74HC241; 74HCT241
Octal buffer/line driver; 3-state
Rev. 4 — 15 July 2021
Product data sheet
1. General description
The 74HC241; 74HCT241 is an 8-bit buffer/line driver with 3-state outputs. The device can be used
as two 4-bit buffers or one 8-bit buffer. The device features two output enables (1OE and 2OE),
each controlling four of the 3-state outputs. A HIGH on 1OE or LOW on 2OE causes the associated
outputs to assume a high-impedance OFF-state. Inputs include clamp diodes. This enables the use
of current limiting resistors to interface inputs to voltages in excess of VCC.
The 74HCT241 device features reduced input threshold levels to allow interfacing to TTL logic
levels.
2. Features and benefits
Wide supply voltage range from 2.0 to 6.0 V
CMOS low power dissipation
High noise immunity
Latch-up performance exceeds 100 mA per JESD 78 Class II Level B
Input levels:
• For 74HC241: CMOS level
• For 74HCT241: TTL level
Octal bus interface
Non-inverting 3-state outputs
Complies with JEDEC standards
• JESD8C (2.7 V to 3.6 V)
• JESD7A (2.0 V to 6.0 V)
ESD protection:
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-A exceeds 200 V
Specified from −40 °C to +85 °C and −40 °C to +125 °C
3. Ordering information
Table 1. Ordering information
Type number
Package
74HC241D
Temperature range
Name
Description
Version
-40 °C to +125 °C
SO20
plastic small outline package; 20 leads;
body width 7.5 mm
SOT163-1
-40 °C to +125 °C
TSSOP20
plastic thin shrink small outline package; 20 leads;
body width 4.4 mm
SOT360-1
74HCT241D
74HC241PW
74HCT241PW
74HC241; 74HCT241
Nexperia
4. Functional diagram
2
4
6
8
1
1Y0
1A1
1Y1
1A2
1Y2
1A3
1Y3
18
16
14
12
1
EN
1OE
2Y0
2A0
17
15
13
11
19
1A0
2A1
2Y1
2A2
2Y2
2A3
2Y3
3
2
18
4
16
6
14
8
12
5
19
7
9
2OE
EN
11
9
13
7
15
5
17
3
mna773
mna772
Fig. 1.
Logic symbol
Fig. 2.
IEC logic symbol
5. Pinning information
5.1. Pinning
74HC241
74HCT241
74HC241
74HCT241
1OE
1
20 VCC
1OE
1
20 VCC
1A0
2
19 2OE
1A0
2
19 2OE
2Y0
3
18 1Y0
2Y0
3
18 1Y0
1A1
4
17 2A0
1A1
4
17 2A0
2Y1
5
16 1Y1
2Y1
5
16 1Y1
1A2
6
15 2A1
1A2
6
15 2A1
2Y2
7
14 1Y2
2Y2
7
14 1Y2
1A3
8
13 2A2
1A3
8
13 2A2
2Y3
9
12 1Y3
2Y3
9
12 1Y3
GND 10
11 2A3
GND 10
aaa-028154
Fig. 3.
Pin configuration SOT163-1 (SO20)
74HC_HCT241
Product data sheet
11 2A3
aaa-028155
Fig. 4.
Pin configuration SOT360-1 (TSSOP20)
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2021. All rights reserved
2 / 13
74HC241; 74HCT241
Nexperia
5.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
1OE
1
output enable input (active LOW)
1A0, 1A1, 1A2, 1A3
2, 4, 6, 8
data input
2A0, 2A1, 2A2, 2A3
17, 15, 13, 11
data input
GND
10
ground (0 V)
1Y0, 1Y1, 1Y2, 1Y3
18, 16, 14, 12
data output
2Y0, 2Y1, 2Y2, 2Y3
3, 5, 7, 9
data output
2OE
19
output enable input (active HIGH)
VCC
supply voltage
6. Functional description
Table 3. Function table
H = HIGH voltage level; L = LOW voltage level; X = Don’t care; Z = High impedance "OFF" state
Inputs
Outputs
Inputs
Outputs
1OE
1An
1Yn
2OE
2An
2Yn
L
L
L
H
L
L
L
H
H
H
H
H
H
X
Z
L
X
Z
7. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Max
Unit
VCC
supply voltage
-0.5
+7
V
IIK
input clamping current
VI < -0.5 V or VI > VCC + 0.5 V
±20
mA
IOK
output clamping current
VO < -0.5 V or VO > VCC + 0.5 V
±20
mA
IO
output current
-0.5 V < VO < VCC + 0.5 V
±35
mA
ICC
supply current
70
mA
IGND
ground current
-70
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
500
mW
[1]
[1]
For SOT163-1 (SO20) package: Ptot derates linearly with 12.3 mW/K above 109 °C.
