MC912DT128ACPV
MC912DT128ACPV
    ROCHESTER(罗切斯特)
    LQFP112
    IC MCU 16BIT 128KB FLASH 112LQFP
MC912DT128ACPV 数据手册
MC68HC912DT128A MC68HC912DG128A MC68HC912DT128C MC68HC912DG128C MC68HC912DT128P MC68HC912DG128P Technical Data M68HC12 Microcontrollers MC912DT128A/D Rev. 4, 10/2003 MOTOROLA.COM/SEMICONDUCTORS MC68HC912DT128A MC68HC912DG128A MC68HC912DT128C MC68HC912DG128C MC68HC912DT128P MC68HC912DG128P Technical Data Rev 4.0 Motorola reserves the right to make changes without further notice to any products herein. Motorola makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does Motorola assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation consequential or incidental damages. "Typical" parameters which may be provided in Motorola data sheets and/or specifications can and do vary in different applications and actual performance may vary over time. All operating parameters, including "Typicals" must be validated for each customer application by customer's technical experts. Motorola does not convey any license under its patent rights nor the rights of others. Motorola products are not designed, intended, or authorized for use as components in systems intended for surgical implant into the body, or other applications intended to support or sustain life, or for any other application in which the failure of the Motorola product could create a situation where personal injury or death may occur. Should Buyer purchase or use Motorola products for any such unintended or unauthorized application, Buyer shall indemnify and hold Motorola and its officers, employees, subsidiaries, affiliates, and distributors harmless against all claims, costs, damages, and expenses, and reasonable attorney fees arising out of, directly or indirectly, any claim of personal injury or death associated with such unintended or unauthorized use, even if such claim alleges that Motorola was negligent regarding the design or manufacture of the part. Motorola, Inc. is an Equal Opportunity/Affirmative Action Employer. Motorola and are registered trademarks of Motorola, Inc. DigitalDNA is a trademark of Motorola, Inc. MC68HC912DT128A — Rev 4.0 MOTOROLA © Motorola, Inc., 2003 Technical Data 3 Technical Data 4 MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data — MC68HC912DT128A List of Paragraphs Technical Data — List of Paragraphs . . . . . . . . . . . . . . . . 5 Technical Data — Table of Contents. . . . . . . . . . . . . . . . . 7 Technical Data — List of Figures . . . . . . . . . . . . . . . . . . 17 Technical Data — List of Tables . . . . . . . . . . . . . . . . . . . 21 Section 1. General Description . . . . . . . . . . . . . . . . . . . . 25 Section 2. Central Processing Unit . . . . . . . . . . . . . . . . . 35 Section 3. Pinout and Signal Descriptions . . . . . . . . . . . 41 Section 4. Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 67 Section 5. Operating Modes. . . . . . . . . . . . . . . . . . . . . . . 79 Section 6. Resource Mapping . . . . . . . . . . . . . . . . . . . . . 87 Section 7. Bus Control and Input/Output . . . . . . . . . . . 103 Section 8. Flash Memory . . . . . . . . . . . . . . . . . . . . . . . . 115 Section 9. EEPROM Memory . . . . . . . . . . . . . . . . . . . . . 123 Section 10. Resets and Interrupts . . . . . . . . . . . . . . . . . 137 Section 11. I/O Ports with Key Wake-up . . . . . . . . . . . . 149 Section 12. Clock Functions . . . . . . . . . . . . . . . . . . . . . 157 Section 13. Oscillator . . . . . . . . . . . . . . . . . . . . . . . . . . . 193 Section 14. Pulse Width Modulator . . . . . . . . . . . . . . . . 225 Section 15. Enhanced Capture Timer . . . . . . . . . . . . . . 241 Section 16. Multiple Serial Interface . . . . . . . . . . . . . . . 277 MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data List of Paragraphs 5 List of Paragraphs Section 17. Inter IC Bus . . . . . . . . . . . . . . . . . . . . . . . . . 301 Section 18. MSCAN Controller . . . . . . . . . . . . . . . . . . . . 325 Section 19. Analog-to-Digital Converter . . . . . . . . . . . . 367 Section 20. Development Support. . . . . . . . . . . . . . . . . 395 Section 21. Electrical Specifications. . . . . . . . . . . . . . . 421 Section 22. Appendix: Changes from MC68HC912DG128 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 441 Section 23. Appendix: CGM Practical Aspects . . . . . . 447 Section 24. Appendix: Information on MC68HC912DT128A Mask Set Changes . . . . . . . . . . . . 457 Technical Data — Glossary . . . . . . . . . . . . . . . . . . . . . . 461 Technical Data — Revision History . . . . . . . . . . . . . . . . 473 Technical Data 6 MC68HC912DT128A — Rev 4.0 List of Paragraphs MOTOROLA Technical Data — MC68HC912DT128A Table of Contents List of Paragraphs Table of Contents List of Figures List of Tables Section 1. General Description 1.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .25 1.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 25 1.3 Devices Covered in this Document. . . . . . . . . . . . . . . . . . . . . .26 1.4 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 26 1.5 MC68HC912DT128A Block Diagram . . . . . . . . . . . . . . . . . . . . 30 1.6 MC68HC912DG128A Block Diagram. . . . . . . . . . . . . . . . . . . . 31 1.7 Ordering Information. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 32 Section 2. Central Processing Unit 2.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .35 2.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 35 2.3 Programming Model . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 36 2.4 Data Types . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 37 2.5 Addressing Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .38 2.6 Indexed Addressing Modes . . . . . . . . . . . . . . . . . . . . . . . . . . .39 MC68HC912DT128A — Rev 4.0 Technical Data MOTOROLA Table of Contents 7 Table of Contents 2.7 Opcodes and Operands . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 40 Section 3. Pinout and Signal Descriptions 3.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .41 3.2 MC68HC912DT128A Pin Assignments in 112-pin QFP. . . . . . 41 3.3 Power Supply Pins . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .45 3.4 Signal Descriptions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 47 3.5 Port Signals . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .56 Section 4. Registers 4.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .67 4.2 Register Block. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .67 Section 5. Operating Modes 5.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .79 5.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 79 5.3 Operating Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 79 5.4 Background Debug Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . .84 Section 6. Resource Mapping 6.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .87 6.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 87 6.3 Internal Resource Mapping. . . . . . . . . . . . . . . . . . . . . . . . . . . .87 6.4 Flash EEPROM mapping through internal Memory Expansion 92 6.5 Miscellaneous System Control Register . . . . . . . . . . . . . . . . . . 96 6.6 Mapping test registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .99 6.7 Memory Maps . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .100 Technical Data 8 MC68HC912DT128A — Rev 4.0 Table of Contents MOTOROLA Table of Contents Section 7. Bus Control and Input/Output 7.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .103 7.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 103 7.3 Detecting Access Type from External Signals . . . . . . . . . . . .103 7.4 Registers. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .104 Section 8. Flash Memory 8.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .115 8.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 115 8.3 Overview. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .116 8.4 Flash EEPROM Control Block . . . . . . . . . . . . . . . . . . . . . . . .116 8.5 Flash EEPROM Arrays . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .116 8.6 Flash EEPROM Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . 117 8.7 Operation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .119 8.8 Programming the Flash EEPROM . . . . . . . . . . . . . . . . . . . . . 120 8.9 Erasing the Flash EEPROM . . . . . . . . . . . . . . . . . . . . . . . . . . 121 8.10 Stop or Wait Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .121 8.11 Flash protection bit FPOPEN . . . . . . . . . . . . . . . . . . . . . . . . .122 Section 9. EEPROM Memory 9.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .123 9.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 123 9.3 EEPROM Selective Write More Zeros . . . . . . . . . . . . . . . . . .124 9.4 EEPROM Programmer’s Model . . . . . . . . . . . . . . . . . . . . . . .125 9.5 EEPROM Control Registers . . . . . . . . . . . . . . . . . . . . . . . . . . 126 9.6 Program/Erase Operation. . . . . . . . . . . . . . . . . . . . . . . . . . . .133 9.7 Shadow Word Mapping . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 134 MC68HC912DT128A — Rev 4.0 Technical Data MOTOROLA Table of Contents 9 Table of Contents 9.8 Programming EEDIVH and EEDIVL Registers. . . . . . . . . . . . 135 Section 10. Resets and Interrupts 10.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .137 10.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 137 10.3 Exception Priority . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 138 10.4 Maskable interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .138 10.5 Latching of Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .139 10.6 Interrupt Control and Priority Registers . . . . . . . . . . . . . . . . .141 10.7 Interrupt test registers. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 142 10.8 Resets. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .143 10.9 Effects of Reset . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 145 10.10 Register Stacking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 147 Section 11. I/O Ports with Key Wake-up 11.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .149 11.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 149 11.3 Key Wake-up and port Registers . . . . . . . . . . . . . . . . . . . . . . 150 11.4 Key Wake-Up Input Filter . . . . . . . . . . . . . . . . . . . . . . . . . . . . 154 Section 12. Clock Functions 12.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .157 12.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 157 12.3 Clock Sources. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .158 12.4 Phase-Locked Loop (PLL) . . . . . . . . . . . . . . . . . . . . . . . . . . . 159 12.5 Acquisition and Tracking Modes. . . . . . . . . . . . . . . . . . . . . . .161 12.6 Limp-Home and Fast STOP Recovery modes . . . . . . . . . . . . 163 Technical Data 10 MC68HC912DT128A — Rev 4.0 Table of Contents MOTOROLA Table of Contents 12.7 System Clock Frequency Formulae . . . . . . . . . . . . . . . . . . . . 181 12.8 Clock Divider Chains . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .182 12.9 Computer Operating Properly (COP) . . . . . . . . . . . . . . . . . . .185 12.10 Real-Time Interrupt. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 186 12.11 Clock Monitor . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .186 12.12 Clock Function Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 187 Section 13. Oscillator 13.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .193 13.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 193 13.3 MC68HC912DT128A Oscillator Specification . . . . . . . . . . . .194 13.4 MC68HC912Dx128C Colpitts Oscillator Specification . . . . . . 197 13.5 MC68HC912Dx128P Pierce Oscillator Specification . . . . . . . 212 Section 14. Pulse Width Modulator 14.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .225 14.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 225 14.3 PWM Register Descriptions . . . . . . . . . . . . . . . . . . . . . . . . . .229 14.4 PWM Boundary Cases . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .240 Section 15. Enhanced Capture Timer 15.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .241 15.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 241 15.3 Enhanced Capture Timer Modes of Operation . . . . . . . . . . . . 247 15.4 Timer Register Descriptions . . . . . . . . . . . . . . . . . . . . . . . . . . 251 15.5 Timer and Modulus Counter Operation in Different Modes . . 275 Section 16. Multiple Serial Interface MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Table of Contents 11 Table of Contents 16.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .277 16.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 277 16.3 Block diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .278 16.4 Serial Communication Interface (SCI) . . . . . . . . . . . . . . . . . .278 16.5 Serial Peripheral Interface (SPI) . . . . . . . . . . . . . . . . . . . . . . .289 16.6 Port S . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 299 Section 17. Inter IC Bus 17.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .301 17.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 301 17.3 IIC Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .302 17.4 IIC System Configuration . . . . . . . . . . . . . . . . . . . . . . . . . . . . 304 17.5 IIC Protocol . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 304 17.6 IIC Register Descriptions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 309 17.7 IIC Programming Examples . . . . . . . . . . . . . . . . . . . . . . . . . .318 Section 18. MSCAN Controller 18.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .325 18.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 325 18.3 External Pins. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 326 18.4 Message Storage . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 327 18.5 Identifier Acceptance Filter . . . . . . . . . . . . . . . . . . . . . . . . . . .332 18.6 Interrupts. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .335 18.7 Protocol Violation Protection. . . . . . . . . . . . . . . . . . . . . . . . . . 337 18.8 Low Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .338 18.9 Timer Link . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 342 18.10 Clock System . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .343 Technical Data 12 MC68HC912DT128A — Rev 4.0 Table of Contents MOTOROLA Table of Contents 18.11 Memory Map. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 345 18.12 Programmer’s Model of Message Storage . . . . . . . . . . . . . . .346 18.13 Programmer’s Model of Control Registers . . . . . . . . . . . . . . . 351 Section 19. Analog-to-Digital Converter 19.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .367 19.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 367 19.3 Modes of Operation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .369 19.4 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .370 19.5 ATD Operational Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . .372 19.6 ATD Operation In Different MCU Modes . . . . . . . . . . . . . . . . 373 19.7 General Purpose Digital Input Port Operation . . . . . . . . . . . .375 19.8 Application Considerations . . . . . . . . . . . . . . . . . . . . . . . . . . .376 19.9 ATD Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 376 Section 20. Development Support 20.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .395 20.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 395 20.3 Instruction Queue . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .395 20.4 Background Debug Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . .397 20.5 Breakpoints. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 412 20.6 Instruction Tagging . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 419 Section 21. Electrical Specifications 21.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .421 21.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 421 21.3 Tables of Data . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 422 MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Table of Contents 13 Table of Contents Section 22. Appendix: Changes from MC68HC912DG128 22.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .441 22.2 Significant changes from the MC68HC912DG128 (non-suffix device)441 Section 23. Appendix: CGM Practical Aspects 23.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .447 23.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 447 23.3 Practical Aspects For The PLL Usage . . . . . . . . . . . . . . . . . .447 23.4 Printed Circuit Board Guidelines. . . . . . . . . . . . . . . . . . . . . . .453 Section 24. Appendix: Information on MC68HC912DT128A Mask Set Changes 24.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .457 24.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 457 24.3 Oscillator – Major Changes . . . . . . . . . . . . . . . . . . . . . . . . . .457 24.4 Flash Protection Feature . . . . . . . . . . . . . . . . . . . . . . . . . . . . 458 24.5 Clock Circuitry. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .458 24.6 Pseudo Stop Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 458 24.7 Oscillator – Minor Changes . . . . . . . . . . . . . . . . . . . . . . . . . .459 24.8 PLL . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 459 Technical Data — Glossary Technical Data — Revision History 24.9 Changes in Rev. 3.1 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 473 24.10 Changes from Rev 2.0 to Rev 3.0 . . . . . . . . . . . . . . . . . . . . . 473 24.11 Changes from Rev 1.0 to Rev 2.0 . . . . . . . . . . . . . . . . . . . . . 475 Technical Data 14 MC68HC912DT128A — Rev 4.0 Table of Contents MOTOROLA Table of Contents 24.12 Changes from first version (internal release, no revision number) to Rev 1.0 . . . . . . . . . . . . . . . . . . . . . . . . . .475 MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Table of Contents 15 Table of Contents Technical Data 16 MC68HC912DT128A — Rev 4.0 Table of Contents MOTOROLA Technical Data — MC68HC912DT128A List of Figures Figure 1-1 1-2 2-1 3-1 3-2 3-3 3-4 3-5 6-1 6-2 11-1 12-1 12-2 12-3 12-4 12-5 12-6 12-7 12-8 12-9 13-1 13-2 13-3 13-4 14-1 14-2 14-3 15-1 15-2 Title MC68HC912DT128A Block Diagram . . . . . . . . . . . . . . . . . . . . 30 MC68HC912DG128A Block Diagram. . . . . . . . . . . . . . . . . . . . 31 Programming Model . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 36 Pin Assignments in 112-pin QFP for MC68HC912DT128A . . . 42 Pin Assignments in 112-pin QFP for MC68HC912DG128A . . .43 112-pin QFP Mechanical Dimensions (case no. 987) . . . . . . . 44 PLL Loop FIlter Connections . . . . . . . . . . . . . . . . . . . . . . . . . .46 External Oscillator Connections . . . . . . . . . . . . . . . . . . . . . . . .48 MC68HC912DT128A Memory Map after reset. . . . . . . . . . . . 100 MC68HC912DT128A Memory Paging . . . . . . . . . . . . . . . . . .101 STOP Key Wake-up Filter . . . . . . . . . . . . . . . . . . . . . . . . . . . 155 Internal Clock Relationships . . . . . . . . . . . . . . . . . . . . . . . . . . 159 PLL Functional Diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . .160 Clock Loss during Normal Operation . . . . . . . . . . . . . . . . . . .164 No Clock at Power-On Reset . . . . . . . . . . . . . . . . . . . . . . . . .166 STOP Exit and Fast STOP Recovery . . . . . . . . . . . . . . . . . . . 168 Clock Generation Chain . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 182 Clock Chain for SCI0, SCI1, RTI, COP. . . . . . . . . . . . . . . . . . 183 Clock Chain for ECT . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 184 Clock Chain for MSCAN, SPI, ATD0, ATD1 and BDM . . . . . . 185 MC68HC912DT128A Colpitts Oscillator Architecture. . . . . . .195 MC68HC912Dx128C Colpitts Oscillator Architecture. . . . . . .198 MC68HC912Dx128C Crystal with DC Blocking Capacitor . . . 210 MC68HC912Dx128P Pierce Oscillator Architecture. . . . . . . .213 Block Diagram of PWM Left-Aligned Output Channel . . . . . . 226 Block Diagram of PWM Center-Aligned Output Channel . . . . 227 PWM Clock Sources. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 228 Timer Block Diagram in Latch Mode. . . . . . . . . . . . . . . . . . . .243 Timer Block Diagram in Queue Mode. . . . . . . . . . . . . . . . . . . 244 MC68HC912DT128A — Rev 4.0 MOTOROLA Page Technical Data List of Figures 17 List of Figures 15-3 8-Bit Pulse Accumulators Block Diagram . . . . . . . . . . . . . . . .245 15-4 16-Bit Pulse Accumulators Block Diagram . . . . . . . . . . . . . . .246 15-5 Block Diagram for Port7 with Output compare / Pulse Accumulator A . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 247 15-6 C3F-C0F Interrupt Flag Setting . . . . . . . . . . . . . . . . . . . . . . .247 16-1 Multiple Serial Interface Block Diagram . . . . . . . . . . . . . . . . .278 16-2 Serial Communications Interface Block Diagram . . . . . . . . . . 279 16-3 Serial Peripheral Interface Block Diagram . . . . . . . . . . . . . . . 291 16-4 SPI Clock Format 0 (CPHA = 0) . . . . . . . . . . . . . . . . . . . . . . .292 16-5 SPI Clock Format 1 (CPHA = 1) . . . . . . . . . . . . . . . . . . . . . . .293 16-6 Normal Mode and Bidirectional Mode. . . . . . . . . . . . . . . . . . . 294 17-1 IIC Block Diagram. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .303 17-2 IIC Transmission Signals . . . . . . . . . . . . . . . . . . . . . . . . . . . . 304 17-3 IIC Clock Synchronization. . . . . . . . . . . . . . . . . . . . . . . . . . . .308 17-4 Flow-Chart of Typical IIC Interrupt Routine . . . . . . . . . . . . . . 323 18-1 The CAN System . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 327 18-2 User Model for Message Buffer Organization. . . . . . . . . . . . . 330 18-3 32-bit Maskable Identifier Acceptance Filters . . . . . . . . . . . . . 333 18-4 16-bit Maskable Acceptance Filters . . . . . . . . . . . . . . . . . . . . 333 18-5 8-bit Maskable Acceptance Filters . . . . . . . . . . . . . . . . . . . . . 334 18-6 SLEEP Request / Acknowledge Cycle . . . . . . . . . . . . . . . . . . 340 18-7 Clocking Scheme . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 343 18-8 Segments within the Bit Time . . . . . . . . . . . . . . . . . . . . . . . . . 344 18-9 CAN Standard Compliant Bit Time Segment Settings . . . . . . 345 18-10 msCAN12 Memory Map . . . . . . . . . . . . . . . . . . . . . . . . . . . . .345 18-11 Message Buffer Organization . . . . . . . . . . . . . . . . . . . . . . . . . 346 18-12 Receive/Transmit Message Buffer Extended Identifier. . . . . . 347 18-13 Standard Identifier Mapping . . . . . . . . . . . . . . . . . . . . . . . . . .348 18-14 Identifier Acceptance Registers (1st bank) . . . . . . . . . . . . . . .364 18-15 Identifier Acceptance Registers (2nd bank) . . . . . . . . . . . . . . 364 18-16 Identifier Mask Registers (1st bank) . . . . . . . . . . . . . . . . . . . .365 18-17 Identifier Mask Registers (2nd bank) . . . . . . . . . . . . . . . . . . .365 19-1 Analog-to-Digital Converter Block Diagram . . . . . . . . . . . . . . 368 20-1 BDM Host to Target Serial Bit Timing. . . . . . . . . . . . . . . . . . . 399 20-2 BDM Target to Host Serial Bit Timing (Logic 1) . . . . . . . . . . .399 20-3 BDM Target to Host Serial Bit Timing (Logic 0) . . . . . . . . . . .400 21-1 Timer Inputs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .429 21-2 POR and External Reset Timing Diagram . . . . . . . . . . . . . . . 430 Technical Data 18 MC68HC912DT128A — Rev 4.0 List of Figures MOTOROLA List of Figures 21-3 21-4 21-5 21-6 21-7 21-8 21-9 21-9 21-9 21-10 STOP Recovery Timing Diagram . . . . . . . . . . . . . . . . . . . . . .431 WAIT Recovery Timing Diagram . . . . . . . . . . . . . . . . . . . . . . 432 Interrupt Timing Diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . 433 Port Read Timing Diagram . . . . . . . . . . . . . . . . . . . . . . . . . . .434 Port Write Timing Diagram . . . . . . . . . . . . . . . . . . . . . . . . . . .434 Multiplexed Expansion Bus Timing Diagram . . . . . . . . . . . . . 436 A) SPI Master Timing (CPHA = 0) . . . . . . . . . . . . . . . . . . . . . 438 B) SPI Master Timing (CPHA = 1) . . . . . . . . . . . . . . . . . . . . . 438 SPI Timing Diagram (1 of 2) . . . . . . . . . . . . . . . . . . . . . . . . . . 438 A) SPI Slave Timing (CPHA = 0) . . . . . . . . . . . . . . . . . . . . . . 439 B) SPI Slave Timing (CPHA = 1) . . . . . . . . . . . . . . . . . . . . . . 439 SPI Timing Diagram (2 of 2) . . . . . . . . . . . . . . . . . . . . . . . . . . 439 MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data List of Figures 19 List of Figures Technical Data 20 MC68HC912DT128A — Rev 4.0 List of Figures MOTOROLA Technical Data — MC68HC912DT128A List of Tables Table 1-1 1-2 2-1 2-2 3-1 3-2 3-3 3-4 4-1 5-1 6-1 6-2 6-3 6-4 6-5 6-6 7-1 9-1 9-2 9-3 9-4 10-1 10-2 12-1 12-2 12-3 12-4 12-5 Title Device Ordering Information. . . . . . . . . . . . . . . . . . . . . . . . . . . 32 Development Tools Ordering Information. . . . . . . . . . . . . . . . .33 M68HC12 Addressing Mode Summary . . . . . . . . . . . . . . . . . .38 Summary of Indexed Operations . . . . . . . . . . . . . . . . . . . . . . . 39 MC68HC912DT128A Power and Ground Connection Summary . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .47 MC68HC912DT128A Signal Description Summary . . . . . . . . .54 MC68HC912DT128A Port Description Summary. . . . . . . . . . . 64 Port Pull-Up, Pull-Down and Reduced Drive Summary . . . . . .65 Register Map . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .68 Mode Selection . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .80 Mapping Precedence . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .88 Program space Page Index . . . . . . . . . . . . . . . . . . . . . . . . . . .93 Flash Register space Page Index. . . . . . . . . . . . . . . . . . . . . . .93 Test mode program space Page Index. . . . . . . . . . . . . . . . . . . 94 RFSTR Stretch Bit Definition . . . . . . . . . . . . . . . . . . . . . . . . . .97 EXSTR Stretch Bit Definition . . . . . . . . . . . . . . . . . . . . . . . . . .98 Access Type vs. Bus Control Pins . . . . . . . . . . . . . . . . . . . . . 104 EEDIV Selection . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .127 2K byte EEPROM Block Protection . . . . . . . . . . . . . . . . . . . . 130 Erase Selection. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .131 Shadow word mapping . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .134 Interrupt Vector Map . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 140 Stacking Order on Entry to Interrupts . . . . . . . . . . . . . . . . . . . 147 Summary of STOP Mode Exit Conditions. . . . . . . . . . . . . . . .174 Summary of Pseudo STOP Mode Exit Conditions . . . . . . . . .174 Clock Monitor Time-Outs . . . . . . . . . . . . . . . . . . . . . . . . . . . . 186 Real Time Interrupt Rates. . . . . . . . . . . . . . . . . . . . . . . . . . . .188 COP Watchdog Rates . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .191 MC68HC912DT128A — Rev 4.0 MOTOROLA Page Technical Data List of Tables 21 List of Tables 14-1 14-2 14-3 15-1 15-2 15-3 16-1 16-2 16-3 16-4 17-1 17-2 18-1 18-2 18-3 18-4 18-5 18-6 18-7 18-8 18-9 19-1 19-2 19-3 19-4 19-5 19-6 19-7 19-8 19-9 19-10 20-1 20-2 20-3 20-4 20-5 20-6 Clock A and Clock B Prescaler. . . . . . . . . . . . . . . . . . . . . . . . 230 PWM Left-Aligned Boundary Conditions . . . . . . . . . . . . . . . . 240 PWM Center-Aligned Boundary Conditions . . . . . . . . . . . . . . 240 Compare Result Output Action . . . . . . . . . . . . . . . . . . . . . . . . 255 Edge Detector Circuit Configuration . . . . . . . . . . . . . . . . . . . .256 Prescaler Selection. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 258 Baud Rate Generation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .280 Loop Mode Functions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 283 SS Output Selection . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 293 SPI Clock Rate Selection . . . . . . . . . . . . . . . . . . . . . . . . . . . . 297 IIC Tap and Prescale Values . . . . . . . . . . . . . . . . . . . . . . . . .310 IIC Divider and SDA Hold values . . . . . . . . . . . . . . . . . . . . . . 311 msCAN12 Interrupt Vectors . . . . . . . . . . . . . . . . . . . . . . . . . .337 msCAN12 vs. CPU operating modes . . . . . . . . . . . . . . . . . . . 338 Data length codes. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .349 Synchronization jump width . . . . . . . . . . . . . . . . . . . . . . . . . .354 Baud rate prescaler . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .354 Time segment syntax . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .355 Time segment values . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .355 Identifier Acceptance Mode Settings . . . . . . . . . . . . . . . . . . .362 Identifier Acceptance Hit Indication . . . . . . . . . . . . . . . . . . . . 362 Result Data Formats Available . . . . . . . . . . . . . . . . . . . . . . . . 379 Left Justified ATD Output Codes . . . . . . . . . . . . . . . . . . . . . . 380 ATD Response to Background Debug Enable . . . . . . . . . . . . 382 Final Sample Time Selection . . . . . . . . . . . . . . . . . . . . . . . . .383 Clock Prescaler Values. . . . . . . . . . . . . . . . . . . . . . . . . . . . . .384 Conversion Sequence Length Coding . . . . . . . . . . . . . . . . . .385 Result Register Assignment for Different Conversion Sequences . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .385 Special Channel Conversion Select Coding . . . . . . . . . . . . . .386 Analog Input Channel Select Coding . . . . . . . . . . . . . . . . . . .387 Multichannel Mode Result Register Assignment (MULT=1) . .388 IPIPE Decoding . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 396 Hardware Commands. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 402 BDM Firmware Commands . . . . . . . . . . . . . . . . . . . . . . . . . .403 BDM registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .405 TTAGO Decoding . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .410 REGN Decoding . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .410 Technical Data 22 MC68HC912DT128A — Rev 4.0 List of Tables MOTOROLA List of Tables 20-7 20-8 20-9 20-10 21-1 21-2 21-3 21-4 21-5 21-6 21-7 21-8 21-9 21-10 21-11 21-12 21-13 21-14 21-15 21-16 21-17 21-18 23-1 Breakpoint Mode Control . . . . . . . . . . . . . . . . . . . . . . . . . . . . 415 Breakpoint Address Range Control . . . . . . . . . . . . . . . . . . . . 416 Breakpoint Read/Write Control . . . . . . . . . . . . . . . . . . . . . . . . 418 Tag Pin Function. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .420 Maximum Ratings . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .422 Thermal Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 423 DC Electrical Characteristics . . . . . . . . . . . . . . . . . . . . . . . . .424 Supply Current . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 425 ATD DC Electrical Characteristics . . . . . . . . . . . . . . . . . . . . . 425 Analog Converter Characteristics (Operating) . . . . . . . . . . . .426 ATD AC Characteristics (Operating). . . . . . . . . . . . . . . . . . . .426 ATD Maximum Ratings. . . . . . . . . . . . . . . . . . . . . . . . . . . . . .427 EEPROM Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . .427 Flash EEPROM Characteristics . . . . . . . . . . . . . . . . . . . . . . .428 Pulse Width Modulator Characteristics. . . . . . . . . . . . . . . . . . 428 Control Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 429 Peripheral Port Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .434 Multiplexed Expansion Bus Timing. . . . . . . . . . . . . . . . . . . . .435 SPI Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .437 CGM Characteristics. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 440 Oscillator Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . 440 STOP Key Wake-up Filter . . . . . . . . . . . . . . . . . . . . . . . . . . . 440 Suggested 8MHz Synthesis PLL Filter Elements (Tracking Mode) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 451 23-2 Suggested 8MHz Synthesis PLL Filter Elements (Acquisition Mode) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .452 MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data List of Tables 23 List of Tables Technical Data 24 MC68HC912DT128A — Rev 4.0 List of Tables MOTOROLA Technical Data — MC68HC912DT128A Section 1. General Description 1.1 Contents 1.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 25 1.3 Devices Covered in this Document. . . . . . . . . . . . . . . . . . . . . .26 1.4 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 26 1.5 MC68HC912DT128A Block Diagram . . . . . . . . . . . . . . . . . . . . 30 1.6 MC68HC912DG128A Block Diagram. . . . . . . . . . . . . . . . . . . . 31 1.7 Ordering Information. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 32 1.2 Introduction The MC68HC912DT128A microcontroller unit (MCU) is a 16-bit device composed of standard on-chip peripherals including a 16-bit central processing unit (CPU12), 128K bytes of flash EEPROM, 8K bytes of RAM, 2K bytes of EEPROM, two asynchronous serial communications interfaces (SCI), a serial peripheral interface (SPI), an inter-IC interface (I2C), an enhanced capture timer (ECT), two 8-channel, 10-bit analogto-digital converters (ADC), a four-channel pulse-width modulator (PWM), and three CAN 2.0 A, B software compatible modules (MSCAN12). System resource mapping, clock generation, interrupt control and bus interfacing are managed by the lite integration module (LIM). The MC68HC912DT128A has full 16-bit data paths throughout, however, the external bus can operate in an 8-bit narrow mode so single 8-bit wide memory can be interfaced for lower cost systems. The inclusion of a PLL circuit allows power consumption and performance to be adjusted to suit operational requirements. In addition to the I/O ports available in each module, 16 I/O ports are available with Key-Wake-Up capability from STOP or WAIT mode. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data General Description 25 General Description 1.3 Devices Covered in this Document The MC68HC912DG128A device is similar to the MC68HC912DT128A, but it has only two MSCAN12 modules. The entire databook applies to both devices, except where differences are noted. The MC68HC912DT128C and MC68HC912DT128P are devices similar to the MC68HC912DT128A, but with different oscillator configurations. Sections of this book applicable to the MC68HC912DT128A also apply to the MC68HC912DT128C and MC68HC912DT128P, except for the differences highlighted in Section 13. Oscillator. The MC68HC912DG128C and MC68HC912DG128P are devices similar to the MC68HC912DG128A, but with different oscillator configurations. Sections of this book applicable to the MC68HC912DG128A also apply to the MC68HC912DG128C and MC68HC912DG128P, except for the differences highlighted in Section 13. Oscillator. NOTE: The generic term MC68HC912DT128A is used throughout the document to mean all derivatives mentioned above, except in Section 13. Oscillator, where it refers only to the MC68HC912DT128A and MC68HC912DG128A devices. 1.4 Features • 16-bit CPU12 – Upward compatible with M68HC11 instruction set – Interrupt stacking and programmer’s model identical to M68HC11 – 20-bit ALU – Instruction queue – Enhanced indexed addressing • Multiplexed bus – Single chip or expanded – 16 address/16 data wide or 16 address/8 data narrow modes Technical Data 26 MC68HC912DT128A — Rev 4.0 General Description MOTOROLA General Description Features • Memory – 128K byte flash EEPROM, made of four 32K byte modules with 8K bytes protected BOOT section in each module – 2K byte EEPROM – 8K byte RAM with Vstby, made of two 4K byte modules. • Two Analog-to-digital converters – 2 times 8-channels, 10-bit resolution • Three 1M bit per second, CAN 2.0 A, B software compatible modules on the MC68HC912DT128A (two on the MC68HC912DG128A) – Two receive and three transmit buffers per CAN – Flexible identifier filter programmable as 2 x 32 bit, 4 x 16 bit or 8 x 8 bit – Four separate interrupt channels for Rx, Tx, error and wake-up per CAN – Low-pass filter wake-up function – Loop-back for self test operation – Programmable link to a timer input capture channel, for timestamping and network synchronization. • Enhanced capture timer (ECT) – 16-bit main counter with 7-bit prescaler – 8 programmable input capture or output compare channels; 4 of the 8 input captures with buffer – Input capture filters and buffers, three successive captures on four channels, or two captures on four channels with a capture/compare selectable on the remaining four – Four 8-bit or two 16-bit pulse accumulators – 16-bit modulus down-counter with 4-bit prescaler – Four user-selectable delay counters for signal filtering MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data General Description 27 General Description • 4 PWM channels with programmable period and duty cycle – 8-bit 4-channel or 16-bit 2-channel – Separate control for each pulse width and duty cycle – Center- or left-aligned outputs – Programmable clock select logic with a wide range of frequencies • Serial interfaces – Two asynchronous serial communications interfaces (SCI) – Inter IC bus interface (I2C) – Synchronous serial peripheral interface (SPI) • LIM (lite integration module) – WCR (windowed COP watchdog, real time interrupt, clock monitor) – ROC (reset and clocks) – MEBI (multiplexed external bus interface) – MMI (memory map and interface) – INT (interrupt control) – BKP (breakpoints) – BDM (background debug mode) • Two 8-bit ports with key wake-up interrupt • Clock generation – Phase-locked loop clock frequency multiplier – Limp home mode in absence of external clock – Slow mode divider – Low power 0.5 to 16 MHz crystal oscillator reference clock – Option of a Pierce or Colpitts oscillator Technical Data 28 MC68HC912DT128A — Rev 4.0 General Description MOTOROLA General Description Features • 112-Pin TQFP package – Up to 67 general-purpose I/O lines on the MC68HC912DT128A (up to 69 on the MC68HC912DG128A), plus up to 18 input-only lines – 5.0V operation at 8 MHz • Development support – Single-wire background debug™ mode (BDM) – On-chip hardware breakpoints MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data General Description 29 General Description 1.5 MC68HC912DT128A Block Diagram VRH0 RxD0 TxD0 RxD1 TxD1 SCI0 EXTAL XTAL RESET SCI1 SDI/MISO SDO/MOSI SCK SS SPI PORT E PE0 PE1 PE2 PE3 PE4 PE5 PE6 PE7 XIRQ IRQ R/W LSTRB ECLK MODA MODB DBE/CAL Lite integration module (LIM) PW0 PW1 PW2 PW3 PWM PIX0 PIX1 PIX2 PPAGE I/O SCL SDA IIC DDRH PORTH CAN0 KWH7 KWH6 KWH5 KWH4 KWH3 KWH2 KWH1 KWH0 PH7 PH6 PH5 PH4 PH3 PH2 PH1 PH0 KWU KWJ7 KWJ6 KWJ5 KWJ4 KWJ3 KWJ2 KWJ1 KWJ0 DDRJ PB7 PB6 PB5 PB4 PB3 PB2 PB1 PB0 ADDR7 ADDR6 ADDR5 ADDR4 ADDR3 ADDR2 ADDR1 ADDR0 DATA7 DATA6 DATA5 DATA4 DATA3 DATA2 DATA1 DATA0 Narrow bus CAN1 PORTJ PA7 PA6 PA5 PA4 PA3 PA2 PA1 PA0 PORT B ADDR15 ADDR14 ADDR13 ADDR12 ADDR11 ADDR10 ADDR9 ADDR8 PORT A DATA7 DATA15 DATA6 DATA14 DATA5 DATA13 DATA4 DATA12 DATA3 DATA11 DATA2 DATA10 DATA1 DATA9 DATA0 DATA8 Wide bus DDRB PORT AD1 PORT T PK0 PK1 PK2 PK3 PK7 PIB7 PIB6 TxCAN2 RxCAN2 TxCAN1 RxCAN1 TxCAN0 RxCAN0 CAN2 DDRA PS4 PS5 PS6 PS7 PP0 PP1 PP2 PP3 ECS Multiplexed Address/Data Bus PS0 PS1 PS2 PS3 PORT P Clock Generation module Enhanced capture timer PAD10 PAD11 PAD12 PAD13 PAD14 PAD15 PAD16 PAD17 PT0 PT1 PT2 PT3 PT4 PT5 PT6 PT7 PORT K PLL IOC0 IOC1 IOC2 IOC3 IOC4 IOC5 IOC6 IOC7 PORT IB XFC VDDPLL VSSPLL Periodic interrupt COP watchdog Clock monitor Breakpoints DDRT BKGD Single-wire background debug module DDRS CPU12 AN10 AN11 AN12 AN13 AN14 AN15 AN16 AN17 DDRP 2K byte EEPROM PAD00 PAD01 PAD02 PAD03 PAD04 PAD05 PAD06 PAD07 PORT S AN00 AN01 AN02 AN03 AN04 AN05 AN06 AN07 VDDA VSSA DDRK 8K byte RAM VRH1 VRL1 VDDA VSSA VRH1 ATD1 VRL1 VDDA VSSA PORT AD0 VSTBY VRH0 VRL0 ATD0 VRL0 DDRIB 128K byte flash EEPROM PJ7 PJ6 PJ5 PJ4 PJ3 PJ2 PJ1 PJ0 VDD ×2 VSS ×2 Power for internal circuitry VDDX ×2 VSSX ×2 Power for I/O drivers Figure 1-1. MC68HC912DT128A Block Diagram Technical Data 30 MC68HC912DT128A — Rev 4.0 General Description MOTOROLA General Description MC68HC912DG128A Block Diagram 1.6 MC68HC912DG128A Block Diagram VRH0 RxD0 TxD0 RxD1 TxD1 SCI0 EXTAL XTAL RESET SCI1 SDI/MISO SDO/MOSI SCK SS SPI PORT E PE0 PE1 PE2 PE3 PE4 PE5 PE6 PE7 XIRQ IRQ R/W LSTRB ECLK MODA MODB DBE/CAL Lite integration module (LIM) PW0 PW1 PW2 PW3 PWM PIX0 PIX1 PIX2 PPAGE I/O ECS Multiplexed Address/Data Bus I/O PORTH DDRH DDRJ Narrow bus KWJ7 KWJ6 KWJ5 KWJ4 KWJ3 KWJ2 KWJ1 KWJ0 PORTJ PB7 PB6 PB5 PB4 PB3 PB2 PB1 PB0 TxCAN1 RxCAN1 ADDR7 ADDR6 ADDR5 ADDR4 ADDR3 ADDR2 ADDR1 ADDR0 CAN1 DATA7 DATA6 DATA5 DATA4 DATA3 DATA2 DATA1 DATA0 PORT B PA7 PA6 PA5 PA4 PA3 PA2 PA1 PA0 PORT A ADDR15 ADDR14 ADDR13 ADDR12 ADDR11 ADDR10 ADDR9 ADDR8 TxCAN0 RxCAN0 KWU PJ7 PJ6 PJ5 PJ4 PJ3 PJ2 PJ1 PJ0 PORT AD1 PIB7 PIB6 PIB5 PIB4 CAN0 PH7 PH6 PH5 PH4 PH3 PH2 PH1 PH0 PS4 PS5 PS6 PS7 PK0 PK1 PK2 PK3 PK7 DDRB KWH7 KWH6 KWH5 KWH4 KWH3 KWH2 KWH1 KWH0 PS0 PS1 PS2 PS3 PP0 PP1 PP2 PP3 DDRA DATA7 DATA15 DATA6 DATA14 DATA5 DATA13 DATA4 DATA12 DATA3 DATA11 DATA2 DATA10 DATA1 DATA9 DATA0 DATA8 Wide bus DDRIB SCL SDA IIC PORT T Clock Generation module Enhanced capture timer PAD10 PAD11 PAD12 PAD13 PAD14 PAD15 PAD16 PAD17 PT0 PT1 PT2 PT3 PT4 PT5 PT6 PT7 PORT S PLL IOC0 IOC1 IOC2 IOC3 IOC4 IOC5 IOC6 IOC7 PORT P XFC VDDPLL VSSPLL Periodic interrupt COP watchdog Clock monitor Breakpoints PORT K BKGD Single-wire background debug module PORTIB CPU12 AN10 AN11 AN12 AN13 AN14 AN15 AN16 AN17 DDRS 2K byte EEPROM PAD00 PAD01 PAD02 PAD03 PAD04 PAD05 PAD06 PAD07 DDRT AN00 AN01 AN02 AN03 AN04 AN05 AN06 AN07 VDDA VSSA DDRP 8K byte RAM VRH1 VRL1 VDDA VSSA VRH1 ATD1 VRL1 VDDA VSSA PORT AD0 VSTBY VRH0 VRL0 ATD0 VRL0 DDRK 128K byte flash EEPROM VDD ×2 VSS ×2 Power for internal circuitry VDDX ×2 VSSX ×2 Power for I/O drivers Figure 1-2. MC68HC912DG128A Block Diagram MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data General Description 31 General Description 1.7 Ordering Information Table 1-1. Device Ordering Information Ambient Temperature Package Order Number Range Designator –40 to +85°C C MC912DG128ACPV –40 to +105°C V MC912DG128AVPV –40 to +125°C M MC912DG128AMPV –40 to +85°C C MC912DT128ACPV –40 to +105°C V MC912DT128AVPV –40 to +125°C M MC912DT128AMPV –40 to +85°C C MC912DG128CCPV –40 to +105°C V MC912DG128CVPV –40 to +125°C M MC912DG128CMPV –40 to +85°C C MC912DT128CCPV –40 to +105°C V MC912DT128CVPV –40 to +125°C M MC912DT128CMPV –40 to +85°C C MC912DG128PCPV –40 to +105°C V MC912DG128PVPV –40 to +125°C M MC912DG128PMPV –40 to +85°C C MC912DT128PCPV –40 to +105°C V MC912DT128PVPV –40 to +125°C M MC912DT128PMPV 112-Pin TQFP Technical Data 32 MC68HC912DT128A — Rev 4.0 General Description MOTOROLA General Description Ordering Information Table 1-2. Development Tools Ordering Information Description Details Order Number Evaluation board kit EVB and user's manual only M68EVB912DG128 Serial Debug Interface Low voltage serial debug interface cable can be ordered separately M68SDIL12 Complete evaluation board kit EVB, MCUez debug software, SDIL low voltage serial debug interface cable M68KIT912DG128 Adapter 112 pin TQFP adapter is also available. M68ADP912DG128PV MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data General Description 33 General Description Technical Data 34 MC68HC912DT128A — Rev 4.0 General Description MOTOROLA Technical Data — MC68HC912DT128A Section 2. Central Processing Unit 2.1 Contents 2.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 35 2.3 Programming Model . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 36 2.4 Data Types . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 37 2.5 Addressing Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .38 2.6 Indexed Addressing Modes . . . . . . . . . . . . . . . . . . . . . . . . . . .39 2.7 Opcodes and Operands . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 40 2.2 Introduction The CPU12 is a high-speed, 16-bit processing unit. It has full 16-bit data paths and wider internal registers (up to 20 bits) for high-speed extended math instructions. The instruction set is a proper superset of the M68HC11instruction set. The CPU12 allows instructions with odd byte counts, including many single-byte instructions. This provides efficient use of ROM space. An instruction queue buffers program information so the CPU always has immediate access to at least three bytes of machine code at the start of every instruction. The CPU12 also offers an extensive set of indexed addressing capabilities. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Central Processing Unit 35 Central Processing Unit 2.3 Programming Model CPU12 registers are an integral part of the CPU and are not addressed as if they were memory locations. 7 A 0 7 B 0 8-BIT ACCUMULATORS A & B OR 15 D 0 16-BIT DOUBLE ACCUMULATOR D 15 IX 0 INDEX REGISTER X 15 IY 0 INDEX REGISTER Y 15 SP 0 STACK POINTER 15 PC 0 PROGRAM COUNTER S X H I N Z V C CONDITION CODE REGISTER Figure 2-1. Programming Model Accumulators A and B are general-purpose 8-bit accumulators used to hold operands and results of arithmetic calculations or data manipulations. Some instructions treat the combination of these two 8bit accumulators as a 16-bit double accumulator (accumulator D). Index registers X and Y are used for indexed addressing mode. In the indexed addressing mode, the contents of a 16-bit index register are added to 5-bit, 9-bit, or 16-bit constants or the content of an accumulator to form the effective address of the operand to be used in the instruction. Technical Data 36 MC68HC912DT128A — Rev 4.0 Central Processing Unit MOTOROLA Central Processing Unit Data Types Stack pointer (SP) points to the last stack location used. The CPU12 supports an automatic program stack that is used to save system context during subroutine calls and interrupts, and can also be used for temporary storage of data. The stack pointer can also be used in all indexed addressing modes. Program counter is a 16-bit register that holds the address of the next instruction to be executed. The program counter can be used in all indexed addressing modes except autoincrement/decrement. Condition Code Register (CCR) contains five status indicators, two interrupt masking bits, and a STOP disable bit. The five flags are half carry (H), negative (N), zero (Z), overflow (V), and carry/borrow (C). The half-carry flag is used only for BCD arithmetic operations. The N, Z, V, and C status bits allow for branching based on the results of a previous operation. 2.4 Data Types The CPU12 supports the following data types: • Bit data • 8-bit and 16-bit signed and unsigned integers • 16-bit unsigned fractions • 16-bit addresses A byte is eight bits wide and can be accessed at any byte location. A word is composed of two consecutive bytes with the most significant byte at the lower value address. There are no special requirements for alignment of instructions or operands. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Central Processing Unit 37 Central Processing Unit 2.5 Addressing Modes Addressing modes determine how the CPU accesses memory locations to be operated upon. The CPU12 includes all of the addressing modes of the M68HC11 CPU as well as several new forms of indexed addressing. Table 2-1 is a summary of the available addressing modes. Table 2-1. M68HC12 Addressing Mode Summary Addressing Mode Source Format INST (no externally supplied operands) INST #opr8i or INST #opr16i Abbreviation Description INH Operands (if any) are in CPU registers IMM Operand is included in instruction stream 8- or 16-bit size implied by context Direct INST opr8a DIR Extended INST opr16a INST rel8 or INST rel16 EXT REL An 8-bit or 16-bit relative offset from the current pc is supplied in the instruction INST oprx5,xysp IDX 5-bit signed constant offset from x, y, sp, or pc INST oprx3,–xys IDX Auto pre-decrement x, y, or sp by 1 ~ 8 INST oprx3,+xys IDX Auto pre-increment x, y, or sp by 1 ~ 8 INST oprx3,xys– IDX Auto post-decrement x, y, or sp by 1 ~ 8 INST oprx3,xys+ IDX Auto post-increment x, y, or sp by 1 ~ 8 INST abd,xysp IDX INST oprx9,xysp IDX1 INST oprx16,xysp IDX2 Indexed-Indirect (16-bit offset) INST [oprx16,xysp] [IDX2] Indexed-Indirect (D accumulator offset) INST [D,xysp] [D,IDX] Inherent Immediate Relative Indexed (5-bit offset) Indexed (auto pre-decrement) Indexed (auto pre-increment) Indexed (auto postdecrement) Indexed (auto post-increment) Indexed (accumulator offset) Indexed (9-bit offset) Indexed (16-bit offset) Operand is the lower 8-bits of an address in the range $0000 – $00FF Operand is a 16-bit address Indexed with 8-bit (A or B) or 16-bit (D) accumulator offset from x, y, sp, or pc 9-bit signed constant offset from x, y, sp, or pc (lower 8-bits of offset in one extension byte) 16-bit constant offset from x, y, sp, or pc (16-bit offset in two extension bytes) Pointer to operand is found at... 16-bit constant offset from x, y, sp, or pc (16-bit offset in two extension bytes) Technical Data 38 Pointer to operand is found at... x, y, sp, or pc plus the value in D MC68HC912DT128A — Rev 4.0 Central Processing Unit MOTOROLA Central Processing Unit Indexed Addressing Modes 2.6 Indexed Addressing Modes The CPU12 indexed modes reduce execution time and eliminate code size penalties for using the Y index register. CPU12 indexed addressing uses a postbyte plus zero, one, or two extension bytes after the instruction opcode. The postbyte and extensions do the following tasks: • Specify which index register is used. • Determine whether a value in an accumulator is used as an offset. • Enable automatic pre- or post-increment or decrement • Specify use of 5-bit, 9-bit, or 16-bit signed offsets. Table 2-2. Summary of Indexed Operations Postbyte Code (xb) rr0nnnnn 111rr0zs 111rr011 rr1pnnnn 111rr1aa 111rr111 Source Code Comments Syntax ,r 5-bit constant offset n = –16 to +15 n,r rr can specify X, Y, SP, or PC –n,r Constant offset (9- or 16-bit signed) z-0 = 9-bit with sign in LSB of postbyte(s) n,r 1 = 16-bit –n,r if z = s = 1, 16-bit offset indexed-indirect (see below) rr can specify X, Y, SP, or PC 16-bit offset indexed-indirect [n,r] rr can specify X, Y, SP, or PC Auto pre-decrement/increment or Auto post-decrement/increment; n,–r n,+r p = pre-(0) or post-(1), n = –8 to –1, +1 to +8 n,r– n,r+ rr can specify X, Y, or SP (PC not a valid choice) Accumulator offset (unsigned 8-bit or 16-bit) aa-00 = A A,r 01 = B B,r 10 = D (16-bit) D,r 11 = see accumulator D offset indexed-indirect rr can specify X, Y, SP, or PC Accumulator D offset indexed-indirect [D,r] rr can specify X, Y, SP, or PC MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Central Processing Unit 39 Central Processing Unit 2.7 Opcodes and Operands The CPU12 uses 8-bit opcodes. Each opcode identifies a particular instruction and associated addressing mode to the CPU. Several opcodes are required to provide each instruction with a range of addressing capabilities. Only 256 opcodes would be available if the range of values were restricted to the number that can be represented by 8-bit binary numbers. To expand the number of opcodes, a second page is added to the opcode map. Opcodes on the second page are preceded by an additional byte with the value $18. To provide additional addressing flexibility, opcodes can also be followed by a postbyte or extension bytes. Postbytes implement certain forms of indexed addressing, transfers, exchanges, and loop primitives. Extension bytes contain additional program information such as addresses, offsets, and immediate data. Technical Data 40 MC68HC912DT128A — Rev 4.0 Central Processing Unit MOTOROLA Technical Data — MC68HC912DT128A Section 3. Pinout and Signal Descriptions 3.1 Contents 3.2 MC68HC912DT128A Pin Assignments in 112-pin QFP. . . . . . 41 3.3 Power Supply Pins . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .45 3.4 Signal Descriptions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 47 3.5 Port Signals . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .56 3.2 MC68HC912DT128A Pin Assignments in 112-pin QFP The MC68HC912DT128A is available in a 112-pin thin quad flat pack (TQFP). Most pins perform two or more functions, as described in the Signal Descriptions. Figure 3-1 shows pin assignments. In expanded narrow modes the lower byte data is multiplexed with higher byte data through pins 57-64. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Pinout and Signal Descriptions 41 84 83 82 81 80 79 78 77 76 75 74 73 72 71 70 69 68 67 66 65 64 63 62 61 60 59 58 57 MC68HC912DT128A 112TQFP 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 PAD17/AN17 PAD07/AN07 PAD16/AN16 PAD06/AN06 PAD15/AN15 PAD05/AN05 PAD14/AN14 PAD04/AN04 PAD13/AN13 PAD03/AN03 PAD12/AN12 PAD02/AN02 PAD11/AN11 PAD01/AN01 PAD10/AN10 PAD00/AN00 VRL0 VRH0 VSS VDD PA7/ADDR15/DATA15/DATA7 PA6/ADDR14/DATA14/DATA6 PA5/ADDR13/DATA13/DATA5 PA4/ADDR12/DATA12/DATA4 PA3/ADDR11/DATA11/DATA3 PA2/ADDR10/DATA10/DATA2 PA1/ADDR9/DATA9/DATA1 PA0/ADDR8/DATA8/DATA0 ADDR5/DATA5/PB5 ADDR6/DATA6/PB6 ADDR7/DATA7/PB7 KWH7/PH7 KWH6/PH6 KWH5/PH5 KWH4/PH4 DBE/CAL/PE7 MODB/IPIPE1/PE6 MODA/IPIPE0/PE5 ECLK/PE4 VSSX VSTBY VDDX VDDPLL XFC VSSPLL RESET EXTAL XTAL KWH3/PH3 KWH2/PH2 KWH1/PH1 KWH0/PH0 LSTRB/TAGLO/PE3 R/W/PE2 IRQ/PE1 XIRQ/PE0 PW2/PP2 PW1/PP1 PW0/PP0 IOC0/PT0 IOC1/PT1 IOC2/PT2 IOC3/PT3 KWJ7/PJ7 KWJ6/PJ6 KWJ5/PJ5 KWJ4/PJ4 VDD PK3 VSS IOC4/PT4 IOC5/PT5 IOC6/PT6 IOC7/PT7 KWJ3/PJ3 KWJ2/PJ2 KWJ1/PJ1 KWJ0/PJ0 SMODN/TAGHI/BKGD ADDR0/DATA0/PB0 ADDR1/DATA1/PB1 ADDR2/DATA2/PB2 ADDR3/DATA3/PB3 ADDR4/DATA4/PB4 112 111 110 109 108 107 106 105 104 103 102 101 100 99 98 97 96 95 94 93 92 91 90 89 88 87 86 85 PP3/PW3 PK0/PIX0 PK1/PIX1 PK2/PIX2 PK7/ECS VDDX VSSX RxCAN0 TxCAN0 RxCAN1 TxCAN1 RxCAN2 TxCAN2 PIB6/SDA PIB7/SCL TEST PS7/SS PS6/SCK PS5/SDO/MOSI PS4/SDI/MISO PS3/TxD1 PS2/RxD1 PS1/TxD0 PS0/RxD0 VSSA VRL1 VRH1 VDDA Pinout and Signal Descriptions Note: TEST = This pin is used for factory test purposes. It is recommended that this pin is not connected in the application, but it may be bonded to 5.5 V max without issue. Never apply voltage higher than 5.5 V to this pin. Figure 3-1. Pin Assignments in 112-pin QFP for MC68HC912DT128A Technical Data 42 MC68HC912DT128A — Rev 4.0 Pinout and Signal Descriptions MOTOROLA MC68HC912DG128A 112TQFP 84 83 82 81 80 79 78 77 76 75 74 73 72 71 70 69 68 67 66 65 64 63 62 61 60 59 58 57 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 PAD17/AN17 PAD07/AN07 PAD16/AN16 PAD06/AN06 PAD15/AN15 PAD05/AN05 PAD14/AN14 PAD04/AN04 PAD13/AN13 PAD03/AN03 PAD12/AN12 PAD02/AN02 PAD11/AN11 PAD01/AN01 PAD10/AN10 PAD00/AN00 VRL0 VRH0 VSS VDD PA7/ADDR15/DATA15/DATA7 PA6/ADDR14/DATA14/DATA6 PA5/ADDR13/DATA13/DATA5 PA4/ADDR12/DATA12/DATA4 PA3/ADDR11/DATA11/DATA3 PA2/ADDR10/DATA10/DATA2 PA1/ADDR9/DATA9/DATA1 PA0/ADDR8/DATA8/DATA0 ADDR5/DATA5/PB5 ADDR6/DATA6/PB6 ADDR7/DATA7/PB7 KWH7/PH7 KWH6/PH6 KWH5/PH5 KWH4/PH4 ECLK/DBE/CAL/PE7 CGMTST/MODB/IPIPE1/PE6 MODA/IPIPE0/PE5 ECLK/PE4 VSSX VSTBY VDDX VDDPLL XFC VSSPLL RESET EXTAL XTAL KWH3/PH3 KWH2/PH2 KWH1/PH1 KWH0/PH0 LSTRB/TAGLO/PE3 R/W/PE2 IRQ/PE1 XIRQ/PE0 PW2/PP2 PW1/PP1 PW0/PP0 IOC0/PT0 IOC1/PT1 IOC2/PT2 IOC3/PT3 KWJ7/PJ7 KWJ6/PJ6 KWJ5/PJ5 KWJ4/PJ4 VDD PK3 VSS IOC4/PT4 IOC5/PT5 IOC6/PT6 IOC7/PT7 KWJ3/PJ3 KWJ2/PJ2 KWJ1/PJ1 KWJ0/PJ0 SMODN/TAGHI/BKGD ADDR0/DATA0/PB0 ADDR1/DATA1/PB1 ADDR2/DATA2/PB2 ADDR3/DATA3/PB3 ADDR4/DATA4/PB4 112 111 110 109 108 107 106 105 104 103 102 101 100 99 98 97 96 95 94 93 92 91 90 89 88 87 86 85 PP3/PW3 PK0/PIX0 PK1/PIX1 PK2/PIX2 PK7/ECS VDDX VSSX RxCAN0 TxCAN0 RxCAN1 TxCAN1 PIB4 PIB5 PIB6/SDA PIB7/SCL TEST PS7/SS PS6/SCK PS5/SDO/MOSI PS4/SDI/MISO PS3/TxD1 PS2/RxD1 PS1/TxD0 PS0/RxD0 VSSA VRL1 VRH1 VDDA Pinout and Signal Descriptions MC68HC912DT128A Pin Assignments in 112-pin QFP Note: TEST = This pin is used for factory test purposes. It is recommended that this pin is not connected in the application, but it may be bonded to 5.5 V max without issue. Never apply voltage higher than 5.5 V to this pin. Figure 3-2. Pin Assignments in 112-pin QFP for MC68HC912DG128A MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Pinout and Signal Descriptions 43 Pinout and Signal Descriptions 0.20 T L-M N 4X PIN 1 IDENT 0.20 T L-M N 4X 28 TIPS 112 J1 85 4X P J1 1 CL 84 VIEW Y 108X X X=L, M OR N G VIEW Y B L V M B1 28 AA J V1 57 29 F D 56 0.13 N M T BASE METAL L-M N SECTION J1-J1 ROTATED 90 ° COUNTERCLOCKWISE A1 S1 A S C2 C VIEW AB θ2 0.050 0.10 T 112X SEATING PLANE NOTES: 1. DIMENSIONING AND TOLERANCING PER ASME Y14.5M, 1994. 2. DIMENSIONS IN MILLIMETERS. 3. DATUMS L, M AND N TO BE DETERMINED AT SEATING PLANE, DATUM T. 4. DIMENSIONS S AND V TO BE DETERMINED AT SEATING PLANE, DATUM T. 5. DIMENSIONS A AND B DO NOT INCLUDE MOLD PROTRUSION. ALLOWABLE PROTRUSION IS 0.25 PER SIDE. DIMENSIONS A AND B INCLUDE MOLD MISMATCH. 6. DIMENSION D DOES NOT INCLUDE DAMBAR PROTRUSION. ALLOWABLE DAMBAR PROTRUSION SHALL NOT CAUSE THE D DIMENSION TO EXCEED 0.46. θ3 T θ R R2 R 0.25 R1 GAGE PLANE (K) C1 θ1 E (Y) (Z) VIEW AB DIM A A1 B B1 C C1 C2 D E F G J K P R1 R2 S S1 V V1 Y Z AA θ θ1 θ2 θ3 MILLIMETERS MAX MIN 20.000 BSC 10.000 BSC 20.000 BSC 10.000 BSC --1.600 0.050 0.150 1.350 1.450 0.270 0.370 0.450 0.750 0.270 0.330 0.650 BSC 0.090 0.170 0.500 REF 0.325 BSC 0.100 0.200 0.100 0.200 22.000 BSC 11.000 BSC 22.000 BSC 11.000 BSC 0.250 REF 1.000 REF 0.090 0.160 8 ° 0° 7 ° 3 ° 13 ° 11 ° 11 ° 13 ° Figure 3-3. 112-pin QFP Mechanical Dimensions (case no. 987) Technical Data 44 MC68HC912DT128A — Rev 4.0 Pinout and Signal Descriptions MOTOROLA Pinout and Signal Descriptions Power Supply Pins 3.3 Power Supply Pins MC68HC912DT128A power and ground pins are described below and summarized in Table 3-1. All power supply pins must be connected to appropriate supplies. On no account must any pins be left floating. 3.3.1 Internal Power (VDD) and Ground (VSS) Power is supplied to the MCU through VDD and VSS. Because fast signal transitions place high, short-duration current demands on the power supply, use bypass capacitors with high-frequency characteristics and place them as close to the MCU as possible. 3.3.2 External Power (VDDX) and Ground (VSSX) External power and ground for I/O drivers. Because fast signal transitions place high, short-duration current demands on the power supply, use bypass capacitors with high-frequency characteristics and place them as close to the MCU as possible. Bypass requirements depend on how heavily the MCU pins are loaded. 3.3.3 VDDA, VSSA Provides operating voltage and ground for the analog-to-digital converter. This allows the supply voltage to the A/D to be bypassed independently. 3.3.4 Analog to Digital Reference Voltages (VRH, VRL) VRH0, VRL0: reference voltage high and low for ATD converter 0. VRH1, VRL1: reference voltage high and low for ATD converter 1. If the ATD modules are not used, leaving VRH connected to VDD will not result in an increase of power consumption. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Pinout and Signal Descriptions 45 Pinout and Signal Descriptions 3.3.5 VDDPLL, VSSPLL Provides operating voltage and ground for the Phase-Locked Loop. This allows the supply voltage to the PLL to be bypassed independently. NOTE: The VSSPLL pin should always be grounded even if the PLL is not used. The VDDPLL pin should not be left floating. It is recommended to connect the VDDPLL pin to ground if the PLL is not used. 3.3.6 XFC PLL loop filter. Please see Appendix: CGM Practical Aspects for information on how to calculate PLL loop filter elements. Any current leakage on this pin must be avoided. VDDPLL C0 MCU R0 Ca XFC Figure 3-4. PLL Loop FIlter Connections Technical Data 46 MC68HC912DT128A — Rev 4.0 Pinout and Signal Descriptions MOTOROLA Pinout and Signal Descriptions Signal Descriptions 3.3.7 VSTBY Stand-by voltage supply to static RAM. Used to maintain the contents of RAM with minimal power when the rest of the chip is powered down. Table 3-1. MC68HC912DT128A Power and Ground Connection Summary VDD Pin Number 112-pin QFP 12, 65 VSS 14, 66 VDDX 42, 107 VSSX 40, 106 VDDA 85 VSSA 88 VRH1 86 VRL1 87 VRH0 67 VRL0 68 VDDPLL 43 VSSPLL 45 VSTBY 41 Mnemonic Description Internal power and ground. External power and ground, supply to pin drivers. Operating voltage and ground for the analog-to-digital converter, allows the supply voltage to the A/D to be bypassed independently. Reference voltages for the analog-to-digital converter 1 Reference voltages for the analog-to-digital converter 0. Provides operating voltage and ground for the Phase-Locked Loop. This allows the supply voltage to the PLL to be bypassed independently. Stand-by voltage supply to maintain the contents of RAM with minimal power when the rest of the chip is powered down. 3.4 Signal Descriptions 3.4.1 Crystal Driver and External Clock Input (XTAL, EXTAL) These pins provide the interface for either a crystal or a CMOS compatible clock to control the internal clock generator circuitry. Out of reset the frequency applied to EXTAL is twice the desired E–clock rate. All the device clocks are derived from the EXTAL input frequency. 3.4.1.1 Crystal Connections Refer to Section 13. Oscillator for details of crystal connections. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Pinout and Signal Descriptions 47 Pinout and Signal Descriptions NOTE: When selecting a crystal, it is recommended to use one with the lowest possible frequency in order to minimise EMC emissions. 3.4.1.2 External Oscillator Connections XTAL is the crystal output. The XTAL pin must be left unterminated when an external CMOS compatible clock input is connected to the EXTAL pin. The XTAL output is normally intended to drive only a crystal. The XTAL output can be buffered with a high-impedance buffer to drive the EXTAL input of another device. 2 xE CMOS-COMPATIBLE EXTERNAL OSCILLATOR EXTAL MCU XTAL NC Figure 3-5. External Oscillator Connections 3.4.2 E-Clock Output (ECLK) ECLK is the output connection for the internal bus clock. It is used to demultiplex the address and data in expanded modes and is used as a timing reference. ECLK frequency is equal to 1/2 the crystal frequency out of reset. The E-clock output is turned off in single chip user mode to reduce the effects of RFI. It can be turned on if necessary. In special single-chip mode, the E-clock is turned ON at reset and can be turned OFF. In special peripheral mode the E-clock is an input to the MCU. All clocks, including the E clock, are halted when the MCU is in STOP mode. It is possible to configure the MCU to interface to slow external memory. ECLK can be stretched for such accesses. 3.4.3 Reset (RESET) An active low bidirectional control signal, RESET, acts as an input to initialize the MCU to a known start-up state. It also acts as an open-drain Technical Data 48 MC68HC912DT128A — Rev 4.0 Pinout and Signal Descriptions MOTOROLA Pinout and Signal Descriptions Signal Descriptions output to indicate that an internal failure has been detected in either the clock monitor or COP watchdog circuit. The MCU goes into reset asynchronously and comes out of reset synchronously. This allows the part to reach a proper reset state even if the clocks have failed, while allowing synchronized operation when starting out of reset. It is important to use an external low-voltage reset circuit (such as MC34064 or MC34164) to prevent corruption of RAM or EEPROM due to power transitions. The reset sequence is initiated by any of the following events: • Power-on-reset (POR) • COP watchdog enabled and watchdog timer times out • Clock monitor enabled and Clock monitor detects slow or stopped clock • User applies a low level to the reset pin External circuitry connected to the reset pin should not include a large capacitance that would interfere with the ability of this signal to rise to a valid logic one within nine bus cycles after the low drive is released. Upon detection of any reset, an internal circuit drives the reset pin low and a clocked reset sequence controls when the MCU can begin normal processing. In the case of POR or a clock monitor error, a 4096 cycle oscillator startup delay is imposed before the reset recovery sequence starts (reset is driven low throughout this 4096 cycle delay). The internal reset recovery sequence then drives reset low for 16 to 17 cycles and releases the drive to allow reset to rise. Nine cycles later this circuit samples the reset pin to see if it has risen to a logic one level. If reset is low at this point, the reset is assumed to be coming from an external request and the internally latched states of the COP timeout and clock monitor failure are cleared so the normal reset vector ($FFFE:FFFF) is taken when reset is finally released. If reset is high after this nine cycle delay, the reset source is tentatively assumed to be either a COP failure or a clock monitor fail. If the internally latched state of the clock monitor fail circuit is true, processing begins by fetching the clock monitor vector ($FFFC:FFFD). If no clock monitor failure is indicated, and the latched state of the COP timeout is true, processing begins by fetching the COP MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Pinout and Signal Descriptions 49 Pinout and Signal Descriptions vector ($FFFA:FFFB). If neither clock monitor fail nor COP timeout are pending, processing begins by fetching the normal reset vector ($FFFE:FFFF). 3.4.4 Maskable Interrupt Request (IRQ) The IRQ input provides a means of applying asynchronous interrupt requests to the MCU. Either falling edge-sensitive triggering or levelsensitive triggering is program selectable (INTCR register). IRQ is always enabled and configured to level-sensitive triggering at reset. It can be disabled by clearing IRQEN bit (INTCR register). When the MCU is reset the IRQ function is masked in the condition code register. This pin is always an input and can always be read. There is an active pull-up on this pin while in reset and immediately out of reset. The pullup can be turned off by clearing PUPE in the PUCR register. Technical Data 50 MC68HC912DT128A — Rev 4.0 Pinout and Signal Descriptions MOTOROLA Pinout and Signal Descriptions Signal Descriptions 3.4.5 Nonmaskable Interrupt (XIRQ) The XIRQ input provides a means of requesting a nonmaskable interrupt after reset initialization. During reset, the X bit in the condition code register (CCR) is set and any interrupt is masked until MCU software enables it. Because the XIRQ input is level sensitive, it can be connected to a multiple-source wired-OR network. This pin is always an input and can always be read. There is an active pull-up on this pin while in reset and immediately out of reset. The pullup can be turned off by clearing PUPE in the PUCR register. XIRQ is often used as a power loss detect interrupt. Whenever XIRQ or IRQ are used with multiple interrupt sources (IRQ must be configured for level-sensitive operation if there is more than one source of IRQ interrupt), each source must drive the interrupt input with an open-drain type of driver to avoid contention between outputs. There must also be an interlock mechanism at each interrupt source so that the source holds the interrupt line low until the MCU recognizes and acknowledges the interrupt request. If the interrupt line is held low, the MCU will recognize another interrupt as soon as the interrupt mask bit in the MCU is cleared (normally upon return from an interrupt). 3.4.6 Mode Select (SMODN, MODA, and MODB) The state of these pins during reset determine the MCU operating mode. After reset, MODA and MODB can be configured as instruction queue tracking signals IPIPE0 and IPIPE1 in expanded modes. MODA and MODB have active pulldowns during reset. The SMODN pin has an active pullup when configured as an input. The pin can be used as BKGD or TAGHI after reset. 3.4.7 Single-Wire Background Mode Pin (BKGD) The BKGD pin receives and transmits serial background debugging commands. A special self-timing protocol is used. The BKGD pin has an active pullup when configured as an input; BKGD has no pullup control. Refer to Development Support. