74LVCH8T245BQ118
74LVCH8T245BQ118
    NEXPERIA(安世)
    VFQFN-24
    IC TRANSLATR TXRX 5.5V 24DHVQFN
74LVCH8T245BQ118 数据手册
74LVC8T245; 74LVCH8T245 8-bit dual supply translating transceiver; 3-state Rev. 5 — 29 April 2021 Product data sheet 1. General description The 74LVC8T245; 74LVCH8T245 are 8-bit dual supply translating transceivers with 3-state outputs that enable bidirectional level translation. They feature two data input-output ports (pins An and Bn), a direction control input (DIR), an output enable input (OE) and dual supply pins (VCC(A) and VCC(B)). Both VCC(A) and VCC(B) can be supplied at any voltage between 1.2 V and 5.5 V making the device suitable for translating between any of the low voltage nodes (1.2 V, 1.5 V, 1.8 V, 2.5 V, 3.3 V and 5.0 V). Pins An, OE and DIR are referenced to VCC(A) and pins Bn are referenced to VCC(B). A HIGH on DIR allows transmission from An to Bn and a LOW on DIR allows transmission from Bn to An. The output enable input (OE) can be used to disable the outputs so the buses are effectively isolated. The devices are fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing any damaging backflow current through the device when it is powered down. In suspend mode when either VCC(A) or VCC(B) are at GND level, both A port and B port are in the high-impedance OFF-state. Active bus hold circuitry in the 74LVCH8T245 holds unused or floating data inputs at a valid logic level. 2. Features and benefits • • • • • • • • • • • • Wide supply voltage range: • VCC(A): 1.2 V to 5.5 V • VCC(B): 1.2 V to 5.5 V High noise immunity Complies with JEDEC standards: • JESD8-7 (1.2 V to 1.95 V) • JESD8-5 (1.8 V to 2.7 V) • JESD8C (2.7 V to 3.6 V) • JESD36 (4.5 V to 5.5 V) ESD protection: • HBM JESD22-A114F Class 3A exceeds 4000 V • MM JESD22-A115-B exceeds 200 V • CDM JESD22-C101E exceeds 1000 V Maximum data rates: • 420 Mbps (3.3 V to 5.0 V translation) • 210 Mbps (translate to 3.3 V) • 140 Mbps (translate to 2.5 V) • 75 Mbps (translate to 1.8 V) • 60 Mbps (translate to 1.5 V) Suspend mode Latch-up performance exceeds 100 mA per JESD 78B Class II ±24 mA output drive (VCC = 3.0 V) Inputs accept voltages up to 5.5 V Low power consumption: 30 μA maximum ICC IOFF circuitry provides partial Power-down mode operation Specified from -40 °C to +85 °C and -40 °C to +125 °C 74LVC8T245; 74LVCH8T245 Nexperia 8-bit dual supply translating transceiver; 3-state 3. Ordering information Table 1. Ordering information Type number Package 74LVC8T245PW Temperature range Name Description Version -40 °C to +125 °C TSSOP24 plastic thin shrink small outline package; 24 leads; body width 4.4 mm SOT355-1 -40 °C to +125 °C DHVQFN24 plastic dual in-line compatible thermal enhanced SOT815-1 very thin quad flat package; no leads; 24 terminals; body 3.5 × 5.5 × 0.85 mm -40 °C to +125 °C DHXQFN24 plastic, leadless dual in-line compatible thermal enhanced extreme thin quad flat package; no leads; 24 terminals; 0.4 mm pitch; body 2 mm × 4 mm × 0.48 mm 74LVCH8T245PW 74LVC8T245BQ 74LVCH8T245BQ 74LVC8T245BZ SOT8024-1 4. Functional diagram B1 B2 21 VCC(A) OE DIR Fig. 1. B3 20 B4 19 B5 18 B6 17 B7 16 B8 15 14 VCC(B) 22 2 3 4 5 6 7 8 9 A1 A2 A3 A4 A5 A6 A7 10 A8 001aai472 Logic symbol DIR OE A1 B1 VCC(A) VCC(B) to other seven channels Fig. 2. 001aai473 Logic diagram (one channel) 74LVC_LVCH8T245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 29 April 2021 © Nexperia B.V. 2021. All rights reserved 2 / 28 74LVC8T245; 74LVCH8T245 Nexperia 8-bit dual supply translating transceiver; 3-state 5. Pinning information 5.1. Pinning 1 terminal 1 index area 24 VCC(B) VCC(A) 74LVC8T245 74LVCH8T245 74LVC8T245 74LVCH8T245 VCC(A) 1 DIR 2 24 VCC(B) 23 VCC(B) A1 3 22 OE A2 4 21 B1 A3 5 20 B2 A4 6 19 B3 A5 7 18 B4 A6 8 17 B5 A7 9 16 B6 A8 10 15 B7 GND 11 14 B8 GND 12 13 GND 2 23 VCC(B) A1 3 22 OE A2 4 21 B1 A3 5 20 B2 A4 6 19 B3 A5 7 18 B4 A6 8 17 B5 A7 9 16 B6 A8 10 15 B7 GND(1) GND 13 14 B8 GND 12 GND 11 001aak437 Transparent top view (1) This is not a ground pin. There is no electrical or mechanical requirement to solder the pad. In case soldered, the solder