 N  3-Wire Interface (Direct Connection between DI and DO) CPU SIO NE DI DO W S-93C86B DE SI G There are two types of serial interface configurations: a 4-wire interface configured using the CS, SK, DI, and DO pins, and a 3-wire interface that connects the DI input pin and DO output pin. When the 3-wire interface is employed, a period in which the data output from the CPU and the data output from the serial memory collide may occur, causing a malfunction. To prevent such a malfunction, connect the DI and DO pins of the S-93C86B via a resistor (10 k to 100 k) so that the data output from the CPU takes precedence in being input to the DI pin (refer to “Figure 13 Connection of 3-Wire Interface”). R: 10 k to 100 k R Connection of 3-Wire Interface FO Figure 13  Input Pin and Output Pin Connection of input pins D 1. 2. EN DE All the input pins of the S-93C86B employ a CMOS structure, so design the equipment so that high impedance will not be input while the S-93C86B is operating. Especially, deselect the CS input (a low level) when turning on / off power and during standby. When the CS pin is deselected (a low level), incorrect data writing will not occur. Connect the CS pin to GND via a resistor (10 k to 100 k pull-down resistor). To prevent malfunction, it is recommended to use equivalent pull-down resistors for pins other than the CS pin. Equivalent circuit of input pin and output pin NO T RE C OM M The following shows the equivalent circuits of input pins of the S-93C86B. None of the input pins incorporate pull-up and pull-down elements, so special care must be taken when designing to prevent a floating status. Output pins are high-level / low-level / high-impedance tri-state outputs. The TEST pin is disconnected from the internal circuit by a switching transistor during normal operation. As long as the absolute maximum rating is satisfied, the TEST pin and internal circuit will never be connected. 17 3-WIRE SERIAL E2PROM S-93C86B Input pin DE SI G N 2. 1 Rev.5.0_03 NE CS Pin R Figure 14 W CS DE D FO SK, DI NO T RE C M OM TEST SK, DI Pin EN Figure 15 18 Figure 16 TEST Pin 3-WIRE SERIAL E2PROM S-93C86B Rev.5.0_03 Output pin N 2. 2 DE SI G VCC NE W DO Input pin noise elimination time FO 3. DO Pin R Figure 17 DE D The S-93C86B includes a built-in low-pass filter to eliminate noise at the SK, DI, and CS pins. This means that if the supply voltage is 5.0 V (at room temperature), noise with a pulse width of 20 ns or less can be eliminated. Note, therefore, that noise with a pulse width of more than 20 ns will be recognized as a pulse if the voltage exceeds VIH / VIL.  Precaution EN ● Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit. M ● ABLIC Inc. claims no responsibility for any and all disputes arising out of or in connection with any infringement of the NO T RE C OM products including this IC upon patents owned by a third party. 19 3-WIRE SERIAL E2PROM S-93C86B Rev.5.0_03 Current consumption (READ) ICC1 vs. ambient temperature Ta 1. 2 Current consumption (READ) ICC1 vs. ambient temperature Ta 0.4 ICC1 (mA) 0.2 0.2 -40 0 Ta (C) NE VCC5.5 V fSK2 MHz DATA0101 0 85 1. 