S-89630AB0A-K8T2U
S-89630AB0A-K8T2U
    ABLIC(艾普凌科)
    TMSOP8_2.9X2.8MM
    IC CMOS 2 CIRCUIT 8TMSOP
S-89630AB0A-K8T2U 数据手册
S-89630A www.ablic.com 125°C OPERATION, LOW INPUT OFFSET VOLTAGE CMOS OPERATIONAL AMPLIFIER Rev.1.0_01 © ABLIC Inc., 2018-2019 This IC incorporates a general purpose analog circuit in a small package. This is a zero-drift operational amplifier with Rail-to-Rail input and output, which uses chopper-stabilizing techniques to provide low input offset voltage. The S-89630AB is a dual operational amplifier (2 circuits), which is suitable for applications requiring less offset voltage.  Features • Low input offset voltage: • Low input offset voltage drift: • Operation power supply voltage range: • • • • • • • • Low current consumption (Per circuit): Low input noise voltage: Low input noise voltage density: Built-in output current limit circuit: Internal phase compensation: Rail-to-Rail input and output Operation temperature range: Lead-free (Sn 100%), halogen-free VIO = +50 μV max. (Ta = −40°C to +125°C) ΔVIO = ±25 nV/°C typ. (VDD = 30.0 V, Ta = −40°C to +125°C) ΔTa VDD = 4.0 V to 36.0 V (Single supply) VDD = ±2.0 V to ±18.0 V (Dual supply) IDD = 250 μA typ. VNOISE_pp = 0.8 μVpp typ. (f = 0.1 Hz to 10 Hz) VNOISE = 25 nV/√Hz typ. (f = 1 kHz) Overcurrent limit when output pin is short-circuited No external parts required Ta = −40°C to +125°C  Applications • High-accuracy current detection • Various sensor interfaces • Strain gauge amplifier  Package • TMSOP-8 1 125°C OPERATION, LOW INPUT OFFSET VOLTAGE CMOS OPERATIONAL AMPLIFIER S-89630A Rev.1.0_01  Block Diagram VDD IN1(+) + IN1(−) − OUT1 IN2(+) + IN2(−) − OUT2 VSS Figure 1 2 125°C OPERATION, LOW INPUT OFFSET VOLTAGE CMOS OPERATIONAL AMPLIFIER Rev.1.0_01 S-89630A  Product Name Structure Refer to "1. Product name" regarding the contents of product name, "2. drawings and "3. 1. Package" regarding the package Product name list" regarding the product type. Product name S-89630A B 0 A - K8T2 U Environmental code U: Lead-free (Sn 100%), halogen-free Package abbreviation and IC packing specifications*1 K8T2: TMSOP-8, Tape Operation temperature A: Ta = −40°C to +125°C Number of circuits B: 2 *1. 2. Refer to the tape drawing. Package Package Name TMSOP-8 3. Table 1 Package Drawing Codes Dimension Tape FM008-A-P-SD Reel FM008-A-C-SD FM008-A-R-SD Product name list Table 2 Product Name S-89630AB0A-K8T2U Package TMSOP-8 3 125°C OPERATION, LOW INPUT OFFSET VOLTAGE CMOS OPERATIONAL AMPLIFIER S-89630A Rev.1.0_01  Pin Configuration 1. TMSOP-8 Top view 1 2 3 4 8 7 6 5 Figure 2 4 Pin No. 1 2 3 4 5 6 7 8 Table 3 Symbol OUT1 IN1(−) IN1(+) VSS IN2(+) IN2(−) OUT2 VDD Description Output pin 1 Inverted input pin 1 Non-inverted input pin 1 GND pin Non-inverted input pin 2 Inverted input pin 2 Output pin 2 Positive power supply pin 125°C OPERATION, LOW INPUT OFFSET VOLTAGE CMOS OPERATIONAL AMPLIFIER Rev.1.0_01 S-89630A  Absolute Maximum Ratings Table 