UG12JHC0G
UG12JHC0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-220-2
    DIODE GEN PURP 600V 12A TO220AC
UG12JHC0G 数据手册
UG12J Taiwan Semiconductor 12A, 600V Ultra Fast Rectifier FEATURES ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Ultra Fast, low VF High current capability High reliability High surge current capability Low power loss RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 12 A VRRM 600 V IFSM 135 A TJ MAX 150 °C Package TO-220AC Configuration Single die APPLICATIONS ● DC to DC converter ● Switching mode converters and inverters ● Freewheeling application MECHANICAL DATA ● ● ● ● ● ● ● Case: TO-220AC Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Mounting torque: 0.56 N⋅m maximum Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 1.80g (approximately) TO-220AC ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device UG12J UNIT UG12J Repetitive peak reverse voltage VRRM 600 V Reverse voltage, total rms value VR(RMS) 420 V Forward current Surge peak forward current 8.3ms single half sine wave superimposed on rated load Junction temperature IF 12 A IFSM 135 A TJ -55 to +150 °C Storage temperature TSTG -55 to +150 °C 1 Version: D2103 UG12J Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER Junction-to-case resistance SYMBOL TYP UNIT RӨJC 3 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS (1) Reverse current @ rated VR IF = 12A, TJ = 25°C (2) Reverse recovery time TJ = 25°C TJ = 125°C IF = 0.5A, IR = 1.0A Irr = 0.25A SYMBOL TYP MAX UNIT VF - 2 V - 5 µA - 600 µA - 20 ns IR trr Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING UG12J TO-220AC 50 / Tube UG12JH TO-220AC 50 / Tube Notes: 1. “H” means AEC-Q101 qualified 2 Version: D2103 UG12J Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 12 10 CAPACITANCE (pF) 8 6 4 100 2 0 25 50 75 100 125 f=1.0MHz Vsig=50mVp-p 10 150 0.1 1 CASE TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=125°C 1 0.1 0.01 TJ=25°C 0.001 30 40 50 60 70 80 90 100 100 10 1 10 0.1 UF1DLW TJ=125°C TJ=25°C TJ=125°C 1 0.01 TJ=25°C Pulse width 0.001 0.1 0.20.3 0.40.4 0.60.5 0.8 0.6 1 0.71.2 0.81.4 0.91.6 11.8 1.1 FORWARD VOLTAGE (V) PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Fig.5 Maximum Non-Repetitive Forward Surge Current 150 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (uA) Fig.4 Typical Forward Characteristics 10 20 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 10 10 (A) AVERAGE FORWARD CURRENT (A) 14 135 120 105 90 75 60 45 30 15 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: D2103 1.2 UG12J Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: D2103 UG12J Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS TO-220AC MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: D2103 UG12J Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: D2103
UG12JHC0G 价格&库存
很抱歉,暂时无法提供与“UG12JHC0G”相匹配的价格&库存,您可以联系我们找货
