AT25SF161B-SSHD-T
AT25SF161B-SSHD-T
    DIALOGSEMICONDUCTOR(戴乐格)
    SOIC8
    IC FLASH 16MBIT SPI 104MHZ 8SOIC
AT25SF161B-SSHD-T 数据手册
AT25SF161B 16-Mbit SPI Serial Flash Memory with Dual I/O and Quad I/O Support Key Features  Serial Peripheral Interface (SPI) Compatible  Support Protocol: Single, Dual, Quad I/O operation  108 MHz Maximum Operating Frequency  Two Supply Voltage Options Available:  2.7 V - 3.6 V  2.5 V - 3.6.V  Execute-In-Place (XiP) support  Continuous Read mode (with 8/16/32/64 bytes wrap)  Serial Flash Discoverable Parameters (SFDP, JDES216B) support  OTP Memory  Three Protected Programmable Security Register Pages (Page size: 256 bytes)  64-bit factory programmable UID register  Hardware Write Protection (WP pin)  Software Write protection (Programmable non-volatile control registers)  Program and Erase Suspend and Resume  Byte programming size: up to 256 bytes  Erase Size and Duration  Uniform 4-kbyte Block Erase (60 ms typical)  Uniform 32-kbyte Block Erase (150 ms typical)  Uniform 64-kbyte Block Erase (250 ms typical)  Full Chip Erase (7 seconds typical)  Low Power Dissipation  Standby Current (30 µA maximum)  Deep Power Down Current (10 µA maximum)  Endurance: 100,000 Program and Erase Cycles  Data Retention: 20 Years  Industrial Temperature Range (-40 oC to 85 oC)  Datasheet DS-AT25SF161B-188 Industry Standard Green (Pb/Halide-free/RoHS Compliant) Package Options  8-lead SOIC (0.150” Narrow and 0.208” Wide)  8-pad Ultra-Thin DFN (5 x 6 x 0.6 mm)  8-ball WLCSP (3 x 2 x 3 grid array)  Die Wafer Form  Other Package Options (contact Dialog Semiconductor) Revision E 1 21-Apr-2021 © 2021 Dialog Semiconductor AT25SF161B 16-Mbit SPI Serial Flash Memory with Dual I/O and Quad I/O Support Contents Key Features............................................................................................................................................................................. 1 1 Product Overview ................................................................................................................................................................. 6 2 Pin Descriptions and Package Pinouts .............................................................................................................................. 7 3 Block Diagram ...................................................................................................................................................................... 9 4 Memory Array ..................................................................................................................................................................... 10 5 Device Operation ................................................................................................................................................................ 12 5.1 Dual Output Read (1-1-2) ........................................................................................................................................12 5.2 Dual I/O Read (1-2-2) ..............................................................................................................................................12 5.3 Quad Output Read (1-1-4) .......................................................................................................................................12 5.4 Quad I/O Read (1-4-4) .............................................................................................................................................12 6 Commands and Addressing .............................................................................................................................................. 13 7 Read Commands ................................................................................................................................................................ 15 7.1 Read Array (0Bh and 03h) .......................................................................................................................................15 7.2 Dual-Output Read Array (3Bh) .................................................................................................................................16 7.3 Dual-I/O Read Array (BBh) ......................................................................................................................................17 7.3.1 Dual-I/O Read Array (BBh) with Continuous Read Mode .......................................................................... 18 7.4 Quad Output Fast Read Array (6Bh) .......................................................................................................................19 7.5 Quad-I/O Read Array (EBh) .....................................................................................................................................20 7.5.1 Quad-I/O Read Array (EBh) with Continuous Read Mode ......................................................................... 21 7.5.2 Set Burst with Wrap (77h) .......................................................................................................................... 22 7.6 Quad-I/O Word Fast Read (E7h) .............................................................................................................................23 7.6.1 Quad I/O Word Fast Read with “Continuous Read Mode” ......................................................................... 23 7.6.2 Quad I/O Word Fast Read with 8-, 16-, 32-, 64-Byte Wrap Around in Standard SPI Mode ....................... 24 7.7 Read Serial Flash Discoverable Parameter (5Ah) ...................................................................................................24 8 Program and Erase Commands ........................................................................................................................................ 