4 (Tj = −40°C to +150°C unless otherwise specified) Item Power supply voltage Input voltage Output voltage Differential input voltage Input pin current Junction temperature Operation ambient temperature Storage temperature Caution Symbol VDD VIN(+), VIN(−) VOUT VIND IIN Tj Topr Tstg Absolute Maximum Rating VSS − 0.3 to VSS + 45.0 VSS − 0.3 to VDD + 0.3 VSS − 0.3 to VDD + 0.3 ±0.5 ±10.0 −40 to +150 −40 to +125 −40 to +150 Unit V V V V mA °C °C °C The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions.  Thermal Resistance Value Table 5 Item Symbol Condition Board A Board B TMSOP-8 θJA Junction-to-ambient thermal resistance*1 Board C Board D Board E *1. Test environment: compliance with JEDEC STANDARD JESD51-2A Min. − − − − − Typ. 160 133 − − − Max. − − − − − Unit °C/W °C/W °C/W °C/W °C/W Remark Refer to " Power Dissipation" and "Test Board" for details. 5 125°C OPERATION, LOW INPUT OFFSET VOLTAGE CMOS OPERATIONAL AMPLIFIER S-89630A Rev.1.0_01  Electrical Characteristics 1. Recommended operation conditions Table 6 (Ta = −40°C to +125°C unless otherwise specified) Item Symbol Condition Min. Typ. Max. Unit Test Circuit − 4.0 − 36.0 V − Operation power supply VDD voltage range 2. VDD = 5.0 V Table 7 (Ta = −40°C to +125°C unless otherwise specified) DC Electrical Characteristics Item Symbol Condition Min. Typ. Max. Unit Test Circuit VDD 2 − 500 760 μA 5 −50 ±10 +50 μV 1 −125 ±30 +125 nV/°C 1 Current consumption (2 circuits) IDD VCMR = VOUT = Input offset voltage VIO VCMR = Input offset voltage drift ΔVIO ΔTa VDD 2 VDD VCMR = 2 Input bias current Input offset current Common-mode input voltage range IBIAS IIO − − − − 3 3 10 10 nA nA 9,10 9,10 VCMR − VSS − VDD V 2 Voltage gain (open loop) AVOL VSS + 0.5 V ≤ VOUT ≤ VDD − 0.5 V, VDD VCMR = 2 , RL = 10 kΩ 93 110 − dB 8 ISOURCE = 100 μA 4.9 − − V 3 4.7 − − − V 3 − 0.1 V 4 ISINK = 1 mA − − 0.3 V 4 CMRR VSS ≤ VCMR ≤ VDD 93 110 − dB 2 PSRR 4.0 V ≤ VDD ≤ 36.0 V 116 130 − dB 1 Source current ISOURCE VOUT = VDD − 0.1 V 0.40 0.60 − mA 6 Sink current Output pin short-circuit current (source) Output pin short-circuit current (sink) ISINK VOUT = 0.1 V 0.25 0.50 − mA 7 ISHORT_SOURCE VOUT = 0 V − 16.0 − mA − ISHORT_SINK VOUT = VDD − 15.0 − mA − Maximum output swing voltage Common-mode input signal rejection ratio Power supply voltage rejection ratio 6 VOH VOL ISOURCE = 1 mA ISINK = 100 μA 125°C OPERATION, LOW INPUT OFFSET VOLTAGE CMOS OPERATIONAL AMPLIFIER Rev.1.0_01 S-89630A Table 8 (Ta = −40°C to +125°C unless otherwise specified) AC Electrical Characteristics Item Symbol Condition RL = 1.0 MΩ, CL = 15 pF (Refer to Figure 13 and Figure 14), VIN(+) = 1.5 V ↔ 3.5 V CL = 0 pF Min. Typ. Max. Unit − 0.45 − V/μs Slew rate SR Gain-bandwidth product GBP − 1.2 − Maximum load capacitance CL − − 470 − MHz pF Input noise voltage VNOISE_pp f = 0.1 Hz to 10 Hz − 0.8 − μVpp Input noise voltage density VNOISE − 25 − nV/√Hz f = 1 kHz 7 125°C OPERATION, LOW INPUT OFFSET VOLTAGE