land should remain floating or connected to GND. 001aak436 Fig. 3. DIR Pin configuration SOT355-1 (TSSOP24) Fig. 4. Pin configuration SOT815-1 (DHVQFN24) terminal 1 index area 24 VCC(B) VCC(A) 74LVC8T245 2 A1 3 22 OE A2 4 21 B1 A3 5 20 B2 A4 6 19 B3 A5 7 18 B4 A6 8 17 B5 A7 9 12 13 GND GND 11 23 VCC(B) 16 B6 GND(1) GND A8 10 1 DIR 15 B7 14 B8 aaa-032843 Transparent top view (1) This is not a ground pin. There is no electrical or mechanical requirement to solder the pad. In case soldered, the solder land should remain floating or connected to GND. Fig. 5. Pin configuration SOT8024-1 (DHXQFN24) 74LVC_LVCH8T245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 29 April 2021 © Nexperia B.V. 2021. All rights reserved 3 / 28 74LVC8T245; 74LVCH8T245 Nexperia 8-bit dual supply translating transceiver; 3-state 5.2. Pin description Table 2. Pin description Symbol Pin Description VCC(A) 1 supply voltage A (An inputs/outputs, OE and DIR inputs are referenced to VCC(A)) DIR 2 direction control A1, A2, A3, A4, A5, A6, A7, A8 3, 4, 5, 6, 7, 8, 9, 10 data input or output GND [1] 11, 12, 13 ground (0 V) B1, B2, B3, B4, B5, B6, B7, B8 21, 20, 19, 18, 17, 16, 15, 14 data input or output OE 22 output enable input (active LOW) VCC(B) 23, 24 supply voltage B (Bn inputs/outputs are referenced to VCC(B)) [1] All GND pins must be connected to ground (0 V). 6. Functional description Table 3. Function table H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state. Supply voltage Input VCC(A), VCC(B) OE [2] DIR [2] An [2] Bn [2] 1.2 V to 5.5 V L L An = Bn input 1.2 V to 5.5 V L H input Bn = An 1.2 V to 5.5 V H X Z Z GND [1] X X Z Z [1] [2] Input/output [1] If at least one of VCC(A) or VCC(B) is at GND level, the device goes into suspend mode. The An inputs/outputs, DIR and OE input circuit is referenced to VCC(A); The Bn inputs/outputs circuit is referenced to VCC(B). 74LVC_LVCH8T245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 29 April 2021 © Nexperia B.V. 2021. All rights reserved 4 / 28 74LVC8T245; 74LVCH8T245 Nexperia 8-bit dual supply translating transceiver; 3-state 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit VCC(A) supply voltage A -0.5 +6.5 V VCC(B) supply voltage B -0.5 +6.5 V IIK input clamping current VI input voltage IOK output clamping current VO < 0 V VO output voltage Active mode VI < 0 V [1] +6.5 -50 - [1] [2] [3] -0.5 Suspend or 3-state mode [1] -0.5 [2] IO output current VO = 0 V to VCCO ICC supply current ICC(A) or ICC(B); per VCC pin IGND ground current per GND pin Tstg storage temperature Ptot total power dissipation mA V mA VCCO + 0.5 V +6.5 V - ±50 mA - 100 mA -100 - mA -65 +150 °C - 500 mW - 250 mW Tamb = -40 °C to +125 °C SOT355-1; SOT815-1 [4] SOT8024-1 [1] [2] [3] [4] -50 -0.5 The minimum input voltage ratings and output voltage ratings may be exceeded if the input and output current ratings are observed. VCCO is the supply voltage associated with the output port. VCCO + 0.5 V should not exceed 6.5 V. For SOT355-1 (TSSOP24) package: Ptot derates linearly with 12.4 mW/K above 110 °C. For SOT815-1 (DHVQFN24) package: Ptot derates linearly with 15.0 mW/K above 117 °C. 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Conditions Min Max Unit VCC(A) supply voltage A 1.2 5.5 V VCC(B) supply voltage B 1.2 5.5 V VI input voltage 0 5.5 V VO output voltage 0 VCCO V 0 5.5 V -40 +125 °C - 20 ns/V VCCI = 1.4 V to 1.95 V - 20 ns/V VCCI = 2.3 V to 2.7 V - 20 ns/V VCCI = 3 V to 3.6 V - 10 ns/V VCCI = 4.5 V to 5.5 V - 5 ns/V Active mode [1] Suspend or 3-state mode Tamb ambient temperature Δt/ΔV input transition rise and fall rate [1] [2] VCCI = 1.2 V [2] VCCO is the supply voltage associated with the output port. VCCI is the supply voltage associated with the input port. 74LVC_LVCH8T245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 29 April 2021 © Nexperia B.V. 2021. All rights reserved 5 / 28 74LVC8T245; 74LVCH8T245 Nexperia 8-bit dual supply translating transceiver; 3-state 9. Static characteristics Table 6. Typical static characteristics at Tamb = 25 °C At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter VOH Conditions HIGH-level output VI = VIH or VIL voltage IO = -3 mA; VCCO = 1.2 V Min Typ Max Unit - 1.09 - V [1] LOW-level output voltage VI = VIH or VIL IO = 3 mA; VCCO = 1.2 V [1] - 0.07 - V II input leakage current DIR, OE input; VI = 0 V to 5.5 V; VCCI = 1.2 V to 5.5 V [2] - - ±1 μA IBHL bus hold LOW current A or B port; VI = 0.42 V; VCCI = 1.2 V [2] - 19 - μA IBHH bus hold HIGH current A or B port; VI = 0.78 V; VCCI = 1.2 V [2] - -19 - μA IBHLO bus hold LOW overdrive current A or B port; VCCI = 1.2 V [2] [3] - 19 - μA IBHHO bus hold HIGH overdrive current A or B port; VCCI = 1.2 V [2] [3] - -19 - μA IOZ OFF-state output current A or B port; VO = 0 V or VCCO; VCCO = 1.2 V to 5.5 V [1] - - ±1 μA suspend mode A port; VO = 0 V or VCCO; VCC(A) = 5.5 V; VCC(B) = 0 V [1] - - ±1 μA suspend mode B port; VO = 0 V or VCCO; VCC(A) = 0 V; VCC(B) = 5.5 V [1] - - ±1 μA power-off leakage A port; VI or VO = 0 V to 5.5 V; VCC(A) = 0 V; VCC(B) = 1.2 V to 5.5 V current - - ±1 μA B port; VI or VO = 0 V to 5.5 V; VCC(B) = 0 V; VCC(A) = 1.2 V to 5.5 V - - ±1 μA VOL IOFF CI input capacitance DIR, OE input; VI = 0 V or 3.3 V; VCC(A) = 3.3 V - 3 - pF CI/O input/output capacitance A and B port; VO = 3.3 V or 0 V; VCC(A) = VCC(B) = 3.3 V - 6.5 - pF [1] [2] [3] VCCO is the supply voltage associated with the output port. VCCI is the supply voltage associated with the data input port. To guarantee the node switches, an external driver must source/sink at least IBHLO / IBHHO when the input is in the range VIL to VIH. 74LVC_LVCH8T245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 29 April 2021 © Nexperia B.V. 2021. All rights reserved 6 / 28 74LVC8T245; 74LVCH8T245 Nexperia 8-bit dual supply translating transceiver; 3-state Table 7. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions VIH data input HIGH-level input voltage -40 °C to +85 °C -40 °C to +125 °C Unit Min Max Min Max VCCI = 1.2 V 0.8VCCI - 0.8VCCI - V VCCI = 1.4 V to 1.95 V 0.65VCCI - 0.65VCCI - V VCCI = 2.3 V to 2.7 V 1.7 - 1.7 - V VCCI = 3.0 V to 3.6 V 2.0 - 2.0 - V VCCI = 4.5 V to 5.5 V 0.7VCCI - 0.7VCCI - V VCCI = 1.2 V 0.8VCC(A) - 0.8VCC(A) - V VCCI = 1.4 V to 1.95 V 0.65VCC(A) - 0.65VCC(A) - V VCCI = 2.3 V to 2.7 V 1.7 - 1.7 - V VCCI = 3.0 V to 3.6 V 2.0 - 2.0 - V VCCI = 4.5 V to 5.5 V 0.7VCC(A) - 0.7VCC(A) - V VCCI = 1.2 V - 0.2VCCI - 0.2VCCI V VCCI = 1.4 V to 1.95 V - 0.35VCCI - 0.35VCCI V VCCI = 2.3 V to 2.7 V - 0.7 - 0.7 V VCCI = 3.0 V to 3.6 V - 0.8 - 0.8 V VCCI = 4.5 V to 5.5 V - 0.3VCCI - 0.3VCCI V [1] DIR, OE input VIL LOW-level input voltage data input [1] DIR, OE input VOH VOL II HIGH-level output voltage LOW-level output voltage input leakage current 74LVC_LVCH8T245 Product data sheet VCCI = 1.2 V - 0.2VCC(A) - 0.2VCC(A) V VCCI = 1.4 V to 1.95 V - 0.35VCC(A) - 0.35VCC(A) V VCCI = 2.3 V to 2.7 V - 0.7 - 0.7 V VCCI = 3.0 V to 3.6 V - 0.8 - 0.8 V VCCI = 4.5 V to 5.5 V - 0.3VCC(A) - - VCCO - 0.1 - V 0.3VCC(A) V VI = VIH IO = -100 μA; VCCO = 1.2 V to 4.5 V [2] VCCO - 0.1 IO = -6 mA; VCCO = 1.4 V 1.0 - 1.0 - V IO = -8 mA; VCCO = 1.65 V 1.2 - 1.2 - V IO = -12 mA; VCCO = 2.3 V 1.9 - 1.9 - V IO = -24 mA; VCCO = 3.0 V 2.4 - 2.4 - V IO = -32 mA; VCCO = 4.5 V 3.8 - 3.8 - V IO = 100 μA; VCCO = 1.2 V to 4.5 V - 0.1 - 0.1 V IO = 6 mA; VCCO = 1.4 V - 0.3 - 0.3 V IO = 8 mA; VCCO = 1.65 V - 0.45 - 0.45 V IO = 12 mA; VCCO = 2.3 V - 0.3 - 0.3 V IO = 24 mA; VCCO = 3.0 V - 0.55 - 0.55 V IO = 32 mA; VCCO = 4.5 V - 0.55 - 0.55 V DIR, OE input; VI = 0 V to 5.5 V; VCCI = 1.2 V to 5.5 V - ±2 - ±10 μA VI = VIL [2] All information provided in this document is subject to legal disclaimers. Rev. 5 — 29 April 2021 © Nexperia B.V. 2021. All rights reserved 7 / 28 74LVC8T245; 74LVCH8T245 Nexperia 8-bit dual supply translating transceiver; 3-state Symbol Parameter IBHL IBHH bus hold LOW current Conditions -40 °C to +85 °C Max Min Max VI = 0.49 V; VCCI = 1.4 V 15 - 10 - μA VI = 0.58 V; VCCI = 1.65 V 25 - 20 - μA VI = 0.70 V; VCCI = 2.3 V 45 - 45 - μA VI = 0.80 V; VCCI = 3.0 V 100 - 80 - μA VI = 1.35 V; VCCI = 4.5 V 100 - 100 - μA -15 - -10 - μA VI = 1.07 V; VCCI = 1.65 V -25 - -20 - μA VI = 1.70 V; VCCI = 2.3 V -45 - -45 - μA VI = 2.00 V; VCCI = 3.0 V -100 - -80 - μA -100 - -100 - μA VCCI = 1.6 V 125 - 125 - μA VCCI = 1.95 V 200 - 200 - μA VCCI = 2.7 V 300 - 300 - μA VCCI = 3.6 V 500 - 500 - μA VCCI = 5.5 V 900 - 900 - μA -125 - -125 - μA -200 - -200 - μA VCCI = 2.7 V -300 - -300 - μA VCCI = 3.6 V -500 - -500 - μA VCCI = 5.5 V -900 - -900 - μA A or B port [1] bus hold HIGH A or B port current VI = 0.91 V; VCCI = 1.4 V IBHHO IOZ IOFF bus hold LOW overdrive current Unit Min [1] VI = 3.15 V; VCCI = 4.5 V IBHLO -40 °C to +125 °C A or B port [1] [3] bus hold HIGH A or B port overdrive VCCI = 1.6 V current VCCI = 1.95 V [1] [3] A or B port; VO = 0 V or VCCO; VCCO = 1.2 V to 5.5 V [2] - ±2 - ±10 μA suspend mode A port; VO = 0 V or VCCO; VCC(A) = 5.5 V; VCC(B) = 0 V [2] - ±2 - ±10 μA suspend mode B port; VO = 0 V or VCCO; VCC(A) = 0 V; VCC(B) = 5.5 V [2] - ±2 - ±10 μA A port; VI or VO = 0 V to 5.5 V; power-off leakage current VCC(A) = 0 V; VCC(B) = 1.2 V to 5.5 V - ±2 - ±10 μA B port; VI or VO = 0 V to 5.5 V; VCC(B) = 0 V; VCC(A) = 1.2 V to 5.5 V - ±2 - ±10 μA OFF-state output current 74LVC_LVCH8T245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 29 April 2021 © Nexperia B.V. 2021. All rights reserved 8 / 28 74LVC8T245; 74LVCH8T245 Nexperia 8-bit dual supply translating transceiver; 3-state Symbol Parameter ICC supply current Conditions -40 °C to +85 °C -40 °C to +125 °C Unit Min Max Min Max VCC(A), VCC(B) = 1.2 V to 5.5 V - 15 - 20 μA VCC(A) = 5.5 V; VCC(B) = 0 V - 15 - 20 μA VCC(A) = 0 V; VCC(B) = 5.5 V -2 - -4 - μA VCC(A), VCC(B) = 1.2 V to 5.5 V - 15 - 20 μA VCC(B) = 0 V; VCC(A) = 5.5 V -2 - -4 - μA VCC(B) = 5.5 V; VCC(A) = 0 V - 15 - 20 μA - 25 - 30 μA - 50 - 75 μA A port; VI = 0 V or VCCI; IO = 0 A [1] B port; VI = 0 V or VCCI; IO = 0 A A plus B port (ICC(A) + ICC(B)); IO = 0 A; VI = 0 V or VCCI VCC(A), VCC(B) = 1.2 V to 5.5 V ΔICC additional supply current per input; VCC(A), VCC(B) = 3.0 V to 5.5 V DIR and OE input; DIR or OE input at VCC(A) - 0.6 V; A port at VCC(A) or GND; B port = open [1] [2] [3] [4] A port; A port at VCC(A) - 0.6 V; DIR at VCC(A); B port = open [4] - 50 - 75 μA B port; B port at VCC(B) - 0.6 V; DIR at GND; A port = open [4] - 50 - 75 μA VCCI is the supply voltage associated with the data input port. VCCO is the supply voltage associated with the output port. To guarantee the node switches, an external driver must source/sink at least IBHLO / IBHHO when the input is in the range VIL to VIH. For non bus hold parts only (74LVC8T245). 10. Dynamic characteristics Table 8. Typical dynamic characteristics at VCC(A) = 1.2 V and Tamb = 25 °C Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 8; for wave forms see Fig. 6 and Fig. 7. [1] Symbol Parameter tpd tdis ten [1] propagation delay disable time enable time Conditions VCC(B) Unit 1.2 V 1.5 V 1.8 V 2.5 V 3.3 V 5.0 V An to Bn 11.0 8.5 7.4 6.2 5.7 5.4 ns Bn to An 11.0 10.0 9.5 9.1 8.9 8.9 ns OE to An 9.5 9.5 9.5 9.5 9.5 9.5 ns OE to Bn 10.2 8.2 7.8 6.7 7.3 6.4 ns OE to An 13.5 13.5 13.5 13.5 13.5 13.5 ns OE to Bn 13.6 10.3 8.9 7.5 7.1 7.0 ns tpd is the same as tPLH and tPHL; tdis is the same as tPLZ and tPHZ; ten is the same as tPZL and tPZH. 74LVC_LVCH8T245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 29 April 2021 © Nexperia B.V. 2021. All rights reserved 9 / 28 74LVC8T245; 74LVCH8T245 Nexperia 8-bit dual supply translating transceiver; 3-state Table 9. Typical dynamic characteristics at VCC(B) = 1.2 V and Tamb = 25 °C Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 8; for wave forms see Fig. 6 and Fig. 7. [1] Symbol Parameter Conditions 1.2 V 1.5 V 1.8 V 2.5 V 3.3 V 5.0 V tpd An to Bn 11.0 10.0 9.5 9.1 8.9 8.8 ns Bn to An 11.0 8.5 7.3 6.2 5.7 5.4 ns OE to An 9.5 6.8 5.4 3.8 4.1 3.1 ns OE to Bn 10.2 9.1 8.6 8.1 7.8 7.8 ns OE to An 13.5 9.0 6.9 4.8 3.8 3.2 ns OE to Bn 13.6 12.5 12.0 11.5 11.4 11.4 ns tdis ten [1] propagation delay disable time enable time VCC(A) Unit tpd is the same as tPLH and tPHL; tdis is the same as tPLZ and tPHZ; ten is the same as tPZL and tPZH. Table 10. Typical power dissipation capacitance at