74AUP1G00
Low-power 2-input NAND gate
Rev. 6 — 27 June 2012
Product data sheet
1. General description
The 74AUP1G00 provides the single 2-input NAND function.
Schmitt-trigger action at all inputs makes the circuit tolerant to slower input rise and fall
times across the entire VCC range from 0.8 V to 3.6 V.
This device ensures a very low static and dynamic power consumption across the entire
This device is fully specified for partial Power-down applications using IOFF.
The IOFF circuitry disables the output, preventing the damaging backflow current through
the device when it is powered down.
2. Features and benefits
Wide supply voltage range from 0.8 V to 3.6 V
High noise immunity
Complies with JEDEC standards:
JESD8-12 (0.8 V to 1.3 V)
JESD8-11 (0.9 V to 1.65 V)
JESD8-7 (1.2 V to 1.95 V)
JESD8-5 (1.8 V to 2.7 V)
JESD8-B (2.7 V to 3.6 V)
ESD protection:
HBM JESD22-A114F Class 3A exceeds 5000 V
MM JESD22-A115-A exceeds 200 V
CDM JESD22-C101E exceeds 1000 V
Low static power consumption; ICC = 0.9 μA (maximum)
Latch-up performance exceeds 100 mA per JESD 78 Class II
Inputs accept voltages up to 3.6 V
Low noise overshoot and undershoot < 10 % of VCC
IOFF circuitry provides partial Power-down mode operation
Multiple package options
Specified from −40 °C to +85 °C and −40 °C to +125 °C
74AUP1G00
NXP Semiconductors
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74AUP1G00GW
−40 °C to +125 °C
TSSOP5
plastic thin shrink small outline package; 5 leads;
body width 1.25 mm
SOT353-1
74AUP1G00GM
−40 °C to +125 °C
XSON6
plastic extremely thin small outline package; no leads; SOT886
6 terminals; body 1 × 1.45 × 0.5 mm
74AUP1G00GF
−40 °C to +125 °C
XSON6
plastic extremely thin small outline package; no leads; SOT891
6 terminals; body 1 × 1 × 0.5 mm
74AUP1G00GN
−40 °C to +125 °C
XSON6
6 terminals; body 0.9 × 1.0 × 0.35 mm
SOT1115
74AUP1G00GS
−40 °C to +125 °C
XSON6
6 terminals; body 1.0 × 1.0 × 0.35 mm
SOT1202
74AUP1G00GX
−40 °C to +125 °C
X2SON5
X2SON5: plastic thermal enhanced extremely thin
small outline package; no leads; 5 terminals;
body 0.8 × 0.8 × 0.35 mm
SOT1226
4. Marking
Table 2.
Marking
Marking code[1]
Type number
74AUP1G00GW
pA
74AUP1G00GM
pA
74AUP1G00GF
pA
74AUP1G00GN
pA
74AUP1G00GS
pA
74AUP1G00GX
pA
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
B
1
B
2
A
1
Y
4
4
Y
2
A
mna097
Fig 1. Logic symbol
74AUP1G00
Product data sheet
mna099
mna098
Fig 2. IEC logic symbol
All information provided in this document is subject to legal disclaimers.
Fig 3. Logic diagram
© NXP B.V. 2012. All rights reserved.
2 of 21
74AUP1G00
NXP Semiconductors
6. Pinning information
6.1 Pinning
74AUP1G00
74AUP1G00
B
1
A
2
GND
3
5
4
B
1
6
VCC
A
2
5
n.c.
GND
3
4
Y
VCC
Y
001aaf017
Transparent top view
001aaf016
Fig 4.
Pin configuration SOT353-1
Fig 5.
Pin configuration SOT886
74AUP1G00
74AUP1G00
B
B
1
6
VCC
A
2
5
n.c.
GND
3
4
Y
5
VCC
4
Y
3
GND
A
001aaf018
2
aaa-002995
Fig 6.
1
Pin configuration SOT891, SOT1115 and
SOT1202
Fig 7.
Pin configuration SOT1226 (X2SON5)
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
TSSOP5 and X2SON5
XSON6
B
1
1
data input
A
2
2
data input
GND
3
3
ground (0 V)
Y
4
4
data output
n.c.