CMOS OPERATIONAL AMPLIFIER S-89630A Rev.1.0_01 3. VDD = 30.0 V Table 9 (Ta = −40°C to +125°C unless otherwise specified) DC Electrical Characteristics Item Symbol Condition Min. Typ. Max. Unit Test Circuit VDD 2 − 500 760 μA 5 −50 ±10 +50 μV 1 −120 ±25 +120 nV/°C 1 Current consumption (2 circuits) IDD VCMR = VOUT = Input offset voltage VIO VCMR = Input offset voltage drift ΔVIO ΔTa Input bias current IBIAS − − 3 10 nA 9,10 Input offset current Common-mode input voltage range IIO − − 3 10 nA 9,10 VCMR − VSS − VDD V 2 Voltage gain (open loop) AVOL VSS + 0.5 V ≤ VOUT ≤ VDD − 0.5 V, VDD VCMR = 2 , RL = 10 kΩ 106 120 − dB 8 ISOURCE = 100 μA 29.9 − − V 3 ISOURCE = 1 mA 29.7 − − − V 3 − 0.1 V 4 − − 0.3 V 4 Maximum output swing voltage Common-mode input signal rejection ratio Power supply voltage rejection ratio VOH VOL VDD 2 VDD VCMR = 2 ISINK = 100 μA ISINK = 1 mA CMRR VSS ≤ VCMR ≤ VDD 106 120 − dB 2 PSRR 4.0 V ≤ VDD ≤ 36.0 V 116 130 − dB 1 Source current ISOURCE VOUT = VDD − 0.1 V 0.40 0.60 − mA 6 Sink current Output pin short-circuit current (source) Output pin short-circuit current (sink) ISINK VOUT = 0.1 V 0.25 0.50 − mA 7 ISHORT_SOURCE VOUT = 0 V − 16.0 − mA − ISHORT_SINK VOUT = VDD − 15.0 − mA − 8 125°C OPERATION, LOW INPUT OFFSET VOLTAGE CMOS OPERATIONAL AMPLIFIER Rev.1.0_01 S-89630A Table 10 (Ta = −40°C to +125°C unless otherwise specified) AC Electrical Characteristics Item Symbol Slew rate SR Gain-bandwidth product GBP Maximum load capacitance CL Input noise voltage Input noise voltage density Condition RL = 1.0 MΩ, CL = 15 pF (Refer to Figure 13 and Figure 14), VIN(+) = 14.0 V ↔ 16.0 V CL = 0 pF Min. Typ. Max. Unit − 0.45 − V/μs − 1.2 − − 470 − MHz pF VNOISE_pp f = 0.1 Hz to 10 Hz − 0.8 − μVpp VNOISE − 25 − nV/√Hz − f = 1 kHz 9 125°C OPERATION, LOW INPUT OFFSET VOLTAGE CMOS OPERATIONAL AMPLIFIER S-89630A Rev.1.0_01  Test Circuits (Per circuit) 1. Power supply voltage rejection ratio, input offset voltage, input offset voltage drift • Power supply voltage rejection ratio (PSRR) VDD The power supply voltage rejection ratio (PSRR) can be calculated by the following expression, with VOUT measured at each VDD. RF RS − VOUT + RS Test conditions: VDD = 4.0 V: VDD = VDD1, VOUT = VOUT1 VDD = 36.0 V: VDD = VDD2, VOUT = VOUT2 RF PSRR = 20 log VDD VCMR = 2 Figure 3 VDD1 − VDD2   VDD1 VDD2   VOUT1 − 2  − VOUT2 − 2   × RF + RS  RS    • Input offset voltage (VIO) Test Circuit 1 VIO = VOUT − VDD 2   × RS RF + RS • Input offset voltage drift ΔVIO ΔTa  The input offset voltage drift ΔVIO ΔTa  can be calculated by the following expression, with VOUT measured at each temperature. Test conditions: Ta = −40°C: VIO = VIO1 Ta = +125°C: VIO = VIO2 ΔVIO VIO2 − VIO1 = ΔTa +125°C − (−40°C) 2. Common-mode input signal rejection ratio, common-mode input voltage range • Common-mode input signal rejection ratio (CMRR) VDD The common-mode input signal rejection ratio (CMRR) can be calculated by the following