VCC(A) = VCC(B) and Tamb = 25 °C Voltages are referenced to GND (ground = 0 V). [1] [2] Symbol Parameter CPD [1] [2] power dissipation capacitance Conditions VCC(A) and VCC(B) Unit 1.8 V 2.5 V 3.3 V 5.0 V A port: (direction A to B); B port: (direction B to A) 1 1 1 2 pF A port: (direction B to A); B port: (direction A to B) 13 13 13 13 pF CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 Σ(CL × VCC × fo) = sum of the outputs. fi = 10 MHz; VI = GND to VCC; tr = tf = 1 ns; CL = 0 pF; RL = ∞ Ω. 74LVC_LVCH8T245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 29 April 2021 © Nexperia B.V. 2021. All rights reserved 10 / 28 74LVC8T245; 74LVCH8T245 Nexperia 8-bit dual supply translating transceiver; 3-state Table 11. Dynamic characteristics for temperature range -40 °C to +85 °C Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 8; for waveforms see Fig. 6 and Fig. 7. [1] Symbol Parameter Conditions VCC(B) Unit 1.5 V ± 0.1 V 1.8 V ± 0.15 V 2.5 V ± 0.2 V 3.3 V ± 0.3 V 5.0 V ± 0.5 V Min Max Min Max Min Max Min Max Min Max VCC(A) = 1.5 V ± 0.1 V propagation delay An to Bn 1.7 27 1.7 23 1.3 18 1.0 15 0.8 13 ns Bn to An 0.9 27 0.9 25 0.8 23 0.7 23 0.7 22 ns disable time OE to An 1.5 30 1.5 30 1.5 30 1.5 30 1.4 30 ns OE to Bn 2.4 34 2.4 33 1.9 15 1.7 14 1.3 12 ns OE to An 0.4 34 0.4 34 0.4 34 0.4 34 0.4 34 ns OE to Bn 1.8 36 1.8 34 1.5 18 1.2 15 0.9 13 ns propagation delay An to Bn 1.7 25 1.7 21.9 1.3 9.2 1.0 7.4 0.8 7.1 ns Bn to An 0.9 23 0.9 23.8 0.8 23.6 0.7 23.4 0.7 23.4 ns disable time OE to An 1.5 30 1.5 29.6 1.5 29.4 1.5 29.3 1.4 29.2 ns OE to Bn 2.4 33 2.4 32.2 1.9 13.1 1.7 12.0 1.3 10.3 ns OE to An 0.4 24 0.4 24.0 0.4 23.8 0.4 23.7 0.4 23.7 ns OE to Bn 1.8 34 1.8 32.0 1.5 16.0 1.2 12.6 0.9 10.8 ns propagation delay An to Bn 1.5 23 1.5 21.4 1.2 9.0 0.8 6.2 0.6 4.8 ns Bn to An 1.2 18 1.2 9.3 1.0 9.1 1.0 8.9 0.9 8.8 ns tdis disable time OE to An 1.4 9.0 1.4 9.0 1.4 9.0 1.4 9.0 1.4 9.0 ns OE to Bn 2.3 31 2.3 29.6 1.8 11.0 1.7 9.3 0.9 6.9 ns ten enable time OE to An 1.0 10.9 1.0 10.9 1.0 10.9 1.0 10.9 1.0 10.9 ns OE to Bn 1.7 32 1.7 28.2 1.5 12.9 1.2 9.4 1.0 6.9 ns 23 1.5 21.2 1.1 8.8 0.8 6.3 0.5 4.4 ns tpd tdis ten enable time VCC(A) = 1.8 V ± 0.15 V tpd tdis ten enable time VCC(A) = 2.5 V ± 0.2 V tpd VCC(A) = 3.3 V ± 0.3 V tpd propagation delay An to Bn 1.5 Bn to An 0.8 15 0.8 7.2 0.8 6.2 0.7 6.1 0.6 6.0 ns tdis disable time OE to An 1.6 8.2 1.6 8.2 1.6 8.2 1.6 8.2 1.6 8.2 ns OE to Bn 2.1 30 2.1 29.0 1.7 10.3 1.5 8.6 0.8 6.3 ns OE to An 0.8 8.1 0.8 8.1 0.8 8.1 0.8 8.1 0.8 8.1 ns OE to Bn 1.8 31 1.8 27.7 1.4 12.4 1.1 8.5 0.9 6.4 ns propagation delay An to Bn 1.5 22 1.5 21.4 1.0 8.8 0.7 6.0 0.4 4.2 ns Bn to An 0.7 13 0.7 7.0 0.4 4.8 0.3 4.5 0.3 4.3 ns disable time OE to An 0.3 5.4 0.3 5.4 0.3 5.4 0.3 5.4 0.3 5.4 ns OE to Bn 2.0 30 2.0 28.7 1.6 9.7 1.4 8.0 0.7 5.7 ns OE to An 0.7 6.4 0.7 6.4 0.7 6.4 0.7 6.4 0.7 6.4 ns OE to Bn 1.5 31 1.5 27.6 1.3 11.4 1.0 8.1 0.9 6.0 ns ten enable time VCC(A) = 5.0 V ± 0.5 V tpd tdis ten [1] enable time tpd is the same as tPLH and tPHL; tdis is the same as tPLZ and tPHZ; ten is the same as tPZL and tPZH. 74LVC_LVCH8T245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 29 April 2021 © Nexperia B.V. 2021. All rights reserved 11 / 28 74LVC8T245; 74LVCH8T245 Nexperia 8-bit dual supply translating transceiver; 3-state Table 12. Dynamic characteristics for temperature range -40 °C to +125 °C Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 8; for waveforms see Fig. 6 and Fig. 7. [1] Symbol Parameter Conditions VCC(B) Unit 1.5 V ± 0.1 V 1.8 V ± 0.15 V 2.5 V ± 0.2 V 3.3 V ± 0.3 V 5.0 V ± 0.5 V Min Max Min Max Min Max Min Max Min Max VCC(A) = 1.5 V ± 0.1 V propagation delay An to Bn 1.7 32 1.7 27 1.3 21 1.0 18 0.8 16 ns Bn to An 0.9 32 0.9 30 0.8 28 0.7 28 0.7 26 ns disable time OE to An 1.5 34 1.5 34 1.5 34 1.5 34 1.4 34 ns OE to Bn 2.4 41 2.4 40 1.9 18 1.7 17 1.3 15 ns OE to An 0.4 40 0.4 40 0.4 40 0.4 40 0.4 40 ns OE to Bn 1.8 43 1.8 41 1.5 22 1.2 18 0.9 16 ns propagation delay An to Bn 1.7 30 1.7 25.9 1.3 13.2 1.0 11.4 0.8 11.1 ns Bn to An 0.9 27 0.9 28.8 0.8 27.6 0.7 27.4 0.7 27.4 ns disable