ESH2BA – ESH2DA
Taiwan Semiconductor
1A, 100V - 200V Ultra Fast Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Low power loss, high efficiency
Ideal for automated placement
Ultra Fast recovery time for high efficiency
High surge current capability
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
1
A
VRRM
100 - 200
V
IFSM
50
A
TJ MAX
175
°C
APPLICATIONS
Package
DO-214AC (SMA)
Configuration
Single die
DC to DC converter
Switching mode converters and inverters
Lighting application
Snubber
Freewheeling application
MECHANICAL DATA
Case: DO-214AC (SMA)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.070g (approximately)
DO-214AC (SMA)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
ESH2BA
ESH2CA
ESH2DA UNIT
ESH2BA
ESH2CA
ESH2DA
Repetitive peak reverse voltage
VRRM
100
150
200
V
Reverse voltage, total rms value
VR(RMS)
70
105
140
V
Forward current
Peak forward surge current, 8.3ms single half
sine-wave superimposed on rated load
Pulse energy in avalanche mode, non-repetitive
(inductive load switch off), L = 120mH
Junction temperature
Storage temperature
IF
1
A
IFSM
50
A
ERSM
mJ
TJ
- 55 to +175
°C
TSTG
- 55 to +175
°C
1
Version: F2102
ESH2BA – ESH2DA
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-lead thermal resistance
RӨJL
°C/W
Junction-to-ambient thermal resistance
RӨJA
75
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
(1)
IF = 1A, TJ = 25°C
SYMBOL
TYP
MAX
UNIT
VF
0.9
V
1
µA
10
µA
50
µA
CJ
25
pF
trr
25
ns
TJ = 25°C
Reverse current @ rated VR
(2)
TJ = 100°C
IR
TJ = 125°C
Junction capacitance
Reverse recovery time
1MHz, VR = 4.0V
IF = 0.5A, IR = 1.0A,
Irr = 0.25A
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
ESH2xA
DO-214AC (SMA)
7,500 / Tape & Reel
Notes:
1. “x” defines voltage from 100V(ESH2BA) to 200V(ESH2DA)
2
Version: F2102
ESH2BA – ESH2DA
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
60
50
CAPACITANCE (pF)
1
40
30
50
75
100
125
150
f=1.0MHz
Vsig=50mVp-p
0.1
1
LEAD TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
10
TJ=125°C
1
TJ=75°C
0.1
TJ=25°C
10
40
50
60
70
80
100
Fig.4 Typical Forward Characteristics
100
90
100
100 10
10
UF1DLW
1
TJ=125°C
TJ=25°C
0.1
1
0.01
0.1
0.001
0.6
0.8
0.3
0.4
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Pulse width 300μs
1% duty cyclePulse width
1.0
0.5
1.2
1.4
0.6
0.7
0.8
1.6
0.9
1.8
1
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
60
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (μA)
Fig.3 Typical Reverse Characteristics
0.01
10
REVERSE VOLTAGE (V)
(A)
AVERAGE FORWARD CURRENT (A)
2
8.3ms single half sine wave
50
40
30
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: F2102
1.2
ESH2BA – ESH2DA
Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram
4
Version: F2102
ESH2BA – ESH2DA
PACKAGE OUTLINE DIMENSIONS
DO-214AC (SMA)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Version: F2102
ESH2BA – ESH2DA
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: F2102
很抱歉,暂时无法提供与“ESH2CA M2G”相匹配的价格&库存,您可以联系我们找货