5
not connected
VCC
5
6
supply voltage
74AUP1G00
Product data sheet
3 of 21
74AUP1G00
NXP Semiconductors
7. Functional description
Table 4.
Function table[1]
Input
Output
A
B
Y
L
L
H
L
H
H
H
L
H
H
H
L
[1]
H = HIGH voltage level; L = LOW voltage level.
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
output voltage
VO
Conditions
Min
−0.5
+4.6
V
VI < 0 V
−50
mA
−0.5
+4.6
V
[1]
Max
Unit
−50
mA
Active mode
[1]
−0.5
VCC + 0.5
V
Power-down mode
[1]
−0.5
+4.6
V
±20
mA
VO < 0 V
IO
output current
ICC
supply current
+50
mA
IGND
ground current
−50
mA
Tstg
storage temperature
−65
+150
°C
250
mW
total power dissipation
Ptot
[1]
[2]
VO = 0 V to VCC
Tamb = −40 °C to +125 °C
[2]
The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed.
For TSSOP5 packages: above 87.5 °C the value of Ptot derates linearly with 4.0 mW/K.
For XSON6 and X2SON5 packages: above 118 °C the value of Ptot derates linearly with 7.8 mW/K.
9. Recommended operating conditions
Table 6.
Symbol
Parameter
Min
Max
Unit
VCC
supply voltage
0.8
3.6
V
VI
input voltage
V
VO
output voltage
Active mode
VCC
V
Power-down mode; VCC = 0 V
V
Tamb
ambient temperature
−40
+125
°C
Δt/ΔV
input transition rise and fall rate
ns/V
74AUP1G00
Product data sheet
Conditions
VCC = 0.8 V to 3.6 V
4 of 21
74AUP1G00
NXP Semiconductors
10. Static characteristics
Table 7.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
VCC = 0.8 V
VCC = 0.9 V to 1.95 V
Typ
Max
Unit
0.70 × VCC -
V
0.65 × VCC -
V
VCC = 2.3 V to 2.7 V
1.6
V
VCC = 3.0 V to 3.6 V
2.0
V
VCC = 0.8 V
0.30 × VCC V
0.35 × VCC V
0.7
V
0.9
V
IO = −20 μA; VCC = 0.8 V to 3.6 V
VCC − 0.1
V
IO = −1.1 mA; VCC = 1.1 V
0.75 × VCC -
V
IO = −1.7 mA; VCC = 1.4 V
1.11
V
IO = −1.9 mA; VCC = 1.65 V
1.32
V
IO = −2.3 mA; VCC = 2.3 V
2.05
V
IO = −3.1 mA; VCC = 2.3 V
1.9
V
IO = −2.7 mA; VCC = 3.0 V
2.72
V
IO = −4.0 mA; VCC = 3.0 V
2.6
V
IO = 20 μA; VCC = 0.8 V to 3.6 V
0.1
V
IO = 1.1 mA; VCC = 1.1 V
0.3 × VCC
V
Tamb = 25 °C
VIH
VIL
VOH
VOL
HIGH-level input voltage
LOW-level input voltage
HIGH-level output voltage
LOW-level output voltage
VI = VIH or VIL
VI = VIH or VIL
IO = 1.7 mA; VCC = 1.4 V
0.31
V
IO = 1.9 mA; VCC = 1.65 V
0.31
V
IO = 2.3 mA; VCC = 2.3 V
0.31
V
IO = 3.1 mA; VCC = 2.3 V
0.44
V
IO = 2.7 mA; VCC = 3.0 V
0.31
V
IO = 4.0 mA; VCC = 3.0 V
0.44
V
II
input leakage current
VI = GND to 3.6 V; VCC = 0 V to 3.6 V
±0.1
μA
IOFF
power-off leakage current
VI or VO = 0 V to 3.6 V; VCC = 0 V
±0.2
μA
ΔIOFF
additional power-off
leakage current
VCC = 0 V to 0.2 V
±0.2
μA
ICC
supply current
VI = GND or VCC; IO = 0 A;
0.5
μA
ΔICC
additional supply current
VI = VCC − 0.6 V; IO = 0 A;
VCC = 3.3 V
40
μA
CI
input capacitance
VCC = 0 V to 3.6 V; VI = GND or VCC
0.8
pF
CO
output capacitance
VO = GND; VCC = 0 V
1.7
pF
74AUP1G00
Product data sheet
[1]
5 of 21
74AUP1G00
NXP Semiconductors
Table 7.
