LM1458N
LM1458N
    L3HARRIS
    DIP-8
    OPERATIONAL AMPLIFIER FOR COMMER
LM1458N 数据手册
Datasheet CA1558 Single and Dual, High Gain Operational Amplifiers for Military, Industrial, and Commercial Applications The CA1458, CA1558 (dual types); CA741C, CA741 (single types); high-gain operational amplifiers lor use in military, industrial, and commercial applications. These monolithic silicon integrated circuit devices provide output short circuit protection and latch-free operation. These types also feature wide common mode and differential mode signal ranges and have low offset voltage nulling capability when used with an approprialely valued potentiometer. A 10kΩ potentiometer is used for offset nulling types CA741C, CA741. Types CA1458, CA1558 have no specific terminals for offset nulling. Each type consists of a differential input amplifier that effectively drives a gain and level shifting stage having a complementary emitter follower output. Rochester Electronics Manufactured Components Rochester branded components are manufactured using either die/wafers purchased from the original suppliers or Rochester wafers recreated from the original IP. All re-creations are done with the approval of the Original Component Manufacturer (OCM). Parts are tested using original factory test programs or Rochester developed test solutions to guarantee product meets or exceeds the OCM data sheet. Quality Overview • ISO-9001 • AS9120 certification • Qualified Manufacturers List (QML) MIL-PRF-35835 • Class Q Military • Class V Space Level • Qualified Suppliers List of Distributors (QSLD) • Rochester is a critical supplier to DLA and meets all industry and DLA standards. Rochester Electronics, LLC is committed to supplying products that satisfy customer expectations for quality and are equal to those originally supplied by industry manufacturers. The original manufacturer’s datasheet accompanying this document reflects the performance and specifications of the Rochester manufactured version of this device. Rochester Electronics guarantees the performance of its semiconductor products to the original OCM specifications. ‘Typical’ values are for reference purposes only. Certain minimum or maximum ratings may be based on product characterization, design, simulation, or sample testing. FOR REFERENCE ONLY © 2019 Rochester Electronics, LLC. All Rights Reserved 04112019 To learn more, please visit www.rocelec.com HARRIS SEMICONDUCTOR CA741, CA741C, CA1458, CA1558, LM741, LM741C, LM1458 Single and Dual, High Gain Operational Amplif iers for Military, Industrial and Commercial Applications November 1996 Description Features Input Blas Current ••••••••••••••••••• S00nA (Max) Input Offset Current.................. 200nA (Max) Applications Com parator Multlvibrator DC Amplifier Summing Amplifier Integrator or Differentiator Narrow Band or Band Pass Filter Ordering In formation PART NUMBER T EMP.RANGE ('C) PACKAGE PKG. NO. -55 to 125 8 Ld PDIP E8.3 CA0741CE Oto 70 8 Ld PDIP EB.3 CA1458E Oto 70 8 Ld PDIP E8.3 CA1558E -55 to 125 8 Ld PDIP EB.3 CA0741T -55 lo 125 8 Pin Metal Can T8_C CA0741CT Oto 70 8 Pin Metal Can TB.C CA1458T Oto 70 8 Pin Metal Can T8_C T8.C CA0741E CA1558T -55 to 125 8 Pin Metal Can LM741 N -55 lo 125 8 Ld PDIP E8_3 0 to 70 8 Ld PDIP E8_3 LM741CN -55 to 125 8 Pin Metal Can TB_C LM741CH Oto 70 8 Pin Metal Can T8_C LM1458N Oto 70 8 Ld PDIP E8.3 LM741 H Pinouts The CA1458, CA1558 (dual types); CA741C, CA741 (single types); high-gain operational amplifiers lor use in military, industrial, and commercial applications. These monolithic silicon integrated circuit devices provide output short circuit protection and latch-free operation. These types also feature wide common mode and differential mode signal ranges and l1ave low offset voltage nulling capability when used with an approprialely valued potentiometer. A 1 Ok!l potentiometer is used for offset nulling types CA741 C, CA741 (see Figure 1). Types CA1458, CA1558 have no specific terminals for offset nulling. Each type consists of a differential input amplifier that effectively drives a gain and level shifting stage having a complementary emitter follower output. The manufacturing process make it possible to produce IC operational amplifiers with low burst ·popcorn" noise characteristics. The CA741 gives limit specifications for burst noise in the data bulletin, File Number 530. Contact your Sales Representative for information pertinent to other oper­ ational amplifier types that meet low burst noise specifications. Technical Data on LM Branded types is identical to the corre­ sponding CA Branded types. CA1458, CA1558 (METAL CAN) TOP VIEW CA741, CA741 C, LM741, LM741 C (CAN) TOP VIEW y. CA1458, CA1558, LM1458 (PDIP) TOP VIEW CA741, CA741C, LM741, LM741 C (PDIP) TOP VIEW INV. INPUT (A) 2 NON-INV. INPUT (A) 3 CAUTION: These devices are sensitive to electrostatic discharge. Users should follow proper IC Handling Procedures. Copyright © Harris Corporation 1996 3-29 7 OUTPUT (B) 6 INV. INPUT (B) 5 NON-INV. INPUT (B) File Number 531 .3
LM1458N 价格&库存
很抱歉,暂时无法提供与“LM1458N”相匹配的价格&库存,您可以联系我们找货