expression, with VOUT measured at each VIN. RF RS − VOUT + RS Test conditions: VIN = VCMR Max.: VIN = VIN1, VOUT = VOUT1 VIN = VCMR Min.: VIN = VIN2, VOUT = VOUT2 RF CMRR = 20 log VIN VDD 2 Figure 4 10    VIN1 − VIN2 RF + RS  × R  S VOUT1 − VOUT2  • Common-mode input voltage range (VCMR) Test Circuit 2 The common-mode input voltage range is the range of VIN in which VOUT satisfies the common-mode input signal rejection ratio specifications when VIN is changed. 125°C OPERATION, LOW INPUT OFFSET VOLTAGE CMOS OPERATIONAL AMPLIFIER Rev.1.0_01 S-89630A 3. Maximum output swing voltage • Maximum output swing voltage (VOH) VDD − VOH + Test conditions: VDD VIN1 = 2 − 0.1 V VDD VIN2 = 2 + 0.1 V ISOURCE = 100 μA, 1 mA ISOURCE VIN1 Figure 5 4. VDD 2 VIN2 Test Circuit 3 Maximum output swing voltage VDD • Maximum output swing voltage (VOL) VDD 2 Test conditions: VDD VIN1 = 2 + 0.1 V VDD VIN2 = 2 − 0.1 V ISINK = 100 μA, 1 mA ISINK − + VIN1 VIN2 Figure 6 5. VOL Test Circuit 4 Current consumption VDD • Current consumption (IDD) A − + VCMR = VDD 2 Figure 7 Test Circuit 5 11 125°C OPERATION, LOW INPUT OFFSET VOLTAGE CMOS OPERATIONAL AMPLIFIER S-89630A Rev.1.0_01 6. Source current • Source current (ISOURCE) VDD Test conditions: VOUT = VDD − 0.1 V VDD VIN1 = 2 − 0.1 V VDD VIN2 = 2 + 0.1 V − + VIN1 A VOUT VIN2 Figure 8 7. Test Circuit 6 Sink current VDD • Sink current (ISINK) VOUT Test conditions: VOUT = 0.1 V VDD VIN1 = 2 + 0.1 V VDD VIN2 = 2 − 0.1 V A − + VIN1 VIN2 Figure 9 8. Test Circuit 7 Voltage gain • Voltage gain (open loop) (AVOL) VDD RS RF − D.U.T + RS RF VDDN + NULL − VDD 2 VDD 2 Figure 10 12 VOUT Test conditions: VM = VDD − 0.5 V: VM = VM1, VOUT = VOUT1 VM = VSS + 0.5 V: VM = VM2, VOUT = VOUT2 RL VSSN VCMR = The voltage gain (AVOL) can be calculated by the following expression, with VOUT measured at each V M. VM Test Circuit 8 AVOL = 20 log RL = 10 kΩ    RF + RS  VM1 − VM2 × R  S VOUT1 − VOUT2  125°C OPERATION, LOW INPUT OFFSET VOLTAGE CMOS OPERATIONAL AMPLIFIER Rev.1.0_01 S-89630A 9. Input bias current, input offset current ・Input bias current (IBIAS) VDD Test conditions: VDD −1 × (VOUT − 2 ) IN(+) pin input bias current (IBIAS(+)) = RB − VOUT + RB VDD VOUT − 2 IN(−) pin input bias current (IBIAS(−)) = RB IBIAS = VCMR = |IBIAS(+) + IBIAS(−)| 2 VDD 2 ・Input offset current (IIO) Figure 11 Test Circuit 9 IIO = |IBIAS(−) − IBIAS(+)| VDD RB − VOUT + VCMR = VDD 2 Figure 12 Test Circuit 10 13 125°C OPERATION, LOW INPUT OFFSET VOLTAGE CMOS OPERATIONAL AMPLIFIER S-89630A Rev.1.0_01 10. Slew rate VDD − VOUT + VIN(+) CL = 15 pF RL = 1.0 MΩ VDD 2 Figure 13 Test Circuit 11 tR = tF = 200 ns (10 V/μs) VDD 2 + 1.0 V When falling 1.6 V SR = t THL VIN(+) VDD 2 − 1.0 V When rising 1.6 V SR = t TLH tTHL VDD 2 + 1.0 V) × 0.8 VDD ( 2 − 1.0 V) × 0.8 ( VOUT (= VIN(−)) tTLH Figure 14 14 ・Slew rate (SR) 125°C OPERATION, LOW INPUT OFFSET VOLTAGE CMOS OPERATIONAL AMPLIFIER Rev.1.0_01 S-89630A  Precautions • Generally an operational