4 vs. ambient temperature Ta D DE ICC1 (mA) 85 1 MHz 0.2 500 kHz 0 2 M 0 Ta (C) OM -40 0.4 Current consumption (READ) ICC1 vs. power supply voltage VCC 1. 6 NO 0 20 2 6 7 Current consumption (READ) ICC1 VCC5.5 V Ta25C 0.4 ICC1 (mA) 100 kHz T 0.2 RE C 0.4 3 4 5 VCC (V) vs. Clock frequency fSK Ta25C fSK100 kHz, 10 kHz DATA0101 ICC1 (mA) Ta25C fSK1 MHz, 500 kHz DATA0101 ICC1 (mA) EN 0.2 0 85 vs. power supply voltage VCC VCC1.8 V fSK500 kHz DATA0101 0.4 0 Ta (C) Current consumption (READ) ICC1 FO Current consumption (READ) ICC1 -40 R 0 1. 5 VCC3.3 V fSK500 kHz DATA0101 0.4 ICC1 (mA) 1. 3 DE SI G 1. 1 DC Characteristics W 1. N  Characteristics (Typical Data) 0.2 10 kHz 3 4 5 VCC (V) 6 7 0 10 1k 100 k 10 M fSK (Hz) Rev.5.0_03 Current consumption (WRITE) ICC2 1. 8 Current consumption (WRITE) ICC2 vs. ambient temperature Ta VCC=5.5 V VCC=3.3 V 1.0 1.0 ICC2 (mA) ICC2 (mA) 0.5 0.5 -40 0 Ta (C) 0 85 Current consumption (WRITE) ICC2 1. 10 85 Current consumption (WRITE) ICC2 vs. power supply voltage VCC FO VCC=2.7 V Ta=25C 1.0 1.0 ICC2 (mA) D ICC2 (mA) -40 0 85 M Ta (C) 0.5 0 EN 0 DE 0.5 1. 11 0 Ta (C) R vs. ambient temperature Ta -40 NE 0 1. 9 DE SI G vs. ambient temperature Ta W 1. 7 N 3-WIRE SERIAL E2PROM S-93C86B Current consumption in standby mode ISB 1. 12 NO -40 0 Ta (C) 85 5 6 7 vs. power supply voltage VCC OM T 0 RE C 0.5 4 Current consumption in standby mode ISB VCC=5.5 V CS=GND 1.0 3 VCC (V) vs. ambient temperature Ta ISB (A) 2 Ta=25C CS=GND ISB (A) 1.0 0.5 0 2 3 4 5 6 7 VCC (V) 21 3-WIRE SERIAL E2PROM S-93C86B 1. 14 vs. ambient temperature Ta VCC=5.5 V CS, SK, DI, TEST=5.5 V VCC=5.5 V CS, SK, DI, TEST=0 V 1.0 1.0 lLI (A) lLI (A) 0.5 0.5 -40 0 0 85 Ta (C) Output leakage current ILO 1. 16 VCC=5.5 V DO=5.5 V 1.0 lLO (A) D lLO (A) -40 0 85 Ta (C) High-level output voltage VOH OM VCC=4.5 V IOH=-400 A 4.6 RE C 4.4 4.2 M vs. ambient temperature Ta EN 0 DE 0.5 NO T -40 22 Output leakage current ILO FO 1.0 VOH (V) 85 vs. ambient temperature Ta VCC=5.5 V DO=0 V 1. 17 0 Ta (C) R vs. ambient temperature Ta -40 NE 0 1. 15 DE SI G vs. ambient temperature Ta Input leakage current ILI 0 85 Ta (C) 0.5 0 1. 18 -40 0 85 Ta (C) High-level output voltage VOH vs. ambient temperature Ta 2.8 N Input leakage current ILI W 1. 13 Rev.5.0_03 VCC=2.7 V IOH=-100 A VOH 2.6 (V) 2.4 -40 0 Ta (C) 85 Rev.5.0_03 High-level output voltage VOH 1. 20 0.3 VOL (V) 1.8 VCC=4.5 V IOL=2.1 mA 0.2 0.1 1.7 -40 1. 21 DE SI G VCC=1.8 V IOH=-10 A 1.9 VOH (V) vs. ambient temperature Ta 0 Ta (C) 85 -40 Low-level output voltage VOL 1. 22 85 High-level output current IOH vs. ambient temperature Ta FO VCC=1.8 V IOL=100 A 0.03 0 Ta (C) R vs. ambient temperature Ta W vs. ambient temperature Ta Low-level output voltage VOL NE 1. 19 N 3-WIRE SERIAL E2PROM S-93C86B VCC=4.5 V VOH=2.4 V -20.0 VOL 0.02 (V) D IOH (mA) 1. 23 0 Ta (C) 85 High-level output current IOH OM VCC=2.7 V VOH=2.4 V -2 -1 -40 1. 24 0 85 Ta (C) -40 0 85 Ta (C) High-level output current IOH vs. ambient temperature Ta VCC=1.8 V VOH=1.6 V -2 IOH (mA) -1 0 -40 0 85 Ta (C) NO T 0 RE C IOH (mA) -10.0 0 M vs. ambient temperature Ta EN -40 DE 0.01 23 3-WIRE SERIAL E2PROM S-93C86B 1. 