HS1JLW RVG
HS1JLW RVG
    TAIWANSEMICONDUCTOR(台湾半导体)
    SOD-123W(CFP3)
    HS1JLW RVG
HS1JLW RVG 数据手册
HS1DLW – HS1MLW Taiwan Semiconductor 1A, 200V - 1000V High Efficient Surface Mount Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS Glass passivated chip junction Ideal for automated placement Low profile package Low power loss, high efficiency Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS PARAMETER VALUE UNIT IF 1 A VRRM 200 - 1000 V IFSM 30 A TJ MAX 175 °C Package SOD-123W Configuration Single die ● DC to DC converter ● Switching mode converters and inverters ● Freewheeling application MECHANICAL DATA ● ● ● ● ● ● Case: SOD-123W Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.016g (approximately) SOD-123W ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device HS1DLW HS1GLW HS1JLW HS1KLW HS1MLW UNIT HDLW HGLW HJLW HKLW HMLW Repetitive peak reverse voltage VRRM 200 400 600 800 1000 V Reverse voltage, total rms value VR(RMS) 140 280 420 560 700 V Forward current Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load Junction temperature IF 1 A IFSM 30 A TJ - 55 to +175 °C Storage temperature TSTG - 55 to +175 °C 1 Version: C2103 HS1DLW – HS1MLW Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-lead thermal resistance RӨJL 25 °C/W Junction-to-ambient thermal resistance RӨJA 80 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL HS1DLW Forward voltage (1) Reverse current @ rated VR (2) HS1GLW I = 1A, TJ = 25°C HS1JLW F HS1KLW HS1MLW TJ = 25°C TJ = 125°C VF IR TYP MAX UNIT - 1.0 V - 1.3 V - 1.7 V - 1 µA - 150 µA 16 - pF 7 - pF - 50 ns - 75 ns HS1DLW HS1GLW Junction capacitance HS1JLW 1MHz, VR = 4.0V CJ HS1KLW Reverse recovery time HS1MLW HS1DLW HS1GLW I = 0.5A, IR = 1.0A, HS1JLW F I = 0.25A HS1KLW rr HS1MLW trr Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING HS1xLW SOD-123W 10,000 / Tape & Reel Notes: 1. “x” defines voltage from 200V(HS1DLW) to 1000V(HS1MLW) 2 Version: C2103 HS1DLW – HS1MLW Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 100 HS1DLW - HS1JLW CAPACITANCE (pF) 1 0 10 HS1KLW - HS1MLW 1 f=1.0MHz Vsig=50mVp-p 0.1 25 55 85 115 145 175 0.1 1 LEAD TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=125°C 1 TJ=25°C 0.01 10 20 30 40 50 60 70 80 90 100 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 10 10 HS1MLW UF1DLW 1 TJ=125°C TJ=125°C 1 0.1 TJ=25°C TJ=25°C 0.01 Pulse width 300μs 1% duty cycle Pulse width 0.1 0.001 0.6 0.8 1.0 1.2 1.4 1.6 1.8 0.3 0.4 0.5 0.6 0.7 0.8 FORWARD VOLTAGE (V) 2.0 0.9 2.2 1 1.1 Fig.5 Maximum Non-Repetitive Forward Surge Current 40 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (uA) Fig.4 Typical Forward Characteristics 100 0.1 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 10 10 (A) AVERAGE FORWARD CURRENT (A) 2 8.3ms single half sine wave 30 20 10 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: C2103 1.2 HS1DLW – HS1MLW Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS SOD-123W SUGGESTED PAD LAYOUT MARKING DIAGRAM 4 P/N = Marking Code YW = Date Code F = Factory Code Version: C2103 HS1DLW – HS1MLW Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: C2103
HS1JLW RVG 价格&库存
很抱歉,暂时无法提供与“HS1JLW RVG”相匹配的价格&库存,您可以联系我们找货