Static characteristics …continued
Symbol Parameter
Conditions
Min
VCC = 0.8 V
Typ
Max
Unit
0.70 × VCC -
V
0.65 × VCC -
V
1.6
V
2.0
V
VCC = 0.8 V
0.30 × VCC V
0.35 × VCC V
0.7
V
0.9
V
Tamb = −40 °C to +85 °C
VIH
VIL
VOH
VOL
VI = VIH or VIL
VCC − 0.1
V
0.7 × VCC
V
1.03
V
1.30
V
1.97
V
1.85
V
2.67
V
2.55
V
0.1
V
0.3 × VCC
V
0.37
V
0.35
V
0.33
V
0.45
V
0.33
V
VI = VIH or VIL
0.45
V
II
±0.5
μA
IOFF
±0.5
μA
ΔIOFF
leakage current
VCC = 0 V to 0.2 V
±0.6
μA
ICC
supply current
0.9
μA
ΔICC
VCC = 3.3 V
50
μA
74AUP1G00
Product data sheet
[1]
6 of 21
74AUP1G00
NXP Semiconductors
Table 7.
Symbol Parameter
Conditions
Min
VCC = 0.8 V
Typ
Max
Unit
0.75 × VCC -
V
0.70 × VCC -
V
1.6
V
2.0
V
VCC = 0.8 V
0.25 × VCC V
0.30 × VCC V
0.7
V
0.9
V
VIH
VIL
VOH
VOL
VI = VIH or VIL
VCC − 0.11 -
V
0.6 × VCC
V
0.93
V
1.17
V
1.77
V
1.67
V
2.40
V
2.30
V
0.11
V
0.33 × VCC V
0.41
V
0.39
V
0.36
V
0.50
V
0.36
V
VI = VIH or VIL
0.50
V
II
±0.75
μA
IOFF
±0.75
μA
ΔIOFF
leakage current
VCC = 0 V to 0.2 V
±0.75
μA
ICC
supply current
1.4
μA
ΔICC
VCC = 3.3 V
75
μA
[1]
[1]
One input at VCC − 0.6 V, other input at VCC or GND.
74AUP1G00
Product data sheet
7 of 21
74AUP1G00
NXP Semiconductors
11. Dynamic characteristics
Table 8.
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 9
Symbol
Parameter
Min
Typ [1]
Max
17.5
ns
VCC = 1.1 V to 1.3 V
2.5
5.3
11.0
ns
VCC = 1.4 V to 1.6 V
2.0
3.8
6.8
ns
Conditions
Unit
Tamb = 25 °C; CL = 5 pF
tpd
propagation delay
A, B to Y; see Figure 8
[2]
VCC = 0.8 V
VCC = 1.65 V to 1.95 V
1.6
3.1
5.3
ns
1.3
2.5
4.0
ns
1.0
2.2
3.6
ns
21.0
ns
2.4
6.1
13.0
ns
2.4
4.4
7.9
ns
Tamb = 25 °C; CL = 10 pF
tpd
propagation delay
[2]
VCC = 0.8 V
2.0
3.7
6.2
ns
1.4
3.0
4.7
ns
1.3
2.8
4.3
ns
24.5
ns
3.4
6.9
14.8
ns
2.8
5.0
8.9
ns
Tamb = 25 °C; CL = 15 pF
tpd
propagation delay
[2]
VCC = 0.8 V
2.0
4.1
7.0
ns
1.7
3.5
5.3
ns
1.6
3.2
4.9
ns
34.8
ns
4.6
9.2
20.1
ns
3.0
6.5
11.8
ns
Tamb = 25 °C; CL = 30 pF
tpd
propagation delay
[2]
VCC = 0.8 V
74AUP1G00
Product data sheet
2.6
5.4
9.3
ns
2.4
4.6
7.1
ns
2.3
4.3
6.5
ns
8 of 21
74AUP1G00
NXP Semiconductors
Table 8.