25 8.1 Byte/Page Program (02h) ........................................................................................................................................25 8.2 Quad Page Program (32h) .......................................................................................................................................26 8.3 Block Erase (20h, 52h, or D8h) ................................................................................................................................27 8.4 Chip Erase (60h or C7h) ..........................................................................................................................................27 8.5 Program/Erase Suspend (75h) ................................................................................................................................28 8.6 Program/Erase Resume (7Ah) .................................................................................................................................29 9 Protection Commands and Features ................................................................................................................................ 30 9.1 Write Enable (06h) ...................................................................................................................................................30 9.2 Write Disable (04h) ..................................................................................................................................................30 9.3 Non-Volatile Protection ............................................................................................................................................31 9.4 Protected States and the Write Protect Pin .............................................................................................................32 9.5 Enable Reset (66h) and Reset Device (99h) ...........................................................................................................33 10 Security Register Commands ......................................................................................................................................... 34 10.1 Read Unique ID Number (4Bh) ..............................................................................................................................34 10.2 Erase Security Registers (44h) ..............................................................................................................................34 10.3 Program Security Registers (42h) ..........................................................................................................................36 10.4 Read Security Registers (48h) ...............................................................................................................................37 11 Status Register Commands ............................................................................................................................................ 38 11.1 Read Status Register (05h, 35h, and 15h) ............................................................................................................38 11.1.1 SRP1, SRP0 Bits ..................................................................................................................................... 40 11.1.2 CMP, BP4, BP3, BP2, BP1, BP0 Bits ...................................................................................................... 41 11.1.3 WEL Bit .................................................................................................................................................... 41 11.1.4 RDY/BSY Bit ............................................................................................................................................ 41 11.1.5 LB3, LB2, LB1 Bits ................................................................................................................................... 41 11.1.6 E_SUS Bit ................................................................................................................................................ 42 11.1.7 P_SUS Bit ................................................................................................................................................ 42 11.1.8 QE Bit ....................................................................................................................................................... 42 Datasheet DS-AT25SF161B-188 Revision E 2 21-Apr-2021 © 2021 Dialog Semiconductor AT25SF161B 16-Mbit SPI Serial Flash Memory with Dual I/O and Quad I/O Support 11.2 Write Status Register (01h, 31h, 11h) ....................................................................................................................43 11.3 Write Enable for Volatile Status Register (50h) ......................................................................................................44 12 Other Commands and Functions .................................................................................................................................... 45 12.1 Read Manufacturer and Device ID (9Fh) ...............................................................................................................45 12.2 Read ID (Legacy Command) (90h) ........................................................................................................................46 12.3 Dual I/O Read Manufacture ID/ Device ID (92h) ....................................................................................................47 12.4 Quad I/O Read Manufacture ID / Device ID (94h) .................................................................................................48 12.5 Deep Power-Down (B9h) .......................................................................................................................................49 12.6 Resume from Deep Power-Down (ABh) ................................................................................................................50 12.6.1 Resume from Deep Power-Down and Read Device ID (ABh) ................................................................. 