26 vs. ambient temperature Ta Low-level output current IOL vs. ambient temperature Ta VCC=4.5 V VOL=0.4 V VCC=1.8 V VOL=0.1 V 20 1.0 IOL (mA) IOL (mA) 10 1. 27 -40 0 Ta (C) 0 85 Input inverted voltage VINV 1. 28 vs. power supply voltage VCC 0 Ta (C) 85 Input inverted voltage VINV R VCC=5.5 V CS, SK, DI FO 1.2 2.0 D VINV (V) 2 3 4 5 6 7 EN 0 DE 0.6 VCC (V) M Low supply voltage detection voltage VDET 1. 29 1.0 OM -40 NO T 0 RE C 2.0 -VDET (V) 0 Ta (C) 85 1.0 0 1. 30 vs. ambient temperature Ta 24 -40 vs. ambient temperature Ta Ta=25C CS, SK, DI VINV (V) W 0.5 NE 0 N Low-level output current IOL DE SI G 1. 25 Rev.5.0_03 -40 0 Ta (C) 85 Low supply voltage release voltage VDET vs. ambient temperature Ta 2.0 +VDET (V) 1.0 0 -40 0 Ta (C) 85 Rev.5.0_03 2. 1 AC Characteristics Maximum operating frequency fMAX. 2. 2 vs. power supply voltage VCC Write time tPR vs. power supply voltage VCC Ta=25C Ta=25C 10M 4 fMAX. 1M (Hz) 100k tPR (ms) 2 2. 3 2 Write time tPR 2. 4 FO VCC=3.3 V tPR (ms) 4 D 4 0 85 Ta (C) Write time tPR OM VCC=2.7 V M vs. ambient temperature Ta EN -40 DE 2 6 RE C 4 2 Write time tPR 6 6 tPR (ms) 7 vs. ambient temperature Ta VCC=5.5 V 2. 5 4 5 6 VCC (V) R vs. ambient temperature Ta tPR (ms) 2 3 1 3 4 5 6 VCC (V) NE 1 W 10k DE SI G 2. N 3-WIRE SERIAL E2PROM S-93C86B 0 85 Ta (C) -40 2. 6 0 85 Ta (C) Data output delay time tPD vs. ambient temperature Ta VCC=4.5 V 0.3 tPD (s) 0.2 0.1 -40 0 Ta (C) 85 NO T -40 2 25 3-WIRE SERIAL E2PROM S-93C86B 2. 8 vs. ambient temperature Ta VCC=2.7 V VCC=1.8 V 0.6 1.5 tPD (s) 0.4 tPD (s) 1.0 0.2 0.5 85 -40 FO D DE EN M OM RE C T NO 26 0 Ta (C) NE 0 Ta (C) R -40 DE SI G vs. ambient temperature Ta Data output delay time tPD N Data output delay time tPD W 2. 7 Rev.5.0_03 85 3-WIRE SERIAL E2PROM S-93C86B Rev.5.0_03 DE SI G 1. N  Product Name Structure Product name S-93C86B D4 I - xxxx x Environmental code U: Lead-free (Sn 100%), halogen-free G: Lead-free (for details, please contact our sales office) NE W Package name (abbreviation) and IC packing specifications J8T1: 8-Pin SOP (JEDEC), Tape T8T1: 8-Pin TSSOP, Tape Operation temperature I: 40C to 85C R Fixed FO Product name S-93C86B: 16 K-bit D Packages DE 2. Package Name Drawing Code Tape Reel FJ008-A-P-SD FJ008-A-P-SD FT008-A-P-SD FT008-A-P-SD FJ008-D-C-SD FJ008-D-C-SD FT008-E-C-SD FT008-E-C-SD FJ008-D-R-SD FJ008-D-R-S1 FT008-E-R-SD FT008-E-R-S1 NO T RE C OM M 8-Pin TSSOP Environmental code = G Environmental code = U Environmental code = G Environmental code = U EN 8-Pin SOP (JEDEC) Package 27 1 4 DE SI G 5 NE W 8 N 5.02±0.2 DE D FO R 0.20±0.05 1.27 NO T RE C OM M EN 0.4±0.05 No. FJ008-A-P-SD-2.2 TITLE SOP8J-D-PKG Dimensions FJ008-A-P-SD-2.2 No. ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches:40.0±0.2) N 2.0±0.05 ø1.55±0.05 2.1±0.1 FO R NE 8.0±0.1 ø2.0±0.05 W DE SI G 0.3±0.05 5 Feed direction NO T RE C OM M 4 8 EN 1 DE D 6.7±0.1 No. FJ008-D-C-SD-1.1 TITLE SOP8J-D-Carrier Tape No. FJ008-D-C-SD-1.1 ANGLE UNIT mm ABLIC Inc. N DE SI G FO R NE W 60° D 13.5±0.5 2±0.5 ø13±0.2 NO T RE C OM M EN ø21±0.8 DE Enlarged drawing in the central part 2±0.5 No. FJ008-D-R-SD-1.1 TITLE SOP8J-D-Reel No. FJ008-D-R-SD-1.1 