time OE to An 1.5 34 1.5 33.6 1.5 33.4 1.5 33.3 1.4 33.2 ns OE to Bn 2.4 40 2.4 36.2 1.9 17.1 1.7 16.0 1.3 14.3 ns OE to An 0.4 28 0.4 28 0.4 27.8 0.4 27.7 0.4 27.7 ns OE to Bn 1.8 41 1.8 40 1.5 20 1.2 16.6 0.9 14.8 ns propagation delay An to Bn 1.5 28 1.5 25.4 1.2 13 0.8 10.2 0.6 8.8 ns Bn to An 1.2 23 1.2 13.3 1.0 13.1 1.0 12.9 0.9 12.8 ns tdis disable time OE to An 1.4 13 1.4 13 1.4 13 1.4 13 1.4 13 ns OE to Bn 2.3 37 2.3 33.6 1.8 15 1.7 14.3 0.9 10.9 ns ten enable time OE to An 1.0 17.2 1.0 17.2 1.0 17.3 1.0 17.2 1.0 17.3 ns OE to Bn 1.7 38 1.7 32.2 1.5 18.1 1.2 14.1 1.0 11.2 ns 28 1.5 25.2 1.1 12.8 0.8 10.3 0.5 10.4 ns tpd tdis ten enable time VCC(A) = 1.8 V ± 0.15 V tpd tdis ten enable time VCC(A) = 2.5 V ± 0.2 V tpd VCC(A) = 3.3 V ± 0.3 V tpd propagation delay An to Bn 1.5 Bn to An 0.8 18 0.8 11.2 0.8 10.2 0.7 10.1 0.6 10 ns tdis disable time OE to An 1.6 12.2 1.6 12.2 1.6 12.2 1.6 12.2 1.6 12.2 ns OE to Bn 2.1 36 2.1 33 1.7 14.3 1.5 12.6 0.8 10.3 ns OE to An 0.8 14.1 0.8 14.1 0.8 13.6 0.8 13.2 0.8 13.6 ns OE to Bn 1.8 37 1.8 31.7 1.4 18.4 1.1 12.9 0.9 10.9 ns propagation delay An to Bn 1.5 26 1.5 25.4 1.0 12.8 0.7 10 0.4 8.2 ns Bn to An 0.7 16 0.7 11 0.4 8.8 0.3 8.5 0.3 8.3 ns disable time OE to An 0.3 9.4 0.3 9.4 0.3 9.4 0.3 9.4 0.3 9.4 ns OE to Bn 2.0 36 2.0 32.7 1.6 13.7 1.4 12 0.7 9.7 ns OE to An 0.7 10.9 0.7 10.9 0.7 10.9 0.7 10.9 0.7 10.9 ns OE to Bn 1.5 37 1.5 31.6 1.3 18.4 1.0 13.7 0.9 10.7 ns ten enable time VCC(A) = 5.0 V ± 0.5 V tpd tdis ten [1] enable time tpd is the same as tPLH and tPHL; tdis is the same as tPLZ and tPHZ; ten is the same as tPZL and tPZH. 74LVC_LVCH8T245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 29 April 2021 © Nexperia B.V. 2021. All rights reserved 12 / 28 74LVC8T245; 74LVCH8T245 Nexperia 8-bit dual supply translating transceiver; 3-state 10.1. Waveforms and test circuit VI VM An, Bn input GND tPHL tPLH VOH VM Bn, An output VOL 001aai475 Measurement points are given in Table 13. VOL and VOH are typical output voltage levels that occur with the output load. Fig. 6. The data input (An, Bn) to output (Bn, An) propagation delay times VI OE input VM GND tPLZ output LOW-to-OFF OFF-to-LOW tPZL VCCO VM VX VOL tPZH tPHZ output HIGH-to-OFF OFF-to-HIGH VOH VY VM GND outputs enabled outputs enabled outputs disabled 001aai474 Measurement points are given in Table 13. VOL and VOH are typical output voltage levels that occur with the output load. Fig. 7. Enable and disable times Table 13. Measurement points Supply voltage Input [1] Output [2] VCC(A), VCC(B) VM VM VX VY 1.2 V to 1.6 V 0.5VCCI 0.5VCCO VOL + 0.1 V VOH - 0.1 V 1.65 V to 2.7 V 0.5VCCI 0.5VCCO VOL + 0.15 V VOH - 0.15 V 3.0 V to 5.5 V 0.5VCCI 0.5VCCO VOL + 0.3 V VOH - 0.3 V [1] [2] VCCI is the supply voltage associated with the data input port. VCCO is the supply voltage associated with the output port. 74LVC_LVCH8T245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 29 April 2021 © Nexperia B.V. 2021. All rights reserved 13 / 28 74LVC8T245; 74LVCH8T245 Nexperia 8-bit dual supply translating transceiver; 3-state VI negative pulse tW 90 % VM 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % VM VM 10 % tW VEXT VCC G VI RL VO DUT RT CL RL 001aae331 Test data is given in Table 14. RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance. VEXT = External voltage for measuring switching times. Fig. 8. Test circuit for measuring switching times Table 14. Test data Supply voltage Input VCC(A), VCC(B) VI [1] Δt/ΔV [2] CL RL tPLH, tPHL tPZH, tPHZ tPZL, tPLZ [3] 1.2 V to 5.5 V VCCI ≤ 1.0 ns/V 15 pF 2 kΩ open GND 2VCCO [1] [2] [3] Load VEXT VCCI is the supply voltage associated with the data input port. dV/dt ≥ 1.0 V/ns. VCCO is the supply voltage associated with the output port. 74LVC_LVCH8T245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 29 April 2021 © Nexperia B.V. 2021. All rights reserved 14 / 28 74LVC8T245; 74LVCH8T245 Nexperia 8-bit dual supply translating transceiver; 3-state 11. Typical propagation delay characteristics 001aal268 14 tPHL (ns) 12 (1) 10 6 2 2 5 10 15 20 25 30 CL (pF) 35 a. HIGH to LOW propagation