51 12.7 Hold Function .........................................................................................................................................................51 13 Electrical Specifications .................................................................................................................................................. 52 13.1 Absolute Maximum Ratings* ..................................................................................................................................52 13.2 DC and AC Operating Range ................................................................................................................................52 13.3 DC Characteristics .................................................................................................................................................52 13.4 AC Characteristics - Maximum Clock Frequencies ................................................................................................53 13.5 AC Characteristics - All Other Parameters .............................................................................................................53 13.6 Program and Erase Characteristics .......................................................................................................................54 13.7 Power Up Conditions .............................................................................................................................................54 13.8 Input Test Waveforms and Measurement Levels ...................................................................................................54 13.9 Output Test Load ...................................................................................................................................................54 14 AC Waveforms .................................................................................................................................................................. 55 15 Ordering Information ....................................................................................................................................................... 57 16 Packaging Information ..................................................................................................................................................... 59 16.1 8S1 – 0.150” Narrow JEDEC SOIC .......................................................................................................................59 16.2 8S2 – 8-lead, 0.208” Wide EIAJ SOIC ...................................................................................................................60 16.3 8MA1 – UDFN ........................................................................................................................................................61 16.4 8-WLCSP — 8-ball 3 x 2 x 3 WLCSP ....................................................................................................................62 17 Revision History ............................................................................................................................................................... 63 Datasheet DS-AT25SF161B-188 Revision E 3 21-Apr-2021 © 2021 Dialog Semiconductor AT25SF161B 16-Mbit SPI Serial Flash Memory with Dual I/O and Quad I/O Support Figures Figure 1: 8-SOIC (0.150” and 0.208”) — Top View....................................................................................................................8 Figure 2: 8-ball WLCSP (3 x 2 x 3) — Bottom View...................................................................................................................8 Figure 3: 8-UDFN — Top View ..................................................................................................................................................8 Figure 4: Block Diagram.............................................................................................................................................................9 Figure 5: SPI Mode 0 and 3 .....................................................................................................................................................12 Figure 6: Read Array - 03h Opcode .........................................................................................................................................15 Figure 7: Read Array - 0Bh Opcode.........................................................................................................................................15 Figure 8: Dual-Output Read Array............................................................................................................................................16 Figure 9: Dual I/O Read Array (Initial command or previous M5,M4 ¹ 1,0) ..............................................................................17 Figure 10: Dual-I/O Read Array (Previous command set M5, M4 = 1,0) .................................................................................18 Figure 11: Quad-Output Read Array ........................................................................................................................................19 Figure 12: Quad-I/O Read Array (Initial command or previous M5, M4 ¹ 1,0)..........................................................................20 Figure 13: Quad I/O Read Array with Continuous Read Mode (Previous Command Set M5, M4 = 1,0).................................21 Figure 14: Set Burst with Wrap Timing (SPI Mode) .................................................................................................................22 Figure 15: Quad I/O Word Fast Read Timing (Initial Command Set M5, M4 ≠ 1,0) SPI Mode ................................................23 Figure 