For SOT360-1 (TSSOP20) package: Ptot derates linearly with 10.0 mW/K above 100 °C.
74HC_HCT241
Product data sheet
3 / 13
74HC241; 74HCT241
Nexperia
8. Recommended operating conditions
Table 5. Recommended operating conditions
Symbol Parameter
Conditions
VCC
supply voltage
VI
input voltage
VO
output voltage
Δt/ΔV
input transition rise and fall
rate
Tamb
74HC241
74HCT241
Unit
Min
Typ
Max
Min
Typ
Max
2.0
5.0
6.0
4.5
5.0
5.5
V
VCC
VCC
V
V
VCC
VCC
VCC = 2.0 V
625
ns/V
VCC = 4.5 V
1.67
139
1.67
139
ns/V
VCC = 6.0 V
83
ns/V
-40
+125
-40
+125
ambient temperature
°C
9. Static characteristics
Table 6. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
25 °C
−40 °C to +85 °C −40 °C to +125 °C Unit
Min
Typ Max
Min
Max
Min
Max
VCC = 2.0 V
1.5
1.2
1.5
1.5
V
VCC = 4.5 V
3.15
2.4
3.15
3.15
V
VCC = 6.0 V
4.2
3.2
4.2
4.2
V
LOW-level input VCC = 2.0 V
voltage
VCC = 4.5 V
0.8
0.5
0.5
0.5
V
2.1
1.35
1.35
1.35
V
VCC = 6.0 V
2.8
1.8
1.8
1.8
V
IO = -20 μA; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = -20 μA; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = -20 μA; VCC = 6.0 V
5.9
6.0
5.9
5.9
V
IO = -6.0 mA; VCC = 4.5 V
3.98 4.32
3.84
3.7
V
IO = -7.8 mA; VCC = 6.0 V
5.48 5.81
5.34
5.2
V
74HC241
VIH
VIL
VOH
VOL
HIGH-level
input voltage
HIGH-level
output voltage
LOW-level
output voltage
VI = VIH or VIL
VI = VIH or VIL
IO = 20 μA; VCC = 2.0 V
0.1
0.1
V
IO = 20 μA; VCC = 4.5 V
0.1
0.1
V
IO = 20 μA; VCC = 6.0 V
0.1
0.1
V
IO = 6.0 mA; VCC = 4.5 V
0.15 0.26
0.33
0.4
V
IO = 7.8 mA; VCC = 6.0 V
0.16 0.26
0.33
0.4
V
II
input leakage
current
VI = VCC or GND; VCC = 6.0 V
±0.1
±1.0
±1.0
μA
IOZ
OFF-state
output current
VI = VIH or VIL; VCC = 6.0 V;
VO = VCC or GND
±0.5
±5.0
±10
μA
ICC
supply current
VI = VCC or GND; IO = 0 A;
VCC = 6.0 V
8.0
80
160
μA
CI
input
capacitance
3.5
pF
74HC_HCT241
Product data sheet
4 / 13
74HC241; 74HCT241
Nexperia
Symbol Parameter
Conditions
25 °C
Min
Typ Max
Min
Max
Min
Max
2.0
1.6
2.0
2.0
V
1.2
0.8
0.8
0.8
V
IO = -20 μA
4.4
4.5
4.4
4.4
V
IO = -6 mA
3.98 4.32
3.84
3.7
V
0.1
0.1
0.1
V
0.16 0.26
74HCT241
VIH
HIGH-level
input voltage
VCC = 4.5 V to 5.5 V
VIL
LOW-level input VCC = 4.5 V to 5.5 V
voltage
VOH
HIGH-level
output voltage
VI = VIH or VIL; VCC = 4.5 V
LOW-level
output voltage
0.33
0.4
V
II
input leakage
current
VI = VCC or GND; VCC = 5.5 V
±0.1
±1.0
±1.0
μA
IOZ
OFF-state
output current
VI = VIH or VIL; VCC = 5.5 V;
VO = VCC or GND
±0.5
±5.0
±10
μA
ICC
supply current
VI = VCC or GND; VCC = 5.5 V;
IO = 0 A
8.0
80
160
μA
ΔICC
additional
supply current
per input pin;
VCC = 4.5 V to 5.5 V;
VI = VCC - 2.1 V;
other inputs at VCC or GND;
IO = 0 A
VOL
CI
IO = 20 μA
IO = 6.0 mA
nAn; 1OE
70
252
315
343
μA
2OE
150
540
675
735
μA
3.5
pF
input
capacitance
10. Dynamic characteristics
Table 7. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 8.