Dynamic characteristics …continued
Symbol
Parameter
Min
Typ [1]
Max
VCC = 0.8 V
2.6
pF
2.8
pF
2.9
pF
3.1
pF
3.6
pF
4.2
pF
Conditions
Unit
Tamb = 25 °C
power dissipation capacitance f = 1 MHz; VI = GND to VCC
CPD
[1]
[3]
All typical values are measured at nominal VCC.
[2]
tpd is the same as tPLH and tPHL.
[3]
CPD is used to determine the dynamic power dissipation (PD in μW).
PD = CPD × VCC2 × fi × N + Σ(CL × VCC2 × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
Σ(CL × VCC2 × fo) = sum of the outputs.
Table 9.
Symbol
Parameter
−40 °C to +85 °C
Conditions
−40 °C to +125 °C
Unit
Min
Max
Min
Max
2.1
12.2
2.1
13.5
ns
1.8
7.8
1.8
8.6
ns
1.4
6.2
1.4
6.9
ns
1.1
4.7
1.1
5.2
ns
1.0
4.2
1.0
4.7
ns
2.2
14.4
2.2
15.9
ns
2.2
9.2
2.2
10.2
ns
1.9
7.3
1.9
8.1
ns
1.3
5.6
1.3
6.2
ns
1.2
4.9
1.2
5.4
ns
CL = 5 pF
tpd
propagation delay
[1]
CL = 10 pF
tpd
propagation delay
74AUP1G00
Product data sheet
[1]
9 of 21
74AUP1G00
NXP Semiconductors
Table 9.
Symbol
Parameter
−40 °C to +85 °C
Conditions
−40 °C to +125 °C
Unit
Min
Max
Min
Max
3.1
16.5
3.1
18.2
ns
2.5
10.5
2.5
11.6
ns
2.0
8.3
2.0
9.2
ns
1.5
6.4
1.5
7.1
ns
1.4
5.7
1.4
6.3
ns
CL = 15 pF
propagation delay
tpd
[1]
CL = 30 pF
propagation delay
tpd
[1]
[1]
4.1
22.6
4.1
24.9
ns
2.9
14.0
2.9
15.4
ns
2.3
11.1
2.3
12.3
ns
2.1
8.5
2.1
9.4
ns
2.1
7.6
2.1
8.4
ns
12. Waveforms
VI
VM
A, B input
GND
t PHL
t PLH
VOH
VM
Y output
mna612
VOL
Measurement points are given in Table 10.
Logic levels: VOL and VOH are typical output voltage drop that occur with the output load.
Fig 8. The data input (A or B) to output (Y) propagation delays
Table 10.
Measurement points
Supply voltage
Output
Input
VCC
VM
VM
VI
tr = tf
0.8 V to 3.6 V
0.5 × VCC
0.5 × VCC
VCC
≤ 3.0 ns
74AUP1G00
Product data sheet
10 of 21
74AUP1G00
NXP Semiconductors
VCC
VEXT
5 kΩ
G
VI
VO
DUT
CL
RT
RL
001aac521
Test data is given in Table 11.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to the output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Fig 9. Test circuit for measuring switching times
Table 11.
Test data
Supply voltage
Load
VEXT
[1]
VCC
CL
RL
0.8 V to 3.6 V
5 pF, 10 pF, 15 pF and 30 pF
5 kΩ or 1 MΩ
[1]
tPLH, tPHL
tPZH, tPHZ
tPZL, tPLZ
open
GND
2 × VCC
For measuring enable and disable times RL = 5 kΩ, for measuring propagation delays, setup and hold times and pulse width RL = 1 MΩ.