16: Quad I/O Word Fast Read Timing (Previous Command Set M5, M4 = 1,0) SPI Mode ..........................................23 Figure 17: Read Serial Flash Discoverable Parameter Command Timing...............................................................................24 Figure 18: Byte Program ..........................................................................................................................................................25 Figure 19: Page Program Timing .............................................................................................................................................26 Figure 20: Quad Page Program (32h) Timing ..........................................................................................................................26 Figure 21: Block Erase .............................................................................................................................................................27 Figure 22: Enable Reset (66h) and Reset Device (99h) Command Timing (SPI Mode)..........................................................33 Figure 23: Read Unique ID Timing (SPI Mode)........................................................................................................................34 Figure 24: Erase Security Register Page .................................................................................................................................35 Figure 25: Program Security Registers ....................................................................................................................................36 Figure 26: Read Security Registers .........................................................................................................................................37 Figure 27: Read Status Register 1 ...........................................................................................................................................38 Figure 28: Read Status Register 2 ...........................................................................................................................................39 Figure 29: Write Status Register ..............................................................................................................................................43 Figure 30: Write Enable for Volatile Status Register ................................................................................................................44 Figure 31: Read Manufacturer and Device ID..........................................................................................................................46 Figure 32: Read ID (Legacy Command) ..................................................................................................................................46 Figure 33: Dual I/O Read Manufacture ID/ Device ID Timing ..................................................................................................47 Figure 34: Quad I/O Read Manufacture ID / Device ID Timing ................................................................................................48 Figure 35: Deep Power-Down ..................................................................................................................................................49 Figure 36: Resume from Deep Power-Down ...........................................................................................................................50 Figure 37: Resume from Deep Power-Down and Read Device ID Timing ..............................................................................51 Figure 38: Serial Input Timing ..................................................................................................................................................55 Figure 39: Serial Output Timing ...............................................................................................................................................55 Figure 40: WP Timing for Write Status Register Command When BPL = 1 ............................................................................55 Figure 41: HOLD Timing – Serial Input ....................................................................................................................................56 Figure 42: HOLD Timing – Serial Output .................................................................................................................................56 Datasheet DS-AT25SF161B-188 Revision E 4 21-Apr-2021 © 2021 Dialog Semiconductor AT25SF161B 16-Mbit SPI Serial Flash Memory with Dual I/O and Quad I/O Support Tables Table 1: Pin Descriptions ...........................................................................................................................................................7 Table 2: Device Memory Map — Block Erase Address Ranges ..............................................................................................10 Table 3: Device Memory Map — Page Program Address Ranges ..........................................................................................11 Table 4: AT25SF161B Command Table ..................................................................................................................................13 Table 5: Set Burst with Wrap Command Functions ................................................................................................................22 Table 6: Memory Array with CMP = 0 ......................................................................................................................................31 Table 7: Memory Array Protection with CMP = 1 .....................................................................................................................32 Table 8: Security Register Addresses for Erase Security Register Page Command ...............................................................35 