Symbol Parameter
Conditions
+25 °C
Min
−40 °C to +85 °C
Typ Max
Min
Max
Min
Max
74HC241
tpd
ten
propagation
delay
enable time
74HC_HCT241
Product data sheet
nAn to nYn; see Fig. 5
[1]
VCC = 2.0 V
25
100
125
150
ns
VCC = 4.5 V
9
30
ns
VCC = 5.0 V; CL = 15 pF
7
ns
VCC = 6.0 V
7
17
21
26
ns
VCC = 2.0 V
30
150
190
225
ns
VCC = 4.5 V
11
30
38
45
ns
VCC = 6.0 V
9
26
33
38
ns
1OE to 1Yn; see Fig. 6;
2OE to 2Yn; see Fig. 7
[2]
5 / 13
74HC241; 74HCT241
Nexperia
Symbol Parameter
Conditions
+25 °C
Min
disable time 1OE to 1Yn; see Fig. 6;
tdis
tt
transition
time
CPD
−40 °C to +85 °C
Typ Max
Min
Max
Min
Max
[3]
VCC = 2.0 V
39
150
190
225
ns
VCC = 4.5 V
14
30
38
45
ns
VCC = 6.0 V
11
26
33
38
ns
VCC = 2.0 V
14
60
75
90
ns
VCC = 4.5 V
5
12
15
18
ns
VCC = 6.0 V
4
10
13
15
ns
30
pF
13
22
28
33
ns
see Fig. 5
[4]
power
per buffer; VI = GND to VCC
dissipation
capacitance
[5]
74HCT241
propagation
delay
11
ns
ten
enable time
2OE to 2Yn; see Fig. 7;
VCC = 4.5 V
[2]
15
30
38
45
ns
tdis
VCC = 4.5 V
[3]
18
30
38
45
ns
tt
transition
time
[4]
5
12
15
18
ns
CPD
power
per buffer;
dissipation
VI = GND to VCC - 1.5 V
capacitance
[5]
30
pF
tpd
[1]
VCC = 4.5 V
[1]
[2]
[3]
[4]
[5]
VCC = 4.5 V; see Fig. 5
tpd is the same as tPHL and tPLH.
ten is the same as tPZH and tPZL.
tdis is the same as tPHZ and tPLZ.
tt is the same as tTHL and tTLH.
CPD is used to determine the dynamic power dissipation (PD in μW):
2
2
PD = CPD VCC fi N + ∑(CL VCC fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
∑(CL VCC fo) = sum of outputs.
74HC_HCT241
Product data sheet
6 / 13
74HC241; 74HCT241
Nexperia
10.1. Waveforms and test circuit
VI
VM
nAn input
VM
GND
t PHL
VOH
90 %
t PLH
VM
VM
nYn output
10 %
VOL
t THL
t TLH
001aae013
See Table 8 for measurement points.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig. 5.
Input (nAn) to output (nYn) propagation delays and output transition times
VI
1OE input
VM
VM
GND
tPLZ
1Yn output
LOW-to-OFF
OFF-to-LOW
tPZL
VCC
VM
VX
VOL
tPHZ
1Yn output
HIGH-to-OFF
OFF-to-HIGH
VOH
tPZH
VY
VM
GND
outputs
enabled
outputs
disabled
outputs
enabled
aaa-028156
VOL and VOH are typical output voltage levels that occur with the output load.
Fig. 6.
3-state output (1OE to 1Yn) enable and disable times
VI
2OE input
VM
VM
GND
tPLZ
2Yn output
LOW-to-OFF
OFF-to-LOW
tPZL
VCC
VM
VX
VOL
tPHZ
2Yn output
HIGH-to-OFF
OFF-to-HIGH
VOH
tPZH
VY
VM
GND
outputs
enabled
outputs
disabled
outputs
enabled
aaa-028157
Fig. 7.