QTY. ANGLE UNIT mm ABLIC Inc. 2,000 N DE SI G FO R NE W 60° D 13.5±0.5 2±0.5 ø13±0.2 NO T RE C OM M EN ø21±0.8 DE Enlarged drawing in the central part 2±0.5 No. FJ008-D-R-S1-1.0 TITLE SOP8J-D-Reel No. FJ008-D-R-S1-1.0 QTY. ANGLE UNIT mm ABLIC Inc. 4,000 N +0.3 5 1 4 R NE W 8 DE SI G 3.00 -0.2 DE D FO 0.17±0.05 EN 0.2±0.1 NO T RE C OM M 0.65 No. FT008-A-P-SD-1.2 TITLE TSSOP8-E-PKG Dimensions No. FT008-A-P-SD-1.2 ANGLE UNIT mm ABLIC Inc. 4.0±0.1 2.0±0.05 ø1.55±0.05 +0.1 8.0±0.1 NE ø1.55 -0.05 W DE SI G N 0.3±0.05 FO R (4.4) +0.4 EN DE D 6.6 -0.2 8 M 1 4 NO T RE C OM 5 Feed direction No. FT008-E-C-SD-1.0 TITLE TSSOP8-E-Carrier Tape FT008-E-C-SD-1.0 No. ANGLE UNIT mm ABLIC Inc. N DE SI G W NE R FO D 17.5±1.0 2±0.5 ø13±0.5 NO T RE C OM M EN ø21±0.8 DE Enlarged drawing in the central part 13.4±1.0 No. FT008-E-R-SD-1.0 TITLE TSSOP8-E-Reel No. FT008-E-R-SD-1.0 QTY. ANGLE UNIT mm ABLIC Inc. 3,000 N DE SI G W NE R FO D 17.5±1.0 2±0.5 ø13±0.5 NO T RE C OM M EN ø21±0.8 DE Enlarged drawing in the central part 13.4±1.0 No. FT008-E-R-S1-1.0 TITLE TSSOP8-E-Reel FT008-E-R-S1-1.0 No. QTY. ANGLE UNIT mm ABLIC Inc. 4,000 Disclaimers (Handling Precautions) All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not responsible for damages caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not responsible for damages caused by the incorrect information described herein. 4. Be careful to use the products within their specified ranges. Pay special attention to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not responsible for damages caused by failures and / or accidents, etc. that occur due to the use of the products outside their specified ranges. 5. When using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products must not be used or provided (exported) for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not responsible for any provision (export) to those whose purpose is to develop, manufacture, use or store nuclear, biological or chemical weapons, missiles, or other military use. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses. Do not apply the products to the above listed devices and equipments without prior written permission by ABLIC Inc. Especially, the products cannot be used for life support devices, devices implanted in the human body and devices that directly affect human life, etc. Prior consultation with our sales office is required when considering the above uses. ABLIC Inc. is not responsible for damages caused by unauthorized or unspecified use of our products. 9. Semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system must be sufficiently evaluated and applied on customer's own responsibility. EN DE D FO R NE W DE SI G N 1. M 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. OM 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. RE C 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party without the express permission of ABLIC Inc. is strictly prohibited. T 14. For more details on the information described herein, contact our sales office. NO 2.0-2018.01 www.ablicinc.com
S-93C86BD4I-T8T1G 价格&库存
很抱歉,暂时无法提供与“S-93C86BD4I-T8T1G”相匹配的价格&库存,您可以联系我们找货