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Pinout and Signal Descriptions 51 Pinout and Signal Descriptions 3.4.8 External Address and Data Buses (ADDR[15:0] and DATA[15:0]) External bus pins share functions with general-purpose I/O ports A and B. In single-chip operating modes, the pins can be used for I/O; in expanded modes, the pins are used for the external buses. In expanded wide mode, ports A and B are used for multiplexed 16-bit data and address buses. PA[7:0] correspond to ADDR[15:8]/DATA[15:8]; PB[7:0] correspond to ADDR[7:0]/DATA[7:0]. In expanded narrow mode, ports A and B are used for the16-bit address bus, and an 8-bit data bus is multiplexed with the most significant half of the address bus on port A. In this mode, 16-bit data is handled as two back-to-back bus cycles, one for the high byte followed by one for the low byte. PA[7:0] correspond to ADDR[15:8] and to DATA[15:8] or DATA[7:0], depending on the bus cycle. The state of the address pins should be latched at the rising edge of E. To allow for maximum address setup time at external devices, a transparent latch should be used. 3.4.9 Read/Write (R/W) In all modes this pin can be used as a general-purpose I/O and is an input with an active pull-up out of reset. If the read/write function is required it should be enabled by setting the RDWE bit in the PEAR register. External writes will not be possible until enabled. 3.4.10 Low-Byte Strobe (LSTRB) In all modes this pin can be used as a general-purpose I/O and is an input with an active pull-up out of reset. If the strobe function is required, it should be enabled by setting the LSTRE bit in the PEAR register. This signal is used in write operations. Therefore external low byte writes will not be possible until this function is enabled. This pin is also used as TAGLO in Special Expanded modes and is multiplexed with the LSTRB function. Technical Data 52 MC68HC912DT128A — Rev 4.0 Pinout and Signal Descriptions MOTOROLA Pinout and Signal Descriptions Signal Descriptions 3.4.11 Instruction Queue Tracking Signals (IPIPE1 and IPIPE0) IPIPE1 (PE6) and IPIPE0 (PE5) signals are used to track the state of the internal instruction queue. Data movement and execution state information is time-multiplexed on the two signals. Refer to Development Support. 3.4.12 Data Bus Enable (DBE) The DBE pin (PE7) is an active low signal that will be asserted low during E-clock high time. DBE provides separation between output of a multiplexed address and the input of data. When an external address is stretched, DBE is asserted during what would be the last quarter cycle of the last E-clock cycle of stretch. In expanded modes this pin is used to enable the drive control of external buses during external reads. Use of the DBE is controlled by the NDBE bit in the PEAR register. DBE is enabled out of reset in expanded modes. 3.4.13 Inverted E clock (ECLK) The ECLK pin (PE7) can be used to latch the address for demultiplexing. It has the same behavior as the ECLK, except is inverted. In expanded modes this pin is used to enable the drive control of external buses during external reads. Use of the ECLK is controlled by the NDBE and DBENE bits in the PEAR register. 3.4.14 Calibration reference (CAL) The CAL pin (PE7) is the output of the Slow Mode programmable clock divider, SLWCLK, and is used as a calibration reference. The SLWCLK frequency is equal to the crystal frequency out of reset and always has a 50% duty. If the DBE function is enabled it will override the enabled CAL output. The CAL pin output is disabled by clearing CALE bit in the PEAR register. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Pinout and Signal Descriptions 53 Pinout and Signal Descriptions 3.4.15 Clock generation module test (CGMTST) The CGMTST pin (PE6) is the output of the clocks tested when CGMTE bit is set in PEAR register. The PIPOE bit must be cleared for the clocks to be tested. 3.4.16 TEST This pin is used for factory test purposes. It is recommended that this pin is not connected in the application, but it may be bonded to 5.5 V max without issue. Never apply voltage higher than 5.5 V to this pin Table 3-2. MC68HC912DT128A Signal Description Summary Pin Name Shared port EXTAL XTAL - RESET - ADDR[7:0] DATA[7:0] ADDR[15:8] DATA[15:8] Pin Number Description 112-pin 47 Crystal driver and external clock input pins. On reset all the device clocks are derived from the EXTAL input frequency. XTAL is the crystal output. 48 An active low bidirectional control signal, RESET acts as an input to initialize the 46 MCU to a known start-up state, and an output when COP or clock monitor causes a reset. PB[7:0] 31–24 PA[7:0] 64–57 DBE PE7 36 ECLK PE7 36 CAL PE7 36 CGMTST PE6 MODB/IPIP E1, PE6, PE5 MODA/IPIP E0 37 37, 38 ECLK PE4 39 LSTRB/TA GLO PE3 53 R/W PE2 54 External bus pins share function with general-purpose I/O ports A and B. In single chip modes, the pins can be used for I/O. In expanded modes, the pins are used for the external buses. Data bus control and, in expanded mode, enables the drive control of external buses during external reads. Inverted E clock used to latch the address. CAL is the output of the Slow Mode programmable clock divider, SLWCLK, and is used as a calibration reference for functions such as time of day. It is overridden when DBE function is enabled. It always has a 50% duty. Clock generation module test output. State of mode select pins during reset determine the initial operating mode of the MCU. After reset, MODB and MODA can be configured as instruction queue tracking signals IPIPE1 and IPIPE0 or as general-purpose I/O pins. E Clock is the output connection for the external bus clock. ECLK is used as a timing reference and for address demultiplexing. Low byte strobe (0 = low byte valid), in all modes this pin can be used as I/O. The low strobe function is the exclusive-NOR of A0 and the internal SZ8 signal. (The SZ8 internal signal indicates the size 16/8 access.) Pin function TAGLO used in instruction tagging. See Development Support. Indicates direction of data on expansion bus. Shares function with generalpurpose I/O. Read/write in expanded modes. Technical Data 54 MC68HC912DT128A — Rev 4.0 Pinout and Signal Descriptions MOTOROLA Pinout and Signal Descriptions Signal Descriptions Table 3-2. MC68HC912DT128A Signal Description Summary Pin Name Shared port Pin Number 112-pin Description Maskable interrupt request input provides a means of applying asynchronous interrupt requests to the MCU. Either falling edge-sensitive triggering or levelsensitive triggering is program selectable (INTCR register). Provides a means of requesting asynchronous nonmaskable interrupt requests XIRQ PE0 56 after reset initialization During reset, this pin determines special or normal operating mode. After reset, SMODN/ single-wire background interface pin is dedicated to the background debug BKGD/ 23 function. Pin function TAGHI used in instruction tagging. See Development TAGHI Support. IX[2:0] PK[2:0] 109-111 Page Index register emulation outputs. ECS PK7 108 Emulation Chip select. PW[3:0] PP[3:0] 112, 1–3 Pulse Width Modulator channel outputs. SS PS7 96 Slave select output for SPI master mode, input for slave mode or master mode. SCK PS6 95 Serial clock for SPI system. SDO/MOSI PS5 94 Master out/slave in pin for serial peripheral interface SDI/MISO PS4 93 Master in/slave out pin for serial peripheral interface TxD1 PS3 92 SCI1 transmit pin RxD1 PS2 91 SCI1 receive pin TxD0 PS1 90 SCI0 transmit pin RxD0 PS0 89 SCI0 receive pin 18–15, Pins used for input capture and output compare in the timer and pulse IOC[7:0] PT[7:0] 7–4 accumulator subsystem. 84/82/80/ AN1[7:0] PAD1[7:0] 78/76/74/ Analog inputs for the analog-to-digital conversion module 1 72/70 83/81/79/ AN0[7:0] PAD0[7:0] 77/75/73/ Analog inputs for the analog-to-digital conversion module 0 71/69 Used for factory test purposes. Do not connect in the application; may be TEST 97 bonded to 5.5 V max. IRQ PE1 55 TxCAN2(1) - 100 RxCAN2(1) - 101 TxCAN1 - 102 RxCAN1 - 103 TxCAN0 - 104 RxCAN0 - 105 SCL PIB7 98 MSCAN2 transmit pin (MC68HC912DT128A only). Leave unconnected if MSCAN2 is not used. MSCAN2 receive pin (MC68HC912DT128A only). Pin has internal pull-up; where msCAN module is not used, do not tie to VSS. MSCAN1 transmit pin. Leave unconnected if MSCAN1 is not used. MSCAN1 receive pin. Pin has internal pull-up; where msCAN module is not used, do not tie to VSS. MSCAN0 transmit pin. Leave unconnected if MSCAN0 is not used. MSCAN0 receive pin. Pin has internal pull-up; where msCAN module is not used, do not tie to VSS. I2C bus serial clock line pin MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Pinout and Signal Descriptions 55 Pinout and Signal Descriptions Table 3-2. MC68HC912DT128A Signal Description Summary Pin Name Shared port SDA PIB6 KWJ[7:0] PJ[7:0] KWH[7:0] PH[7:0] Pin Number 112-pin Description I2C bus serial data line pin 8–11, Key wake-up and general purpose I/O; can cause an interrupt when an input 19–22 transitions from high to low or from low to high (KWPJ). 32–35, Key wake-up and general purpose I/O; can cause an interrupt when an input 49–52 transitions from high to low or from low to high (KWPH). 99 1. MC68HC912DT128A only 3.5 Port Signals The MC68HC912DT128A incorporates eleven ports which are used to control and access the various device subsystems. When not used for these purposes, port pins may be used for general-purpose I/O. In addition to the pins described below, each port consists of a data register which can be read and written at any time, and, with the exception of port AD0, port AD1, PE[1:0], RxCAN and TxCAN, a data direction register which controls the direction of each pin. After reset all general purpose I/O pins are configured as input. 3.5.1 Port A Port A pins are used for address and data in expanded modes. When this port is not used for external access such as in single-chip mode, these pins can be used as general purpose I/O. The port data register is not in the address map during expanded and peripheral mode operation. When it is in the map, port A can be read or written at anytime. Register DDRA determines whether each port A pin is an input or output. DDRA is not in the address map during expanded and peripheral mode operation. Setting a bit in DDRA makes the corresponding bit in port A an output; clearing a bit in DDRA makes the corresponding bit in port A an input. The default reset state of DDRA is all zeroes. When the PUPA bit in the PUCR register is set, all port A input pins are pulled-up internally by an active pull-up device. PUCR is not in the address map in peripheral mode. Technical Data 56 MC68HC912DT128A — Rev 4.0 Pinout and Signal Descriptions MOTOROLA Pinout and Signal Descriptions Port Signals Setting the RDPA bit in register RDRIV causes all port A outputs to have reduced drive level. RDRIV can be written once after reset. RDRIV is not in the address map in peripheral mode. Refer to Bus Control and Input/Output. 3.5.2 Port B Port B pins are used for address and data in expanded modes. When this port is not used for external access such as in single-chip mode, these pins can be used as general purpose I/O. The port data register is not in the address map during expanded and peripheral mode operation. When it is in the map, port B can be read or written at anytime. Register DDRB determines whether each port B pin is an input or output. DDRB is not in the address map during expanded and peripheral mode operation. Setting a bit in DDRB makes the corresponding bit in port B an output; clearing a bit in DDRB makes the corresponding bit in port B an input. The default reset state of DDRB is all zeroes. When the PUPB bit in the PUCR register is set, all port B input pins are pulled-up internally by an active pull-up device. PUCR is not in the address map in peripheral mode. Setting the RDPB bit in register RDRIV causes all port B outputs to have reduced drive level. RDRIV can be written once after reset. RDRIV is not in the address map in peripheral mode. Refer to Bus Control and Input/Output. 3.5.3 Port E Port E pins operate differently from port A and B pins. Port E pins are used for bus control signals and interrupt service request signals. When a pin is not used for one of these specific functions, it can be used as general-purpose I/O. However, two of the pins (PE[1:0]) can only be used for input, and the states of these pins can be read in the port data register even when they are used for IRQ and XIRQ. The PEAR register determines pin function, and register DDRE determines whether each pin is an input or output when it is used for MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Pinout and Signal Descriptions 57 Pinout and Signal Descriptions general-purpose I/O. PEAR settings override DDRE settings. Because PE[1:0] are input-only pins, only DDRE[7:2] have effect. Setting a bit in the DDRE register makes the corresponding bit in port E an output; clearing a bit in the DDRE register makes the corresponding bit in port E an input. The default reset state of DDRE is all zeroes. When the PUPE bit in the PUCR register is set, PE[7,3,2,1,0] are pulled up. PE[7,3,2,0] are active pull-up devices. PUPCR is not in the address map in peripheral mode. Neither port E nor DDRE is in the map in peripheral mode or in the internal map in expanded modes with EME set. Setting the RDPE bit in register RDRIV causes all port E outputs to have reduced drive level. RDRIV can be written once after reset. RDRIV is not in the address map in peripheral mode. Refer to Bus Control and Input/Output. 3.5.4 Port H Port H pins are used for key wake-ups that can be used with the pins configured as inputs or outputs. The key wake-ups are triggered with either a rising or falling edge signal (KWPH). An interrupt is generated if the corresponding bit is enabled (KWIEH). If any of the interrupts is not enabled, the corresponding pin can be used as a general purpose I/O pin. Refer to I/O Ports with Key Wake-up. Register DDRH determines whether each port H pin is an input or output. Setting a bit in DDRH makes the corresponding bit in port H an output; clearing a bit in DDRH makes the corresponding bit in port H an input. The default reset state of DDRH is all zeroes. Register KWPH not only determines what type of edge the key wake ups are triggered, but it also determines what type of resistive load is used for port H input pins when PUPH bit is set in the PUCR register. Setting a bit in KWPH makes the corresponding key wake up input pin trigger at rising edges and loads a pull down in the corresponding port H input pin. Clearing a bit in KWPH makes the corresponding key wake up input pin trigger at falling edges and loads a pull up in the corresponding port H input pin. The default state of KWPH is all zeroes. Technical Data 58 MC68HC912DT128A — Rev 4.0 Pinout and Signal Descriptions MOTOROLA Pinout and Signal Descriptions Port Signals Setting the RDPH bit in register RDRIV causes all port H outputs to have reduced drive level. RDRIV can be written once after reset. RDRIV is not in the address map in peripheral mode. Refer to Bus Control and Input/Output. 3.5.5 Port J Port J pins are used for key wake-ups that can be used with the pins configured as inputs or outputs. The key wake-ups are triggered with either a rising or falling edge signal (KWPJ). An interrupt is generated if the corresponding bit is enabled (KWIEJ). If any of the interrupts is not enabled, the corresponding pin can be used as a general purpose I/O pin. Refer to I/O Ports with Key Wake-up. Register DDRJ determines whether each port J pin is an input or output. Setting a bit in DDRJ makes the corresponding bit in port J an output; clearing a bit in DDRJ makes the corresponding bit in port J an input. The default reset state of DDRJ is all zeroes. Register KWPJ not only determines what type of edge the key wake ups are triggered, but it also determines what type of resistive load is used for port J input pins when PUPJ bit is set in the PUCR register. Setting a bit in KWPJ makes the corresponding key wake up input pin trigger at rising edges and loads a pull down in the corresponding port J input pin. Clearing a bit in KWPJ makes the corresponding key wake up input pin trigger at falling edges and loads a pull up in the corresponding port J input pin. The default state of KWPJ is all zeroes. Setting the RDPJ bit in register RDRIV causes all port J outputs to have reduced drive level. RDRIV can be written once after reset. RDRIV is not in the address map in peripheral mode. Refer to Bus Control and Input/Output. 3.5.6 Port K Port K pins are used for page index emulation in expanded or peripheral modes. When page index emulation is not enabled, EMK is not set in MODE register, or the part is in single chip mode, these pins can be used MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Pinout and Signal Descriptions 59 Pinout and Signal Descriptions for general purpose I/O. Port K bit 3 is used as a general purpose I/O pin only. The port data register is not in the address map during expanded and peripheral mode operation with EMK set. When it is in the map, port K can be read or written at anytime. Register DDRK determines whether each port K pin is an input or output. DDRK is not in the address map during expanded and peripheral mode operation with EMK set. Setting a bit in DDRK makes the corresponding bit in port K an output; clearing a bit in DDRK makes the corresponding bit in port K an input. The default reset state of DDRK is all zeroes. When the PUPK bit in the PUCR register is set, all port K input pins are pulled-up internally by an active pull-up device. PUCR is not in the address map in peripheral mode. Setting the RDPK bit in register RDRIV causes all port K outputs to have reduced drive level. RDRIV can be written once after reset. RDRIV is not in the address map in peripheral mode. Refer to Bus Control and Input/Output. 3.5.7 Port CAN2 (MC68HC912DT128A only) The MSCAN2 uses two external pins, one input (RxCAN2) and one output (TxCAN2). The TxCAN2 output pin represents the logic level on the CAN: ‘0’ is for a dominant state, and ‘1’ is for a recessive state. RxCAN2 is on bit 0 of Port CAN2, TxCAN2 is on bit 1. If the MSCAN2 is not used, TxCAN2 should be left unconnected and, due to an internal pull-up, the RxCAN2 pin should not be tied to VSS. 3.5.8 Port CAN1 The MSCAN1 uses two external pins, one input (RxCAN1) and one output (TxCAN1). The TxCAN1 output pin represents the logic level on the CAN: ‘0’ is for a dominant state, and ‘1’ is for a recessive state. RxCAN1 is on bit 0 of Port CAN1, TxCAN1 is on bit 1. If the MSCAN1 is not used, TxCAN1 should be left unconnected and, due to an internal pull-up, the RxCAN1 pin should not be tied to VSS. Technical Data 60 MC68HC912DT128A — Rev 4.0 Pinout and Signal Descriptions MOTOROLA Pinout and Signal Descriptions Port Signals 3.5.9 Port CAN0 The MSCAN0 uses two external pins, one input (RxCAN0) and one output (TxCAN0). The TxCAN0 output pin represents the logic level on the CAN: ‘0’ is for a dominant state, and ‘1’ is for a recessive state. RxCAN0 is on bit 0 of Port CAN0, TxCAN0 is on bit 1. If the MSCAN0 is not used, TxCAN0 should be left unconnected and, due to an internal pull-up, the RxCAN0 pin should not be tied to VSS. 3.5.10 Port IB Bidirectional pins to IIC bus interface subsystem. The IIC bus interface uses a Serial Data line (SDA) and Serial Clock line (SCL) for data transfer. The pins are connected to a positive voltage supply via a pull up resistor. The pull ups can be enabled internally or connected externally. The output stages have open drain outputs in order to perform the wired-AND function. When the IIC is disabled the pins can be used as general purpose I/O pins. SCL is on bit 7 of Port IB and SDA is on bit 6. On the MC68HC912DG128A, the remaining two pins of Port IB (PIB5 and PIB4) are controlled by registers in the IIC address space. Register DDRIB determines pin direction of port IB when used for general-purpose I/O. When DDRIB bits are set, the corresponding pin is configured for output. On reset the DDRIB bits are cleared and the corresponding pin is configured for input. When the PUPIB bit in the IBPURD register is set, all input pins are pulled up internally by an active pull-up device. Pullups are disabled after reset, except for input ports 0 through 5, which are always on regardless of PUPIB bit. Setting the RDPIB bit in the IBPURD register configures all port IB outputs to have reduced drive levels. Levels are at normal drive capability after reset. The IBPURD register can be read or written anytime after reset. Refer to section Inter IC Bus. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Pinout and Signal Descriptions 61 Pinout and Signal Descriptions 3.5.11 Port AD1 This port is an analog input interface to the analog-to-digital subsystem and used for general-purpose input. When analog-to-digital functions are not enabled, the port has eight general-purpose input pins, PAD1[7:0]. The ADPU bit in the ATD1CTL2 register enables the A/D function. Port AD1 pins are inputs; no data direction register is associated with this port. The port has no resistive input loads and no reduced drive controls. Refer to Analog-to-Digital Converter. 3.5.12 Port AD0 This port is an analog input interface to the analog-to-digital subsystem and used for general-purpose input. When analog-to-digital functions are not enabled, the port has eight general-purpose input pins, PAD0[7:0]. The ADPU bit in the ATD0CTL2 register enables the A/D function. Port AD0 pins are inputs; no data direction register is associated with this port. The port has no resistive input loads and no reduced drive controls. Refer to Analog-to-Digital Converter. 3.5.13 Port P The four pulse-width modulation channel outputs share general-purpose port P pins. The PWM function is enabled with the PWEN register. Enabling PWM pins takes precedence over the general-purpose port. When pulse-width modulation is not in use, the port pins may be used for general-purpose I/O. Register DDRP determines pin direction of port P when used for general-purpose I/O. When DDRP bits are set, the corresponding pin is configured for output. On reset the DDRP bits are cleared and the corresponding pin is configured for input. When the PUPP bit in the PWCTL register is set, all input pins are pulled up internally by an active pull-up device. Pullups are disabled after reset. Technical Data 62 MC68HC912DT128A — Rev 4.0 Pinout and Signal Descriptions MOTOROLA Pinout and Signal Descriptions Port Signals Setting the RDPP bit in the PWCTL register configures all port P outputs to have reduced drive levels. Levels are at normal drive capability after reset. The PWCTL register can be read or written anytime after reset. Refer to Pulse Width Modulator. 3.5.14 Port S Port S is the 8-bit interface to the standard serial interface consisting of the two serial communications interfaces (SCI1 and SCI0) and the serial peripheral interface (SPI) subsystems. Port S pins are available for general-purpose I/O when standard serial functions are not enabled. Port S pins serve several functions depending on the various internal control registers. If WOMS bit in the SC0CR1register is set, the Pchannel drivers of the output buffers are disabled (wire-or mode) for pins 0 through 3. If SWOM bit in the SP0CR1 register is set, the P-channel drivers of the output buffers are disabled (wire-or mode) for pins 4 through 7. The open drain control affects both the serial and the generalpurpose outputs. If the RDPS bit in the SP0CR2 register is set, Port S pin drive capabilities are reduced. If PUPS bit in the SP0CR2 register is set, a pull-up device is activated for each port S pin programmed as a general purpose input. If the pin is programmed as a general-purpose output, the pull-up is disconnected from the pin regardless of the state of PUPS bit. See Multiple Serial Interface. 3.5.15 Port T This port provides eight general-purpose I/O pins when not enabled for input capture and output compare in the timer and pulse accumulator subsystem. The TEN bit in the TSCR register enables the timer function. The pulse accumulator subsystem is enabled with the PAEN bit in the PACTL register. Register DDRT determines pin direction of port T when used for generalpurpose I/O. When DDRT bits are set, the corresponding pin is configured for output. On reset the DDRT bits are cleared and the corresponding pin is configured for input. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Pinout and Signal Descriptions 63 Pinout and Signal Descriptions When the PUPT bit in the TMSK2 register is set, all input pins are pulled up internally by an active pull-up device. Pullups are disabled after reset. Setting the RDPT bit in the TMSK2 register configures all port T outputs to have reduced drive levels. Levels are at normal drive capability after reset. The TMSK2 register can be read or written anytime after reset. Refer to Enhanced Capture Timer. Table 3-3. MC68HC912DT128A Port Description Summary Port Name Pin Numbers 112-pin Data Direction Register (Address) Port A PA[7:0] 64-57 In/Out DDRA ($0002) Port B PB[7:0] 31–24 In/Out DDRB ($0003) Port AD1 PAD1[7:0] Port AD0 PAD0[7:0] 84/82/80/7 8/76/74/72 /70 83/81/79/7 7/75/73/71 /69 Port CAN2 PCAN2[1:0] 100–101 (1) Port CAN1 PCAN1[1:0] Port CAN0 PCAN0[1:0] 102–103 104–105 Description Port A and port B pins are used for address and data in expanded modes. The port data registers are not in the address map during expanded and peripheral mode operation. When in the map, port A and port B can be read or written any time. DDRA and DDRB are not in the address map in expanded or peripheral modes. In Analog-to-digital converter 1 and general-purpose I/O. In Analog-to-digital converter 0 and general-purpose I/O. PCAN2[1] Out PCAN2[0] In PCAN2[1:0] are used with the MSCAN2 module and cannot be used as general purpose I/O (MC68HC912DT128A only). PCAN1[1] Out PCAN1[0] In PCAN0[1] Out PCAN0[0] In PCAN1[1:0] are used with the MSCAN1 module and cannot be used as general purpose I/O. PCAN0[1:0] are used with the MSCAN0 module and cannot be used as general purpose I/O. Port IB PIB[7:6] 98–99 In/Out DDRIB ($00E7) General purpose I/O. PIB[7:6] are used with the I-Bus module when enabled. Port IB PIB[5:4](2) 100–101 In/Out DDRIB ($00E7) General purpose I/O (MC68HC912DG128A only). Port E PE[7:0] 36–39, 53–56 Port K PK[7,3:0] Port P PP[3:0] 13, 108-111 112, 1–3 PE[1:0] In PE[7:2] In/Out DDRE ($0009) In/Out DDRK ($00FD) In/Out DDRP ($0057) Mode selection, bus control signals and interrupt service request signals; or general-purpose I/O. Page index emulation signals in expanded or peripheral mode or general-purpose I/O. General-purpose I/O. PP[3:0] are used with the pulse-width modulator when enabled. Technical Data 64 MC68HC912DT128A — Rev 4.0 Pinout and Signal Descriptions MOTOROLA Pinout and Signal Descriptions Table 3-3. MC68HC912DT128A Port Description Summary Port Name Pin Numbers 112-pin Data Direction Register (Address) Port S PS[7:0] 96–89 In/Out DDRS ($00D7) Port T PT[7:0] 18–15, 7–4 In/Out DDRT ($00AF) Description Serial communications interfaces 1 and 0 and serial peripheral interface subsystems; or general-purpose I/O. General-purpose I/O when not enabled for input capture and output compare in the timer and pulse accumulator subsystem. 1. MC68HC912DT128A only 2. MC68HC912DG128A only 3.5.16 Port Pull-Up Pull-Down and Reduced Drive MCU ports can be configured for internal pull-up. To reduce power consumption and RFI, the pin output drivers can be configured to operate at a reduced drive level. Reduced drive causes a slight increase in transition time depending on loading and should be used only for ports which have a light loading. Table 3-4 summarizes the port pull-up default status and controls. Table 3-4. Port Pull-Up, Pull-Down and Reduced Drive Summary Port Resistive Name Input Loads Port A Pull-up Port B Pull-up Port E: PE7, PE[3:2] Pull-up PE[1:0] Pull-up PE[6:4] None Pull-up or Port H Pull-down Pull-up or Port J Pull-down Port K Pull-up Port P Pull-up Port S Pull-up Port T Pull-up Port IB[7:6] Pull-up Enable Bit Register Reset Bit Name (Address) State PUCR ($000C) PUPA Disabled PUCR ($000C) PUPB Disabled Reduced Drive Control Bit Register Reset Bit Name (Address) State RDRIV ($000D) RDPA Full drive RDRIV ($000D) RDPB Full drive PUCR ($000C) PUCR ($000C) RDRIV ($000D) PUPE PUPE Enabled Enabled — Full drive PUCR ($000C) PUPH Disabled RDRIV ($000D) RDPH Full drive PUCR ($000C) PUPJ Disabled RDRIV ($000D) RDPJ Full drive PUCR ($000C) PWCTL ($0054) SP0CR2 ($00D1) TMSK2 ($008D) IBPURD ($00E5) PUPK PUPP PUPS TPU PUPIB Disabled Disabled Enabled Disabled Disabled RDRIV ($000D) PWCTL ($0054) SP0CR2 ($00D1) TMSK2 ($008D) IBPURD ($00E5) RDPK RDPP RDPS TDRB RDPIB Full drive Full drive Full drive Full drive Full drive Technical Data 65 Full drive RDRIV ($000D) RDPE — RDPE MC68HC912DT128A — Rev 4.0 Pinout and Signal Descriptions MOTOROLA Pinout and Signal Descriptions Table 3-4. Port Pull-Up, Pull-Down and Reduced Drive Summary Enable Bit Port Name Resistive Input Loads Register (Address) Bit Name Port IB[5:4](1) Port AD0 Port AD1 Port CAN2[1](2) Port CAN2[0](2) Port CAN1[1] Port CAN1[0] Port CAN0[1] Port CAN0[0] Pull-up IBPURD ($00E5) PUPIB Reset State Reduced Drive Control Bit Register Reset Bit Name (Address) State Disabled IBPURD ($00E5) RDPIB None None — — — — None — — Pull-up Always enabled — None Pull-up None Pull-up — Always enabled — Always enabled — — — — Full drive 1. MC68HC912DG128A only 2. MC68HC912DT128A only Technical Data 66 MC68HC912DT128A — Rev 4.0 Pinout and Signal Descriptions MOTOROLA Technical Data — MC68HC912DT128A Section 4. Registers 4.1 Contents 4.2 Register Block. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .67 4.2 Register Block The register block can be mapped to any 2K byte boundary within the standard 64K byte address space by manipulating bits REG[15:11] in the INITRG register. INITRG establishes the upper five bits of the register block’s 16-bit address. The register block occupies the first 1K byte of the 2K byte block. Default addressing (after reset) is indicated in the table below. For additional information refer to Operating Modes. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Registers 67 Registers Address Bit 7 6 5 4 3 2 1 Bit 0 Name $0000 PA7 PA6 PA5 PA4 PA3 PA2 PA1 PA0 PORTA(1) $0001 PB7 PB6 PB5 PB4 PB3 PB2 PB1 PB0 PORTB(1) $0002 DDA7 DDA6 DDA5 DDA4 DDA3 DDA2 DDA1 DDA0 DDRA(1) $0003 DDB7 DDB6 DDB5 DDB4 DDB3 DDB2 DDB1 DDB0 DDRB(1) $0004$0007 0 0 0 0 0 0 0 0 Reserved(3) $0008 PE7 PE6 PE5 PE4 PE3 PE2 PE1 PE0 PORTE(2) $0009 DDE7 DDE6 DDE5 DDE4 DDE3 DDE2 0 0 DDRE(2) $000A NDBE CGMTE PIPOE NECLK LSTRE RDWE CALE DBENE PEAR(3) $000B SMODN MODB MODA ESTR IVIS EBSWAI EMK EME MODE(3) $000C PUPK PUPJ PUPH PUPE 0 0 PUPB PUPA PUCR(3) $000D RDPK RDPJ RDPH RDPE 0 0 RDPB RDPA RDRIV(3) $000E 0 0 0 0 0 0 0 0 Reserved(3) $000F 0 0 0 0 0 0 0 0 Reserved(3) $0010 RAM15 RAM14 RAM13 0 0 0 0 0 INITRM $0011 REG15 REG14 REG13 REG12 REG11 0 0 MMSWAI INITRG $0012 EE15 EE14 EE13 EE12 0 0 0 EEON INITEE $0013 ROMTST NDRF RFSTR1 RFSTR0 EXSTR1 EXSTR0 ROMHM ROMON MISC $0014 RTIE RSWAI RSBCK Reserved RTBYP RTR2 RTR1 RTR0 RTICTL $0015 RTIF 0 0 0 0 0 0 0 RTIFLG $0016 CME FCME FCMCOP WCOP DISR CR2 CR1 CR0 COPCTL $0017 Bit 7 6 5 4 3 2 1 Bit 0 COPRST $0018 ITE6 ITE8 ITEA ITEC ITEE ITF0 ITF2 ITF4 ITST0 $0019 ITD6 ITD8 ITDA ITDC ITDE ITE0 ITE2 ITE4 ITST1 $001A ITC6 ITC8 ITCA ITCC ITCE ITD0 ITD2 ITD4 ITST2 $001B ITB6 ITB8 ITBA ITBC ITBE ITC0 ITC2 ITC4 ITST3 $001C ITA6 ITA8 ITAA ITAC ITAE ITB0 ITB2 ITB4 ITST4 $001D 0 0 0 0 0 0 0 0 Reserved $001E IRQE IRQEN DLY 0 0 0 0 0 INTCR $001F 1 PSEL6 PSEL5 PSEL4 PSEL3 PSEL2 PSEL1 0 HPRIO $0020 BKEN1 BKEN0 BKPM 0 BK1ALE BK0ALE 0 0 BRKCT0 $0021 0 BKDBE BKMBH BKMBL BK1RWE BK1RW BK0RWE BK0RW BRKCT1 $0022 Bit 15 14 13 12 11 10 9 Bit 8 BRKAH $0023 Bit 7 6 5 4 3 2 1 Bit 0 BRKAL Table 4-1. Register Map (Sheet 1 of 11) Technical Data 68 MC68HC912DT128A — Rev 4.0 Registers MOTOROLA Registers Register Block Address Bit 7 6 5 4 3 2 1 Bit 0 Name $0024 Bit 15 14 13 12 11 10 9 Bit 8 BRKDH $0025 Bit 7 6 5 4 3 2 1 Bit 0 BRKDL $0026 0 0 0 0 0 0 0 0 Reserved $0027 0 0 0 0 0 0 0 0 Reserved $0028 PJ7 PJ6 PJ5 PJ4 PJ3 PJ2 PJ1 PJ0 PORTJ $0029 PH7 PH6 PH5 PH4 PH3 PH2 PH1 PH0 PORTH $002A DDJ7 DDJ6 DDJ5 DDJ4 DDJ3 DDJ2 DDJ1 DDJ0 DDRJ $002B DDH7 DDH6 DDH5 DDH4 DDH3 DDH2 DDH1 DDH0 DDRH $002C KWIEJ7 KWIEJ6 KWIEJ5 KWIEJ4 KWIEJ3 KWIEJ2 KWIEJ1 KWIEJ0 KWIEJ $002D KWIEH7 KWIEH6 KWIEH5 KWIEH4 KWIEH3 KWIEH2 KWIEH1 KWIEH0 KWIEH $002E KWIFJ7 KWIFJ6 KWIFJ5 KWIFJ4 KWIFJ3 KWIFJ2 KWIFJ1 KWIFJ0 KWIFJ $002F KWIFH7 KWIFH6 KWIFH5 KWIFH4 KWIFH3 KWIFH2 KWIFH1 KWIFH0 KWIFH $0030 KWPJ7 KWPJ6 KWPJ5 KWPJ4 KWPJ3 KWPJ2 KWPJ1 KWPJ0 KWPJ $0031 KWPH7 KWPH6 KWPH5 KWPH4 KWPH3 KWPH2 KWPH1 KWPH0 KWPH $0032 0 0 0 0 0 0 0 0 Reserved $0033 0 0 0 0 0 0 0 0 Reserved $0034– $0037 Unimplemented(4) Reserved $0038 0 0 SYN5 SYN4 SYN3 SYN2 SYN1 SYN0 SYNR $0039 0 0 0 0 0 REFDV2 REFDV1 REFDV0 REFDV $003A TSTOUT7 TSTOUT6 TSTOUT5 TSTOUT4 TSTOUT3 TSTOUT2 TSTOUT1 TSTOUT0 CGTFLG $003B LOCKIF LOCK 0 0 0 0 LHIF LHOME PLLFLG $003C LOCKIE PLLON AUTO ACQ 0 PSTP LHIE NOLHM PLLCR $003D 0 BCSP BCSS 0 0 MCS 0 0 CLKSEL $003E 0 0 SLDV5 SLDV4 SLDV3 SLDV2 SLDV1 SLDV0 SLOW $003F OPNLE TRK TSTCLKE TST4 TST3 TST2 TST1 TST0 CGTCTL $0040 CON23 CON01 PCKA2 PCKA1 PCKA0 PCKB2 PCKB1 PCKB0 PWCLK $0041 PCLK3 PCLK2 PCLK1 PCLK0 PPOL3 PPOL2 PPOL1 PPOL0 PWPOL $0042 0 0 0 0 PWEN3 PWEN2 PWEN1 PWEN0 PWEN $0043 0 Bit 6 5 4 3 2 1 Bit 0 PWPRES $0044 Bit 7 6 5 4 3 2 1 Bit 0 PWSCAL0 $0045 Bit 7 6 5 4 3 2 1 Bit 0 PWSCNT0 $0046 Bit 7 6 5 4 3 2 1 Bit 0 PWSCAL1 $0047 Bit 7 6 5 4 3 2 1 Bit 0 PWSCNT1 $0048 Bit 7 6 5 4 3 2 1 Bit 0 PWCNT0 $0049 Bit 7 6 5 4 3 2 1 Bit 0 PWCNT1 $004A Bit 7 6 5 4 3 2 1 Bit 0 PWCNT2 $004B Bit 7 6 5 4 3 2 1 Bit 0 PWCNT3 Table 4-1. Register Map (Sheet 2 of 11) MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Registers 69 Registers Address Bit 7 6 5 4 3 2 1 Bit 0 Name $004C Bit 7 6 5 4 3 2 1 Bit 0 PWPER0 $004D Bit 7 6 5 4 3 2 1 Bit 0 PWPER1 $004E Bit 7 6 5 4 3 2 1 Bit 0 PWPER2 $004F Bit 7 6 5 4 3 2 1 Bit 0 PWPER3 $0050 Bit 7 6 5 4 3 2 1 Bit 0 PWDTY0 $0051 Bit 7 6 5 4 3 2 1 Bit 0 PWDTY1 $0052 Bit 7 6 5 4 3 2 1 Bit 0 PWDTY2 $0053 Bit 7 6 5 4 3 2 1 Bit 0 PWDTY3 $0054 0 0 0 PSWAI CENTR RDPP PUPP PSBCK PWCTL $0055 DISCR DISCP DISCAL 0 0 0 0 0 PWTST $0056 PP7 PP6 PP5 PP4 PP3 PP2 PP1 PP0 PORTP $0057 DDP7 DDP6 DDP5 DDP4 DDP3 DDP2 DDP1 DDP0 DDRP $0058$005F 0 0 0 0 0 0 0 0 Reserved $0060 Reserved ATD0CTL0 $0061 Reserved ATD0CTL1 $0062 ADPU AFFC ASWAI DJM DSGN Reserved ASCIE ASCIF ATD0CTL2 $0063 0 0 0 0 S1C FIFO FRZ1 FRZ0 ATD0CTL3 $0064 RES10 SMP1 SMP0 PRS4 PRS3 PRS2 PRS1 PRS0 ATD0CTL4 $0065 0 S8C SCAN MULT CD CC CB CA ATD0CTL5 $0066 SCF 0 0 0 0 CC2 CC1 CC0 ATD0STAT0 $0067 CCF7 CCF6 CCF5 CCF4 CCF3 CCF2 CCF1 CCF0 ATD0STAT1 $0068 SAR9 SAR8 SAR7 SAR6 SAR5 SAR4 SAR3 SAR2 ATD0TESTH $0069 SAR1 SAR0 RST TSTOUT TST3 TST2 TST1 TST0 ATD0TESTL $006A–$ 006E 0 0 0 0 0 0 0 0 Reserved $006F PAD07 PAD06 PAD05 PAD04 PAD03 PAD02 PAD01 PAD00 PORTAD0 $0070 Bit 15 14 13 12 11 10 9 Bit 8 ADR00H $0071 Bit 7 Bit 6 0 0 0 0 0 0 ADR00L $0072 Bit 15 14 13 12 11 10 9 Bit 8 ADR01H $0073 Bit 7 Bit 6 0 0 0 0 0 0 ADR01L $0074 Bit 15 14 13 12 11 10 9 Bit 8 ADR02H $0075 Bit 7 Bit 6 0 0 0 0 0 0 ADR02L $0076 Bit 15 14 13 12 11 10 9 Bit 8 ADR03H $0077 Bit 7 Bit 6 0 0 0 0 0 0 ADR03L $0078 Bit 15 14 13 12 11 10 9 Bit 8 ADR04H $0079 Bit 7 Bit 6 0 0 0 0 0 0 ADR04L $007A Bit 15 14 13 12 11 10 9 Bit 8 ADR05H $007B Bit 7 Bit 6 0 0 0 0 0 0 ADR05L Table 4-1. Register Map (Sheet 3 of 11) Technical Data 70 MC68HC912DT128A — Rev 4.0 Registers MOTOROLA Registers Register Block Address Bit 7 6 5 4 3 2 1 Bit 0 Name $007C Bit 15 14 13 12 11 10 9 Bit 8 ADR06H $007D Bit 7 Bit 6 0 0 0 0 0 0 ADR06L $007E Bit 15 14 13 12 11 10 9 Bit 8 ADR07H $007F Bit 7 Bit 6 0 0 0 0 0 0 ADR07L $0080 IOS7 IOS6 IOS5 IOS4 IOS3 IOS2 IOS1 IOS0 TIOS $0081 FOC7 FOC6 FOC5 FOC4 FOC3 FOC2 FOC1 FOC0 CFORC $0082 OC7M7 OC7M6 OC7M5 OC7M4 OC7M3 OC7M2 OC7M1 OC7M0 OC7M $0083 OC7D7 OC7D6 OC7D5 OC7D4 OC7D3 OC7D2 OC7D1 OC7D0 OC7D $0084 Bit 15 14 13 12 11 10 9 Bit 8 TCNT $0085 Bit 7 6 5 4 3 2 1 Bit 0 $0086 TEN TSWAI TSBCK TFFCA $0087 Reserved Reserved $0088 OM7 OL7 OM6 OL6 TCNT TSCR TQCR OM5 OL5 OM4 OL4 TCTL1 $0089 OM3 OL3 OM2 OL2 OM1 OL1 OM0 OL0 TCTL2 $008A EDG7B EDG7A EDG6B EDG6A EDG5B EDG5A EDG4B EDG4A TCTL3 $008B EDG3B EDG3A EDG2B EDG2A EDG1B EDG1A EDG0B EDG0A TCTL4 $008C C7I C6I C5I C4I C3I C2I C1I C0I TMSK1 $008D TOI 0 PUPT RDPT TCRE PR2 PR1 PR0 TMSK2 $008E C7F C6F C5F C4F C3F C2F C1F C0F TFLG1 $008F TOF 0 0 0 0 0 0 0 TFLG2 $0090 Bit 15 14 13 12 11 10 9 Bit 8 TC0 $0091 Bit 7 6 5 4 3 2 1 Bit 0 TC0 $0092 Bit 15 14 13 12 11 10 9 Bit 8 TC1 $0093 Bit 7 6 5 4 3 2 1 Bit 0 TC1 $0094 Bit 15 14 13 12 11 10 9 Bit 8 TC2 $0095 Bit 7 6 5 4 3 2 1 Bit 0 TC2 $0096 Bit 15 14 13 12 11 10 9 Bit 8 TC3 $0097 Bit 7 6 5 4 3 2 1 Bit 0 TC3 $0098 Bit 15 14 13 12 11 10 9 Bit 8 TC4 $0099 Bit 7 6 5 4 3 2 1 Bit 0 TC4 $009A Bit 15 14 13 12 11 10 9 Bit 8 TC5 $009B Bit 7 6 5 4 3 2 1 Bit 0 TC5 $009C Bit 15 14 13 12 11 10 9 Bit 8 TC6 $009D Bit 7 6 5 4 3 2 1 Bit 0 TC6 $009E Bit 15 14 13 12 11 10 9 Bit 8 TC7 $009F Bit 7 6 5 4 3 2 1 Bit 0 TC7 $00A0 0 PAEN PAMOD PEDGE CLK1 CLK0 PAOVI PAI PACTL $00A1 0 0 0 0 0 0 PAOVF PAIF PAFLG Table 4-1. Register Map (Sheet 4 of 11) MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Registers 71 Registers Address Bit 7 6 5 4 3 2 1 Bit 0 Name $00A2 Bit 7 6 5 4 3 2 1 Bit 0 PACN3 $00A3 Bit 7 6 5 4 3 2 1 Bit 0 PACN2 $00A4 Bit 7 6 5 4 3 2 1 Bit 0 PACN1 $00A5 Bit 7 6 5 4 3 2 1 Bit 0 PACN0 $00A6 MCZI MODMC RDMCL ICLAT FLMC MCEN MCPR1 MCPR0 MCCTL $00A7 MCZF 0 0 0 POLF3 POLF2 POLF1 POLF0 MCFLG $00A8 0 0 0 0 PA3EN PA2EN PA1EN PA0EN ICPAR $00A9 0 0 0 0 0 0 DLY1 DLY0 DLYCT $00AA NOVW7 NOVW6 NOVW5 NOVW4 NOVW3 NOVW2 NOVW1 NOVW0 ICOVW $00AB SH37 SH26 SH15 SH04 TFMOD PACMX BUFEN LATQ ICSYS $00AC 0 0 0 0 0 0 0 0 Reserved $00AD 0 0 0 0 0 0 TCBYP 0 TIMTST $00AE PT7 PT6 PT5 PT4 PT3 PT2 PT1 PT0 PORTT $00AF DDT7 DDT6 DDT5 DDT4 DDT3 DDT2 DDT1 DDT0 DDRT $00B0 0 PBEN 0 0 0 0 PBOVI 0 PBCTL $00B1 0 0 0 0 0 0 PBOVF 0 PBFLG $00B2 Bit 7 6 5 4 3 2 1 Bit 0 PA3H $00B3 Bit 7 6 5 4 3 2 1 Bit 0 PA2H $00B4 Bit 7 6 5 4 3 2 1 Bit 0 PA1H $00B5 Bit 7 6 5 4 3 2 1 Bit 0 PA0H $00B6 Bit 15 14 13 12 11 10 9 Bit 8 MCCNTH $00B7 Bit 7 6 5 4 3 2 1 Bit 0 MCCNTL $00B8 Bit 15 14 13 12 11 10 9 Bit 8 TC0H $00B9 Bit 7 6 5 4 3 2 1 Bit 0 TC0H $00BA Bit 15 14 13 12 11 10 9 Bit 8 TC1H $00BB Bit 7 6 5 4 3 2 1 Bit 0 TC1H $00BC Bit 15 14 13 12 11 10 9 Bit 8 TC2H $00BD Bit 7 6 5 4 3 2 1 Bit 0 TC2H $00BE Bit 15 14 13 12 11 10 9 Bit 8 TC3H $00BF Bit 7 6 5 4 3 2 1 Bit 0 TC3H $00C0 BTST BSPL BRLD SBR12 SBR11 SBR10 SBR9 SBR8 SC0BDH $00C1 SBR7 SBR6 SBR5 SBR4 SBR3 SBR2 SBR1 SBR0 SC0BDL $00C2 LOOPS WOMS RSRC M WAKE ILT PE PT SC0CR1 $00C3 TIE TCIE RIE ILIE TE RE RWU SBK SC0CR2 $00C4 TDRE TC RDRF IDLE OR NF FE PF SC0SR1 $00C5 0 0 0 0 0 0 0 RAF SC0SR2 $00C6 R8 T8 0 0 0 0 0 0 SC0DRH $00C7 R7/T7 R6/T6 R5/T5 R4/T4 R3/T3 R2/T2 R1/T1 R0/T0 SC0DRL Table 4-1. Register Map (Sheet 5 of 11) Technical Data 72 MC68HC912DT128A — Rev 4.0 Registers MOTOROLA Registers Register Block Address Bit 7 6 5 4 3 2 1 Bit 0 Name $00C8 BTST BSPL BRLD SBR12 SBR11 SBR10 SBR9 SBR8 SC1BDH $00C9 SBR7 SBR6 SBR5 SBR4 SBR3 SBR2 SBR1 SBR0 SC1BDL $00CA LOOPS WOMS RSRC M WAKE ILT PE PT SC1CR1 $00CB TIE TCIE RIE ILIE TE RE RWU SBK SC1CR2 $00CC TDRE TC RDRF IDLE OR NF FE PF SC1SR1 $00CD 0 0 0 0 0 0 0 RAF SC1SR2 $00CE R8 T8 0 0 0 0 0 0 SC1DRH $00CF R7/T7 R6/T6 R5/T5 R4/T4 R3/T3 R2/T2 R1/T1 R0/T0 SC1DRL $00D0 SPIE SPE SWOM MSTR CPOL CPHA SSOE LSBF SP0CR1 $00D1 0 0 0 0 PUPS RDPS SSWAI SPC0 SP0CR2 $00D2 0 0 0 0 0 SPR2 SPR1 SPR0 SP0BR $00D3 SPIF WCOL 0 MODF 0 0 0 0 SP0SR $00D4 0 0 0 0 0 0 0 0 Reserved $00D5 Bit 7 6 5 4 3 2 1 Bit 0 SP0DR $00D6 PS7 PS6 PS5 PS4 PS3 PS2 PS1 PS0 PORTS $00D7 DDS7 DDS6 DDS5 DDS4 DDS3 DDS2 DDS1 DDS0 DDRS $00D8–$ 00DF 0 0 0 0 0 0 0 0 Reserved $00E0 ADR7 ADR6 ADR5 ADR4 ADR3 ADR2 ADR1 0 IBAD $00E1 0 0 IBC5 IBC4 IBC3 IBC2 IBC1 IBC0 IBFD $00E2 IBEN IBIE MS/SL Tx/Rx TXAK RSTA 0 IBSWAI IBCR $00E3 TCF IAAS IBB IBAL 0 SRW IBIF RXAK IBSR $00E4 D7 D6 D5 D4 D3 D2 D1 D0 IBDR $00E5 0 0 0 RDPIB 0 0 0 PUPIB IBPURD $00E6 PIB7 PIB6 PIB5 PIB4 PIB3 PIB2 PIB1 PIB0 PORTIB $00E7 DDRIB7 DDRIB6 DDRIB5 DDRIB4 DDRIB3 DDRIB2 DDRIB1 DDRIB0 DDRIB $00E8– $00EB Unimplemented(4) $00EC–$ 00ED 0 0 0 0 0 Reserved 0 0 0 Reserved $00EE 0 0 0 0 0 0 EEDIV9 EEDIV8 EEDIVH $00EF EEDIV7 EEDIV6 EEDIV5 EEDIV4 EEDIV3 EEDIV2 EEDIV1 EEDIV0 EEDIVL FPOPEN(5) 1 EERC EEMCR BPROT4 BPROT3 BPROT2 BPROT0 EEPROT $00F0 NOBDML NOSHW Reserved $00F1 SHPROT 1 $00F2 0 EREVTN 0 0 0 ETMSD ETMR ETMSE EETST $00F3 BULKP 0 AUTO BYTE ROW ERASE EELAT EEPGM EEPROG $00F4 0 0 0 0 0 0 0 LOCK FEELCK $00F5 0 0 0 0 0 0 0 BOOTP FEEMCR $00F6 STRE REVTUN 0 0 0 TMSD TMR TMSE FEETST BPROT5 EESWAI PROTLCK BPROT1 Table 4-1. Register Map (Sheet 6 of 11) MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Registers 73 Registers Address Bit 7 6 5 4 3 2 1 Bit 0 Name $00F7 0 0 0 FEESWAI HVEN 0 ERAS PGM FEECTL $00F8 MT07 MT06 MT05 MT04 MT03 MT02 MT01 MT00 MTST0 $00F9 MT0F MT0E MT0D MT0C MT0B MT0A MT09 MT08 MTST1 $00FA MT17 MT16 MT15 MT14 MT13 MT12 MT11 MT10 MTST2 $00FB MT1F MT1E MT1D MT1C MT1B MT1A MT19 MT18 MTST3 $00FC PK7 0 0 0 PK3 PK2 PK1 PK0 PORTK(6) $00FD DDK7 0 0 0 DDK3 DDK2 DDK1 DDK0 DDRK(6) $00FE 0 0 0 0 0 0 0 0 Reserved $00FF 0 0 0 0 0 PIX2 PIX1 PIX0 PPAGE $0100 0 0 CSWAI SYNCH TLNKEN SLPAK SLPRQ SFTRES C0MCR0 $0101 0 0 0 0 0 LOOPB WUPM CLKSRC C0MCR1 $0102 SJW1 SJW0 BRP5 BRP4 BRP3 BRP2 BRP1 BRP0 C0BTR0 $0103 SAMP TSEG22 TSEG21 TSEG20 TSEG13 TSEG12 TSEG11 TSEG10 C0BTR1 $0104 WUPIF RWRNIF TWRNIF RERRIF TERRIF BOFFIF OVRIF RXF C0RFLG $0105 WUPIE RWRNIE TWRNIE RERRIE TERRIE BOFFIE OVRIE RXFIE C0RIER $0106 0 ABTAK2 ABTAK1 ABTAK0 0 TXE2 TXE1 TXE0 C0TFLG $0107 0 ABTRQ2 ABTRQ1 ABTRQ0 0 TXEIE2 TXEIE1 TXEIE0 C0TCR $0108 0 0 IDHIT2 IDHIT1 IDHIT0 C0IDAC 0 IDAM1 IDAM0 $0109– $010D Unimplemented(4) Reserved $010E RXERR7 RXERR6 RXERR5 RXERR4 RXERR3 RXERR2 RXERR1 RXERR0 C0RXERR $010F TXERR7 TXERR6 TXERR5 TXERR4 TXERR3 TXERR2 TXERR1 TXERR0 C0TXERR $0110 AC7 AC6 AC5 AC4 AC3 AC2 AC1 AC0 C0IDAR0 $0111 AC7 AC6 AC5 AC4 AC3 AC2 AC1 AC0 C0IDAR1 $0112 AC7 AC6 AC5 AC4 AC3 AC2 AC1 AC0 C0IDAR2 $0113 AC7 AC6 AC5 AC4 AC3 AC2 AC1 AC0 C0IDAR3 $0114 AM7 AM6 AM5 AM4 AM3 AM2 AM1 AM0 C0IDMR0 $0115 AM7 AM6 AM5 AM4 AM3 AM2 AM1 AM0 C0IDMR1 $0116 AM7 AM6 AM5 AM4 AM3 AM2 AM1 AM0 C0IDMR2 $0117 AM7 AM6 AM5 AM4 AM3 AM2 AM1 AM0 C0IDMR3 $0118 AC7 AC6 AC5 AC4 AC3 AC2 AC1 AC0 C0IDAR4 $0119 AC7 AC6 AC5 AC4 AC3 AC2 AC1 AC0 C0IDAR5 $011A AC7 AC6 AC5 AC4 AC3 AC2 AC1 AC0 C0IDAR6 $011B AC7 AC6 AC5 AC4 AC3 AC2 AC1 AC0 C0IDAR7 $011C AM7 AM6 AM5 AM4 AM3 AM2 AM1 AM0 C0IDMR4 $011D AM7 AM6 AM5 AM4 AM3 AM2 AM1 AM0 C0IDMR5 $011E AM7 AM6 AM5 AM4 AM3 AM2 AM1 AM0 C0IDMR6 $011F AM7 AM6 AM5 AM4 AM3 AM2 AM1 AM0 C0IDMR7 Table 4-1. Register Map (Sheet 7 of 11) Technical Data 74 MC68HC912DT128A — Rev 4.0 Registers MOTOROLA Registers Register Block Address Bit 7 6 5 $0120– $013C 4 3 2 Bit 0 Unimplemented(4) Name Reserved $013D 0 0 0 0 0 0 $013E PCAN7 PCAN6 PCAN5 PCAN4 PCAN3 PCAN2 $013F 1 PUPCAN RDPCAN PCTLCAN0 TxCAN RxCAN PORTCAN0 0 0 DDRCAN0 DDCAN7 DDCAN6 DDCAN5 DDCAN4 DDCAN3 DDCAN2 $0140– $014F FOREGROUND RECEIVE BUFFER 0 RxFG0 $0150– $015F TRANSMIT BUFFER 00 Tx00 $0160– $016F TRANSMIT BUFFER 01 Tx01 $0170– $017F TRANSMIT BUFFER 02 Tx02 $0180– $01DF Unimplemented(4) Reserved $01E0 Reserved ATD1CTL0 $01E1 Reserved ATD1CTL1 $01E2 ADPU AFFC ASWAI DJM DSGN Reserved ASCIE ASCIF ATD1CTL2 $01E3 0 0 0 0 S1C FIFO FRZ1 FRZ0 ATD1CTL3 $01E4 RES10 SMP1 SMP0 PRS4 PRS3 PRS2 PRS1 PRS0 ATD1CTL4 $01E5 0 S8C SCAN MULT CD CC CB CA ATD1CTL5 $01E6 SCF 0 0 0 0 CC2 CC1 CC0 ATD1STAT0 $01E7 CCF7 CCF6 CCF5 CCF4 CCF3 CCF2 CCF1 CCF0 ATD1STAT1 $01E8 SAR9 SAR8 SAR7 SAR6 SAR5 SAR4 SAR3 SAR2 ATD1TESTH $01E9 SAR1 SAR0 RST TSTOUT TST3 TST2 TST1 TST0 ATD1TESTL $01EA–$ 01EE 0 0 0 0 0 0 0 0 Reserved $01EF PAD17 PAD16 PAD15 PAD14 PAD13 PAD12 PAD11 PAD10 PORTAD1 $01F0 Bit 15 14 13 12 11 10 9 Bit 8 ADR10H $01F1 Bit 7 Bit 6 0 0 0 0 0 0 ADR10L $01F2 Bit 15 14 13 12 11 10 9 Bit 8 ADR11H $01F3 Bit 7 Bit 6 0 0 0 0 0 0 ADR11L $01F4 Bit 15 14 13 12 11 10 9 Bit 8 ADR12H $01F5 Bit 7 Bit 6 0 0 0 0 0 0 ADR12L $01F6 Bit 15 14 13 12 11 10 9 Bit 8 ADR13H $01F7 Bit 7 Bit 6 0 0 0 0 0 0 ADR13L $01F8 Bit 15 14 13 12 11 10 9 Bit 8 ADR14H $01F9 Bit 7 Bit 6 0 0 0 0 0 0 ADR14L $01FA Bit 15 14 13 12 11 10 9 Bit 8 ADR15H $01FB Bit 7 Bit 6 0 0 0 0 0 0 ADR15L Table 4-1. Register Map (Sheet 8 of 11) MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Registers 75 Registers Address Bit 7 6 5 4 3 2 1 Bit 0 Name $01FC Bit 15 14 13 12 11 10 9 Bit 8 ADR16H $01FD Bit 7 Bit 6 0 0 0 0 0 0 ADR16L $01FE Bit 15 14 13 12 11 10 9 Bit 8 ADR17H $01FF Bit 7 Bit 6 0 0 0 0 0 0 ADR17L (7) $0200 0 0 CSWAI SYNCH TLNKEN SLPAK SLPRQ SFTRES C2MCR0 (7)$0201 0 0 0 0 0 LOOPB WUPM CLKSRC C2MCR1 (7) $0202 SJW1 SJW0 BRP5 BRP4 BRP3 BRP2 BRP1 BRP0 C2BTR0 (7)$0203 SAMP TSEG22 TSEG21 TSEG20 TSEG13 TSEG12 TSEG11 TSEG10 C2BTR1 (7) $0204 WUPIF RWRNIF TWRNIF RERRIF TERRIF BOFFIF OVRIF RXF C2RFLG (7)$0205 WUPIE RWRNIE TWRNIE RERRIE TERRIE BOFFIE OVRIE RXFIE C2RIER ABTAK1 (7) $0206 0 ABTAK2 ABTAK0 0 TXE2 TXE1 TXE0 C2TFLG (7) $0207 0 ABTRQ2 ABTRQ1 ABTRQ0 0 TXEIE2 TXEIE1 TXEIE0 C2TCR (7) $0208 0 0 IDHIT2 IDHIT1 IDHIT0 C2IDAC 0 IDAM1 $0209– $020D (7) IDAM0 Unimplemented(4) Reserved $020E RXERR7 RXERR6 RXERR5 RXERR4 RXERR3 RXERR2 RXERR1 RXERR0 (7)$020F C2RXERR TXERR7 TXERR6 TXERR5 TXERR4 TXERR3 TXERR2 TXERR1 TXERR0 C2TXERR $0210 AC7 AC6 AC5 AC4 AC3 AC2 AC1 AC0 C2IDAR0 (7)$0211 AC7 AC6 AC5 AC4 AC3 AC2 AC1 AC0 C2IDAR1 (7) $0212 AC7 AC6 AC5 AC4 AC3 AC2 AC1 AC0 C2IDAR2 (7)$0213 AC7 AC6 AC5 AC4 AC3 AC2 AC1 AC0 C2IDAR3 (7) $0214 AM7 AM6 AM5 AM4 AM3 AM2 AM1 AM0 C2IDMR0 (7)$0215 AM7 AM6 AM5 AM4 AM3 AM2 AM1 AM0 C2IDMR1 (7) $0216 AM7 AM6 AM5 AM4 AM3 AM2 AM1 AM0 C2IDMR2 (7) $0217 AM7 AM6 AM5 AM4 AM3 AM2 AM1 AM0 C2IDMR3 (7) $0218 AC7 AC6 AC5 AC4 AC3 AC2 AC1 AC0 C2IDAR4 (7) $0219 AC7 AC6 AC5 AC4 AC3 AC2 AC1 AC0 C2IDAR5 (7)$021A AC7 AC6 AC5 AC4 AC3 AC2 AC1 AC0 C2IDAR6 (7) (7) $021B AC7 AC6 AC5 AC4 AC3 AC2 AC1 AC0 C2IDAR7 (7)$021C AM7 AM6 AM5 AM4 AM3 AM2 AM1 AM0 C2IDMR4 (7) $021D AM7 AM6 AM5 AM4 AM3 AM2 AM1 AM0 C2IDMR5 (7)$021E AM7 AM6 AM5 AM4 AM3 AM2 AM1 AM0 C2IDMR6 (7) AM7 AM6 AM5 AM4 AM3 AM2 AM1 AM0 C2IDMR7 $021F Table 4-1. Register Map (Sheet 9 of 11) Technical Data 76 MC68HC912DT128A — Rev 4.0 Registers MOTOROLA Registers Register Block Address Bit 7 6 5 $0220– $023C 3 2 1 Bit 0 Name Unimplemented(4) (7) Reserved 0 0 0 0 0 0 PCAN7 PCAN6 PCAN5 PCAN4 PCAN3 PCAN2 $023D (7)$023E 4 PUPCAN RDPCAN PCTLCAN2 TxCAN RxCAN PORTCAN2 0 0 DDRCAN2 (7) $023F DDCAN7 DDCAN6 DDCAN5 DDCAN4 DDCAN3 DDCAN2 (7)$0240 FOREGROUND RECEIVE BUFFER 2 RxFG2 TRANSMIT BUFFER 20 Tx20 TRANSMIT BUFFER 21 Tx21 $0270 – $027F TRANSMIT BUFFER 22 Tx22 $0280$02FF Unimplemented(4) Reserved – $024F (7) $0250 – $025F (7) $0260 – $026F (7) $0300 0 0 CSWAI SYNCH TLNKEN SLPAK SLPRQ SFTRES C1MCR0 $0301 0 0 0 0 0 LOOPB WUPM CLKSRC C1MCR1 $0302 SJW1 SJW0 BRP5 BRP4 BRP3 BRP2 BRP1 BRP0 C1BTR0 $0303 SAMP TSEG22 TSEG21 TSEG20 TSEG13 TSEG12 TSEG11 TSEG10 C1BTR1 $0304 WUPIF RWRNIF TWRNIF RERRIF TERRIF BOFFIF OVRIF RXF C1RFLG $0305 WUPIE RWRNIE TWRNIE RERRIE TERRIE BOFFIE OVRIE RXFIE C1RIER $0306 0 ABTAK2 ABTAK1 ABTAK0 0 TXE2 TXE1 TXE0 C1TFLG $0307 0 ABTRQ2 ABTRQ1 ABTRQ0 0 TXEIE2 TXEIE1 TXEIE0 C1TCR $0308 0 0 IDHIT2 IDHIT1 IDHIT0 C1IDAC 0 IDAM1 IDAM0 $0309– $030D Unimplemented(4) Reserved $030E RXERR7 RXERR6 RXERR5 RXERR4 RXERR3 RXERR2 RXERR1 RXERR0 C1RXERR $030F TXERR7 TXERR6 TXERR5 TXERR4 TXERR3 TXERR2 TXERR1 TXERR0 C1TXERR $0310 AC7 AC6 AC5 AC4 AC3 AC2 AC1 AC0 C1IDAR0 $0311 AC7 AC6 AC5 AC4 AC3 AC2 AC1 AC0 C1IDAR1 $0312 AC7 AC6 AC5 AC4 AC3 AC2 AC1 AC0 C1IDAR2 $0313 AC7 AC6 AC5 AC4 AC3 AC2 AC1 AC0 C1IDAR3 $0314 AM7 AM6 AM5 AM4 AM3 AM2 AM1 AM0 C1IDMR0 $0315 AM7 AM6 AM5 AM4 AM3 AM2 AM1 AM0 C1IDMR1 $0316 AM7 AM6 AM5 AM4 AM3 AM2 AM1 AM0 C1IDMR2 $0317 AM7 AM6 AM5 AM4 AM3 AM2 AM1 AM0 C1IDMR3 $0318 AC7 AC6 AC5 AC4 AC3 AC2 AC1 AC0 C1IDAR4 $0319 AC7 AC6 AC5 AC4 AC3 AC2 AC1 AC0 C1IDAR5 Table 4-1. Register Map (Sheet 10 of 11) MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Registers 77 Registers Address Bit 7 6 5 4 3 2 1 Bit 0 Name $031A AC7 AC6 AC5 AC4 AC3 AC2 AC1 AC0 C1IDAR6 $031B AC7 AC6 AC5 AC4 AC3 AC2 AC1 AC0 C1IDAR7 $031C AM7 AM6 AM5 AM4 AM3 AM2 AM1 AM0 C1IDMR4 $031D AM7 AM6 AM5 AM4 AM3 AM2 AM1 AM0 C1IDMR5 $031E AM7 AM6 AM5 AM4 AM3 AM2 AM1 AM0 C1IDMR6 $031F AM7 AM6 AM5 AM4 AM3 AM2 AM1 AM0 C1IDMR7 $0320– $033C Unimplemented(4) Reserved $033D 0 0 0 0 0 0 $033E PCAN7 PCAN6 PCAN5 PCAN4 PCAN3 PCAN2 $033F PUPCAN RDPCAN PCTLCAN1 TxCAN RxCAN PORTCAN1 0 0 DDRCAN1 DDCAN7 DDCAN6 DDCAN5 DDCAN4 DDCAN3 DDCAN2 $0340– $034F FOREGROUND RECEIVE BUFFER 1 RxFG1 $0350– $035F TRANSMIT BUFFER 10 Tx10 $0360– $036F TRANSMIT BUFFER 11 Tx11 $0370– $037F TRANSMIT BUFFER 12 Tx12 $0380$03FF Unimplemented(4) Reserved = Reserved or unimplemented bits. Table 4-1. Register Map (Sheet 11 of 11) 1. Port A, port B and data direction registers DDRA, DDRB are not in map in expanded and peripheral modes. 2. Port E and DDRE not in the map in peripheral and expanded modes with EME set. 3. Registers also not in map in peripheral mode. 4. Data read at these locations is undefined. 5. The FPOPEN bit is available only on the 0L05H and later mask sets. For previous masks, this bit is reserved. 6. Port K and DDRK not in the map in peripheral and expanded modes with EMK set. 7. MC68HC912DT128A only. Locations are unimplemented on the MC68HC912DG128A. Technical Data 78 MC68HC912DT128A — Rev 4.0 Registers MOTOROLA Technical Data — MC68HC912DT128A Section 5. Operating Modes 5.1 Contents 5.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 79 5.3 Operating Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 79 5.4 Background Debug Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . .84 5.2 Introduction Eight possible operating modes determine the operating configuration of the MC68HC912DT128A. Each mode has an associated default memory map and external bus configuration. 5.3 Operating Modes The operating mode out of reset is determined by the states of the BKGD, MODB, and MODA pins during reset. The SMODN, MODB, and MODA bits in the MODE register show current operating mode and provide limited mode switching during operation. The states of the BKGD, MODB, and MODA pins are latched into these bits on the rising edge of the reset signal. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Operating Modes 79 Operating Modes Table 5-1. Mode Selection BKGD 1 1 1 1 0 0 0 0 MODB 0 0 1 1 0 0 1 1 MODA 0 1 0 1 0 1 0 1 Mode Normal Single Chip Normal Expanded Narrow Reserved (Forced to Peripheral) Normal Expanded Wide Special Single Chip Special Expanded Narrow Special Peripheral Special Expanded Wide Port A G.P. I/O ADDR/DATA — ADDR/DATA G.P. I/O ADDR/DATA ADDR/DATA ADDR/DATA Port B G.P. I/O ADDR — ADDR/DATA G.P. I/O ADDR ADDR/DATA ADDR/DATA There are two basic types of operating modes: Normal modes — some registers and bits are protected against accidental changes. Special modes — allow greater access to protected control registers and bits for special purposes such as testing and emulation. A system development and debug feature, background debug mode (BDM), is available in all modes. In special single-chip mode, BDM is active immediately after reset. 5.3.1 Normal Operating Modes These modes provide three operating configurations. Background debug is available in all three modes, but must first be enabled for some operations by means of a BDM background command, then activated. Normal Single-Chip Mode — There are no external address and data buses in this mode. The MCU operates as a stand-alone device and all program and data resources are on-chip. External port pins normally associated with address and data buses can be used for general-purpose I/O. Normal Expanded Wide Mode — This is a normal mode of operation in which the expanded bus is present with a 16-bit data bus. Ports A and B are used for the 16-bit multiplexed address/data bus. Technical Data 80 MC68HC912DT128A — Rev 4.0 Operating Modes MOTOROLA Operating Modes Operating Modes Normal Expanded Narrow Mode — This is a normal mode of operation in which the expanded bus is present with an 8-bit data bus. Ports A and B are used for the16-bit address bus. Port A is used as the data bus, multiplexed with addresses. In this mode, 16-bit data is presented one byte at a time, the high byte followed by the low byte. The address is automatically incremented on the second cycle. 5.3.2 Special Operating Modes There are three special operating modes that correspond to normal operating modes. These operating modes are commonly used in factory testing and system development. In addition, there is a special peripheral mode, in which an external master, such as an I.C. tester, can control the on-chip peripherals. Special Single-Chip Mode — This mode can be used to force the MCU to active BDM mode to allow system debug through the BKGD pin. There are no external address and data buses in this mode. The MCU operates as a stand-alone device and all program and data space are on-chip. External port pins can be used for general-purpose I/O. Special Expanded Wide Mode — This mode can be used for emulation of normal expanded wide mode and emulation of normal single-chip mode. Ports A and B are used for the 16-bit multiplexed address/data bus. Special Expanded Narrow Mode — This mode can be used for emulation of normal expanded narrow mode. Ports A and B are used for the16-bit address bus. Port A is used as the data bus, multiplexed with addresses. In this mode, 16-bit data is presented one byte at a time, the high byte followed by the low byte. The address is automatically incremented on the second cycle. Special Peripheral Mode — The CPU is not active in this mode. An external master can control on-chip peripherals for testing purposes. It is not possible to change to or from this mode without going through reset. Background debugging should not be used MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Operating Modes 81 Operating Modes while the MCU is in special peripheral mode as internal bus conflicts between BDM and the external master can cause improper operation of both functions. Bit 7 6 5 4 3 2 1 Bit 0 SMODN MODB MODA ESTR IVIS EBSWAI EMK EME RESET: 0 0 0 1 1 0 1 1 Special Single Chip RESET: 0 0 1 1 1 0 1 1 Special Exp Nar RESET: 0 1 0 1 1 0 1 1 Peripheral RESET: 0 1 1 1 1 0 1 1 Special Exp Wide RESET: 1 0 0 1 0 0 0 0 Normal Single Chip RESET: 1 0 1 1 0 0 0 0 Normal Exp Nar RESET: 1 1 1 1 0 0 0 0 Normal Exp Wide MODE — Mode Register $000B The MODE register controls the MCU operating mode and various configuration options. This register is not in the map in peripheral mode SMODN, MODB, MODA — Mode Select Special, B and A These bits show the current operating mode and reflect the status of the BKGD, MODB and MODA input pins at the rising edge of reset. Read anytime. SMODN may only be written if SMODN = 0 (in special modes) but the first write is ignored. MODB, MODA may be written once if SMODN = 1; anytime if SMODN = 0 but the first write is ignored and in special peripheral and reserved modes cannot be selected. Technical Data 82 MC68HC912DT128A — Rev 4.0 Operating Modes MOTOROLA Operating Modes Operating Modes ESTR — E Clock Stretch Enable Determines if the E Clock behaves as a simple free-running clock or as a bus control signal that is active only for external bus cycles. ESTR is always one in expanded modes since it is required for address and data de-multiplexing and must follow stretched cycles. 0 = E never stretches (always free running). 1 = E stretches high during external access cycles and low during non-visible internal accesses (IVIS = 0). Normal modes: write once; Special modes: write anytime, read anytime. IVIS — Internal Visibility This bit determines whether internal ADDR, DATA, R/W and LSTRB signals can be seen on the external bus during accesses to internal locations. In Special Narrow Mode if this bit is set and an internal access occurs the data will appear wide on Ports A and B. This serves the same function as the EMD bit of the non-multiplexed versions of the HC12 and allows for emulation. Visibility is not available when the part is operating in a single-chip mode. 0 = No visibility of internal bus operations on external bus. 1 = Internal bus operations are visible on external bus. Normal modes: write once; Special modes: write anytime EXCEPT the first time. Read anytime. EBSWAI — Multiplexed External Bus Interface Module Stops in Wait Mode This bit controls access to the multiplexed external bus interface module during wait mode. The module will delay before shutting down in wait mode to allow for final bus activity to complete. 0 = MEBI continues functioning during wait mode. 1 = MEBI is shut down during wait mode. Normal modes: write anytime; special modes: write never. Read anytime. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Operating Modes 83 Operating Modes EMK — Emulate Port K In single-chip mode PORTK and DDRK are always in the map regardless of the state of this bit. 0 = Port K and DDRK registers are in the memory map. Memory expansion emulation is disabled and all pins are general purpose I/O. 1 = In expanded or peripheral mode, PORTK and DDRK are removed from the internal memory map. Removing the registers from the map allows the user to emulate the function of these registers externally. Normal modes: write once; special modes: write anytime EXCEPT the first time. Read anytime. EME — Emulate Port E In single-chip mode PORTE and DDRE are always in the map regardless of the state of this bit. 0 = PORTE and DDRE are in the memory map. 1 = If in an expanded mode, PORTE and DDRE are removed from the internal memory map. Removing the registers from the map allows the user to emulate the function of these registers externally. Normal modes: write once; special modes: write anytime EXCEPT the first time. Read anytime. 5.4 Background Debug Mode Background debug mode (BDM) is an auxiliary operating mode that is used for system development. BDM is implemented in on-chip hardware and provides a full set of debug operations. Some BDM commands can be executed while the CPU is operating normally. Other BDM commands are firmware based, and require the BDM firmware to be enabled and active for execution. In special single-chip mode, BDM is enabled and active immediately out of reset. BDM is available in all other operating modes, but must be enabled before it can be activated. BDM should not be used in special peripheral mode because of potential bus conflicts. Technical Data 84 MC68HC912DT128A — Rev 4.0 Operating Modes MOTOROLA Operating Modes Background Debug Mode Once enabled, background mode can be made active by a serial command sent via the BKGD pin or execution of a CPU12 BGND instruction. While background mode is active, the CPU can interpret special debugging commands, and read and write CPU registers, peripheral registers, and locations in memory. While BDM is active, the CPU executes code located in a small on-chip ROM mapped to addresses $FF20 to $FFFF, and BDM control registers are accessible at addresses $FF00 to $FF06. The BDM ROM replaces the regular system vectors while BDM is active. While BDM is active, the user memory from $FF00 to $FFFF is not in the map except through serial BDM commands. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Operating Modes 85 Operating Modes Technical Data 86 MC68HC912DT128A — Rev 4.0 Operating Modes MOTOROLA Technical Data — MC68HC912DT128A Section 6. Resource Mapping 6.1 Contents 6.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 87 6.3 Internal Resource Mapping. . . . . . . . . . . . . . . . . . . . . . . . . . . .87 6.4 Flash EEPROM mapping through internal Memory Expansion 92 6.5 Miscellaneous System Control Register . . . . . . . . . . . . . . . . . . 96 6.6 Mapping test registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .99 6.7 Memory Maps . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .100 6.2 Introduction After reset, most system resources can be mapped to other addresses by writing to the appropriate control registers. 6.3 Internal Resource Mapping The internal register block, RAM, and EEPROM have default locations within the 64K byte standard address space but may be reassigned to other locations during program execution by setting bits in mapping registers INITRG, INITRM, and INITEE. During normal operating modes these registers can be written once. It is advisable to explicitly establish these resource locations during the initialization phase of program execution, even if default values are chosen, in order to protect the registers from inadvertent modification later. Writes to the mapping registers go into effect between the cycle that follows the write and the cycle after that. To assure that there are no MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Resource Mapping 87 Resource Mapping unintended operations, a write to one of these registers should be followed with a NOP instruction. If conflicts occur when mapping resources, the register block will take precedence over the other resources; RAM or EEPROM addresses occupied by the register block will not be available for storage. When active, BDM ROM takes precedence over other resources, although a conflict between BDM ROM and register space is not possible. The following table shows resource mapping precedence. Table 6-1. Mapping Precedence Precedence 1 2 3 4 5 6 Resource BDM ROM (if active) Register Space RAM EEPROM On-Chip Flash EEPROM External Memory In expanded modes, all address space not used by internal resources is by default external memory. The MC68HC912DT128A contains 128K bytes of Flash EEPROM nonvolatile memory which can be used to store program code or static data. This physical memory is composed of four 32k byte array modules, 00FEE32K, 01FEE32K, 10FEE32K and 11FEE32K. The 32K byte array 11FEE32K has a fixed location from $4000 to $7FFF and $C000 to $FFFF. The three 32K byte arrays 00FEE32K, 01FEE32K and 10FEE32K are accessible through a 16K byte program page window mapped from $8000 to $BFFF. The fixed 32K byte array 11FEE32K can also be accessed through the program page window. Technical Data 88 MC68HC912DT128A — Rev 4.0 Resource Mapping MOTOROLA Resource Mapping Internal Resource Mapping 6.3.1 Register Block Mapping After reset the 1K byte register block resides at location $0000 but can be reassigned to any 2K byte boundary within the standard 64K byte address space. Mapping of internal registers is controlled by five bits in the INITRG register. The register block occupies the first 1K byte of the 2K byte block. INITRG — Initialization of Internal Register Position Register RESET: $0011 Bit 7 6 5 4 3 2 1 Bit 0 REG15 REG14 REG13 REG12 REG11 0 0 MMSWAI 0 0 0 0 0 0 0 0 REG[15:11] — Internal register map position These bits specify the upper five bits of the 16-bit registers address. Normal modes: write once; special modes: write anytime. Read anytime. MMSWAI — Memory Mapping Interface Stop in Wait Control This bit controls access to the memory mapping interface when in Wait mode. Normal modes: write anytime; special modes: write never. Read anytime. 0 = Memory mapping interface continues to function during Wait mode. 1 = Memory mapping interface access is shut down during Wait mode. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Resource Mapping 89 Resource Mapping 6.3.2 RAM Mapping The MC68HC912DT128A has 8K bytes of fully static RAM that is used for storing instructions, variables, and temporary data during program execution. Since the RAM is actually implemented with two 4K RAM arrays, any misaligned word access between last address of first 4K RAM and first address of second 4K RAM will take two cycles instead of one. After reset, RAM addressing begins at location $2000 but can be assigned to any 8K byte boundary within the standard 64K byte address space. Mapping of internal RAM is controlled by three bits in the INITRM register. INITRM — Initialization of Internal RAM Position Register $0010 Bit 7 6 5 4 3 2 1 Bit 0 RAM15 RAM14 RAM13 0 0 0 0 0 0 0 1 0 0 0 0 0 RESET: RAM[15:13] — Internal RAM map position These bits specify the upper three bits of the 16-bit RAM address. Normal modes: write once; special modes: write anytime. Read anytime. Technical Data 90 MC68HC912DT128A — Rev 4.0 Resource Mapping MOTOROLA Resource Mapping Internal Resource Mapping 6.3.3 EEPROM Mapping The MC68HC912DT128A has 2K bytes of EEPROM which is activated by the EEON bit in the INITEE register. Mapping of internal EEPROM is controlled by four bits in the INITEE register. After reset EEPROM address space begins at location $0800 but can be mapped to any 4K byte boundary within the standard 64K byte address space. The EEPROM block occupies the last 2K bytes of the 4K byte block. INITEE— Initialization of Internal EEPROM Position Register RESET: $0012 Bit 7 6 5 4 3 2 1 Bit 0 EE15 EE14 EE13 EE12 0 0 0 EEON 0 0 0 0 0 0 0 1 EE[15:12] — Internal EEPROM map position These bits specify the upper four bits of the 16-bit EEPROM address. Normal modes: write once; special modes: write anytime. Read anytime. EEON — internal EEPROM On (Enabled) Read or write anytime. 0 = Removes the EEPROM from the map. 1 = Places the on-chip EEPROM in the memory map at the address selected by EE[15:12]. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Resource Mapping 91 Resource Mapping 6.4 Flash EEPROM mapping through internal Memory Expansion The Page Index register or PPAGE provides memory management for the MC68HC912DT128A. PPAGE consists of three bits to indicate which physical location is active within the windows of the MC68HC912DT128A. The MC68HC912DT128A has a user’s program space window, a register space window for Flash module registers, and a test program space window. The user’s program page window consists of 16K Flash EEPROM bytes. One of eight pages is viewed through this window for a total of 128K accessible Flash EEPROM bytes. The register space window consists of a 4-byte register block. One of four pages is viewed through this window for each of the 32K flash module register blocks of MC68HC912DT128A. The test mode program page window consists of 32K Flash EEPROM bytes. One of the four 32K byte arrays is viewed through this window for a total 128K accessible Flash EEPROM bytes. This window is only available in special mode for test purposes and replaces the user’s program page window. MC68HC912DT128A has a five pin port, port K, for emulation and for general purpose I/O. Three pins are used to emulate the three page indices (PPAGE bits) and one pin is used as an emulation chip select. When these four pins are not used for emulation they serve as general purpose I/O pins. The fifth port K pin is used as a general purpose I/O pin. 6.4.1 Program space expansion There are 128K bytes of Flash EEPROM for MC68HC912DT128A. With a 64K byte address space, the PPAGE register is needed to perform on chip memory expansion. A program space window of 16K byte pages is located from $8000 to $BFFF. Three page indices are used to point to one of eight different 16K byte pages. Technical Data 92 MC68HC912DT128A — Rev 4.0 Resource Mapping MOTOROLA Resource Mapping Flash EEPROM mapping through internal Memory Expansion Table 6-2. Program space Page Index Page Index 2 Page Index 1 Page Index 0 (PPAGE bit 2) (PPAGE bit 1) (PPAGE bit 0) 0 0 0 0 0 1 0 1 0 0 1 1 1 0 0 1 0 1 1 1 0 1 1 1 16K Program space Page Flash array 16K byte Page 0 16K byte Page 1 16K byte Page 2 16K byte Page 3 16K byte Page 4 16K byte Page 5 16K byte Page 6* 16K byte Page 7* 00FEE32K 00FEE32K 01FEE32K 01FEE32K 10FEE32K 10FEE32K 11FEE32K 11FEE32K * The 16K byte flash in program space page 6 can also be accessed at a fixed location from $4000 to $7FFF. The 16K byte flash in program space page 7 can also be accessed at a fixed location from $C000 to $FFFF. 6.4.2 Flash register space expansion There are four 32K Flash arrays for MC68HC912DT128A and each requires a 4-byte register block. A register space window is used to access one of the four 4-byte blocks and the PPAGE register to map each one into the window. The register space window is located from $00F4 to $00F7 after reset. Only two page indices are used to point to one of the four pages of the register space. Table 6-3. Flash Register space Page Index Page Index 2 Page Index 1 Page Index 0 (PPAGE bit (PPAGE bit 1) (PPAGE bit 0) 2) 0 0 X 0 1 X 1 0 X 1 1 X Flash register space Page Flash array $00F4-$00F7 Page 0 $00F4-$00F7 Page 1 $00F4-$00F7 Page 2 $00F4-$00F7 Page 3 00FEE32K 01FEE32K 10FEE32K 11FEE32K MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Resource Mapping 93 Resource Mapping 6.4.3 Test mode Program space expansion In special mode and for test purposes only, the 128K bytes of Flash EEPROM for MC68HC912DT128A can be accessed through a test program space window of 32K bytes. This window replaces the user’s program space window to be able to access an entire array. In special mode and with ROMTST bit set in MISC register, a program space is located from $8000 to $FFFF. Only two page indices are used to point to one of the four 32K byte arrays. These indices can be viewed as expanded addresses X16 and X15. Table 6-4. Test mode program space Page Index Page Index 2 Page Index 1 Page Index 0 (PPAGE bit 2) (PPAGE bit 1) (PPAGE bit 0) 0 0 X 0 1 X 1 0 X 1 1 X Flash register space Page Flash array 32K byte array Page 0 32K byte array Page 1 32K byte array Page 2 32K byte array Page 3 00FEE32K 01FEE32K 10FEE32K 11FEE32K 6.4.4 Page Index register descriptions PORTK — Port K Data Register $00FC Bit 7 6 5 4 3 2 1 Bit 0 PORT PK7 0 0 0 PK3 PK2 PK1 PK0 Emulation ECS 0 0 0 - PIX2 PIX1 PIX0 RESET: - 0 0 0 - - - - Read and write anytime Writes do not change pin state when pin configured for page index emulation output. This port is associated with page index emulation pins. When the port is not enabled to emulate page index, the port pins are used as generalpurpose I/O. Port K bit 3 is used as a general purpose I/O pin only. This register is not in the map in peripheral or expanded modes while the EMK control bit in MODE register is set. Technical Data 94 MC68HC912DT128A — Rev 4.0 Resource Mapping MOTOROLA Resource Mapping Flash EEPROM mapping through internal Memory Expansion When inputs, these pins can be selected to be high impedance or pulled up. ECS — Emulation Chip Select of selected program space When this signal is active low it indicates that the program space is accessed. This also applies to test mode program space. An access is made if address is at the program space window and either the Flash or external memory is accessed. The ECS timing is E clock high and can be stretched when accessing external memory depending on the EXTR0 and EXTR1 bits in the MISC register. The ECS signal is only active when the EMK bit is set. PIX[2:0] — The content of the PPAGE register emulated externally. This content indicates which Flash module register space is in the memory map and which 16K byte Flash memory is in the program space. In special mode and with ROMTST bit set, the content of the Page Index register indicates which 32K byte Flash array is in the test program space. I DDRK — Port K Data Direction Register RESET: $00FD Bit 7 6 5 4 3 2 1 Bit 0 DDK7 0 0 0 DDK3 DDK2 DDK1 DDK0 0 0 0 0 0 0 0 0 Read and write: anytime. This register determines the primary direction for each port K pin configured as general-purpose I/O. 0 = Associated pin is a high-impedance input. 1 = Associated pin is an output. This register is not in the map in peripheral or expanded modes while the EMK control bit is set. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Resource Mapping 95 Resource Mapping PPAGE — (Program) Page Index Register $00FF Bit 7 6 5 4 3 2 1 Bit 0 0 0 0 0 0 PIX2 PIX1 PIX0 0 0 0 0 0 0 0 0 RESET: Read and write: anytime. This register determines the active page viewed through MC68HC912DT128A windows. CALL and RTC instructions have a special single wire mechanism to read and write this register without using an address bus. 6.5 Miscellaneous System Control Register Additional mapping and external resource controls are available. To use external resources the part must be operated in one of the expanded modes. MISC — Miscellaneous Mapping Control Register $0013 RESET: Bit 7 ROMTST 0 6 NDRF 0 5 RFSTR1 0 4 RFSTR0 0 3 EXSTR1 1 2 EXSTR0 1 1 ROMHM 0 Bit 0 ROMON 0 RESET: 0 0 0 0 1 1 0 1 Mode Exp mode peripheral or SC mode Normal modes: write once; Special modes: write anytime. Read anytime. ROMTST — FLASH EEPROM Test mode In normal modes, this bit is forced to zero. 0 = 16K window for Flash memory is located from $8000-$BFFF 1 = 32K window for Flash memory is located from $8000-$FFFF Technical Data 96 MC68HC912DT128A — Rev 4.0 Resource Mapping MOTOROLA Resource Mapping Miscellaneous System Control Register NDRF — Narrow Data Bus for Register-Following Map Space This bit enables a narrow bus feature for the 1K byte RegisterFollowing Map. This is useful for accessing 8-bit peripherals and allows 8-bit and 16-bit external memory devices to be mixed in a system. In Expanded Narrow (eight bit) modes, Single Chip Modes, and Peripheral mode, this bit has no effect. 0 = Makes Register-Following MAP space act as a full 16 bit data bus. 1 = Makes the Register-Following MAP space act the same as an 8 bit only external data bus (data only goes through port A externally). The Register-Following space is mapped from $0400 to $07FF after reset, which is next to the register map. If the registers are moved this space follows. RFSTR1, RFSTR0 — Register Following Stretch This two bit field determines the amount of clock stretch on accesses to the 1K byte Register Following Map. It is valid regardless of the state of the NDRF bit. In Single Chip and Peripheral Modes this bit has no meaning or effect. Table 6-5. RFSTR Stretch Bit Definition RFSTR1 RFSTR0 0 0 1 1 0 1 0 1 Number of E Clocks Stretched 0 1 2 3 EXSTR1, EXSTR0 — External Access Stretch This two bit field determines the amount of clock stretch on accesses to an external address space. In Single Chip and Peripheral Modes this bit has no meaning or effect. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Resource Mapping 97 Resource Mapping Table 6-6. EXSTR Stretch Bit Definition EXSTR1 EXSTR0 0 0 1 1 0 1 0 1 Number of E Clocks Stretched 0 1 2 3 ROMHM — Flash EEPROM only in second Half of Map This bit has no meaning if ROMON bit is clear. 0 = The 16K byte of fixed Flash EEPROM in location $4000-$7FFF can be accessed. 1 = Disables direct access to 16K byte Flash EEPROM from $4000-$7FFF in the memory map. The physical location of this16K byte Flash can still be accessed through the Program Page window. In special mode and with ROMTST bit set, this bit will allow overlap of the four 32K Flash arrays and overlap the four 4-byte Flash register space in the same map space to be able to program all arrays at the same time. 0 = The four 32K Flash arrays are accessed with four pages for each. 1 = The four 32K Flash arrays coincide in the same space and are selected at the same time for programming. CAUTION: Bit must be cleared before reading any of the arrays or registers. ROMON — Enable Flash EEPROM These bits are used to enable the Flash EEPROM arrays. 0 = Disables Flash EEPROM in the memory map. 1 = Enables Flash EEPROM in the memory map. Technical Data 98 MC68HC912DT128A — Rev 4.0 Resource Mapping MOTOROLA Resource Mapping Mapping test registers 6.6 Mapping test registers These registers are used in for testing the mapping logic. They can only be read and after each read they get cleared. A write to each register will have no effect. MTST0 — Mapping Test Register 0 RESET: Bit 7 MT07 0 6 MT06 0 $00F8 5 MT05 0 4 MT04 0 3 MT03 0 2 MT02 0 1 MT01 0 Bit 0 MT00 0 MTST1 — Mapping Test Register 1 RESET: Bit 7 MT0F 0 6 MT0E 0 $00F9 5 MT0D 0 4 MT0C 0 3 MT0B 0 2 MT0A 0 1 MT09 0 Bit 0 MT08 0 MTST2 — Mapping Test Register 2 RESET: Bit 7 MT17 0 6 MT16 0 $00FA 5 MT15 0 4 MT14 0 3 MT13 0 2 MT12 0 1 MT11 0 Bit 0 MT10 0 MTST3 — Mapping Test Register 3 RESET: Bit 7 MT1F 0 6 MT1E 0 $00FB 5 MT1D 0 4 MT1C 0 3 MT1B 0 MC68HC912DT128A — Rev 4.0 MOTOROLA 2 MT1A 0 1 MT19 0 Bit 0 MT18 0 Technical Data Resource Mapping 99 Resource Mapping 6.7 Memory Maps The following diagrams illustrate the memory map for each mode of operation immediately after reset. $0000 $03FF $0000 $0400 $0800 $0FFF $0800 $1000 $2000 $2000 $3FFF $4000 $4000 $8000 $8000 EXT $BFFF $C000 $C000 REGISTERS (MAPPABLE TO ANY 2K SPACE) 2K bytes EEPROM (MAPPABLE TO ANY 4K SPACE) 8K bytes RAM (MAPPABLE TO ANY 8K SPACE) 16K Fixed Flash EEPROM 16K Page Window Eight 16K Flash EEPROM pages $A000 - $BFFF Protected BOOT at odd programing pages 16K Fixed Flash EEPROM $E000 - $FFFF Protected BOOT $FFFF $FF00 $FF00 $FFFF VECTORS VECTORS VECTORS NORMAL SINGLE CHIP EXPANDED SPECIAL SINGLE CHIP $FFFF BDM (if active) Figure 6-1. MC68HC912DT128A Memory Map after reset The following diagram illustrates the memory paging scheme. Technical Data 100 MC68HC912DT128A — Rev 4.0 Resource Mapping MOTOROLA Resource Mapping Memory Maps $0000 $0400 $0800 $1000 $2000 $4000 6 16K Flash (Unpaged) One 16K Page accessible at a time (selected by PPAGE value = 0 to 7) 00 Flash 32K $8000 0 01 Flash 32K 1 2 10 Flash 32K 3 4 11 Flash 32K * 5 6 7 16K Flash (Paged) (8K Boot) $C000 (8K Boot) (8K Boot) 7 * This 32K Flash accessible as pages 6 & 7 and as unpaged $4000 - $7FFF & $C000 - $FFFF 16K Flash (Unpaged) $E000 (8K Boot) $FF00 $FFFF (8K Boot) VECTORS NORMAL SINGLE CHIP Figure 6-2. MC68HC912DT128A Memory Paging MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Resource Mapping 101 Resource Mapping Technical Data 102 MC68HC912DT128A — Rev 4.0 Resource Mapping MOTOROLA Technical Data — MC68HC912DT128A Section 7. Bus Control and Input/Output 7.1 Contents 7.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 103 7.3 Detecting Access Type from External Signals . . . . . . . . . . . .103 7.4 Registers. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .104 7.2 Introduction Internally the MC68HC912DT128A has full 16-bit data paths, but depending upon the operating mode and control registers, the external multiplexed bus may be 8 or 16 bits. There are cases where 8-bit and 16-bit accesses can appear on adjacent cycles using the LSTRB signal to indicate 8- or 16-bit data. It is possible to have a mix of 8 and 16 bit peripherals attached to the external multiplexed bus, using the NDRF bit in the MISC register while in expanded wide modes. 7.3 Detecting Access Type from External Signals The external signals LSTRB, R/W, and A0 can be used to determine the type of bus access that is taking place. Accesses to the internal RAM module are the only type of access that produce LSTRB = A0 = 1, because the internal RAM is specifically designed to allow misaligned 16-bit accesses in a single cycle. In these cases the data for the address that was accessed is on the low half of the data bus and the data for address + 1 is on the high half of the data bus. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Bus Control and Input/Output 103 Bus Control and Input/Output Table 7-1. Access Type vs. Bus Control Pins LSTRB 1 0 1 0 0 A0 0 1 0 1 0 R/W 1 1 0 0 1 1 1 1 0 0 0 1 1 0 Type of Access 8-bit read of an even address 8-bit read of an odd address 8-bit write of an even address 8-bit write of an odd address 16-bit read of an even address 16-bit read of an odd address (low/high data swapped) 16-bit write to an even address 16-bit write to an odd address (low/high data swapped) 7.4 Registers Not all registers are visible in the MC68HC912DT128A memory map under certain conditions. In special peripheral mode the first 16 registers associated with bus expansion are removed from the memory map. In expanded modes, some or all of port A, port B, and port E are used for expansion buses and control signals. In order to allow emulation of the single-chip functions of these ports, some of these registers must be rebuilt in an external port replacement unit. In any expanded mode, port A, and port B, are used for address and data lines so registers for these ports, as well as the data direction registers for these ports, are removed from the on-chip memory map and become external accesses. In any expanded mode, port E pins may be needed for bus control (e.g., ECLK, R/W). To regain the single-chip functions of port E, the emulate port E (EME) control bit in the MODE register may be set. In this special case of expanded mode and EME set, PORTE and DDRE registers are removed from the on-chip memory map and become external accesses so port E may be rebuilt externally. Technical Data 104 MC68HC912DT128A — Rev 4.0 Bus Control and Input/Output MOTOROLA Bus Control and Input/Output Registers PORTA — Port A Register Single Chip RESET: Expanded & Periph: Expanded narrow Bit 7 PA7 — ADDR15/ DATA15 ADDR15/ DATA15/ DATA7 $0000 6 PA6 — ADDR14/ DATA14 ADDR14/ DATA14/ DATA6 5 PA5 — ADDR13/ DATA13 ADDR13/ DATA13/ DATA5 4 PA4 — ADDR12/ DATA12 ADDR12/ DATA12/ DATA4 3 PA3 — ADDR11/ DATA11 ADDR11/ DATA11/ DATA3 2 PA2 — ADDR10/ DATA10 ADDR10/ DATA10/ DATA2 1 PA1 — ADDR9/ DATA9 ADDR9/ DATA9/ DATA1 Bit 0 PA0 — ADDR8/ DATA8 ADDR8/ DATA8/ DATA0 Bits PA[7:0] are associated respectively with addresses ADDR[15:8], DATA[15:8] and DATA[7:0], in narrow mode. When this port is not used for external addresses such as in single-chip mode, these pins can be used as general-purpose I/O. DDRA determines the primary direction of each pin. This register is not in the on-chip map in expanded and peripheral modes. Read and write anytime. DDRA — Port A Data Direction Register RESET: Bit 7 DDA7 0 6 DDA6 0 $0002 5 DDA5 0 4 DDA4 0 3 DDA3 0 2 DDA2 0 1 DDA1 0 Bit 0 DDA0 0 This register determines the primary direction for each port A pin when functioning as a general-purpose I/O port. DDRA is not in the on-chip map in expanded and peripheral modes. Read and write anytime. 0 = Associated pin is a high-impedance input 1 = Associated pin is an output MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Bus Control and Input/Output 105 Bus Control and Input/Output PORTB — Port B Register Single Chip RESET: Expanded & Periph: Expanded narrow Bit 7 PB7 — ADDR7/ DATA7 ADDR7 $0001 6 PB6 — ADDR6/ DATA6 ADDR6 5 PB5 — ADDR5/ DATA5 ADDR5 4 PB4 — ADDR4/ DATA4 ADDR4 3 PB3 — ADDR3/ DATA3 ADDR3 2 PB2 — ADDR2/ DATA2 ADDR2 1 PB1 — ADDR1/ DATA1 ADDR1 Bit 0 PB0 — ADDR0/ DATA0 ADDR0 Bits PB[7:0] are associated with addresses ADDR[7:0] and DATA[7:0] (except in narrow mode) respectively. When this port is not used for external addresses such as in single-chip mode, these pins can be used as general-purpose I/O. DDRB determines the primary direction of each pin. This register is not in the on-chip map in expanded and peripheral modes. Read and write anytime. DDRB — Port B Data Direction Register RESET: Bit 7 DDB7 0 6 DDB6 0 $0003 5 DDB5 0 4 DDB4 0 3 DDB3 0 2 DDB2 0 1 DDB1 0 Bit 0 DDB0 0 This register determines the primary direction for each port B pin when functioning as a general-purpose I/O port. DDRB is not in the on-chip map in expanded and peripheral modes. Read and write anytime. 0 = Associated pin is a high-impedance input 1 = Associated pin is an output PORTE — Port E Register RESET: Alt. Pin Function BIT 7 PE7 — DBE or ECLK or CAL $0008 6 PE6 — MODB or IPIPE1 or CGMTST 5 PE5 — 4 PE4 — 3 PE3 — 2 PE2 — 1 PE1 — BIT 0 PE0 — MODA or IPIPE0 ECLK LSTRB or TAGLO R/W IRQ XIRQ This register is associated with external bus control signals and interrupt inputs, including data bus enable (DBE), mode select (MODB/IPIPE1, MODA/IPIPE0), E clock, size (LSTRB), read/write Technical Data 106 MC68HC912DT128A — Rev 4.0 Bus Control and Input/Output MOTOROLA Bus Control and Input/Output Registers (R/W), IRQ, and XIRQ. When the associated pin is not used for one of these specific functions, the pin can be used as general-purpose I/O. The port E assignment register (PEAR) selects the function of each pin. DDRE determines the primary direction of each port E pin when configured to be general-purpose I/O. Some of these pins have software selectable pull-ups (DBE, LSTRB, R/W, IRQ and XIRQ). A single control bit enables the pull-ups for all these pins which are configured as inputs. This register is not in the map in peripheral mode or expanded modes when the EME bit is set. Read and write anytime. DDRE — Port E Data Direction Register RESET: Bit 7 DDE7 0 6 DDE6 0 5 DDE5 0 $0009 4 DDE4 0 3 DDE3 0 2 DDE2 0 1 0 0 Bit 0 0 0 This register determines the primary direction for each port E pin configured as general-purpose I/O. 0 = Associated pin is a high-impedance input 1 = Associated pin is an output PE[1:0] are associated with XIRQ and IRQ and cannot be configured as outputs. These pins can be read regardless of whether the alternate interrupt functions are enabled. This register is not in the map in peripheral mode and expanded modes while the EME control bit is set. Read and write anytime. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Bus Control and Input/Output 107 Bus Control and Input/Output PEAR — Port E Assignment Register $000A BIT 7 NDBE 6 CGMTE 5 PIPOE 4 NECLK 3 LSTRE 2 RDWE 1 CALE BIT 0 DBENE RESET: 0 0 0 0 0 0 0 0 RESET: 0 0 1 0 1 1 0 0 RESET: 1 1 0 1 0 0 0 0 RESET: 1 0 0 1 0 0 0 0 RESET: 0 0 1 0 1 1 0 0 Normal Expanded Special Expanded Peripheral Normal single chip Special single chip Port E serves as general purpose I/O lines or as system and bus control signals. The PEAR register is used to choose between the general-purpose I/O functions and the alternate bus control functions. When an alternate control function is selected, the associated DDRE bits are overridden. The reset condition of this register depends on the mode of operation because bus control signals are needed immediately after reset in some modes. In normal single-chip mode, no external bus control signals are needed so all of port E is configured for general-purpose I/O. In normal expanded modes, the reset vector is located in external memory. The DBE and E clock are required for de-multiplexing address and data but LSTRB and R/W are only needed by the system when there are external writable resources. Therefore in normal expanded modes, the DBE and the E clock are configured for their alternate bus control functions and the other bits of port E are configured for general-purpose I/O. If the normal expanded system needs any other bus control signals, PEAR would need to be written before any access that needed the additional signals. In special expanded modes, DBE, IPIPE1, IPIPE0, E, LSTRB, and R/W are configured as bus-control signals. In special single chip modes, DBE, IPIPE1, IPIPE0, E, LSTRB, R/W, and CALE are configured as bus-control signals. Technical Data 108 MC68HC912DT128A — Rev 4.0 Bus Control and Input/Output MOTOROLA Bus Control and Input/Output Registers In peripheral mode, the PEAR register is not accessible for reads or writes. However, the CGMTE control bit is reset to one to configure PE6 as a test output for the CGM module. NDBE — No Data Bus Enable Normal: write once; Special: write anytime EXCEPT the first. Read anytime. 0 = PE7 is used for DBE, external control of data enable on memories, or inverted E clock. 1 = PE7 is CAL function if CALE bit is set in PEAR register or general-purpose I/O otherwise. The NDBE bit has no effect in Single Chip or Peripheral Modes and PE7 is defaulted to the CAL function if CALE bit is set in PEAR register or to an I/O otherwise. CGMTE — Clock Generator Module Testing Enable Normal: write never; Special: write anytime EXCEPT the first time. Read anytime. 0 = PE6 is general-purpose I/O or pipe output. 1 = PE6 is a test signal output from the CGM module (no effect in single chip or normal expanded modes). PIPOE = 1 overrides this function and forces PE6 to be a pipe status output signal. PIPOE — Pipe Status Signal Output Enable Normal: write once; Special: write anytime EXCEPT the first time. Read anytime. 0 = PE[6:5] are general-purpose I/O (if CGMTE = 1, PE6 is a test output signal from the CGM module). 1 = PE[6:5] are outputs and indicate the state of the instruction queue (only effective in expanded modes). NECLK — No External E Clock Normal single chip: write once; special single chip: write anytime; all other modes: write never. Read anytime. In peripheral mode, E is an input and in all other modes, E is an output. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Bus Control and Input/Output 109 Bus Control and Input/Output 0 = PE4 is the external E-clock pin subject to the following limitation: In single-chip modes, to get an E clock output signal, it is necessary to have ESTR = 0 in addition to NECLK = 0. A 16-bit write to PEAR and MODE registers can configure all three bits in one operation. 1 = PE4 is a general-purpose I/O pin. LSTRE — Low Strobe (LSTRB) Enable Normal: write once; Special: write anytime EXCEPT the first time. Read anytime. This bit has no effect in single-chip modes or normal expanded narrow mode. 0 = PE3 is a general-purpose I/O pin. 1 = PE3 is configured as the LSTRB bus-control output, provided the MCU is not in single chip or normal expanded narrow modes. LSTRB is used during external writes. After reset in normal expanded mode, LSTRB is disabled. If needed, it should be enabled before external writes. External reads do not normally need LSTRB because all 16 data bits can be driven even if the MCU only needs 8 bits of data. TAGLO is a shared function of the PE3/LSTRB pin. In special expanded modes with LSTRE set and the BDM tagging on, a zero at the falling edge of E tags the instruction word low byte being read into the instruction queue. RDWE — Read/Write Enable Normal: write once; Special: write anytime EXCEPT the first time. Read anytime. This bit has no effect in single-chip modes. 0 = PE2 is a general-purpose I/O pin. 1 = PE2 is configured as the R/W pin. In single chip modes, RDWE has no effect and PE2 is a general-purpose I/O pin. R/W is used for external writes. After reset in normal expanded mode, it is disabled. If needed it should be enabled before any external writes. Technical Data 110 MC68HC912DT128A — Rev 4.0 Bus Control and Input/Output MOTOROLA Bus Control and Input/Output Registers CALE — Calibration Reference Enable Read and write anytime. 0 = Calibration reference is disabled and PE7 is general purpose I/O in single chip or peripheral modes or if NDBE bit is set. 1 = Calibration reference is enabled on PE7 in single chip and peripheral modes or if NDBE bit is set. DBENE — DBE or Inverted E Clock on PE7 Normal modes: write once. Special modes: write anytime EXCEPT the first time. Read anytime. DBENE controls which signal is output on PE7 when NDBE control bit is cleared. The inverted E clock output can be used to latch the address for de-multiplexing. It has the same behavior as the E clock, except it is inverted. Please note that in the case of idle expansion bus, the ‘not E clock’ signal could stay high for many cycles. The DBENE bit has no effect in Single Chip or Peripheral Modes and PE7 is defaulted to the CAL function if CALE bit is set in PEAR register or to an I/O otherwise. 0 = PE7 pin used for DBE external control of data enable on memories in expanded modes when NDBE = 0 1 = PE7 pin used for inverted E clock output in expanded modes when NDBE = 0 PUCR — Pull-Up Control Register RESET: Bit 7 PUPK 0 6 PUPJ 0 $000C 5 PUPH 0 4 PUPE 1 3 0 0 2 0 0 1 PUPB 0 Bit 0 PUPA 0 These bits select pull-up resistors for any pin in the corresponding port that is currently configured as an input. This register is not in the map in peripheral mode. Read and write anytime. PUPK — Pull-Up Port K Enable 0 = Port K pull-ups are disabled. 1 = Enable pull-up devices for all port K input pins. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Bus Control and Input/Output 111 Bus Control and Input/Output PUPJ — Pull-Up or Pull-Down Port J Enable 0 = Port J resistive loads (pull-ups or pull-downs) are disabled. 1 = Enable resistive load devices (pull-ups or pull-downs) for all port J input pins. PUPH — Pull-Up or Pull-Down Port H Enable 0 = Port H resistive loads (pull-ups or pull-downs) are disabled. 1 = Enable resistive load devices (pull-ups or pull-downs) for all port H input pins. PUPE — Pull-Up Port E Enable 0 = Port E pull-ups on PE7, PE3, PE2, PE1 and PE0 are disabled. 1 = Enable pull-up devices for port E input pins PE7, PE3, PE2, PE1 and PE0. When this bit is set port E input pins 7, 3, 2, 1 & 0 have an active pullup device. PUPB — Pull-Up Port B Enable 0 = Port B pull-ups are disabled. 1 = Enable pull-up devices for all port B input pins. PUPA — Pull-Up Port A Enable 0 = Port A pull-ups are disabled. 1 = Enable pull-up devices for all port A input pins. Technical Data 112 MC68HC912DT128A — Rev 4.0 Bus Control and Input/Output MOTOROLA Bus Control and Input/Output Registers RDRIV — Reduced Drive of I/O Lines RESET: Bit 7 RDPK 0 6 RDPJ 0 $000D 5 RDPH 0 4 RDPE 0 3 0 0 2 0 0 1 RDPB 0 Bit 0 RDPA 0 These bits select reduced drive for the associated port pins. This gives reduced power consumption and reduced RFI with a slight increase in transition time (depending on loading). The reduced drive function is independent of which function is being used on a particular port. This register is not in the map in peripheral mode. Normal: write once; Special: write anytime EXCEPT the first time. Read anytime. RDPK — Reduced Drive of Port K 0 = All port K output pins have full drive enabled. 1 = All port K output pins have reduced drive capability. RDPJ — Reduced Drive of Port J 0 = All port J output pins have full drive enabled. 1 = All port J output pins have reduced drive capability. RDPH — Reduced Drive of Port H 0 = All port H output pins have full drive enabled. 1 = All port H output pins have reduced drive capability. RDPE — Reduced Drive of Port E 0 = All port E output pins have full drive enabled. 1 = All port E output pins have reduced drive capability. RDPB — Reduced Drive of Port B 0 = All port B output pins have full drive enabled. 1 = All port B output pins have reduced drive capability. RDPA — Reduced Drive of Port A 0 = All port A output pins have full drive enabled. 1 = All port A output pins have reduced drive capability. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Bus Control and Input/Output 113 Bus Control and Input/Output Technical Data 114 MC68HC912DT128A — Rev 4.0 Bus Control and Input/Output MOTOROLA Technical Data — MC68HC912DT128A Section 8. Flash Memory 8.1 Contents 8.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 115 8.3 Overview. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .116 8.4 Flash EEPROM Control Block . . . . . . . . . . . . . . . . . . . . . . . .116 8.5 Flash EEPROM Arrays . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .116 8.6 Flash EEPROM Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . 117 8.7 Operation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .119 8.8 Programming the Flash EEPROM . . . . . . . . . . . . . . . . . . . . . 120 8.9 Erasing the Flash EEPROM . . . . . . . . . . . . . . . . . . . . . . . . . . 121 8.10 Stop or Wait Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .121 8.11 Flash protection bit FPOPEN . . . . . . . . . . . . . . . . . . . . . . . . .122 8.2 Introduction The four Flash EEPROM array modules 00FEE32K, 01FEE32K, 10FEE32K and 11FEE32K for the MC68HC912DT128A serve as electrically erasable and programmable, non-volatile ROM emulation memory. The modules can be used for program code that must either execute at high speed or is frequently executed, such as operating system kernels and standard subroutines, or they can be used for static data which is read frequently. The Flash EEPROM module is ideal for program storage for single-chip applications allowing for field reprogramming. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Flash Memory 115 Flash Memory 8.3 Overview Each 32K Flash EEPROM array is arranged in a 16-bit configuration and may be read as either bytes, aligned words or misaligned words. Access time is one bus cycle for byte and aligned word access and two bus cycles for misaligned word operations. The Flash EEPROM module supports bulk erase only. Each Flash EEPROM module has hardware interlocks which protect stored data from accidental corruption. An erase- and programprotected 8-Kbyte block for boot routines is located at the top of each 32Kbyte array. Since boot programs must be available at all times, the only useful boot block is at $E000–$FFFF location. All paged boot blocks can be used as protected program space if desired. On 0L05H and later mask sets, an optional protection scheme is supported to protect all four 32-Kbyte Flash EEPROM modules against accident program or erase. This is achieved using the protection bit FPOPEN in EEPROM EEMCR (see 8.11 Flash protection bit FPOPEN). 8.4 Flash EEPROM Control Block A 4-byte register block for each module controls the Flash EEPROM operation. Configuration information is specified and programmed independently from the contents of the Flash EEPROM array. At reset, the 4-byte register section starts at address $00F4 and points to the 00FEE32K register block. 8.5 Flash EEPROM Arrays After reset, a fixed 32K Flash EEPROM array, 11FEE32K, is located from addresses $4000 to $7FFF and from $C000 to $FFFF. The other three 32K Flash EEPROM arrays 00FEE32K, 01FEE32K and 10FEE32K, are mapped through a 16K byte program page window located from addresses $8000 to $BFFF. The page window has eight 16K byte pages. The last two pages also map the physical location of the Technical Data 116 MC68HC912DT128A — Rev 4.0 Flash Memory MOTOROLA Flash Memory Flash EEPROM Registers fixed 32K Flash EEPROM array 11FEE32K. In expanded modes, the Flash EEPROM arrays are turned off. See Operating Modes. 8.6 Flash EEPROM Registers Each 32K byte Flash EEPROM module has a set of registers. The register space $00F4-$00F7 is in a register space window of four pages. Each register page of four bytes maps the register space for each Flash module and each page is selected by the PPAGE register. See Resource Mapping FEELCK — Flash EEPROM Lock Control Register RESET: $00F4 Bit 7 6 5 4 3 2 1 Bit 0 0 0 0 0 0 0 0 LOCK 0 0 0 0 0 0 0 0 In normal modes the LOCK bit can only be written once after reset. LOCK — Lock Register Bit 0 = Enable write to FEEMCR register 1 = Disable write to FEEMCR register FEEMCR — Flash EEPROM Module Configuration Register RESET: $00F5 Bit 7 6 5 4 3 2 1 Bit 0 0 0 0 0 0 0 0 BOOTP 0 0 0 0 0 0 0 1 This register controls the operation of the Flash EEPROM array. BOOTP cannot be changed when the LOCK control bit in the FEELCK register is set or if HVEN or PGM or ERAS in the FEECTL register is set. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Flash Memory 117 Flash Memory BOOTP — Boot Protect The boot blocks are located at $E000–$FFFF and $A000–$BFFF for odd program pages for each Flash EEPROM module. Since boot programs must be available at all times, the only useful boot block is at $E000–$FFFF location. All paged boot blocks can be used as protected program space if desired. 0 = Enable erase and program of 8K byte boot block 1 = Disable erase and program of 8K byte boot block FEECTL — Flash EEPROM Control Register $00F7 Bit 7 6 5 4 3 2 1 Bit 0 0 0 0 FEESWAI HVEN 0 ERAS PGM 0 0 0 0 0 0 0 0 RESET: This register controls the programming and erasure of the Flash EEPROM. FEESWAI — Flash EEPROM Stop in Wait Control 0 = Do not halt Flash EEPROM clock when the part is in wait mode. 1 = Halt Flash EEPROM clock when the part is in wait mode. HVEN — High-Voltage Enable This bit enables the charge pump to supply high voltages for program and erase operations in the array. HVEN can only be set if either PGM or ERAS are set and the proper sequence for program or erase is followed. 0 = Disables high voltage to array and charge pump off 1 = Enables high voltage to array and charge pump on ERAS — Erase Control This bit configures the memory for erase operation. ERAS is interlocked with the PGM bit such that both bits cannot be equal to 1 or set to1 at the same time. 0 = Erase operation is not selected. 1 = Erase operation selected. Technical Data 118 MC68HC912DT128A — Rev 4.0 Flash Memory MOTOROLA Flash Memory Operation PGM — Program Control This bit configures the memory for program operation. PGM is interlocked with the ERAS bit such that both bits cannot be equal to 1 or set to1 at the same time. 0 = Program operation is not selected. 1 = Program operation selected. 8.7 Operation The Flash EEPROM can contain program and data. On reset, it can operate as a bootstrap memory to provide the CPU with internal initialization information during the reset sequence. 8.7.1 Bootstrap Operation Single-Chip Mode After reset, the CPU controlling the system will begin booting up by fetching the first program address from address $FFFE. 8.7.2 Normal Operation The Flash EEPROM allows a byte or aligned word read in one bus cycle. Misaligned word read require an additional bus cycle. The Flash EEPROM array responds to read operations only. Write operations are ignored. 8.7.3 Program/Erase Operation An unprogrammed Flash EEPROM bit has a logic state of one. A bit must be programmed to change its state from one to zero. Erasing a bit returns it to a logic one. The Flash EEPROM has a minimum program/erase life of 100 cycles. Programming or erasing the Flash EEPROM is accomplished by a series of control register writes. The Flash EEPROM must be completely erased prior to programming final data values. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Flash Memory 119 Flash Memory Programming and erasing of Flash locations cannot be performed by code being executed from the Flash memory. While these operations must be performed in the order shown, other unrelated operations may occur between the steps. Do not exceed tFPGM maximum (40µs). 8.8 Programming the Flash EEPROM Programming the Flash EEPROM is done on a row basis. A row consists of 32 consecutive words (64 bytes) with rows starting from addresses $XX00, $XX40, $XX80 and $XXC0. When writing a row care should be taken not to write data to addresses outside of the row. Programming is restricted to aligned word i.e. data writes to select rows/blocks for programming/erase should be to even adresses and writes to any row for programming should be to aligned words. Use this step-by-step procedure to program a row of Flash memory. 1. Set the PGM bit. This configures the memory for program operation and enables the latching of address and data for programming. 2. Write to any aligned word Flash address within the row address range desired (with any data) to select the row. 3. Wait for a time, tNVS (min. 10µs). 4. Set the HVEN bit. 5. Wait for a time, tPGS (min. 5µs). 6. Write one data word (two bytes) to the next aligned word Flash address to be programmed. If BOOTP is asserted, an attempt to program an address in the boot block will be ignored. 7. Wait for a time, tFPGM (min. 30µs). 8. Repeat step 6 and 7 until all the words within the row are programmed. 9. Clear the PGM bit. 10. Wait for a time, tNVH (min. 5µs). 11. Clear the HVEN bit. Technical Data 120 MC68HC912DT128A — Rev 4.0 Flash Memory MOTOROLA Flash Memory Erasing the Flash EEPROM 12. After time, tRCV (min 1µs), the memory can be accessed in read mode again. This program sequence is repeated throughout the memory until all data is programmed. For minimum overall programming time and least program disturb effect, the sequence should be part of an intelligent operation which iterates per row. 8.9 Erasing the Flash EEPROM The following sequence demonstrates the recommended procedure for erasing any of the Flash EEPROM array. 1. Set the ERAS bit. 2. Write to any valid address in the Flash array. The data written and the address written are not important. The boot block will be erased only if the control bit BOOTP is negated. 3. Wait for a time, tNVS. 4. Set the HVEN bit. 5. Wait for a time, tERAS. 6. Clear the ERAS bit. 7. Wait for a time, tNVHL. 8. Clear the HVEN bit. 9. After time, tRCV, the memory can be accessed in read mode again. 8.10 Stop or Wait Mode When stop or wait commands are executed, the MCU puts the Flash EEPROM in stop or wait mode. In these modes the Flash module will cease erasure or programming immediately. CAUTION: It is advised not to enter stop or wait modes when program or erase operation of the Flash array is in progress. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Flash Memory 121 Flash Memory 8.11 Flash protection bit FPOPEN The FPOPEN bit is located in EEMCR – EEPROM Module Configuration Register, bit 4. FPOPEN – Opens the Flash array for program or erase 0 = The whole Flash array is protected. 1 = The whole Flash array is enabled for program or erase FPOPEN can be read at anytime. FPOPEN can be written only to ’0’ for protection but not to ’1’ for unprotect in normal mode. FPOPEN can be written ’0’ and ’1’ in special mode only. FPOPEN is loaded at reset from EEPROM SHADOW word bit 4. When FPOPEN is cleared to ’0’, the Flash array cannot be reprogrammed in normal modes. CAUTION: Programming the NVM FPOPEN bit in the SHADOW word ($_FC0, bit 4) means that the FPOPEN bit in the EEMCR register will always be ’0’ in normal modes. The flash array can no longer be modified in normal modes. Technical Data 122 MC68HC912DT128A — Rev 4.0 Flash Memory MOTOROLA Technical Data — MC68HC912DT128A Section 9. EEPROM Memory 9.1 Contents 9.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 123 9.3 EEPROM Selective Write More Zeros . . . . . . . . . . . . . . . . . .124 9.4 EEPROM Programmer’s Model . . . . . . . . . . . . . . . . . . . . . . .125 9.5 EEPROM Control Registers . . . . . . . . . . . . . . . . . . . . . . . . . . 126 9.6 Program/Erase Operation. . . . . . . . . . . . . . . . . . . . . . . . . . . .133 9.7 Shadow Word Mapping . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 134 9.8 Programming EEDIVH and EEDIVL Registers. . . . . . . . . . . . 135 9.2 Introduction The MC68HC912DT128A EEPROM nonvolatile memory is arranged in a 16-bit configuration. The EEPROM array may be read as either bytes, aligned words or misaligned words. Access times are one bus cycle for byte and aligned word access and two bus cycles for misaligned word operations. Programming is by byte or aligned word. Attempts to program or erase misaligned words will fail. Only the lower byte will be latched and programmed or erased. Programming and erasing of the user EEPROM can be done in normal modes. Each EEPROM byte or aligned word must be erased before programming. The EEPROM module supports byte, aligned word, row (32 bytes) or bulk erase, all using the internal charge pump. The erased state is $FF. The EEPROM module has hardware interlocks which protect stored data from corruption by accidentally enabling the program/erase voltage. Programming voltage is derived from the internal VDD supply with an internal charge pump. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data EEPROM Memory 123 EEPROM Memory 9.3 EEPROM Selective Write More Zeros The EEPROM can be programmed such that one or multiple bits are programmed (written to a logic “0”) at a time. However, the user should never program any bit more than once before erasing the entire byte. In other words, the user is not allowed to over write a logic “0” with another “0’. For some applications it may be advantageous to track more than 10k events with a single byte of EEPROM by programming one bit at a time. For that purpose, a special selective bit programming technique is available. An example is shown here. Original state of byte = binary 1111:1111 (erased) First event is recorded by programming bit position 0 Program write = binary 1111:1110; Result = binary 1111:1110 Second event is recorded by programming bit position 1 Program write = binary 1111:1101; Result = binary 1111:1100 Third event is recorded by programming bit position 2 Program write = binary 1111:1011; Result = binary 1111:1000 Fourth event is recorded by programming bit position 3 Program write = binary 1111:0111; Result = binary 1111:0000 Events five through eight are recorded in a similar fashion. Note that none of the bit locations are actually programmed more than once although the byte was programmed eight times. When this technique is utilized, a program / erase cycle is defined as multiple writes (up to eight) to a unique location followed by a single erase sequence. Technical Data 124 MC68HC912DT128A — Rev 4.0 EEPROM Memory MOTOROLA EEPROM Memory EEPROM Programmer’s Model 9.4 EEPROM Programmer’s Model The EEPROM module consists of two separately addressable sections. The first is an eight-byte memory mapped control register block used for control, testing and configuration of the EEPROM array. The second section is the EEPROM array itself. At reset, the eight-byte register section starts at address $00EC and the EEPROM array is located from addresses $0800 to $0FFF. Registers $00EC-$00ED are reserved. Read/write access to the memory array section can be enabled or disabled by the EEON control bit in the INITEE register ($0012). This feature allows the access of memory mapped resources that have lower priority than the EEPROM memory array. EEPROM control registers can be accessed regardless of the state of EEON. Any EEPROM erase or program operation already in progress will not be affected by the change of EEON state. For information on re-mapping the register block and EEPROM address space, refer to Operating Modes. CAUTION: It is strongly recommended to discontinue program/erase operations during WAIT (when EESWAI=1) or STOP modes since all program/erase activities will be terminated abruptly and considered unsuccessful. For lowest power consumption during WAIT mode, it is advised to turn off EEPGM. The EEPROM module contains an extra word called SHADOW word which is loaded at reset into the EEMCR, EEDIVH and EEDIVL registers. To program the SHADOW word, when in special modes (SMODN=0), the NOSHW bit in EEMCR register must be cleared. Normal programming routines are used to program the SHADOW word which becomes accessible at address $0FC0-$0FC1 when NOSHW is cleared. At the next reset the SHADOW word data is loaded into the EEMCR, EEDIVH and EEDIVL registers. The SHADOW word can be protected from being programmed or erased by setting the SHPROT bit of EEPROT register. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data EEPROM Memory 125 EEPROM Memory A steady internal self-time clock is required to provide accurate counts to meet EEPROM program/erase requirements. This clock is generated via by a programmable 10-bit prescaler register. Automatic program/erase termination is also provided. In ordinary situations, with crystal operating properly, the steady internal self-time clock is derived from the input clock source (EXTALi). The divider value is as in EEDIVH:EEDIVL. In limp-home mode, where the oscillator clock has malfunctioned or is unavailable, the self-time clock is derived from the PLL at a nominal fVCOMIN using a predefined divider value of $0023. Program/erase operation is not guaranteed in limphome mode. CAUTION: It is strongly recommended that program/erase operation is terminated in the event of loss of crystal, either by the application software (clearing EEPGM & EELAT bits) when entering limp home mode or by enabling the clock monitor to generate a clock monitor reset. This will prevent unnecessary stress on the emulated EEPROM during oscillator failure. 9.5 EEPROM Control Registers EEDIVH — EEPROM Modulus Divider RESET: Bit 7 0 0 6 0 0 $00EE 5 0 0 4 0 0 3 0 0 2 0 0 1 EEDIV9 —(1) Bit 0 EEDIV8 —(1) 1. Loaded from SHADOW word. EEDIVL — EEPROM Modulus Divider RESET: Bit 7 EEDIV7 —(1) 6 EEDIV6 —(1) 5 EEDIV5 —(1) $00EF 4 EEDIV4 —(1) 3 EEDIV3 —(1) 2 EEDIV2 —(1) 1 EEDIV1 —(1) Bit 0 EEDIV0 —(1) 1. Loaded from SHADOW word. Technical Data 126 MC68HC912DT128A — Rev 4.0 EEPROM Memory MOTOROLA EEPROM Memory EEPROM Control Registers EEDIV[9:0] — Prescaler divider Loaded from SHADOW word at reset. Read anytime. Write once in normal modes (SMODN =1) if EELAT = 0 and anytime in special modes (SMODN =0) if EELAT = 0. The prescaler divider is required to produce a self-time clock with a fixed frequency around 28.6 Khz for the range of oscillator frequencies. The divider is set so that the oscillator frequency can be divided by a divide factor that can produce a 35 µs ± 2µs timebase. CAUTION: An incorrect or uninitialized value on EEDIV can result in overstress of EEPROM array during program/erase operation. It is also strongly recommend not to program EEPROM with oscillator frequencies less than 250 Khz. The EEDIV value is determined by the following formula: EEDIV = INT [ EXTALi (hz) x 35 ×10 NOTE: –6 + 0.5 ] INT[A] denotes the round down integer value of A. Program/erase cycles will not be activated when EEDIV = 0. Table 9-1. EEDIV Selection Osc Freq. 16 Mhz 8 Mhz 4 Mhz 2 Mhz 1 Mhz 500 Khz 250 Khz Osc Period 62.5ns 125ns 250ns 500ns 1µs 2µs 4µs MC68HC912DT128A — Rev 4.0 MOTOROLA Divide Factor 560 280 140 70 35 18 9 EEDIV $0230 $0118 $008C $0046 $0023 $0012 $0009 Technical Data EEPROM Memory 127 EEPROM Memory EEMCR — EEPROM Module Configuration RESET: Bit 7 6 NOBDML NOSHW —(3) —(3) $00F0 5 Reserved —(3) 4 (1) (2) FPOPEN —(3) 3 2 1 Bit 0 1 EESWAI PROTLCK DMY 1 1 0 0 1. Bit 5 has a test function and should not be programmed. 2. The FPOPEN bit is available only on the 0L05H and later mask sets. For previous masks, this bit is reserved. 3. Loaded from SHADOW word. Bits[7:4] are loaded at reset from the EEPROM SHADOW word. NOTE: The bits 5 and 4 are reserved for test purposes. These locations in SHADOW word should not be programmed otherwise some locations of regular EEPROM array will not be more visible. NOBDML — Background Debug Mode Lockout Disable 0 = The BDM lockout is enabled. 1 = The BDM lockout is disabled. Loaded from SHADOW word at reset. Read anytime. Write anytime in special modes (SMODN=0). NOSHW — SHADOW Word Disable 0 = The SHADOW word is enabled and accessible at address $0FC0-$0FC1. 1 = Regular EEPROM array at address $0FC0-$0FC1. Loaded from SHADOW word at reset. Read anytime. Write anytime in special modes (SMODN=0). When NOSHW cleared, the regular EEPROM array bytes at address $0FC0 and $0FC1 are not visible. The SHADOW word is accessed instead for both read and program/erase operations. Bits[7:4] from the high byte of the SHADOW word, $0FC0, are loaded to EEMCR[7:4]. Bits[1:0] from the high byte of the SHADOW word, $0FC0,are loaded to EEDIVH[1:0]. Bits[7:0] from the low byte of the SHADOW word, $0FC1,are loaded to EEDIVL[7:0]. BULK program/erase only applies if SHADOW word is enabled. NOTE: Bit 6 from high byte of SHADOW word should not be programmed in order to have the full EEPROM array visible. Technical Data 128 MC68HC912DT128A — Rev 4.0 EEPROM Memory MOTOROLA EEPROM Memory EEPROM Control Registers FPOPEN — Opens the Flash Block for Program or Erase 0 = The whole Flash array is protected. 1 = The whole Flash array is enable for program or erase. Loaded from SHADOW word at reset. Read anytime. Write anytime in special modes (SMODN=0). Write once ’0’ is allowed in normal mode. EESWAI — EEPROM Stops in Wait Mode 0 = The module is not affected during WAIT mode 1 = The module ceases to be clocked during WAIT mode Read and write anytime. NOTE: The EESWAI bit should be cleared if the WAIT mode vectors are mapped in the EEPROM array. PROTLCK — Block Protect Write Lock 0 = Block protect bits and bulk erase protection bit can be written 1 = Block protect bits are locked Read anytime. Write once in normal modes (SMODN = 1), set and clear any time in special modes (SMODN = 0). DMY— Dummy bit Read and write anytime. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data EEPROM Memory 129 EEPROM Memory EEPROT — EEPROM Block Protect RESET: Bit 7 SHPROT 1 6 1 1 $00F1 5 BPROT5 1 4 BPROT4 1 3 BPROT3 1 2 BPROT2 1 1 BPROT1 1 Bit 0 BPROT0 1 Prevents accidental writes to EEPROM. Read anytime. Write anytime if EEPGM = 0 and PROTLCK = 0. SHPROT — SHADOW Word Protection 0 = The SHADOW word can be programmed and erased. 1 = The SHADOW word is protected from being programmed and erased. BPROT[5:0] — EEPROM Block Protection 0 = Associated EEPROM block can be programmed and erased. 1 = Associated EEPROM block is protected from being programmed and erased. Table 9-2. 2K byte EEPROM Block Protection Bit Name BPROT5 BPROT4 BPROT3 BPROT2 BPROT1 BPROT0 Block Protected $0800 to $0BFF $0C00 to $0DFF $0E00 to $0EFF $0F00 to $0F7F $0F80 to $0FBF $0FC0 to $0FFF Block Size 1024 Bytes 512 Bytes 256 Bytes 128 Bytes 64 Bytes 64 Bytes EETST — EEPROM Test RESET: Bit 7 0 0 $00F2 6 EREVTN 0 5 0 0 4 0 0 3 0 0 2 ETMSD 0 1 ETMR 0 Bit 0 ETMSE 0 In normal mode, writes to EETST control bits have no effect and always read zero. The EEPROM module cannot be placed in test mode inadvertently during normal operation Technical Data 130 MC68HC912DT128A — Rev 4.0 EEPROM Memory MOTOROLA EEPROM Memory EEPROM Control Registers . EEPROG — EEPROM Control RESET: Bit 7 BULKP 1 6 0 0 $00F3 5 AUTO 0 4 BYTE 0 3 ROW 0 2 ERASE 0 1 EELAT 0 Bit 0 EEPGM 0 BULKP — Bulk Erase Protection 0 = EEPROM can be bulk erased. 1 = EEPROM is protected from being bulk or row erased. Read anytime. Write anytime if EEPGM = 0 and PROTLCK = 0. AUTO — Automatic shutdown of program/erase operation. EEPGM is cleared automatically after the program/erase cycles are finished when AUTO is set. 0 = Automatic clear of EEPGM is disabled. 1 = Automatic clear of EEPGM is enabled. Read anytime. Write anytime if EEPGM = 0. BYTE — Byte and Aligned Word Erase 0 = Bulk or row erase is enabled. 1 = One byte or one aligned word erase only. Read anytime. Write anytime if EEPGM = 0. ROW — Row or Bulk Erase (when BYTE = 0) 0 = Erase entire EEPROM array. 1 = Erase only one 32-byte row. Read anytime. Write anytime if EEPGM = 0. BYTE and ROW have no effect when ERASE = 0 Table 9-3. Erase Selection BYTE 0 0 1 1 ROW 0 1 0 1 Block size Bulk erase entire EEPROM array Row erase 32 bytes Byte or aligned word erase Byte or aligned word erase If BYTE = 1 only the location specified by the address written to the programming latches will be erased. The operation will be a byte or an aligned word erase depending on the size of written data. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data EEPROM Memory 131 EEPROM Memory ERASE — Erase Control 0 = EEPROM configuration for programming. 1 = EEPROM configuration for erasure. Read anytime. Write anytime if EEPGM = 0. Configures the EEPROM for erasure or programming. Unless BULKP is set, erasure is by byte, aligned word, row or bulk. EELAT — EEPROM Latch Control 0 = EEPROM set up for normal reads. 1 = EEPROM address and data bus latches set up for programming or erasing. Read anytime. Write anytime except when EEPGM = 1 or EEDIV = 0. BYTE, ROW, ERASE and EELAT bits can be written simultaneously or in any sequence. EEPGM — Program and Erase Enable 0 = Disables program/erase voltage to EEPROM. 1 = Applies program/erase voltage to EEPROM. The EEPGM bit can be set only after EELAT has been set. When EELAT and EEPGM are set simultaneously, EEPGM remains clear but EELAT is set. The BULKP, AUTO, BYTE, ROW, ERASE and EELAT bits cannot be changed when EEPGM is set. To complete a program or erase cycle when AUTO bit is clear, two successive writes to clear EEPGM and EELAT bits are required before reading the programmed data. When the AUTO bit is set, EEPGM is automatically cleared after the program or erase cycle completes. Note that if an attempt is made to modify a protected block location the modify cycle does not start and the EEPGM bit isn’t automatically cleared. A write to an EEPROM location has no effect when EEPGM is set. Latched address and data cannot be modified during program or erase. Technical Data 132 MC68HC912DT128A — Rev 4.0 EEPROM Memory MOTOROLA EEPROM Memory Program/Erase Operation 9.6 Program/Erase Operation A program or erase operation should follow the sequence below if AUTO bit is clear: 1. Write BYTE, ROW and ERASE to desired value, write EELAT = 1 2. Write a byte or an aligned word to an EEPROM address 3. Write EEPGM = 1 4. Wait for programming, tPROG or erase, tERASE delay time 5. Write EEPGM = 0 6. Write EELAT = 0 If the AUTO bit is set, steps 4 and 5 can be replaced by a step to poll the EEPGM bit until it is cleared. CAUTION: The state machine will not start if an attempt is made to program or erase a protected location and therefore the EEPGM bit will never clear on that EEPROM operation. Check for protected status or use a software timeout to avoid a continuous loop whilst polling the EEPGM bit. If using a timeout, ensure steps 5 and 6 are still executed. It is possible to program/erase more bytes or words without intermediate EEPROM reads, by jumping from step 5 to step 2. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data EEPROM Memory 133 EEPROM Memory 9.7 Shadow Word Mapping The shadow word is mapped to location $_FC0 and $_FC1 when the NOSHW bit in EEMCR register is zero. The value in the shadow word is loaded to the EEMCR, EEDIVH and EEDIVL after reset. Table 9-4 shows the mapping of each bit from shadow word to the registers. Table 9-4. Shadow word mapping Shadow word location Register / Bit $_FC0 bit 7 EEMCR / NOBDML $_FC0, bit 6 EEMCR / NOSHW $_FC0, bit 5 EEMCR / bit 5(1) $_FC0, bit 4 EEMCR / bit 4(1) $_FC0, bit 3:2 not mapped(2)) $_FC0, bit 1:0 EEDIVH / bit 1:0 $_FC1, bit 7:0 EEDIVCLK / bit 7:0 1. Reserved for testing. Must be set to one in user application. 2. Reserved. Must be set to one in user application for future compatibility. Technical Data 134 MC68HC912DT128A — Rev 4.0 EEPROM Memory MOTOROLA EEPROM Memory Programming EEDIVH and EEDIVL Registers 9.8 Programming EEDIVH and EEDIVL Registers The EEDIVH and EEDIVL registers must be correctly set according to the oscillator frequency before any EEPROM location can be programmed or erased. 9.8.1 Normal mode The EEDIVH and EEDIVL registers are write once in normal mode. Upon system reset, the application program is required to write the correct divider value to EEDIVH and EEDIVL registers based on the oscillator frequency. After the first write, the value in the EEDIVH and EEDIVL registers is locked from being overwritten until the next reset. The EEPROM is then ready for standard program/erase routines. CAUTION: Runaway code can possibly corrupt the EEDIVH and EEDIVL registers if they are not initialized (write once registers). 9.8.2 Special mode If an existing application code with EEPROM program/erase routines is fixed and the system is already operating at a known oscillator frequency, it is recommended to initialize the shadow word with the corresponding EEDIVH and EEDIVL values in special mode. The shadow word initializes EEDIVH and EEDIVL registers upon system reset to ensure software compatibility with existing code. Initializing the EEDIVH and EEDIVL registers in special modes (SMODN=0) is accomplished by the following steps. 1. Write correct divider value to EEDIVH and EEDIVL registers based on the oscillator frequency as per Table 9-1. 2. Remove the SHADOW word protection by clearing SHPROT bit in EEPROT register. 3. Clear NOSHW bit in EEMCR register to make the SHADOW word visible at $0FC0-$0FC1. 4. Write NOSHW bit in EEMCR register to make the SHADOW word visible at $0FC0-$0FC1. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data EEPROM Memory 135 EEPROM Memory 5. Program bits 1 and 0 of the high byte of the SHADOW word and bits 7 to 0 of the low byte of the SHADOW word like a regular EEPROM location at address $0FC0 and $0FC1. Do not program other bits of the high byte of the SHADOW word (location $0FC0); otherwise some regular EEPROM array locations will not be visible. At the next reset, the SHADOW values are loaded into the EEDIVH and EEDIVL registers. They do not require further initialization as long as the oscillator frequency of the target application is not changed. 6. Protect the SHADOW word by setting SHPROT bit in EEPROT register. Technical Data 136 MC68HC912DT128A — Rev 4.0 EEPROM Memory MOTOROLA Technical Data — MC68HC912DT128A Section 10. Resets and Interrupts 10.1 Contents 10.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 137 10.3 Exception Priority . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 138 10.4 Maskable interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .138 10.5 Latching of Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .139 10.6 Interrupt Control and Priority Registers . . . . . . . . . . . . . . . . .141 10.7 Interrupt test registers. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 142 10.8 Resets. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .143 10.9 Effects of Reset . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 145 10.10 Register Stacking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 147 10.2 Introduction CPU12 exceptions include resets and interrupts. Each exception has an associated 16-bit vector, which points to the memory location where the routine that handles the exception is located. Vectors are stored in the upper 128 bytes of the standard 64K byte address map. The six highest vector addresses are used for resets and non-maskable interrupt sources. The remainder of the vectors are used for maskable interrupts, and all must be initialized to point to the address of the appropriate service routine. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Resets and Interrupts 137 Resets and Interrupts 10.3 Exception Priority A hardware priority hierarchy determines which reset or interrupt is serviced first when simultaneous requests are made. Six sources are not maskable. The remaining sources are maskable, and any one of them can be given priority over other maskable interrupts. The priorities of the non-maskable sources are: 1. POR or RESET pin 2. Clock monitor reset 3. COP watchdog reset 4. Unimplemented instruction trap 5. Software interrupt instruction (SWI) 6. XIRQ signal (if X bit in CCR = 0) 10.4 Maskable interrupts Maskable interrupt sources include on-chip peripheral systems and external interrupt service requests. Interrupts from these sources are recognized when the global interrupt mask bit (I) in the CCR is cleared. The default state of the I bit out of reset is one, but it can be written at any time. Interrupt sources are prioritized by default but any one maskable interrupt source may be assigned the highest priority by means of the HPRIO register. The relative priorities of the other sources remain the same. An interrupt that is assigned highest priority is still subject to global masking by the I bit in the CCR, or by any associated local bits. Interrupt vectors are not affected by priority assignment. HPRIO can only be written while the I bit is set (interrupts inhibited). Table 10-1 lists interrupt sources and vectors in default order of priority. Before masking an interrupt by clearing the corresponding local enable bit, it is required to set the I-bit to avoid an SWI. Technical Data 138 MC68HC912DT128A — Rev 4.0 Resets and Interrupts MOTOROLA Resets and Interrupts Latching of Interrupts 10.5 Latching of Interrupts XIRQ is always level triggered and IRQ can be selected as a level triggered interrupt. These level triggered interrupt pins should only be released during the appropriate interrupt service routine. Generally the interrupt service routine will handshake with the interrupting logic to release the pin. In this way, the MCU will never start the interrupt service sequence only to determine that there is no longer an interrupt source. In event that this does occur the trap vector will be taken. If IRQ is selected as an edge triggered interrupt, the hold time of the level after the active edge is independent of when the interrupt is serviced. As long as the minimum hold time is met, the interrupt will be latched inside the MCU. In this case the IRQ edge interrupt latch is cleared automatically when the interrupt is serviced. All of the remaining interrupts are latched by the MCU with a flag bit. These interrupt flags should be cleared during an interrupt service routine or when interrupts are masked by the I bit. By doing this, the MCU will never get an unknown interrupt source and take the trap vector. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Resets and Interrupts 139 Resets and Interrupts Table 10-1. Interrupt Vector Map Vector Address Interrupt Source CCR Mask None None None None None X bit I bit I bit I bit I bit I bit I bit I bit I bit I bit I bit I bit I bit I bit I bit $FFFE, $FFFF $FFFC, $FFFD $FFFA, $FFFB $FFF8, $FFF9 $FFF6, $FFF7 $FFF4, $FFF5 $FFF2, $FFF3 $FFF0, $FFF1 $FFEE, $FFEF $FFEC, $FFED $FFEA, $FFEB $FFE8, $FFE9 $FFE6, $FFE7 $FFE4, $FFE5 $FFE2, $FFE3 $FFE0, $FFE1 $FFDE, $FFDF $FFDC, $FFDD $FFDA, $FFDB $FFD8, $FFD9 Reset Clock monitor fail reset COP failure reset Unimplemented instruction trap SWI XIRQ IRQ Real time interrupt Timer channel 0 Timer channel 1 Timer channel 2 Timer channel 3 Timer channel 4 Timer channel 5 Timer channel 6 Timer channel 7 Timer overflow Pulse accumulator overflow Pulse accumulator input edge SPI serial transfer complete $FFD6, $FFD7 SCI 0 I bit $FFD4, $FFD5 SCI 1 I bit $FFD2, $FFD3 $FFD0, $FFD1 ATD0 or ATD1 MSCAN 0 wake-up I bit I bit $FFCE, $FFCF Key wake-up J or H I bit $FFCC, $FFCD $FFCA, $FFCB Modulus down counter underflow Pulse Accumulator B Overflow I bit I bit $FFC8, $FFC9 MSCAN 0 errors I bit $FFC6, $FFC7 $FFC4, $FFC5 $FFC2, $FFC3 $FFC0, $FFC1 $FFBE, $FFBF MSCAN 0 receive MSCAN 0 transmit CGM lock and limp home IIC Bus MSCAN 1 wake-up I bit I bit I bit I bit I bit Technical Data 140 Local Enable None COPCTL (CME, FCME) COP rate selected None None None INTCR (IRQEN) RTICTL (RTIE) TMSK1 (C0I) TMSK1 (C1I) TMSK1 (C2I) TMSK1 (C3I) TMSK1 (C4I) TMSK1 (C5I) TMSK1 (C6I) TMSK1 (C7I) TMSK2 (TOI) PACTL (PAOVI) PACTL (PAI) SP0CR1 (SPIE) SC0CR2 (TIE, TCIE, RIE, ILIE) SC1CR2 (TIE, TCIE, RIE, ILIE) ATDxCTL2 (ASCIE) C0RIER (WUPIE) KWIEJ[7:0] and KWIEH[7:0] MCCTL (MCZI) PBCTL (PBOVI) C0RIER (RWRNIE, TWRNIE, RERRIE, TERRIE, BOFFIE, OVRIE) C0RIER (RXFIE) C0TCR (TXEIE[2:0]) PLLCR (LOCKIE, LHIE) IBCR (IBIE) C1RIER (WUPIE) HPRIO Value to Elevate – – – – – – $F2 $F0 $EE $EC $EA $E8 $E6 $E4 $E2 $E0 $DE $DC $DA $D8 $D6 $D4 $D2 $D0 $CE $CC $CA $C8 $C6 $C4 $C2 $C0 $BE MC68HC912DT128A — Rev 4.0 Resets and Interrupts MOTOROLA Resets and Interrupts Interrupt Control and Priority Registers Table 10-1. Interrupt Vector Map Vector Address CCR Mask Interrupt Source Local Enable HPRIO Value to Elevate $FFBC, $FFBD MSCAN 1 errors I bit $FFBA, $FFBB $FFB8, $FFB9 MSCAN 1 receive MSCAN 1 transmit I bit I bit C1RIER (RWRNIE, TWRNIE, RERRIE, TERRIE, BOFFIE, OVRIE) C1RIER (RXFIE) C1TCR (TXEIE[2:0]) $FFB6, $FFB7(1) MSCAN 2 wake-up I bit C2RIER (WUPIE) $B6 $B4 $B2 $FFB4, $FFB5 MSCAN 2 errors I bit C2RIER (RWRNIE, TWRNIE, RERRIE, TERRIE, BOFFIE, OVRIE) $FFB2, $FFB3(1) MSCAN 2 receive I bit C2RIER (RXFIE) $FFB0, $FFB1(1) $FF80–$FFAF MSCAN 2 transmit I bit C2TCR (TXEIE[2:0]) Reserved I bit (1) $BC $BA $B8 $B0 $80–$AE 1. MC68HC912DT128A only 10.6 Interrupt Control and Priority Registers INTCR — Interrupt Control Register RESET: Bit 7 IRQE 0 6 IRQEN 1 $001E 5 DLY 1 4 0 0 3 0 0 2 0 0 1 0 0 Bit 0 0 0 IRQE — IRQ Select Edge Sensitive Only 0 = IRQ configured for low-level recognition. 1 = IRQ configured to respond only to falling edges (on pin PE1/IRQ). IRQE can be read anytime and written once in normal modes. In special modes, IRQE can be read anytime and written anytime, except the first write is ignored. IRQEN — External IRQ Enable The IRQ pin has an internal pull-up. 0 = External IRQ pin is disconnected from interrupt logic. 1 = External IRQ pin is connected to interrupt logic. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Resets and Interrupts 141 Resets and Interrupts IRQEN can be read and written anytime in all modes. DLY — Enable Oscillator Start-up Delay on Exit from STOP The delay time of about 4096 cycles is based on the XCLK rate chosen. 0 = No stabilization delay imposed on exit from STOP mode. A stable external oscillator must be supplied. 1 = Stabilization delay is imposed before processing resumes after STOP. DLY can be read anytime and written once in normal modes. In special modes, DLY can be read and written anytime. HPRIO — Highest Priority I Interrupt RESET: Bit 7 1 1 6 PSEL6 1 $001F 5 PSEL5 1 4 PSEL4 1 3 PSEL3 0 2 PSEL2 0 1 PSEL1 1 Bit 0 0 0 Write only if I mask in CCR = 1 (interrupts inhibited). Read anytime. To give a maskable interrupt source highest priority, write the low byte of the vector address to the HPRIO register. For example, writing $F0 to HPRIO would assign highest maskable interrupt priority to the real-time interrupt timer ($FFF0). If an un-implemented vector address or a non-Imasked vector address (value higher than $F2) is written, then IRQ will be the default highest priority interrupt. 10.7 Interrupt test registers These registers are used in special modes for testing the interrupt logic and priority without needing to know which modules and what functions are used to generate the interrupts.Each bit is used to force a specific interrupt vector by writing it to 1.Bits are named with B6 through F4 to indicate vectors $FFB6 through $FFF4. These bits are also used in special modes to view that an interrupt caused by a module has reached the interrupt module. Technical Data 142 MC68HC912DT128A — Rev 4.0 Resets and Interrupts MOTOROLA Resets and Interrupts Resets These registers can only be read in special modes (read in normal mode will return $00). Reading these registers at the same time as the interrupt is changing will cause an indeterminate value to be read. These registers can only be written in special mode. ITST0 — Interrupt Test Register 0 RESET: Bit 7 ITE6 0 6 ITE8 0 $0018 5 ITEA 0 4 ITEC 0 3 ITEE 0 2 ITF0 0 1 ITF2 0 Bit 0 ITF4 0 ITST1 — Interrupt Test Register 1 RESET: Bit 7 ITD6 0 6 ITD8 0 $0019 5 ITDA 0 4 ITDC 0 3 ITDE 0 2 ITE0 0 1 ITE2 0 Bit 0 ITE4 0 ITST2 — Interrupt Test Register 2 RESET: Bit 7 ITC6 0 6 ITC8 0 $001A 5 ITCA 0 4 ITCC 0 3 ITCE 0 2 ITD0 0 1 ITD2 0 Bit 0 ITD4 0 ITST3 — Interrupt Test Register 3 RESET: Bit 7 ITB6 0 6 ITB8 0 $001B 5 ITBA 0 4 ITBC 0 3 ITBE 0 2 ITC0 0 1 ITC2 0 Bit 0 ITC4 0 10.8 Resets There are four possible sources of reset. Power-on reset (POR), and external reset on the RESET pin share the normal reset vector. The computer operating properly (COP) reset and the clock monitor reset each has a vector. Entry into reset is asynchronous and does not require a clock but the MCU cannot sequence out of reset without a system clock. 10.8.1 Power-On Reset A positive transition on VDD causes a power-on reset (POR). An external voltage level detector, or other external reset circuits, are the usual MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Resets and Interrupts 143 Resets and Interrupts source of reset in a system. The POR circuit only initializes internal circuitry during cold starts and cannot be used to force a reset as system voltage drops. It is important to use an external low voltage reset circuit (for example: MC34064 or MC33464) to prevent power transitions or corruption of RAM or EEPROM. 10.8.2 External Reset The CPU distinguishes between internal and external reset conditions by sensing whether the reset pin rises to a logic one in less than nine Eclock cycles after an internal device releases reset. When a reset condition is sensed, an internal circuit drives the RESET pin low and a clocked reset sequence controls when the MCU can begin normal processing. In the case of a clock monitor error, a 4096 cycle oscillator start-up delay is imposed before the reset recovery sequence starts (reset is driven low throughout this 4096 cycle delay). The internal reset recovery sequence then drives reset low for 16 to 17 cycles and releases the drive to allow reset to rise. Nine E-clock cycles later the reset pin is sampled. If the pin is still held low, the CPU assumes that an external reset has occurred. If the pin is high, it indicates that the reset was initiated internally by either the COP system or the clock monitor. To prevent a COP reset from being detected during an external reset, hold the reset pin low for at least 32 cycles. To prevent a clock monitor reset from being detected during an external reset, hold the reset pin low for at least 4096 + 32 cycles. An external RC power-up delay circuit on the reset pin is not recommended — circuit charge time can cause the MCU to misinterpret the type of reset that has occurred. 