amplifier may cause oscillation depending on the selection of external parts. Perform thorough evaluation using the actual application to set the constants. • Do not apply an electrostatic discharge to this IC that exceeds performance ratings of the built-in electrostatic protection circuit. • ABLIC Inc. claims no responsibility for any disputes arising out of or in connection with any infringement by products including this IC of patents owned by a third party. • This IC operates stably even directly connecting a load capacitance of 470 pF or less to the output pin, as shown in Figure 15. When connecting a load capacitance of 470 pF or more, connect a resistor of 100 Ω or more as shown in Figure 16. In case of connecting a filter for noise prevention, and connecting a load capacitance of 470 pF or more, also connect a resistor of 100 Ω or more as shown in Figure 17. VDD VIN+ + VIN− − VOUT Load capacitance 470 pF or less VSS Figure 15 VDD VIN+ + VIN− − VOUT 100 Ω or more Load capacitance VSS Figure 16 VDD Filter VIN+ + VIN− − VOUT 100 Ω or more Load capacitance VSS Figure 17 Caution The above connection diagrams and constants will not guarantee successful operation. Perform thorough evaluation using the actual application to set the constants. 15 125°C OPERATION, LOW INPUT OFFSET VOLTAGE CMOS OPERATIONAL AMPLIFIER S-89630A Rev.1.0_01  Precaution for use 1. Methods for protection against application of overvoltage to input pin ESD protection elements are connected to the input pins as shown in Figure 1. If the input voltage (VIN) exceeds the VIN absolute maximum rating VDD + 0.3 V, there is a risk of the input pin current which flows through the ESD protection element exceeding ±10.0 mA (the absolute maximum rating). In this case, connect a current limiting resistor (RLIMT) to the input pin as shown in Figure 18 to limit the input pin current to less than ±10.0 mA. However, error voltage and noise generate as a result of input bias current and input offset current. Select the lowest possible resistance when connecting the RLIMT. VDD VIN RLIMT − + VOUT Figure 18 2. Input voltage range (input crossover distortion) This IC has two sets of differential circuits in order to achieve the Rail-to-Rail input voltage range. The differential circuits used switch based on the common-mode input voltage range (VCMR). Differences in the characteristics of the two sets of differential circuits result in the generation of distortion of the output voltage which is referred to as "input crossover distortion" when the differential circuits switch. The differential circuit switching voltage of this IC is approximately between VDD − 2.2 V and VDD − 1.2 V. When using this IC in applications which require high-accuracy measurement, avoid the range near the differential circuit switching voltage in order to avoid changes in input offset voltage caused by input crossover distortion and changes in input offset voltage