S3KB M4G
S3KB M4G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO214AA
    DIODE GEN PURP 800V 3A DO214AA
S3KB M4G 数据手册
S3AB – S3MB Taiwan Semiconductor 3A, 50V - 1000V Standard Surface Mount Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS Glass passivated chip junction Ideal for automated placement Low forward voltage drop High surge current capability Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS ● ● ● ● PARAMETER VALUE UNIT IF 3 A VRRM 50 - 1000 V IFSM 80 A TJ MAX 150 °C Package DO-214AA (SMB) Configuration Single die Switching mode power supply (SMPS) Adapters Lighting application Converter MECHANICAL DATA ● ● ● ● ● ● Case: DO-214AA (SMB) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.090g (approximately) DO-214AA (SMB) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) Repetitive peak reverse voltage VRRM S3 AB S3 AB 50 Reverse voltage, total rms value VR(RMS) 35 PARAMETER SYMBOL Marking code on the device S3 BB S3 BB 100 S3 DB S3 DB 200 S3 GB S3 GB 400 S3 JB S3 JB 600 S3 KB S3 KB 800 S3 MB S3 MB 1000 70 140 280 420 560 700 UNIT V V Forward current Surge peak forward current, 8.3ms single half sine-wave superimposed on rated load Junction temperature IF 3 A IFSM 80 A TJ - 55 to +150 °C Storage temperature TSTG - 55 to +150 °C 1 Version: M2102 S3AB – S3MB Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJL 10 °C/W Junction-to-lead thermal resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS (1) Reverse current @ rated VR IF = 3A, TJ = 25°C (2) Junction capacitance Reverse recovery time TJ = 25°C TJ = 125°C 1MHz, VR = 4.0V IF = 0.5A, IR = 1.0A Irr = 0.25A SYMBOL TYP MAX UNIT VF - 1.15 V - 10 µA - 250 µA CJ 40 - pF trr 1500 - ns IR Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING S3xB DO-214AA (SMB) 3,000 / Tape & Reel Notes: 1. "x" defines voltage from 50V(S3AB) to 1000V(S3MB) 2 Version: M2102 S3AB – S3MB Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 100 3 CAPACITANCE (pF) AVERAGE FORWARD CURRENT (A) 4 2 1 0 25 50 75 100 125 10 f=1.0MHz Vsig=50mVp-p 1 150 1 10 REVERSE VOLTAGE (V) LEAD TEMPERATURE (°C) Fig.3 Typical Reverse Characteristics Fig.4 Typical Forward Characteristics 10 TJ=125°C 1 TJ=25°C 0.1 20 30 40 50 60 70 80 90 100 100 10 10 TJ=125°C TJ=25°C 0.1 1 0.01 0.001 0.3 0.1 0.7 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) UF1DLW 1 (A) INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (μA) 100 10 100 0.4 0.8 0.9 0.5 0.6 1 1.1 0.7 1.2 Pulse width Pulse Width=300μs 1% Duty 0.8 0.9 Cycle 1 1.1 1.3 1.4 1.5 1.6 FORWARD VOLTAGE (V) 3 Version: M2102 1.2 S3AB – S3MB Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.5 Maximum Non-Repetitive Forward Surge Current PEAK FORWARD SURGE CURRENT (A) 100 8.3ms single half sine wave 80 60 40 20 0 1 10 100 NUMBER OF CYCLES AT 60 Hz Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: M2102 S3AB – S3MB Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-214AA (SMB) SUGGESTED PAD LAYOUT MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YW = Date Code F = Factory Code Version: M2102 S3AB – S3MB Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: M2102
S3KB M4G 价格&库存
很抱歉,暂时无法提供与“S3KB M4G”相匹配的价格&库存,您可以联系我们找货