10.8.3 COP Reset The MCU includes a computer operating properly (COP) system to help protect against software failures. When COP is enabled, software must write $55 and $AA (in this order) to the COPRST register in order to keep a watchdog timer from timing out. Other instructions may be executed between these writes. A write of any value other than $55 or $AA or Technical Data 144 MC68HC912DT128A — Rev 4.0 Resets and Interrupts MOTOROLA Resets and Interrupts Effects of Reset software failing to execute the sequence properly causes a COP reset to occur. In addition, windowed COP operation can be selected. In this mode, a write to the COPRST register must occur in the last 25% of the selected period. A premature write will also reset the part. 10.8.4 Clock Monitor Reset If clock frequency falls below a predetermined limit when the clock monitor is enabled, a reset occurs. 10.9 Effects of Reset When a reset occurs, MCU registers and control bits are changed to known start-up states, as follows. 10.9.1 Operating Mode and Memory Map Operating mode and default memory mapping are determined by the states of the BKGD, MODA, and MODB pins during reset. The SMODN, MODA, and MODB bits in the MODE register reflect the status of the mode-select inputs at the rising edge of reset. Operating mode and default maps can subsequently be changed according to strictly defined rules. 10.9.2 Clock and Watchdog Control Logic The COP watchdog system is enabled, with the CR[2:0] bits set for the longest duration time-out. The clock monitor is disabled. The RTIF flag is cleared and automatic hardware interrupts are masked. The rate control bits are cleared, and must be initialized before the RTI system is used. The DLY control bit is set to specify an oscillator start-up delay upon recovery from STOP mode. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Resets and Interrupts 145 Resets and Interrupts 10.9.3 Interrupts PSEL is initialized in the HPRIO register with the value $F2, causing the external IRQ pin to have the highest I-bit interrupt priority. The IRQ pin is configured for level-sensitive operation (for wired-OR systems). However, the interrupt mask bits in the CPU12 CCR are set to mask Xand I-related interrupt requests. 10.9.4 Parallel I/O If the MCU comes out of reset in a single-chip mode, all ports are configured as general-purpose high-impedance inputs. If the MCU comes out of reset in an expanded mode, port A and port B are used for the address/data bus, and port E pins are normally used to control the external bus (operation of port E pins can be affected by the PEAR register). Out of reset, port J, port H, port K, port IB, port P, port S, port T, port AD0 and port AD1 are all configured as general-purpose inputs. 10.9.5 Central Processing Unit After reset, the CPU fetches a vector from the appropriate address, then begins executing instructions. The stack pointer and other CPU registers are indeterminate immediately after reset. The CCR X and I interrupt mask bits are set to mask any interrupt requests. The S bit is also set to inhibit the STOP instruction. 10.9.6 Memory After reset, the internal register block is located from $0000 to $03FF, RAM is at $2000 to $3FFF, and EEPROM is located at $0800 to $0FFF. In single chip mode one 32-Kbyte FLASH EEPROM module is located from $4000 to $7FFF and $C000 to $FFFF, and the other three 32-Kbyte FLASH EEPROM modules are accessible through the program page window located from $8000 to $BFFF. The first 32-Kbyte FLASH EEPROM is also accessible through the program page window. Technical Data 146 MC68HC912DT128A — Rev 4.0 Resets and Interrupts MOTOROLA Resets and Interrupts Register Stacking 10.9.7 Other Resources The enhanced capture timer (ECT), pulse width modulation timer (PWM), serial communications interfaces (SCI0 and SCI1), serial peripheral interface (SPI), inter-IC bus (IIC), Motorola Scalable CANs (MSCAN0 and MSCAN1) and analog-to-digital converters (ATD0 and ATD1) are off after reset. 10.10 Register Stacking Once enabled, an interrupt request can be recognized at any time after the I bit in the CCR is cleared. When an interrupt service request is recognized, the CPU responds at the completion of the instruction being executed. Interrupt latency varies according to the number of cycles required to complete the instruction. Some of the longer instructions can be interrupted and will resume normally after servicing the interrupt. When the CPU begins to service an interrupt, the instruction queue is cleared, the return address is calculated, and then it and the contents of the CPU registers are stacked as shown in Table 10-2. Table 10-2. Stacking Order on Entry to Interrupts Memory Location SP – 2 CPU Registers RTNH : RTNL SP – 4 YH : YL SP – 6 XH : XL SP – 8 SP – 9 B:A CCR After the CCR is stacked, the I bit (and the X bit, if an XIRQ interrupt service request is pending) is set to prevent other interrupts from disrupting the interrupt service routine. The interrupt vector for the highest priority source that was pending at the beginning of the interrupt sequence is fetched, and execution continues at the referenced location. At the end of the interrupt service routine, an RTI instruction restores the content of all registers from information on the stack, and normal program execution resumes. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Resets and Interrupts 147 Resets and Interrupts If another interrupt is pending at the end of an interrupt service routine, the register unstacking and restacking is bypassed and the vector of the interrupt is fetched. Technical Data 148 MC68HC912DT128A — Rev 4.0 Resets and Interrupts MOTOROLA Technical Data — MC68HC912DT128A Section 11. I/O Ports with Key Wake-up 11.1 Contents 11.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 149 11.3 Key Wake-up and port Registers . . . . . . . . . . . . . . . . . . . . . . 150 11.4 Key Wake-Up Input Filter . . . . . . . . . . . . . . . . . . . . . . . . . . . . 154 11.2 Introduction The offers 16 additional I/O ports with key wake-up capability. The key wake-up feature of the MC68HC912DT128A issues an interrupt that will wake up the CPU when it is in the STOP or WAIT mode. Two ports are associated with the key wake-up function: port H and port J. Port H and port J wake-ups are triggered with either a rising or falling signal edge. For each pin which has an interrupt enabled, there is a path to the interrupt request signal which has no clocked devices when the part is in stop mode. This allows an active edge to bring the part out of stop. Digital filtering is included to prevent pulses shorter than a specified value from waking the part from STOP. An interrupt is generated when a bit in the KWIFH or KWIFJ register and its corresponding KWIEH or KWIEJ bit are both set. All 16 bits/pins share the same interrupt vector. Key wake-ups can be used with the pins configured as inputs or outputs. Default register addresses, as established after reset, are indicated in the following descriptions. For information on re-mapping the register block, refer to Operating Modes. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data I/O Ports with Key Wake-up 149 I/O Ports with Key Wake-up 11.3 Key Wake-up and port Registers PORTJ — Port J Register $0028 Bit 7 6 5 4 3 2 1 Bit 0 PORT PJ7 PJ6 PJ5 PJ4 PJ3 PJ2 PJ1 PJ0 KWU KWJ7 KWJ6 KWJ5 KWJ4 KWJ3 KWJ2 KWJ1 KWJ0 RESET: - - - - - - - - Read and write anytime. PORTH — Port H Register $0029 Bit 7 6 5 4 3 2 1 Bit 0 PH7 PH6 PH5 PH4 PH3 PH2 PH1 PH0 KWU KWH7 KWH6 KWH5 KWH4 KWH3 KWH2 KWH1 KWH0 RESET: - - - - - - - - Read and write anytime. DDRJ — Port J Data Direction Register $002A Bit 7 6 5 4 3 2 1 Bit 0 DDJ7 DDJ6 DDJ5 DDJ4 DDJ3 DDJ2 DDJ1 DDJ0 0 0 0 0 0 0 0 0 RESET: Data direction register J is associated with port J and designates each pin as an input or output. Read and write anytime DDRJ[7:0] — Data Direction Port J 0 = Associated pin is an input 1 = Associated pin is an output Technical Data 150 MC68HC912DT128A — Rev 4.0 I/O Ports with Key Wake-up MOTOROLA I/O Ports with Key Wake-up Key Wake-up and port Registers DDRH — Port H Data Direction Register RESET: $002B Bit 7 6 5 4 3 2 1 Bit 0 DDH7 DDH6 DDH5 DDH4 DDH3 DDH2 DDH1 DDH0 0 0 0 0 0 0 0 0 Data direction register H is associated with port H and designates each pin as an input or output. Read and write anytime. DDRH[7:0] — Data Direction Port H 0 = Associated pin is an input 1 = Associated pin is an output KWIEJ — Key Wake-up Port J Interrupt Enable Register RESET: $002C Bit 7 6 5 4 3 2 1 Bit 0 KWIEJ7 KWIEJ6 KWIEJ5 KWIEJ4 KWIEJ3 KWIEJ2 KWIEJ1 KWIEJ0 0 0 0 0 0 0 0 0 Read and write anytime. KWIEJ[7:0] — Key Wake-up Port J Interrupt Enables 0 = Interrupt for the associated bit is disabled 1 = Interrupt for the associated bit is enabled KWIEH — Key Wake-up Port H Interrupt Enable Register $002D Bit 7 6 5 4 3 2 1 Bit 0 KWIEH7 KWIEH6 KWIEH5 KWIEH4 KWIEH3 KWIEH2 KWIEH1 KWIEH0 0 0 0 0 0 0 0 0 RESET: Read and write anytime. KWIEH[7:0] — Key Wake-up Port H Interrupt Enables 0 = Interrupt for the associated bit is disabled 1 = Interrupt for the associated bit is enabled MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data I/O Ports with Key Wake-up 151 I/O Ports with Key Wake-up KWIFJ — Key Wake-up Port J Flag Register $002E Bit 7 6 5 4 3 2 1 Bit 0 KWIFJ7 KWIFJ6 KWIFJ5 KWIFJ4 KWIFJ3 KWIFJ2 KWIFJ1 KWIFJ0 0 0 0 0 0 0 0 0 RESET: Read and write anytime. Each flag is set by an active edge on its associated input pin. This could be a rising or falling edge based on the state of the KWPJ register. To clear the flag, write one to the corresponding bit in KWIFJ. Initialize this register after initializing KWPJ so that illegal flags can be cleared. KWIFJ[7:0] — Key Wake-up Port J Flags 0 = Active edge on the associated bit has not occurred 1 = Active edge on the associated bit has occurred (an interrupt will occur if the associated enable bit is set). KWIFH — Key Wake-up Port H Flag Register $002F Bit 7 6 5 4 3 2 1 Bit 0 KWIFH7 KWIFH6 KWIFH5 KWIFH4 KWIFH3 KWIFH2 KWIFH1 KWIFH0 0 0 0 0 0 0 0 0 RESET: Read and write anytime. Each flag is set by an active edge on its associated input pin. This could be a rising or falling edge based on the state of the KWPH register. To clear the flag, write one to the corresponding bit in KWIFH. Initialize this register after initializing KWPH so that illegal flags can be cleared. KWIFH[7:0] — Key Wake-up Port H Flags 0 = Active edge on the associated bit has not occurred 1 = Active edge on the associated bit has occurred (an interrupt will occur if the associated enable bit is set) Technical Data 152 MC68HC912DT128A — Rev 4.0 I/O Ports with Key Wake-up MOTOROLA I/O Ports with Key Wake-up Key Wake-up and port Registers KWPJ — Key Wake-up Port J Polarity Register RESET: $0030 Bit 7 6 5 4 3 2 1 Bit 0 KWPJ7 KWPJ6 KWPJ5 KWPJ4 KWPJ3 KWPJ2 KWPJ1 KWPJ0 0 0 0 0 0 0 0 0 Read and write anytime. It is best to clear the flags after initializing this register because changing the polarity of a bit can cause the associated flag to become set. KWPJ[7:0] — Key Wake-up Port J Polarity Selects 0 = Falling edge on the associated port J pin sets the associated flag bit in the KWIFJ register and a resistive pull-up device is connected to associated port J input pin. 1 = Rising edge on the associated port J pin sets the associated flag bit in the KWIFJ register and a resistive pull-down device is connected to associated port J input pin. KWPH — Key Wake-up Port H Polarity Register $0031 Bit 7 6 5 4 3 2 1 Bit 0 KWPH7 KWPH6 KWPH5 KWPH4 KWPH3 KWPH2 KWPH1 KWPH0 0 0 0 0 0 0 0 0 RESET: Read and write anytime. It is best to clear the flags after initializing this register because changing the polarity of a bit can cause the associated flag to become set. KWPH[7:0] — Key Wake-up Port H Polarity Selects 0 = Falling edge on the associated port H pin sets the associated flag bit in the KWIFH register and a resistive pull-up device is connected to associated port H input pin. 1 = Rising edge on the associated port H pin sets the associated flag bit in the KWIFH register and a resistive pull-down device is connected to associated port H input pin. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data I/O Ports with Key Wake-up 153 I/O Ports with Key Wake-up 11.4 Key Wake-Up Input Filter The KWU input signals are filtered by a digital filter which is active only during STOP mode. The purpose of the filter is to prevent single pulses shorter than a specified value from waking the part from STOP. The filter is composed of an internal oscillator and a majority voting logic. The filter oscillator starts the oscillation by detecting a triggering edge on an input if the corresponding interrupt enable bit is set. The majority voting logic takes three samples of an asserted input pin at each filter oscillator period and if two samples are taken at the triggering level, the filter recognizes a valid triggering level and sets the corresponding interrupt flag. In this way the majority voting logic rejects the short non-triggering state between two incoming triggering pulses. As the filter is shared with all KWU inputs, the filter considers any pulse coming from any input pin for which the corresponding interrupt enable bit is set. The timing specification is given for a single pulse. The time interval between the triggering edges of two following pulses should be greater than the tKWSP in order to be considered as a single pulse by the filter. If this time interval is shorter than tKWSP, the majority voting logic may treat the two consecutive pulses as a single valid pulse. The filter is shared by all the KWU pins. Hence any valid triggering level on any KWU pin is seen by the filter. The timing specification applies to the input of the filter. Technical Data 154 MC68HC912DT128A — Rev 4.0 I/O Ports with Key Wake-up MOTOROLA I/O Ports with Key Wake-up Key Wake-Up Input Filter Glitch, filtered out, no STOP wake-up Valid STOP Wake-Up pulse tKWSTP min. tKWSTP max. Minimum time interval between pulses to be recognized as single pulses tKWSP Figure 11-1. STOP Key Wake-up Filter MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data I/O Ports with Key Wake-up 155 I/O Ports with Key Wake-up Technical Data 156 MC68HC912DT128A — Rev 4.0 I/O Ports with Key Wake-up MOTOROLA Technical Data — MC68HC912DT128A Section 12. Clock Functions 12.1 Contents 12.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 157 12.3 Clock Sources. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .158 12.4 Phase-Locked Loop (PLL) . . . . . . . . . . . . . . . . . . . . . . . . . . . 159 12.5 Acquisition and Tracking Modes. . . . . . . . . . . . . . . . . . . . . . .161 12.6 Limp-Home and Fast STOP Recovery modes . . . . . . . . . . . . 163 12.7 System Clock Frequency Formulae . . . . . . . . . . . . . . . . . . . . 181 12.8 Clock Divider Chains . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .182 12.9 Computer Operating Properly (COP) . . . . . . . . . . . . . . . . . . .185 12.10 Real-Time Interrupt. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 186 12.11 Clock Monitor . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .186 12.12 Clock Function Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 187 12.2 Introduction Clock generation circuitry generates the internal and external E-clock signals as well as internal clock signals used by the CPU and on-chip peripherals. A clock monitor circuit, a computer operating properly (COP) watchdog circuit, and a periodic interrupt circuit are also incorporated into the MC68HC912DT128A. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Clock Functions 157 Clock Functions 12.3 Clock Sources A compatible external clock signal can be applied to the EXTAL pin or the MCU can generate a clock signal using an on-chip oscillator circuit and an external crystal or ceramic resonator. The MCU uses several types of internal clock signals derived from the primary clock signal: TxCLK clocks are used by the CPU. ECLK and PCLK are used by the bus interfaces, SPI, PWM, ATD0 and ATD1. MCLK is either PCLK or XCLK, and drives on-chip modules such as SCI0, SCI1 and ECT. XCLK drives on-chip modules such as RTI, COP and restart-from-stop delay time. SLWCLK is used as a calibration output signal. The MSCAN module is clocked by EXTALi or SYSCLK, under control of an MSCAN bit. The clock monitor is clocked by EXTALi. The BDM system is clocked by BCLK or ECLK, under control of a BDM bit. A slow mode clock divider is included to deliver a lower clock frequency for the SCI baud rate generators, the ECT timer module, and the RTI and COP clocks. The slow clock bus frequencies divide the crystal frequency in a programmable range of 4 to 252, with steps of 4. This is very useful for low power operation. See the Clock Divider Chains section for further details. Figure 12-1 shows some of the timing relationships. Technical Data 158 MC68HC912DT128A — Rev 4.0 Clock Functions MOTOROLA Clock Functions Phase-Locked Loop (PLL) T1CLK T2CLK T3CLK T4CLK INT ECLK PCLK XCLK CANCLK Figure 12-1. Internal Clock Relationships 12.4 Phase-Locked Loop (PLL) The phase-locked loop (PLL) of the MC68HC912DT128A is designed for robust operation in an Automotive environment. The allowed PLL crystal or ceramic resonator reference of 0.5 to 8MHz is selected for the wide availability of components with good stability over the automotive temperature range. Please refer to Figure 12-6 in section Clock Divider Chains for an overview of system clocks. NOTE: When selecting a crystal, it is recommended to use one with the lowest possible frequency in order to minimise EMC emissions. An oscillator design with reduced power consumption allows for slow wait operation with a typical power supply current less than a milliampere. The PLL circuitry can be bypassed when the VDDPLL supply is at VSS level. In this case, the PLL module is powered down and the oscillator output transistor has a stronger transconductance for improved drive of higher frequency resonators (as the crystal frequency needs to be twice the maximum bus frequency). Refer to Figure 3-4 in Pinout and Signal Descriptions. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Clock Functions 159 Clock Functions EXTAL REDUCED CONSUMPTION OSCILLATOR LOCK LOCK DETECTOR REFDV REFERENCE PROGRAMMABLE DIVIDER REFCLK XTAL EXTALi DIVCLK PDET PHASE DETECTOR UP DOWN CPUMP VCO VDDPLL SLOW MODE PROGRAMMABLE CLOCK DIVIDER SLWCLK LOOP PROGRAMMABLE DIVIDER LOOP FILTER ÷2 SLDV EXTALi SYN XFC PAD ×2 PLLCLK XCLK Figure 12-2. PLL Functional Diagram The PLL may be used to run the MCU from a different time base than the incoming crystal value. It creates an integer multiple of a reference frequency. For increased flexibility, the crystal clock can be divided by values in a range of 1 – 8 (in unit steps) to generate the reference frequency. The PLL can multiply this reference clock in a range of 1 to 64. Although it is possible to set the divider to command a very high clock frequency, do not exceed the specified bus frequency limit for the MCU. If the PLL is selected, it will continue to run when in WAIT mode resulting in more power consumption than normal. To take full advantage of the reduced power consumption of WAIT mode, turn off the PLL before going into WAIT. Please note that in this case the PLL stabilization time applies. The PLL operation is suspended in STOP mode. After STOP exit followed by the stabilization time, it resumes operation at the same frequency, provided the AUTO bit is set. A passive external loop filter must be placed on the control line (XFC pad). The filter is a second-order, low-pass filter to eliminate the VCO input ripple. Values of components in the diagram are dependent upon the desired VCO operation. See XFC description. Technical Data 160 MC68HC912DT128A — Rev 4.0 Clock Functions MOTOROLA Clock Functions Acquisition and Tracking Modes 12.5 Acquisition and Tracking Modes The lock detector compares the frequencies of the VCO feedback clock, DIVCLK, and the final reference clock, REFCLK. Therefore, the speed of the lock detector is directly proportional to the final reference frequency. The circuit determines the mode of the PLL and the lock condition based on this comparison. The PLL filter is manually or automatically configurable into one of two operating modes: • Acquisition mode — In acquisition mode, the filter can make large frequency corrections to the VCO. This mode is used at PLL startup or when the PLL has suffered a severe noise hit and the VCO frequency is far off the desired frequency. This mode can also be desired in harsh environments when the leakage levels on the filter pin (XFC) can overcome the tracking currents of the PLL charge pump. When in acquisition mode, the ACQ bit in the PLL control register is clear. • Tracking mode — In tracking mode, the filter makes only small corrections to the frequency of the VCO. The PLL enters tracking mode when the VCO frequency is nearly correct. The PLL is automatically in tracking mode when not in acquisition mode or when the ACQ bit is set. The PLL can change the bandwidth or operational mode of the loop filter manually or automatically. With an identical filtering time constant, the PLL bandwidth is larger in acquisition mode than in tracking by a ratio of about 3. In automatic bandwidth control mode (AUTO = 1), the lock detector automatically switches between acquisition and tracking modes. Automatic bandwidth control mode also is used to determine when the VCO clock, PLLCLK, is safe to use as the source for the base clock, SYSCLK. If PLL LOCK interrupt requests are enabled, the software can wait for an interrupt request and then check the LOCK bit. If CPU interrupts are disabled, software can poll the LOCK bit continuously (during PLL start-up, usually) or at periodic intervals. In either case, when the LOCK bit is set, the PLLCLK clock is safe to use as the source MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Clock Functions 161 Clock Functions for the base clock. See Clock Divider Chains. If the VCO is selected as the source for the base clock and the LOCK bit is clear, the PLL has suffered a severe noise hit and the software must take appropriate action, depending on the application. The following conditions apply when the PLL is in automatic bandwidth control mode: • The ACQ bit is a read-only indicator of the mode of the filter. • The ACQ bit is set when the VCO frequency is within a certain tolerance, ∆trk, and is cleared when the VCO frequency is out of a certain tolerance, ∆unt. See 19 Electrical Characteristics. • The LOCK bit is a read-only indicator of the locked state of the PLL. • The LOCK bit is set when the VCO frequency is within a certain tolerance, ∆Lock, and is cleared when the VCO frequency is out of a certain tolerance, ∆unl. See 19 Electrical Characteristics. • CPU interrupts can occur if enabled (LOCKIE = 1) when the lock condition changes, toggling the LOCK bit. The PLL also can operate in manual mode (AUTO = 0). All LOCK features described above are active in this mode, only the bandwidth control is disabled. Manual mode is used mainly for systems operating under harsh conditions (e.g.uncoated PCBs in automotive environments). When this is the case, the PLL is likely to remain in acquisition mode. The following conditions apply when in manual mode: • ACQ is a writable control bit that controls the mode of the filter. Before turning on the PLL in manual mode, the ACQ bit must be clear. • In case tracking is desired (ACQ = 1), the software must wait a given time, tacq, after turning on the PLL by setting PLLON in the PLL control register. This is to avoid switching to tracking mode too early while the XFC voltage level is still too far away from its quiescent value corresponding to the target frequency. This operation would be very detrimental to the stabilization time. Technical Data 162 MC68HC912DT128A — Rev 4.0 Clock Functions MOTOROLA Clock Functions Limp-Home and Fast STOP Recovery modes 12.6 Limp-Home and Fast STOP Recovery modes If the crystal frequency is not available due to a crystal failure or a long crystal start-up time, the MCU system clock can be supplied by the VCO at its minimum operating frequency, f VCOMIN. This mode of operation is called Limp-Home Mode and is only available when the VDDPLL supply voltage is at VDD level (i.e. power supply for the PLL module is present). Upon power-up, the ability of the system to start in Limp-Home Mode is restricted to normal MCU modes only. The Clock Monitor circuit (see section Clock Monitor) can detect the loss of EXTALi, the external clock input signal, regardless of whether this signal is used as the source for MCU clocks or as the PLL reference clock. The clock monitor control bits, CME and FCME, are used to enable or disable external clock detection. A missing external clock may occur in the three following instances: • During normal clock operation. • At Power-On Reset. • In the STOP exit sequence 12.6.1 Clock Loss during Normal Operation The ‘no limp-home mode’ bit, NOLHM, determines how the MCU responds to an external clock loss in this case. With limp home mode disabled (NOLHM bit set) and the clock monitor enabled (CME or FCME bits set), on a loss of clock the MCU is reset via the clock monitor reset vector. A latch in the PLL control section prevents the chip exiting reset in Limp Home Mode (this is required as the NOLHM bit gets cleared bu reset). Only external clock activity can bring the MCU out from this reset state. Once reset has been exited, the latch is cleared and another session, with or without Limp Home Mode enabled, can take place. This is the same behavior as standard M68HC12 circuits without PLL or operation with VDDPLL at VSS level. With limp home mode enabled (NOLHM bit cleared) and the clock monitor enabled (CME or FCME bits set), on a loss of clock, the PLL MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Clock Functions 163 Clock Functions VCO clock at its minimum frequency, f VCOMIN, is provided as the system clock, allowing the MCU to continue operating. The MCU is said to be operating in “limp-home” mode with the forced VCO clock as the system clock. PLLON and BCSP (‘bus clock select PLL’) signals are forced high and the MCS (‘module clock select’) signal is forced low. The LHOME flag in the PLLFLG register is set to indicate that the MCU is running in limp-home mode. A change of this flag sets the limp-home interrupt flag, LHIF, and if enabled by the LHIE bit, the limp-home mode interrupt is requested. The Clock Monitor is enabled irrespective of CME and FCME bit settings. Module clocks to the RTI & COP (XCLK), BDM (BCLK) and ECT & SCI (MCLK) are forced to be PCLK (at f VCOMIN) and ECLK is also equal to f VCOMIN. MSCAN clock select is unaffected. EXTALi A B Clock Monitor Fail 0 --> 4096 0 --> 4096 13-stage counter (Clocked by XCLK) Limp-Home BCSP SYSCLK Restore BCSP PLLCLK (Limp-Home) Restore PLLCLK or EXTALi Figure 12-3. Clock Loss during Normal Operation The clock monitor is polled each time the 13-stage free running counter reaches a count of 4096 XCLK cycles i.e. mid-count, hence the clock status gets checked once every 8192 XCLK cycles. When the presence of an external clock is detected, the MCU exits limp-home mode, clearing the LHOME flag and setting the limp-home interrupt flag. Upon leaving limp-home mode, BCSP and MCS signals are restored to their Technical Data 164 MC68HC912DT128A — Rev 4.0 Clock Functions MOTOROLA Clock Functions Limp-Home and Fast STOP Recovery modes values before the clock loss. All clocks return to their normal settings and Clock Monitor control is returned to the CME & FCME bits. If AUTO and BCSP bits were set before the clock loss (selecting the PLL to provide a system clock) the SYSCLK ramps-up and the PLL locks at the previously selected frequency. To prevent PLL operation when the external clock frequency comes back, software should clear the BCSP bit while running in limp-home mode. The two shaded regions A and B in Figure 12-3 present a of code run away due to incorrect clocks on SYSCLK if the MCU is clocked by EXTALi and the PLL is not used. In region A, there is a delay between the loss of clock and its detection by the clock monitor. When the EXTALi clock signal is disturbed, the clock generation circuitry may receive an out of spec signal and drive the CPU with irregular clocks. This may lead to code runaway. In region B, as the 13-stage counter is free running, the count of 4096 may be reached when the amplitude of the EXTALi clock has not stabilized. In this case, an improper EXTALi is sent to the clock generation circuitry when limp-home mode is exited. This may also cause code runaway. If the MCU is clocked by the PLL, the risk of code runaway is very low, but it can still occur under certain conditions due to irregular clocks from the clock source appearing on the SYSCLK. CAUTION: NOTE: The COP watch dog should always be enabled in order to reset the MCU in case of a code runaway situation. It is always advisable to take additional precautions within the application software to trap such situations. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Clock Functions 165 Clock Functions 12.6.2 No Clock at Power-On Reset The voltage level on VDDPLL determines how the MCU responds to an external clock loss in this case. With the VDDPLL supply voltage at VDD level, any reset sets the Clock Monitor Enable bit (CME) and the PLLON bit and clears the NOLHM bit. Therefore, if the MCU is powered up without an external clock, limphome mode is entered provided the MCU is in a normal mode of operation. VDD Power-On Detector EXTALi (Slow EXTALi) Clock Monitor Fail Limp-Home 13-stage counter (Clocked by XCLK) 0 --> 4096 0 --> 4096 BCSP Reset: BCSP = 0 Internal reset SYSCLK SYSCLK (Slow EXTALi) PLLCLK (L.H.) EXTALi PLLCLK (Software check of Limp-Home Flag) EXTALi Figure 12-4. No Clock at Power-On Reset Technical Data 166 MC68HC912DT128A — Rev 4.0 Clock Functions MOTOROLA Clock Functions Limp-Home and Fast STOP Recovery modes During this power up sequence, after the POR pulse falling edge, the VCO supplies the limp-home clock frequency to the 13-stage counter, as the BCSP output is forced high and MCS is forced low. XCLK, BCLK and MCLK are forced to be PCLK, which is supplied by the VCO at fVCOMIN. The initial period taken for the 13-stage counter to reach 4096 defines the internal reset period. If the clock monitor indicates the presence of an external clock during the internal reset period, limp-home mode is de-asserted and the 13-stage counter is then driven by EXTALi clock. After the 13-stage counter reaches a count of 4096 XCLK cycles, the internal reset is released, the 13-stage counter is reset and the MCU exits reset normally using EXTALi clock. However, if the crystal start-up time is longer than the initial count of 4096 XCLK cycles, or in the absence of an external clock, the MCU will leave the reset state in limp-home mode. The LHOME flag is set and LHIF limp-home interrupt request is set, to indicate it is not operating at the desired frequency. Then after yet another 4096 XCLK cycles followed regularly by 8192 XCLK cycles (corresponding to the 13-stage counter timing out), a check of the clock monitor status is performed. When the presence of an external clock is detected limp-home mode is exited generating a limp-home interrupt if enabled. CAUTION: The clock monitor circuit can be misled by the EXTALi clock into reporting a good signal before it has fully stabilised. Under these conditions improper EXTALi clock cycles can occur on SYSCLK. This may lead to a code runaway. To ensure that this situation does not occur, the external Reset period should be longer than the oscillator stabilisation time - this is an application dependent parameter. With the VDDPLL supply voltage at VSS level, the PLL module and hence limp-home mode are disabled, the device will remain effectively in a static state whilst there is no activity on EXTALi. The internal reset period and MCU operation will execute only on EXTALi clock. NOTE: The external clock signal must stabilise within the initial 4096 reset counter cycles. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Clock Functions 167 Clock Functions 12.6.3 STOP Exit and Fast STOP Recovery Stop mode is entered when a STOP instruction is executed. Recovery from STOP depends primarily on the state of the three status bits NOLHM, CME & DLY. The DLY bit controls the duration of the waiting period between the actual exit for some key blocks (e.g. clock monitor, clock generators) and the effective exit from stop for all the rest of the MCU. DLY=1 enables the 13-stage counter to generate a 4096 count delay. DLY=0 selects no delay. As the XCLK is derived from the slow mode divider, the value in the SLOW register modifies the actual delay time. NOTE: DLY=0 is only recommended when there is a good signal available at the EXTAL pin (e.g. an external square wave source). STOP mode is exited with an external reset, an external interrupt from IRQ or XIRQ, a Key Wake-Up interrupt from port J or port H, or an MSCAN Wake-Up interrupt. EXTALi Clock Monitor Fail Limp-Home 13-stage counter (Clocked by XCLK) 0 --> 4096 BCSP Restore BCSP STOP (DLY = 1) STOP (DLY = 0) SYSCLK PLLCLK (L.H.) Restore PLLCLK or EXTALi Figure 12-5. STOP Exit and Fast STOP Recovery Technical Data 168 MC68HC912DT128A — Rev 4.0 Clock Functions MOTOROLA Clock Functions Limp-Home and Fast STOP Recovery modes 12.6.4 STOP exit without Limp Home mode, clock monitor disabled (NOLHM=1, CME=0, DLY=X) If Limp home mode is disabled (VDDPLL=VSS or NOLHM bit set) and the CME (or FCME) bit is cleared, the MCU goes into STOP mode when a STOP instruction is executed. If EXTALi clock is present then exit from STOP will occur normally using this clock. Under this condition, DLY should always be set to allow the crystal to stabilise and minimise the risk of code runaway. With DLY=1 execution resumes after a delay of 4096 XCLK cycles. NOTE: The external clock signal should stabilise within the 4096 reset counter cycles. Use of DLY=0 is not recommended due to this requirement. 12.6.5 Executing the STOP instruction without Limp Home mode, clock monitor enabled (NOLHM=1, CME=1, DLY=X) If the NOLHM bit and the CME (or FCME) bits are set, a clock monitor failure is detected when a STOP instruction is executed and the MCU resets via the clock monitor reset vector. 12.6.6 STOP exit in Limp Home mode with Delay (NOLHM=0, CME=X, DLY=1) If the NOLHM bit is cleared, then the CME (or FCME) bit is masked when a STOP instruction is executed to prevent a clock monitor failure. When coming out of STOP mode, the MCU goes into limp-home mode where CME and FCME signals are asserted. When using a crystal oscillator, a normal STOP exit sequence requires the DLY bit to be set to allow for the crystal stabilization period. With the 13-stage counter clocked by the VCO (at fVCOMIN), following a delay of 4096 XCLK cycles at the limp-home frequency, if the clock monitor indicates the presence of an external clock, the limp-home mode is de-asserted and the MCU exits STOP normally using EXTALi clock. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Clock Functions 169 Clock Functions Where the crystal start-up time is longer than the initial count of 4096 XCLK cycles, or in the absence of an external clock, the MCU recovers from STOP following the 4096 count in limp-home mode with both the LHOME flag set and the LHIF limp-home interrupt request set to indicate it is not operating at the desired frequency. Each time the 13-stage counter reaches a count of 4096 XCLK cycles, a check of the clock monitor status is performed. When the presence of an external clock is detected, limp-home mode is exited and the LHOME flag is cleared. This sets the limp-home interrupt flag and if enabled by the LHIE bit, the limp-home mode interrupt is requested. CAUTION: The clock monitor circuit can be misled by EXTALi clock into reporting a good signal before it has fully stabilised. Under these conditions, improper EXTALi clock cycles can occur on SYSCLK. This may lead to a code runaway. 12.6.7 STOP exit in Limp Home mode without Delay (Fast Stop Recovery) (NOLHM=0, CME=X, DLY=0) Fast STOP recovery refers to any exit from STOP using DLY=0. If the NOLHM bit is cleared, then the CME (or FCME) bit is masked when a STOP instruction is executed to prevent a clock monitor failure. When coming out of STOP mode, the MCU goes into limp-home mode where CME and FCME signals are asserted. When using a crystal oscillator, it is possible to exit STOP with the DLY bit cleared. In this case, STOP is de-asserted without delay and the MCU will execute software in limp-home mode, giving the crystal oscillator time to stablise. CAUTION: This mode is not recommended since the risk of the clock monitor detecting incorrect clocks is high. Technical Data 170 MC68HC912DT128A — Rev 4.0 Clock Functions MOTOROLA Clock Functions Limp-Home and Fast STOP Recovery modes Each time the 13-stage counter reaches a count of 4096 XCLK cycles (every 8192 cycles), a check of the clock monitor status is performed. If the clock monitor indicates the presence of an external clock limp-home mode is de-asserted, the LHOME flag is cleared and the limp-home interrupt flag is set. Upon leaving limp-home mode, BCSP and MCS are restored to their values before the loss of clock, and all clocks return to their previous frequencies. If AUTO and BCSP were set before the clock loss, the SYSCLK ramps-up and the PLL locks at the previously selected frequency. To prevent PLL operation when the external clock frequency comes back, the software should clear the BCSP bit while running in limp-home mode. When using an external clock, i.e. a square wave source, it is possible to exit STOP with the DLY bit cleared. In this case the LHOME flag is never set and STOP is de-asserted without delay. 12.6.8 Pseudo-STOP Pseudo-STOP is a low power mode similar to STOP where the external oscillator is allowed to run (at reduced amplitude) whilst the rest of the part is in STOP. This increases the current consumption over STOP mode by the amount of current in the oscillator, but reduces wear and mechanical stress on the crystal. If the PSTP bit in the PLLCR register is set, the MCU goes into PseudoSTOP mode when a STOP instruction is executed. Pseudo-STOP mode is exited the same as STOP with an external reset, an external interrupt from IRQ or XIRQ, a Key Wake-Up interrupt from port J or port H, or an MSCAN Wake-Up interrupt. The effect of the DLY bit is the same as noted above in STOP Exit and Fast STOP Recovery. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Clock Functions 171 Clock Functions 12.6.9 Pseudo-STOP exit in Limp Home mode with Delay (NOLHM=0, CME=X, DLY=1) When coming out of Pseudo-STOP mode with the NOLHM bit cleared and the DLY bit set, the MCU goes into limp-home mode (regardless of the state of the CME or FCME bits). The VCO supplies the limp-home clock frequency to the 13-stage counter (XCLK). The BCSP output is forced high and MCS is forced low. After the 13-stage counter reaches a count of 4096 XCLK cycles, a check of the clock monitor is performed and as the crystal oscillator was kept running due to the Pseudo-stop mode, the MCU exits STOP normally, using the EXTALi clock. In the case where a crystal failure occurred during pseudo-stop, then the MCU exits STOP using the limp home clock (fVCOMIN) with both the LHOME flag set and the LHIF limphome interrupt request set to indicate it is not operating at the desired frequency. Each time the 13-stage counter reaches a count of 4096 XCLK cycles, a check of the clock monitor is performed. If the clock monitor indicates the presence of an external clock, limp-home mode is de-asserted, the LHOME flag is cleared and the LHIF limp-home interrupt request is set to indicate a return to normal operation using EXTALi clock. 12.6.10 Pseudo-STOP exit in Limp Home mode without Delay (Fast Stop Recovery) (NOLHM=0, CME=X, DLY=0) If Pseudo-STOP is exited with the NOLHM bit set to 0 and the DLY bit is cleared then the exit from Pseudo-STOP is accomplished without delay as in Fast STOP recovery. CAUTION: Where Pseudo-STOP recovers using the Limp Home Clock the VCO which has been held in STOP - must be restarted in order to supply the limp home frequency. This restart, which occurs at a high frequency and ramps toward the limp home frequency, is almost immediately supplied to the CPU before it may have reached the steady state frequency. It is possible that the initial clock frequency may be high enough to cause the CPU to function incorrectly with a resultant risk of code runaway. Technical Data 172 MC68HC912DT128A — Rev 4.0 Clock Functions MOTOROLA Clock Functions Limp-Home and Fast STOP Recovery modes 12.6.11 Pseudo-STOP exit without Limp Home mode, clock monitor enabled (NOLHM=1, CME=1, DLY=X) If the NOLHM bit is set and the CME (or FCME) bits are set, a clock monitor failure is detected when a STOP instruction is executed and the MCU resets via the clock monitor reset vector. 12.6.12 Pseudo-STOP exit without Limp Home mode, clock monitor disabled (NOLHM=1, CME=0, DLY=1) If NOLHM is set to 1 and the CME and FCME bits are cleared, the limp home clock is not used. In this mode, crystal activity is the only method by which the device may recover from Pseudo-STOP. The device will start execution with the EXTALi clock following 4096 XCLK cycles. (NOLHM=1, CME=0, DLY=0) If NOLHM is set to 1 and the CME and FCME bits are cleared, the limp home clock is not used. In this mode, crystal activity is the only method by which the device may recover from Pseudo-STOP. The device will start execution with the EXTALi clock following 16 XCLK cycles. CAUTION: Due to switching of the clock this configuration is not recommended. 12.6.13 Summary of STOP and pseudo-STOP Mode Exit Conditions Table 12-1 and Table 12-2 summarise the exit conditions from STOP and pseudo-STOP modes using Interrupt, Key-interrupt and XIRQ. A short RESET pulse should not be used to exit stop or pseudo-STOP mode because Limp Home mode is automatically entered after RESET (when VDDPLL=VDD). The RESET wakeup pulse must be longer than the oscillator startup time (as in power on reset) in order to remove the risk of code runaway. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Clock Functions 173 Clock Functions . . Table 12-1. Summary of STOP Mode Exit Conditions Mode Conditions Summary STOP exit without Limp Home mode, clock monitor disabled NOLHM=1 CME=0 DLY=X Oscillator must be stable within 4096 XCLK cycles. XCLK can be modified by SLOW divider register. Use of DLY=0 only recommended with external clock. Executing the STOP instruction without Limp Home mode, clock monitor enabled NOLHM=1 CME=1 DLY=X When a STOP instruction is executed the MCU resets via the clock monitor reset vector. STOP exit in Limp Home mode with Delay NOLHM=0 CME=X DLY=1 Oscillator must be stable within 4096 fVCOMIN cycles or there is a possibility of code runaway as the clock monitor circuit can be misled by EXTALi clock into reporting a good signal before it has fully stabilised STOP exit in Limp Home mode without Delay (Fast Stop Recovery) NOLHM=0 CME=X DLY=0 This mode is only recommended for use with an external clock source. Table 12-2. Summary of Pseudo STOP Mode Exit Conditions Mode Conditions Summary Pseudo-STOP exit in Limp Home mode with Delay NOLHM=0 CME=X DLY=1 CPU exits stop in limp home mode and oscillator running. If the oscillator fails during pseudo-STOP and then recovers there is a possibility of code runaway as the clock monitor circuit can be misled by EXTALi clock into reporting a good signal before it has fully stabilised Pseudo-STOP exit in Limp Home mode without Delay (Fast Stop Recovery) NOLHM=0 CME=X DLY=0 This mode is not recommended as it is possible that the initial VCO clock frequency may be high enough to cause code runaway. Pseudo-STOP exit without Limp Home mode, clock monitor enabled NOLHM=1 CME=1 DLY=X When a STOP instruction is executed the MCU resets via the clock monitor reset vector. Pseudo-STOP exit without Limp Home mode, clock monitor disabled, with Delay NOLHM=1 CME=0 DLY=1 Oscillator starts operation following 4096 XCLK cycles (actual controlled by SLOW mode divider). Pseudo-STOP exit without Limp Home mode, clock monitor disabled, without Delay NOLHM=1 CME=0 DLY=0 This mode is only recommended for use with an external clock source. Technical Data 174 MC68HC912DT128A — Rev 4.0 Clock Functions MOTOROLA Clock Functions Limp-Home and Fast STOP Recovery modes 12.6.14 PLL Register Descriptions RESET: Bit 7 6 5 4 3 2 1 Bit 0 0 0 SYN5 SYN4 SYN3 SYN2 SYN1 SYN0 0 0 0 0 0 0 0 0 SYNR — Synthesizer Register $0038 Read anytime, write anytime, except when BCSP = 1 (PLL selected as bus clock). If the PLL is on, the count in the loop divider (SYNR) register effectively multiplies up the bus frequency from the PLL reference frequency by SYNR + 1. Internally, SYSCLK runs at twice the bus frequency. Caution should be used not to exceed the maximum rated operating frequency for the CPU. RESET: Bit 7 6 5 4 3 2 1 Bit 0 0 0 0 0 0 REFDV2 REFDV1 REFDV0 0 0 0 0 0 0 0 0 REFDV — Reference Divider Register $0039 Read anytime, write anytime, except when BCSP = 1. The reference divider bits provides a finer granularity for the PLL multiplier steps. The reference frequency is divided by REFDV + 1. Bit 7 6 5 4 3 2 1 Bit 0 TSTOUT7 TSTOUT6 TSTOUT5 TSTOUT4 TSTOUT3 TSTOUT2 TSTOUT1 TSTOUT0 0 0 0 0 0 0 0 0 RESET: CGTFLG — Clock Generator Test Register $003A Always reads zero, except in test modes. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Clock Functions 175 Clock Functions Bit 7 6 5 4 3 2 1 Bit 0 LOCKIF LOCK 0 0 0 0 LHIF LHOME 0 0 0 0 0 0 0 0 RESET: PLLFLG — PLL Flags $003B Read anytime, refer to each bit for write conditions. LOCKIF — PLL Lock Interrupt Flag 0 = No change in LOCK bit. 1 = LOCK condition has changed, either from a locked state to an unlocked state or vice versa. To clear the flag, write one to this bit in PLLFLG. Cleared in limp-home mode. LOCK — Locked Phase Lock Loop Circuit Regardless of the bandwidth control mode (automatic or manual): 0 = PLL VCO is not within the desired tolerance of the target frequency. 1 = After the phase lock loop circuit is turned on, indicates the PLL VCO is within the desired tolerance of the target frequency. Write has no effect on LOCK bit. This bit is cleared in limp-home mode as the lock detector cannot operate without the reference frequency. LHIF — Limp-Home Interrupt Flag 0 = No change in LHOME bit. 1 = LHOME condition has changed, either entered or exited limphome mode. To clear the flag, write one to this bit in PLLFLG. LHOME — Limp-Home Mode Status 0 = MCU is operating normally, with EXTALi clock available for generating clocks or as PLL reference. 1 = Loss of reference clock. CGM delivers PLL VCO limp-home frequency to the MCU. For Limp-Home mode, see Limp-Home and Fast STOP Recovery modes. Technical Data 176 MC68HC912DT128A — Rev 4.0 Clock Functions MOTOROLA Clock Functions Limp-Home and Fast STOP Recovery modes Bit 7 6 5 4 3 2 1 Bit 0 LOCKIE PLLON AUTO ACQ 0 PSTP LHIE NOLHM 0 —(1) 1 0 0 0 0 —(2) RESET: PLLCR — PLL Control Register $003C 1. Set when VDDPLL power supply is high. Forced to 0 when VDDPLL is low. 2. Cleared when VDDPLL power supply is high. Forced to 1 when VDDPLL is low. Read and write anytime. Exceptions are listed below for each bit. LOCKIE — PLL LOCK Interrupt Enable 0 = PLL LOCK interrupt is disabled 1 = PLL LOCK interrupt is enabled Forced to 0 when VDDPLL=0. PLLON — Phase Lock Loop On 0 = Turns the PLL off. 1 = Turns on the phase lock loop circuit. If AUTO is set, the PLL will lock automatically. Cannot be cleared when BCSP = 1 (PLL selected as bus clock). Forced to 0 when VDDPLL is at VSS level. In limp-home mode, the output of PLLON is forced to 1, but the PLLON bit reads the latched value. AUTO — Automatic Bandwidth Control 0 = Automatic Mode Control is disabled and the PLL is under software control, using ACQ bit. 1 = Automatic Mode Control is enabled. ACQ bit is read only. Automatic bandwidth control selects either the high bandwidth (acquisition) mode or the low bandwidth (tracking) mode depending on how close to the desired frequency the VCO is running. See Electrical Specifications. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Clock Functions 177 Clock Functions ACQ — Not in Acquisition If AUTO = 1 (ACQ is Read Only) 0 = PLL VCO is not within the desired tolerance of the target frequency. The loop filter is in high bandwidth, acquisition mode. 1 = After the phase lock loop circuit is turned on, indicates the PLL VCO is within the desired tolerance of the target frequency. The loop filter is in low bandwidth, tracking mode. If AUTO = 0 0 = High bandwidth PLL loop selected 1 = Low bandwidth PLL loop selected PSTP — Pseudo-STOP Enable 0 = Pseudo-STOP oscillator mode is disabled 1 = Pseudo-STOP oscillator mode is enabled In Pseudo-STOP mode, the oscillator is still running while the MCU is maintained in STOP mode. This allows for a faster STOP recovery and reduces the mechanical stress and aging of the resonator in case frequent STOP conditions at the expense of a slightly increased power consumption. LHIE — Limp-Home Interrupt Enable 0 = Limp-Home interrupt is disabled 1 = Limp-Home interrupt is enabled Forced to 0 when VDDPLL is at VSS level. NOLHM —No Limp-Home Mode 0 = Loss of reference clock forces the MCU in limp-home mode. 1 = Loss of reference clock causes standard Clock Monitor reset. Read anytime; Normal modes: write once; Special modes: write anytime. Forced to 1 when VDDPLL is at VSS level. Technical Data 178 MC68HC912DT128A — Rev 4.0 Clock Functions MOTOROLA Clock Functions Limp-Home and Fast STOP Recovery modes RESET: Bit 7 6 5 4 3 2 1 Bit 0 0 BCSP BCSS 0 0 MCS 0 0 0 0 0 0 0 0 0 0 CLKSEL — Clock Generator Clock select Register $003D Read and write anytime. Exceptions are listed below for each bit. BCSP and BCSS bits determine the clock used by the main system including the CPU and buses. BCSP — Bus Clock Select PLL 0 = SYSCLK is derived from the crystal clock or from SLWCLK. 1 = SYSCLK source is the PLL. Cannot be set when PLLON = 0. In limp-home mode, the output of BCSP is forced to 1, but the BCSP bit reads the latched value. BCSS — Bus Clock Select Slow 0 = SYSCLK is derived from the crystal clock EXTALi. 1 = SYSCLK source is the Slow clock SLWCLK. This bit has no effect when BCSP is set. MCS — Module Clock Select 0 = M clock is the same as PCLK. 1 = M clock is derived from Slow clock SLWCLK. This bit determines the clock used by the ECT module and the baud rate generators of the SCIs. In limp-home mode, the output of MCS is forced to 0, but the MCS bit reads the latched value. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Clock Functions 179 Clock Functions Bit 7 6 5 4 3 2 1 Bit 0 0 0 SLDV5 SLDV4 SLDV3 SLDV2 SLDV1 SLDV0 0 0 0 0 0 0 0 0 RESET: SLOW — Slow mode Divider Register $003E Read and write anytime. A write to this register changes the SLWCLK frequency with minimum delay (less than one SLWCLK cycle), thus allowing immediate tuneup of the performance versus power consumption for the modules using this clock. The frequency divide ratio is 2 times (SLOW), hence the divide range is 2 to 126 (not on first pass products). When SLOW = 0, the divider is bypassed. The generation of E, P and M clocks further divides SLWCLK by 2. Hence, the final ratio of Bus to EXTALi Frequency is programmable to 2, 4, 8, 12, 16, 20, ..., 252, by steps of 4. SLWCLK is a 50% duty cycle signal. Technical Data 180 MC68HC912DT128A — Rev 4.0 Clock Functions MOTOROLA Clock Functions System Clock Frequency Formulae 12.7 System Clock Frequency Formulae See Figure 12-6: SLWCLK = EXTALi / ( 2 x SLOW ) SLOW = 1,2,..63 SLWCLK = EXTALi SLOW = 0 PLLCLK = 2 x EXTALi x (SYNR + 1) / (REFDV + 1) ECLK = SYSCLK / 2 XCLK = SLWCLK / 2 PCLK = SYSCLK / 2 BCLK(1) = EXTALi / 2 Boolean equations: SYSCLK = (BCSP & PLLCLK) | (BCSP & BCSS & EXTALi) | (BCSP & BCSS & SLWCLK) MCLK = (PCLK & MCS) | (XCLK & MCS) MSCAN system = (EXTALi & CLKSRC) | (SYSCLK & CLKSRC) BDM system = (BCLK & CLKSW) | (ECLK & CLKSW) NOTE: During limp-home mode PCLK, ECLK, BCLK, MCLK and XCLK are supplied by VCO (PLLCLK). 1. If SYSCLK is slower than EXTALi (BCSS=1, BCSP=0, SLOW>0), BCLK becomes ECLK. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Clock Functions 181 Clock Functions 12.8 Clock Divider Chains Figure 12-6, Figure 12-7, Figure 12-8, and Figure 12-9 summarize the clock divider chains for the various peripherals on the MC68HC912DT128A. BCSP BCSS 1:x PHASE LOCK LOOP SYSCLK PLLCLK ÷2 EXTALi EXTAL BCSP BCSS 0:0 REDUCED CONSUMPTION OSCILLATOR T CLOCK GENERATOR TCLKs E AND P CLOCK GENERATOR ECLK PCLK EXTALi TO CPU TO BUSES, SPI, PWM, ATD0, ATD1 CLKSRC = 1 BCSP BCSS 0:1 XTAL EXTALi TO MSCAN CLKSRC = 0 MCS = 0 MCLK MCS = 1 SLOW MODE CLOCK DIVIDER SLWCLK ÷2 TO SCI0, SCI1, ECT SYNC XCLK TO RTI, COP TO CAL CLKSW = 0 ÷2 SYNC CLKSW = 1 TO BDM TO CLOCK MONITOR Figure 12-6. Clock Generation Chain Technical Data 182 MC68HC912DT128A — Rev 4.0 Clock Functions MOTOROLA Clock Functions Clock Divider Chains Bus clock select bits BCSP and BCSS in the clock select register (CLKSEL) determine which clock drives SYSCLK for the main system including the CPU and buses. BCSS has no effect if BCSP is set. During the transition, the clock select output will be held low and all CPU activity will cease until the transition is complete. The Module Clock Select bit MCS determines the clock used by the ECT module and the baud rate generators of the SCIs. In limp-home mode, the output of MCS is forced to 0, but the MCS bit reads the latched value. It allows normal operation of the serial and timer subsystems at a fixed reference frequency while allowing the CPU to operate at a higher, variable frequency. XCLK ÷ 2048 ÷4 REGISTER: RTICTL BITS: RTR2, RTR1, RTR0 REGISTER: RTICTL BIT:RTBYP 0:0:0 REGISTER: COPCTL BITS: CR2, CR1, CR0 0:0:1 MCLK SC0BD MODULUS DIVIDER: ÷ 1, 2, 3, 4, 5, 6,...,8190, 8191 SCI0 RECEIVE BAUD RATE (16x) ÷ 16 SCI0 TRANSMIT BAUD RATE (1x) SC1BD MODULUS DIVIDER: ÷ 1, 2, 3, 4, 5, 6,...,8190, 8191 SCI1 RECEIVE BAUD RATE (16x) ÷ 16 SCI1 TRANSMIT BAUD RATE (1x) 0:0:0 0:0:1 ÷2 0:1:0 ÷4 0:1:0 ÷2 0:1:1 ÷4 0:1:1 ÷2 1:0:0 ÷4 1:0:0 ÷2 1:0:1 ÷4 1:0:1 ÷2 1:1:0 ÷2 1:1:0 ÷2 1:1:1 ÷2 1:1:1 TO RTI TO COP Figure 12-7. Clock Chain for SCI0, SCI1, RTI, COP MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Clock Functions 183 Clock Functions MCLK REGISTER: TMSK2 BITS: PR2, PR1, PR0 0:0:0 TEN REGISTER: MCCTL BITS: MCPR1, MCPR0 0:0 MCEN ÷2 0:0:1 ÷4 0:1 ÷2 0:1:0 ÷2 1:0 ÷2 0:1:1 ÷2 1:1 MODULUS DOWN COUNTER REGISTER: PACTL BITS: PAEN, CLK1, CLK0 0:x:x 1:0:0 ÷2 1:0:0 Prescaled MCLK 1:0:1 ÷2 1:0:1 ÷2 1:1:0 1:1:0 ÷2 PULSE ACC LOW BYTE PACLK/256 1:1:1 PACLK/65536 (PAOV) 1:1:1 PACLK GATE LOGIC PORT T7 PULSE ACC HIGH BYTE PAMOD TO TIMER MAIN COUNTER (TCNT) PAEN Figure 12-8. Clock Chain for ECT Technical Data 184 MC68HC912DT128A — Rev 4.0 Clock Functions MOTOROLA Clock Functions Computer Operating Properly (COP) PCLK 5-BIT MODULUS COUNTER (PR0-PR4) ÷2 ÷2 TO ATD0 and ATD1 ÷2 REGISTER: SP0BR BITS: SPR2, SPR1, SPR0 0:0:0 SPI BIT RATE 0:0:1 MSCAN CLOCK EXTALi ÷2 0:1:0 ÷2 0:1:1 ÷2 1:0:0 ÷2 1:0:1 ÷2 ÷2 CLKSRC SYSCLK ECLK CLKSW 1:1:0 BDM BIT CLOCK: BCLK BKGD IN SYNCHRONIZER 1:1:1 BKGD DIRECTION BKGD PIN LOGIC BKGD OUT Receive: Detect falling edge, count 12 E clocks, Sample input Transmit 1: Detect falling edge, count 6 E clocks while output is high impedance, Drive out 1 E cycle pulse high, high impedance output again Transmit 0: Detect falling edge, Drive out low, count 9 E clocks, Drive out 1 E cycle pulse high, high impedance output Figure 12-9. Clock Chain for MSCAN, SPI, ATD0, ATD1 and BDM 12.9 Computer Operating Properly (COP) The COP or watchdog timer is an added check that a program is running and sequencing properly. When the COP is being used, software is responsible for keeping a free running watchdog timer from timing out. If the watchdog timer times out it is an indication that the software is no longer being executed in the intended sequence; thus a system reset is initiated. Three control bits allow selection of seven COP time-out periods. When COP is enabled, sometime during the selected period the program must write $55 and $AA (in this order) to the COPRST register. If the program fails to do this the part will reset. If any value other than $55 or $AA is written, the part is reset. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Clock Functions 185 Clock Functions In addition, windowed COP operation can be selected. In this mode, writes to the COPRST register must occur in the last 25% of the selected period. A premature write will also reset the part. 12.10 Real-Time Interrupt There is a real time (periodic) interrupt available to the user. This interrupt will occur at one of seven selected rates. An interrupt flag and an interrupt enable bit are associated with this function. There are three bits for the rate select. 12.11 Clock Monitor The clock monitor circuit is based on an internal resistor-capacitor (RC) time delay. If no EXTALi clock edges are detected within this RC time delay, the clock monitor can optionally generate a system reset. The clock monitor function is enabled/disabled by the CME control bit in the COPCTL register. This time-out is based on an RC delay so that the clock monitor can operate without any EXTALi clock. Clock monitor time-outs are shown in Table 12-3. The corresponding EXTALi clock period with an ideal 50% duty cycle is twice this time-out value. Table 12-3. Clock Monitor Time-Outs Supply 5 V +/– 10% Technical Data 186 Range 2–20 µS MC68HC912DT128A — Rev 4.0 Clock Functions MOTOROLA Clock Functions Clock Function Registers 12.12 Clock Function Registers All register addresses shown reflect the reset state. Registers may be mapped to any 2K byte space. RESET: Bit 7 6 5 4 3 2 1 Bit 0 RTIE RSWAI RSBCK Reserved RTBYP RTR2 RTR1 RTR0 0 0 0 0 0 0 0 0 RTICTL — Real-Time Interrupt Control Register $0014 RTIE — Real Time Interrupt Enable Read and write anytime. 0 = Interrupt requests from RTI are disabled. 1 = Interrupt will be requested whenever RTIF is set. RSWAI — RTI and COP Stop While in Wait Write once in normal modes, anytime in special modes. Read anytime. 0 = Allows the RTI and COP to continue running in wait. 1 = Disables both the RTI and COP whenever the part goes into Wait. RSBCK — RTI and COP Stop While in Background Debug Mode Write once in normal modes, anytime in special modes. Read anytime. 0 = Allows the RTI and COP to continue running while in background mode. 1 = Disables both the RTI and COP when the part is in background mode. This is useful for emulation. RTBYP — Real Time Interrupt Divider Chain Bypass Write not allowed in normal modes, anytime in special modes. Read anytime. 0 = Divider chain functions normally. 1 = Divider chain is bypassed, allows faster testing (the divider chain is normally XCLK divided by 213, when bypassed becomes XCLK divided by 4). MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Clock Functions 187 Clock Functions RTR2, RTR1, RTR0 — Real-Time Interrupt Rate Select Read and write anytime. Rate select for real-time interrupt. The clock used for this module is the XCLK. Table 12-4. Real Time Interrupt Rates RTR2 RTR1 RTR0 Divide X By: Time-Out Period Time-Out Period Time-Out Period Time-Out Period X = 125 KHz X = 500 KHz X = 2.0 MHz X = 8.0 MHz OFF OFF OFF OFF 0 0 0 OFF 0 0 1 213 65.536 ms 16.384 ms 4.096 ms 1.024 ms 131.72 ms 32.768 ms 8.196 ms 2.048 ms 0 1 0 214 0 1 1 215 263.44 ms 65.536 ms 16.384 ms 4.096 ms 1 0 0 216 526.88 ms 131.72 ms 32.768 ms 8.196 ms 1 0 1 217 1.05 s 263.44 ms 65.536 ms 16.384 ms 0 2 18 2.11 s 526.88 ms 131.72 ms 32.768 ms 1 219 4.22 s 1.05 s 263.44 ms 65.536 ms 1 1 1 1 Bit 7 6 5 4 3 2 1 Bit 0 RTIF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 RESET: RTIFLG — Real Time Interrupt Flag Register $0015 RTIF — Real Time Interrupt Flag This bit is cleared automatically by a write to this register with this bit set. 0 = Time-out has not yet occurred. 1 = Set when the time-out period is met. Technical Data 188 MC68HC912DT128A — Rev 4.0 Clock Functions MOTOROLA Clock Functions Clock Function Registers Bit 7 6 5 4 3 2 1 Bit 0 CME FCME FCMCOP WCOP DISR CR2 CR1 CR0 RESET: 0/1 0 0 0 0 1 1 1 Normal RESET: 0/1 0 0 0 1 1 1 1 Special COPCTL — COP Control Register $0016 CME — Clock Monitor Enable Read and write anytime. If FCME is set, this bit has no meaning nor effect. 0 = Clock monitor is disabled. Slow clocks and stop instruction may be used. 1 = Slow or stopped clocks (including the stop instruction) will cause a clock reset sequence or limp-home mode. See LimpHome and Fast STOP Recovery modes. On reset CME is 1 if VDDPLL is high CME is 0 if VDDPLL is low. NOTE: The VDDPLL-dependent reset operation is not implemented on first pass products. In this case the state of CME on reset is 0. FCME — Force Clock Monitor Enable Write once in normal modes, anytime in special modes. Read anytime. In normal modes, when this bit is set, the clock monitor function cannot be disabled until a reset occurs. 0 = Clock monitor follows the state of the CME bit. 1 = Slow or stopped clocks will cause a clock reset sequence or limp-home mode. See Limp-Home and Fast STOP Recovery modes. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Clock Functions 189 Clock Functions FCMCOP — Force Clock Monitor Reset or COP Watchdog Reset Writes are not allowed in normal modes, anytime in special modes. Read anytime. If DISR is set, this bit has no effect. 0 = Normal operation. 1 = A clock monitor failure reset or a COP failure reset is forced depending on the state of CME and if COP is enabled. CME COP enabled Forced reset 0 0 none 0 1 COP failure 1 0 Clock monitor failure 1 1 Both(1) 1. Highest priority interrupt vector is serviced. WCOP — Window COP mode Write once in normal modes, anytime in special modes. Read anytime. 0 = Normal COP operation 1 = Window COP operation When set, a write to the COPRST register must occur in the last 25% of the selected period. A premature write will also reset the part. As long as all writes occur during this window, $55 can be written as often as desired. Once $AA is written the time-out logic restarts and the user must wait until the next window before writing to COPRST. Please note, there is a fixed time uncertainty about the exact COP counter state when reset, as the initial prescale clock divider in the RTI section is not cleared when the COP counter is cleared. This means the effective window is reduced by this uncertainty. Table 125 below shows the exact duration of this window for the seven available COP rates. Technical Data 190 MC68HC912DT128A — Rev 4.0 Clock Functions MOTOROLA Clock Functions Clock Function Registers Table 12-5. COP Watchdog Rates CR2 CR1 CR0 Window COP enabled: Divide XCLK by 8.0 MHz XCLK Time-out Window start (1) Window end Effective Window (2) 0 0 0 OFF OFF OFF OFF OFF 0 0 1 2 13 1.024 ms -0/+0.256 ms 0.768 ms 0.768 ms 0 % (3) 0 1 0 2 15 4.096 ms -0/+0.256 ms 3.072 ms 3.840 ms 18.8 % 0 1 1 2 17 16.384 ms -0/+0.256 ms 12.288 ms 16.128 ms 23.4 % 1 0 0 2 19 65.536 ms -0/+1.024 ms 49.152 ms 64.512 ms 23.4 % 1 0 1 2 21 262.144 ms -0/+1.024 ms 196.608 ms 261.120 ms 24.6 % 1 1 0 2 22 524.288 ms -0/+1.024 ms 393.216 ms 523.264 ms 24.8 % 1 1 1 2 23 1.048576 ms -0/+1.024 ms 786.432 ms 1.047552 s 24.9 % 1. Time for writing $55 following previous COP restart of time-out logic due to writing $AA. 2. Please refer to WCOP bit description above. 3. Window COP cannot be used at this rate. DISR — Disable Resets from COP Watchdog and Clock Monitor Writes are not allowed in normal modes, anytime in special modes. Read anytime. 0 = Normal operation. 1 = Regardless of other control bit states, COP and clock monitor will not generate a system reset. CR2, CR1, CR0 — COP Watchdog Timer Rate select bits These bits select the COP time-out rate. The clock used for this module is the XCLK. Write once in normal modes, anytime in special modes. Read anytime. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Clock Functions 191 Clock Functions Bit 7 6 5 4 3 2 1 Bit 0 Bit 7 6 5 4 3 2 1 Bit 0 0 0 0 0 0 0 0 0 RESET: COPRST — Arm/Reset COP Timer Register $0017 Always reads $00. Writing $55 to this address is the first step of the COP watchdog sequence. Writing $AA to this address is the second step of the COP watchdog sequence. Other instructions may be executed between these writes but both must be completed in the correct order prior to time-out to avoid a watchdog reset. Writing anything other than $55 or $AA causes a COP reset to occur. Technical Data 192 MC68HC912DT128A — Rev 4.0 Clock Functions MOTOROLA Oscillator Contents Technical Data — MC68HC912DT128A Section 13. Oscillator 13.1 Contents 13.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 193 13.3 MC68HC912DT128A Oscillator Specification . . . . . . . . . . . .194 13.4 MC68HC912Dx128C Colpitts Oscillator Specification . . . . . . 197 13.5 MC68HC912Dx128P Pierce Oscillator Specification . . . . . . . 212 13.2 Introduction The oscillator implementation on the original 0.65µ (non-suffix) HC12 Dfamily is a ‘Colpitts Oscillator with Translated Ground’. This design was carried over to the first 0.5µ devices (A-suffix), up to the 0L05H mask set, and is described in Section 13.3 MC68HC912DT128A Oscillator Specification. In this section of the document, the term MC68HC912DT128A refers only to the MC68HC912DT128A and MC68HC912DG128A devices. On mask set 1L05H, the Colpitts oscillator was updated, primarily to improve its performance. To maximise the benefit of this change, different external component values are required. However, the oscillator will perform at least as well as the MC68HC912DT128A version with the same components. This implementation and the changes are described in section 13.4 MC68HC912Dx128C Colpitts Oscillator Specification. In this section of the document, the term MC68HC912Dx128C refers only to the MC68HC912DT128C and MC68HC912DG128C devices. In order to make the HC12 D-family oscillator options more flexible, a Pierce oscillator configuration has been implemented on the 2L05H MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Oscillator 193 Oscillator mask set. This implementation, described in section 13.5 MC68HC912Dx128P Pierce Oscillator Specification, utilises the Automatic Level Control circuit to provide a lower power oscillator than traditional Pierce oscillators based on simple inverter circuits. In this section of the document, the term MC68HC912Dx128P refers only to the MC68HC912DT128P and MC68HC912DG128P devices. In the following sections, each particular oscillator implementation is described in detail. Refer to the appropriate sections for the mask set being used and optimum external component selection. 13.3 MC68HC912DT128A Oscillator Specification This section applies to the 0L05H mask set and all previous MC68HC912DT128A versions. 