74AUP1G00
Product data sheet
11 of 21
74AUP1G00
NXP Semiconductors
13. Package outline
TSSOP5: plastic thin shrink small outline package; 5 leads; body width 1.25 mm
E
D
SOT353-1
A
X
c
y
HE
v M A
Z
5
4
A2
A
(A3)
A1
θ
1
Lp
3
L
e
w M
bp
detail X
e1
3 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D(1)
E(1)
e
e1
HE
L
Lp
v
w
y
Z(1)
θ
mm
1.1
0.1
0.8
0.15
0.30
0.15
0.25
0.08
2.25
1.85
1.35
1.15
0.65
1.3
2.25
2.0
0.425
0.46
0.21
0.3
0.1
0.1
0.60
0.15
7°
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
OUTLINE
VERSION
SOT353-1
REFERENCES
IEC
JEDEC
JEITA
MO-203
SC-88A
EUROPEAN
PROJECTION
ISSUE DATE
00-09-01
03-02-19
Fig 10. Package outline SOT353-1 (TSSOP5)
74AUP1G00
Product data sheet
12 of 21
74AUP1G00
NXP Semiconductors
SOT886
XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1.45 x 0.5 mm
b
1
2
3
4x
(2)
L
L1
e
6
5
e1
4
e1
6x
A
(2)
A1
D
E
terminal 1
index area
2 mm
scale
Dimensions (mm are the original dimensions)
Unit
mm
max
nom
min
A(1)
0.5
A1
b
D
E
0.04 0.25 1.50 1.05
0.20 1.45 1.00
0.17 1.40 0.95
e
e1
0.6
0.5
L
L1
0.35 0.40
0.30 0.35
0.27 0.32
Notes
1. Including plating thickness.
2. Can be visible in some manufacturing processes.
Outline
version
SOT886
sot886_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
04-07-22
12-01-05
MO-252
Fig 11. Package outline SOT886 (XSON6)
74AUP1G00
Product data sheet
13 of 21
74AUP1G00
NXP Semiconductors
XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1 x 0.5 mm
1
SOT891
b
3
2
4×
(1)
L
L1
e
6
5
e1
4
e1
6×
A
(1)
A1
D
E
terminal 1
index area
2 mm
scale
UNIT
A
max
A1
max
b
D
E
e
e1
L
L1
mm
0.5
0.04
0.20
0.12
1.05
0.95
1.05
0.95
0.55
0.35
0.35
0.27
0.40
0.32
Note
1. Can be visible in some manufacturing processes.
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
05-04-06
07-05-15
SOT891
Fig 12. Package outline SOT891 (XSON6)
74AUP1G00
Product data sheet
14 of 21
74AUP1G00
NXP Semiconductors
XSON6: extremely thin small outline package; no leads;
6 terminals; body 0.9 x 1.0 x 0.35 mm
1
SOT1115
b
3
2
(4×)(2)
L
L1
e
6
5
4
e1
e1
(6×)(2)
A1
A
D
E
terminal 1
index area
scale
Dimensions
Unit
mm
1 mm
A(1)
A1
b
D
E
e
e1
max 0.35 0.04 0.20 0.95 1.05
nom
0.15 0.90 1.00 0.55
min
0.12 0.85 0.95
0.3
L
L1
0.35 0.40
0.30 0.35
0.27 0.32
Note
2. Visible depending upon used manufacturing technology.
Outline
version
sot1115_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
10-04-02
10-04-07
SOT1115
Fig 13. Package outline SOT1115 (XSON6)
74AUP1G00
Product data sheet
15 of 21
74AUP1G00
NXP Semiconductors
6 terminals; body 1.0 x 1.0 x 0.35 mm
1
SOT1202
b
3
2
(4×)(2)
L
L1
e
6
5
4
e1
e1
(6×)(2)
A1
A
D
E
terminal 1
index area
scale
Dimensions
Unit
mm
1 mm
A(1)
A1
b
D
E
e
e1
L
L1
max 0.35 0.04 0.20 1.05 1.05
0.35 0.40
nom
0.15 1.00 1.00 0.55 0.35 0.30 0.35
min
0.12 0.95 0.95
0.27 0.32
Note
Outline
version
sot1202_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
10-04-02
10-04-06
SOT1202
Fig 14. Package outline SOT1202 (XSON6)
74AUP1G00
Product data sheet
16 of 21
74AUP1G00
NXP Semiconductors
X2SON5: plastic thermal enhanced extremely thin small outline package; no leads;
5 terminals; body 0.8 x 0.8 x 0.35 mm
B
A
D
SOT1226
X
A
E
A1
A3
detail X
terminal 1
index area
e
C
v
w
b
1
2
terminal 1
index area
C A B
C
y1 C
y
k
D
h
3
L
5
4
1 mm
scale
Dimensions
Unit
mm
A(1)