drift. This IC is a chopper-stabilized zero-drift amplifier; therefore, it always cancels input offset voltage. For this reason, the input crossover distortion is kept extremely small when compared to standard operational amplifiers. However, please contact our sales representatives when using this IC near the differential circuit switching voltage. Refer to "8. Input offset voltage (VIO) vs. Common-mode input voltage range (VCMR)" in " Characteristics (Typical Data)". VDD Approximately VDD − 2.2 V to VDD − 1.2 V Input range Output circuit Differential circuit 1 Differential circuit 2 Figure 19 16 Distortion 125°C OPERATION, LOW INPUT OFFSET VOLTAGE CMOS OPERATIONAL AMPLIFIER Rev.1.0_01 S-89630A 3. Recommended processing methods for unused circuit When using only a single circuit of this IC, it is recommended that the unused circuit be connected as shown in Figure 20. Set the non-inverted input pin voltage (VIN(+)) within the common-mode input voltage range (VCMR). VDD − VOUT + VIN(+) = VSS to VDD Figure 20 17 125°C OPERATION, LOW INPUT OFFSET VOLTAGE CMOS OPERATIONAL AMPLIFIER S-89630A Rev.1.0_01  Characteristics (Typical Data) 1. Current consumption (IDD) (Per circuit) vs. Power supply voltage (VDD) 400 Ta = +125°C IDD [μA] 300 200 Ta = +25°C Ta = −40°C 100 0 2. 0 10 20 VDD [V] 30 40 Voltage gain (AVOL) vs. Frequency (f) VDD = 4.0 V VDD = 18.0 V 120 120 100 Ta = +125°C 80 60 40 Ta = −40°C Ta = +25°C 20 0 0.01 0.1 1 10 100 f [kHz] 1000 10000 VDD = 36.0 V AVOL [dB] 100 Ta = +125°C 80 60 Ta = +25°C Ta = −40°C 20 0 0.01 18 Ta = +125°C 80 60 40 Ta = +25°C Ta = −40°C 20 120 40 AVOL [dB] AVOL [dB] 100 0.1 1 10 100 f [kHz] 1000 10000 0 0.01 0.1 1 10 100 f [kHz] 1000 10000 125°C OPERATION, LOW INPUT OFFSET VOLTAGE CMOS OPERATIONAL AMPLIFIER Rev.1.0_01 S-89630A Output current 3. 1 Source current (ISOURCE) vs. Power supply voltage (VDD) VOUT = VDD − 0.1 V, VSS = 0 V 1.2 0.8 Ta = −40°C 0.6 Ta = +25°C ISOURCE [mA] ISOURCE [mA] 5.0 0.4 Ta = +125°C 0.2 0.0 10 20 VDD [V] 30 3.0 Ta = +25°C 2.0 Ta = +125°C 1.0 40 0 VOUT = VSS + 0.1 V, VSS = 0 V 10 30 40 ISINK [mA] 5.0 0.8 Ta = −40°C 0.6 Ta = +25°C 0.4 0.2 0 10 20 VDD [V] 30 4.0 Ta = −40°C 3.0 Ta = +25°C 2.0 1.0 Ta = +125°C 0.0 Ta = +125°C 0.0 40 0 10 20 VDD [V] 30 40 Output voltage (VOUT) vs. Source current (ISOURCE) VDD = 4.0 V, VSS = 0 V VDD = 18.0 V, VSS = 0 V 5.0 20 4.0 Ta = −40°C 3.0 Ta = +25°C 2.0 1.0 Ta = −40°C Ta = +25°C 15 VOUT [V] VOUT [V] 20 VDD [V] VOUT = VSS + 0.5 V, VSS = 0 V 6.0 1.0 ISINK [mA] Ta = −40°C Sink current (ISINK) vs. Power supply voltage (VDD) 1.2 3. 3 4.0 0.0 0 3. 2 VOUT = VDD − 0.5 V, VSS = 0 V 6.0 1.0 10 Ta = +125°C 5 Ta = +125°C 0.0 0 0 5 10 15 ISOURCE [mA] 20 25 0 5 10 15 ISOURCE [mA] 20 25 VDD = 36.0 V, VSS = 0 V 40 30 VOUT [V] 3. Ta = −40°C 20 Ta = +25°C 10 Ta = +125°C 0 0 5 10 15 ISOURCE [mA] 20 25 19 125°C OPERATION, LOW INPUT OFFSET VOLTAGE CMOS OPERATIONAL AMPLIFIER S-89630A Rev.1.0_01 3. 