Table 9: Security Register Addresses for Program Security Registers Command ..................................................................36 Table 10: Security Register Addresses for Read Security Registers Command .....................................................................37 Table 11: Status Register 1 Bit Assignments ...........................................................................................................................38 Table 12: Status Register 2 Bit Assignments ...........................................................................................................................39 Table 13: Status Register 3 Bit Assignments ...........................................................................................................................40 Table 14: Status Register Protection Table..............................................................................................................................40 Table 15: Write Status Register 1 ............................................................................................................................................43 Table 16: Write Status Register 2 ............................................................................................................................................43 Table 17: Write Status Register 3 ............................................................................................................................................43 Table 18: Manufacturer and Device ID Information..................................................................................................................45 Table 19: Manufacturer and Device ID Information..................................................................................................................45 Table 20: Manufacturer and Device ID Details.........................................................................................................................45 Table 21: Ordering Codes for 2.7 V to 3.6 V Devices ..............................................................................................................57 Table 22: Ordering Codes for 2.5 V to 3.6 V Devices ..............................................................................................................57 Table 23: Description of Package Types..................................................................................................................................58 Datasheet DS-AT25SF161B-188 Revision E 5 21-Apr-2021 © 2021 Dialog Semiconductor AT25SF161B 16-Mbit SPI Serial Flash Memory with Dual I/O and Quad I/O Support 1 Product Overview The AT25SF161B is a serial interface Flash memory device designed for a wide variety of high-volume consumer-based applications in which program code is shadowed from Flash memory into embedded or external RAM for execution. The flexible erase architecture of the AT25SF161B also is ideal for data storage, eliminating the need for additional data storage devices. The AT25SF161B erase block sizes are optimized to meet the needs of today's code and data storage applications. This means memory space can be used much more efficiently. Because certain code modules and data storage segments must reside in their own erase regions, the wasted and unused memory space that occurs with large-block-erase Flash memory devices can be reduced greatly. This increased memory space allows additional code routines and data storage segments to be added, while maintaining the same overall device density. This device also contains three Security Register pages for unique device serialization, system-level Electronic Serial Number (ESN) storage, locked key storage, etc. These pages can be locked individually. Datasheet DS-AT25SF161B-188 Revision E 6 21-Apr-2021 © 2021 Dialog Semiconductor AT25SF161B 16-Mbit SPI Serial Flash Memory with Dual I/O and Quad I/O Support 2 Pin Descriptions and Package Pinouts Table 1: Pin Descriptions Symbol Name and Function Assert State Type Low Input - Input - Input/ Output - Input/ Output - Input/ Output - Input/ Output CHIP SELECT: Asserting the CS pin selects the device. When the CS pin is deasserted, the device is deselected and normally be placed in standby mode. CS SCK A high-to-low transition on the CS pin is required to start an operation; a low-to-high transition is required to end an operation. When ending an internally self-timed operation, such as a program or erase cycle, the device does not enter the standby mode until the operation is complete. SERIAL CLOCK: This pin provides a clock to the device. Command, address, and input data present on the SI pin is latched in on the rising edge of SCK, while output data on the SO pin is clocked out on the falling edge of SCK. SERIAL INPUT: The SI pin is used for all data input, including command and address sequences. Data on the SI pin is always latched in on the rising edge of SCK. SI (I/O0) With the Dual-Output and Quad-Output Read commands, the SI pin becomes an output pin (I/O0) in conjunction with other pins to allow two or four bits of data (on I/O3-0) to be clocked in on every falling edge of SCK. Data present on the SI pin is ignored whenever the device is deselected (CS is deasserted). SERIAL OUTPUT: Data on the SO pin is clocked out on the falling edge of SCK. SO (I/O1) With the Dual-Output Read commands, the SO pin remains an output pin (I/O0) in conjunction with other pins to allow two bits of data (on I/O1-0) to be clocked in on every falling edge of SCK. The SO pin is in a high-impedance state whenever the device is deselected (CS is deasserted). WRITE PROTECT: The WP pin controls the hardware locking feature of the device. WP (I/O2) With the Quad-Input Byte/Page Program command, the WP pin becomes an input pin (I/ O2) and, along with other pins, allows four bits (on I/O3-0) of data to be clocked in on every