13.3.1 MC68HC912DT128A Oscillator Design Architecture The Colpitts oscillator architecture is shown in Figure 13-1. The component configuration for this oscillator is the same as all previous MC68HC912DT128A configurations. Technical Data 194 MC68HC912DT128A — Rev 4.0 Oscillator MOTOROLA Oscillator MC68HC912DT128A Oscillator Specification BUF - CFLT 2 OTA + RFLT ALC + BIAS EN RFLT CFLT GM RESD EXTAL XTAL CX-EX Resonator CX-VSS Figure 13-1. MC68HC912DT128A Colpitts Oscillator Architecture MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Oscillator 195 Oscillator 13.3.2 MC68HC912DT128A Oscillator Design Guidelines Proper and robust operation of the oscillator circuit requires excellent board layout design practice. Poor layout of the application board can contribute to EMC susceptibility, noise generation, slow starting oscillators, and reaction to noise on the clock input buffer. In addition to published errata for the MC68HC912DT128A, the following guidelines must be followed or failure in operation may occur. • Minimize Capacitance to VSS on EXTAL pin — The Colpitts oscillator architecture is sensitive to capacitance in parallel with the resonator (from EXTAL to VSS). Follow these techniques: i. Remove ground plane from all layers around resonator and EXTAL route ii. Observe a minimum spacing from the EXTAL trace to all other traces of at least three times the design rule minimum (until the microcontroller’s pin pitch prohibits this guideline) iii. Where possible, use XTAL as a shield between EXTAL and VSS iv. Keep EXTAL capacitance to less than 1pF (2pF absolute maximum) NOTE: • Shield all oscillator components from all noisy traces (while observing above guideline). • Keep the VSSPLL pin and the VSS reference to the oscillator as identical as possible. Impedance between these signals must be minimum. • Observe best practice supply bypassing on all MCU power pins. The oscillator’s supply reference is VDD, not VDPLL. • Account for XTAL–VSS and EXTAL–XTAL parasitics in component values. An increase in the EXTAL–XTAL parasitic as a result of reducing EXTAL–VSS parasitic is acceptable provided component value is reduced by the appropriate value. • Minimize XTAL and EXTAL routing lengths to reduce EMC issues. Technical Data 196 MC68HC912DT128A — Rev 4.0 Oscillator MOTOROLA Oscillator MC68HC912Dx128C Colpitts Oscillator Specification NOTE: EXTAL and XTAL routing resistances are less important than capacitances. Using minimum width traces is an acceptable trade-off to reduce capacitance. 13.4 MC68HC912Dx128C Colpitts Oscillator Specification This section applies to the 1L05H mask set, which refers to the newest set of CGM improvements (to the MC68HC912DT128A) with the Colpitts oscillator configuration enabled. The name for these devices is MC68HC912Dx128C. 13.4.1 MC68HC912Dx128C Oscillator Design Architecture The Colpitts oscillator architecture is shown in Figure 13-2. The component configuration for this oscillator is the same as all previous MC68HC912DT128A configurations, although the recommended component values may be different. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Oscillator 197 Oscillator BUF - CFLT 2 OTA + RFLT ALC + BIAS EN RFLT CFLT GM RESD EXTAL XTAL CX-EX Resonator CX-VSS Figure 13-2. MC68HC912Dx128C Colpitts Oscillator Architecture There are the following primary differences between the previous (’A’) and new (’C’) Colpitts oscillator configurations: • Hysteresis was added to the clock input buffer to reduce sensitivity to noise • Internal parasitics were reduced from EXTAL to VSS to increase oscillator gain margin. Technical Data 198 MC68HC912DT128A — Rev 4.0 Oscillator MOTOROLA Oscillator MC68HC912Dx128C Colpitts Oscillator Specification • The bias current to the amplifier was optimized for less variation over process. • The input ESD resistor from EXTAL to the gate of the oscillator amplifier was changed to provide a parallel path, reducing parasitic phase shift in the oscillator. 13.4.1.1 Clock Buffer Hysteresis The input clock buffer uses an Operational Transconductance Amplifier (labeled ‘OTA’ in the figure above) followed by a digital buffer to amplify the input signal on the EXTAL pin into a full-swing clock for use by the clock generation section of the microcontroller. There is an internal R-C filter (composed of components RFLT2 and CFLT2 in the figure above), which creates the DC value to which the EXTAL signal is compared. In this manner, the clock input buffer can track changes in the EXTAL bias voltage due to process variation as well as external factors such as leakage. Because the purpose of the clock input buffer is to amplify relatively lowswing signals into a full-rail output, the gain of the OTA is very high. In the configuration shown, this means that very small levels of noise can be coupled onto the input of the clock buffer resulting in noise amplification. To remedy this issue, hysteresis was added to the OTA so that the circuit could still provide the tolerance to leakage and the high gain required without the noise sensitivity. Approximately 150mV of hysteresis was added with a maximum hysteresis over process variation of 350mV. As such, the clock input buffer will not respond to input signals until they exceed the hysteresis level. At this point, the input signal due to oscillation will dominate the total input waveform and narrow clock pulses due to noise will be eliminated. This circuit will limit the overall performance of the oscillator block only in cases where the amplitude of oscillation is less than the level of hysteresis. The minimum amplitude of oscillation is expected to be in excess of 750mV and the maximum hysteresis is expected to be less than 350mV, providing a factor of safety in excess of two. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Oscillator 199 Oscillator 13.4.1.2 Internal Parasitic Reduction Any oscillator circuit’s gain margin is reduced when a low AC-impedance (low resistance or high capacitance) is placed in parallel with the resonator. In the Colpitts oscillator configuration, this impedance is dominated by the parasitic capacitance from the EXTAL pin to VSS. Since this capacitance is large compared to the shunt capacitance of the resonator, the gain margin in a Colpitts configuration is less than in other configurations. To remedy this issue, the internal circuits were optimized for lower capacitance. This should increase the gain margin and allow more robust operation over process, temperature and voltage variation. To maximize the benefit of this change, different external component values are required. However, the oscillator will function at least as well as the MC68HC912DT128A version with the same components. 13.4.1.3 Bias Current Process Optimization For proper oscillation, the gain margin of the oscillator must exceed one or the circuit will not oscillate. Due to the sensitive gain margin of the Colpitts configuration, process variance in the bias current (which controls the gain of the amplifier) can cause the gain margin to be much lower than typical. This can be as a result of either too much or too little current. To reduce the process sensitivity of the gain, the material of the device that sets the bias current was changed to a material with tighter process and temperature control. As a result, the transconductance and Ibias variances are more limited than in the previous design. Technical Data 200 MC68HC912DT128A — Rev 4.0 Oscillator MOTOROLA Oscillator MC68HC912Dx128C Colpitts Oscillator Specification 13.4.1.4 Input ESD Resistor Path Modification To satisfy the condition of oscillation, the oscillator circuit must not only provide the correct amount of gain but also the correct amount of phase shift. In the Colpitts configuration, the phase shift due to parasitics in the input path to the gate of the transconductance amplifier must be as low as possible. In the original configuration, the parasitic capacitance of the clock input buffer (OTA), automatic Loop Control circuit (ALC), and input resistors (RFLT and RFLT2) reacted with the input resistance to cause a large phase shift. To reduce the phase shift, the input ESD resistor (marked RESD in the figure above) was changed from a single path to the input circuitry (the ALC and the OTA) and oscillator transconductance amplifier (marked GM in the figure above) to a parallel path. In this configuration, the only capacitance causing a phase shift on the input to the transconductance device is due to the transconductance device itself. 13.4.2 MC68HC912Dx128C Oscillator Circuit Specifications 13.4.2.1 Negative Resistance Margin Negative Resistance Margin (NRM) is a figure of merit commonly used to qualify an oscillator circuit with a given resonator. NRM is an indicator of how much additional resistance in series with the resonator is tolerable while still maintaining oscillation. This figure is usually expected to be a multiple of the nominal "maximum" rated ESR of the resonator to allow for variation and degradation of the resonator. Currently, many systems are optimized for NRM by adjusting the load capacitors until NRM is maximized. This method may not achieve the best overall NRM because the optimization method is empirical and not analytical. That is, the method only achieves the best NRM for the particular sample set of microcontrollers, resonators, and board values tested. The figure below shows the anticipated NRM for a nominal 4MHz resonator given the expected process variance of the microcontroller (D60A), board, and crystal (excluding ESR). In this case, the value of load capacitors providing the optimum NRM for a best-case situation MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Oscillator 201 Oscillator yield an unacceptable NRM for a worst-case situation (the slope of the NRM vs. capacitance curve is very steep, indicating severe sensitivity to small variations). If the NRM optimization happened to be performed on a best-case sample set, there could be unexpected sensitivity at worstcase. Negative Resistance Margin vs. Capacitance 100 Negative Resistance Margin 1000 WCS TYP TYP BCS 10 8 10 13 15 18 22 27 33 39 47 56 68 Capacitance NRM measurement techniques can also generate misleading results when applied to Automatic Level Control (ALC) style oscillator circuits such as the D60x/Dx128x. Many NRM methods slowly increase series resistance until oscillation stops. ALC-style oscillators reduce the gain of the oscillator circuit after start-up to reduce current, so if the oscillator tends to have more gain than optimum it will be more tolerant of additional resistance after start-up than it will during the start-up process. This means that NRM figures may be optimistic unless the method verifies the NRM value by attempting to start the oscillator with the additional resistance in-place. Worse, this phenomenon exaggerates the difference between best- and worst-case NRM curves. Technical Data 202 MC68HC912DT128A — Rev 4.0 Oscillator MOTOROLA Oscillator MC68HC912Dx128C Colpitts Oscillator Specification 13.4.2.2 Gain Margin The Gain Margin of the oscillator indicates the amount the gain of the oscillator can vary while maintaining oscillation. Specifically, Gain Margin is: Gain Margin = MIN(gain/minimum required gain, maximum allowed gain/gain) Just like NRM, Gain Margin may be dominated by either too much or too little oscillator gain and an increase in gain may not increase Gain Margin. Gain Margin is theoretically related to NRM since the maximum allowed gain is (approximately) inversely proportional to ESR, and the minimum required gain is (approximately) proportional to ESR, leaving Gain Margin (approximately) inversely proportional to ESR. The preferred method for specifying the oscillator, given a set of load capacitor values, is to determine the maximum allowed while maintaining a worst-case Gain Margin of 2. Since Gain Margin is proportional to ESR, this means the empirically measured NRM at the worst-case point would be approximately twice the maximum allowed ESR. However, since typical NRM is likely to be higher and most measurement techniques do not account for ALC effects, actual NRM measurements are likely to be much higher. 13.4.2.3 Optimizing Component Values The maximum ESR possible (given a worst-case Gain Margin of 2) is not the optimum operating point. In some cases, the frequency accuracy of the oscillator is important and in other cases satisfying the traditional NRM measurement technique is important. If frequency accuracy is important, the total load capacitance (the combination of the load capacitors and their associated parasitics) should be equal (or close to equal) to the rated load capacitance of the resonator. Provided the resultant load capacitors yield a maximum allowed ESR greater than the maximum ESR of the crystal (while maintaining the worst case Gain Margin of 2), this is an acceptable operating point. If the maximum allowed ESR is not high enough, the closest possible components with high enough ESR should be chosen. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Oscillator 203 Oscillator Similarly, if meeting a traditional NRM optimization criteria is important, then the components determined by this method are acceptable if the same components yield a maximum allowed ESR greater than the maximum ESR of the crystal while maintaining the worst case Gain Margin of 2. There is no guarantee that components chosen through traditional NRM optimization techniques will yield acceptable results across all expected variations. 13.4.2.4 Key Parameters The following items are of critical importance to the operation of the oscillator: • EXTAL–XTAL capacitor value — The value of the component plus external (board) parasitic in excess of 0.1pF between EXTAL and XTAL. • XTAL–VSS capacitor value — The value of the component plus external (board) parasitic in excess of 1.0pF between XTAL and VSS. • Maximum Shunt Capacitance — The maximum value of the resonator’s shunt capacitance (C0) plus the external (board) parasitics in excess of 1pF from EXTAL to VSS. • VDDPLL Setting — The Voltage applied to the VDDPLL pin (Logic 1 means VDDPLL is tied to the same potential as VDD). • Resonator Frequency — The frequency of oscillation of the resonator. • Maximum ESR — The maximum effective series resistance (ESR) of the resonator. This figure must include any increases due to ageing, power dissipation, temperature, process variation or particle contamination. Technical Data 204 MC68HC912DT128A — Rev 4.0 Oscillator MOTOROLA Oscillator MC68HC912Dx128C Colpitts Oscillator Specification 13.4.3 Important Information For Calculating Component Values Before attempting to apply the information in section 13.4.2.4 Key Parameters, the following data from the resonator vendor is required: • Resonator Frequency (f) • Maximum ESR (R, ESR, or R1) • Maximum Shunt Capacitance (C0) • Load Capacitance (CL) — this is not the external component values but rather the capacitance applied in parallel with the resonator during the tuning procedure. 13.4.3.1 How to Use This Information The following tables provide Maximum ESR vs. component value for various frequencies. This table should be used in the following manner: 1. Choose the set of component values corresponding to the correct maximum shunt capacitance (equal to the sum of EXTAL–VSS parasitics in excess of 1pF, plus the C0 of the resonator) and VDDPLL setting. 2. Determine the range of components for which the Maximum ESR is greater than the absolute maximum ESR of the resonator (including ageing, power dissipation, temperature, process variation or particle contamination). 3. Within this range, choose the EXTAL–XTAL capacitance closest to (CEXTAL–XTAL = 2*CL – 1pF). 4. If the ideal component is between two valid component values (the maximum ESR is sufficient for both component values), then choose the component with the highest maximum ESR or choose an available component between the two listed values. 5. Choose the size of the XTAL–VSS capacitance equal to the closest available size to (CXTAL–VSS = 0.82*CEXTAL–XTAL). MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Oscillator 205 Oscillator 6. If the frequency of the crystal falls between listed values, determine the appropriate component for the listed frequency values on either side and extrapolate. 7. The maximum allowed capacitor is the highest listed component, and the minimum allowed capacitor is the lowest listed component. ‘NA’ or ‘Not Allowed’ means the listed component is not valid or allowed for the given frequency, Shunt Capacitance, and VDDPLL setting. 13.4.3.2 General Specifications The following limitations apply to every system: • Ceramic resonators with integrated components should not be used, as they are designed for Pierce-configured oscillators. • Series cut resonators should not be used. Use parallel cut instead. • The Load Capacitance should be 12pF or higher, preferably greater than 15pF. Technical Data 206 MC68HC912DT128A — Rev 4.0 Oscillator MOTOROLA Oscillator MC68HC912Dx128C Colpitts Oscillator Specification Table 13-1. MC68HC912Dx128C EXTAL–XTAL Capacitor Values vs. Maximum ESR, Shunt Capacitance, and VDDPLL setting Maximum ESR vs. EXTAL–XTAL capacitor value, 1MHz resonators Shunt Capacitance (pF) (VDDPLL=VDD) 3 1570 2080 2620 2700 1870 1140 630 170 5 1460 1890 2340 2010 1370 830 460 120 7 1350 1730 2100 1550 1050 630 350 90 10 1210 1520 1600 1100 740 440 240 60 100pF 82pF 68pF 56pF 47pF 39pF 33pF 27pF CEXTAL-XTAL (pF) 22pF 18pF Maximum ESR vs. EXTAL–XTAL capacitor value, 2MHz resonators Shunt Capacitance (pF) (VDDPLL=VDD) 3 360 480 620 780 940 1100 1080 730 440 240 5 340 450 570 700 830 950 800 530 320 170 7 320 410 520 630 740 830 620 410 250 130 10 290 370 450 550 620 600 440 290 170 90 100pF 82pF 68pF 56pF 47pF 39pF 33pF 27pF 22pF 18pF CEXTAL-XTAL (pF) Maximum ESR vs. EXTAL–XTAL capacitor value, 4MHz resonators Shunt Capacitance (pF) (VDDPLL=VDD) Shunt Capacitance (pF) (VDDPLL=0) 3 210 255 290 335 370 340 175 80 5 190 225 254 290 310 255 130 60 7 170 200 227 250 270 200 100 45 10 145 170 190 205 205 140 70 25 3 250 300 350 400 440 325 165 75 5 225 265 305 340 345 245 120 55 7 200 235 265 295 270 190 90 40 10 175 200 220 240 195 135 65 20 47pF 39pF 33pF 27pF 22pF 18pF 13pF 10pF CEXTAL-XTAL (pF) MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Oscillator 207 Oscillator Maximum ESR vs. EXTAL–XTAL capacitor value, 8MHz resonators Shunt Capacitance (pF) (VDDPLL=VDD) Shunt Capacitance (pF) (VDDPLL=0) 3 40 50 60 70 80 90 95 90 5 35 45 50 60 70 75 80 70 7 30 40 45 50 60 65 65 10 25 30 35 40 45 50 3 50 60 70 85 95 105 115 104 5 40 50 60 70 80 90 95 75 7 35 45 55 60 70 75 80 60 10 35 40 45 50 55 60 47pF 39pF 33pF 27pF 22pF 18pF 13pF 10pF CEXTAL-XTAL (pF) Maximum ESR vs. EXTAL–XTAL capacitor value, 10MHz resonators Shunt Capacitance (pF) (VDDPLL=0) 3 25 35 40 50 55 65 70 5 25 30 35 40 50 55 60 7 20 25 30 35 40 45 10 15 20 25 30 35 47pF 39pF 33pF 27pF 22pF CEXTAL-XTAL (pF) 18pF 70 13pF 10pF Maximum ESR vs. EXTAL–XTAL capacitor value, 16MHz resonators 3 Shunt Capacitance (pF) (1) (VDDPLL=0) 5 7 10 CEXTAL-XTAL (pF) 47pF 39pF 33pF 27pF 22pF 18pF 13pF 10pF = Not allowed 1. Please refer to point 1 in 13.4.3.1 How to Use This Information for important information regarding shunt capacitance. Technical Data 208 MC68HC912DT128A — Rev 4.0 Oscillator MOTOROLA Oscillator MC68HC912Dx128C Colpitts Oscillator Specification 13.4.4 MC68HC912Dx128C DC Blocking Capacitor Guidelines Due to the placement of the resonator from EXTAL to VSS and the nature of the microcontroller’s inputs, there will be a DC bias voltage of approximately (VDD–2V) across the pins of the resonator. For some resonators, this can have long-term reliability issues. To remedy this situation, a DC-blocking capacitor can be placed in series with the crystal, as shown in Figure 13-3. The value of the DC-blocking capacitor should be between 0.1 and 10nF, with a preferred value of 1nF. This capacitor must be connected as shown in Figure 13-3. If connected thus, all other oscillator specifications and guidelines continue to apply. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Oscillator 209 Oscillator BUF - CFLT 2 OTA + RFLT ALC + BIAS EN RFLT CFLT GM RESD EXTAL XTAL CX-EX 1nF DC-blocking capacitor Resonator CX-VSS CDC Figure 13-3. MC68HC912Dx128C Crystal with DC Blocking Capacitor Technical Data 210 MC68HC912DT128A — Rev 4.0 Oscillator MOTOROLA Oscillator MC68HC912Dx128C Colpitts Oscillator Specification 13.4.5 MC68HC912Dx128C Oscillator Design Guidelines Proper and robust operation of the oscillator circuit requires excellent board layout design practice. Poor layout of the application board can contribute to EMC susceptibility, noise generation, slow starting oscillators, and reaction to noise on the clock input buffer. In addition to published errata for the MC68HC912DT128A, the following guidelines must be followed or failure in operation may occur. • Minimize Capacitance to VSS on EXTAL pin — The Colpitts oscillator architecture is sensitive to capacitance in parallel with the resonator (from EXTAL to VSS). Follow these techniques: i. Remove ground plane from all layers around resonator and EXTAL route ii. Observe a minimum spacing from the EXTAL trace to all other traces of at least three times the design rule minimum (until the microcontroller’s pin pitch prohibits this guideline) iii. Where possible, use XTAL as a shield between EXTAL and VSS iv. Keep EXTAL capacitance to less than 1pF (2pF absolute maximum) NOTE: • Shield all oscillator components from all noisy traces (while observing above guideline). • Keep the VSSPLL pin and the VSS reference to the oscillator as identical as possible. Impedance between these signals must be minimum. • Observe best practice supply bypassing on all MCU power pins. The oscillator’s supply reference is VDD, not VDDPLL. • Account for XTAL–VSS and EXTAL–XTAL parasitics in component values. The specified component values assume a maximum parasitic capacitance of 1pF and 0.1pF, respectively. An increase in the EXTAL–XTAL parasitic as a result of reducing EXTAL–VSS parasitic is acceptable provided component value is reduced by the appropriate value. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Oscillator 211 Oscillator • NOTE: Minimize XTAL and EXTAL routing lengths to reduce EMC issues. EXTAL and XTAL routing resistances are less important than capacitances. Using minimum width traces is an acceptable trade-off to reduce capacitance. 13.5 MC68HC912Dx128P Pierce Oscillator Specification This section applies to the 2L05H mask set, which refers to the newest set of CGM fixes (to the MC68HC912DT128A) with the Pierce oscillator configuration enabled. The name for these devices is MC68HC912Dx128P. 13.5.1 MC68HC912Dx128P Oscillator Design Architecture The Pierce oscillator architecture is shown in Figure 13-4. The component configuration for this oscillator is different to all previous MC68HC912DT128A configurations and the recommended components may be different. Please note carefully the connection of external capacitors and the resonator in this diagram. Technical Data 212 MC68HC912DT128A — Rev 4.0 Oscillator MOTOROLA Oscillator MC68HC912Dx128P Pierce Oscillator Specification BUF - CFLT 2 OTA + RFLT ALC + BIAS RFEEDBACK EN GM RESD EXTAL XTAL Resonator CEX-VSS CX-VSS Figure 13-4. MC68HC912Dx128P Pierce Oscillator Architecture There are the following primary differences between the previous Colpitts (‘A’) and new Pierce (‘P’) oscillator configurations: • Oscillator architecture was changed from Colpitts to Pierce. • Hysteresis was added to the clock input buffer to reduce sensitivity to noise. • The bias current to the amplifier was optimized for less process variation. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Oscillator 213 Oscillator • The input ESD resistor from EXTAL to the gate of the oscillator amplifier was changed to provide a parallel path, reducing parasitic phase shift in the oscillator. 13.5.1.1 Oscillator Architecture Change from Colpitts to Pierce The primary difference from the ‘A’ to the ‘P’ versions of the MC68HC912Dx128 is the architecture, or configuration, of the oscillator. The previous version (‘A’) is connected in Colpitts configuration, where the resonator is connected between the EXTAL pin and VSS. This configuration causes the relatively large parasitics from EXTAL to VSS react in parallel with the resonator, decreasing gain margin in some corners. The Pierce configuration places the much-lower EXTAL to XTAL parasitic capacitances in parallel with the resonator, providing a much larger gain margin across process, temperature and voltage variance. Implementation of the Pierce architecture required the replacement of the previous P-type, non-inverting source-follower amplifier with an Ntype, inverting, traditional amplifier. Additionally, the EXTAL biasing circuit on the Colpitts configurations was replaced with a feedback resistor from XTAL to EXTAL to achieve self-bias. Parametric differences from the ‘A’ to the ‘P’ versions of the oscillator include: • Phase shift from EXTAL to XTAL — The phase shift on the ‘P’ version will be approximately 180 degrees (vs. approximately 0 degrees on the ‘A’ version) due to the requirement of an inverting amplifier in the Pierce configuration). • DC offset of oscillation on EXTAL and XTAL — The DC offset of the EXTAL and XTAL nodes on the ‘P’ version will be approximately 0.7–1.0V (vs. approximately VDD–2V and VDD–1V, respectively, on the ‘A’ version) due to the different bias requirements of the N-type inverting amplifier. • Amplitude of oscillation — The amplitude of oscillation may be slightly lower on the ‘P’ version than the ‘A’ version due to using the same Amplitude Level Control (ALC) circuit for both architectures. The circuit responds slightly differently to the different DC offsets in the two architectures, resulting in slightly Technical Data 214 MC68HC912DT128A — Rev 4.0 Oscillator MOTOROLA Oscillator MC68HC912Dx128P Pierce Oscillator Specification lower amplitude for the Pierce. The amplitude will still be sufficient for robust operation across process, temperature, and voltage variance. 13.5.1.2 Clock Buffer Hysteresis The input clock buffer uses an Operational Transconductance Amplifier (labeled ‘OTA’ in the figure above) followed by a digital buffer to amplify the input signal on the EXTAL pin into a full-swing clock for use by the clock generation section of the microcontroller. There is an internal R-C filter (composed of components RFLT2 and CFLT2 in the figure above), which creates the DC value to which the EXTAL signal is compared. In this manner, the clock input buffer can track changes in the EXTAL DC offset voltage due to process variation as well as external factors such as leakage. Because the purpose of the clock input buffer is to amplify relatively lowswing signals into a full-rail output, the gain of the OTA is very high. In the configuration shown, this means that very small levels of noise can be coupled onto the input of the clock buffer resulting in noise amplification. To remedy this issue, hysteresis was added to the OTA so that the circuit could still provide the tolerance to leakage and the high gain required without the noise sensitivity. Approximately 150mV of hysteresis was added with a maximum hysteresis over process variation of 350mV. As such, the clock input buffer will not respond to input signals until they exceed the hysteresis level. At this point, the input signal due to oscillation will dominate the total input waveform and narrow clock pulses due to noise will be eliminated. This circuit will limit the overall performance of the oscillator block only in cases where the amplitude of oscillation is less than the level of hysteresis. The minimum amplitude of oscillation is expected to be in excess of 750mV and the maximum hysteresis is expected to be less than 350mV, providing a factor of safety in excess of two. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Oscillator 215 Oscillator 13.5.1.3 Bias Current Process Optimization For proper oscillation, the gain margin of the oscillator must exceed one or the circuit will not oscillate. Process variance in the bias current (which controls the gain of the amplifier) can cause the gain margin to be much lower than typical. This can be as a result of either too much or too little current. To reduce the process sensitivity of the gain, the material of the device that sets the bias current was changed to a material with tighter process and temperature control. As a result, the transconductance and Ibias variances are more limited than in the previous design. 13.5.1.4 Input ESD Resistor Path Modification To satisfy the condition of oscillation, the oscillator circuit must not only provide the correct amount of gain but also the correct amount of phase shift. In the Pierce configuration, the phase shift due to parasitics in the input path to the gate of the transconductance amplifier must be as low as possible. In the original configuration, the parasitic capacitance of the clock input buffer (OTA), automatic Loop Control circuit (ALC), and input resistor (RFLT) reacted with the input resistance to cause a large phase shift. To reduce the phase shift, the input ESD resistor (marked RESD in the figure above) was changed from a single path to the input circuitry (the ALC and the OTA) and oscillator transconductance amplifier (marked GM in the figure above) to a parallel path. In this configuration, the only capacitance causing a phase shift on the input to the transconductance device is due to the transconductance device itself. Technical Data 216 MC68HC912DT128A — Rev 4.0 Oscillator MOTOROLA Oscillator MC68HC912Dx128P Pierce Oscillator Specification 13.5.2 MC68HC912Dx128P Oscillator Circuit Specifications 13.5.2.1 Negative Resistance Margin Negative Resistance Margin (NRM) is a figure of merit commonly used to qualify an oscillator circuit with a given resonator. NRM is an indicator of how much additional resistance in series with the resonator is tolerable while still maintaining oscillation. This figure is usually expected to be a multiple of the nominal "maximum" rated ESR of the resonator to allow for variation and degradation of the resonator. Currently, many systems are optimized for NRM by adjusting the load capacitors until NRM is maximized. This method may not achieve the best overall NRM because the optimization method is empirical and not analytical. That is, the method only achieves the best NRM for the particular sample set of microcontrollers, resonators, and board values tested. The figure below shows the anticipated NRM for a nominal 4MHz resonator given the expected process variance of the microcontroller (D60A), board, and crystal (excluding ESR). In this case, the value of load capacitors providing the optimum NRM for a best-case situation yield an unacceptable NRM for a worst-case situation (the slope of the NRM vs. capacitance curve is very steep, indicating severe sensitivity to small variations). If the NRM optimization happened to be performed on a best-case sample set, there could be unexpected sensitivity at worstcase. Negative Resistance Margin vs. Capacitance 100 Negative Resistance Margin 1000 WCS TYP TYP BCS 10 8 10 13 15 18 22 27 33 39 47 56 68 Capacitance MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Oscillator 217 Oscillator NRM measurement techniques can also generate misleading results when applied to Automatic Level Control (ALC) style oscillator circuits such as the D60x/Dx128x. Many NRM methods slowly increase series resistance until oscillation stops. ALC-style oscillators reduce the gain of the oscillator circuit after start-up to reduce current, so if the oscillator tends to have more gain than optimum it will be more tolerant of additional resistance after start-up than it will during the start-up process. This means that NRM figures may be optimistic unless the method verifies the NRM value by attempting to start the oscillator with the additional resistance in-place. Worse, this phenomenon exaggerates the difference between best- and worst-case NRM curves. 13.5.2.2 Gain Margin The Gain Margin of the oscillator indicates the amount the gain of the oscillator can vary while maintaining oscillation. Specifically, Gain Margin is: Gain Margin = MIN(gain/minimum required gain, maximum allowed gain/gain) Just like NRM, Gain Margin may be dominated by either too much or too little oscillator gain and an increase in gain may not increase Gain Margin. Gain Margin is theoretically related to NRM since the maximum allowed gain is (approximately) inversely proportional to ESR, and the minimum required gain is (approximately) proportional to ESR, leaving Gain Margin (approximately) inversely proportional to ESR. The preferred method for specifying the oscillator, given a set of load capacitor values, is to determine the maximum allowed ESR while maintaining a worst-case Gain Margin of 2. Since Gain Margin is proportional to ESR, this means the empirically measured NRM at the worst-case point would be approximately twice the maximum allowed ESR. However, since typical NRM is likely to be higher and most measurement techniques do not account for ALC effects, actual NRM measurements are likely to be much higher. Technical Data 218 MC68HC912DT128A — Rev 4.0 Oscillator MOTOROLA Oscillator MC68HC912Dx128P Pierce Oscillator Specification 13.5.2.3 Optimizing Component Values The maximum ESR possible (given a worst-case Gain Margin of 2) is not the optimum operating point. In some cases, the frequency accuracy of the oscillator is important and in other cases satisfying the traditional NRM measurement technique is important. If frequency accuracy is important, the total load capacitance (the combination of the load capacitors and their associated parasitics) should be equal (or close to equal) to the rated load capacitance of the resonator. Provided the resultant load capacitors yield a maximum allowed ESR greater than the maximum ESR of the crystal (while maintaining the worst case Gain Margin of 2), this is an acceptable operating point. If the maximum allowed ESR is not high enough, the closest possible components with high enough ESR should be chosen. Similarly, if meeting a traditional NRM optimization criteria is important, then the components determined by this method are acceptable if the same components yield a maximum allowed ESR greater than the maximum ESR of the crystal while maintaining the worst case Gain Margin of 2. There is no guarantee that components chosen through traditional NRM optimization techniques will yield acceptable results across all expected variations. 13.5.2.4 Key Parameters The following items are of critical importance to the operation of the oscillator: • EXTAL–VSS capacitor value — The value of the component plus external (board) parasitic in excess of 1.0pF between EXTAL and VSS. • XTAL–VSS capacitor value — The value of the component plus external (board) parasitic in excess of 1.0pF between XTAL and VSS. • Maximum Shunt Capacitance — The maximum value of the resonator’s shunt capacitance (C0) plus the external (board) parasitics in excess of 0.1pF from EXTAL to XTAL. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Oscillator 219 Oscillator • VDDPLL Setting — The Voltage applied to the VDDPLL pin (Logic 1 means VDDPLL is tied to the same potential as VDD). • Resonator Frequency — The frequency of oscillation of the resonator. • Maximum ESR — The maximum effective series resistance (ESR) of the resonator. This figure must include any increases due to ageing, power dissipation, temperature, process variation or particle contamination. 13.5.3 Important Information For Calculating Component Values Before attempting to apply the information in section 13.5.2.4 Key Parameters, the following data from the resonator vendor is required: • Resonator Frequency (f) • Maximum ESR (R, ESR, or R1) • Maximum Shunt Capacitance (C0) • Load Capacitance (CL) — this is not the external component values but rather the capacitance applied in parallel with the resonator during the tuning procedure. 13.5.3.1 How to Use This Information The following tables provide Maximum ESR vs. component value for various frequencies. This table should be used in the following manner: 1. Choose the set of component values corresponding to the correct maximum shunt capacitance (equal to the sum of EXTAL–XTAL parasitics in excess of 0.1pF, plus the C0 of the resonator) and VDDPLL setting. 2. Determine the range of components for which the Maximum ESR is greater than the absolute maximum ESR of the resonator (including ageing, power dissipation, temperature, process Technical Data 220 MC68HC912DT128A — Rev 4.0 Oscillator MOTOROLA Oscillator MC68HC912Dx128P Pierce Oscillator Specification variation or particle contamination). 3. Within this range, choose the EXTAL–VSS capacitance closest to (CEXTAL–VSS = 2*CL – 10pF). 4. If the ideal component is between two valid component values (the maximum ESR is sufficient for both component values), then choose the component with the highest maximum ESR or choose an available component between the two listed values. 5. Choose the size of the XTAL–VSS capacitance equal to EXTAL–VSS capacitance. 6. If the frequency of the crystal falls between listed values, determine the appropriate component for the listed frequency values on either side and extrapolate. 7. The maximum allowed capacitor is the highest listed component, and the minimum allowed capacitor is the lowest listed component. ‘NA’ or ‘Not Allowed’ means the listed component is not valid or allowed for the given frequency, Shunt Capacitance, and VDDPLL setting. 13.5.3.2 General Specifications The following limitations apply to every system: • Ceramic resonators with integrated components must have the integrated components accounted for in the total component value. • Series cut resonators should not be used. Use parallel cut instead. • The Load Capacitance should be 12pF or higher, preferably greater than 15pF. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Oscillator 221 Oscillator Table 13-2. MC68HC912Dx128P EXTAL–VSS, XTAL–VSS Capacitor Values vs. Maximum ESR, Shunt Capacitance, and VDDPLL setting Maximum ESR vs. EXTAL–VSS or XTAL–VSS capacitor value, 1MHz resonators Shunt Capacitance (pF) (VDDPLL=0) 3 4400 5500 6700 8100 8500 6350 3700 2250 5 3800 4650 5400 5350 4000 2900 1650 1000 7 3300 3950 4150 3100 2300 1650 950 550 10 2700 2900 2300 1700 1200 850 500 300 47pF 39pF 33pF 27pF 22pF 18pF 13pF 10pF CEXTAL-VSS (pF) Maximum ESR vs. EXTAL–VSS or XTAL–VSS capacitor value, 2MHz resonators Shunt Capacitance (pF) (VDDPLL=0) 3 1100 1425 1750 2200 2700 3200 3975 3925 5 975 1225 1500 1825 2150 2475 2350 1825 7 850 1050 1275 1525 1750 1925 1375 1050 10 725 875 1025 1175 1325 1050 725 550 47pF 39pF 33pF 27pF 22pF 18pF 13pF 10pF CEXTAL-VSS (pF) Maximum ESR vs. EXTAL–VSS or XTAL–VSS capacitor value, 4MHz resonators Shunt Capacitance (pF) (VDDPLL=VDD) Shunt Capacitance (pF) (VDDPLL=0) 3 270 350 440 560 700 850 1100 1310 5 240 310 380 470 570 680 850 970 7 210 270 320 400 480 550 670 740 10 180 220 260 320 370 420 490 520 3 250 330 410 520 660 800 1040 1230 5 230 290 350 440 540 640 800 910 7 200 250 300 370 450 520 630 700 10 170 210 250 300 350 400 450 500 47pF 39pF 33pF 27pF 22pF 18pF 13pF 10pF CEXTAL-VSS (pF) Technical Data 222 MC68HC912DT128A — Rev 4.0 Oscillator MOTOROLA Oscillator MC68HC912Dx128P Pierce Oscillator Specification Maximum ESR vs. EXTAL–VSS or XTAL–VSS capacitor value, 8MHz resonators Shunt Capacitance (pF) (VDDPLL=VDD) Shunt Capacitance (pF) (VDDPLL=0) 3 60 80 100 130 165 200 270 325 5 55 70 85 110 135 165 210 250 7 50 60 75 95 115 135 170 195 10 40 50 60 75 90 105 125 145 3 60 75 95 125 155 190 255 305 5 50 65 80 105 130 155 200 235 7 45 55 70 90 105 125 160 185 10 40 45 55 70 85 95 120 130 47pF 39pF 33pF 27pF 22pF 18pF 13pF 10pF CEXTAL-VSS (pF) Maximum ESR vs. EXTAL–VSS or XTAL–VSS capacitor value,10MHz resonators Shunt Capacitance (pF) (VDDPLL=0) 3 35 45 60 80 100 120 165 200 5 30 40 50 65 80 100 125 150 7 25 35 45 55 65 80 100 120 10 20 30 35 40 50 60 70 80 47pF 39pF 33pF 27pF 22pF 18pF 13pF 10pF CEXTAL-VSS (pF) Maximum ESR vs. EXTAL–VSS or XTAL–VSS capacitor value,16MHz resonators 10 3 Shunt Capacitance (pF) (1) (VDDPLL=0) 5 15 20 30 35 50 60 10 15 20 25 30 45 10 15 20 30 35 7 10 CEXTAL-VSS (pF) 20 47pF 39pF 33pF 27pF 22pF 18pF 13pF 10pF 1. Please refer to point 1 in 13.5.3.1 How to Use This Information for important information regarding shunt capacitance. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Oscillator 223 Oscillator 13.5.4 MC68HC912Dx128P Guidelines Proper and robust operation of the oscillator circuit requires excellent board layout design practice. Poor layout of the application board can contribute to EMC susceptibility, noise generation, slow starting oscillators, and reaction to noise on the clock input buffer. In addition to published errata for the MC68HC912DT128A, the following guidelines must be followed or failure in operation may occur. NOTE: • Minimize Capacitance between EXTAL and XTAL traces — The Pierce oscillator architecture is sensitive to capacitance in parallel with the resonator (from EXTAL to XTAL). To reduce this capacitance, run a shield trace (connected to VSS) between EXTAL and XTAL as far as possible. • Shield all oscillator components from all noisy traces. If the VSS used for shielding is not identical to the oscillator reference, it must be considered a noisy signal. • Keep the VSSPLL pin and the VSS reference to the oscillator as identical as possible. Impedance between these signals must be minimum. • Observe best practice supply bypassing on all MCU power pins. The oscillator’s supply reference is VDD, not VDDPLL. • Account for XTAL–VSS and EXTAL–VSS parasitics in component values. The specified component values assume a maximum parasitic capacitance of 1pF for these pins. An increase in the EXTAL–VSS or XTAL–VSS parasitic as a result of reducing EXTAL–XTAL parasitic is acceptable provided the component values are reduced by the appropriate value. • NOTE: Minimize XTAL and EXTAL routing lengths to reduce EMC issues. EXTAL and XTAL routing resistances are less important than capacitances. Using minimum width traces is an acceptable trade-off to reduce capacitance. Technical Data 224 MC68HC912DT128A — Rev 4.0 Oscillator MOTOROLA Technical Data — MC68HC912DT128A Section 14. Pulse Width Modulator 14.1 Contents 14.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 225 14.3 PWM Register Descriptions . . . . . . . . . . . . . . . . . . . . . . . . . .229 14.4 PWM Boundary Cases . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .240 14.2 Introduction The pulse-width modulator (PWM) subsystem provides four independent 8-bit PWM waveforms or two 16-bit PWM waveforms or a combination of one 16-bit and two 8-bit PWM waveforms. Each waveform channel has a programmable period and a programmable duty-cycle as well as a dedicated counter. A flexible clock select scheme allows four different clock sources to be used with the counters. Each of the modulators can create independent, continuous waveforms with software-selectable duty rates from 0 percent to 100 percent. The PWM outputs can be programmed as left-aligned outputs or center-aligned outputs. The period and duty registers are double buffered so that if they change while the channel is enabled, the change will not take effect until the counter rolls over or the channel is disabled. If the channel is not enabled, then writes to the period and/or duty register will go directly to the latches as well as the buffer, thus ensuring that the PWM output will always be either the old waveform or the new waveform, not some variation in between. A change in duty or period can be forced into immediate effect by writing the new value to the duty and/or period registers and then writing to the counter. This causes the counter to reset and the new duty and/or period values to be latched. In addition, since the counter is readable it is MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Pulse Width Modulator 225 Pulse Width Modulator possible to know where the count is with respect to the duty value and software can be used to make adjustments by turning the enable bit off and on. The four PWM channel outputs share general-purpose port P pins. Enabling PWM pins takes precedence over the general-purpose port. When PWM are not in use, the port pins may be used for discrete input/output. CLOCK SOURCE (ECLK or Scaled ECLK) CENTR = 0 FROM PORT P DATA REGISTER UP/DOWN PWCNTx GATE (CLOCK EDGE SYNC) RESET 8-BIT COMPARE = PWDTYx S Q MUX MUX Q 8-BIT COMPARE = PWPERx PWENx TO PIN DRIVER R PPOLx SYNC PPOL = 0 PPOL = 1 PWDTY PWPER Figure 14-1. Block Diagram of PWM Left-Aligned Output Channel Technical Data 226 MC68HC912DT128A — Rev 4.0 Pulse Width Modulator MOTOROLA Pulse Width Modulator Introduction CLOCK SOURCE (ECLK or Scaled ECLK) CENTR = 1 FROM PORT P DATA REGISTER RESET PWCNTx GATE (CLOCK EDGE SYNC) UP/DOWN (DUTY CYCLE) 8-BIT COMPARE = PWDTYx T Q (PERIOD) MUX MUX Q TO PIN DRIVER 8-BIT COMPARE = PWPERx PPOLx PWENx SYNC PPOL = 1 PPOL = 0 PWDTY (PWPER − PWDTY) × 2 PWPER × 2 PWDTY Figure 14-2. Block Diagram of PWM Center-Aligned Output Channel MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Pulse Width Modulator 227 Pulse Width Modulator PSBCK PSBCK IS BIT 0 OF PWCTL REGISTER. INTERNAL SIGNAL LIMBDM IS ONE IF THE MCU IS IN BACKGROUND DEBUG MODE. LIMBDM CLOCK A MUX ECLK 0:0:0 8-BIT DOWN COUNTER 0:1:0 ÷2 ÷2 0:0:1 PWSCNT0 0:1:0 8-BIT SCALE REGISTER 0:1:1 ÷2 0:1:1 1:0:0 ÷2 1:0:0 PCLK0 MUX 0:0:1 =0 CLOCK S0* 0:0:0 PCLK1 1:0:1 1:1:0 ÷2 1:1:0 1:1:1 ÷2 1:1:1 MUX ÷2 8-BIT DOWN COUNTER BITS: PCKA2, PCKA1, PCKA0 CLOCK S1** 8-BIT SCALE REGISTER PWSCAL1 PCLK2 MUX REGISTER: PWPRES CLOCK TO PWM CHANNEL 2 =0 PWSCNT1 BITS: PCKB2, PCKB1, PCKB0 CLOCK TO PWM CHANNEL 1 ÷2 PWSCAL0 CLOCK B 1:0:1 CLOCK TO PWM CHANNEL 0 CLOCK TO PWM CHANNEL 3 ÷2 *CLOCK S0 = (CLOCK A)/2, (CLOCK A)/4, (CLOCK A)/6,... (CLOCK A)/512 **CLOCK S1 = (CLOCK B)/2, (CLOCK B)/4, (CLOCK B)/6,... (CLOCK B)/512 PCLK3 Figure 14-3. PWM Clock Sources Technical Data 228 MC68HC912DT128A — Rev 4.0 Pulse Width Modulator MOTOROLA Pulse Width Modulator PWM Register Descriptions 14.3 PWM Register Descriptions PWCLK — PWM Clocks and Concatenate RESET: $0040 Bit 7 6 5 4 3 2 1 Bit 0 CON23 CON01 PCKA2 PCKA1 PCKA0 PCKB2 PCKB1 PCKB0 0 0 0 0 0 0 0 0 Read and write anytime. CON23 — Concatenate PWM Channels 2 and 3 When concatenated, channel 2 becomes the high-order byte and channel 3 becomes the low-order byte. Channel 2 output pin is used as the output for this 16-bit PWM (bit 2 of port P). Channel 3 clockselect control bits determines the clock source. Channel 3 output pin becomes a general purpose I/O. 0 = Channels 2 and 3 are separate 8-bit PWMs. 1 = Channels 2 and 3 are concatenated to create one 16-bit PWM channel. CON01 — Concatenate PWM Channels 0 and 1 When concatenated, channel 0 becomes the high-order byte and channel 1 becomes the low-order byte. Channel 0 output pin is used as the output for this 16-bit PWM (bit 0 of port P). Channel 1 clockselect control bits determine the clock source. Channel 1 output pin becomes a general purpose I/O. 0 = Channels 0 and 1 are separate 8-bit PWMs. 1 = Channels 0 and 1 are concatenated to create one 16-bit PWM channel. PCKA2 – PCKA0 — Prescaler for Clock A Clock A is one of two clock sources which may be used for channels 0 and 1. These three bits determine the rate of clock A, as shown in Table 14-1. PCKB2 – PCKB0 — Prescaler for Clock B Clock B is one of two clock sources which may be used for channels 2 and 3. These three bits determine the rate of clock B, as shown in Table 14-1. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Pulse Width Modulator 229 Pulse Width Modulator Table 14-1. Clock A and Clock B Prescaler PCKA2 (PCKB2) 0 0 0 0 1 1 1 1 PCKA1 (PCKB1) 0 0 1 1 0 0 1 1 PCKA0 (PCKB0) 0 1 0 1 0 1 0 1 Value of Clock A (B) P P÷2 P÷4 P÷8 P ÷ 16 P ÷ 32 P ÷ 64 P ÷ 128 PWPOL — PWM Clock Select and Polarity $0041 Bit 7 6 5 4 3 2 1 Bit 0 PCLK3 PCLK2 PCLK1 PCLK0 PPOL3 PPOL2 PPOL1 PPOL0 0 0 0 0 0 0 0 0 RESET: Read and write anytime. PCLK3 — PWM Channel 3 Clock Select 0 = Clock B is the clock source for channel 3. 1 = Clock S1 is the clock source for channel 3. PCLK2 — PWM Channel 2 Clock Select 0 = Clock B is the clock source for channel 2. 1 = Clock S1 is the clock source for channel 2. PCLK1 — PWM Channel 1 Clock Select 0 = Clock A is the clock source for channel 1. 1 = Clock S0 is the clock source for channel 1. PCLK0 — PWM Channel 0 Clock Select 0 = Clock A is the clock source for channel 0. 1 = Clock S0 is the clock source for channel 0. If a clock select is changed while a PWM signal is being generated, a truncated or stretched pulse may occur during the transition. The following four bits apply in left-aligned mode only: Technical Data 230 MC68HC912DT128A — Rev 4.0 Pulse Width Modulator MOTOROLA Pulse Width Modulator PWM Register Descriptions PPOL3 — PWM Channel 3 Polarity 0 = Channel 3 output is low at the beginning of the period; high when the duty count is reached. 1 = Channel 3 output is high at the beginning of the period; low when the duty count is reached. PPOL2 — PWM Channel 2 Polarity 0 = Channel 2 output is low at the beginning of the period; high when the duty count is reached. 1 = Channel 2 output is high at the beginning of the period; low when the duty count is reached. PPOL1 — PWM Channel 1 Polarity 0 = Channel 1 output is low at the beginning of the period; high when the duty count is reached. 1 = Channel 1 output is high at the beginning of the period; low when the duty count is reached. PPOL0 — PWM Channel 0 Polarity 0 = Channel 0 output is low at the beginning of the period; high when the duty count is reached. 1 = Channel 0 output is high at the beginning of the period; low when the duty count is reached. Depending on the polarity bit, the duty registers may contain the count of either the high time or the low time. If the polarity bit is zero and left alignment is selected, the duty registers contain a count of the low time. If the polarity bit is one, the duty registers contain a count of the high time. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Pulse Width Modulator 231 Pulse Width Modulator PWEN — PWM Enable $0042 Bit 7 6 5 4 3 2 1 Bit 0 0 0 0 0 PWEN3 PWEN2 PWEN1 PWEN0 0 0 0 0 0 0 0 0 RESET: Setting any of the PWENx bits causes the associated port P line to become an output regardless of the state of the associated data direction register (DDRP) bit. This does not change the state of the data direction bit. When PWENx returns to zero, the data direction bit controls I/O direction. On the front end of the PWM channel, the scaler clock is enabled to the PWM circuit by the PWENx enable bit being high. When all four PWM channels are disabled, the prescaler counter shuts off to save power. There is an edge-synchronizing gate circuit to guarantee that the clock will only be enabled or disabled at an edge. Read and write anytime. PWEN3 — PWM Channel 3 Enable The pulse modulated signal will be available at port P, bit 3 when its clock source begins its next cycle. 0 = Channel 3 is disabled. 1 = Channel 3 is enabled. PWEN2 — PWM Channel 2 Enable The pulse modulated signal will be available at port P, bit 2 when its clock source begins its next cycle. 0 = Channel 2 is disabled. 1 = Channel 2 is enabled. PWEN1 — PWM Channel 1 Enable The pulse modulated signal will be available at port P, bit 1 when its clock source begins its next cycle. 0 = Channel 1 is disabled. 1 = Channel 1 is enabled. PWEN0 — PWM Channel 0 Enable The pulse modulated signal will be available at port P, bit 0 when its clock source begins its next cycle. 0 = Channel 0 is disabled. 1 = Channel 0 is enabled. Technical Data 232 MC68HC912DT128A — Rev 4.0 Pulse Width Modulator MOTOROLA Pulse Width Modulator PWM Register Descriptions PWPRES — PWM Prescale Counter RESET: $0043 Bit 7 6 5 4 3 2 1 Bit 0 0 Bit 6 5 4 3 2 1 Bit 0 0 0 0 0 0 0 0 0 PWPRES is a free-running 7-bit counter. Read anytime. Write only in special mode (SMOD = 1). PWSCAL0 — PWM Scale Register 0 RESET: $0044 Bit 7 6 5 4 3 2 1 Bit 0 Bit 7 6 5 4 3 2 1 Bit 0 0 0 0 0 0 0 0 0 Read and write anytime. A write will cause the scaler counter PWSCNT0 to load the PWSCAL0 value unless in special mode with DISCAL = 1 in the PWTST register. PWM channels 0 and 1 can select clock S0 (scaled) as its input clock by setting the control bit PCLK0 and PCLK1 respectively. Clock S0 is generated by dividing clock A by the value in the PWSCAL0 register + 1 and dividing again by two. When PWSCAL0 = $FF, clock A is divided by 256 then divided by two to generate clock S0. PWSCNT0 — PWM Scale Counter 0 Value RESET: $0045 Bit 7 6 5 4 3 2 1 Bit 0 Bit 7 6 5 4 3 2 1 Bit 0 0 0 0 0 0 0 0 0 PWSCNT0 is a down-counter that, upon reaching $00, loads the value of PWSCAL0. Read any time. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Pulse Width Modulator 233 Pulse Width Modulator PWSCAL1 — PWM Scale Register 1 $0046 Bit 7 6 5 4 3 2 1 Bit 0 Bit 7 6 5 4 3 2 1 Bit 0 0 0 0 0 0 0 0 0 RESET: Read and write anytime. A write will cause the scaler counter PWSCNT1 to load the PWSCAL1 value unless in special mode with DISCAL = 1 in the PWTST register. PWM channels 2 and 3 can select clock S1 (scaled) as its input clock by setting the control bit PCLK2 and PCLK3 respectively. Clock S1 is generated by dividing clock B by the value in the PWSCAL1 register + 1 and dividing again by two. When PWSCAL1 = $FF, clock B is divided by 256 then divided by two to generate clock S1. PWSCNT1 — PWM Scale Counter 1 Value $0047 Bit 7 6 5 4 3 2 1 Bit 0 Bit 7 6 5 4 3 2 1 Bit 0 0 0 0 0 0 0 0 0 RESET: PWSCNT1 is a down-counter that, upon reaching $00, loads the value of PWSCAL1. Read any time. PWCNTx — PWM Channel Counters Bit 7 6 5 4 3 2 1 Bit 0 PWCNT0 Bit 7 6 5 4 3 2 1 Bit 0 $0048 PWCNT1 Bit 7 6 5 4 3 2 1 Bit 0 $0049 PWCNT2 Bit 7 6 5 4 3 2 1 Bit 0 $004A PWCNT3 Bit 7 6 5 4 3 2 1 Bit 0 $004B RESET: 0 0 0 0 0 0 0 0 Read and write anytime. A write will cause the PWM counter to reset to $00. In special mode, if DISCR = 1, a write does not reset the PWM counter. Technical Data 234 MC68HC912DT128A — Rev 4.0 Pulse Width Modulator MOTOROLA Pulse Width Modulator PWM Register Descriptions The PWM counters are not reset when PWM channels are disabled. The counters must be reset prior to a new enable. Each counter may be read any time without affecting the count or the operation of the corresponding PWM channel. Writes to a counter cause the counter to be reset to $00 and force an immediate load of both duty and period registers with new values. To avoid a truncated PWM period, write to a counter while the counter is disabled. In left-aligned output mode, resetting the counter and starting the waveform output is controlled by a match between the period register and the value in the counter. In center-aligned output mode the counters operate as up/down counters, where a match in period changes the counter direction. The duty register changes the state of the output during the period to determine the duty. When a channel is enabled, the associated PWM counter starts at the count in the PWCNTx register using the clock selected for that channel. In special mode, when DISCP = 1 and configured for left-aligned output, a match of period does not reset the associated PWM counter. PWPERx — PWM Channel Period Registers Bit 7 6 5 4 3 2 1 Bit 0 PWPER0 Bit 7 6 5 4 3 2 1 Bit 0 $004C PWPER1 Bit 7 6 5 4 3 2 1 Bit 0 $004D PWPER2 Bit 7 6 5 4 3 2 1 Bit 0 $004E PWPER3 Bit 7 6 5 4 3 2 1 Bit 0 $004F RESET: 1 1 1 1 1 1 1 1 Read and write anytime. The value in the period register determines the period of the associated PWM channel. If written while the channel is enabled, the new value will not take effect until the existing period terminates, forcing the counter to reset. The new period is then latched and is used until a new period value is written. Reading this register returns the most recent value written. To start a new period immediately, write the new period value MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Pulse Width Modulator 235 Pulse Width Modulator and then write the counter forcing a new period to start with the new period value. Period = Channel-Clock-Period × (PWPER + 1) Period = Channel-Clock-Period × (2 × PWPER) (CENTR = 0) (CENTR = 1) PWDTYx — PWM Channel Duty Registers Bit 7 6 5 4 3 2 1 Bit 0 PWDTY0 Bit 7 6 5 4 3 2 1 Bit 0 $0050 PWDTY1 Bit 7 6 5 4 3 2 1 Bit 0 $0051 PWDTY2 Bit 7 6 5 4 3 2 1 Bit 0 $0052 PWDTY3 Bit 7 6 5 4 3 2 1 Bit 0 $0053 RESET: 1 1 1 1 1 1 1 1 Read and write anytime. The value in each duty register determines the duty of the associated PWM channel. When the duty value is equal to the counter value, the output changes state. If the register is written while the channel is enabled, the new value is held in a buffer until the counter rolls over or the channel is disabled. Reading this register returns the most recent value written. If the duty register is greater than or equal to the value in the period register, there will be no duty change in state. If the duty register is set to $FF the output will always be in the state which would normally be the state opposite the PPOLx value. Left-Aligned-Output Mode (CENTR = 0): Duty cycle = [(PWDTYx+1)/(PWPERx+1)] × 100% Duty cycle = [(PWPERx−PWDTYx)/(PWPERx+1)] × 100% (PPOLx = 1) (PPOLx = 0) Center-Aligned-Output Mode (CENTR = 1): Duty cycle = [(PWPERx−PWDTYx)/PWPERx] × 100% Duty cycle = [PWDTYx/PWPERx] × 100% (PPOLx = 0) (PPOLx = 1) Technical Data 236 MC68HC912DT128A — Rev 4.0 Pulse Width Modulator MOTOROLA Pulse Width Modulator PWM Register Descriptions PWCTL — PWM Control Register RESET: $0054 Bit 7 6 5 4 3 2 1 Bit 0 0 0 0 PSWAI CENTR RDPP PUPP PSBCK 0 0 0 0 0 0 0 0 Read and write anytime. PSWAI — PWM Halts while in Wait Mode 0 = Allows PWM main clock generator to continue while in wait mode. 1 = Halt PWM main clock generator when the part is in wait mode. CENTR — Center-Aligned Output Mode To avoid irregularities in the PWM output mode, write the CENTR bit only when PWM channels are disabled. 0 = PWM channels operate in left-aligned output mode 1 = PWM channels operate in center-aligned output mode RDPP — Reduced Drive of Port P 0 = All port P output pins have normal drive capability. 1 = All port P output pins have reduced drive capability. PUPP — Pull-Up Port P Enable 0 = All port P pins have an active pull-up device disabled. 1 = All port P pins have an active pull-up device enabled. PSBCK — PWM Stops while in Background Mode 0 = Allows PWM to continue while in background mode. 1 = Disable PWM input clock when the part is in background mode. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Pulse Width Modulator 237 Pulse Width Modulator PWTST — PWM Special Mode Register (“Test”) $0055 Bit 7 6 5 4 3 2 1 Bit 0 DISCR DISCP DISCAL 0 0 0 0 0 0 0 0 0 0 0 0 0 RESET: Read anytime but write only in special mode (SMODN = 0). These bits are available only in special mode and are reset in normal mode. DISCR — Disable Reset of Channel Counter on Write to Channel Counter 0 = Normal operation. Write to PWM channel counter will reset channel counter. 1 = Write to PWM channel counter does not reset channel counter. DISCP — Disable Compare Count Period 0 = Normal operation 1 = In left-aligned output mode, match of period does not reset the associated PWM counter register. DISCAL — Disable Load of Scale-Counters on Write to the Associated Scale-Registers 0 = Normal operation 1 = Write to PWSCAL0 and PWSCAL1 does not load scale counters Technical Data 238 MC68HC912DT128A — Rev 4.0 Pulse Width Modulator MOTOROLA Pulse Width Modulator PWM Register Descriptions PORTP — Port P Data Register $0056 Bit 7 6 5 4 3 2 1 Bit 0 PP7 PP6 PP5 PP4 PP3 PP2 PP1 PP0 PWM – – – – PWM3 PWM2 PWM1 PWM0 RESET: – – – – – – – – PORTP can be read anytime. PWM functions share port P pins 3 to 0 and take precedence over the general-purpose port when enabled. When configured as input, a read will return the pin level. For port bits 7 to 4 it will read zero because there are no available external pins. When configured as output, a read will return the latched output data. For port bits 7 to 4 it will read the last value written. A write will drive associated pins only if configured for output and the corresponding PWM channel is not enabled. After reset, all pins are general-purpose, high-impedance inputs. DDRP — Port P Data Direction Register RESET: $0057 Bit 7 6 5 4 3 2 1 Bit 0 DDP7 DDP6 DDP5 DDP4 DDP3 DDP2 DDP1 DDP0 0 0 0 0 0 0 0 0 DDRP determines pin direction of port P when used for general-purpose I/O. DDRP[7:4] — This bits served as memory locations since there are no corresponding port pins. DDRP[3:0] — Data Direction Port P pin 0-3 0 = I/O pin configured as high impedance input 1 = I/O pin configured for output. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Pulse Width Modulator 239 Pulse Width Modulator 14.4 PWM Boundary Cases The boundary conditions for the PWM channel duty registers and the PWM channel period registers cause these results: Table 14-2. PWM Left-Aligned Boundary Conditions PWDTYx $FF $FF ≥PWPERx ≥PWPERx – – PWPERx >$00 >$00 – – $00 $00 PPOLx 1 0 1 0 1 0 Output Low High High Low High Low Table 14-3. PWM Center-Aligned Boundary Conditions PWDTYx $00 $00 ≥PWPERx ≥PWPERx – – PWPERx >$00 >$00 – – $00 $00 Technical Data 240 PPOLx 1 0 1 0 1 0 Output Low High High Low High Low MC68HC912DT128A — Rev 4.0 Pulse Width Modulator MOTOROLA Technical Data — MC68HC912DT128A Section 15. Enhanced Capture Timer 15.1 Contents 15.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 241 15.3 Enhanced Capture Timer Modes of Operation . . . . . . . . . . . . 247 15.4 Timer Register Descriptions . . . . . . . . . . . . . . . . . . . . . . . . . . 251 15.5 Timer and Modulus Counter Operation in Different Modes . . 275 15.2 Introduction The HC12 Enhanced Capture Timer module has the features of the HC12 Standard Timer module enhanced by additional features in order to enlarge the field of applications, in particular for automotive ABS applications. The additional features permit the operation of this timer module in a mode similar to the Input Control Timer implemented on MC68HC11NB4. These additional features are: • 16-Bit Buffer Register for four Input Capture (IC) channels. • Four 8-Bit Pulse Accumulators with 8-bit buffer registers associated with the four buffered IC channels. Configurable also as two 16-Bit Pulse Accumulators. • 16-Bit Modulus Down-Counter with 4-bit Prescaler. • Four user selectable Delay Counters for input noise immunity increase. • Main Timer Prescaler extended to 7-bit. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Enhanced Capture Timer 241 Enhanced Capture Timer This design specification describes the standard timer as well as the additional features. The basic timer consists of a 16-bit, software-programmable counter driven by a prescaler. This timer can be used for many purposes, including input waveform measurements while simultaneously generating an output waveform. Pulse widths can vary from microseconds to many seconds. A full access for the counter registers or the input capture/output compare registers should take place in one clock cycle. Accessing high byte and low byte separately for all of these registers may not yield the same result as accessing them in one word. Technical Data 242 MC68HC912DT128A — Rev 4.0 Enhanced Capture Timer MOTOROLA Enhanced Capture Timer Introduction ÷ 1, 2, ..., 128 M clock 16-bit Free-running 16 BIT MAIN mainTIMER timer Prescaler ÷ 1, 4, 8, 16 M clock Prescaler 16-bit load register 16-bit modulus down counter RESET 0 PT0 Pin logic Delay counter EDG0 TC0 capture/compare register TC0H hold register Underflow Comparator PAC0 PA0H hold register RESET 0 Comparator PT1 Pin logic Delay counter EDG1 TC1 capture/compare register TC1H hold register PAC1 PA1H hold register RESET 0 Comparator PT2 Pin logic Delay counter EDG2 TC2 capture/compare register TC2H hold register PAC2 PA2H hold register RESET 0 Comparator Pin logic Delay counter EDG3 TC3 capture/compare register TC3H hold register PAC3 PA3H hold register LATCH PT3 Comparator PT4 Pin logic EDG4 EDG0 TC4 capture/compare register MUX ICLAT, LATQ, BUFEN (force latch) Comparator PT5 Pin logic EDG5 EDG1 TC5 capture/compare register MUX Comparator PT6 Pin logic EDG6 EDG2 Write $0000 to modulus counter LATQ (MDC latch enable) TC6 capture/compare register MUX Comparator PT7 Pin logic EDG7 EDG3 TC7 capture/compare register MUX Figure 15-1. Timer Block Diagram in Latch Mode MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Enhanced Capture Timer 243 Enhanced Capture Timer ÷1, 2, ..., 128 M clock 16-bit Free-running 16 BIT MAIN mainTIMER timer Prescaler 16-bit load register ÷ 1, 4, 8, 16 M clock Prescaler 16-bit modulus down counter 0 RESET Comparator Pin logic Delay counter EDG0 TC0 capture/compare register TC0H hold register PAC0 LATCH0 PT0 PA0H hold register 0 RESET Comparator Pin logic Delay counter EDG1 TC1 capture/compare register TC1H hold register PAC1 LATCH1 PT1 PA1H hold register 0 RESET Comparator Pin logic Delay counter EDG2 TC2 capture/compare register TC2H hold register PAC2 PA2H hold register 0 RESET LATCH2 PT2 Comparator Pin logic Delay counter EDG3 TC3 capture/compare register TC3H hold register PAC3 PA3H hold register LATCH3 PT3 Comparator PT4 Pin logic EDG4 EDG0 TC4 capture/compare register MUX Comparator PT5 Pin logic EDG5 EDG1 LATQ, BUFEN (queue mode) Read TC3H hold register TC5 capture/compare register MUX Read TC2H hold register Comparator PT6 Pin logic EDG6 EDG2 TC6 capture/compare register MUX Read TC1H hold register Comparator PT7 Pin logic EDG7 EDG3 TC7 capture/compare register Read TC0H hold register MUX Figure 15-2. Timer Block Diagram in Queue Mode Technical Data 244 MC68HC912DT128A — Rev 4.0 Enhanced Capture Timer MOTOROLA Enhanced Capture Timer Introduction Load holding register and reset pulse accumulator 0 EDG0 PT0 Edge detector 8-bit PAC0 (PACN0) Delay counter PA0H holding register Interrupt 0 EDG1 Edge detector 8-bit PAC1 (PACN1) Delay counter Host CPU data bus PT1 PA1H holding register 0 EDG2 PT2 Edge detector 8-bit PAC2 (PACN2) Delay counter PA2H holding register Interrupt 0 EDG3 PT3 Edge detector 8-bit PAC3 (PACN3) Delay counter PA3H holding register Figure 15-3. 8-Bit Pulse Accumulators Block Diagram MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Enhanced Capture Timer 245 Enhanced Capture Timer To TCNT Counter CLK1 CLK0 Clock select (PAMOD) Edge detector PT7 PACLK PACLK / 256 PACLK / 65536 Prescaled MCLK (TMSK2 bits PR2-PR0) 4:1 MUX Interrupt 8-bit PAC3 (PACN3) 8-bit PAC2 (PACN2) MUX PACA M clock Intermodule Bus Divide by 64 Interrupt 8-bit PAC1 (PACN1) 8-bit PAC0 (PACN0) Delay counter PACB Edge detector PT0 Figure 15-4. 16-Bit Pulse Accumulators Block Diagram Technical Data 246 MC68HC912DT128A — Rev 4.0 Enhanced Capture Timer MOTOROLA Enhanced Capture Timer Enhanced Capture Timer Modes of Operation Pulse accumulator A PAD OC7 (OM7=1 or OL7=1) or (OC7M7 = 1) Figure 15-5. Block Diagram for Port7 with Output compare / Pulse Accumulator A 16-bit Main Timer PTn Delay counter Edge detector Set CnF Interrupt TCn Input Capture Reg. TCnH I.C. Holding Reg. BUFEN • LATQ • TFMOD Figure 15-6. C3F-C0F Interrupt Flag Setting 15.3 Enhanced Capture Timer Modes of Operation The Enhanced Capture Timer has 8 Input Capture, Output Compare (IC/OC) channels same as on the HC12 standard timer (timer channels TC0 to TC7). When channels are selected as input capture by selecting the IOSx bit in TIOS register, they are called Input Capture (IC) channels. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Enhanced Capture Timer 247 Enhanced Capture Timer Four IC channels are the same as on the standard timer with one capture register which memorizes the timer value captured by an action on the associated input pin. Four other IC channels, in addition to the capture register, have also one buffer called holding register. This permits to memorize two different timer values without generation of any interrupt. Four 8-bit pulse accumulators are associated with the four buffered IC channels. Each pulse accumulator has a holding register to memorize their value by an action on its external input. Each pair of pulse accumulators can be used as a 16-bit pulse accumulator. The 16-bit modulus down-counter can control the transfer of the IC registers contents and the pulse accumulators to the respective holding registers for a given period, every time the count reaches zero. The modulus down-counter can also be used as a stand-alone time base with periodic interrupt capability. 