3-state output (2OE to 2Yn) enable and disable times
74HC_HCT241
Product data sheet
7 / 13
74HC241; 74HCT241
Nexperia
Table 8. Measurement points
Type
Input
Output
VI
VM
VM
VX
VY
74HC241
GND to VCC
0.5 x VCC
0.5 x VCC
0.1 x VCC
0.9 x VCC
74HCT241
GND to 3 V
1.3 V
1.3 V
0.1 x VCC
0.9 x VCC
VI
negative
pulse
tW
90 %
VM
0V
VI
positive
pulse
0V
VM
10 %
tf
tr
tr
tf
90 %
VM
VM
10 %
tW
VCC
G
VI
VCC
VO
DUT
RT
RL
S1
open
CL
001aad983
Test data is given in Table 9.
Definitions test circuit:
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
CL = Load capacitance including jig and probe capacitance.
RL = Load resistance.
S1 = Test selection switch.
Fig. 8.
Test circuit for measuring switching times
Table 9. Test data
Type
Input
Load
S1 position
VI
tr, tf
CL
RL
tPHL, tPLH
tPZH, tPHZ
tPZL, tPLZ
74HC241
GND to VCC
6 ns
50 pF
1 kΩ
open
GND
VCC
74HCT241
GND to 3 V
6 ns
50 pF
1 kΩ
open
GND
VCC
74HC_HCT241
Product data sheet
8 / 13
74HC241; 74HCT241
Nexperia
11. Package outline
SO20: plastic small outline package; 20 leads; body width 7.5 mm
SOT163-1
D
E
A
X
c
y
HE
v M A
Z
Q
A2
A
(A 3 )
A1
pin 1 index
θ
Lp
L
1
10
e
detail X
w M
bp
10 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
mm
2.65
0.3
0.1
2.45
2.25
0.25
0.49
0.36
0.32
0.23
13.0
12.6
7.6
7.4
1.27
10.65
10.00
1.4
1.1
0.4
1.1
1.0
0.25
0.25
0.1
0.9
0.4
inches
0.1
0.012 0.096
0.004 0.089
0.01
0.019 0.013
0.014 0.009
0.51
0.49
0.30
0.29
0.05
0.419
0.043
0.055
0.394
0.016
0.043
0.039
0.01
0.01
0.004
0.035
0.016
Z
(1)
θ
o
8
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
Fig. 9.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT163-1
075E04
MS-013
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Package outline SOT163-1 (SO20)
74HC_HCT241
Product data sheet
9 / 13
74HC241; 74HCT241
Nexperia
TSSOP20: plastic thin shrink small outline package; 20 leads; body width 4.4 mm
D
SOT360-1
E
A
X
c
HE
y
v M A
Z
11
Q
A2
pin 1 index
(A 3 )
A1
A
θ
Lp
1
L
10
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
6.6
6.4
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.5
0.2
8o
0o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT360-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-153
Fig. 10. Package outline SOT360-1 (TSSOP20)
74HC_HCT241
Product data sheet
10 / 13
74HC241; 74HCT241
Nexperia
12. Abbreviations
Table 10. Abbreviations
Acronym
Description
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
13. Revision history
Table 11. Revision history
Document ID
Release date
Data sheet status
Change notice Supersedes
74HC_HCT241 v.4
20210715
Product data sheet
Modifications:
74HC_HCT241 v.3
20180220
Modifications:
74HC_HCT241 v.2
74HC_HCT241
Product data sheet
74HC_HCT241 v.3
Type numbers 74HC241DB and 74HCT241DB (SOT339-1/SSOP20) removed.
Section 2 updated.
Section 7: Derating values for Ptot total power dissipation updated.
Product data sheet
74HC_HCT241 v.2
The format of this data sheet has been redesigned to comply with the identity
guidelines of Nexperia.
Legal texts have been adapted to the new company name where appropriate.
19930801
Product data sheet
74HC_HCT241 v.1
11 / 13
74HC241; 74HCT241
Nexperia
14. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
74HC_HCT241
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
12 / 13
74HC241; 74HCT241
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................1
4. Functional diagram.......................................................2
5. Pinning information......................................................2
5.1. Pinning.........................................................................2
5.2. Pin description............................................................. 3
6. Functional description................................................. 3
7. Limiting values............................................................. 3
8. Recommended operating conditions..........................4
9. Static characteristics....................................................4
10. Dynamic characteristics............................................ 5
10.1. Waveforms and test circuit........................................ 7
11. Package outline.......................................................... 9
12. Abbreviations............................................................ 11
13. Revision history........................................................11
14. Legal information......................................................12
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 15 July 2021
74HC_HCT241
Product data sheet
13 / 13
