TSSA3U45 M2G
TSSA3U45 M2G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO-214AC
    DIODE SCHOTTKY 45V 3A DO214AC
TSSA3U45 M2G 数据手册
TSSA3U45 Taiwan Semiconductor 3A, 45V Trench Schottky Surface Mount Rectifier FEATURES ● ● ● ● ● ● KEY PARAMETERS Patented Trench Schottky technology Low power loss, high efficiency High surge current capability Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS ● Trench Schottky barrier rectifier are designed for high frequency miniature switched mode power supplies such as adapters, lighting PARAMETER VALUE UNIT IF 3 A VRRM 45 V IFSM 50 A TJ MAX 150 °C Package DO-214AC (SMA) Configuration Single die MECHANICAL DATA ● ● ● ● ● ● Case: DO-214AC (SMA) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.060g (approximately) DO-214AC (SMA) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device TSSA3U45 UNIT 3U45 Repetitive peak reverse voltage VRRM 45 V Reverse voltage, total rms value VR(RMS) 31 V Forward current Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load Junction temperature IF 3 A IFSM 50 A TJ - 55 to +150 °C Storage temperature TSTG - 55 to +150 °C 1 Version: O2102 TSSA3U45 Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-lead thermal resistance RӨJL 10 °C/W Junction-to-ambient thermal resistance RӨJA 70 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS IF = 3A, TJ = 25°C (1) Reverse current @ rated VR IF = 3A, TJ = 125°C (2) TJ = 25°C SYMBOL VF IR TJ = 125°C TYP MAX UNIT 0.42 0.48 V 0.30 0.40 V - 500 µA 50 100 mA Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE PACKAGE PACKING TSSA3U45 DO-214AC (SMA) 7,500 / Tape & Reel 2 Version: O2102 TSSA3U45 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 10000 3 CAPACITANCE (pF) 2 1 1000 100 f=1.0MHz Vsig=50mVp-p 0 10 25 50 75 100 125 150 0.1 LEAD TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) TJ=150°C 10 TJ=100°C 0.1 TJ=25°C 10 20 30 40 50 60 70 80 100 Fig.4 Typical Forward Characteristics 100 0.01 10 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 1 1 90 100 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 10 10 1 1 0.1 TJ=150°C UF1DLW TJ=125°C TJ=125°C TJ=100°C TJ=25°C (A) AVERAGE FORWARD CURRENT (A) 4 TJ=25°C 0.01 0.1 0.001 0.0 0.1 0.2 0.3 0.3 0.4 0.5 0.6 Pulse width 300μs 1% duty cycle Pulse width 0.4 0.7 0.5 0.8 0.6 0.9 0.7 1 1.1 FORWARD VOLTAGE (V) 3 Version: O2102 1.2 TSSA3U45 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-214AC (SMA) SUGGESTED PAD LAYOUT MARKING DIAGRAM 4 P/N = Marking Code G = Green Compound YW = Date Code F = Factory Code Version: O2102 TSSA3U45 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: O2102
TSSA3U45 M2G
物料型号为TSSA3U45,由台湾半导体制造。
以下是该器件的详细信息:
1. 器件简介: - 采用专利的沟槽肖特基技术。
- 低功耗、高效率。
- 高浪涌电流承受能力。
- 符合RoHS标准。
- 无卤素,符合IEC 61249-2-21标准。
2. 引脚分配: - 封装类型为DO-214AC(SMA),具有阴极和阳极两个引脚。
3. 参数特性: - 正向电流(IF):3A。
- 反向电压(VRRM):45V。
- 浪涌电流(IFSM):50A。
- 最高结温(TJMAX):150°C。
- 封装:DO-214AC(SMA)。
- 配置:单芯片。
4. 功能详解: - 专为高频微型开关电源设计,如适配器、照明。
5. 应用信息: - 用于高频率的微型开关电源,例如电源适配器和照明设备。
6. 封装信息: - 封装尺寸:DO-214AC(SMA),详细尺寸数据和建议的焊盘布局已提供。
此外,文档还提供了器件的热性能参数、电特性规格、特性曲线图、封装外形尺寸和建议的标记图。
规格受版权保护,使用时需遵守相关条款。
TSSA3U45 M2G 价格&库存
很抱歉,暂时无法提供与“TSSA3U45 M2G”相匹配的价格&库存,您可以联系我们找货