A1
A3
D
Dh
E
b
e
k
L
max 0.35 0.04 0.128 0.85 0.30 0.85 0.27
0.27
nom
0.80 0.25 0.80 0.22 0.48
0.22
min
0.20 0.17
0.040 0.75 0.20 0.75 0.17
v
0.1
w
y
y1
0.05 0.05 0.05
Note
1. Dimension A is including plating thickness.
2. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
Outline
version
References
IEC
JEDEC
EIAJ
sot1226_po
European
projection
Issue date
12-04-10
12-04-25
SOT1226
Fig 15. Package outline SOT1226 (X2SON5)
74AUP1G00
Product data sheet
17 of 21
74AUP1G00
NXP Semiconductors
14. Abbreviations
Table 12:
Abbreviations
Acronym
Description
CDM
Charged Device Model
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
15. Revision history
Table 13.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74AUP1G00 v.6
20120627
Product data sheet
74AUP1G00 v.5
Modifications:
74AUP1G00 v.5
Modifications:
74AUP1G00 v.4
Modifications:
Added type number 74AUP1G00GX (SOT1226).
20120316
74AUP1G00 v.4
Package outline drawing of SOT886 (Figure 11) modified.
20111115
Product data sheet
Product data sheet
74AUP1G00 v.3
Legal pages updated.
74AUP1G00 v.3
20101007
Product data sheet
74AUP1G00 v.2
74AUP1G00 v.2
20060629
Product data sheet
74AUP1G00 v.1
74AUP1G00 v.1
20050711
Product data sheet
74AUP1G00
Product data sheet
18 of 21
74AUP1G00
NXP Semiconductors
16. Legal information
16.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nxp.com.
16.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. NXP Semiconductors does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local NXP Semiconductors sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
NXP Semiconductors and its customer, unless NXP Semiconductors and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the NXP Semiconductors product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
16.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, NXP Semiconductors does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. NXP Semiconductors takes no
responsibility for the content in this document if provided by an information
source outside of NXP Semiconductors.
In no event shall NXP Semiconductors be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, NXP Semiconductors’ aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of NXP Semiconductors.
Right to make changes — NXP Semiconductors reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
74AUP1G00
Product data sheet
Suitability for use — NXP Semiconductors products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of an NXP Semiconductors product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. NXP Semiconductors and its suppliers accept no liability for
inclusion and/or use of NXP Semiconductors products in such equipment or
applications and therefore such inclusion and/or use is at the customer’s own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. NXP Semiconductors makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using NXP Semiconductors products, and NXP Semiconductors
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the NXP
Semiconductors product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
NXP Semiconductors does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using NXP
Semiconductors products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). NXP does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — NXP Semiconductors
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nxp.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. NXP Semiconductors hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of NXP Semiconductors products by customer.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
19 of 21
74AUP1G00
NXP Semiconductors
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific NXP Semiconductors product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor tested
in accordance with automotive testing or application requirements. NXP
Semiconductors accepts no liability for inclusion and/or use of
non-automotive qualified products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards, customer
(a) shall use the product without NXP Semiconductors’ warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
NXP Semiconductors’ specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies NXP Semiconductors for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond NXP Semiconductors’
standard warranty and NXP Semiconductors’ product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
16.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
17. Contact information
For more information, please visit: http://www.nxp.com
For sales office addresses, please send an email to: salesaddresses@nxp.com
74AUP1G00
Product data sheet
20 of 21
74AUP1G00
NXP Semiconductors
18. Contents
1
2
3
4
5
6
6.1
6.2
7
8
9
10
11
12
13
14
15
16
16.1
16.2
16.3
16.4
17
18
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 3
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3
Functional description . . . . . . . . . . . . . . . . . . . 4
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4
Recommended operating conditions. . . . . . . . 4
Static characteristics. . . . . . . . . . . . . . . . . . . . . 5
Dynamic characteristics . . . . . . . . . . . . . . . . . . 8
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 12
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 18
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 18
Legal information. . . . . . . . . . . . . . . . . . . . . . . 19
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 19
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 19
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 20
Contact information. . . . . . . . . . . . . . . . . . . . . 20
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 21
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section ‘Legal information’.
© NXP B.V. 2012.
Date of release: 27 June 2012
Document identifier: 74AUP1G00