delay (A to B) 001aal270 14 tPHL (ns) 12 0 0 8 6 6 4 4 2 2 10 15 20 25 30 CL (pF) 10 15 20 25 35 c. HIGH to LOW propagation delay (B to A) 30 CL (pF) 35 001aal271 (1) (2) (3) (4) (5) (6) 10 5 5 b. LOW to HIGH propagation delay (A to B) 8 0 (4) (5) (6) 14 tPLH (ns) 12 (1) (2) (3) (4) (5) (6) 10 (3) 6 4 0 (2) 8 4 0 (1) 10 (2) (3) (4) (5) (6) 8 0 001aal269 14 tPLH (ns) 12 0 0 5 10 15 20 25 30 CL (pF) 35 d. LOW to HIGH propagation delay (B to A) (1) VCC(B) = 1.2 V. (2) VCC(B) = 1.5 V. (3) VCC(B) = 1.8 V. (4) VCC(B) = 2.5 V. (5) VCC(B) = 3.3 V. (6) VCC(B) = 5.0 V. Fig. 9. Typical propagation delay versus load capacitance; Tamb = 25 °C; VCC(A) = 1.2 V 74LVC_LVCH8T245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 29 April 2021 © Nexperia B.V. 2021. All rights reserved 15 / 28 74LVC8T245; 74LVCH8T245 Nexperia 8-bit dual supply translating transceiver; 3-state 001aal272 14 tPHL (ns) 12 001aal273 14 tPLH (ns) 12 (1) (1) 10 10 (2) (2) 8 8 (3) (4) (5) (6) 6 6 4 4 2 2 0 0 5 10 15 20 25 30 CL (pF) 35 a. HIGH to LOW propagation delay (A to B) 001aal274 14 tPHL (ns) 12 10 6 0 10 15 20 25 30 CL (pF) 35 001aal275 10 (1) (2) (3) (4) (5) (6) 8 6 4 2 2 0 5 b. LOW to HIGH propagation delay (A to B) 4 0 0 14 tPLH (ns) 12 (1) (2) (3) (4) (5) (6) 8 (3) (4) (5) (6) 5 10 15 20 25 30 CL (pF) 35 c. HIGH to LOW propagation delay (B to A) 0 0 5 10 15 20 25 30 CL (pF) 35 d. LOW to HIGH propagation delay (B to A) (1) VCC(B) = 1.2 V. (2) VCC(B) = 1.5 V. (3) VCC(B) = 1.8 V. (4) VCC(B) = 2.5 V. (5) VCC(B) = 3.3 V. (6) VCC(B) = 5.0 V. Fig. 10. Typical propagation delay versus load capacitance; Tamb = 25 °C; VCC(A) = 1.5 V 74LVC_LVCH8T245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 29 April 2021 © Nexperia B.V. 2021. All rights reserved 16 / 28 74LVC8T245; 74LVCH8T245 Nexperia 8-bit dual supply translating transceiver; 3-state 001aal276 14 tPHL (ns) 12 (1) (1) 10 8 10 (3) (3) 6 (4) (5) (6) 4 2 0 5 10 15 20 25 30 CL (pF) 35 a. HIGH to LOW propagation delay (A to B) 001aal278 14 tPHL (ns) 12 0 0 5 10 15 20 25 (1) (2) (3) (4) (5) (6) 6 (1) (2) (3) (4) (5) (6) 8 6 4 4 2 2 0 5 10 15 20 25 30 CL (pF) 35 c. HIGH to LOW propagation delay (B to A) 35 001aal279 10 8 30 CL (pF) b. LOW to HIGH propagation delay (A to B) 14 tPLH (ns) 12 10 0 (4) (5) (6) 4 2 0 (2) 8 (2) 6 001aal277 14 tPLH (ns) 12 0 0 5 10 15 20 25 30 CL (pF) 35 d. LOW to HIGH propagation delay (B to A) (1) VCC(B) = 1.2 V. (2) VCC(B) = 1.5 V. (3) VCC(B) = 1.8 V. (4) VCC(B) = 2.5 V. (5) VCC(B) = 3.3 V. (6) VCC(B) = 5.0 V. Fig. 11. Typical propagation delay versus load capacitance; Tamb = 25 °C; VCC(A) = 1.8 V 74LVC_LVCH8T245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 29 April 2021 © Nexperia B.V. 2021. All rights reserved 17 / 28 74LVC8T245; 74LVCH8T245 Nexperia 8-bit dual supply translating transceiver; 3-state 001aal280 14 tPHL (ns) 12 (1) 10 8 8 (2) (3) 6 4 (4) (5) (6) 4 2 (2) (3) (4) (5) (6) 2 0 5 10 15 20 25 30 CL (pF) 35 a. HIGH to LOW propagation delay (A to B) 001aal282 14 tPHL (ns) 12 0 0 5 10 15 20 25 30 CL (pF) 35 b. LOW to HIGH propagation delay (A to B) 001aal283 14 tPLH (ns) 12 10 10 8 8 (1) (2) (3) (4) (5) (6) 6 4 (1) (2) (3) (4) (5) (6) 6 4 2 0 (1) 10 6 0 001aal281 14 tPLH (ns) 12 2 0 5 10 15 20 25 30 CL (pF) 35 c. HIGH to LOW propagation delay (B to A) 0 0 5 10 15 20 25 30 CL (pF) 35 d. LOW to HIGH propagation delay (B to A) (1) VCC(B) = 1.2 V. (2) VCC(B) = 1.5 V. (3) VCC(B) = 1.8 V. (4) VCC(B) = 2.5 V. (5) VCC(B) = 3.3 V. (6) VCC(B) = 5.0 V. Fig. 12. Typical propagation delay versus load capacitance; Tamb = 25 °C; VCC(A) = 2.5 V 74LVC_LVCH8T245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 29 April 2021 © Nexperia B.V. 2021. All rights reserved 18 / 28 74LVC8T245; 74LVCH8T245 Nexperia 8-bit dual supply translating transceiver; 3-state 001aal284 14 tPHL (ns) 12 (1) 10 8 001aal285 14 tPLH (ns) 12 (1) 10 8 (2) (2) 6 (3) 6 (3) 4 (4) (5) (6) 4 (4) (5) (6) 2 0 2 0 5 10 15 20 25 30 CL (pF) 35 a. HIGH to LOW propagation delay (A to B) 001aal286 14 tPHL (ns) 12 0 5 10 15 20 25 30 CL (pF) 35 b. LOW to HIGH propagation delay (A to B) 001aal287 14 tPLH (ns) 12 10 10 8 8 (1) (2) (3) (4) (5) (6) 6 4 (1) (2) (3) (4) (5) (6) 6 4 2 0 0 2 0 5 10 15 20 25 30 CL (pF) 35 c. HIGH to LOW propagation delay (B to A) 0 0 5 10 15 20 25 30 CL (pF) 35 d. LOW to HIGH propagation delay (B to A) (1) VCC(B) = 1.2 V. (2) VCC(B) = 1.5 V. (3) VCC(B) = 1.8 V. (4) VCC(B) = 2.5 V. (5) VCC(B) = 3.3 V. (6) VCC(B) = 5.0 V. Fig. 13. Typical propagation delay versus load capacitance; Tamb = 25 °C; VCC(A) = 3.3 V 74LVC_LVCH8T245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 29 April 2021 © Nexperia B.V. 2021. All rights reserved 19 / 28 74LVC8T245; 74LVCH8T245 Nexperia 8-bit dual supply translating transceiver; 3-state 001aal288 14 tPHL (ns) 12 (1) 10 8 8 (2) (3) 6 4 (4) (5) (6) 4 2 (2) (3) (4) (5) (6) 2 0 5 10 15 20 25 30 CL (pF) 35 a. HIGH to LOW propagation delay (A to B) 001aal290 14 tPHL (ns) 12 0 8 8 (1) (2) (3) (4) (5) (6) 4 5 10 15 20 25 35 (1) (2) (3) (4) (5) (6) 6 4 2 30 CL (pF) 001aal291 14 tPLH (ns) 12 10 6 0 b. LOW to HIGH propagation delay (A to B) 10 0 (1) 10 6 0 001aal289 14 tPLH (ns) 12 2 0 5 10 15 20 25 30 CL (pF) 35 c. HIGH to LOW propagation delay (B to A) 0 0 5 10 15 20 25 30 CL (pF) 35 d. LOW to HIGH propagation delay (B to A) (1) VCC(B) = 1.2 V. (2) VCC(B) = 1.5 V. (3) VCC(B) = 1.8 V. (4) VCC(B) = 2.5 V. (5) VCC(B) = 3.3 V. (6) VCC(B) = 5.0 V. Fig. 14. Typical propagation delay versus load capacitance; Tamb = 25 °C; VCC(A) = 5 V 74LVC_LVCH8T245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 29 April 2021 © Nexperia B.V. 2021. All rights reserved 20 / 28 74LVC8T245; 74LVCH8T245 Nexperia 8-bit dual supply translating transceiver; 3-state 12. Application information 12.1. Unidirectional logic level-shifting application The circuit given in Fig. 15 is an example of the 74LVC8T245; 74LVCH8T245 being used in an unidirectional logic level-shifting application. VCC1 VCC1 VCC(A) VCC(B) 74LVC8T245 74LVCH8T245 GND An DIR VCC2 VCC2 Bn OE system-1 system-2 001aak438 Schematic given for one channel. Fig. 15. Unidirectional logic level-shifting application Table 15. Description unidirectional logic level-shifting application Name Function Description VCC(A) VCC1 supply voltage of system-1 (1.2 V to 5.5 V) GND GND device GND A OUT output level depends on VCC1 voltage B IN input threshold value depends on VCC2 voltage DIR DIR the GND (LOW level) determines B port to A port direction VCC(B) VCC2 supply voltage of system-2 (1.2 V to 5.5 V) OE OE The GND (LOW level) enables the output ports 12.2. Bidirectional logic level-shifting application Fig. 16 shows the 74LVC8T245; 74LVCH8T245 being used in a bidirectional logic level-shifting application. VCC1 VCC1 I/O-1 PULL-UP/DOWN VCC(A) GND A VCC(B) 74LVC8T245 74LVCH8T245 DIR VCC2 VCC2 I/O-2 PULL-UP/DOWN B OE OE DIR CTRL system-1 system-2 001aak439 Schematic given for one channel. Pull-up or pull-down only needed for 74LVC8T245. Fig. 16. Bidirectional logic level-shifting application 74LVC_LVCH8T245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 29 April 2021 © Nexperia B.V. 2021. All rights reserved 21 / 28 74LVC8T245; 74LVCH8T245 Nexperia 8-bit dual supply translating transceiver; 3-state Table 16 gives a sequence that will illustrate data transmission from system-1 to system-2 and then from system-2 to system-1. Table 16. Description bidirectional logic level-shifting application H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF-state. State DIR CTRL OE I/O-1 I/O-2 Description 1 H L output input system-1 data to system-2 2 H H Z Z system-2 is getting ready to send data to system-1. I/O-1 and I/O-2 are disabled. The bus-line state depends on bus hold. 3 L H Z Z DIR bit is set LOW. I/O-1 and I/O-2 still are disabled. The bus-line state depends on bus hold. 4 L L input output system-2 data to system-1 12.3. Power-up considerations The device is designed such that no special power-up sequence is required other than GND being applied first. Table 17. Typical total supply current (ICC(A) + ICC(B)) VCC(A) VCC(B) 74LVC_LVCH8T245 Product data sheet Unit 0V 1.8 V 2.5 V 3.3 V 5.0 V 0V 0
74LVCH8T245BQ118 价格&库存
很抱歉,暂时无法提供与“74LVCH8T245BQ118”相匹配的价格&库存,您可以联系我们找货
