SK215AHR3G
SK215AHR3G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO-214AC
    DIODE SCHOTTKY 150V 2A DO214AC
SK215AHR3G 数据手册
SK22A – SK215A Taiwan Semiconductor 2A, 20V - 150V Schottky Barrier Surface Mount Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS Low power loss, high efficiency Ideal for automated placement Guard ring for over-voltage protection High surge current capability Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 2 A VRRM 20 - 150 V IFSM 50 A TJ MAX 125, 150 °C APPLICATIONS ● ● ● ● Package DO-214AC (SMA) Configuration Single die Switching mode power supply (SMPS) Adapters Lighting application Converter MECHANICAL DATA ● ● ● ● ● ● Case: DO-214AC (SMA) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.070g (approximately) DO-214AC (SMA) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) Repetitive peak reverse voltage VRRM SK 22A SK 22A 20 Reverse voltage, total rms value VR(RMS) 14 PARAMETER SYMBOL Marking code on the device Forward current Surge peak forward current, 8.3ms single half sine-wave superimposed on rated load Non-repetitive peak reverse avalanche energy, L = 40mH Critical rate of rise of off-state voltage Junction temperature Storage temperature SK 23A SK 23A 30 SK 24A SK 24A 40 SK 25A SK 25A 50 SK 26A SK 26A 60 21 28 35 42 SK SK SK UNIT 29A 210A 215A SK SK SK 29A 210A 215A 90 100 150 V 63 70 105 V IF 2 A IFSM 50 A ERSM 20 mJ dV/dt 10,000 V/µs TJ - 55 to +125 TSTG - 55 to +150 - 55 to +150 1 °C °C Version: Q2102 SK22A – SK215A Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER Junction-to-ambient thermal resistance SYMBOL TYP UNIT RӨJA 88 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS (1) Reverse current @ rated VR Reverse current @ rated VR Reverse current @ rated VR (2) (2) (2) SK22A SK23A SK24A SK25A SK26A SK29A SK210A SK215A SK22A SK23A SK24A SK25A SK26A SK29A SK210A SK215A SK22A SK23A SK24A SK25A SK26A SK29A SK210A SK215A SK22A SK23A SK24A SK25A SK26A SK29A SK210A SK215A IF = 2A, TJ = 25°C TJ = 25°C SYMBOL VF TYP MAX UNIT - 0.50 V - 0.70 V - 0.85 V - 0.95 V - 0.5 mA - 0.1 mA - 10 mA - 5 mA - - mA - - mA - 2 mA IR TJ = 100°C IR TJ = 125°C IR Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING SK2xA DO-214AC (SMA) 7,500 / Tape & Reel Notes: 1. “x” defines voltage from 20V(SK22A) to 150V(SK215A) 2 Version: Q2102 SK22A – SK215A Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 SK22A - SK26A CAPACITANCE (pF) 2 SK22A - SK25A 1 100 SK29A - SK215A 10 SK26A - SK215A 0 25 50 75 100 125 f=1.0MHz Vsig=50mVp-p 1 150 0.1 1 LEAD TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) 10 TJ=125°C 1 TJ=75°C 0.1 0.01 TJ=25°C 0.001 100 Fig.4 Typical Forward Characteristics 100 10 20 30 40 50 60 70 80 90 100 110 120 100 10 SK22A - SK24A 10 1 UF1DLW SK25A - SK26A TJ=125°C TJ=25°C 0.1 SK215A 1 SK29A - SK210A 0.01 0.1 0.001 0.1 0.3 0.5 0.7 0.3 0.4 0.5 0.6 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Pulse width 300μs 1% duty cyclePulse width 0.9 0.7 1.1 0.8 1.3 0.9 1.5 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 50 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.3 Typical Reverse Characteristics SK22A - SK24A SK25A - SK26A SK29A - SK215A 10 REVERSE VOLTAGE (V) (A) AVERAGE FORWARD CURRENT (A) 3 8.3ms single half sine wave 40 30 20 10 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: Q2102 1.2 SK22A – SK215A Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Typical Transient Thermal Characteristics TRANSIENT THERMAL IMPEDANCE (°C/W) 100 10 1 0.01 0.1 1 10 100 PULSE DURATION (s) 4 Version: Q2102 SK22A – SK215A Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-214AC (SMA) SUGGESTED PAD LAYOUT MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YW = Date Code F = Factory Code Version: Q2102 SK22A – SK215A Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: Q2102
SK215AHR3G 价格&库存
很抱歉,暂时无法提供与“SK215AHR3G”相匹配的价格&库存,您可以联系我们找货