4 Output voltage (VOUT) vs. Sink current (ISINK) VDD = 18.0 V, VSS = 0 V VDD = 4.0 V, VSS = 0 V 5.0 Ta = +125°C 4.0 15 VOUT [V] VOUT [V] 20 3.0 2.0 Ta = +25°C 1.0 0 5 10 15 ISINK [mA] 25 VDD = 36.0 V, VSS = 0 V VOUT [V] Ta = +125°C Ta = +25°C 20 Ta = −40°C 10 0 0 4. 5 10 15 ISINK [mA] 20 25 Input bias current (IBIAS) vs. Temperature (Ta) VDD = 36.0 V 100 IBIAS [nA] 75 50 25 0 −25 −40 −25 0 25 50 Ta [°C] 20 75 Ta = −40°C 0 20 40 30 Ta = +25°C 10 5 Ta = −40°C 0.0 Ta = +125°C 100 125 0 5 10 15 ISINK [mA] 20 25 125°C OPERATION, LOW INPUT OFFSET VOLTAGE CMOS OPERATIONAL AMPLIFIER Rev.1.0_01 S-89630A 5. Input noise voltage density (VNOISE) vs. Frequency (f) VDD = 4.0 V, VSS = 0 V Ta = +125°C Ta = +25°C 10 Ta = −40°C Ta = +125°C Ta = +25°C 10 1 Ta = −40°C 1 0.1 1 10 100 f [kHz] 0.1 1 10 100 f [kHz] VDD = 36.0 V, VSS = 0 V 100 VNOISE [nV/√Hz] VDD = 18.0 V, VSS = 0 V 100 VNOISE [nV/√Hz] VNOISE [nV/√Hz] 100 Ta = +125°C Ta = +25°C 10 Ta = −40°C 1 0.1 1 10 100 f [kHz] Input pin current (IIN) vs. Differential input voltage (VIND) VDD = 36.0 V, VSS = 0 V 20 10 IIN [μA] 6. Ta = −40°C 0 −10 −20 −1.0 Ta = +25°C Ta = +125°C −0.5 0.0 VIND [V] 0.5 1.0 21 125°C OPERATION, LOW INPUT OFFSET VOLTAGE CMOS OPERATIONAL AMPLIFIER S-89630A Rev.1.0_01 7. Input offset voltage (VIO) vs. Power supply voltage (VDD) VSS = 0 V, VCMR = VDD/2 50 VIO [μV] 25 0 −25 −50 0 20 VDD [V] 30 40 Measured six samples Remark 8. 10 Input offset voltage (VIO) vs. Common-mode input voltage range (VCMR) VDD = 4.0 V, VSS = 0 V VDD = 18.0 V, VSS = 0 V 25 25 VIO [μV] 50 VIO [μV] 50 0 −25 −25 −50 0 1 2 3 4 VCMR [V] VDD = 36.0 V, VSS = 0 V 50 VIO [μV] 25 0 −25 −50 Remark 22 0 0 10 20 VCMR [V] Measured four samples 30 40 −50 0 5 10 VCMR [V] 15 20 125°C OPERATION, LOW INPUT OFFSET VOLTAGE CMOS OPERATIONAL AMPLIFIER Rev.1.0_01 S-89630A 9. Voltage gain (open loop) (AVOL) vs. Temperature (Ta) VDD = 18.0 V, VSS = 0 V 160 140 140 AVOL [dB] AVOL [dB] VDD = 4.0 V, VSS = 0 V 160 120 100 80 −40 −25 0 25 50 75 100 125 120 100 80 −40 −25 Ta [°C] 0 25 50 75 100 125 Ta [°C] VDD = 36.0 V, VSS = 0 V AVOL [dB] 160 140 120 100 80 −40 −25 0 25 50 75 100 125 Ta [°C] 10. Power supply voltage rejection ratio (PSRR) vs. Temperature (Ta) PSRR [dB] 160 140 120 100 80 −40 −25 0 25 50 75 100 125 Ta [°C] 23 125°C OPERATION, LOW INPUT OFFSET VOLTAGE CMOS OPERATIONAL AMPLIFIER S-89630A Rev.1.0_01 11. Common-mode input signal rejection ratio (CMRR) vs. Temperature (Ta) 140 140 120 100 80 −40 −25 0 25 50 75 100 125 Ta [°C] VDD = 36.0 V, VSS = 0 V CMRR [dB] 140 120 100 80 −40 −25 0 25 50 Ta [°C] 120 100 80 −40 −25 0 25 50 Ta [°C] 160 24 VDD = 18.0 V, VSS = 0 V 160 CMRR [dB] CMRR [dB] VDD = 4.0 V, VSS = 0 V 160 75 100 125 75 100 125 125°C OPERATION, LOW INPUT OFFSET VOLTAGE CMOS OPERATIONAL AMPLIFIER Rev.1.0_01 S-89630A 12. Step response (Slew rate) 12. 1 Input signal width (0.4 V) 12. 1. 1 VIN(+) = 1.8 V ↔ 2.2 V 12. 1. 2 VIN(+) = 8.8 V ↔ 9.2 V VDD = 18.0 V, VSS = 0 V VDD = 4.0 V, VSS = 0 V 9.4 VOUT, Ta = −40°C 2.2 2.0 VIN 1.8 1.6 12. 