UG5J
Taiwan Semiconductor
5A, 600V Ultra Fast Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
High efficiency, low VF
High current capability
High reliability
High surge current capability
Low power loss
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
5
A
VRRM
600
V
IFSM
65
A
TJ MAX
150
°C
Package
TO-220AC
Configuration
Single die
APPLICATIONS
● DC to DC converter
● Switching mode converters and inverters
● Freewheeling application
MECHANICAL DATA
Case: TO-220AC
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Mounting torque: 0.56 N⋅m maximum
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.80g (approximately)
TO-220AC
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
UG5J
UNIT
UG5J
Repetitive peak reverse voltage
VRRM
600
V
Reverse voltage, total rms value
VR(RMS)
420
V
Forward current
Surge peak forward current 8.3ms single half sine
wave superimposed on rated load
Junction temperature
IF
5
A
IFSM
65
A
TJ
-55 to +150
°C
Storage temperature
TSTG
-55 to +150
°C
1
Version: J2103
UG5J
THERMAL PERFORMANCE
PARAMETER
Junction-to-case resistance
SYMBOL
TYP
UNIT
RӨJC
3
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
IF = 5A, TJ = 25°C
(1)
Reverse current @ rated VR
IF = 5A, TJ = 125°C
(2)
Reverse recovery time
TJ = 25°C
TJ = 125°C
IF = 0.5A, IR = 1.0A
Irr = 0.25A
SYMBOL
VF
IR
trr
TYP
MAX
UNIT
3.0
V
2.5
V
30
µA
200
µA
ns
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
UG5J
TO-220AC
50 / Tube
UG5JH
TO-220AC
50 / Tube
Notes:
1. “H” means AEC-Q101 qualified
2
Version: J2103
UG5J
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
1000
5
CAPACITANCE (pF)
AVERAGE FORWARD CURRENT (A)
6
4
3
2
100
1
f=1.0MHz
Vsig=50mVp-p
25
50
75
100
125
150
0.1
1
CASE TEMPERATURE (°C)
TJ=125°C
0.1
TJ=25°C
0.001
10
40
50
60
70
80
90
100
10
10
1
UF1DLW
TJ=125°C
TJ=125°C
TJ=25°C
10.1
(A)
INSTANTANEOUS FORWARD CURRENT (A)
10
0.01
TJ=25°C
Pulse width
0.001
0.1
0.40.3 0.6 0.40.8 0.51
0.6
1.2
0.7 1.6
0.8 1.80.9 2
1.4
12.2 1.1
FORWARD VOLTAGE (V)
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Fig.5 Maximum Non-Repetitive Forward Surge Current
70
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (uA)
Fig.4 Typical Forward Characteristics
100
0.01
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
1
10
60
50
40
30
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: J2103
1.2
UG5J
Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram
4
Version: J2103
UG5J
PACKAGE OUTLINE DIMENSIONS
TO-220AC
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: J2103
UG5J
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: J2103
很抱歉,暂时无法提供与“UG5JHC0G”相匹配的价格&库存,您可以联系我们找货