15.3.1 IC Channels The IC channels are composed of four standard IC registers and four buffered IC channels. An IC register is empty when it has been read or latched into the holding register. A holding register is empty when it has been read. 15.3.1.1 Non-Buffered IC Channels The main timer value is memorized in the IC register by a valid input pin transition. If the corresponding NOVWx bit of the ICOVW register is cleared, with a new occurrence of a capture, the contents of IC register are overwritten by the new value. If the corresponding NOVWx bit of the ICOVW register is set, the capture register cannot be written unless it is empty. This will prevent the captured value to be overwritten until it is read. Technical Data 248 MC68HC912DT128A — Rev 4.0 Enhanced Capture Timer MOTOROLA Enhanced Capture Timer Enhanced Capture Timer Modes of Operation 15.3.1.2 Buffered IC Channels There are two modes of operations for the buffered IC channels. • IC Latch Mode: When enabled (LATQ=1), the main timer value is memorized in the IC register by a valid input pin transition. The value of the buffered IC register is latched to its holding register by the Modulus counter for a given period when the count reaches zero, by a write $0000 to the modulus counter or by a write to ICLAT in the MCCTL register. If the corresponding NOVWx bit of the ICOVW register is cleared, with a new occurrence of a capture, the contents of IC register are overwritten by the new value. In case of latching, the contents of its holding register are overwritten. If the corresponding NOVWx bit of the ICOVW register is set, the capture register or its holding register cannot be written by an event unless they are empty (see IC Channels). This will prevent the captured value to be overwritten until it is read or latched in the holding register. • IC queue mode: When enabled (LATQ=0), the main timer value is memorized in the IC register by a valid input pin transition. If the corresponding NOVWx bit of the ICOVW register is cleared, with a new occurrence of a capture, the value of the IC register will be transferred to its holding register and the IC register memorizes the new timer value. If the corresponding NOVWx bit of the ICOVW register is set, the capture register or its holding register cannot be written by an event unless they are empty (see IC Channels). In queue mode, reads of holding register will latch the corresponding pulse accumulator value to its holding register. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Enhanced Capture Timer 249 Enhanced Capture Timer 15.3.2 Pulse Accumulators There are four 8-bit pulse accumulators with four 8-bit holding registers associated with the four IC buffered channels. A pulse accumulator counts the number of active edges at the input of its channel. The user can prevent 8-bit pulse accumulators counting further than $FF by PACMX control bit in ICSYS ($AB). In this case a value of $FF means that 255 counts or more have occurred. Each pair of pulse accumulators can be used as a 16-bit pulse accumulator. There are two modes of operation for the pulse accumulators. 15.3.2.1 Pulse Accumulator latch mode The value of the pulse accumulator is transferred to its holding register when the modulus down-counter reaches zero, a write $0000 to the modulus counter or when the force latch control bit ICLAT is written. At the same time the pulse accumulator is cleared. 15.3.2.2 Pulse Accumulator queue mode When queue mode is enabled, reads of an input capture holding register will transfer the contents of the associated pulse accumulator to its holding register. At the same time the pulse accumulator is cleared. 15.3.3 Modulus Down-Counter The modulus down-counter can be used as a time base to generate a periodic interrupt. It can also be used to latch the values of the IC registers and the pulse accumulators to their holding registers. The action of latching can be programmed to be periodic or only once. Technical Data 250 MC68HC912DT128A — Rev 4.0 Enhanced Capture Timer MOTOROLA Enhanced Capture Timer Timer Register Descriptions 15.4 Timer Register Descriptions Input/output pins default to general-purpose I/O lines until an internal function which uses that pin is specifically enabled. The timer overrides the state of the DDR to force the I/O state of each associated port line when an output compare using a port line is enabled. In these cases the data direction bits will have no affect on these lines. When a pin is assigned to output an on-chip peripheral function, writing to this PORTT bit does not affect the pin but the data is stored in an internal latch such that if the pin becomes available for general-purpose output the driven level will be the last value written to the PORTT bit. TIOS — Timer Input Capture/Output Compare Select RESET: $0080 Bit 7 6 5 4 3 2 1 Bit 0 IOS7 IOS6 IOS5 IOS4 IOS3 IOS2 IOS1 IOS0 0 0 0 0 0 0 0 0 Read or write anytime. IOS[7:0] — Input Capture or Output Compare Channel Configuration 0 = The corresponding channel acts as an input capture 1 = The corresponding channel acts as an output compare. CFORC — Timer Compare Force Register RESET: $0081 Bit 7 6 5 4 3 2 1 Bit 0 FOC7 FOC6 FOC5 FOC4 FOC3 FOC2 FOC1 FOC0 0 0 0 0 0 0 0 0 Read anytime but will always return $00 (1 state is transient). Write anytime. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Enhanced Capture Timer 251 Enhanced Capture Timer FOC[7:0] — Force Output Compare Action for Channel 7-0 A write to this register with the corresponding data bit(s) set causes the action which is programmed for output compare “n” to occur immediately. The action taken is the same as if a successful comparison had just taken place with the TCn register except the interrupt flag does not get set. OC7M — Output Compare 7 Mask Register $0082 Bit 7 6 5 4 3 2 1 Bit 0 OC7M7 OC7M6 OC7M5 OC7M4 OC7M3 OC7M2 OC7M1 OC7M0 0 0 0 0 0 0 0 0 RESET: Read or write anytime. The bits of OC7M correspond bit-for-bit with the bits of timer port (PORTT). Setting the OC7Mn will set the corresponding port to be an output port regardless of the state of the DDRTn bit when the corresponding TIOSn bit is set to be an output compare. This does not change the state of the DDRT bits. At successful OC7, for eachbit that is set in OC7M, the corresponding data bit in OC7D is stored to the corresponding bit of the timer port. NOTE: OC7M has priority over output action on timer port enabled by OMn and OLn bits in TCTL1 and TCTL2. If an OC7M bit is set, it prevents the action of corresponding OM and OL bits on the selected timer port. OC7D — Output Compare 7 Data Register $0083 Bit 7 6 5 4 3 2 1 Bit 0 OC7D7 OC7D6 OC7D5 OC7D4 OC7D3 OC7D2 OC7D1 OC7D0 0 0 0 0 0 0 0 0 RESET: Read or write anytime. The bits of OC7D correspond bit-for-bit with the bits of timer port (PORTT). When a successful OC7 compare occurs, for each bit that is set in OC7M, the corresponding data bit in OC7D is stored to the corresponding bit of the timer port. Technical Data 252 MC68HC912DT128A — Rev 4.0 Enhanced Capture Timer MOTOROLA Enhanced Capture Timer Timer Register Descriptions When the OC7Mn bit is set, a successful OC7 action will override a successful OC[6:0] compare action during the same cycle; therefore, the OCn action taken will depend on the corresponding OC7D bit. TCNT — Timer Count Register RESET: $0084–$0085 Bit 7 6 5 4 3 2 1 Bit 0 Bit 15 14 13 12 11 10 9 Bit 8 Bit 7 6 5 4 3 2 1 Bit 0 0 0 0 0 0 0 0 0 The 16-bit main timer is an up counter. A full access for the counter register should take place in one clock cycle. A separate read/write for high byte and low byte will give a different result than accessing them as a word. Read anytime. Write has no meaning or effect in the normal mode; only writable in special modes (SMODN = 0). The period of the first count after a write to the TCNT registers may be a different size because the write is not synchronized with the prescaler clock. TSCR — Timer System Control Register RESET: $0086 Bit 7 6 5 4 TEN TSWAI TSBCK TFFCA 0 0 0 0 3 2 1 Bit 0 0 0 0 0 Read or write anytime. TEN — Timer Enable 0 = Disables the main timer, including the counter. Can be used for reducing power consumption. 1 = Allows the timer to function normally. If for any reason the timer is not active, there is no ÷64 clock for the pulse accumulator since the E÷64 is generated by the timer prescaler. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Enhanced Capture Timer 253 Enhanced Capture Timer TSWAI — Timer Module Stops While in Wait 0 = Allows the timer module to continue running during wait. 1 = Disables the timer module when the MCU is in the wait mode. Timer interrupts cannot be used to get the MCU out of wait. TSWAI also affects pulse accumulators and modulus down counters. TSBCK — Timer and Modulus Counter Stop While in Background Mode 0 = Allows the timer and modulus counter to continue running while in background mode. 1 = Disables the timer and modulus counter whenever the MCU is in background mode. This is useful for emulation. TBSCK does not stop the pulse accumulator. TFFCA — Timer Fast Flag Clear All 0 = Allows the timer flag clearing to function normally. 1 = For TFLG1($8E), a read from an input capture or a write to the output compare channel ($90–$9F) causes the corresponding channel flag, CnF, to be cleared. For TFLG2 ($8F), any access to the TCNT register ($84, $85) clears the TOF flag. Any access to the PACN3 and PACN2 registers ($A2, $A3) clears the PAOVF and PAIF flags in the PAFLG register ($A1). Any access to the PACN1 and PACN0 registers ($A4, $A5) clears the PBOVF flag in the PBFLG register ($B1). Any access to the MCCNT register ($B6, $B7) clears the MCZF flag in the MCFLG register ($A7). This has the advantage of eliminating software overhead in a separate clear sequence. Extra care is required to avoid accidental flag clearing due to unintended accesses. Technical Data 254 MC68HC912DT128A — Rev 4.0 Enhanced Capture Timer MOTOROLA Enhanced Capture Timer Timer Register Descriptions TQCR — Reserved RESET: $0087 Bit 7 6 5 4 3 2 1 Bit 0 0 0 0 0 0 0 0 0 TCTL1 — Timer Control Register 1 RESET: $0088 Bit 7 6 5 4 3 2 1 Bit 0 OM7 OL7 OM6 OL6 OM5 OL5 OM4 OL4 0 0 0 0 0 0 0 0 TCTL2 — Timer Control Register 2 RESET: $0089 Bit 7 6 5 4 3 2 1 Bit 0 OM3 OL3 OM2 OL2 OM1 OL1 OM0 OL0 0 0 0 0 0 0 0 0 Read or write anytime. OMn — Output Mode OLn — Output Level These eight pairs of control bits are encoded to specify the output action to be taken as a result of a successful OCn compare. When either OMn or OLn is one, the pin associated with OCn becomes an output tied to OCn regardless of the state of the associated DDRT bit. NOTE: To enable output action by OMn and OLn bits on timer port, the corresponding bit in OC7M should be cleared. Table 15-1. Compare Result Output Action OMn 0 0 1 1 OLn 0 1 0 1 Action Timer disconnected from output pin logic Toggle OCn output line Clear OCn output line to zero Set OCn output line to one To operate the 16-bit pulse accumulators A and B (PACA and PACB) independently of input capture or output compare 7 and 0 respectively the user must set the corresponding bits IOSn = 1, OMn = 0 and OLn = 0. OC7M7 or OC7M0 in the OC7M register must also be cleared. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Enhanced Capture Timer 255 Enhanced Capture Timer TCTL3 — Timer Control Register 3 $008A Bit 7 6 5 4 3 2 1 Bit 0 EDG7B EDG7A EDG6B EDG6A EDG5B EDG5A EDG4B EDG4A 0 0 0 0 0 0 0 0 RESET: TCTL4 — Timer Control Register 4 $008B Bit 7 6 5 4 3 2 1 Bit 0 EDG3B EDG3A EDG2B EDG2A EDG1B EDG1A EDG0B EDG0A 0 0 0 0 0 0 0 0 RESET: Read or write anytime. EDGnB, EDGnA — Input Capture Edge Control These eight pairs of control bits configure the input capture edge detector circuits. Table 15-2. Edge Detector Circuit Configuration EDGnB 0 0 1 1 EDGnA 0 1 0 1 Configuration Capture disabled Capture on rising edges only Capture on falling edges only Capture on any edge (rising or falling) TMSK1 — Timer Interrupt Mask 1 $008C Bit 7 6 5 4 3 2 1 Bit 0 C7I C6I C5I C4I C3I C2I C1I C0I 0 0 0 0 0 0 0 0 RESET: Read or write anytime. The bits in TMSK1 correspond bit-for-bit with the bits in the TFLG1 status register. If cleared, the corresponding flag is disabled from causing a hardware interrupt. If set, the corresponding flag is enabled to cause a hardware interrupt. Read or write anytime. C7I–C0I — Input Capture/Output Compare “x” Interrupt Enable. Technical Data 256 MC68HC912DT128A — Rev 4.0 Enhanced Capture Timer MOTOROLA Enhanced Capture Timer Timer Register Descriptions TMSK2 — Timer Interrupt Mask 2 RESET: $008D Bit 7 6 5 4 3 2 1 Bit 0 TOI 0 PUPT RDPT TCRE PR2 PR1 PR0 0 0 0 0 0 0 0 0 Read or write anytime. TOI — Timer Overflow Interrupt Enable 0 = Interrupt inhibited 1 = Hardware interrupt requested when TOF flag set PUPT — Timer Port Pull-Up Resistor Enable This enable bit controls pull-up resistors on the timer port pins when the pins are configured as inputs. 0 = Disable pull-up resistor function 1 = Enable pull-up resistor function RDPT — Timer Port Drive Reduction This bit reduces the effective output driver size which can reduce power supply current and generated noise depending upon pin loading. 0 = Normal output drive capability 1 = Enable output drive reduction function TCRE — Timer Counter Reset Enable This bit allows the timer counter to be reset by a successful output compare 7 event. This mode of operation is similar to an up-counting modulus counter. 0 = Counter reset inhibited and counter free runs 1 = Counter reset by a successful output compare 7 If TC7 = $0000 and TCRE = 1, TCNT will stay at $0000 continuously. If TC7 = $FFFF and TCRE = 1, TOF will never be set when TCNT is reset from $FFFF to $0000. PR2, PR1, PR0 — Timer Prescaler Select These three bits specify the number of ÷2 stages that are to be inserted between the module clock and the main timer counter. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Enhanced Capture Timer 257 Enhanced Capture Timer Table 15-3. Prescaler Selection PR2 0 0 0 0 1 1 1 1 PR1 0 0 1 1 0 0 1 1 PR0 0 1 0 1 0 1 0 1 Prescale Factor 1 2 4 8 16 32 64 128 The newly selected prescale factor will not take effect until the next synchronized edge where all prescale counter stages equal zero. TFLG1 — Main Timer Interrupt Flag 1 $008E Bit 7 6 5 4 3 2 1 Bit 0 C7F C6F C5F C4F C3F C2F C1F C0F 0 0 0 0 0 0 0 0 RESET: TFLG1 indicates when interrupt conditions have occurred. To clear a bit in the flag register, write a one to the bit. Use of the TFMOD bit in the ICSYS register ($AB) in conjunction with the use of the ICOVW register ($AA) allows a timer interrupt to be generated after capturing two values in the capture and holding registers instead of generating an interrupt for every capture. Read anytime. Write used in the clearing mechanism (set bits cause corresponding bits to be cleared). Writing a zero will not affect current status of the bit. When TFFCA bit in TSCR register is set, a read from an input capture or a write into an output compare channel ($90–$9F) will cause the corresponding channel flag CnF to be cleared. C7F–C0F — Input Capture/Output Compare Channel “n” Flag. Technical Data 258 MC68HC912DT128A — Rev 4.0 Enhanced Capture Timer MOTOROLA Enhanced Capture Timer Timer Register Descriptions TFLG2 — Main Timer Interrupt Flag 2 RESET: $008F Bit 7 6 5 4 3 2 1 Bit 0 TOF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 TFLG2 indicates when interrupt conditions have occurred. To clear a bit in the flag register, set the bit to one. Read anytime. Write used in clearing mechanism (set bits cause corresponding bits to be cleared). Any access to TCNT will clear TFLG2 register if the TFFCA bit in TSCR register is set. TOF — Timer Overflow Flag Set when 16-bit free-running timer overflows from $FFFF to $0000. This bit is cleared automatically by a write to the TFLG2 register with bit 7 set. (See also TCRE control bit explanation.) TC0 — Timer Input Capture/Output Compare Register 0 $0090–$0091 Bit 7 6 5 4 3 2 1 Bit 0 Bit 15 14 13 12 11 10 9 Bit 8 Bit 7 6 5 4 3 2 1 Bit 0 TC1 — Timer Input Capture/Output Compare Register 1 $0092–$0093 Bit 7 6 5 4 3 2 1 Bit 0 Bit 15 14 13 12 11 10 9 Bit 8 Bit 7 6 5 4 3 2 1 Bit 0 TC2 — Timer Input Capture/Output Compare Register 2 $0094–$0095 Bit 7 6 5 4 3 2 1 Bit 0 Bit 15 14 13 12 11 10 9 Bit 8 Bit 7 6 5 4 3 2 1 Bit 0 TC3 — Timer Input Capture/Output Compare Register 3 $0096–$0097 Bit 7 6 5 4 3 2 1 Bit 0 Bit 15 14 13 12 11 10 9 Bit 8 Bit 7 6 5 4 3 2 1 Bit 0 MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Enhanced Capture Timer 259 Enhanced Capture Timer TC4 — Timer Input Capture/Output Compare Register 4 $0098–$0099 Bit 7 6 5 4 3 2 1 Bit 0 Bit 15 14 13 12 11 10 9 Bit 8 Bit 7 6 5 4 3 2 1 Bit 0 TC5 — Timer Input Capture/Output Compare Register 5 $009A–$009B Bit 7 6 5 4 3 2 1 Bit 0 Bit 15 14 13 12 11 10 9 Bit 8 Bit 7 6 5 4 3 2 1 Bit 0 TC6 — Timer Input Capture/Output Compare Register 6 $009C–$009D Bit 7 6 5 4 3 2 1 Bit 0 Bit 15 14 13 12 11 10 9 Bit 8 Bit 7 6 5 4 3 2 1 Bit 0 TC7 — Timer Input Capture/Output Compare Register 7 $009E–$009F Bit 7 6 5 4 3 2 1 Bit 0 Bit 15 14 13 12 11 10 9 Bit 8 Bit 7 6 5 4 3 2 1 Bit 0 Depending on the TIOS bit for the corresponding channel, these registers are used to latch the value of the free-running counter when a defined transition is sensed by the corresponding input capture edge detector or to trigger an output action for output compare. Read anytime. Write anytime for output compare function. Writes to these registers have no meaning or effect during input capture. All timer input capture/output compare registers are reset to $0000. PACTL — 16-Bit Pulse Accumulator A Control Register $00A0 BIT 7 6 5 4 3 2 1 BIT 0 0 PAEN PAMOD PEDGE CLK1 CLK0 PAOVI PAI 0 0 0 0 0 0 0 0 RESET: 16-Bit Pulse Accumulator A (PACA) is formed by cascading the 8-bit pulse accumulators PAC3 and PAC2. When PAEN is set, the PACA is enabled. The PACA shares the input pin with IC7. Read: any time Write: any time Technical Data 260 MC68HC912DT128A — Rev 4.0 Enhanced Capture Timer MOTOROLA Enhanced Capture Timer Timer Register Descriptions PAEN — Pulse Accumulator A System Enable 0 = 16-Bit Pulse Accumulator A system disabled. 8-bit PAC3 and PAC2 can be enabled when their related enable bits in ICPACR ($A8) are set. Pulse Accumulator Input Edge Flag (PAIF) function is disabled. 1 = Pulse Accumulator A system enabled. The two 8-bit pulse accumulators PAC3 and PAC2 are cascaded to form the PACA 16-bit pulse accumulator. When PACA in enabled, the PACN3 and PACN2 registers contents are respectively the high and low byte of the PACA. PA3EN and PA2EN control bits in ICPACR ($A8) have no effect. Pulse Accumulator Input Edge Flag (PAIF) function is enabled. PAEN is independent from TEN. With timer disabled, the pulse accumulator can still function unless pulse accumulator is disabled. PAMOD — Pulse Accumulator Mode 0 = event counter mode 1 = gated time accumulation mode PEDGE — Pulse Accumulator Edge Control For PAMOD bit = 0 (event counter mode). 0 = falling edges on PT7 pin cause the count to be incremented 1 = rising edges on PT7 pin cause the count to be incremented For PAMOD bit = 1 (gated time accumulation mode). 0 = PT7 input pin high enables M divided by 64 clock to Pulse Accumulator and the trailing falling edge on PT7 sets the PAIF flag. 1 = PT7 input pin low enables M divided by 64 clock to Pulse Accumulator and the trailing rising edge on PT7 sets the PAIF flag. PAMOD PEDGE 0 0 Falling edge Pin Action 0 1 Rising edge 1 0 Div. by 64 clock enabled with pin high level 1 1 Div. by 64 clock enabled with pin low level If the timer is not active (TEN = 0 in TSCR), there is no divide-by-64 since the E÷64 clock is generated by the timer prescaler. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Enhanced Capture Timer 261 Enhanced Capture Timer CLK1, CLK0 — Clock Select Bits CLK1 CLK0 0 0 Use timer prescaler clock as timer counter clock Clock Source 0 1 Use PACLK as input to timer counter clock 1 0 Use PACLK/256 as timer counter clock frequency 1 1 Use PACLK/65536 as timer counter clock frequency If the pulse accumulator is disabled (PAEN = 0), the prescaler clock from the timer is always used as an input clock to the timer counter. The change from one selected clock to the other happens immediately after these bits are written. PAOVI — Pulse Accumulator A Overflow Interrupt enable 0 = interrupt inhibited 1 = interrupt requested if PAOVF is set PAI — Pulse Accumulator Input Interrupt enable 0 = interrupt inhibited 1 = interrupt requested if PAIF is set PAFLG — Pulse Accumulator A Flag Register $00A1 BIT 7 6 5 4 3 2 1 BIT 0 0 0 0 0 0 0 PAOVF PAIF 0 0 0 0 0 0 0 0 RESET: Read or write anytime. When the TFFCA bit in the TSCR register is set, any access to the PACNT register will clear all the flags in the PAFLG register. PAOVF — Pulse Accumulator A Overflow Flag Set when the 16-bit pulse accumulator A overflows from $FFFF to $0000,or when 8-bit pulse accumulator 3 (PAC3) overflows from $FF to $00. This bit is cleared automatically by a write to the PAFLG register with bit 1 set. Technical Data 262 MC68HC912DT128A — Rev 4.0 Enhanced Capture Timer MOTOROLA Enhanced Capture Timer Timer Register Descriptions PAIF — Pulse Accumulator Input edge Flag Set when the selected edge is detected at the PT7 input pin. In event mode the event edge triggers PAIF and in gated time accumulation mode the trailing edge of the gate signal at the PT7 input pin triggers PAIF. This bit is cleared by a write to the PAFLG register with bit 0 set. Any access to the PACN3, PACN2 registers will clear all the flags in this register when TFFCA bit in register TSCR($86) is set. PACN3, PACN2 — Pulse Accumulators Count Registers $00A2, $00A3 BIT 7 6 5 4 3 2 1 BIT 0 $00A2 BIt 7 6 5 4 3 2 1 Bit 0 PACN3 (hi) $00A3 Bit 7 6 5 4 3 2 1 Bit 0 PACN2 (lo) RESET: 0 0 0 0 0 0 0 0 Read or write any time. The two 8-bit pulse accumulators PAC3 and PAC2 are cascaded to form the PACA 16-bit pulse accumulator. When PACA in enabled (PAEN=1 in PACTL, $A0) the PACN3 and PACN2 registers contents are respectively the high and low byte of the PACA. When PACN3 overflows from $FF to $00, the Interrupt flag PAOVF in PAFLG ($A1) is set. Full count register access should take place in one clock cycle. A separate read/write for high byte and low byte will give a different result than accessing them as a word. PACN1, PACN0 — Pulse Accumulators Count Registers $00A4, $00A5 BIT 7 6 5 4 3 2 1 BIT 0 $00A4 BIt 7 6 5 4 3 2 1 Bit 0 PACN1 (hi) $00A5 Bit 7 6 5 4 3 2 1 Bit 0 PACN0 (lo) RESET: 0 0 0 0 0 0 0 0 Read or write any time. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Enhanced Capture Timer 263 Enhanced Capture Timer The two 8-bit pulse accumulators PAC1 and PAC0 are cascaded to form the PACB 16-bit pulse accumulator. When PACB in enabled, (PBEN=1 in PBCTL, $B0) the PACN1 and PACN0 registers contents are respectively the high and low byte of the PACB. When PACN1 overflows from $FF to $00, the Interrupt flag PBOVF in PBFLG ($B1) is set. Full count register access should take place in one clock cycle. A separate read/write for high byte and low byte will give a different result than accessing them as a word. MCCTL — 16-Bit Modulus Down-Counter Control Register $00A6 BIT 7 6 5 4 3 2 1 BIT 0 MCZI MODMC RDMCL ICLAT FLMC MCEN MCPR1 MCPR0 0 0 0 0 0 0 0 0 RESET: Read or write any time. MCZI — Modulus Counter Underflow Interrupt Enable 0 = Modulus counter interrupt is disabled. 1 = Modulus counter interrupt is enabled. MODMC — Modulus Mode Enable 0 = The counter counts once from the value written to it and will stop at $0000. 1 = Modulus mode is enabled. When the counter reaches $0000, the counter is loaded with the latest value written to the modulus count register. NOTE: For proper operation, the MCEN bit should be cleared before modifying the MODMC bit in order to reset the modulus counter to $FF. RDMCL — Read Modulus Down-Counter Load 0 = Reads of the modulus count register will return the present value of the count register. 1 = Reads of the modulus count register will return the contents of the load register. Technical Data 264 MC68HC912DT128A — Rev 4.0 Enhanced Capture Timer MOTOROLA Enhanced Capture Timer Timer Register Descriptions ICLAT — Input Capture Force Latch Action When input capture latch mode is enabled (LATQ and BUFEN bit in ICSYS ($AB) are set), a write one to this bit immediately forces the contents of the input capture registers TC0 to TC3 and their corresponding 8-bit pulse accumulators to be latched into the associated holding registers. The pulse accumulators will be automatically cleared when the latch action occurs. Writing zero to this bit has no effect. Read of this bit will return always zero. FLMC — Force Load Register into the Modulus Counter Count Register This bit is active only when the modulus down-counter is enabled (MCEN=1). A write one into this bit loads the load register into the modulus counter count register. This also resets the modulus counter prescaler. Write zero to this bit has no effect. When MODMC=0, counter starts counting and stops at $0000. Read of this bit will return always zero. MCEN — Modulus Down-Counter Enable 0 = Modulus counter disabled. 1 = Modulus counter is enabled. When MCEN=0, the counter is preset to $FFFF. This will prevent an early interrupt flag when the modulus down-counter is enabled. MCPR1, MCPR0 — Modulus Counter Prescaler select These two bits specify the division rate of the modulus counter prescaler. The newly selected prescaler division rate will not be effective until a load of the load register into the modulus counter count register occurs. MCPR1 MCPR0 Prescaler division rate 0 0 1 0 1 4 1 0 8 1 1 16 MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Enhanced Capture Timer 265 Enhanced Capture Timer MCFLG — 16-Bit Modulus Down-Counter FLAG Register $00A7 BIT 7 6 5 4 3 2 1 BIT 0 MCZF 0 0 0 POLF3 POLF2 POLF1 POLF0 0 0 0 0 0 0 0 0 RESET: Read: any time Write: Only for clearing bit 7 MCZF — Modulus Counter Underflow Interrupt Flag The flag is set when the modulus down-counter reaches $0000. A write one to this bit clears the flag. Write zero has no effect. Any access to the MCCNT register will clear the MCZF flag in this register when TFFCA bit in register TSCR($86) is set. POLF3 – POLF0 — First Input Capture Polarity Status This are read only bits. Write to these bits has no effect. Each status bit gives the polarity of the first edge which has caused an input capture to occur after capture latch has been read. Each POLFx corresponds to a timer PORTx input. 0 = The first input capture has been caused by a falling edge. 1 = The first input capture has been caused by a rising edge. ICPAR — Input Control Pulse Accumulators Register $00A8 BIT 7 6 5 4 3 2 1 BIT 0 0 0 0 0 PA3EN PA2EN PA1EN PA0EN 0 0 0 0 0 0 0 0 RESET: The 8-bit pulse accumulators PAC3 and PAC2 can be enabled only if PAEN in PATCL ($A0) is cleared. If PAEN is set, PA3EN and PA2EN have no effect. The 8-bit pulse accumulators PAC1 and PAC0 can be enabled only if PBEN in PBTCL ($B0) is cleared. If PBEN is set, PA1EN and PA0EN have no effect. Read or write any time. Technical Data 266 MC68HC912DT128A — Rev 4.0 Enhanced Capture Timer MOTOROLA Enhanced Capture Timer Timer Register Descriptions PAxEN — 8-Bit Pulse Accumulator ‘x’ Enable 0 = 8-Bit Pulse Accumulator is disabled. 1 = 8-Bit Pulse Accumulator is enabled. DLYCT — Delay Counter Control Register RESET: $00A9 BIT 7 6 5 4 3 2 1 BIT 0 0 0 0 0 0 0 DLY1 DLY0 0 0 0 0 0 0 0 0 Read or write any time. If enabled, after detection of a valid edge on input capture pin, the delay counter counts the pre-selected number of M clock (module clock) cycles, then it will generate a pulse on its output. The pulse is generated only if the level of input signal, after the preset delay, is the opposite of the level before the transition.This will avoid reaction to narrow input pulses. After counting, the counter will be cleared automatically. Delay between two active edges of the input signal period should be longer than the selected counter delay. DLYx — Delay Counter Select DLY1 DLY0 0 0 Disabled (bypassed) Delay 0 1 256M clock cycles 1 0 512M clock cycles 1 1 1024 M clock cycles ICOVW — Input Control Overwrite Register RESET: $00AA BIT 7 6 5 4 3 2 1 BIT 0 NOVW7 NOVW6 NOVW5 NOVW4 NOVW3 NOVW2 NOVW1 NOVW0 0 0 0 0 0 0 0 0 Read or write any time. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Enhanced Capture Timer 267 Enhanced Capture Timer An IC register is empty when it has been read or latched into the holding register. A holding register is empty when it has been read. NOVWx — No Input Capture Overwrite 0 = The contents of the related capture register or holding register can be overwritten when a new input capture or latch occurs. 1 = The related capture register or holding register cannot be written by an event unless they are empty (see IC Channels). This will prevent the captured value to be overwritten until it is read or latched in the holding register. ICSYS — Input Control System Control Register $00AB BIT 7 6 5 4 3 2 1 BIT 0 SH37 SH26 SH15 SH04 TFMOD PACMX BUFEN LATQ 0 0 0 0 0 0 0 0 RESET: Read: any time Write: May be written once (SMODN=1). Writes are always permitted when SMODN=0. SHxy — Share Input action of Input Capture Channels x and y 0 = Normal operation 1 = The channel input ‘x’ causes the same action on the channel ‘y’. The port pin ‘x’ and the corresponding edge detector is used to be active on the channel ‘y’. TFMOD — Timer Flag-setting Mode Use of the TFMOD bit in the ICSYS register ($AB) in conjunction with the use of the ICOVW register ($AA) allows a timer interrupt to be generated after capturing two values in the capture and holding registers instead of generating an interrupt for every capture. By setting TFMOD in queue mode, when NOVW bit is set and the corresponding capture and holding registers are emptied, an input capture event will first update the related input capture register with Technical Data 268 MC68HC912DT128A — Rev 4.0 Enhanced Capture Timer MOTOROLA Enhanced Capture Timer Timer Register Descriptions the main timer contents. At the next event the TCn data is transferred to the TCnH register, The TCn is updated and the CnF interrupt flag is set. See Figure 15-6. In all other input capture cases the interrupt flag is set by a valid external event on PTn. 0 = The timer flags C3F–C0F in TFLG1 ($8E) are set when a valid input capture transition on the corresponding port pin occurs. 1 = If in queue mode (BUFEN=1 and LATQ=0), the timer flags C3F–C0F in TFLG1 ($8E) are set only when a latch on the corresponding holding register occurs. If the queue mode is not engaged, the timer flags C3F–C0F are set the same way as for TFMOD=0. PACMX — 8-Bit Pulse Accumulators Maximum Count 0 = Normal operation. When the 8-bit pulse accumulator has reached the value $FF, with the next active edge, it will be incremented to $00. 1 = When the 8-bit pulse accumulator has reached the value $FF, it will not be incremented further. The value $FF indicates a count of 255 or more. BUFEN — IC Buffer Enable 0 = Input Capture and pulse accumulator holding registers are disabled. 1 = Input Capture and pulse accumulator holding registers are enabled. The latching mode is defined by LATQ control bit. Write one into ICLAT bit in MCCTL ($A6), when LATQ is set will produce latching of input capture and pulse accumulators registers into their holding registers. LATQ — Input Control Latch or Queue Mode Enable The BUFEN control bit should be set in order to enable the IC and pulse accumulators holding registers. Otherwise LATQ latching modes are disabled. Write one into ICLAT bit in MCCTL ($A6), when LATQ and BUFEN are set will produce latching of input capture and pulse accumulators registers into their holding registers. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Enhanced Capture Timer 269 Enhanced Capture Timer 0 = Queue Mode of Input Capture is enabled. The main timer value is memorized in the IC register by a valid input pin transition. With a new occurrence of a capture, the value of the IC register will be transferred to its holding register and the IC register memorizes the new timer value. 1 = Latch Mode is enabled. Latching function occurs when modulus down-counter reaches zero or a zero is written into the count register MCCNT (see Buffered IC Channels). With a latching event the contents of IC registers and 8-bit pulse accumulators are transferred to their holding registers. 8-bit pulse accumulators are cleared. TIMTST — Timer Test Register $00AD BIT 7 6 5 4 3 2 1 BIT 0 0 0 0 0 0 0 TCBYP 0 0 0 0 0 0 0 0 0 RESET: Read: any time Write: only in special mode (SMOD = 1). TCBYP — Main Timer Divider Chain Bypass 0 = Normal operation 1 = For testing only. The 16-bit free-running timer counter is divided into two 8-bit halves and the prescaler is bypassed. The clock drives both halves directly. When the high byte of timer counter TCNT ($84) overflows from $FF to $00, the TOF flag in TFLG2 ($8F) will be set. PORTT — Timer Port Data Register $00AE BIT 7 6 5 4 3 2 1 BIT 0 PORT PT7 PT6 PT5 PT4 PT3 PT2 PT1 PT0 TIMER I/OC7 I/OC6 I/OC5 I/OC4 I/OC3 I/OC2 I/OC1 I/OC0 RESET: - - - - - - - - Read: any time (inputs return pin level; outputs return data register contents) Technical Data 270 MC68HC912DT128A — Rev 4.0 Enhanced Capture Timer MOTOROLA Enhanced Capture Timer Timer Register Descriptions Write: data stored in an internal latch (drives pins only if configured for output) Since the Output Compare 7 shares the pin with Pulse Accumulator input, the only way for Pulse accumulator to receive an independent input from Output Compare 7 is setting both OM7 & OL7 to be zero, and also OC7M7 in OC7M register to be zero. OC7 is still able to reset the counter if enabled while PT7 is used as input to Pulse Accumulator. PORTT can be read anytime. When configured as an input, a read will return the pin level. When configured as an output, a read will return the latched output data. NOTE: Writes do not change pin state when the pin is configured for timer output. The minimum pulse width for pulse accumulator input should always be greater than the width of two module clocks due to input synchronizer circuitry. The minimum pulse width for the input capture should always be greater than the width of two module clocks due to input synchronizer circuitry. DDRT — Data Direction Register for Timer Port RESET: $00AF BIT 7 6 5 4 3 2 1 BIT 0 DDT7 DDT6 DDT5 DDT4 DDT3 DDT2 DDT1 DDT0 0 0 0 0 0 0 0 0 Read or write any time. 0 = Configures the corresponding I/O pin for input only 1 = Configures the corresponding I/O pin for output. The timer forces the I/O state to be an output for each timer port line associated with an enabled output compare. In these cases the data direction bits will not be changed, but have no effect on the direction of these pins. The DDRT will revert to controlling the I/O direction of a pin when the associated timer output compare is disabled. Input captures do not override the DDRT settings. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Enhanced Capture Timer 271 Enhanced Capture Timer PBCTL — 16-Bit Pulse Accumulator B Control Register $00B0 BIT 7 6 5 4 3 2 1 BIT 0 0 PBEN 0 0 0 0 PBOVI 0 0 0 0 0 0 0 0 0 RESET: Read or write any time. 16-Bit Pulse Accumulator B (PACB) is formed by cascading the 8-bit pulse accumulators PAC1 and PAC0. When PBEN is set, the PACB is enabled. The PACB shares the input pin with IC0. PBEN — Pulse Accumulator B System Enable 0 = 16-bit Pulse Accumulator system disabled. 8-bit PAC1 and PAC0 can be enabled when their related enable bits in ICPACR ($A8) are set. 1 = Pulse Accumulator B system enabled. The two 8-bit pulse accumulators PAC1 and PAC0 are cascaded to form the PACB 16-bit pulse accumulator. When PACB in enabled, the PACN1 and PACN0 registers contents are respectively the high and low byte of the PACB. PA1EN and PA0EN control bits in ICPACR ($A8) have no effect. PBEN is independent from TEN. With timer disabled, the pulse accumulator can still function unless pulse accumulator is disabled. PBOVI — Pulse Accumulator B Overflow Interrupt enable 0 = interrupt inhibited 1 = interrupt requested if PBOVF is set PBFLG — Pulse Accumulator B Flag Register $00B1 BIT 7 6 5 4 3 2 1 BIT 0 0 0 0 0 0 0 PBOVF 0 0 0 0 0 0 0 0 0 RESET: Read or write any time. Technical Data 272 MC68HC912DT128A — Rev 4.0 Enhanced Capture Timer MOTOROLA Enhanced Capture Timer Timer Register Descriptions PBOVF — Pulse Accumulator B Overflow Flag This bit is set when the 16-bit pulse accumulator B overflows from $FFFF to $0000, or when 8-bit pulse accumulator 1 (PAC1) overflows from $FF to $00. This bit is cleared by a write to the PBFLG register with bit 1 set. Any access to the PACN1 and PACN0 registers will clear the PBOVF flag in this register when TFFCA bit in register TSCR($86) is set. PA3H–PA0H — 8-Bit Pulse Accumulators Holding Registers $00B2–$00B5 BIT 7 6 5 4 3 2 1 BIT 0 $00B2 BIt 7 6 5 4 3 2 1 Bit 0 PA3H $00B3 Bit 7 6 5 4 3 2 1 Bit 0 PA2H $00B4 BIt 7 6 5 4 3 2 1 Bit 0 PA1H $00B5 Bit 7 6 5 4 3 2 1 Bit 0 PA0H RESET: 0 0 0 0 0 0 0 0 Read: any time Write: has no effect. These registers are used to latch the value of the corresponding pulse accumulator when the related bits in register ICPAR ($A8) are enabled (see Pulse Accumulators). MCCNT — Modulus Down-Counter Count Register $00B6, $00B7 BIT 7 6 5 4 3 2 1 BIT 0 $00B6 BIt 15 14 13 12 11 10 9 Bit 8 MCCNTH $00B7 Bit 7 6 5 4 3 2 1 Bit 0 MCCNTL RESET: 1 1 1 1 1 1 1 1 Read or write any time. A full access for the counter register should take place in one clock cycle. A separate read/write for high byte and low byte will give different result than accessing them as a word. If the RDMCL bit in MCCTL register is cleared, reads of the MCCNT register will return the present value of the count register. If the RDMCL MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Enhanced Capture Timer 273 Enhanced Capture Timer bit is set, reads of the MCCNT will return the contents of the load register. If a $0000 is written into MCCNT and modulus counter while LATQ and BUFEN in ICSYS ($AB) register are set, the input capture and pulse accumulator registers will be latched. With a $0000 write to the MCCNT, the modulus counter will stay at zero and does not set the MCZF flag in MCFLG register. If modulus mode is enabled (MODMC=1), a write to this address will update the load register with the value written to it. The count register will not be updated with the new value until the next counter underflow. The FLMC bit in MCCTL ($A6) can be used to immediately update the count register with the new value if an immediate load is desired. If modulus mode is not enabled (MODMC=0), a write to this address will clear the prescaler and will immediately update the counter register with the value written to it and down-counts once to $0000. TC0H — Timer Input Capture Holding Register 0 $00B8–$00B9 Bit 7 6 5 4 3 2 1 Bit 0 Bit 15 14 13 12 11 10 9 Bit 8 Bit 7 6 5 4 3 2 1 Bit 0 TC1H — Timer Input Capture Holding Register 1 $00BA–$00BB Bit 7 6 5 4 3 2 1 Bit 0 Bit 15 14 13 12 11 10 9 Bit 8 Bit 7 6 5 4 3 2 1 Bit 0 TC2H — Timer Input Capture Holding Register 2 $00BC–$00BD Bit 7 6 5 4 3 2 1 Bit 0 Bit 15 14 13 12 11 10 9 Bit 8 Bit 7 6 5 4 3 2 1 Bit 0 TC3H — Timer Input Capture Holding Register 3 $00BE–$00BF Bit 7 6 5 4 3 2 1 Bit 0 Bit 15 14 13 12 11 10 9 Bit 8 Bit 7 6 5 4 3 2 1 Bit 0 Technical Data 274 MC68HC912DT128A — Rev 4.0 Enhanced Capture Timer MOTOROLA Enhanced Capture Timer Timer and Modulus Counter Operation in Different Modes Read: any time Write: has no effect. These registers are used to latch the value of the input capture registers TC0 – TC3. The corresponding IOSx bits in TIOS ($80) should be cleared (see IC Channels). 15.5 Timer and Modulus Counter Operation in Different Modes STOP: Timer and modulus counter are off since clocks are stopped. BGDM: Timer and modulus counter keep on running, unless TSBCK (REG$86, bit5) is set to one. WAIT: Counters keep on running, unless TSWAI in TSCR ($86) is set to one. NORMAL: Timer and modulus counter keep on running, unless TEN in TSCR($86) respectively MCEN in MCCTL ($A6) are cleared. TEN=0: All 16-bit timer operations are stopped, can only access the registers. MCEN=0: Modulus counter is stopped. PAEN=1: 16-bit Pulse Accumulator A is active. PAEN=0: 8-Bit Pulse Accumulators 3 and 2 can be enabled. (see ICPAR) PBEN=1: 16-bit Pulse Accumulator B is active. PBEN=0: 8-Bit Pulse Accumulators 1 and 0 can be enabled. (see ICPAR) MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Enhanced Capture Timer 275 Enhanced Capture Timer Technical Data 276 MC68HC912DT128A — Rev 4.0 Enhanced Capture Timer MOTOROLA Technical Data — MC68HC912DT128A Section 16. Multiple Serial Interface 16.1 Contents 16.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 277 16.3 Block diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .278 16.4 Serial Communication Interface (SCI) . . . . . . . . . . . . . . . . . .278 16.5 Serial Peripheral Interface (SPI) . . . . . . . . . . . . . . . . . . . . . . .289 16.6 Port S . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 299 16.2 Introduction The multiple serial interface (MSI) module consists of three independent serial I/O sub-systems: two serial communication interfaces (SCI0 and SCI1) and the serial peripheral interface (SPI). Each serial pin shares function with the general-purpose port pins of port S. The SCI subsystems are NRZ type systems that are compatible with standard RS-232 systems. These SCI systems have a new single wire operation mode which allows the unused pin to be available as general-purpose I/O. The SPI subsystem, which is compatible with the M68HC11 SPI, includes new features such as SS output and bidirectional mode. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Multiple Serial Interface 277 Multiple Serial Interface 16.3 Block diagram SCI1 RxD0 PS0 TxD0 PS1 RxD1 TxD1 MISO/SISO SPI MOSI/MOMI PORT S I/O DRIVERS SCI0 DDRS/IOCTLR MSI PS2 PS3 PS4 PS5 SCK PS6 CS/SS PS7 HC12A4 MSI BLOCK Figure 16-1. Multiple Serial Interface Block Diagram 16.4 Serial Communication Interface (SCI) Two serial communication interfaces are available on the MC68HC912DT128A. These are NRZ format (one start, eight or nine data, and one stop bit) asynchronous communication systems with independent internal baud rate generation circuitry and SCI transmitters and receivers. They can be configured for eight or nine data bits (one of which may be designated as a parity bit, odd or even). If enabled, parity is generated in hardware for transmitted and received data. Receiver parity errors are flagged in hardware. The baud rate generator is based on a modulus counter, allowing flexibility in choosing baud rates. There is a receiver wake-up feature, an idle line detect feature, a loop-back mode, and various error detection features. Two port pins for each SCI provide the external interface for the transmitted data (TXD) and the received data (RXD). For a faster wake-up out of WAIT mode by a received SCI message, both SCI have the capability of sending a receiver interrupt, if enabled, when RAF (receiver active flag) is set. For compatibility with other M68HC12 products, this feature is active only in WAIT mode and is disabled when VDDPLL supply is at VSS level. Technical Data 278 MC68HC912DT128A — Rev 4.0 Multiple Serial Interface MOTOROLA Multiple Serial Interface Serial Communication Interface (SCI) MCLK BAUD RATE CLOCK SCI TRANSMITTER MSB DIVIDER Rx Baud Rate PARITY GENERATOR LSB 10-11 Bit SHIFT REG TxD BUFFER/SCxDRL PIN CONTROL / DDRS / PORT S SCxBD/SELECT Tx Baud Rate SCxCR1/SCI CTL 1 TxMTR CONTROL DATA BUS SCxCR2/SCI CTL 2 TxD SCxSR1/INT STATUS RxD INT REQUEST LOGIC TO INTERNAL LOGIC PARITY DETECT DATA RECOVERY SCI RECEIVER MSB LSB 10-11 BIT SHIFT REG TxD BUFFER/SCxDRL SCxCR1/SCI CTL 1 WAKE-UP LOGIC SCxSR1/INT STATUS SCxCR2/SCI CTL 2 INT REQUEST LOGIC HC12A4 SCI BLOCK Figure 16-2. Serial Communications Interface Block Diagram MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Multiple Serial Interface 279 Multiple Serial Interface 16.4.1 Data Format The serial data format requires the following conditions: • An idle-line in the high state before transmission or reception of a message. • A start bit (logic zero), transmitted or received, that indicates the start of each character. • Data that is transmitted or received least significant bit (LSB) first. • A stop bit (logic one), used to indicate the end of a frame. (A frame consists of a start bit, a character of eight or nine data bits and a stop bit.) • A BREAK is defined as the transmission or reception of a logic zero for one frame or more. • This SCI supports hardware parity for transmit and receive. 16.4.2 SCI Baud Rate Generation The basis of the SCI baud rate generator is a 13-bit modulus counter. This counter gives the generator the flexibility necessary to achieve a reasonable level of independence from the CPU operating frequency and still be able to produce standard baud rates with a minimal amount of error. The clock source for the generator comes from the M Clock. Table 16-1. Baud Rate Generation Desired SCI Baud Rate 110 300 600 1200 2400 4800 9600 14400 19200 38400 BR Divisor for M = 4.0 MHz 2273 833 417 208 104 52 26 17 13 — Technical Data 280 BR Divisor for M = 8.0 MHz 4545 2273 833 417 208 104 52 35 26 13 MC68HC912DT128A — Rev 4.0 Multiple Serial Interface MOTOROLA Multiple Serial Interface Serial Communication Interface (SCI) 16.4.3 SCI Register Descriptions Control and data registers for the SCI subsystem are described below. The memory address indicated for each register is the default address that is in use after reset. Both SCI have identical control registers mapped in two blocks of eight bytes. SC0BDH/SC1BDH — SCI Baud Rate Control Register RESET: Bit 7 BTST 0 6 BSPL 0 5 BRLD 0 4 SBR12 0 $00C0/$00C8 3 SBR11 0 2 SBR10 0 1 SBR9 0 SC0BDL/SC1BDL — SCI Baud Rate Control Register RESET: Bit 7 SBR7 0 6 SBR6 0 5 SBR5 0 4 SBR4 0 Bit 0 SBR8 0 High $00C1/$00C9 3 SBR3 0 2 SBR2 1 1 SBR1 0 Bit 0 SBR0 0 Low SCxBDH and SCxBDL are considered together as a 16-bit baud rate control register. Read any time. Write SBR[12:0] anytime. Low order byte must be written for change to take effect. Write SBR[15:13] only in special modes. The value in SBR[12:0] determines the baud rate of the SCI. The desired baud rate is determined by the following formula: MCLKSCI Baud Rate = ------------------16 × BR which is equivalent to: MCLK BR = -----------------------------------------------16 × SCI Baud Rate BR is the value written to bits SBR[12:0] to establish baud rate. NOTE: The baud rate generator is disabled until TE or RE bit in SCxCR2 register is set for the first time after reset, and/or the baud rate generator is disabled when SBR[12:0] = 0. BTST — Reserved for test function BSPL — Reserved for test function BRLD — Reserved for test function MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Multiple Serial Interface 281 Multiple Serial Interface SC0CR1/SC1CR1 — SCI Control Register 1 RESET: Bit 7 LOOPS 0 6 WOMS 0 5 RSRC 0 $00C2/$00CA 4 M 0 3 WAKE 0 2 ILT 0 1 PE 0 Bit 0 PT 0 Read or write anytime. LOOPS — SCI LOOP Mode/Single Wire Mode Enable 0 = SCI transmit and receive sections operate normally. 1 = SCI receive section is disconnected from the RXD pin and the RXD pin is available as general purpose I/O. The receiver input is determined by the RSRC bit. The transmitter output is controlled by the associated DDRS bit. Both the transmitter and the receiver must be enabled to use the LOOP or the single wire mode. If the DDRS bit associated with the TXD pin is set during the LOOPS = 1, the TXD pin outputs the SCI waveform. If the DDRS bit associated with the TXD pin is clear during the LOOPS = 1, the TXD pin becomes high (IDLE line state) for RSRC = 0 and high impedance for RSRC = 1. Refer to Table 16-2. WOMS — Wired-Or Mode for Serial Pins This bit controls the two pins (TXD and RXD) associated with the SCIx section. 0 = Pins operate in a normal mode with both high and low drive capability. To affect the RXD bit, that bit would have to be configured as an output (via DDRS0/2) which is the single wire case when using the SCI. WOMS bit still affects generalpurpose output on TXD and RXD pins when SCIx is not using these pins. 1 = Each pin operates in an open drain fashion if that pin is declared as an output. Technical Data 282 MC68HC912DT128A — Rev 4.0 Multiple Serial Interface MOTOROLA Multiple Serial Interface Serial Communication Interface (SCI) RSRC — Receiver Source When LOOPS = 1, the RSRC bit determines the internal feedback path for the receiver. 0 = Receiver input is connected to the transmitter internally (not TXD pin) 1 = Receiver input is connected to the TXD pin Table 16-2. Loop Mode Functions LOOPS RSRC DDRS1(3) WOMS Function of Port S Bit 1/3 0 x x x Normal Operations 1 0 0 0/1 LOOP mode without TXD output(TXD = High Impedance) 1 0 1 1 LOOP mode with TXD output (CMOS) 1 0 1 1 LOOP mode with TXD output (open-drain) Single wire mode without TXD output 1 1 0 x (the pin is used as receiver input only, TXD = High Impedance) Single wire mode with TXD output 1 1 1 0 (the output is also fed back to receiver input, CMOS) 1 1 1 1 Single wire mode for the receiving and transmitting(open-drain) M — Mode (select character format) 0 = One start, eight data, one stop bit 1 = One start, eight data, ninth data, one stop bit WAKE — Wake-up by Address Mark/Idle 0 = Wake up by IDLE line recognition 1 = Wake up by address mark (last data bit set) ILT — Idle Line Type Determines which of two types of idle line detection will be used by the SCI receiver. 0 = Short idle line mode is enabled. 1 = Long idle line mode is detected. In the short mode, the SCI circuitry begins counting ones in the search for the idle line condition immediately after the start bit. This means that the stop bit and any bits that were ones before the stop bit could be counted in that string of ones, resulting in earlier recognition of an idle line. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Multiple Serial Interface 283 Multiple Serial Interface In the long mode, the SCI circuitry does not begin counting ones in the search for the idle line condition until a stop bit is received. Therefore, the last byte’s stop bit and preceding “1” bits do not affect how quickly an idle line condition can be detected. PE — Parity Enable 0 = Parity is disabled. 1 = Parity is enabled. PT — Parity Type If parity is enabled, this bit determines even or odd parity for both the receiver and the transmitter. 0 = Even parity is selected. An even number of ones in the data character causes the parity bit to be zero and an odd number of ones causes the parity bit to be one. 1 = Odd parity is selected. An odd number of ones in the data character causes the parity bit to be zero and an even number of ones causes the parity bit to be one. SC0CR2/SC1CR2 — SCI Control Register 2 RESET: Bit 7 TIE 0 6 TCIE 0 5 RIE 0 $00C3/$00CB 4 ILIE 0 3 TE 0 2 RE 0 1 RWU 0 Bit 0 SBK 0 Read or write anytime. TIE — Transmit Interrupt Enable 0 = TDRE interrupts disabled 1 = SCI interrupt will be requested whenever the TDRE status flag is set. TCIE — Transmit Complete Interrupt Enable 0 = TC interrupts disabled 1 = SCI interrupt will be requested whenever the TC status flag is set. Technical Data 284 MC68HC912DT128A — Rev 4.0 Multiple Serial Interface MOTOROLA Multiple Serial Interface Serial Communication Interface (SCI) RIE — Receiver Interrupt Enable 0 = RDRF and OR interrupts disabled, RAF interrupt in WAIT mode disabled 1 = SCI interrupt will be requested whenever the RDRF or OR status flag is set, or when RAF is set while in WAIT mode with VDDPLL high. ILIE — Idle Line Interrupt Enable 0 = IDLE interrupts disabled 1 = SCI interrupt will be requested whenever the IDLE status flag is set. TE — Transmitter Enable 0 = Transmitter disabled 1 = SCI transmit logic is enabled and the TXD pin (Port S bit 1/bit 3) is dedicated to the transmitter. The TE bit can be used to queue an idle preamble. RE — Receiver Enable 0 = Receiver disabled 1 = Enables the SCI receive circuitry. RWU — Receiver Wake-Up Control 0 = Normal SCI Receiver 1 = Enables the wake-up function and inhibits further receiver interrupts. Normally hardware wakes the receiver by automatically clearing this bit. SBK — Send Break 0 = Break generator off 1 = Generate a break code (at least 10 or 11 contiguous zeros). As long as SBK remains set the transmitter will send zeros. When SBK is changed to zero, the current frame of all zeros is finished before the TxD line goes to the idle state. If SBK is toggled on and off, the transmitter will send only 10 (or 11) zeros and then revert to mark idle or sending data. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Multiple Serial Interface 285 Multiple Serial Interface SC0SR1/SC1SR1 — SCI Status Register 1 RESET: Bit 7 TDRE 1 6 TC 1 5 RDRF 0 $00C4/$00CC 4 IDLE 0 3 OR 0 2 NF 0 1 FE 0 Bit 0 PF 0 The bits in these registers are set by various conditions in the SCI hardware and are automatically cleared by special acknowledge sequences. The receive related flag bits in SCxSR1 (RDRF, IDLE, OR, NF, FE, and PF) are all cleared by a read of the SCxSR1 register followed by a read of the transmit/receive data register low byte. However, only those bits which were set when SCxSR1 was read will be cleared by the subsequent read of the transmit/receive data register low byte. The transmit related bits in SCxSR1 (TDRE and TC) are cleared by a read of the SCxSR1 register followed by a write to the transmit/receive data register low byte. Read anytime (used in auto clearing mechanism). Write has no meaning or effect. TDRE — Transmit Data Register Empty Flag New data will not be transmitted unless SCxSR1 is read before writing to the transmit data register. Reset sets this bit. 0 = SCxDR busy 1 = Any byte in the transmit data register is transferred to the serial shift register so new data may now be written to the transmit data register. TC — Transmit Complete Flag Flag is set when the transmitter is idle (no data, preamble, or break transmission in progress). Clear by reading SCxSR1 with TC set and then writing to SCxDR. 0 = Transmitter busy 1 = Transmitter is idle Technical Data 286 MC68HC912DT128A — Rev 4.0 Multiple Serial Interface MOTOROLA Multiple Serial Interface Serial Communication Interface (SCI) RDRF — Receive Data Register Full Flag Once cleared, IDLE is not set again until the RxD line has been active and becomes idle again. RDRF is set if a received character is ready to be read from SCxDR. Clear the RDRF flag by reading SCxSR1 with RDRF set and then reading SCxDR. 0 = SCxDR empty 1 = SCxDR full IDLE — Idle Line Detected Flag Receiver idle line is detected (the receipt of a minimum of 10/11 consecutive ones). This bit will not be set by the idle line condition when the RWU bit is set. Once cleared, IDLE will not be set again until after RDRF has been set (after the line has been active and becomes idle again). 0 = RxD line is idle 1 = RxD line is active OR — Overrun Error Flag New byte is ready to be transferred from the receive shift register to the receive data register and the receive data register is already full (RDRF bit is set). Data transfer is inhibited until this bit is cleared. 0 = No overrun 1 = Overrun detected NF — Noise Error Flag Set during the same cycle as the RDRF bit but not set in the case of an overrun (OR). 0 = Unanimous decision 1 = Noise on a valid start bit, any of the data bits, or on the stop bit FE — Framing Error Flag Set when a zero is detected where a stop bit was expected. Clear the FE flag by reading SCxSR1 with FE set and then reading SCxDR. 0 = Stop bit detected 1 = Zero detected rather than a stop bit MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Multiple Serial Interface 287 Multiple Serial Interface PF — Parity Error Flag Indicates if received data’s parity matches parity bit. This feature is active only when parity is enabled. The type of parity tested for is determined by the PT (parity type) bit in SCxCR1. 0 = Parity correct 1 = Incorrect parity detected SC0SR2/SC1SR2 — SCI Status Register 2 RESET: Bit 7 0 0 6 0 0 $00C5/$00CD 5 0 0 4 0 0 3 0 0 2 0 0 1 0 0 Bit 0 RAF 0 Read anytime. Write has no meaning or effect. RAF — Receiver Active Flag This bit is controlled by the receiver front end. It is set during the RT1 time period of the start bit search. It is cleared when an idle state is detected or when the receiver circuitry detects a false start bit (generally due to noise or baud rate mismatch). 0 = A character is not being received 1 = A character is being received If enabled with RIE = 1, RAF set generates an interrupt when VDDPLL is high while in WAIT mode. SC0DRH/SC1DRH — SCI Data Register High RESET: Bit 7 R8 — 6 T8 — 5 0 — $00C6/$00CE 4 0 — 3 0 — 2 0 — 1 0 — SC0DRL/SC1DRL — SCI Data Register Low RESET: Bit 7 R7/T7 — 6 R6/T6 — 5 R5/T5 — $00C7/$00CF 4 R4/T4 — 3 R3/T3 — Technical Data 288 Bit 0 0 — 2 R2/T2 — 1 R1/T1 — Bit 0 R0/T0 — MC68HC912DT128A — Rev 4.0 Multiple Serial Interface MOTOROLA Multiple Serial Interface Serial Peripheral Interface (SPI) R8 — Receive Bit 8 Read anytime. Write has no meaning or affect. This bit is the ninth serial data bit received when the SCI system is configured for nine-data-bit operation. T8 — Transmit Bit 8 Read or write anytime. This bit is the ninth serial data bit transmitted when the SCI system is configured for nine-data-bit operation. When using 9-bit data format this bit does not have to be written for each data word. The same value will be transmitted as the ninth bit until this bit is rewritten. R7/T7–R0/T0 — Receive/Transmit Data Bits 7 to 0 Reads access the eight bits of the read-only SCI receive data register (RDR). Writes access the eight bits of the write-only SCI transmit data register (TDR). SCxDRL:SCxDRH form the 9-bit data word for the SCI. If the SCI is being used with a 7- or 8-bit data word, only SCxDRL needs to be accessed. If a 9-bit format is used, the upper register should be written first to ensure that it is transferred to the transmitter shift register with the lower register. 16.5 Serial Peripheral Interface (SPI) The serial peripheral interface allows the MC68HC912DT128A to communicate synchronously with peripheral devices and other microprocessors. The SPI system in the MC68HC912DT128A can operate as a master or as a slave. The SPI is also capable of interprocessor communications in a multiple master system. When the SPI is enabled, all pins that are defined by the configuration as inputs will be inputs regardless of the state of the DDRS bits for those pins. All pins that are defined as SPI outputs will be outputs only if the DDRS bits for those pins are set. Any SPI output whose corresponding DDRS bit is cleared can be used as a general-purpose input. A bidirectional serial pin is possible using the DDRS as the direction control. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Multiple Serial Interface 289 Multiple Serial Interface 16.5.1 SPI Baud Rate Generation The E Clock is input to a divider series and the resulting SPI clock rate may be selected to be E divided by 2, 4, 8, 16, 32, 64, 128 or 256. Three bits in the SP0BR register control the SPI clock rate. This baud rate generator is activated only when SPI is in the master mode and serial transfer is taking place. Otherwise this divider is disabled to save power. 16.5.2 SPI Operation In the SPI system the 8-bit data register in the master and the 8-bit data register in the slave are linked to form a distributed 16-bit register. When a data transfer operation is performed, this 16-bit register is serially shifted eight bit positions by the SCK clock from the master so the data is effectively exchanged between the master and the slave. Data written to the SP0DR register of the master becomes the output data for the slave and data read from the SP0DR register of the master after a transfer operation is the input data from the slave. Technical Data 290 MC68HC912DT128A — Rev 4.0 Multiple Serial Interface MOTOROLA Multiple Serial Interface Serial Peripheral Interface (SPI) MCU P CLOCK (SAME AS E RATE) DIVIDER ÷2 ÷4 ÷8 ÷16 ÷32 ÷64 ÷128 ÷256 8-BIT SHIFT REGISTER S M MISO PS4 M S MOSI PS5 READ DATA BUFFER SP0DR SPI DATA REGISTER SELECT LSBF PIN CONTROL LOGIC SPR0 SPR1 SPR2 SHIFT CONTROL LOGIC CLOCK SPI CONTROL SCK PS6 S CLOCK LOGIC SP0BR SPI BAUD RATE REGISTER M SS PS7 MSTR SPE SPI INTERRUPT REQUEST SP0SR SPI STATUS REGISTER SP0CR1 SPI CONTROL REGISTER 1 SPC0 RDS PUPS LSBF SSOE CPHA CPOL SWOM MSTR SPE SPIE MODF WCOL SPIF SWOM SP0CR2 SPI CONTROL REGISTER 2 INTERNAL BUS HC12 SPI BLOCK Figure 16-3. Serial Peripheral Interface Block Diagram A clock phase control bit (CPHA) and a clock polarity control bit (CPOL) in the SP0CR1 register select one of four possible clock formats to be used by the SPI system. The CPOL bit simply selects non-inverted or inverted clock. The CPHA bit is used to accommodate two fundamentally different protocols by shifting the clock by one half cycle or no phase shift. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Multiple Serial Interface 291 Multiple Serial Interface Begin Transfer End SCK (CPOL=0) SCK (CPOL=1) If next transfer begins here SAMPLE I (MOSI/MISO) CHANGE O (MOSI pin) CHANGE O (MISO pin) SEL SS (O) (Master only) SEL SS (I) MSB first (LSBF=0): LSB first (LSBF=1): tL MSB LSB Bit 6 Bit 1 Bit 5 Bit 2 Bit 4 Bit 3 Bit 3 Bit 4 Bit 2 Bit 5 Bit 1 Bit 6 LSB MSB tI tT tL Minimum 1/2 SCK for tT, tl, tL HC12 SPI CLOCK FORM 0 Figure 16-4. SPI Clock Format 0 (CPHA = 0) Technical Data 292 MC68HC912DT128A — Rev 4.0 Multiple Serial Interface MOTOROLA Multiple Serial Interface Serial Peripheral Interface (SPI) Transfer Begin End SCK (CPOL=0) SCK (CPOL=1) If next transfer begins here SAMPLE I (MOSI/MISO) CHANGE O (MOSI pin) CHANGE O (MISO pin) SEL SS (O) (Master only) SEL SS (I) tL MSB first (LSBF=0): LSB first (LSBF=1): MSB LSB Bit 6 Bit 1 Bit 5 Bit 2 Bit 4 Bit 3 Bit 3 Bit 4 Bit 2 Bit 5 Bit 1 Bit 6 tI tT tL LSB Minimum 1/2 SCK for tT, tl, tL MSB HC12 SPI CLOCK FORM 1 Figure 16-5. SPI Clock Format 1 (CPHA = 1) 16.5.3 SS Output Available in master mode only, SS output is enabled with the SSOE bit in the SP0CR1 register if the corresponding DDRS is set. The SS output pin will be connected to the SS input pin of the external slave device. The SS output automatically goes low for each transmission to select the external device and it goes high during each idling state to deselect external devices. Table 16-3. SS Output Selection DDRS7 0 0 1 1 SSOE 0 1 0 1 Master Mode SS Input with MODF Feature Reserved General-Purpose Output SS Output MC68HC912DT128A — Rev 4.0 MOTOROLA Slave Mode SS Input SS Input SS Input SS Input Technical Data Multiple Serial Interface 293 Multiple Serial Interface 16.5.4 Bidirectional Mode (MOMI or SISO) In bidirectional mode, the SPI uses only one serial data pin for external device interface. The MSTR bit decides which pin to be used. The MOSI pin becomes serial data I/O (MOMI) pin for the master mode, and the MISO pin becomes serial data I/O (SISO) pin for the slave mode. The direction of each serial I/O pin depends on the corresponding DDRS bit. Figure 16-6. Normal Mode and Bidirectional Mode When SPE=1 Master Mode MSTR=1 Slave Mode MSTR=0 MO Serial Out Normal Mode SPC0=0 SPI SPI DDRS5 MI Serial In SPI SPI PS4 SWOM enables open drain output. PS4 becomes GPIO. PS5 Serial In DDRS5 Serial In SO SWOM enables open drain output. MOMI Serial Out DDRS4 Serial Out SWOM enables open drain output. Bidirectional Mode SPC0=1 SI Serial In DDRS4 SISO Serial Out SWOM enables open drain output. PS5 becomes GPIO. 16.5.5 Register Descriptions Control and data registers for the SPI subsystem are described below. The memory address indicated for each register is the default address that is in use after reset. For more information refer to Operating Modes. SP0CR1 — SPI Control Register 1 RESET: Bit 7 SPIE 0 6 SPE 0 $00D0 5 SWOM 0 4 MSTR 0 3 CPOL 0 2 CPHA 1 1 SSOE 0 Bit 0 LSBF 0 Read or write anytime. SPIE — SPI Interrupt Enable 0 = SPI interrupts are inhibited Technical Data 294 MC68HC912DT128A — Rev 4.0 Multiple Serial Interface MOTOROLA Multiple Serial Interface Serial Peripheral Interface (SPI) 1 = Hardware interrupt sequence is requested each time the SPIF or MODF status flag is set SPE — SPI System Enable 0 = SPI internal hardware is initialized and SPI system is in a lowpower disabled state. 1 = PS[4:7] are dedicated to the SPI function When MODF is set, SPE always reads zero. SP0CR1 must be written as part of a mode fault recovery sequence. SWOM — Port S Wired-OR Mode Controls not only SPI output pins but also the general-purpose output pins (PS[4:7]) which are not used by SPI. 0 = SPI and/or PS[4:7] output buffers operate normally 1 = SPI and/or PS[4:7] output buffers behave as open-drain outputs MSTR — SPI Master/Slave Mode Select 0 = Slave mode 1 = Master mode When MODF is set, MSTR always reads zero. SP0CR1 must be written as part of a mode fault recovery sequence. CPOL, CPHA — SPI Clock Polarity, Clock Phase These two bits are used to specify the clock format to be used in SPI operations. When the clock polarity bit is cleared and data is not being transferred, the SCK pin of the master device is low. When CPOL is set, SCK idles high. See Figure 16-4 and Figure 16-5. SSOE — Slave Select Output Enable The SS output feature is enabled only in the master mode by asserting the SSOE and DDRS7. LSBF — SPI LSB First enable 0 = Data is transferred most significant bit first 1 = Data is transferred least significant bit first Normally data is transferred most significant bit first.This bit does not affect the position of the MSB and LSB in the data register. Reads and writes of the data register will always have MSB in bit 7. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Multiple Serial Interface 295 Multiple Serial Interface SP0CR2 — SPI Control Register 2 RESET: Bit 7 0 0 6 0 0 $00D1 5 0 0 4 0 0 3 PUPS 1 2 RDPS 0 1 SSWAI 0 Bit 0 SPC0 0 Read or write anytime. PUPS — Pull-Up Port S Enable 0 = No internal pull-ups on port S 1 = All port S input pins have an active pull-up device. If a pin is programmed as output, the pull-up device becomes inactive RDPS — Reduce Drive of Port S 0 = Port S output drivers operate normally 1 = All port S output pins have reduced drive capability for lower power and less noise SSWAI — Serial Interface Stop in WAIT mode 0 = Serial interface clock operates normally 1 = Halt serial interface clock generation in WAIT mode SPC0 — Serial Pin Control 0 This bit decides serial pin configurations with MSTR control bit. SPC0(1) Pin Mode #1 #2 #3 #4 Normal 0 Bidirectional 1 MSTR MISO(2) MOSI(3) SCK(4) SS(5) 0 Slave Out Slave In SCK In SS In 1 Master In Master Out SCK Out SS I/O 0 Slave I/O GPI/O SCK In SS In 1 GPI/O Master I/O SCK Out SS I/O 1. The serial pin control 0 bit enables bidirectional configurations. 2. Slave output is enabled if DDRS4 = 1, SS = 0 and MSTR = 0. (#1, #3) 3. Master output is enabled if DDRS5 = 1 and MSTR = 1. (#2, #4) 4. SCK output is enabled if DDRS6 = 1 and MSTR = 1. (#2, #4) 5. SS output is enabled if DDRS7 = 1, SSOE = 1 and MSTR = 1. (#2, #4) Technical Data 296 MC68HC912DT128A — Rev 4.0 Multiple Serial Interface MOTOROLA Multiple Serial Interface Serial Peripheral Interface (SPI) SP0BR — SPI Baud Rate Register RESET: Bit 7 0 0 6 0 0 $00D2 5 0 0 4 0 0 3 0 0 2 SPR2 0 1 SPR1 0 Bit 0 SPR0 0 Read anytime. Write anytime. At reset, E Clock divided by 2 is selected. SPR[2:0] — SPI Clock (SCK) Rate Select Bits These bits are used to specify the SPI clock rate. Table 16-4. SPI Clock Rate Selection SPR2 SPR1 SPR0 0 0 0 0 1 1 1 1 0 0 1 1 0 0 1 1 0 1 0 1 0 1 0 1 E Clock Divisor 2 4 8 16 32 64 128 256 Frequency at E Clock = 4 MHz 2.0 MHz 1.0 MHz 500 kHz 250 kHz 125 kHz 62.5 kHz 31.3 kHz 15.6 kHz Frequency at E Clock = 8 MHz 4.0 MHz 2.0 MHz 1.0 MHz 500 KHz 250 KHz 125 KHz 62.5 KHz 31.3 KHz SP0SR — SPI Status Register RESET: Bit 7 SPIF 0 $00D3 6 WCOL 0 5 0 0 4 MODF 0 3 0 0 2 0 0 1 0 0 Bit 0 0 0 Read anytime. Write has no meaning or effect. SPIF — SPI Interrupt Request SPIF is set after the eighth SCK cycle in a data transfer and it is cleared by reading the SP0SR register (with SPIF set) followed by an access (read or write) to the SPI data register. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Multiple Serial Interface 297 Multiple Serial Interface WCOL — Write Collision Status Flag The MCU write is disabled to avoid writing over the data being transferred. No interrupt is generated because the error status flag can be read upon completion of the transfer that was in progress at the time of the error. Automatically cleared by a read of the SP0SR (with WCOL set) followed by an access (read or write) to the SP0DR register. 0 = No write collision 1 = Indicates that a serial transfer was in progress when the MCU tried to write new data into the SP0DR data register. MODF — SPI Mode Error Interrupt Status Flag This bit is set automatically by SPI hardware if the MSTR control bit is set and the slave select input pin becomes zero. This condition is not permitted in normal operation. In the case where DDRS bit 7 is set, the PS7 pin is a general-purpose output pin or SS output pin rather than being dedicated as the SS input for the SPI system. In this special case the mode fault function is inhibited and MODF remains cleared. This flag is automatically cleared by a read of the SP0SR (with MODF set) followed by a write to the SP0CR1 register. SP0DR — SPI Data Register Bit 7 Bit 7 6 6 $00D5 5 5 4 4 3 3 2 2 1 1 Bit 0 Bit 0 Read anytime (normally only after SPIF flag set). Write anytime (see WCOL write collision flag). Reset does not affect this address. This 8-bit register is both the input and output register for SPI data. Reads of this register are double buffered but writes cause data to written directly into the serial shifter. In the SPI system the 8-bit data register in the master and the 8-bit data register in the slave are linked by the MOSI and MISO wires to form a distributed 16-bit register. When a data transfer operation is performed, this 16-bit register is serially shifted eight bit positions by the SCK clock from the master so the data is effectively exchanged between the master and the slave. Note that Technical Data 298 MC68HC912DT128A — Rev 4.0 Multiple Serial Interface MOTOROLA Multiple Serial Interface Port S some slave devices are very simple and either accept data from the master without returning data to the master or pass data to the master without requiring data from the master. 16.6 Port S In all modes, port S bits PS[7:0] can be used for either general-purpose I/O, or with the SCI and SPI subsystems. During reset, port S pins are configured as high-impedance inputs (DDRS is cleared). PORTS — Port S Data Register Bit 7 6 $00D6 5 4 3 2 1 Bit 0 PS7 PS6 PS5 PS4 PS3 PS2 PS1 PS0 MSI SS CS SCK MOSI MOMI MISO SISO TXD1 RXD1 TXD0 RXD0 RESET: - - - - - - - - Read anytime (inputs return pin level; outputs return pin driver input level). Write data stored in internal latch (drives pins only if configured for output). Writes do not change pin state when pin configured for SPI or SCI output. After reset all bits are configured as general-purpose inputs. Port S shares function with the on-chip serial systems (SPI and SCI0/1). DDRS — Data Direction Register for Port S RESET: Bit 7 DDS7 0 6 DDS6 0 5 DDS5 0 $00D7 4 DDS4 0 3 DDS3 0 2 DDS2 0 1 DDS1 0 Bit 0 DDS0 0 Read or write anytime. After reset, all general-purpose I/O are configured for input only. 0 = Configure the corresponding I/O pin for input only 1 = Configure the corresponding I/O pin for output MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Multiple Serial Interface 299 Multiple Serial Interface DDS2, DDS0 — Data Direction for Port S Bit 2 and Bit 0 If the SCI receiver is configured for two-wire SCI operation, corresponding port S pins will be input regardless of the state of these bits. DDS3, DDS1 — Data Direction for Port S Bit 3 and Bit 1 If the SCI transmitter is configured for two-wire SCI operation, corresponding port S pins will be output regardless of the state of these bits. DDS[6:4] — Data Direction for Port S Bits 6 through 4 If the SPI is enabled and expects the corresponding port S pin to be an input, it will be an input regardless of the state of the DDRS bit. If the SPI is enabled and expects the bit to be an output, it will be an output ONLY if the DDRS bit is set. DDS7 — Data Direction for Port S Bit 7 In SPI slave mode, DDRS7 has no meaning or effect; the PS7 pin is dedicated as the SS input. In SPI master mode, DDRS7 determines whether PS7 is an error detect input to the SPI or a general-purpose or slave select output line. NOTE: If mode fault error occurs bits 5, 6 and 7 are forced to zero. Technical Data 300 MC68HC912DT128A — Rev 4.0 Multiple Serial Interface MOTOROLA Technical Data — MC68HC912DT128A Section 17. Inter IC Bus 17.1 Contents 17.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 301 17.3 IIC Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .302 17.4 IIC System Configuration . . . . . . . . . . . . . . . . . . . . . . . . . . . . 304 17.5 IIC Protocol . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 304 17.6 IIC Register Descriptions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 309 17.7 IIC Programming Examples . . . . . . . . . . . . . . . . . . . . . . . . . .318 17.2 Introduction The Inter-IC Bus (IIC or I2C) is a two-wire, bidirectional serial bus that provides a simple, efficient method of data exchange between devices. Being a two-wire device, the IIC minimizes the need for large numbers of connections between devices, and eliminates the need for an address decoder. This bus is suitable for applications requiring occasional communications over a short distance between a number of devices. It also provides flexibility, allowing additional devices to be connected to the bus for further expansion and system development. The interface is designed to operate up to 100kbps with maximum bus loading and timing. The device is capable of operating at higher baud rates, up to a maximum of clock/20, with reduced bus loading. The maximum communication length and the number of devices that can be connected are limited by a maximum bus capacitance of 400pF. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Inter IC Bus 301 Inter IC Bus 17.3 IIC Features The IIC module has the following key features: • Compatible with I2C Bus standard • Multi-master operation • Software programmable for one of 64 different serial clock frequencies • Software selectable acknowledge bit • Interrupt driven byte-by-byte data transfer • Arbitration lost interrupt with automatic mode switching from master to slave • Calling address identification interrupt • Start and stop signal generation/detection • Repeated start signal generation • Acknowledge bit generation/detection • Bus busy detection • Eight-bit general purpose I/O port A block diagram of the IIC module is shown in Figure 17-1. Technical Data 302 MC68HC912DT128A — Rev 4.0 Inter IC Bus MOTOROLA Inter IC Bus IIC Features ADDR & CONTROL DATA INTERRUPT ADDR_DECODE CTRL_REG DATA_MUX FREQ_REG ADDR_REG STATUS_REG DATA_REG In/Out Input Data Sync Shift Start, Register Stop & Arbitration Control Clock Control Address Compare SCL SDA Figure 17-1. IIC Block Diagram MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Inter IC Bus 303 Inter IC Bus 17.4 IIC System Configuration The IIC system uses a Serial Data line (SDA) and a Serial Clock Line (SCL) for data transfer. All devices connected to it must have open drain or open collector outputs. Logic “and” function is exercised on both lines with external pull-up resistors, the value of these resistors is system dependent. 17.5 IIC Protocol Normally, a standard communication is composed of four parts: START signal, slave address transmission, data transfer and STOP signal. They are described briefly in the following sections and illustrated in Figure 172. MSB SCL SDA 1 LSB 2 3 4 5 6 7 Calling Address Read/ Write MSB SDA Start Signal 9 AD7 AD6 AD5 AD4 AD3 AD2 AD1 R/W Start Signal SCL 8 MSB 1 XXX 3 4 5 6 7 8 Read/ Write 2 3 4 5 6 7 8 D7 D6 D5 D4 D3 D2 D1 D0 Data Byte 1 XX Ack Bit 9 No Ack Bit MSB 9 AD7 AD6 AD5 AD4 AD3 AD2 AD1 R/W Calling Address 1 Ack Bit LSB 2 LSB Stop Signal LSB 2 3 4 5 6 7 8 9 AD7 AD6 AD5 AD4 AD3 AD2 AD1 R/W Repeated Start Signal New Calling Address Read/ Write No Ack Bit Stop Signal Figure 17-2. IIC Transmission Signals Technical Data 304 MC68HC912DT128A — Rev 4.0 Inter IC Bus MOTOROLA Inter IC Bus IIC Protocol 17.5.1 START Signal When the bus is free, i.e. no master device is engaging the bus (both SCL and SDA lines are at logical high), a master may initiate communication by sending a START signal. As shown in Figure 17-2, a START signal is defined as a high-to-low transition of SDA while SCL is high. This signal denotes the beginning of a new data transfer (each data transfer may contain several bytes of data) and wakes up all slaves. 17.5.2 Slave Address Transmission The first byte of data transfer immediately after the START signal is the slave address transmitted by the master. This is a seven-bit calling address followed by a R/W bit. The R/W bit tells the slave the desired direction of data transfer. 1 = Read transfer, the slave transmits data to the master. 0 = Write transfer, the master transmits data to the slave. Only the slave with a calling address that matches the one transmitted by the master will respond by sending back an acknowledge bit. This is done by pulling the SDA low at the 9th clock (see Figure 17-2). Slave address - No two slaves in the system may have the same address. If the IIC is master, it must not transmit an address that is equal to its own slave address. The IIC cannot be master and slave at the same time. If however arbitration is lost during an address cycle the IIC will revert to slave mode and operate correctly even if it is being addressed by another master. 17.5.3 Data Transfer Once successful slave addressing is achieved, the data transfer can proceed byte-by-byte in a direction specified by the R/W bit sent by the calling master. NOTE: All transfers that come after an address cycle are referred to as data transfers, even if they carry sub-address information for the slave device. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Inter IC Bus 305 Inter IC Bus Each data byte is 8 bits long. Data may be changed only while SCL is low and must be held stable while SCL is high as shown in Figure 17-2. There is one clock pulse on SCL for each data bit, the MSB being transferred first. Each data byte has to be followed by an acknowledge bit, which is signalled from the receiving device by pulling the SDA low at the ninth clock. So one complete data byte transfer needs nine clock pulses. If the slave receiver does not acknowledge the master, the SDA line must be left high by the slave. The master can then generate a stop signal to abort the data transfer or a start signal (repeated start) to commence a new calling. If the master receiver does not acknowledge the slave transmitter after a byte transmission, it means 'end of data' to the slave, so the slave releases the SDA line for the master to generate STOP or START signal. 17.5.4 STOP Signal The master can terminate the communication by generating a STOP signal to free the bus. However, the master may generate a START signal followed by a calling command without generating a STOP signal first. This is called repeated START. A STOP signal is defined as a lowto-high transition of SDA while SCL at logical “1” (see Figure 17-2). The master can generate a STOP even if the slave has generated an acknowledge at which point the slave must release the bus. 17.5.5 Repeated START Signal As shown in Figure 17-2, a repeated START signal is a START signal generated without first generating a STOP signal to terminate the communication. This is used by the master to communicate with another slave or with the same slave in different mode (transmit/receive mode) without releasing the bus. Technical Data 306 MC68HC912DT128A — Rev 4.0 Inter IC Bus MOTOROLA Inter IC Bus IIC Protocol 17.5.6 Arbitration Procedure IIC is a true multi-master bus that allows more than one master to be connected on it. If two or more masters try to control the bus at the same time, a clock synchronization procedure determines the bus clock, for which the low period is equal to the longest clock low period and the high is equal to the shortest one among the masters. The relative priority of the contending masters is determined by a data arbitration procedure, a bus master loses arbitration if it transmits logic “1” while another master transmits logic “0”. The losing masters immediately switch over to slave receive mode and stop driving SDA output. In this case the transition from master to slave mode does not generate a STOP condition. Meanwhile, a status bit is set by hardware to indicate loss of arbitration. 17.5.7 Clock Synchronization Since wire-AND logic is performed on SCL line, a high-to-low transition on SCL line affects all the devices connected on the bus. The devices start counting their low period and once a device's clock has gone low, it holds the SCL line low until the clock high state is reached. However, the change of low to high in this device clock may not change the state of the SCL line if another device clock is still within its low period. Therefore, synchronized clock SCL is held low by the device with the longest low period. Devices with shorter low periods enter a high wait state during this time (see Figure 17-3). When all devices concerned have counted off their low period, the synchronized clock SCL line is released and pulled high. There is then no difference between the device clocks and the state of the SCL line and all the devices start counting their high periods. The first device to complete its high period pulls the SCL line low again. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Inter IC Bus 307 Inter IC Bus WAIT Start Counting High Period SCL1 SCL2 SCL Internal Counter Reset Figure 17-3. IIC Clock Synchronization 17.5.8 Handshaking The clock synchronization mechanism can be used as a handshake in data transfer. Slave devices may hold the SCL low after completion of one byte transfer (9 bits). In such case, it halts the bus clock and forces the master clock into wait states until the slave releases the SCL line. 17.5.9 Clock Stretching The clock synchronization mechanism can be used by slaves to slow down the bit rate of a transfer. After the master has driven SCL low the slave can drive SCL low for the required period and then release it. If the slave SCL low period is greater than the master SCL low period then the resulting SCL bus signal low period is stretched. Technical Data 308 MC68HC912DT128A — Rev 4.0 Inter IC Bus MOTOROLA Inter IC Bus IIC Register Descriptions 17.6 IIC Register Descriptions . IBAD — IIC Bus Address Register RESET: Bit 7 ADR7 0 6 ADR6 0 $00E0 5 ADR5 0 4 ADR4 0 3 ADR3 0 2 ADR2 0 1 ADR1 0 Bit 0 0 0 Read and write anytime This register contains the address the IIC will respond to when addressed as a slave; note that it is not the address sent on the bus during the address transfer ADR7–ADR1 — Slave Address Bit 1 to bit 7 contain the specific slave address to be used by the IIC module. The default mode of IIC is slave mode for an address match on the bus. IBFD — IIC Bus Frequency Divider Register RESET: Bit 7 0 0 6 0 0 5 IBC5 0 $00E1 4 IBC4 0 3 IBC3 0 2 IBC2 0 1 IBC1 0 Bit 0 IBC0 0 Read and write anytime IBC5–IBC0 — IIC Bus Clock Rate 5–0 This field is used to prescale the clock for bit rate selection. The bit clock generator is implemented as a prescaled shift register - IBC5-3 select the prescaler divider and IBC2-0 select the shift register tap point. The IBC bits are decoded to give the Tap and Prescale values as shown in Table 17-1. NOTE: At 8 MHz system bus frequency, the IIC bus frequency will slow down by as much as 5%. However, the communications rate of the IIC system will be automatically adjusted to a slower rate. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Inter IC Bus 309 Inter IC Bus Table 17-1. IIC Tap and Prescale Values IBC2-0 (bin) SCL Tap (clocks) SDA Tap (clocks) IBC5-3 (bin) scl2tap (clocks) tap2tap (clocks) 000 5 1 000 4 1 001 6 1 001 4 2 010 7 2 010 6 4 011 8 2 011 6 8 100 9 3 100 14 16 101 10 3 101 30 32 110 12 4 110 62 64 111 15 4 111 126 128 The number of clocks from the falling edge of SCL to the first tap (Tap[1]) is defined by the values shown in the scl2tap column of Table 17-1, all subsequent tap points are separated by 2IBC5-3 as shown in the tap2tap column in Table 17-1. The SCL Tap is used to generated the SCL period and the SDA Tap is used to determine the delay from the falling edge of SCL to SDA changing, the SDA hold time. The serial bit clock frequency is equal to the CPU clock frequency divided by the divider shown in Table 17-2. The equation used to generate the divider values from the IBFD bits is: SCL Divider = 2 x ( scl2tap + [ ( SCL_Tap -1 ) x tap2tap ] + 2 ) The SDA hold delay is equal to the CPU clock period multiplied by the SDA Hold value shown in Figure 17-2. The equation used to generate the SDA Hold value from the IBFD bits is: SDA Hold = scl2tap + [ ( SDA_Tap - 1 ) x tap2tap ] + 3 Technical Data 310 MC68HC912DT128A — Rev 4.0 Inter IC Bus MOTOROLA Inter IC Bus IIC Register Descriptions Table 17-2. IIC Divider and SDA Hold values IBC5-0 (hex) SCL Divider (clocks) SDA Hold (clocks) IBC5-0 (hex) SCL Divider (clocks) SDA Hold (clocks) 00 20 7 20 160 17 01 22 7 21 192 17 02 24 8 22 224 33 03 26 8 23 256 33 04 28 9 24 288 49 05 30 9 25 320 49 06 34 10 26 384 65 07 40 10 27 480 65 08 28 7 28 320 33 09 32 7 29 384 33 0A 36 9 2A 448 65 0B 40 9 2B 512 65 0C 44 11 2C 576 97 0D 48 11 2D 640 97 0E 56 13 2E 768 129 0F 68 13 2F 960 129 10 48 9 30 640 65 11 56 9 31 768 65 12 64 13 32 896 129 13 72 13 33 1024 129 14 80 17 34 1152 193 15 88 17 35 1280 193 16 104 21 36 1536 257 17 128 21 37 1920 257 18 80 9 38 1280 129 19 96 9 39 1536 129 1A 112 17 3A 1792 257 MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Inter IC Bus 311 Inter IC Bus Table 17-2. IIC Divider and SDA Hold values IBC5-0 (hex) SCL Divider (clocks) SDA Hold (clocks) IBC5-0 (hex) SCL Divider (clocks) SDA Hold (clocks) 1B 128 17 3B 2048 257 1C 144 25 3C 2304 385 1D 160 25 3D 2560 385 1E 192 33 3E 3072 513 1F 240 33 3F 3840 513 IBCR — IIC Bus Control Register RESET: Bit 7 IBEN 0 6 IBIE 0 $00E2 5 MS/SL 0 4 Tx/Rx 0 3 TXAK 0 2 RSTA 0 1 0 0 Bit 0 IBSWAI 0 Read and write anytime IBEN — IIC Bus Enable This bit controls the software reset of the entire IIC module. 0 = The module is reset and disabled. This is the power-on reset situation. When low the IIC system is held in reset but registers can still be accessed. 1 = The IIC system is enabled. This bit must be set before any other IBCR bits have any effect. If the IIC module is enabled in the middle of a byte transfer the interface behaves as follows: slave mode ignores the current transfer on the bus and starts operating whenever a subsequent start condition is detected. Master mode will not be aware that the bus is busy, hence if a start cycle is initiated then the current bus cycle may become corrupt. This would ultimately result in either the current bus master or the IIC module losing arbitration, after which bus operation would return to normal. NOTE: To prevent glitches from appearing on the SDA & SCL lines during reset of the IIC module, set PORTIB bit 6 & 7 to 1 before clearing the IBEN bit. Technical Data 312 MC68HC912DT128A — Rev 4.0 Inter IC Bus MOTOROLA Inter IC Bus IIC Register Descriptions IBIE — IIC Bus Interrupt Enable 0 = Interrupts from the IIC module are disabled. Note that this does not clear any currently pending interrupt condition. 1 = Interrupts from the IIC module are enabled. An IIC interrupt occurs provided the IBIF bit in the status register is also set. MS/SL — Master/Slave mode select bit Upon reset, this bit is cleared. When this bit is changed from 0 to 1, a START signal is generated on the bus, and the master mode is selected. When this bit is changed from 1 to 0, a STOP signal is generated and the operation mode changes from master to slave. MS/SL is cleared without generating a STOP signal when the master loses arbitration. 0 = Slave Mode 1 = Master Mode Tx/Rx — Transmit/Receive mode select bit This bit selects the direction of master and slave transfers. When addressed as a slave this bit should be set by software according to the SRW bit in the status register. In master mode this bit should be set according to the type of transfer required. Therefore, for address cycles, this bit will always be high. 0 = Receive 1 = Transmit TXAK — Transmit Acknowledge enable This bit specifies the value driven onto SDA during acknowledge cycles for both master and slave receivers. Note that values written to this bit are only used when the IIC is a receiver, not a transmitter. 0 = An acknowledge signal will be sent out to the bus at the 9th clock bit after receiving one byte data 1 = No acknowledge signal response is sent (i.e. acknowledge bit = 1) MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Inter IC Bus 313 Inter IC Bus RSTA — Repeat Start Writing a 1 to this bit will generate a repeated START condition on the bus, provided it is the current bus master. This bit will always be read as a low. Attempting a repeated start at the wrong time, if the bus is owned by another master, will result in loss of arbitration. 1 = Generate repeat start cycle IBSWAI — IIC Stop in WAIT mode 0 = IIC module operates normally 1 = Halt clock generation of IIC module in WAIT mode IBSR — IIC Bus Status Register RESET: Bit 7 TCF 1 6 IAAS 0 $00E3 5 IBB 0 4 IBAL 0 3 0 0 2 SRW 0 1 IBIF 0 Bit 0 RXAK 0 This status register is read-only with exception of bit 1 (IBIF) and bit 4 (IBAL), which are software clearable TCF — Data transferring bit While one byte of data is being transferred, this bit is cleared. It is set by the falling edge of the 9th clock of a byte transfer. 0 = Transfer in progress 1 = Transfer complete IAAS — Addressed as a slave bit When its own specific address (IIC Bus Address Register) is matched with the calling address, this bit is set. The CPU is interrupted provided the IBIE is set. Then the CPU needs to check the SRW bit and set its Tx/Rx mode accordingly. Writing to the IIC Bus Control Register clears this bit. 0 = Not addressed 1 = Addressed as a slave IBB — IIC Bus busy bit This bit indicates the status of the bus. When a START signal is detected, the IBB is set. If a STOP signal is detected, it is cleared. 0 = Bus is idle 1 = Bus is busy Technical Data 314 MC68HC912DT128A — Rev 4.0 Inter IC Bus MOTOROLA Inter IC Bus IIC Register Descriptions NOTE: If, after trying to generate a START signal and neither the IBB nor IBAL bits are set after several cycles, the IIC should be disabled and reenabled with IBEN bit. IBAL — Arbitration Lost The arbitration lost bit (IBAL) is set by hardware when the arbitration procedure is lost. Arbitration is lost in the following circumstances: 1. SDA sampled as low when the master drives a high during an address or data transmit cycle. 2. SDA sampled as a low when the master drives a high during the acknowledge bit of a data receive cycle. 3. A start cycle is attempted when the bus is busy. 4. A repeated start cycle is requested in slave mode. 5. A stop condition is detected when the master did not request it. This bit must be cleared by software, by writing a one to it. NOTE: If, after trying to generate a START signal and neither the IBB nor IBAL bits are set after several cycles, the IIC should be disabled and reenabled with IBEN bit. SRW — Slave Read/Write When IAAS is set this bit indicates the value of the R/W command bit of the calling address sent from the master. CAUTION: This bit is only valid when the IIC is in slave mode, a complete address transfer has occurred with an address match and no other transfers have been initiated. Checking this bit, the CPU can select slave transmit/receive mode according to the command of the master. 0 = Slave receive, master writing to slave 1 = Slave transmit, master reading from slave MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Inter IC Bus 315 Inter IC Bus IBIF — IIC Bus Interrupt Flag The IBIF bit is set when an interrupt is pending, which will cause a processor interrupt request provided IBIE is set. IBIF is set when one of the following events occurs: 1. Complete one byte transfer (set at the falling edge of the 9th clock). 2. Receive a calling address that matches its own specific address in slave receive mode. 3. Arbitration lost. This bit must be cleared by software, writing a one to it, in the interrupt routine. RXAK — Received Acknowledge The value of SDA during the acknowledge bit of a bus cycle. If the received acknowledge bit (RXAK) is low, it indicates an acknowledge signal has been received after the completion of 8 bits data transmission on the bus. If RXAK is high, it means no acknowledge signal is detected at the 9th clock. 0 = Acknowledge received 1 = No acknowledge received . IBDR — IIC Bus Data I/O Register RESET: Bit 7 D7 0 6 D6 0 $00E4 5 D5 0 4 D4 0 3 D3 0 2 D2 0 1 D1 0 Bit 0 D0 0 High Read and write anytime In master transmit mode, when data is written to the IBDR a data transfer is initiated. The most significant bit is sent first. In master receive mode, reading this register initiates next byte data receiving. In slave mode, the same functions are available after an address match has occurred. NOTE: In master transmit mode, the first byte of data written to IBDR following assertion of MS/SL is used for the address transfer and should comprise of the calling address (in position D7-D1) concatenated with the required R/W bit (in position D0). Technical Data 316 MC68HC912DT128A — Rev 4.0 Inter IC Bus MOTOROLA Inter IC Bus IIC Register Descriptions IBPURD — Pull-Up and Reduced Drive for Port IB RESET: Bit 7 0 0 6 0 0 5 0 0 $00E5 4 RDPIB 0 3 0 0 2 0 0 1 0 0 Bit 0 PUPIB 0 Read and write anytime RDPIB - Reduced Drive of Port IB 0 = All port IB output pins have full drive enabled. 1 = All port IB output pins have reduced drive capability. PUPIB - Pull-Up Port IB Enable 0 = Port IB pull-ups are disabled. 1 = Enable pull-up devices for port IB input pins [7:6]. Pull-ups for port IB input pins [5:0] are always enabled. PORTIB — Port Data IB Register IIC RESET: Bit 7 PIB7 SCL - 6 PIB6 SDA - $00E6 5 PIB5 - 4 PIB4 - 3 PIB3 - 2 PIB2 - 1 PIB1 - Bit 0 PIB0 - Read and write anytime. IIC functions SCL and SDA share port IB pins 7 and 6 and take precedence over the general-purpose port when IIC is enabled. The SCL and SDA output buffers behave as open-drain outputs. When port is configured as input, a read will return the pin level. Port bits 5 through 0 have internal pull ups when configured as inputs so they will read ones. When configured as output, a read will return the latched output data. Port bits 5 through 0 will read the last value written. A write will drive associated pins only if configured for output and IIC is not enabled. Port bits 5 through 0 do not have available external pins for MC68HC912DT128A. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Inter IC Bus 317 Inter IC Bus DDRIB — Data Direction for Port IB Register RESET: Bit 7 DDRIB7 0 6 DDRIB6 0 5 DDRIB5 0 $00E7 4 DDRIB4 0 3 DDRIB3 0 2 DDRIB2 0 1 DDRIB1 0 Bit 0 DDRIB0 0 Read and write anytime DDRIB[7:2]— Port IB [7:2] Data direction Each bit determines the primary direction for each pin configured as general-purpose I/O. 0 = Associated pin is a high-impedance input. 1 = Associated pin is an output. DDRIB[5:0] — These bits served as memory locations since there are no corresponding external port pins for MC68HC912DT128A. 17.7 IIC Programming Examples 17.7.1 Initialization Sequence Reset will put the IIC Bus Control Register to its default status. Before the interface can be used to transfer serial data, an initialization procedure must be carried out, as follows: 1. Update the Frequency Divider Register (IBFD) and select the required division ratio to obtain SCL frequency from system clock. 2. Update the IIC Bus Address Register (IBAD) to define its slave address. 3. Set the IBEN bit of the IIC Bus Control Register (IBCR) to enable the IIC interface system. 4. Modify the bits of the IIC Bus Control Register (IBCR) to select Master/Slave mode, Transmit/Receive mode and interrupt enable or not. Technical Data 318 MC68HC912DT128A — Rev 4.0 Inter IC Bus MOTOROLA Inter IC Bus IIC Programming Examples 17.7.2 Generation of START After completion of the initialization procedure, serial data can be transmitted by selecting the 'master transmitter' mode. If the device is connected to a multi-master bus system, the state of the IIC Bus Busy bit (IBB) must be tested to check whether the serial bus is free. If the bus is free (IBB=0), the start condition and the first byte (the slave address) can be sent. The data written to the data register comprises the slave calling address and the LSB set to indicate the direction of transfer required from the slave. The bus free time (i.e., the time between a STOP condition and the following START condition) is built into the hardware that generates the START cycle. Depending on the relative frequencies of the system clock and the SCL period it may be necessary to wait until the IIC is busy after writing the calling address to the IBDR before proceeding with the following instructions. This is illustrated in the following example. An example of a program which generates the START signal and transmits the first byte of data (slave address) is shown below: CHFLAG TXSTART IBFREE BRSET BSET IBSR,#$20,* IBCR,#$30 MOVB CALLING,IBDR BRCLR IBSR,#$20,* ;WAIT FOR IBB FLAG TO CLEAR ;SET TRANSMIT AND MASTER MODE ;i.e. GENERATE START CONDITION ;TRANSMIT THE CALLING ;ADDRESS, D0=R/W ;WAIT FOR IBB FLAG TO SET 17.7.3 Post-Transfer Software Response Transmission or reception of a byte will set the data transferring bit (TCF) to 1, which indicates one byte communication is finished. The IIC Bus interrupt bit (IBIF) is set also; an interrupt will be generated if the interrupt function is enabled during initialization by setting the IBIE bit. Software must clear the IBIF bit in the interrupt routine first. The TCF bit will be cleared by reading from the IIC Bus Data I/O Register (IBDR) in receive mode or writing to IBDR in transmit mode. Software may service the IIC I/O in the main program by monitoring the IBIF bit if the interrupt function is disabled. Note that polling should MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Inter IC Bus 319 Inter IC Bus monitor the IBIF bit rather than the TCF bit since their operation is different when arbitration is lost. Note that when an interrupt occurs at the end of the address cycle the master will always be in transmit mode, i.e. the address is transmitted. If master receive mode is required, indicated by R/W bit in IBDR, then the Tx/Rx bit should be toggled at this stage. During slave mode address cycles (IAAS=1) the SRW bit in the status register is read to determine the direction of the subsequent transfer and the Tx/Rx bit is programmed accordingly. For slave mode data cycles (IAAS=0) the SRW bit is not valid, the Tx/Rx bit in the control register should be read to determine the direction of the current transfer. The following is an example of a software response by a 'master transmitter' in the interrupt routine (see Figure 17-4). ISR TRANSMIT BCLR BRCLR BRCLR BRSET MOVB IBSR,#$02 IBCR,#$20,SLAVE IBCR,#$10,RECEIVE IBSR,#$01,END DATABUF,IBDR ;CLEAR THE IBIF FLAG ;BRANCH IF IN SLAVE MODE ;BRANCH IF IN RECEIVE MODE ;IF NO ACK, END OF TRANSMISSION ;TRANSMIT NEXT BYTE OF DATA 17.7.4 Generation of STOP A data transfer ends with a STOP signal generated by the 'master' device. A master transmitter can simply generate a STOP signal after all the data has been transmitted. The following is an example showing how a stop condition is generated by a master transmitter. MASTX TST TXCNT END EMASTX BEQ BRSET MOVB DEC BRA BCLR RTI END IBSR,#$01,END DATABUF,IBDR TXCNT EMASTX IBCR,#$20 ;GET VALUE FROM THE ;TRANSMITING COUNTER ;END IF NO MORE DATA ;END IF NO ACK ;TRANSMIT NEXT BYTE OF DATA ;DECREASE THE TXCNT ;EXIT ;GENERATE A STOP CONDITION ;RETURN FROM INTERRUPT If a master receiver wants to terminate a data transfer, it must inform the slave transmitter by not acknowledging the last byte of data which can Technical Data 320 MC68HC912DT128A — Rev 4.0 Inter IC Bus MOTOROLA Inter IC Bus IIC Programming Examples be done by setting the transmit acknowledge bit (TXAK) before reading the 2nd last byte of data. Before reading the last byte of data, a STOP signal must be generated first. The following is an example showing how a STOP signal is generated by a master receiver. MASR LAMAR ENMASR NXMAR DEC BEQ MOVB DEC BNE BSET RXCNT ENMASR RXCNT,D1 D1 NXMAR IBCR,#$08 BRA BCLR MOVB RTI NXMAR IBCR,#$20 IBDR,RXBUF ;DECREASE THE RXCNT ;LAST BYTE TO BE READ ;CHECK SECOND LAST BYTE ;TO BE READ ;NOT LAST OR SECOND LAST ;SECOND LAST, DISABLE ACK ;TRANSMITTING ;LAST ONE, GENERATE ‘STOP’ SIGNAL ;READ DATA AND STORE 17.7.5 Generation of Repeated START At the end of data transfer, if the master still wants to communicate on the bus, it can generate another START signal followed by another slave address without first generating a STOP signal. A program example is as shown. RESTART BSET MOVB IBCR,#$04 CALLING,IBDR ANOTHER START (RESTART) ;TRANSMIT THE CALLING ADDRESS ;D0=R/W 17.7.6 Slave Mode In the slave interrupt service routine, the module addressed as slave bit (IAAS) should be tested to check if a calling of its own address has just been received (see Figure 17-4). If IAAS is set, software should set the transmit/receive mode select bit (Tx/Rx bit of IBCR) according to the R/W command bit (SRW). Writing to the IBCR clears the IAAS automatically. Note that the only time IAAS is read as set is from the interrupt at the end of the address cycle where an address match occurred, interrupts resulting from subsequent data transfers will have IAAS cleared. A data transfer may now be initiated by writing information to IBDR, for slave transmits, or dummy reading from IBDR, in slave MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Inter IC Bus 321 Inter IC Bus receive mode. The slave will drive SCL low in-between byte transfers, SCL is released when the IBDR is accessed in the required mode. In slave transmitter routine, the received acknowledge bit (RXAK) must be tested before transmitting the next byte of data. Setting RXAK means an 'end of data' signal from the master receiver, after which it must be switched from transmitter mode to receiver mode by software. A dummy read then releases the SCL line so that the master can generate a STOP signal. 17.7.7 Arbitration Lost If several masters try to engage the bus simultaneously, only one master wins and the others lose arbitration. The devices which lost arbitration are immediately switched to slave receive mode by the hardware. Their data output to the SDA line is stopped, but SCL is still generated until the end of the byte during which arbitration was lost. An interrupt occurs at the falling edge of the ninth clock of this transfer with IBAL=1 and MS/SL=0. If one master attempts to start transmission while the bus is being engaged by another master, the hardware will inhibit the transmission; switch the MS/SL bit from 1 to 0 without generating STOP condition; generate an interrupt to CPU and set the IBAL to indicate that the attempt to engage the bus is failed. When considering these cases, the slave service routine should test the IBAL first and the software should clear the IBAL bit if it is set. Technical Data 322 MC68HC912DT128A — Rev 4.0 Inter IC Bus MOTOROLA Inter IC Bus Clear IBIF Master Mode ? Y TX N Y RX Tx/Rx ? Arbitration Lost ? N Last Byte Transmitted ? Clear IBAL Y N RXAK=0 ? Last Byte To Be Read ? N N Y N Y Y IAAS=1 ? IAAS=1 ? Y N Data Transfer Address Transfer End Of Addr Cycle (Master Rx) ? N Y Y Y (Read) 2nd Last Byte To Be Read ? SRW=1 ? Write Next Byte To IBDR Set TXAK =1 Generate Stop Signal Y Set TX Mode Switch To Rx Mode Generate Stop Signal Read Data From IBDR And Store ACK From Receiver ? N Read Data From IBDR And Store Tx Next Byte Write Data To IBDR Dummy Read From IBDR TX N (Write) N RX TX/RX ? Set RX Mode Switch To Rx Mode Dummy Read From IBDR Dummy Read From IBDR RTI Figure 17-4. Flow-Chart of Typical IIC Interrupt Routine Technical Data 323 MC68HC912DT128A — Rev 4.0 Inter IC Bus MOTOROLA Inter IC Bus Technical Data 324 MC68HC912DT128A — Rev 4.0 Inter IC Bus MOTOROLA Technical Data — MC68HC912DT128A Section 18. MSCAN Controller 18.1 Contents 18.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 325 18.3 External Pins. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 326 18.4 Message Storage . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 327 18.5 Identifier Acceptance Filter . . . . . . . . . . . . . . . . . . . . . . . . . . .332 18.6 Interrupts. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .335 18.7 Protocol Violation Protection. . . . . . . . . . . . . . . . . . . . . . . . . . 337 18.8 Low Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .338 18.9 Timer Link . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 342 18.10 Clock System . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .343 18.11 Memory Map. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 345 18.12 Programmer’s Model of Message Storage . . . . . . . . . . . . . . .346 18.13 Programmer’s Model of Control Registers . . . . . . . . . . . . . . . 351 18.2 Introduction The MC68HC912DT128A has three identical msCAN12 modules, identified as CAN0, CAN1 and CAN2. The MC68HC912DG128A has two: CAN0 and CAN1. The information to follow describes one msCAN unless specifically noted and register locations specifically relate to CAN0. CAN1 registers are located 512 bytes from CAN0, and on the MC68HC912DT128A, CAN2 registers are located 256 bytes from CAN0. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data MSCAN Controller 325 MSCAN Controller The msCAN12 is the specific implementation of the Motorola scalable CAN (msCAN) concept targeted for the Motorola M68HC12 microcontroller family. The module is a communication controller implementing the CAN 2.0 A/B protocol as defined in the BOSCH specification dated September 1991. The CAN protocol was primarily, but not only, designed to be used as a vehicle serial data bus, meeting the specific requirements of this field: real-time processing, reliable operation in the EMI environment of a vehicle, cost-effectiveness and required bandwidth. msCAN12 utilizes an advanced buffer arrangement resulting in a predictable real-time behavior and simplifies the application software. 18.3 External Pins The msCAN12 uses 2 external pins, 1 input (RxCAN) and 1 output (TxCAN). The TxCAN output pin represents the logic level on the CAN: 0 is for a dominant state, and 1 is for a recessive state. RxCAN is on bit 0 of Port CAN, TxCAN is on bit 1. The remaining six pins of Port CAN are controlled by registers in the msCAN12 address space (see msCAN12 Port CAN Control Register (PCTLCAN) and msCAN12 Port CAN Data Direction Register (DDRCAN)). A typical CAN system with msCAN12 is shown in Figure 18-1 below. Each CAN station is connected physically to the CAN bus lines through a transceiver chip. The transceiver is capable of driving the large current needed for the CAN and has current protection, against defected CAN or defected stations. Technical Data 326 MC68HC912DT128A — Rev 4.0 MSCAN Controller MOTOROLA MSCAN Controller Message Storage CAN station 1 CAN station 2 ..... CAN station n CAN system msCAN12 Controller TxCAN RxCAN Transceiver CAN Figure 18-1. The CAN System 18.4 Message Storage msCAN12 facilitates a sophisticated message storage system which addresses the requirements of a broad range of network applications. 18.4.1 Background Modern application layer software is built upon two fundamental assumptions: 1. Any CAN node is able to send out a stream of scheduled messages without releasing the bus between two messages. Such nodes will arbitrate for the bus right after sending the previous message and will only release the bus in case of lost arbitration. 2. The internal message queue within any CAN node is organized such that if more than one message is ready to be sent, the highest priority message will be sent out first. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data MSCAN Controller 327 MSCAN Controller Above behavior can not be achieved with a single transmit buffer. That buffer must be reloaded right after the previous message has been sent. This loading process lasts a definite amount of time and has to be completed within the inter-frame sequence (IFS) in order to be able to send an uninterrupted stream of messages. Even if this is feasible for limited CAN bus speeds it requires that the CPU reacts with short latencies to the transmit interrupt. A double buffer scheme would de-couple the re-loading of the transmit buffers from the actual message sending and as such reduces the reactiveness requirements on the CPU. Problems may arise if the sending of a message would be finished just while the CPU re-loads the second buffer, no buffer would then be ready for transmission and the bus would be released. At least three transmit buffers are required to meet the first of above requirements under all circumstances. The msCAN12 has three transmit buffers. The second requirement calls for some sort of internal prioritizing which the msCAN12 implements with the local priority concept described below. 18.4.2 Receive Structures The received messages are stored in a two stage input FIFO. The two message buffers are mapped using a ping-pong arrangement into a single memory area (see Figure 18-2). While the background receive buffer (RxBG) is exclusively associated to the msCAN12, the foreground receive buffer (RxFG) is addressed by the CPU12. This scheme simplifies the handler software as only one address area is applicable for the receive process. Both buffers have a size of 13 bytes to store the CAN control bits, the identifier (standard or extended) and the data contents (for details see Programmer’s Model of Message Storage). The receiver full flag (RXF) in the msCAN12 receiver flag register (CRFLG) (see msCAN12 Receiver Flag Register (CRFLG)) signals the Technical Data 328 MC68HC912DT128A — Rev 4.0 MSCAN Controller MOTOROLA MSCAN Controller Message Storage status of the foreground receive buffer. When the buffer contains a correctly received message with matching identifier this flag is set. After the msCAN12 successfully received a message into the background buffer and if the message passes the filter, it copies the content of RxBG into RxFG(1), sets the RXF flag, and emits a receive interrupt to the CPU(2). A new message (which may follow immediately after the IFS field of the CAN frame) will be received into RxBG. The over-writing of the background buffer is independent of the identifier filter function. The user’s receive handler has to read the received message from RxFG and to reset the RXF flag in order to acknowledge the interrupt and to release the foreground buffer. An overrun condition occurs when both the foreground and the background receive message buffers are filled with correctly received messages with accepted identifiers and a further correctly received message with accepted identifier is received from the bus. The latter message will be discarded and an error interrupt with overrun indication will occur if enabled. As long as both buffers remain filled, the msCAN12 is able to transmit messages but it will discard all incoming messages. NOTE: The msCAN12 will receive its own messages into the background receive buffer RxBG but will not overwrite RxFG and will not emit a receive interrupt nor will it acknowledge (ACK) its own messages on the CAN bus. The exception to this rule is that when in loop-back mode msCAN12 will treat its own messages exactly like all other incoming messages. 1. Only if the RXF flag is not set. 2. The receive interrupt will occur only if not masked. A polling scheme can be applied on RXF also. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data MSCAN Controller 329 MSCAN Controller msCAN12 CPU bus RxBG RxFG RXF Tx0 TXE PRIO Tx1 TXE PRIO Tx2 TXE PRIO Figure 18-2. User Model for Message Buffer Organization 18.4.3 Transmit Structures The msCAN12 has a triple transmit buffer scheme in order to allow multiple messages to be set up in advance and to achieve an optimized real-time performance. The three buffers are arranged as shown in Figure 18-2. All three buffers have a 13 byte data structure similar to the outline of the receive buffers (see Programmer’s Model of Message Storage). An additional transmit buffer priority register (TBPR) contains an 8-bit so Technical Data 330 MC68HC912DT128A — Rev 4.0 MSCAN Controller MOTOROLA MSCAN Controller Message Storage called local priority field (PRIO) (see Transmit Buffer Priority Registers (TBPR)). In order to transmit a message, the CPU12 has to identify an available transmit buffer which is indicated by a set transmit buffer empty (TXE) flag in the msCAN12 transmitter flag register (CTFLG) (see msCAN12 Transmitter Flag Register (CTFLG)). The CPU12 then stores the identifier, the control bits and the data content into one of the transmit buffers. Finally, the buffer has to be flagged as being ready for transmission by clearing the TXE flag. The msCAN12 will then schedule the message for transmission and will signal the successful transmission of the buffer by setting the TXE flag. A transmit interrupt will be emitted(1) when TXE is set and this can be used to drive the application software to re-load the buffer. In case more than one buffer is scheduled for transmission when the CAN bus becomes available for arbitration, the msCAN12 uses the local priority setting of the three buffers for prioritizing. For this purpose every transmit buffer has an 8-bit local priority field (PRIO). The application software sets this field when the message is set up. The local priority reflects the priority of this particular message relative to the set of messages being emitted from this node. The lowest binary value of the PRIO field is defined to be the highest priority. The internal scheduling process takes places whenever the msCAN12 arbitrates for the bus. This is also the case after the occurrence of a transmission error. When a high priority message is scheduled by the application software it may become necessary to abort a lower priority message being set up in one of the three transmit buffers. As messages that are already under transmission can not be aborted, the user has to request the abort by setting the corresponding abort request flag (ABTRQ) in the transmission control register (CTCR). The msCAN12 grants the request, if possible, by setting the corresponding abort request acknowledge (ABTAK) and the TXE flag in order to release the buffer and by emitting 1. The transmit interrupt will occur only if not masked. A polling scheme can be applied on TXE also. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data MSCAN Controller 331 MSCAN Controller a transmit interrupt. The transmit interrupt handler software can tell from the setting of the ABTAK flag whether the message was actually aborted (ABTAK=1) or sent in the meantime (ABTAK=0). 18.5 Identifier Acceptance Filter A very flexible programmable generic identifier acceptance filter has been introduced in order to reduce the CPU interrupt loading. The filter is programmable to operate in four different modes: • Two identifier acceptance filters, each to be applied to the full 29 bits of the identifier and to the following bits of the CAN frame: RTR, IDE, SRR. This mode implements a two filters for a full length CAN 2.0B compliant extended identifier. Figure 18-3 shows how the first 32-bit filter bank (CIDAR0–3, CIDMR0–3) produces a filter 0 hit. Similarly, the second filter bank (CIDAR4–7, CIDMR4–7) produces a filter 1 hit. • Four identifier acceptance filters, each to be applied to a) the 11 bits of the identifier and the RTR bit of CAN 2.0A messages or b) the 14 most significant bits of the identifier of CAN 2.0B messages. Figure 18-4 shows how the first 32-bit filter bank (CIDAR0–3, CIDMR0–3) produces filter 0 and 1 hits. Similarly, the second filter bank (CIDAR4–7, CIDMR4–7) produces filter 2 and 3 hits. • Eight identifier acceptance filters, each to be applied to the first 8 bits of the identifier. This mode implements eight independent filters for the first 8 bit of a CAN 2.0A compliant standard identifier or of a CAN 2.0B compliant extended identifier. Figure 18-5 shows how the first 32-bit filter bank (CIDAR0–3, CIDMR0–3) produces filter 0 to 3 hits. Similarly, the second filter bank (CIDAR4–7, CIDMR4–7) produces filter 4 to 7 hits. • Closed filter. No CAN message will be copied into the foreground buffer RxFG, and the RXF flag will never be set. Technical Data 332 MC68HC912DT128A — Rev 4.0 MSCAN Controller MOTOROLA MSCAN Controller Identifier Acceptance Filter ID28 IDR0 ID10 IDR0 ID21 ID20 IDR1 ID3 ID2 ID15 ID14 IDR2 ID7 ID6 IDR3 RTR IDR1 IDE AM7 CIDMRO AM0 AM7 CIDMR1 AM0 AM7 CIDMR2 AM0 AM7 CIDMR3 AM0 AC7 CIDARO AC0 AC7 CIDAR1 AC0 AC7 CIDAR2 AC0 AC7 CIDAR3 AC0 ID accepted (Filter 0 hit) Figure 18-3. 32-bit Maskable Identifier Acceptance Filters ID28 IDR0 ID10 IDR0 ID21 ID20 IDR1 ID3 ID2 ID15 ID14 IDR2 ID7 ID6 IDR3 RTR IDR1 IDE AM7 CIDMRO AM0 AM7 CIDMR1 AM0 AC7 CIDARO AC0 AC7 CIDAR1 AC0 ID accepted (Filter 0 hit) AM7 CIDMR2 AM0 AM7 CIDMR3 AM0 AC7 CIDAR2 AC0 AC7 CIDAR3 AC0 ID accepted (Filter 1 hit) Figure 18-4. 16-bit Maskable Acceptance Filters MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data MSCAN Controller 333 MSCAN Controller ID28 IDR0 ID21 ID20 ID10 IDR0 ID3 ID2 IDR1 ID15 ID14 IDR2 ID7 ID6 IDR3 RTR IDR1 IDE AM7 CIDMRO AM0 AC7 CIDARO AC0 ID accepted (Filter 0 hit) AM7 CIDMR1 AM0 AC7 CIDAR1 AC0 ID accepted (Filter 1 hit) AM7 CIDMR2 AM0 AC7 CIDAR2 AC0 ID accepted (Filter 2 hit) AM7 CIDMR3 AM0 AC7 CIDAR3 AC0 Figure 18-5. 8-bit Maskable Acceptance Filters The identifier acceptance registers (CIDAR0–7) define the acceptable patterns of the standard or extended identifier (ID10–ID0 or ID28–ID0). Any of these bits can be marked don’t care in the identifier mask registers (CIDMR0–7). A filter hit is indicated to the application software by a set RXF (receive buffer full flag, see msCAN12 Receiver Flag Register (CRFLG)) and Technical Data 334 MC68HC912DT128A — Rev 4.0 MSCAN Controller MOTOROLA MSCAN Controller Interrupts three bits in the identifier acceptance control register (see msCAN12 Identifier Acceptance Control Register (CIDAC)). These identifier hit flags (IDHIT2–0) clearly identify the filter section that caused the acceptance. They simplify the application software’s task to identify the cause of the receiver interrupt. In case that more than one hit occurs (two or more filters match) the lower hit has priority. A hit will also cause a receiver interrupt if enabled. 18.6 Interrupts The msCAN12 supports four interrupt vectors mapped onto eleven different interrupt sources, any of which can be individually masked (for details see msCAN12 Receiver Flag Register (CRFLG) to msCAN12 Transmitter Control Register (CTCR)): • Transmit interrupt: At least one of the three transmit buffers is empty (not scheduled) and can be loaded to schedule a message for transmission. The TXE flags of the empty message buffers are set. • Receive interrupt: A message has been successfully received and loaded into the foreground receive buffer. This interrupt will be emitted immediately after receiving the EOF symbol. The RXF flag is set. • Wake-up interrupt: An activity on the CAN bus occurred during msCAN12 internal SLEEP mode. • Error interrupt: An overrun, error or warning condition occurred. The receiver flag register (CRFLG) will indicate one of the following conditions: – Overrun: an overrun condition as described in Receive Structures has occurred. – Receiver warning: the receive error counter has reached the CPU warning limit of 96. – Transmitter warning: the transmit error counter has reached the CPU warning limit of 96. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data MSCAN Controller 335 MSCAN Controller – Receiver error passive: the receive error counter has exceeded the error passive limit of 127 and msCAN12 has gone to error passive state. – Transmitter error passive: the transmit error counter has exceeded the error passive limit of 127 and msCAN12 has gone to error passive state. – Bus off: the transmit error counter has exceeded 255 and msCAN12 has gone to BUSOFF state. 18.6.1 Interrupt Acknowledge Interrupts are directly associated with one or more status flags in either the msCAN12 receiver flag register (CRFLG) or the msCAN12 transmitter flag register (CTFLG). Interrupts are pending as long as one of the corresponding flags is set. The flags in above registers must be reset within the interrupt handler in order to handshake the interrupt. The flags are reset through writing a 1 to the corresponding bit position. A flag can not be cleared if the respective condition still prevails. NOTE: Bit manipulation instructions (BSET) shall not be used to clear interrupt flags. 18.6.2 Interrupt Vectors The msCAN12 supports four interrupt vectors as shown in Table 18-1. The vector addresses and the relative interrupt priority are dependent on the chip integration and to be defined. Technical Data 336 MC68HC912DT128A — Rev 4.0 MSCAN Controller MOTOROLA MSCAN Controller Protocol Violation Protection Table 18-1. msCAN12 Interrupt Vectors Function Wake-Up Source WUPIF RWRNIF TWRNIF RERRIF TERRIF BOFFIF OVRIF RXF TXE0 TXE1 TXE2 Error Interrupts Receive Transmit Local Mask WUPIE RWRNIE TWRNIE RERRIE TERRIE BOFFIE OVRIE RXFIE TXEIE0 TXEIE1 TXEIE2 Global Mask I Bit 18.7 Protocol Violation Protection The msCAN12 will protect the user from accidentally violating the CAN protocol through programming errors. The protection logic implements the following features: • The receive and transmit error counters cannot be written or otherwise manipulated. • All registers which control the configuration of the msCAN12 can not be modified while the msCAN12 is on-line. The SFTRES bit in CMCR0 (see msCAN12 Module Control Register (CMCR0)) serves as a lock to protect the following registers: – msCAN12 module control register 1 (CMCR1) – msCAN12 bus timing register 0 and 1 (CBTR0, CBTR1) – msCAN12 identifier acceptance control register (CIDAC) – msCAN12 identifier acceptance registers (CIDAR0–7) – msCAN12 identifier mask registers (CIDMR0–7) • The TxCAN pin is forced to recessive when the msCAN12 is in any of the low power modes. MC68HC912DT128A — Rev 4.0 Technical Data MOTOROLA MSCAN Controller 337 MSCAN Controller 18.8 Low Power Modes The msCAN12 has three modes with reduced power consumption compared to normal mode. In SLEEP and SOFT_RESET mode, power consumption is reduced by stopping all clocks except those to access the registers. In POWER_DOWN mode, all clocks are stopped and no power is consumed. The WAI and STOP instructions put the MCU in low power consumption stand-by modes. Table 18-2 summarizes the combinations of msCAN12 and CPU modes. A particular combination of modes is entered for the given settings of the bits CSWAI, SLPAK, and SFTRES. For all modes, an msCAN wake-up interrupt can occur only if SLPAK=WUPIE=1. While the CPU is in Wait Mode, the msCAN12 can be operated in Normal Mode and emit interrupts (registers can be accessed via background debug mode). Table 18-2. msCAN12 vs. CPU operating modes STOP CPU Mode WAIT CSWAI = X(1) SLPAK = X SFTRES = X CSWAI = 1 SLPAK = X SFTRES = X msCAN Mode POWER_DOWN SLEEP SOFT_RESET Normal CSWAI = 0 SLPAK = 1 SFTRES = 0 CSWAI = 0 SLPAK = 0 SFTRES = 1 CSWAI = 0 SLPAK = 0 SFTRES = 0 RUN CSWAI = X SLPAK = 1 SFTRES = 0 CSWAI = X SLPAK = 0 SFTRES = 1 CSWAI = X SLPAK = 0 SFTRES = 0 1. X means don’t care. Technical Data 338 MC68HC912DT128A — Rev 4.0 MSCAN Controller MOTOROLA MSCAN Controller Low Power Modes 18.8.1 msCAN12 SLEEP Mode The CPU can request the msCAN12 to enter this low-power mode by asserting the SLPRQ bit in the module configuration register (see Figure 18-6). The time when the msCAN12 will then enter SLEEP mode depends on its current activity: • If there are one or more message buffers are scheduled for transmission (TXEx = 0), the msCAN will continue to transmit until all transmit message buffers are empty (TXEx = 1, transmitted successfully or aborted) and then goes into Sleep Mode • If it is receiving, it continues to receive and goes into Sleep Mode as soon as the CAN bus next becomes idle • If it is neither transmitting nor receiving, it will immediately go into SLEEP mode The application software must avoid setting up a transmission (by clearing one or more TXE flag(s)) and immediately request SLEEP mode (by setting SLPRQ). It will then depend on the exact sequence of operations whether the msCAN12 will start transmitting or go into SLEEP mode directly. During SLEEP mode, the SLPAK flag is set. The application software should use SLPAK as a handshake indication for the request (SLPRQ) to go into SLEEP mode. When in SLEEP mode, the msCAN12 stops its internal clocks. Clocks to allow register accesses will still run. The TxCAN pin will stay in recessive state. If RXF=1, the message can be read and RXF can be cleared. However, if the msCAN12 is in bus-off state, it stops counting 128*11 consecutive recessive bits due to the stopped clocks. Likewise, copying of RxBG into RxFG will not take place while in sleep mode. It is possible to access the transmit buffers and to clear the TXE flags. No message abort will take place while in sleep mode. The msCAN12 will leave SLEEP mode (wake-up) when • bus activity occurs or • the MCU clears the SLPRQ bit or • the MCU sets SFTRES. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data MSCAN Controller 339 MSCAN Controller NOTE: The MCU cannot clear the SLPRQ bit before the msCAN12 is in SLEEP mode (SLPAK = 1). After wake-up, the msCAN12 waits for 11 consecutive recessive bits to synchronize to the bus. As a consequence, if the msCAN12 is woken-up by a CAN frame, this frame will not be received. The receive message buffers (RxBG and RxFG) will contain messages if they were received before sleep mode was entered. Pending copying of RxBG and RxFG, as well as pending message aborts and pending message transmissions, will now be executed. If the msCAN12 is still in bus-off state after sleep mode was left, it continues counting the 128*11 consecutive recessive bits. msCAN12 Running SLPRQ = 0 SLPAK = 0 MCU MCU or msCAN12 msCAN12 Sleeping SLEEP Request SLPRQ = 1 SLPAK = 1 SLPRQ = 1 SLPAK = 0 msCAN12 Figure 18-6. SLEEP Request / Acknowledge Cycle Technical Data 340 MC68HC912DT128A — Rev 4.0 MSCAN Controller MOTOROLA MSCAN Controller Low Power Modes 18.8.2 msCAN12 SOFT_RESET Mode In SOFT_RESET mode, the msCAN12 is stopped. Registers can still be accessed. This mode is used to initialize the module configuration, bit timing, and the CAN message filter. See msCAN12 Module Control Register (CMCR0) for a complete description of the SOFT_RESET mode. When setting the SFTRES bit, the msCAN12 immediately stops all ongoing transmissions and receptions, potentially causing the CAN protocol violations. The user is responsible to take care that the msCAN12 is not active when SOFT_RESET mode is entered. The recommended procedure is to bring the msCAN12 into SLEEP mode before the SFTRES bit is set. 18.8.3 msCAN12 POWER_DOWN Mode The msCAN12 is in POWER_DOWN mode when • the CPU is in STOP mode or • the CPU is in WAIT mode and the CSWAI bit is set (see msCAN12 Module Control Register (CMCR0)). When entering the POWER_DOWN mode, the msCAN12 immediately stops all ongoing transmissions and receptions, potentially causing CAN protocol violations. The user is responsible to take care that the msCAN12 is not active when POWER_DOWN mode is entered. The recommended procedure is to bring the msCAN12 into SLEEP mode before the STOP instruction (or the WAI instruction, if CSWAI is set) is executed. To protect the CAN bus system from fatal consequences of violations to above rule, the msCAN12 will drive the TxCAN pin into recessive state. In POWER_DOWN mode, no registers can be accessed. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data MSCAN Controller 341 MSCAN Controller 18.8.4 Programmable Wake-Up Function The msCAN12 can be programmed to apply a low-pass filter function to the RxCAN input line while in SLEEP mode (see control bit WUPM in the module control register, msCAN12 Module Control Register (CMCR0)). This feature can be used to protect the msCAN12 from wake-up due to short glitches on the CAN bus lines. Such glitches can result from electromagnetic inference within noisy environments. 18.9 Timer Link The msCAN12 will generate a timer signal whenever a valid frame has been received. Because the CAN specification defines a frame to be valid if no errors occurred before the EOF field has been transmitted successfully, the timer signal will be generated right after the EOF. A pulse of one bit time is generated. As the msCAN12 receiver engine receives also the frames being sent by itself, a timer signal will also be generated after a successful transmission. The previously described timer signal can be routed into the on-chip timer module (ECT). Under the control of the timer link enable (TLNKEN) bit in the CMCR0, this signal will be connected to the ECT timer channel m input(1). After ECT timer has been programmed to capture rising edge events, it can be used under software control to generate 16-bit time stamps which can be stored with the received message. 1. The timer channel being used for the timer link for CAN0 is channel 4 and for CAN1 is channel 5. Technical Data 342 MC68HC912DT128A — Rev 4.0 MSCAN Controller MOTOROLA MSCAN Controller Clock System 18.10 Clock System Figure 18-7 shows the structure of the msCAN12 clock generation circuitry. With this flexible clocking scheme the msCAN12 is able to handle CAN bus rates ranging from 10 kbps up to 1 Mbps. CGM msCAN12 SYSCLK CGMCANCLK CLKSRC EXTALi Prescaler (1...64) Time quanta clock CLKSRC Figure 18-7. Clocking Scheme The clock source bit (CLKSRC) in the msCAN12 module control register (CMCR1) (see msCAN12 Bus Timing Register 0 (CBTR0)) defines whether the msCAN12 is connected to the output of the crystal oscillator (EXTALi) or to the system clock (SYSCLK). The clock source has to be chosen such that the tight oscillator tolerance requirements (up to 0.4%) of the CAN protocol are met. Additionally, for high CAN bus rates (1 Mbps), a 50% duty cycle of the clock is required. For microcontrollers without the CGM module, CGMCANCLK is driven from the crystal oscillator (EXTALi). A programmable prescaler is used to generate out of msCANCLK the time quanta (Tq) clock. A time quantum is the atomic unit of time handled by the msCAN12. A bit time is subdivided into three segments(1): • SYNC_SEG: This segment has a fixed length of one time quantum. Signal edges are expected to happen within this section. 1. For further explanation of the under-lying concepts please refer to ISO/DIS 11519-1, Section 10.3. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data MSCAN Controller 343 MSCAN Controller • Time segment 1: This segment includes the PROP_SEG and the PHASE_SEG1 of the CAN standard. It can be programmed by setting the parameter TSEG1 to consist of 4 to 16 time quanta. • Time segment 2: This segment represents the PHASE_SEG2 of the CAN standard. It can be programmed by setting the TSEG2 parameter to be 2 to 8 time quanta long. The synchronization jump width can be programmed in a range of 1 to 4 time quanta by setting the SJW parameter. Above parameters can be set by programming the bus timing registers (CBTR0–1, see msCAN12 Bus Timing Register 0 (CBTR0) and msCAN12 Bus Timing Register 1 (CBTR1)). It is the user’s responsibility to make sure that his bit time settings are in compliance with the CAN standard. Figure 18-9 gives an overview on the CAN conforming segment settings and the related parameter values. NRZ Signal SYNC _SEG Time segment 1 (PROP_SEG + PHASE_SEG1) Time Seg. 2 (PHASE_SEG2) 1 4 ... 16 2 ... 8 8... 25 Time Quanta = 1 Bit Time Transmit point Sample point (single or triple sampling) Figure 18-8. Segments within the Bit Time Technical Data 344 MC68HC912DT128A — Rev 4.0 MSCAN Controller MOTOROLA MSCAN Controller Memory Map Figure 18-9. CAN Standard Compliant Bit Time Segment Settings Time Segment 1 TSEG1 Time Segment 2 TSEG2 5 .. 10 4 .. 11 5 .. 12 6 .. 13 7 .. 14 8 .. 15 9 .. 16 4 .. 9 3 .. 10 4 .. 11 5 .. 12 6 .. 13 7 .. 14 8 .. 15 2 3 4 5 6 7 8 1 2 3 4 5 6 7 Synchron. Jump Width 1 .. 2 1 .. 3 1 .. 4 1 .. 4 1 .. 4 1 .. 4 1 .. 4 SJW 0 .. 1 0 .. 2 0 .. 3 0 .. 3 0 .. 3 0 .. 3 0 .. 3 18.11 Memory Map The msCAN12 occupies 128 bytes in the CPU12 memory space. The background receive buffer can only be read in test mode. Figure 18-10. msCAN12 Memory Map $0100 $0108 $0109 $010D $010E $010F $0110 $011F $0120 $013C $013D $013F $0140 $014F $0150 $015F $0160 $016F $0170 $017F Control registers 9 bytes Reserved 5 bytes Error counters 2 bytes Identifier filter 16 bytes Reserved 29 bytes Port CAN registers 3 bytes Foreground Receive buffer MC68HC912DT128A — Rev 4.0 MOTOROLA Transmit buffer 0 Transmit buffer 1 Transmit buffer 2 Technical Data MSCAN Controller 345 MSCAN Controller 18.12 Programmer’s Model of Message Storage The following section details the organization of the receive and transmit message buffers and the associated control registers. For reasons of programmer interface simplification the receive and transmit message buffers have the same outline. Each message buffer allocates 16 bytes in the memory map containing a 13 byte data structure. An additional transmit buffer priority register (TBPR) is defined for the transmit buffers. Figure 18-11. Message Buffer Organization Address (1) Register name 01x0 Identifier register 0 01x1 01x2 01x3 01x4 01x5 01x6 01x7 01x8 01x9 01xA 01xB 01xC Identifier register 1 Identifier register 2 Identifier register 3 Data segment register 0 Data segment register 1 Data segment register 2 Data segment register 3 Data segment register 4 Data segment register 5 Data segment register 6 Data segment register 7 Data length register 01xD Transmit buffer priority register(2) Unused Unused 01xE 01xF 1. x is 4, 5, 6, or 7 depending on which buffer RxFG, Tx0, Tx1, or Tx2 respectively. 2. Not applicable for receive buffers Technical Data 346 MC68HC912DT128A — Rev 4.0 MSCAN Controller MOTOROLA MSCAN Controller Programmer’s Model of Message Storage 18.12.1 Message Buffer Outline Figure 18-12 shows the common 13 byte data structure of receive and transmit buffers for extended identifiers. The mapping of standard identifiers into the IDR registers is shown in Figure 18-13. All bits of the 13 byte data structure are undefined out of reset. NOTE: The foreground receive buffer can be read anytime but can not be written. The transmit buffers can be read or written anytime. Figure 18-12. Receive/Transmit Message Buffer Extended Identifier ADDR(1) REGISTER $01x0 IDR0 $01x1 IDR1 $01x2 IDR2 $01x3 IDR3 $01x4 DSR0 $01x5 DSR1 $01x6 DSR2 $01x7 DSR3 $01x8 DSR4 $01x9 DSR5 $01xA DSR6 $01xB DSR7 $01xC DLR R/W R W R W R W R W R W R W R W R W R W R W R W R W R W BIT 7 6 5 4 3 2 1 BIT 0 ID28 ID27 ID26 ID25 ID24 ID23 ID22 ID21 ID20 ID19 ID18 ID17 ID16 ID15 ID14 ID13 ID12 ID11 ID10 ID9 ID8 ID7 ID6 ID5 ID4 ID3 ID2 ID1 ID0 RTR DB7 DB6 DB5 DB4 DB3 DB2 DB1 DB0 DB7 DB6 DB5 DB4 DB3 DB2 DB1 DB0 DB7 DB6 DB5 DB4 DB3 DB2 DB1 DB0 DB7 DB6 DB5 DB4 DB3 DB2 DB1 DB0 DB7 DB6 DB5 DB4 DB3 DB2 DB1 DB0 DB7 DB6 DB5 DB4 DB3 DB2 DB1 DB0 DB7 DB6 DB5 DB4 DB3 DB2 DB1 DB0 DB7 DB6 DB5 DB4 DB3 DB2 DB1 DB0 DLC3 DLC2 DLC1 DLC0 SRR (1) IDE (1) 1. x is 4, 5, 6, or 7 depending on which buffer RxFG, Tx0, Tx1, or Tx2 respectively. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data MSCAN Controller 347 MSCAN Controller Figure 18-13. Standard Identifier Mapping ADDR(1) REGISTER $01x0 IDR0 $01x1 IDR1 $01x2 IDR2 $01x3 IDR3 R/W R W R W R W R W BIT 7 6 5 4 3 2 1 BIT 0 ID10 ID9 ID8 ID7 ID6 ID5 ID4 ID3 ID2 ID1 ID0 RTR IDE(0) 1. x is 4, 5, 6, or 7 depending on which buffer RxFG, Tx0, Tx1, or Tx2 respectively. 