rising edge of SCK. With the Quad-Output Read commands, the WP Pin becomes an output pin (I/O2) in conjunction with other pins to allow four bits of data (on I/O33-0) to be clocked in on every falling edge of SCK. The WP pin is internally pulled-high and can be left floating if hardware-controlled protection is not used; however, it is recommended that the WP pin also be externally connected to VCC whenever possible. HOLD: The HOLD pin temporarily pauses serial communication without deselecting or resetting the device. While the HOLD pin is asserted, transitions on the SCK pin and data on the SI pin are ignored, and the SO pin is in a high-impedance state. HOLD (I/O3) The CS pin must be asserted, and the SCK pin must be in the low state, for a Hold condition to start. A Hold condition pauses serial communication only and does not have an affect on internally self-timed operations, such as a program or erase cycle. See “Hold Function”, on page 51 for additional details on the Hold operation. With the Quad-Input Byte/Page Program command, the HOLD pin becomes an input pin (I/ O3) and, along with other pins, allows four bits (on I/O3-0) of data to be clocked in on every rising edge of SCK. With the Quad-Output Read commands, the HOLD pin becomes an output pin (I/O3) in conjunction with other pins to allow four bits of data (on I/O33-0) to be clocked in on every falling edge of SCK. The HOLD pin is internally pulled-high and can be left floating if the Hold function is not used. It is recommended, however, that the HOLD pin is externally connected to VCC whenever possible. Datasheet DS-AT25SF161B-188 Revision E 7 21-Apr-2021 © 2021 Dialog Semiconductor AT25SF161B 16-Mbit SPI Serial Flash Memory with Dual I/O and Quad I/O Support Table 1: Pin Descriptions (Continued) Symbol Name and Function Assert State Type VCC DEVICE POWER SUPPLY: The VCC pin supplies the source voltage to the device. - Power GND GROUND: The ground reference for the power supply. Connect GND to the system ground. - Power CS SO (IO1) WP (IO2) GND 1 2 3 4 CS SO (IO1) WP (IO2) GND VCC HOLD (IO3) SCK SI (IO0) 8 7 6 5 VCC HOLD (IO3) SCK SI (IO0) VCC A3 GND A1 SO B2 HOLD C3 SI C1 WP D2 SCK E3 8 7 6 5 Figure 3: 8-UDFN — Top View Figure 1: 8-SOIC (0.150” and 0.208”) — Top View CS 1 2 3 4 E1 Figure 2: 8-ball WLCSP (3 x 2 x 3) — Bottom View Datasheet DS-AT25SF161B-188 Revision E 8 21-Apr-2021 © 2021 Dialog Semiconductor AT25SF161B 16-Mbit SPI Serial Flash Memory with Dual I/O and Quad I/O Support 3 Block Diagram Control and Protection Logic CS I/O Buffers and Latches SRAM Data Buffer SI (I/O0) SO (I/O1) WP (I/O2) Interface Control And Logic Address Latch SCK Y-Decoder Y-Gating X-Decoder Flash Memory Array HOLD (I/O3) Note: I/O3-0 pin naming convention is used for Dual-I/O and Quad-I/O commands. Figure 4: Block Diagram Datasheet DS-AT25SF161B-188 Revision E 9 21-Apr-2021 © 2021 Dialog Semiconductor AT25SF161B 16-Mbit SPI Serial Flash Memory with Dual I/O and Quad I/O Support 4 Memory Array To provide the greatest flexibility, the memory array of the AT25SF161B can be erased in four levels of granularity, including a full-chip erase. The size of the erase blocks is optimized for both code and data storage applications, allowing both code and data segments to reside in their own erase regions. Note that in the following figures, the (Bxxx) value in parentheses indicates the block number. Table 2: Device Memory Map — Block Erase Address Ranges 64 kbyte Block Erase (D8h) 32 kbyte Block Erase (52h) 4 kbyte Block Erase (20h) Block Address Range 4 kbytes (B511) 4 kbytes (B510) 4 kbytes (B509) 4 kbytes (B508) 4 kbytes (B507) 4 kbytes (B506) 4 kbytes (B505) 4 kbytes (B504) 4 kbytes (B503) 4 kbytes (B502) 4 kbytes (B501) 4 kbytes (B500) 4 kbytes (B499) 4 kbytes (B498) 4 kbytes (B497) 4 kbytes (B496) 4 kbytes (B495) to 4 kbytes (B16) 1FF000h - 1FFFFFh 1FE000h - 1FEFFFh 1FD000h - 1FDFFFh 1FC000h - 1FCFFFh 1FB000h - 1FBFFFh 1FA000h - 1FAFFFh 1F9000h - 1F9FFFh 1F8000h - 1F8FFFh 1F7000h - 1F7FFFh 1F6000h - 1F6FFFh 1F5000h - 1F5FFFh 1F4000h - 1F4FFFh 1F3000h - 1F3FFFh 1F2000h - 1F2FFFh 1F1000h - 1F1FFFh 1F0000h - 1F0FFFh 1EF000h - 1EFFFFh to 010000h - 010FFFh 4 kbytes (B15) 4 kbytes (B14) 4 kbytes (B13) 4 kbytes (B12) 4 kbytes (B11) 4 kbytes (B10) 4 kbytes (B9) 4 kbytes (B8) 4 kbytes (B7) 4 kbytes (B6) 4 kbytes (B5) 4 kbytes (B4) 4 kbytes (B3) 4 kbytes (B2) 4 kbytes (B1) 4 kbytes (B0) 00F000h - 00FFFFh 00E000h - 00EFFFh 00D000h - 00DFFFh 00C000h - 00CFFFh 00B000h - 00BFFFh 00A000h - 00AFFFh 009000h - 009FFFh 008000h - 008FFFh 007000h - 007FFFh 006000h - 006FFFh 005000h - 005FFFh 004000h - 004FFFh 003000h - 003FFFh 002000h - 002FFFh 001000h - 001FFFh 000000h - 000FFFh 32 kbytes (block 63) 64 kbytes (block 31) 32 kbytes (block 62) 64 kbytes (block 30) to 64 kbytes (block 1) 32 kbytes (block 61) to 32 kbytes (block 2) 32 kbytes (block 1) 64 kbytes (block 0 32 kbytes (block 0) Datasheet DS-AT25SF161B-188 Revision E 10 21-Apr-2021 © 2021 Dialog Semiconductor AT25SF161B 16-Mbit SPI Serial Flash Memory with Dual I/O and Quad I/O Support Table 3: Device Memory Map — Page Program Address Ranges 4 kbytes Blocks 256 Byte Page 1 - 256 Byte Page Program 4 kbytes (B511) 256 Bytes 1FFF00h - 1FFFFFh 4 kbytes (B510) 256 Bytes 1FFE00h - 1FFEFFh 4 kbytes (B509) 256 Bytes 1FFD00h - 1FFDFFh 4 kbytes (B508) 256 Bytes 1FFC00h - 1FFCFFh 4 kbytes (B507) 256 Bytes 1FFB00h - 1FFBFFh 4 kbytes (B506) 256 Bytes 1FFA00h - 1FFAFFh 4 kbytes (B505) 256 Bytes 1FF900h - 1FF9FFh 4 kbytes (B504) 256 Bytes 1FF800h - 1FF8FFh 4 kbytes (B503) 256 Bytes 1FF700h - 1FF7FFh 4 kbytes (B502) 256 Bytes 1FF600h - 1F6FFFh 4 kbytes (B501) 256 Bytes 1FF500h - 1FF5FFh 4 kbytes (B500) 256 Bytes 1FF400h - 1FF4FFh 4 kbytes (B499) 256 Bytes 1FF300h - 1FF3FFh 4 kbytes (B498) 256 Bytes 1FF200h - 1FF2FFh 4 kbytes (B497) 256 Bytes 1FF100h - 1FF1FFh 4 kbytes (B496) 256 Bytes 1FF000h - 1FF0FFh . . . . . . 4 kbytes (B494) to 4 kbytes (B16) . . . 