1. 3 VIN, VOUT [V] VIN, VOUT [V] 2.4 VOUT, Ta = +125°C VOUT, Ta = +25°C −1 0 1 2 3 4 t [μs] 5 6 7 VOUT, Ta = −40°C 9.2 9.0 VIN 8.8 8.6 VOUT, Ta = +125°C VOUT, Ta = +25°C −1 0 1 2 3 4 t [μs] 5 6 7 VIN(+) = 17.8 V ↔ 18.2 V VDD = 36.0 V, VSS = 0 V VIN, VOUT [V] 18.4 VOUT, Ta = −40°C 18.2 18.0 VIN 17.8 17.6 VOUT, Ta = +125°C VOUT, Ta = +25°C −1 0 1 2 3 4 t [μs] 5 6 7 25 125°C OPERATION, LOW INPUT OFFSET VOLTAGE CMOS OPERATIONAL AMPLIFIER S-89630A Rev.1.0_01 12. 2 Input signal width (4.0 V) 12. 2. 1 VIN(+) = 0 V ↔ 4.0 V VIN(+) = 7.0 V ↔ 11.0 V 12. 2. 2 VDD = 18.0 V, VSS = 0 V VDD = 4.0 V, VSS = 0 V 5 VOUT, Ta = −40°C 3 2 V IN 1 ° VOUT, Ta = 25°C 0 12. 2. 3 −10 0 10 20 30 40 t [μs] 50 60 VOUT, Ta = −40°C 11 VIN, VOUT [V] VIN, VOUT [V] 4 −1 12 10 9 V IN 8 ° VOUT, Ta = 25°C 7 6 70 −10 0 10 20 30 40 t [μs] 50 60 70 VIN(+) = 16.0 V ↔ 20.0 V VDD = 4.0 V, VSS = 0 V 21 VOUT, Ta = −40°C VIN, VOUT [V] 20 19 18 ° VOUT, Ta = 25°C 16 15 12. 3 V IN 17 −10 0 10 20 30 40 t [μs] 50 60 70 Input signal width (VSS ↔ VDD) 12. 3. 1 VIN(+) = 0 V ↔ 18.0 V 12. 3. 2 VIN(+) = 0 V ↔ 36.0 V VDD = 36.0 V, VSS = 0 V 40 15 30 10 VIN VOUT, Ta = −40°C 5 0 −5 26 VIN, VOUT [V] VIN, VOUT [V] VDD = 18.0 V, VSS = 0 V 20 VOUT, Ta = 25°C −10 0 10 20 30 40 t [μs] 50 60 70 20 VIN 10 VOUT, Ta = −40°C 0 −10 VOUT , Ta = +25°C −20 0 20 40 60 80 100 120 140 t [μs] 125°C OPERATION, LOW INPUT OFFSET VOLTAGE CMOS OPERATIONAL AMPLIFIER Rev.1.0_01 S-89630A 13. Input offset voltage distribution 50 50 40 40 30 20 10 0 30 20 10 0 −50 −40 −30 −20 −10 0 10 20 30 40 50 VIO [μV] −50 −40 −30 −20 −10 0 10 20 30 40 50 VIO [μV] Input offset voltage drift distribution VDD = 5.0 V, VSS = 0 V, Ta = −40°C to +125°C VDD = 30.0 V, VSS = 0 V, Ta = −40°C to +125°C 50 50 40 40 Percentage [%] Percentage [%] 14. VDD = 30.0 V, VSS = 0 V, Ta = +25°C Percentage [%] Percentage [%] VDD = 5.0 V, VSS = 0 V, Ta = +25°C 30 20 10 0 0 20 40 60 80 100 120 140 |ΔVIO/ΔTa| [nV/°C] 30 20 10 0 0 20 40 60 80 100 120 140 |ΔVIO/ΔTa| [nV/°C] 27 125°C OPERATION, LOW INPUT OFFSET VOLTAGE CMOS OPERATIONAL AMPLIFIER S-89630A Rev.1.0_01  Power Dissipation TMSOP-8 Tj = +150°C max. 1.0 Power dissipation (PD) [W] B 0.8 A 0.6 0.4 0.2 0.0 0 25 50 75 100 125 150 Ambient temperature (Ta) [°C] 28 Board Power Dissipation (PD) A 0.78 W B 0.94 W C − D − E − 175 2.90±0.2 8 5 1 4 0.13±0.1 0.2±0.1 0.65±0.1 No. FM008-A-P-SD-1.2 TITLE TMSOP8-A-PKG Dimensions No. FM008-A-P-SD-1.2 ANGLE UNIT mm ABLIC Inc. 2.00±0.05 4.00±0.1 4.00±0.1 1.00±0.1 +0.1 1.5 -0 1.05±0.05 0.30±0.05 3.25±0.05 4 1 5 8 Feed direction No. FM008-A-C-SD-2.0 TITLE TMSOP8-A-Carrier Tape FM008-A-C-SD-2.0 No. ANGLE UNIT mm ABLIC Inc. 16.5max. 13.0±0.3 Enlarged drawing in the central part 13±0.2 (60°) (60°) No. FM008-A-R-SD-1.0 TITLE TMSOP8-A-Reel No. FM008-A-R-SD-1.0 QTY. ANGLE UNIT mm ABLIC Inc. 4,000 Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-89630AB0A-K8T2U 价格&库存
很抱歉,暂时无法提供与“S-89630AB0A-K8T2U”相匹配的价格&库存,您可以联系我们找货