4 kbytes (B15) 256 Bytes 000F00h - 000FFFh 4 kbytes (B14) 256 Bytes 000E00h - 000EFFh 4 kbytes (B13) 256 Bytes 000D00h - 000DFFh 4 kbytes (B12) 256 Bytes 000C00h - 000CFFh 4 kbytes (B11) 256 Bytes 000B00h - 000BFFh 4 kbytes (B10) 256 Bytes 000A00h - 000AFFh 4 kbytes (B9) 256 Bytes 000900h - 0009FFh 4 kbytes (B8) 256 Bytes 000800h - 0008FFh 4 kbytes (B7) 256 Bytes 000700h - 0007FFh 4 kbytes (B6) 256 Bytes 000600h - 0006FFh 4 kbytes (B5) 256 Bytes 000500h - 0005FFh 4 kbytes (B4) 256 Bytes 000400h - 0004FFh 4 kbytes (B3) 256 Bytes 000300h - 0003FFh 4 kbytes (B2) 256 Bytes 000200h - 0002FFh 4 kbytes (B1) 256 Bytes 000100h - 0001FFh 4 kbytes (B0) 256 Bytes 000000h - 0000FFh Datasheet DS-AT25SF161B-188 Revision E 11 21-Apr-2021 © 2021 Dialog Semiconductor AT25SF161B 16-Mbit SPI Serial Flash Memory with Dual I/O and Quad I/O Support 5 Device Operation The AT25SF161B is controlled by a set of commands sent from a host controller, SPI Master. The SPI Master communicates with the AT25SF161B through the SPI bus, which consists of four pins: Chip Select (CS), Serial Clock (SCK), Serial Input (SI), and Serial Output (SO). The SPI protocol defines a total of four modes of operation (mode 0, 1, 2, or 3). The AT25SF161B supports the two most common modes, SPI modes 0 and 3. For these modes, data is latched in on the rising edge of SCK and output on the falling edge of SCK. CS SCK SI MSB LSB SO MSB LSB Figure 5: SPI Mode 0 and 3 5.1 DUAL OUTPUT READ (1-1-2) The AT25SF161B supports Dual Output (1-1-2) transfers, which enhance overall throughput over the standard SPI mode. This mode transfers the command and address on the SI pin, but the data are transferred on the SI and SO pins. This means that only half the number of clocks are required to transfer the data. 5.2 DUAL I/O READ (1-2-2) The AT25SF161B supports Dual I/O (1-2-2) transfers, which enhance throughput over the standard SPI mode. This mode transfers the command on the SI pin, but the address and data are transferred on the SI and SO pins. This means that only half the number of clocks are required to transfer the address and data. 5.3 QUAD OUTPUT READ (1-1-4) The AT25SF161B supports Quad Output (1-1-4) transfers, which enhance overall throughput over the standard SPI mode. This mode transfers the command and address on the SI pin, but the data is transferred on the SI, SO, WP, and HOLD pins. This means that only a quarter the number of clocks are required to transfer the data. With the Quad-Output Read Array command, the SI, WP, and HOLD pins become outputs along with the SO pin. 5.4 QUAD I/O READ (1-4-4) The AT25SF161B supports Quad I/O (1-4-4) transfers, which enhance throughput over the standard SPI mode. This mode transfers the command on the SI pin, but the address and data are transferred on the SI, SO, WP, and HOLD pins. This means that only a quarter of the number of clocks are required to transfer the address and data. With the Quad I/O Read Array command, the SI, WP, and HOLD and SO pins become inputs during the address transfer, and switch to outputs during the data transfer. Datasheet DS-AT25SF161B-188 Revision E 12 21-Apr-2021 © 2021 Dialog Semiconductor AT25SF161B 16-Mbit SPI Serial Flash Memory with Dual I/O and Quad I/O Support 6 Commands and Addressing A valid command or operation must be started by first asserting the CS pin. After the CS pin has been asserted, the host controller must clock out a valid eight-bit opcode on the SPI bus. Following the opcode, command-dependent information, such as address and data bytes, can be clocked out by the host controller. All opcode, address, and data bytes are transferred with the mostsignificant bit (MSB) first. An operation is ended by deasserting the CS pin. Opcodes not supported by the AT25SF161B are ignored by the device, and no operation is started. The device continues to ignore any data presented on the SI pin until the start of the next operation (CS pin being deasserted and then reasserted). If the CS pin is deasserted before complete opcode, and address information is sent to the device, no operation is performed, and the device returns to the idle state and waits for the next operation. Addressing of the device requires three bytes of information to be sent, representing address bits A23-A0. Since the upper address limit of the AT25SF161B memory array is 1FFFFFh, address bits A23-A21 are ignored by the device. Table 4: AT25SF161B Command Table Command Opcode Bus Transfer Type (OP-AD-DA) 1 Enable Reset 66h 1-0-0 N 0 0 0 Reset Device 99h 1-0-0 N 0 0 0 Deep Power-down B9h 1-0-0 N 0 0 0 Release Power-down ABh 1-0-0 N 0 0 0 Normal Read Data 03h 1-1-1 N 0 0 1+ Fast Read 0Bh 1-1-1 N 0 8 1+ Dual Output Fast read 3Bh 1-1-2 N 0 8 1+ Dual I/O Fast read BBh 1-2-2 Y 4 0 1+ Dual I/O Fast read (Continuous Mode) BBh 0-2-2 Y 4 0 1+ Quad Output Fast read 6Bh 1-1-4 N 0 8 1+ Quad I/O Fast read EBh 1-4-4 Y 2 4 1+ Quad I/O Fast read (Continuous Mode) EBh 0-4-4 Y 2 4 1+ Word Read Quad I/O E7h 1-4-4 Y 2 2 1+ Word Read Quad I/O (Continuous Mode) E7h 0-4-4 Y 2 2 1+ Set Burst With Wrap 77h 1-0-4 N 0 6 1, D[6:4] Write Enable 06h 1-0-0 N 0 0 0 Volatile SR Write Enable 50h 1-0-0 N 0 0 0 Write Disable 04h 1-0-0 N 0 0 0 Command Name Mode Bit Mode Bit Wait Cycle DumPresent Clocks my Clocks Data Bytes System Commands Read Commands Write Commands Datasheet DS-AT25SF161B-188 Revision E 13 21-Apr-2021 © 2021 Dialog Semiconductor AT25SF161B 16-Mbit SPI Serial Flash Memory with Dual I/O and Quad I/O Support Table 4: AT25SF161B Command Table (Continued) Command Opcode Bus Transfer Type (OP-AD-DA) 1 Page Program 02h 1-1-1 N 0 0 1+ Quad Page Program 32h 1-1-4 N 0 0 1+ Block Erase (4KB) 20h 1-1-0 N 0 0 0 Block Erase (32KB) 52h 1-1-0 N 0 0 0 Block Erase (64KB) D8h 1-1-0 N 0 0 0 C7h/60h 1-0-0 N 0 0 0 Program/Erase Suspend 75h 1-0-0 N 0 0 0 Program/Erase Resume 7Ah 1-0-0 N 0 0 0 Read Status Register 1 05h 1-0-1 N 0 0 1 Read Status Register 2 35h 1-0-1 N 0 0 1 Read Status Register 3 15h 1-0-1 N 0 0 1 Write Status Register 1 01h 1-0-1 N 0 0 1 Write Status Register 2 31h 1-0-1 N 0 0 1 Write Status Register 3 11h 1-0-1 N 0 0 1 Manufacturer/Device ID 90h 1-1-1 N 0 0 2 Mfgr./Device ID Dual I/O 92h 1-2-2 N 0 4 2 Mfgr./Device ID Quad I/O 94h 1-4-4 N 0 4 2 Read JEDEC ID 9Fh 1-0-1 N 0 0 3 5Ah 1-1-1 N 0 8 1+ Erase Security Registers 44h 1-1-0 N 0 0 0 Program Security Registers 42h 1-1-1 N 0 0 1+ Read Security Registers 48h 1-1-1 N 0 8 1+ Read Unique ID Number 4Bh 1-0-1 N 0 32 1+ Command Name Mode Bit Mode Bit Wait Cycle DumPresent Clocks my Clocks Data Bytes Program Commands Erase Commands Chip Erase Suspend/Resume Commands Status Register Commands Device Information Commands Read Serial Flash Discoverable Parameter OTP Commands 1. OP = Opcode (command number), AD = Address. DA = Data. 0 indicates the corresponding transfer does not occur in that command. 1 indicates the transfer does occur. For example, 1-0-0 indicates a command transfer occurs, but no address or data transfers occur. Op: Opcode or Commands (8-bits): 0 → No Opcode [continuous Read], 1 → 8 clocks for Opcode, 2 → 4 clocks for Opcode, 4 → 2 clocks for opcode. AD: Address (24-bits) Only: 0 → No address, Opcode only operation, 1 → 24 clocks for Address, 2 → 12 clocks for address, 4 → 6 clocks for address. AD: Address (24-bits) + Mode (8-bits): 2 → 12 clocks for address, 4 clocks for mode [BBh only], 4 → 6 clocks for address, 2 clocks for mode [EBh and E7h]. DA: Data(8-bits): 1 → 8 clocks for Byte, 2 → 4 clocks for Byte, 4 → 2 clocks for Byte. Datasheet DS-AT25SF161B-188 Revision E 14 21-Apr-2021 © 2021 Dialog Semiconductor AT25SF161B 16-Mbit SPI Serial Flash Memory with Dual I/O and Quad I/O Support 7 Read Commands 7.1 READ ARRAY (0BH AND 03H) The Read Array command can be used to sequentially read a continuous stream of data from the device by providing the clock pin once the initial starting address is specified. The device incorporates an internal address counter that automatically increments every clock cycle. To perform the Read Array operation, the CS pin first must be asserted, and the appropriate opcode (0Bh or 03h) must be clocked into the device. After the opcode has been clocked in, the three address bytes must be clocked in to specify the starting address location of the first byte to read within the memory array. If the 0Bh opcode is used for the Read Array operation, an additional dummy byte must be clocked into the device after the three address bytes. After the three address bytes (and the dummy byte, if using opcode 0Bh) have been clocked in, additional clock cycles result in data being output on the SO pin. The data is always output with the MSB of a byte first. When the last byte (1FFFFFh) of the memory array has been read, the device continues reading back at the beginning of the array (000000h). No delays are incurred when wrapping around from the end of the array to the beginning of the array. Deasserting the CS pin terminates the read operation and puts the SO pin into high-impedance state. The CS pin can be deasserted at any time and does not require a full byte of data be read. CS 0 1 2 3 4 5 6 7 8 9 10 11 12 29 30 31 32 33 34 35 36 37 38 39 40 SCK OPCODE SI 0 0 0 0 0 ADDRESS BITS A23-A0 0 1 A 1 MSB A A A A A A A A MSB DATA BYTE 1 High-Impedance SO D D D D D D D MSB D D D MSB Figure 6: Read Array - 03h Opcode CS 0 1 2 3 4 5 6 7 8 9 10 11 12 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 SCK OPCODE SI 0 0 0 0 1 MSB ADDRESS BITS A23-A0 0 1 1 A A A A A A A DON'T CARE A A MSB X X X X X X X X MSB DATA BYTE 1 SO High-Impedance D MSB D D D D D D D D D MSB Figure 7: Read Array - 0Bh Opcode Datasheet DS-AT25SF161B-188 Revision E 15 21-Apr-2021 © 2021 Dialog Semiconductor AT25SF161B 16-Mbit SPI Serial Flash Memory with Dual I/O and Quad I/O Support 7.2 DUAL-OUTPUT READ ARRAY (3BH) The Dual-Output Read Array command is similar to the standard Read Array command; it can be used to sequentially read a continuous stream of data from the device by providing the clock pin once the initial starting address has been specified. Unlike the standard Read Array command, the Dual-Output Read Array command allows two bits of data to be clocked out of the device on every clock cycle, rather than just one. To perform the Dual-Output Read Array operation, the CS pin must first be asserted; then, the opcode 3Bh must be clocked into the device. After the opcode has been clocked in, the three address bytes must be clocked in to specify the location of the first byte to read within the memory array. Following the three address bytes, a single dummy byte also must be clocked into the device. After the three address bytes and the dummy byte have been clocked in, additional clock cycles output data on both the SO and SI pins. The data is output with the MSB of a byte first, and the MSB is output on the SO pin. During the first clock cycle, bit seven of the first data byte is output on the SO pin, while bit six of the same data byte is output on the SI pin. During the next clock cycle, bits five and four of the first data byte are output on the SO and SI pins, respectively. The sequence continues with each byte of data being output after every four clock cycles. When the last byte (1FFFFFh) of the memory array has been read, the device continues reading from the beginning of the array (000000h). There are no delays because of wrapping around from the end of the array to the beginning of the array. Deasserting the CS pin terminates the read operation and puts the SO and SI pins into a high-impedance state. The CS pin can be deasserted at any time and does not require that a full byte of data be read. CS 0 1 2 3 4 5 6 7 8 9 10 11 12 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 SCK 23&2'( SI (SIO) 0 0 1 1 1 0 06% SO $''5(66%,76$$ 1 1 A A A A A A A 287387 '$7$%
AT25SF161B-SSHD-T 价格&库存
很抱歉,暂时无法提供与“AT25SF161B-SSHD-T”相匹配的价格&库存,您可以联系我们找货