18.12.2 Identifier Registers (IDRn) The identifiers consist of either 11 bits (ID10–ID0) for the standard, or 29 bits (ID28–ID0) for the extended format. ID10/28 is the most significant bit and is transmitted first on the bus during the arbitration procedure. The priority of an identifier is defined to be highest for the smallest binary number. SRR — Substitute Remote Request This fixed recessive bit is used only in extended format. It must be set to 1 by the user for transmission buffers and will be stored as received on the CAN bus for receive buffers. IDE — ID Extended This flag indicates whether the extended or standard identifier format is applied in this buffer. In case of a receive buffer the flag is set as being received and indicates to the CPU how to process the buffer identifier registers. In case of a transmit buffer the flag indicates to the msCAN12 what type of identifier to send. 0 = Standard format (11-bit) 1 = Extended format (29-bit) Technical Data 348 MC68HC912DT128A — Rev 4.0 MSCAN Controller MOTOROLA MSCAN Controller Programmer’s Model of Message Storage RTR — Remote transmission request This flag reflects the status of the Remote Transmission Request bit in the CAN frame. In case of a receive buffer it indicates the status of the received frame and allows to support the transmission of an answering frame in software. In case of a transmit buffer this flag defines the setting of the RTR bit to be sent. 0 = Data frame 1 = Remote frame 18.12.3 Data Length Register (DLR) This register keeps the data length field of the CAN frame. DLC3 – DLC0 — Data length code bits The data length code contains the number of bytes (data byte count) of the respective message. At transmission of a remote frame, the data length code is transmitted as programmed while the number of transmitted bytes is always 0. The data byte count ranges from 0 to 8 for a data frame. Table 18-3 shows the effect of setting the DLC bits. Table 18-3. Data length codes Data length code DLC3 DLC2 DLC1 DLC0 0 0 0 0 0 0 0 0 1 0 0 0 0 1 1 1 1 0 0 0 1 1 0 0 1 1 0 0 1 0 1 0 1 0 1 0 MC68HC912DT128A — Rev 4.0 MOTOROLA Data byte count 0 1 2 3 4 5 6 7 8 Technical Data MSCAN Controller 349 MSCAN Controller 18.12.4 Data Segment Registers (DSRn) The eight data segment registers contain the data to be transmitted or being received. The number of bytes to be transmitted or being received is determined by the data length code in the corresponding DLR. 18.12.5 Transmit Buffer Priority Registers (TBPR) TBPR(1) R $01xD W RESET BIT 7 BIT 6 BIT 5 BIT 4 BIT 3 BIT 2 BIT 1 BIT 0 PRIO7 PRIO6 PRIO5 PRIO4 PRIO3 PRIO2 PRIO1 PRIO0 - - - - - - - - 1. x is 5, 6, or 7 depending on which buffer Tx0, Tx1, or Tx2 respectively. PRIO7 – PRIO0 — Local Priority This field defines the local priority of the associated message buffer. The local priority is used for the internal prioritizing process of the msCAN12 and is defined to be highest for the smallest binary number. The msCAN12 implements the following internal priorization mechanism: NOTE: • All transmission buffers with a cleared TXE flag participate in the priorisation right before the SOF (Start of Frame) is sent. • The transmission buffer with the lowest local priority field wins the priorisation. • In case of more than one buffer having the same lowest priority the message buffer with the lower index number wins. To ensure data integrity, no registers of the transmit buffers shall be written while the associated TXE flag is cleared. To ensure data integrity, no registers of the receive buffer shall be read while the RXF flag is cleared. Technical Data 350 MC68HC912DT128A — Rev 4.0 MSCAN Controller MOTOROLA MSCAN Controller Programmer’s Model of Control Registers 18.13 Programmer’s Model of Control Registers 18.13.1 Overview The programmer’s model has been laid out for maximum simplicity and efficiency. 18.13.2 msCAN12 Module Control Register (CMCR0) CMCR0 R $0100 W RESET Bit 7 0 6 0 0 0 5 CSWAI 1 4 SYNCH 3 TLNKEN 0 0 2 SLPAK 0 1 Bit 0 SLPRQ SFTRES 0 1 CSWAI — CAN Stops in Wait Mode 0 = The module is not affected during WAIT mode. 1 = The module ceases to be clocked during WAIT mode. SYNCH — Synchronized Status This bit indicates whether the msCAN12 is synchronized to the CAN bus and as such can participate in the communication process. 0 = msCAN12 is not synchronized to the CAN bus 1 = msCAN12 is synchronized to the CAN bus TLNKEN — Timer Enable This flag is used to establish a link between the msCAN12 and the onchip timer (see Timer Link). 0 = The port is connected to the timer input. 1 = The msCAN12 timer signal output is connected to the timer input. SLPAK — SLEEP Mode Acknowledge This flag indicates whether the msCAN12 is in module internal SLEEP Mode. It shall be used as a handshake for the SLEEP Mode request (see msCAN12 SLEEP Mode). 0 = Wake-up – The msCAN12 is not in SLEEP Mode. 1 = SLEEP – The msCAN12 is in SLEEP Mode. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data MSCAN Controller 351 MSCAN Controller SLPRQ — SLEEP request This flag allows to request the msCAN12 to go into an internal powersaving mode (see msCAN12 SLEEP Mode). 0 = Wake-up – The msCAN12 will function normally. 1 = SLEEP request – The msCAN12 will go into SLEEP Mode when the CAN bus is idle, i.e. the module is not receiving a message and all transmit buffers are empty. SFTRES— SOFT_RESET When this bit is set by the CPU, the msCAN12 immediately enters the SOFT_RESET state. Any ongoing transmission or reception is aborted and synchronization to the bus is lost. The following registers will go into and stay in the same state as out of hard reset: CMCR0, CRFLG, CRIER, CTFLG, CTCR. The registers CMCR1, CBTR0, CBTR1, CIDAC, CIDAR0–3, CIDMR0–3 can only be written by the CPU when the msCAN12 is in SOFT_RESET state. The values of the error counters are not affected by SOFT_RESET. When this bit is cleared by the CPU, the msCAN12 will try to synchronize to the CAN bus: If the msCAN12 is not in BUSOFF state it will be synchronized after 11 recessive bits on the bus; if the msCAN12 is in BUSOFF state it continues to wait for 128 occurrences of 11 recessive bits. Clearing SFTRES and writing to other bits in CMCR0 must be in separate instructions. 0 = Normal operation 1 = msCAN12 in SOFT_RESET state. Technical Data 352 MC68HC912DT128A — Rev 4.0 MSCAN Controller MOTOROLA MSCAN Controller Programmer’s Model of Control Registers 18.13.3 msCAN12 Module Control Register (CMCR1) CMCR1 R $0101 W RESET Bit 7 0 6 0 5 0 4 0 3 0 0 0 0 0 0 2 1 Bit 0 LOOPB WUPM CLKSRC 0 0 0 LOOPB — Loop Back Self Test Mode When this bit is set the msCAN12 performs an internal loop back which can be used for self test operation: the bit stream output of the transmitter is fed back to the receiver. The RxCAN input pin is ignored and the TxCAN output goes to the recessive state (1). Note that in this state the msCAN12 ignores the bit sent during the ACK slot of the CAN frame Acknowledge field to insure proper reception of its own message and will treat messages being received while in transmission as received messages from remote nodes. 0 = Normal operation 1 = Activate loop back self test mode WUPM — Wake-Up Mode This flag defines whether the integrated low-pass filter is applied to protect the msCAN12 from spurious wake-ups (see Programmable Wake-Up Function). 0 = msCAN12 will wake up the CPU after any recessive to dominant edge on the CAN bus. 1 = msCAN12 will wake up the CPU only in case of dominant pulse on the bus which has a length of at least approximately Twup. CLKSRC — msCAN12 Clock Source This flag defines which clock source the msCAN12 module is driven from (only for system with CGM module; see Clock System, Figure 18-7). 0 = The msCAN12 clock source is EXTALi. 1 = The msCAN12 clock source is SYSCLK, twice the frequency of ECLK. NOTE: The CMCR1 register can only be written if the SFTRES bit in CMCR0 is set. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data MSCAN Controller 353 MSCAN Controller 18.13.4 msCAN12 Bus Timing Register 0 (CBTR0) CBTR0 R $0102 W RESET Bit 7 6 5 4 3 2 1 Bit 0 SJW1 SJW0 BRP5 BRP4 BRP3 BRP2 BRP1 BRP0 0 0 0 0 0 0 0 0 SJW1, SJW0 — Synchronization Jump Width The synchronization jump width defines the maximum number of time quanta (Tq) clock cycles by which a bit may be shortened, or lengthened, to achieve resynchronization on data transitions on the bus (see Table 18-4). Table 18-4. Synchronization jump width SJW1 0 0 1 1 SJW0 0 1 0 1 Synchronization jump width 1 Tq clock cycle 2 Tq clock cycles 3 Tq clock cycles 4 Tq clock cycles BRP5 – BRP0 — Baud Rate Prescaler These bits determine the time quanta (Tq) clock, which is used to build up the individual bit timing, according to Table 18-5. Table 18-5. Baud rate prescaler BRP5 0 0 0 0 : : 1 NOTE: BRP4 0 0 0 0 : : 1 BRP3 0 0 0 0 : : 1 BRP2 0 0 0 0 : : 1 BRP0 0 1 0 1 : : 1 Prescaler value (P) 1 2 3 4 : : 64 The CBTR0 register can only be written if the SFTRES bit in CMCR0 is set. Technical Data 354 BRP1 0 0 1 1 : : 1 MC68HC912DT128A — Rev 4.0 MSCAN Controller MOTOROLA MSCAN Controller Programmer’s Model of Control Registers 18.13.5 msCAN12 Bus Timing Register 1 (CBTR1) CBTR1 R $0103 W RESET Bit 7 6 5 4 3 2 1 Bit 0 SAMP TSEG22 TSEG21 TSEG20 TSEG13 TSEG12 TSEG11 TSEG10 0 0 0 0 0 0 0 0 SAMP — Sampling This bit determines the number of samples of the serial bus to be taken per bit time. If set three samples per bit are taken, the regular one (sample point) and two preceding samples, using a majority rule. For higher bit rates SAMP should be cleared, which means that only one sample will be taken per bit. 0 = One sample per bit. 1 = Three samples per bit(1). TSEG22 – TSEG10 — Time Segment Time segments within the bit time fix the number of clock cycles per bit time, and the location of the sample point. Table 18-6. Time segment syntax SYNC_SEG System expects transitions to occur on the bus during this period. A node in transmit mode will transfer a new value to the CAN bus at Transmit point this point. A node in receive mode will sample the bus at this point. If the three Sample point samples per bit option is selected then this point marks the position of the third sample. Time segment 1 (TSEG1) and time segment 2 (TSEG2) are programmable as shown in Table 18-7. Table 18-7. Time segment values TSEG13 TSEG12 TSEG11 TSEG10 Time segment 1 0 0 0 0 1 Tq clock cycle 0 0 0 1 2 Tq clock cycles 0 0 1 0 3 Tq clock cycles 0 0 1 1 4 Tq clock cycles . . . . . . . . . . 1 1 1 1 16 Tq clock cycles TSEG22 TSEG21 TSEG20 Time segment 2 0 0 0 1 Tq clock cycle 0 0 1 2 Tq clock cycles . . . . . . . . 1 1 1 8 Tq clock cycles 1. In this case PHASE_SEG1 must be at least 2 TimeQuanta. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data MSCAN Controller 355 MSCAN Controller The bit time is determined by the oscillator frequency, the baud rate prescaler, and the number of time quanta (Tq) clock cycles per bit (as shown above). NOTE: The CBTR1 register can only be written if the SFTRES bit in CMCR0 is set. 18.13.6 msCAN12 Receiver Flag Register (CRFLG) All bits of this register are read and clear only. A flag can be cleared by writing a 1 to the corresponding bit position. A flag can only be cleared when the condition which caused the setting is no more valid. Writing a 0 has no effect on the flag setting. Every flag has an associated interrupt enable flag in the CRIER register. A hard or soft reset will clear the register. CRFLG R $0104 W RESET Bit 7 6 5 4 3 2 1 Bit 0 WUPIF RWRNIF TWRNIF RERRIF TERRIF BOFFIF OVRIF RXF 0 0 0 0 0 0 0 0 WUPIF — Wake-up Interrupt Flag If the msCAN12 detects bus activity while it is in SLEEP Mode, it clears the SLPAK bit in the CMCR0 register; the WUPIF bit will then be set. If not masked, a Wake-Up interrupt is pending while this flag is set. 0 = No wake-up activity has been observed while in SLEEP Mode. 1 = msCAN12 has detected activity on the bus and requested wake-up. RWRNIF — Receiver Warning Interrupt Flag This bit will be set when the msCAN12 goes into warning status due to the Receive Error counter (REC) exceeding 96 and neither one of the Error interrupt flags or the Bus-Off interrupt flag is set(1). If not masked, an Error interrupt is pending while this flag is set. 0 = No receiver warning status has been reached. 1 = msCAN12 went into receiver warning status. 1. RWRNIF = (96 < REC) & RERRIF& TERRIF & BOFFIF Technical Data 356 MC68HC912DT128A — Rev 4.0 MSCAN Controller MOTOROLA MSCAN Controller Programmer’s Model of Control Registers TWRNIF — Transmitter Warning Interrupt Flag This bit will be set when the msCAN12 goes into warning status due to the Transmit Error counter (TEC) exceeding 96 and neither one of the Error interrupt flags or the Bus-Off interrupt flag is set(1). If not masked, an Error interrupt is pending while this flag is set. 0 = No transmitter warning status has been reached. 1 = msCAN12 went into transmitter warning status. RERRIF — Receiver Error Passive Interrupt Flag This bit will be set when the msCAN12 goes into error passive status due to the Receive Error counter (REC) exceeding 127 and the BusOff interrupt flag is not set(2). If not masked, an Error interrupt is pending while this flag is set. 0 = No receiver error passive status has been reached. 1 = msCAN12 went into receiver error passive status. TERRIF — Transmitter Error Passive Interrupt Flag This bit will be set when the msCAN12 goes into error passive status due to the Transmit Error counter (TEC) exceeding 127 and the BusOff interrupt flag is not set(3). If not masked, an Error interrupt is pending while this flag is set. 0 = No transmitter error passive status has been reached. 1 = msCAN12 went into transmitter error passive status. BOFFIF — BUSOFF Interrupt Flag This bit will be set when the msCAN12 goes into BUSOFF status, due to the Transmit Error counter exceeding 255. It cannot be cleared before the msCAN12 has monitored 128*11 consecutive recessive bits on the bus. If not masked, an Error interrupt is pending while this flag is set. 0 = No BUSOFF status has been reached. 1 = msCAN12 went into BUSOFF status. 1. TWRNIF = (96 < TEC) & RERRIF& TERRIF & BOFFIF 2. RERRIF = (128 < REC < 255) & BOFFIF 3. TERRIF = (128 < TEC < 255) & BOFFIF MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data MSCAN Controller 357 MSCAN Controller OVRIF — Overrun Interrupt Flag This bit will be set when a data overrun condition occurred. If not masked, an Error interrupt is pending while this flag is set. 0 = No data overrun has occurred. 1 = A data overrun has been detected. RXF — Receive Buffer Full The RXF flag is set by the msCAN12 when a new message is available in the foreground receive buffer. This flag indicates whether the buffer is loaded with a correctly received message. After the CPU has read that message from the receive buffer the RXF flag must be handshaked (cleared) in order to release the buffer. A set RXF flag prohibits the exchange of the background receive buffer into the foreground buffer. If not masked, a Receive interrupt is pending while this flag is set. 0 = The receive buffer is released (not full). 1 = The receive buffer is full. A new message is available. NOTE: The CRFLG register is held in the reset state if the SFTRES bit in CMCR0 is set. 18.13.7 msCAN12 Receiver Interrupt Enable Register (CRIER) CRIER R $0105 W RESET Bit 7 6 5 4 3 2 1 Bit 0 WUPIE RWRNIE TWRNIE RERRIE TERRIE BOFFIE OVRIE RXFIE 0 0 0 0 0 0 0 0 WUPIE — Wake-up Interrupt Enable 0 = No interrupt will be generated from this event. 1 = A wake-up event will result in a wake-up interrupt. RWRNIE — Receiver Warning Interrupt Enable 0 = No interrupt will be generated from this event. 1 = A receiver warning status event will result in an error interrupt. TWRNIE — Transmitter Warning Interrupt Enable 0 = No interrupt will be generated from this event. 1 = A transmitter warning status event will result in an error interrupt. Technical Data 358 MC68HC912DT128A — Rev 4.0 MSCAN Controller MOTOROLA MSCAN Controller Programmer’s Model of Control Registers RERRIE — Receiver Error Passive Interrupt Enable 0 = No interrupt will be generated from this event. 1 = A receiver error passive status event will result in an error interrupt. TERRIE — Transmitter Error Passive Interrupt Enable 0 = No interrupt will be generated from this event. 1 = A transmitter error passive status event will result in an error interrupt. BOFFIE — BUSOFF Interrupt Enable 0 = No interrupt will be generated from this event. 1 = A BUSOFF event will result in an error interrupt. OVRIE — Overrun Interrupt Enable 0 = No interrupt will be generated from this event. 1 = An overrun event will result in an error interrupt. RXFIE — Receiver Full Interrupt Enable 0 = No interrupt will be generated from this event. 1 = A receive buffer full (successful message reception) event will result in a receive interrupt. NOTE: The CRIER register is held in the reset state if the SFTRES bit in CMCR0 is set. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data MSCAN Controller 359 MSCAN Controller 18.13.8 msCAN12 Transmitter Flag Register (CTFLG) The Abort Acknowledge flags are read only. The Transmitter Buffer Empty flags are read and clear only. A flag can be cleared by writing a1 to the corresponding bit position. Writing a zero has no effect on the flag setting. The Transmitter Buffer Empty flags each have an associated interrupt enable flag in the CTCR register. A hard or soft reset will reset the register. CTFLG R $0106 W RESET Bit 7 0 6 ABTAK2 5 ABTAK1 4 ABTAK0 3 0 0 0 0 0 0 2 1 Bit 0 TXE2 TXE1 TXE0 1 1 1 ABTAK2 – ABTAK0 — Abort Acknowledge This flag acknowledges that a message has been aborted due to a pending abort request from the CPU. After a particular message buffer has been flagged empty, this flag can be used by the application software to identify whether the message has been aborted successfully or has been sent in the meantime. The flag is reset implicitly whenever the associated TXE flag is set to 0. 0 = The massage has not been aborted, thus has been sent out. 1 = The message has been aborted. TXE2 – TXE0 —Transmitter Buffer Empty This flag indicates that the associated transmit message buffer is empty, thus not scheduled for transmission. The CPU must handshake (clear) the flag after a message has been set up in the transmit buffer and is due for transmission. The msCAN12 will set the flag after the message has been sent successfully. The flag will also be set by the msCAN12 when the transmission request was successfully aborted due to a pending abort request (msCAN12 Transmitter Control Register (CTCR)). If not masked, a transmit interrupt is pending while this flag is set. Clearing this flag will also clear the corresponding Abort Acknowledge flag (ABTAK, see above). Setting this flag will clear the corresponding Abort Request flag (ABTRQ, msCAN12 Transmitter Control Register (CTCR)). Technical Data 360 MC68HC912DT128A — Rev 4.0 MSCAN Controller MOTOROLA MSCAN Controller Programmer’s Model of Control Registers 0 = The associated message buffer is full (loaded with a message due for transmission). 1 = The associated message buffer is empty (not scheduled). NOTE: The CTFLG register is held in the reset state if the SFTRES bit in CMCR0 is set. 18.13.9 msCAN12 Transmitter Control Register (CTCR) CTCR R $0107 W RESET Bit 7 0 6 5 4 ABTRQ2 ABTRQ1 ABTRQ0 0 0 0 0 3 0 0 2 1 Bit 0 TXEIE2 TXEIE1 TXEIE0 0 0 0 ABTRQ2 – ABTRQ0 — Abort Request The CPU sets this bit to request that an already scheduled message buffer (TXE = 0) shall be aborted. The msCAN12 will grant the request when the message is not already under transmission. When a message is aborted the associated TXE and the abort acknowledge flag (ABTAK, see msCAN12 Transmitter Flag Register (CTFLG)) will be set and an TXE interrupt will occur if enabled. The CPU can not reset ABTRQx. ABTRQx is reset implicitly whenever the associated TXE flag is set. 0 = No abort request. 1 = Abort request pending. NOTE: The software must not clear one or more of the TXE flags in CTFGL and simultaneously set the respective ABTRQ bit(s). TXEIE2 – TXEIE0 — Transmitter Empty Interrupt Enable 0 = No interrupt will be generated from this event. 1 = A transmitter empty (transmit buffer available for transmission) event will result in a transmitter empty interrupt. NOTE: The CTCR register is held in the reset state if the SFTRES bit in CMCR0 is set. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data MSCAN Controller 361 MSCAN Controller 18.13.10 msCAN12 Identifier Acceptance Control Register (CIDAC) CIDAC R $0108 W RESET Bit 7 0 6 0 0 0 5 4 IDAM1 IDAM0 0 0 3 0 2 IDHIT2 1 IDHIT1 Bit 0 IDHIT0 0 0 0 0 IDAM1 – IDAM0 — Identifier Acceptance Mode The CPU sets these flags to define the identifier acceptance filter organization (see Identifier Acceptance Filter). Table 18-7 summarizes the different settings. In Filter Closed mode no messages will be accepted such that the foreground buffer will never be reloaded. Table 18-8. Identifier Acceptance Mode Settings IDAM1 0 0 1 1 IDAM0 0 1 0 1 Identifier Acceptance Mode Two 32 bit Acceptance Filters Four 16 bit Acceptance Filters Eight 8 bit Acceptance Filters Filter Closed IDHIT2 – IDHIT0 — Identifier Acceptance Hit Indicator The msCAN12 sets these flags to indicate an identifier acceptance hit (see Identifier Acceptance Filter). Table 18-7 summarizes the different settings. Table 18-9. Identifier Acceptance Hit Indication IDHIT2 0 0 0 0 1 1 1 1 IDHIT1 0 0 1 1 0 0 1 1 IDHIT0 0 1 0 1 0 1 0 1 Identifier Acceptance Hit Filter 0 Hit Filter 1 Hit Filter 2 Hit Filter 3 Hit Filter 4 Hit Filter 5 Hit Filter 6 Hit Filter 7 Hit The IDHIT indicators are always related to the message in the foreground buffer. When a message gets copied from the background to the foreground buffer the indicators are updated as well. NOTE: The CIDAC register can only be written if the SFTRES bit in CMCR0 is set. Technical Data 362 MC68HC912DT128A — Rev 4.0 MSCAN Controller MOTOROLA MSCAN Controller Programmer’s Model of Control Registers 18.13.11 msCAN12 Receive Error Counter (CRXERR) CRXERR R $010E W RESET Bit 7 RXERR7 6 RXERR6 5 RXERR5 4 RXERR4 3 RXERR3 2 RXERR2 1 RXERR1 Bit 0 RXERR0 0 0 0 0 0 0 0 0 This register reflects the status of the msCAN12 receive error counter. The register is read only. 18.13.12 msCAN12 Transmit Error Counter (CTXERR) CTXERR R $010F W RESET Bit 7 TXERR7 6 TXERR6 5 TXERR5 4 TXERR4 3 TXERR3 2 TXERR2 1 TXERR1 Bit 0 TXERR0 0 0 0 0 0 0 0 0 This register reflects the status of the msCAN12 transmit error counter. The register is read only. NOTE: Both error counters must only be read when in SLEEP or SOFT_RESET mode. 18.13.13 msCAN12 Identifier Acceptance Registers (CIDAR0–7) On reception each message is written into the background receive buffer. The CPU is only signalled to read the message however, if it passes the criteria in the identifier acceptance and identifier mask registers (accepted); otherwise, the message will be overwritten by the next message (dropped). The acceptance registers of the msCAN12 are applied on the IDR0 to IDR3 registers of incoming messages in a bit by bit manner. For extended identifiers all four acceptance and mask registers are applied. For standard identifiers only the first two (CIDMR0/1 and CIDAR0/1) are applied. In the latter case it is required to program the three last bits (AM2 – AM0) in the mask register CIDMR1 to ‘don’t care’. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data MSCAN Controller 363 MSCAN Controller Figure 18-14. Identifier Acceptance Registers (1st bank) CIDAR0 $0110 CIDAR1 $0111 CIDAR2 $0112 CIDAR3 $0113 RESET R W R W R W R W Bit 7 6 5 4 3 2 1 Bit 0 AC7 AC6 AC5 AC4 AC3 AC2 AC1 AC0 AC7 AC6 AC5 AC4 AC3 AC2 AC1 AC0 AC7 AC6 AC5 AC4 AC3 AC2 AC1 AC0 AC7 AC6 AC5 AC4 AC3 AC2 AC1 AC0 - - - - - - - - Figure 18-15. Identifier Acceptance Registers (2nd bank) CIDAR4 $0118 CIDAR5 $0119 CIDAR6 $011A CIDAR7 $011B RESET R W R W R W R W Bit 7 6 5 4 3 2 1 Bit 0 AC7 AC6 AC5 AC4 AC3 AC2 AC1 AC0 AC7 AC6 AC5 AC4 AC3 AC2 AC1 AC0 AC7 AC6 AC5 AC4 AC3 AC2 AC1 AC0 AC7 AC6 AC5 AC4 AC3 AC2 AC1 AC0 - - - - - - - - AC7 – AC0 — Acceptance Code Bits AC7 – AC0 comprise a user defined sequence of bits with which the corresponding bits of the related identifier register (IDRn) of the receive message buffer are compared. The result of this comparison is then masked with the corresponding identifier mask register. NOTE: The CIDAR0–7 registers can only be written if the SFTRES bit in CMCR0 is set. Technical Data 364 MC68HC912DT128A — Rev 4.0 MSCAN Controller MOTOROLA MSCAN Controller Programmer’s Model of Control Registers 18.13.14 msCAN12 Identifier Mask Registers (CIDMR0–7) The identifier mask register specifies which of the corresponding bits in the identifier acceptance register are relevant for acceptance filtering. Figure 18-16. Identifier Mask Registers (1st bank) CIDMR0 $0114 CIDMR1 $0115 CIDMR2 $0116 CIDMR3 $0117 RESET R W R W R W R W Bit 7 6 5 4 3 2 1 Bit 0 AM7 AM6 AM5 AM4 AM3 AM2 AM1 AM0 AM7 AM6 AM5 AM4 AM3 AM2 AM1 AM0 AM7 AM6 AM5 AM4 AM3 AM2 AM1 AM0 AM7 AM6 AM5 AM4 AM3 AM2 AM1 AM0 - - - - - - - - Figure 18-17. Identifier Mask Registers (2nd bank) CIDMR4 $011C CIDMR5 $011D CIDMR6 $011E CIDMR7 $011F RESET R W R W R W R W Bit 7 6 5 4 3 2 1 Bit 0 AM7 AM6 AM5 AM4 AM3 AM2 AM1 AM0 AM7 AM6 AM5 AM4 AM3 AM2 AM1 AM0 AM7 AM6 AM5 AM4 AM3 AM2 AM1 AM0 AM7 AM6 AM5 AM4 AM3 AM2 AM1 AM0 - - - - - - - - AM7 – AM0 — Acceptance Mask Bits If a particular bit in this register is cleared this indicates that the corresponding bit in the identifier acceptance register must be the same as its identifier bit, before a match will be detected. The message will be accepted if all such bits match. If a bit is set, it indicates that the state of the corresponding bit in the identifier acceptance register will not affect whether or not the message is accepted. 0 = Match corresponding acceptance code register and identifier bits. 1 = Ignore corresponding acceptance code register bit. NOTE: The CIDMR0–7 registers can only be written if the SFTRES bit in CMCR0 is set. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data MSCAN Controller 365 MSCAN Controller 18.13.15 msCAN12 Port CAN Control Register (PCTLCAN) PCTLCAN R $013D W RESET Bit 7 0 6 0 5 0 4 0 3 0 2 0 0 0 0 0 0 0 1 Bit 0 PUPCAN RDPCAN 0 0 The following bits control pins 7 through 2 of Port CAN when they are implemented externally. PUPCAN — Pull-Up Enable Port CAN 0 = Pull mode disabled for Port CAN. 1 = Pull mode enabled for Port CAN. RDPCAN — Reduced Drive Port CAN 0 = Reduced drive disabled for Port CAN. 1 = Reduced drive enabled for Port CAN. 18.13.16 msCAN12 Port CAN Data Register (PORTCAN) PORTCAN $013E RESET R W Bit 7 6 5 4 3 2 PCAN7 PCAN6 PCAN5 PCAN4 PCAN3 PCAN2 - - - 1 TxCAN Bit 0 RxCAN - - Port bits 7 to 2 will read zero when configured as inputs because they are not implemented externally. When configured as output, port bits 7 to 2 will read the last value written. Reading bits 1 and 0 returns the value of the TxCan and RxCan pins, respectively. 18.13.17 msCAN12 Port CAN Data Direction Register (DDRCAN) DDRCAN R $013F W RESET Bit 7 6 5 4 3 2 DDCAN7 DDCAN6 DDCAN5 DDCAN4 DDCAN3 DDCAN2 0 0 0 0 0 0 1 0 Bit 0 0 0 0 DDCAN7 – DDCAN2 — This bits served as memory locations since there are no corresponding external port pins. Technical Data 366 MC68HC912DT128A — Rev 4.0 MSCAN Controller MOTOROLA Technical Data — MC68HC912DT128A Section 19. Analog-to-Digital Converter 19.1 Contents 19.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 367 19.3 Modes of Operation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .369 19.4 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .370 19.5 ATD Operational Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . .372 19.6 ATD Operation In Different MCU Modes . . . . . . . . . . . . . . . . 373 19.7 General Purpose Digital Input Port Operation . . . . . . . . . . . .375 19.8 Application Considerations . . . . . . . . . . . . . . . . . . . . . . . . . . .376 19.9 ATD Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 376 19.2 Introduction The MC68HC912DT128A has two identical ATD modules identified as ATD0 and ATD1. Except for the VDDA and VSSA Analog supply voltage, all pins are duplicated and indexed with ‘0’ or ‘1’ in the following description. An ‘x’ indicates either ‘0’ or ‘1’. The ATD module is an 8-channel, 10-bit or 8-bit, multiplexed-input, successive-approximation analog-to-digital converter. It does not require external sample and hold circuits because of the type of charge redistribution technique used. The ATD converter timing can be synchronized to the system PCLK. The ATD module consists of a 16word (32-byte) memory-mapped control register block used for control, testing and configuration. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Analog-to-Digital Converter 367 Analog-to-Digital Converter 19.2.1 Features • 8/10 Bit Resolution • 10 µs, 10-Bit Single Conversion Time • Sample and Transfer Buffer Amplifier • Programmable Sample Time • Left/Right Justified Result Data • Conversion Completion Interrupt • Analog Input Multiplexer for 8 Analog Input Channels • Analog/Digital Input Pin Multiplexing • 1, 4, 8 Conversion Sequence Lengths • Continuous Conversion Mode • Multiple Channel Scans VRHx RC DAC ARRAY AND COMPARATOR VRLx REFERENCE MODE AND TIMING CONTROLS VDDA SUPPLY VSSA SAR ATD 0 ANALOG MUX AND SAMPLE BUFFER AMP ATD 1 ATD 2 ATD 3 ATD 4 ANx7/PADx7 ANx6/PADx6 ANx5/PADx5 ANx4/PADx4 ANx3/PADx3 ANx2/PADx2 ANx1/PADx1 ANx0/PADx0 PORT AD DATA INPUT REGISTER ATD 5 ATD 6 ATD 7 CLOCK SELECT/PRESCALE INTERNAL BUS HC12 ATD BLOCK Figure 19-1. Analog-to-Digital Converter Block Diagram Technical Data 368 MC68HC912DT128A — Rev 4.0 Analog-to-Digital Converter MOTOROLA Analog-to-Digital Converter Modes of Operation 19.3 Modes of Operation Analog to digital conversions are performed in a variety of different programmable sequences referred to as conversion modes. Each conversion mode is defined by: • How many A/D conversions (one, four or eight) are performed in a sequence • Which analog input channels are examined during a sequence • The sample time length • Whether sequences are performed continuously or not • Result register assignments The modes are defined by the settings of three control bits (in ATDCTL5) • MULT controls whether the sequence examines a single analog input channel or scans a number of different channels • SCAN determines if sequences are performed continuously • SC determines if we are performing a special conversion i.e. converting VRL, VRH, (VRL+VRH)/2 (usually used for test purposes). and three control values • CC/CB/CA (in ATDCTL5) define the input channel(s) to be examined • S8C/S1C (in ATDCTL3/5) define the number of conversions in a sequence • SMP0/SMP1 (in ATDCTL4) define the length of the sample time. Sequences are initiated or halted by writing to control registers ATDCTL4 and ATDCTL5. For the continuous sequence modes, conversions will not stop until • Another non-continuous conversion sequence is initiated and finishes • The ATD is powered down (ADPU control bit) • The ATD is reset MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Analog-to-Digital Converter 369 Analog-to-Digital Converter • WAIT is executed (if the ASWAI bit is activated) • STOP is executed. The MCU can discover when result data is available in the result registers with an interrupt on sequence complete or by polling the conversion complete flags NOTE: • The SCF bit is set after the completion of each sequence. • The CCF bit associated with each result register is set when that register is loaded with result data. ATD conversion modes should not be confused with MCU operating modes such as STOP, WAIT, IDLE, RUN, DEBUG, and SPECIAL (test) modes or with module defined operating modes such as power down, fast flag clear, 8-bit resolution, 10-bit resolution, interrupt enable, clock prescaler setting, and freeze modes; and finally do not confuse with module result data formats such as right justify mode and left justify mode. 19.4 Functional Description 19.4.1 Analog Input Multiplexer The analog input multiplexer selects one of the 8 external analog input channels to generate an analog sample. The input analog signals are unipolar and must fall within the potential range of VSSA to VDDA (analog electronics supply potentials). 19.4.2 Sample Buffer Amplifier A sample amplifier is used to buffer the input analog signal so that a storage node can be quickly charged to the sample potential. Technical Data 370 MC68HC912DT128A — Rev 4.0 Analog-to-Digital Converter MOTOROLA Analog-to-Digital Converter Functional Description 19.4.3 Sample and Hold Stage A Sample and Hold (S/H) stage accepts the analog signal from the input multiplexer and stores it as a capacitor charge on a storage node in the module. The sample process uses a three stage approach: 1. The input signal is sampled onto a sample capacitor (for 2 module clocks). 2. The sample amplifier quickly charges the storage node with a copy of the sample capacitor potential (for 4 module clocks). 3. The input signal is connected directly to the storage node to complete the sample for high accuracy (for 2, 4, 8 or 16 module clocks). Longer sample times allow accurate measurement of higher impedance sources. This charge redistribution method eliminates the need for external sample-and-hold circuitry. 19.4.4 Analog-to-Digital Converter Submodule The Analog-to-Digital (A/D) Machine uses a successive approximation A/D architecture to perform analog to digital conversions. The resolution of the A/D converter is selectable at either 8 or 10 bits. It functions by comparing the stored analog sample potential with a series of digitally generated analog potentials (using CDAC & RDAC arrays). By following a binary search algorithm, the converter quickly locates the approximating potential that is nearest to the sampled potential. At the end of the conversion process (10 module clocks for 8-bit, 12 module clocks for 10-bit), the Successive Approximation Register (SAR) contains the nearest approximation to the sampled signal, given the resolution of the A/D converter, and is transferred to the appropriate results register in the selected format. 19.4.5 Clock Prescaler Function To keep the ATD module clock within the specified frequency range (note: there is a minimum and maximum frequency), a clock prescaler function is available. This function divides the system PCLK by a MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Analog-to-Digital Converter 371 Analog-to-Digital Converter programmable constant in order to generate the ATD module’s internal clock. One additional benefit of the prescaled clock feature is that it allows the user further control over the sample period (note that changing the module clock also affects conversion time). The prescaler is based on a 5 bit modulus counter and divides the PCLK by an integer value between 1 and 32. The final clock frequency is obtained with a further division by 2. The internal ATD module clock and the system PCLK have a direct phase relationship, however the ATD module operates as if it is effectively asynchronous to MCU bus clock cycles. 19.5 ATD Operational Modes 19.5.1 Power Down Mode The ATD module can be powered down under program control. This is done by turning the clock signals off to the digital electronics of the module and eliminating the quiescent current draw of the analog electronics. Power down control is implemented in one of three ways. 1. Using the ADPU bit in control register ATDCTL2. 2. When STOP instruction is executed, the module will power down for the duration of the STOP function. 3. If the module WAIT enable bit (ASWAI) is set and a WAIT instruction is executed, the module will power down for the duration of the WAIT function. Note that the reset default for the ADPU bit is zero. Therefore, when this module is reset, it is reset into the power down state. Once the command to power down has been received, the ATD module aborts any conversion sequence in progress and enters lower power mode. When the module is powered up again, the bias settings in the analog electronics must be given time to stabilize before conversions Technical Data 372 MC68HC912DT128A — Rev 4.0 Analog-to-Digital Converter MOTOROLA Analog-to-Digital Converter ATD Operation In Different MCU Modes can be performed. Note that powering up the module does not reset the module since the register file is not initialized. In power down mode, the control and result registers are still accessible. 19.5.2 IDLE Mode IDLE mode for the ATD module is defined as the state where the ATD module is powered up and ready to perform an A/D conversion, but not actually performing a conversion at the present time. Access to all control, status, and result registers is available. The module is consuming near maximum power. NOTE: When not active, the sample-and-hold and analog-to-digital submodules disable the clocks at their inputs to conserve power. The analog electronics still draw quiescent current. 19.5.3 RUN Mode RUN mode for the ATD module is defined as the state where the ATD module is powered up and currently performing an A/D conversion. Complete assess to all control, status and result registers is available. The module is consuming maximum power. 19.6 ATD Operation In Different MCU Modes 19.6.1 STOP Mode Asserting Stop causes the ATD module to power down. The digital clocks are disabled and the analog quiescent current draw is turned off; this places the module into its power down state and is equivalent to clearing the ADPU control bit in ATDCTL2. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Analog-to-Digital Converter 373 Analog-to-Digital Converter 19.6.2 WAIT Mode If the ASWAI control bit in ATDCTL2 is set, then the ATD responds to WAIT mode. If the ASWAI control bit is clear, then the ATD ignores the WAIT signal. The ATD response to the wait mode is to power down the module. In this mode, the MCU does not have access to the control, status or result registers. 19.6.3 Background Debug (ATD FREEZE) Mode When debugging an application, it is useful to have the ATD pause when a breakpoint is encountered. To accommodate this, there are two FREEZE bits in the ATDCTL3 register used to select one of three responses: 1. The ATD module may ignore the freeze request. 2. It may respond to the freeze request by finishing the current conversion and ‘freezing’ before starting the next sample period. 3. It may respond by immediately ‘freezing’. Control and timing logic is static allowing the register contents and timing position to be remembered indefinitely. The analog electronics remains powered up; however, internal leakage may compromise the accuracy of a frozen conversion depending on the length of the freeze period. When the BDM signal is negated clock activity resumes. Access to the ATD register file is possible during the ‘frozen’ period. 19.6.4 Module Reset The ATD module is reset on two different events. 1. In the case of a system reset. 2. If the RST bit in the ATDTEST register is activated. The single difference between the two events is that the RST bit event does not reset the ADPU bit to its reset state value - i.e. the module is not reset into a powered down state and will be returned to an idle state. Technical Data 374 MC68HC912DT128A — Rev 4.0 Analog-to-Digital Converter MOTOROLA Analog-to-Digital Converter General Purpose Digital Input Port Operation The ATD module reset function places the module back into an initialized state. If the module is performing a conversion sequence, both the current conversion and the sequence are terminated. The conversion complete flags are cleared and any pending interrupts are cancelled. Note that the control, test, and status registers are initialized on reset; the initialized register state is defined in the register description section of this specification. Note that when the module powers up via a WAIT signal that the ATD is not reset; ATD operation proceeds as it was prior to entering the wait. Freezing the module does not cause it to be reset. If a freeze mode is entered and defines that the current conversion be terminated, then this is done and the module will be idle after exiting the freeze state, but the module is not initialized. Powering the module up (using the ADPU bit) does not cause the module to reset since the register file is not initialized. Finally, writing to control register ATDCTL4/5 does not cause the module to be reset; the current conversion and sequence will be terminated and new ones started; the conversion complete flags and pending interrupts will be cleared. This is a restart operation rather than a reset operation because the register file is not reinitialized. 19.7 General Purpose Digital Input Port Operation There is one digital, 8-bit, input-only port associated with the ATD module. It is accessed through the 8-bit Port Data Register (PORTADx). Since the port pins are used only as inputs, in normal operating modes, no data direction register is available for this port. The input channel pins can be used to read analog and digital data. As analog inputs, they are multiplexed and sampled to supply signals to the A/D converter. As digital inputs, they supply input data buffers that can be accessed through the digital port registers. Analog signals present on the input pins at the digital sampling time that don’t meet the VIL or VIH specification will return unknown digital values. A read of PORTADx may affect the accuracy of an in progress sample period but will not affect an in progress A/D conversion. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Analog-to-Digital Converter 375 Analog-to-Digital Converter 19.8 Application Considerations Note that the A/D converter’s accuracy is limited by the accuracy of the reference potentials. Noise on the reference potentials will result in noise on the digital output data stream: the reference potential lines do not reject reference noise. The reference potential pins must have a low AC impedance path back to the source. A large bypass capacitor (100nF or larger) will suffice in most cases. In extreme cases, inductors and/or ferrite beads may be necessary if high frequency noise is present. Series resistance is not advisable since the ATD module draws current from the reference. A potential drop across any series resistance would result in gain and offset errors in the digital data output stream unless the reference potential was sensed at the reference input pin and any potential drop compensated for. For best performance, the analog inputs should have a low AC impedance at the input pins to shunt noise current coupled onto the input node away from the A/D input. This can be accomplished by placing a capacitor with good high frequency characteristics between the input pin and VSSA. The size of this capacitor is application dependent; larger capacitors will lower the AC impedance and be more effective at shunting away noise current. However, the input analog signal has its own dynamic characteristics which the A/D converter is being used to track. These, along with the source impedance of the signal driver, must also be considered when choosing the capacitor size to avoid rolling off any high frequency components of interest. If the input signal contains excessive high frequency conducted noise, then a series resistance may be used with the capacitor to generate a one pole, low pass anti-aliasing filter. 19.9 ATD Registers Control and data registers for the ATD modules are described below. Both ATDs have identical control registers mapped in two blocks of 16 bytes. Technical Data 376 MC68HC912DT128A — Rev 4.0 Analog-to-Digital Converter MOTOROLA Analog-to-Digital Converter ATD Registers 19.9.1 ATD Control Registers 0 &1 (ATDCTL0, ATDCTL1) ATD0CTL0/ATD1CTL0 — Reserved RESET: $0060/$01E0 Bit 7 6 5 4 3 2 1 Bit 0 0 0 0 0 0 0 0 0 Writes to this register will abort current conversion sequence. Read or write any time. ATD0CTL1/ATD1CTL1 — Reserved RESET: $0061/$01E1 Bit 7 6 5 4 3 2 1 Bit 0 0 0 0 0 0 0 0 0 WRITE: Write to this register has no meaning. READ: Special Mode only. 19.9.2 ATD Control Registers 2 & 3 (ATDCTL2, ATDCTL3) The ATD control registers 2 & 3 are used to select the power up mode, fast flag clear mode, wait mode, 16 channel mode, interrupt control, and freeze control. Writes to these registers will not abort the current conversion sequence nor start a new sequence. ATD0CTL2/ATD1CTL2 — ATD Control Register 2 RESET: Bit 7 ADPU 0 6 AFFC 0 5 ASWAI 0 4 DJM 0 $0062/$01E2 3 Reserved 0 2 Reserved 0 1 ASCIE 0 Bit 0 ASCIF 0 READ: any time WRITE: any time (except for Bit 0 – ASCIF, READ: any time, WRITE: not allowed) ADPU — ATD Disable / Power Down 0 = Disable and power down the ATD 1 = Normal ATD functionality MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Analog-to-Digital Converter 377 Analog-to-Digital Converter This bit provides program on/off control over the ATD module allowing reduced MCU power consumption when the ATD is not being used. When reset to zero, the ADPU bit aborts any conversion sequence in progress. Because the analog electronics is turned off when powered down, the ATD requires a recovery time period when ADPU bit is enabled. AFFC — ATD Fast Conversion Complete Flag Clear 0 = ATD flag clearing operates normally (read the status register before reading the result register to clear the associated CCF bit). 1 = Changes all ATD conversion complete flags to a fast clear sequence. Any access to a result register (ATD0–7) will cause the associated CCF flag to clear automatically if it was set at the time. Operating normally means that the status register must be read after the conversion complete flag has been set before that flag can be reset. After the status register read, a read to the associated result register causes its conversion complete flag in the status register to be cleared. The SCF flag is cleared when a new conversion sequence is begun by writing to control register ATDCTL4/5. In applications where the ATD module is polled to determine if an ATD conversion is complete, this feature provides a convenient way of clearing the status register conversion complete flag. In applications where ATD interrupts are used to signal conversion completion, the precondition of reading the status register can be eliminated using fast conversion complete flag clear mode. In this mode, any access to a result register will cause its associated conversion complete flag in the status register to be cleared. The SCF flag is cleared after the first (any) result register is read. ASWAI — ATD Stop In Wait Mode 0 = ATD continues to run when the MCU is in wait mode 1 = ATD stops to save power when the MCU is in wait mode The wait function allows the MCU to selectively halt and power down the ATD module. If the ASWAI bit is set and the MCU, then the ATD module immediately halts operation and powers down. When WAIT is Technical Data 378 MC68HC912DT128A — Rev 4.0 Analog-to-Digital Converter MOTOROLA Analog-to-Digital Converter ATD Registers exited, the ATD module powers up and continues operation. The module is not reset; the register file is not reinitialized; the conversion sequence is not restarted. When the module comes out of wait, it is recommended that a stabilization delay ( tSR) is allowed before new conversions are started. DJM — Result Register Data Justification Mode 0 = Left justified mode 1 = Right justified mode For 10-bit resolution, left justified mode maps a result register into data bus bits 6 through 15; bit 15 is the MSB. In right justified mode, the result registers maps onto data bus bits 0 through 9; bit 9 is the MSB. For 8-bit resolution, left justified mode maps a result into the high byte (bits 8 though 15; bit 15 is the MSB). Right justified maps a result into the low byte (bits 0 through 7; bit 7 is the MSB). Table 19-1 summarizes the result data formats available and how they are set up using the control bits. Table 19-2 illustrates left justified output codes for an input signal range between 0 and 5.1 Volts. RES10 DJM 0 0 1 1 0 1 0 1 Result Data Formats Description and Bus Bit Mapping 8-bit/left justified - bits 8-15 8-bit/right justified - bits 0-7 10-bit/left justified - bits 6-15 10-bit/right justified - bits 0-9 Table 19-1. Result Data Formats Available MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Analog-to-Digital Converter 379 Analog-to-Digital Converter Input Signal Vrl = 0 Volts Vrh = 5.12 Volts 5.120 Volts 5.100 5.080 8-Bit Codes 10-Bit Codes FF FF FE FFC0 FF00 FE00 2.580 2.560 2.540 81 80 7F 8100 8000 7F00 0.020 0.000 01 00 0100 0000 Table 19-2. Left Justified ATD Output Codes ASCIE — ATD Sequence Complete Interrupt Enable 0 = Disables ATD interrupt 1 = Enables ATD interrupt on Sequence Complete The sequence complete interrupt function signals the MCU when a conversion sequence is complete. At this time, the result registers contain the result data generated by the conversion sequence. If this interrupt function is disabled, then the conversion complete flags must be polled to determine when a conversion or a conversion sequence is complete. Note that reset clears pending interrupts. ASCIF — ATD Sequence Complete Interrupt Flag 0 = No ATD sequence complete interrupt occurred 1 = ATD sequence complete interrupt occurred The sequence complete interrupt flag. This flag is not cleared until the interrupt is serviced (by reading the result data in such a way that the conversion complete flag is cleared), a new conversion sequence is initiated, or the module is reset. This bit is not writable in any mode. Technical Data 380 MC68HC912DT128A — Rev 4.0 Analog-to-Digital Converter MOTOROLA Analog-to-Digital Converter ATD Registers ATD0CTL3/ATD1CTL3 — ATD Control Register 3 RESET: Bit 7 0 0 6 0 0 5 0 0 $0063/$01E3 4 0 0 3 S1C 0 2 FIFO 0 1 FRZ1 0 Bit 0 FRZ0 0 READ: any time WRITE: any time S1C — Conversion Sequence Length (Least Significant Bit) This control bit works with control bit S8C in ATDCTL5 in determining how many conversion are performed per sequence. When the S1C bit is set, a sequence length of 1 is defined. However, if the S8C bit is also set, the S8C bit takes precedence. For sequence length coding information see the description for S8C bit in ATDCTL5. FIFO — Result Register FIFO Mode 0 = Result registers maps to the conversion sequence 1 = Result registers do not map to the conversion sequence In normal operation, the A/D conversion results map into the result registers based on the conversion sequence; the result of the first conversion appears in the first result register, the second result in the second result register, and so on. In FIFO mode the result register counter is not reset at the beginning or ending of a conversion sequence; conversion results are placed in consecutive result registers between sequences. The result register counter wraps around when it reaches the end of the result register file. The conversion counter value in ATDSTAT0 can be used to determine where in the result register file, the next conversion result will be placed. The results register counter is initialized to zero on three events: on reset, the beginning of a normal (non-FIFO) conversion sequence, and the end of a normal (non-FIFO) conversion sequence. Therefore, the reset bit in register ATDTEST1 can be toggled to zero the result register counter; any sequence allowed to complete normally will zero the result register counter; a new sequence (non-FIFO) initiated with a write to ATDCTL4/5 followed by a write to ATDCTL3 to set the FIFO bit will start a FIFO sequence with the result register initialized. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Analog-to-Digital Converter 381 Analog-to-Digital Converter Finally, which result registers hold valid data can be tracked using the conversion complete flags. Fast flag clear mode may or may not be useful in a particular application to track valid data. FRZ1, FRZ0 — Background Debug Freeze Enable Background debug freeze function allows the ATD module to pause when a breakpoint is encountered. Table 19-3 shows how FRZ1 and FRZ0 determine the ATD’s response to a breakpoint. When BDM is deasserted, the ATD module continues operating as it was before the breakpoint occurred. Table 19-3. ATD Response to Background Debug Enable FRZ1 0 0 1 1 FRZ0 0 1 0 1 ATD Response Continue conversions in active background mode Reserved Finish current conversion, then freeze Freeze when BDM is active 19.9.3 ATDCTL4 ATD Control Register 4 ATD control register 4 is used to select the internal ATD clock frequency (based on the system clock), select the length of the third phase of the sample period, and set the resolution of the A/D conversion (i.e. 8-bits or 10-bits). All writes to this register have an immediate effect. If a conversion is in progress, the entire conversion sequence is aborted. A write to this register (or ATDCTL5) initiates a new conversion sequence. ATD0CTL4/ATD1CTL4 — ATD Control Register 4 RESET: Bit 7 RES10 0 6 SMP1 0 5 SMP0 0 4 PRS4 0 $0064/$01E4 3 PRS3 0 Technical Data 382 2 PRS2 0 1 PRS1 0 Bit 0 PRS0 1 MC68HC912DT128A — Rev 4.0 Analog-to-Digital Converter MOTOROLA Analog-to-Digital Converter ATD Registers RES10 — A/D Resolution Select 0 = 8-bit resolution selected 1 = 10-bit resolution selected This bit determines the resolution of the A/D converter: 8-bits or 10bits. The A/D converter has the accuracy of a 10-bit converter. However, if low resolution is adequate, the conversion can be speeded up by selecting 8-bit resolution. SMP[1:0] — Sample Time Select These two bits select the length of the third phase of the sample period (in internal ATD clock cycles) which occurs after the buffered sample and transfer. During this phase, the external analog signal is connected directly to the storage node for final charging and improved accuracy. Note that the ATD clock period is itself a function of the prescaler value (bits PRS0–4). Table 19-4 lists the lengths available for the third sample phase. Table 19-4. Final Sample Time Selection SMP1 0 0 1 1 SMP0 0 1 0 1 Final Sample Time 2 A/D clock periods 4 A/D clock periods 8 A/D clock periods 16 A/D clock periods PRS[4:0] — ATD Clock Prescaler The binary prescaler value (0 to 31) plus one (1 to 32) becomes the divide-by-factor for a modulus counter used to prescale the system PCLK frequency. The resulting scaled clock is further divided by 2 before the ATD internal clock is generated. This clock is used to drive the S/H and A/D machines. Note that the maximum ATD clock frequency is half of the system clock. The default prescaler value is 00001 which results in a default ATD clock frequency that is quarter of the system clock i.e. with 8MHz bus the ATD module clock is 2MHz. Table 19-5 illustrates the divideby operation and the appropriate range of system clock frequencies. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Analog-to-Digital Converter 383 Analog-to-Digital Converter Table 19-5. Clock Prescaler Values Prescale Value 00000 00001 00010 00011 00100 00101 00110 00111 01xxx 1xxxx Total Divisor Max PCLK(1) Min PCLK(2) ÷2 ÷4 ÷6 ÷8 ÷10 ÷12 ÷14 ÷16 4 MHz 8 MHz 8 MHz 8 MHz 8 MHz 8 MHz 8 MHz 8 MHz 1 MHz 2 MHz 3 MHz 4 MHz 5 MHz 6 MHz 7 MHz 8 MHz Do Not Use 1. Maximum conversion frequency is 2 MHz. Maximum PCLK divisor value will become maximum conversion rate that can be used on this ATD module. 2. Minimum conversion frequency is 500 kHz. Minimum PCLK divisor value will become minimum conversion rate that this ATD can perform. 19.9.4 ATDCTL5 ATD Control Register 5 ATD control register 5 determines the type of conversion sequence and the analog input channels sampled. All writes to this register have an immediate effect. If a conversion is in progress, the entire conversion sequence is aborted. A write to this register (or ATDCTL4) initiates a new conversion sequence (SCF and CCF bits are reset). ATD0CTL5/ATD1CTL5 — ATD Control Register 5 RESET: Bit 7 0 0 6 S8C 0 5 SCAN 0 4 MULT 0 $0065/$01E5 3 SC 0 2 CC 0 1 CB 0 Bit 0 CA 0 S8C / S1C — Conversion Sequence Length S8C: Bit Position: 6, ATDCTL5 S1C: Bit Position: 3, ATDCTL3 The S8C/S1C bits define the length of a conversion sequence. Table 19-6 lists the coding combinations. Technical Data 384 MC68HC912DT128A — Rev 4.0 Analog-to-Digital Converter MOTOROLA Analog-to-Digital Converter ATD Registers S8C S1C 0 0 1 0 1 X Number of Conversions per Sequence 4 1 8 Table 19-6. Conversion Sequence Length Coding The result register assignments made to a conversion sequence follow a few simple rules. Normally, the first result is placed in the first register; the second result is placed in the second register, and so on. Table 197 presents the result register assignments for the various conversion lengths that are normally made. If FIFO mode is used, the result register assignments differ. The results are placed in consecutive registers between conversion sequences; the result register mapping wraps around when the end of the register file is reached. Number of Conversions per Sequence 1 4 8 Result Register Assignment ADR0 ADR0 through ADR3 ADR0 through ADR7 Table 19-7. Result Register Assignment for Different Conversion Sequences SCAN — Continuous Conversion Sequence Mode 0 = Perform a conversion sequence and return to idle mode 1 = Perform conversion sequences continuously (scan mode) The scan mode bit controls whether or not conversion sequences are performed continuously or not. If this control bit is 0, a write to control register 4 or 5 will initiate a conversion sequence; the conversion sequence will be executed; the sequence complete flag (SCF) will be set, and the module will return to idle mode. In this mode, the module remains powered up but no conversions are performed; the module waits for the next conversion sequence to be initiated. If this control bit is 1, a single conversion sequence initiation will result in a continuously executed conversion sequence. When a conversion sequence completes, the sequence complete flag (SCF) is set and a new sequence is immediately begun. The conversion mode characteristics of each sequence are identical. If a new conversion MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Analog-to-Digital Converter 385 Analog-to-Digital Converter mode is required, the existing continuous sequence must be interrupted, the control registers modified, and a new conversion sequence initiated. MULT — Multi-Channel Sample Mode 0 = Sample only the specified channel 1 = Sample across many channels When MULT is 0, the ATD sequence controller samples only from the specified analog input channel for an entire conversion sequence. The analog channel is selected by channel selection code (control bits CC/CB/CA located in ATDCTL5). When MULT is 1, the ATD sequence controller samples across channels. The number of channels sampled is determined by the sequence length value (S8C, S1C control bits). The first analog channel examined is determined by channel selection code (CC, CB, CA control bits); subsequent channels sampled in the sequence are determined by incrementing the channel selection code. SC — Special Channel Conversion Mode 0 = Perform A/D conversion on an analog input channel 1 = Perform special channel A/D conversion SC determines if the ATD module performs A/D conversions on any of the analog input channels (normal operation) or whether it performs a conversion on one of the defined, special channels. The special channels are normally used to test the A/D machine and include converting the high and low reference potentials for the module. The control bits CC/CB/CA are used to indicate which special channel is to be converted. Table 19-8. Special Channel Conversion Select Coding CC CB CA 0 1 1 1 1 X 0 0 1 1 X 0 1 0 1 Special Channel reserved VRH VRL (VRH + VRL)/2 reserved Technical Data 386 Expected Digital Result Code – $FF $00 $7F – MC68HC912DT128A — Rev 4.0 Analog-to-Digital Converter MOTOROLA Analog-to-Digital Converter ATD Registers Table 19-8 lists the special channels. The last column in the table denote the expected digital code that should be generated by the special conversion for 8-bit resolution. CC, CB, CA — Analog Input Channel Select Code These bits select the analog input channel(s). Table 19-9 lists the coding used to select the various analog input channels. In the case of single channel scans (MULT=0), this selection code specifies the channel for conversion. In the case of multi-channel scans (MULT=1), this selection code represents the first channel to be examined in the conversion sequence. Subsequent channels are determined by incrementing the channel selection code; selection codes that reach the maximum value wrap around to the minimum value. Note that for special conversion mode, bits CC/CB/CA have a different function. Instead of specifying the analog input channel, they identify which special channel conversion is to take place. (See Table 19-8.) A summart of the channels converted and the associated result locations for multiple channel scans can be found in Table 19-10. Table 19-9. Analog Input Channel Select Coding CC CB CA 0 0 0 0 1 1 1 1 0 0 1 1 0 0 1 1 0 1 0 1 0 1 0 1 MC68HC912DT128A — Rev 4.0 MOTOROLA Analog Input Channel AD0 AD1 AD2 AD3 AD4 AD5 AD6 AD7 Technical Data Analog-to-Digital Converter 387 Analog-to-Digital Converter Table 19-10. Multichannel Mode Result Register Assignment (MULT=1) 4 channel conversion, External channels (S8C = 0, SC = 0) CC 0 0 0 0 CB 0 0 1 1 CA 0 1 0 1 ADR0 AN0 AN1 AN2 AN3 ADR1 AN1 AN2 AN3 AN4 ADR2 AN2 AN3 AN4 AN5 ADR3 AN3 AN4 AN5 AN6 1 0 0 AN4 AN5 AN6 AN7 1 0 1 AN5 AN6 AN7 AN0 1 1 0 AN6 AN7 AN0 AN1 1 1 1 AN7 AN0 AN1 AN2 1 0 0 VRH VRL MID 1 0 1 VRL MID 1 1 0 MID 1 1 1 S1C bit must be clear. 4 channel conversion, Internal sources (S8C = 0, SC = 1) CC 0 0 0 0 CB 0 0 1 1 CA 0 1 0 1 ADR0 ADR1 VRH ADR2 VRH VRL ADR3 VRH VRL MID Shaded cells are reserved MID = (VRH + VRL) / 2 S1C bit must be clear. Technical Data 388 MC68HC912DT128A — Rev 4.0 Analog-to-Digital Converter MOTOROLA Analog-to-Digital Converter ATD Registers Table 19-10. Multichannel Mode Result Register Assignment (MULT=1) (Continued) 8 channel conversion, External channels (S8C = 1, SC = 0) CC 0 0 0 0 CB 0 0 1 1 CA 0 1 0 1 ADR0 AN0 AN1 AN2 AN3 ADR1 AN1 AN2 AN3 AN4 ADR2 AN2 AN3 AN4 AN5 ADR3 AN3 AN4 AN5 AN6 ADR4 AN4 AN5 AN6 AN7 ADR5 AN5 AN6 AN7 AN0 ADR6 AN6 AN7 AN0 AN1 ADR7 AN7 AN0 AN1 AN2 8 channel conversion, Internal Sources (S8C = 1, SC = 1) CC 0 0 0 0 CB 0 0 1 1 CA 0 1 0 1 ADR0 ADR1 VRH ADR2 VRH VRL ADR3 VRH VRL MID ADR4 VRH VRL MID ADR5 VRL MID ADR6 MID ADR7 1 0 0 AN4 AN5 AN6 AN7 AN0 AN1 AN2 AN3 1 0 1 AN5 AN6 AN7 AN0 AN1 AN2 AN3 AN4 1 1 0 AN6 AN7 AN0 AN1 AN2 AN3 AN4 AN5 1 1 1 AN7 AN0 AN1 AN2 AN3 AN4 AN5 AN6 1 0 0 VRH VRL MID 1 0 1 VRL MID 1 1 0 MID 1 1 1 VRH VRH VRL VRH VRL MID Shaded cells are reserved MID = (VRH + VRL) / 2 NOTES: 1) For compatibility with the MC68HC912DG128, CA, CB, CC bits must be ‘0’ where masked on the MC68HC912DG128. This is shown above in bold text. 2) When MULT = 0, all four bits (SC, CC, CB, and CA) must be specified and a conversion sequence consists of four or eight consecutive conversions of the single specified channel. 3) When S8C = 0 and S1C = 1, all four bits (SC, CC, CB, and CA) must be specified and a conversion sequence consists of one conversion of the single specified channel. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Analog-to-Digital Converter 389 Analog-to-Digital Converter 19.9.5 ATDSTAT A/D Status Register The ATD Status registers contain the conversion complete flags and the conversion sequence counter. The status registers are read-only. ATD0STAT0/ATD1STAT0 — ATD Status Register RESET: Bit 7 SCF 0 6 0 0 5 0 0 $0066/$01E6 4 0 0 3 0 0 2 CC2 0 1 CC1 0 Bit 0 CC0 0 ATD0STAT1/ATD1STAT1 — ATD Status Register RESET: Bit 7 CCF7 0 6 CCF6 0 5 CCF5 0 4 CCF4 0 $0067/$01E7 3 CCF3 0 2 CCF2 0 1 CCF1 0 Bit 0 CCF0 0 SCF — Sequence Complete Flag This flag is set upon completion of a conversion sequence. If conversion sequences are continuously performed (SCAN=1), the flag is set after each one is completed. How this flag is cleared depends on the setting of the fast flag clear bit. When AFFC=0, SCF is cleared when a new conversion sequence is initiated (write to register ATDCTL4/5). When AFFC=1, SCF is cleared after reading the first (any) result register. CC[2:0] — Conversion Counter This 3-bit value represents the contents of the result register counter; the result register counter points to the result register that will receive the result of the current conversion. If not in FIFO mode, the register counter is initialized to zero when a new conversion sequence is begun. If in FIFO mode, the register counter is not initialized. The result register count wraps around when its maximum value is reached. CCF[7:0] — Conversion Complete Flags A conversion complete flag is set at the end of each conversion in a conversion sequence. The flags are associated with the conversion position in a sequence and the result register number. Therefore, CCF0 is set when the first conversion in a sequence is complete and Technical Data 390 MC68HC912DT128A — Rev 4.0 Analog-to-Digital Converter MOTOROLA Analog-to-Digital Converter ATD Registers the result is available in result register ADR0; CCF1 is set when the second conversion in a sequence is complete and the result is available in ADR1, and so forth. The conversion complete flags are cleared depending on the setting of the fast flag clear bit (AFFC in ATDCTL2). When AFFC=0, the status register containing the conversion complete flag must be read as a precondition before the flag can be cleared. The flag is actually cleared during a subsequent access to the result register. This provides a convenient method for clearing the conversion complete flag when the user is polling the ATD module; it ensures the user is signaled as to the availability of new data and avoids having to have the user clear the flag explicitly. When AFFC=1, the conversion complete flags are cleared when their associated result registers are read; reading the status register is not a necessary condition in order to clear them. This is the easiest method for clearing the conversion complete flags which is useful when the ATD module signals conversion completion with an interrupt. The conversion complete flags are normally read only; in special (test) mode they can be written. NOTE: When ATDCTL4/5 register is written, the SCF flags and all CCFx flags are cleared; any pending interrupt request is canceled. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Analog-to-Digital Converter 391 Analog-to-Digital Converter 19.9.6 ATDTEST Module Test Register (ATDTEST) The test registers implement various special (test) modes used to test the ATD module. The reset bit in ATDTEST1 is always read/write. The SAR (successive approximation register) can always be read but only written in special (test) mode. The functions implemented by the test registers are reserved for factory test. ATD0TESTH/ATD1TESTH — ATD Test Register RESET: Bit 7 SAR9 0 6 SAR8 0 5 SAR7 0 $0068/$01E8 4 SAR6 0 3 SAR5 0 2 SAR4 0 1 SAR3 0 Bit 0 SAR2 0 ATD0TESTL/ATD1TESTL — ATD Test Register RESET: Bit 7 SAR1 0 6 SAR0 0 5 RST 0 $0069/$01E9 4 0 0 3 0 0 2 0 0 1 0 0 Bit 0 0 0 SAR[9:0] — Successive Approximation Register This ten bit value represents the contents of the AD machine’s successive approximation register. This value can always be read. It can only be written in special (test) mode. Note that ATDTEST0 acts as a ten bit register since the entire SAR is read/written when accessing this address. RST — Test Mode Reset Bit 0 = No reset 1 = Reset the ATD module When set, this bit causes the ATD module to reset itself. This sets all registers to their reset state (note the reset state of the reset bit is zero), the current conversion and conversion sequence are aborted, pending interrupts are cleared, and the module is placed in an idle mode. Technical Data 392 MC68HC912DT128A — Rev 4.0 Analog-to-Digital Converter MOTOROLA Analog-to-Digital Converter ATD Registers Resetting to idle mode defines the only exception of the reset control bit condition to the system reset condition. The reset control bit does not initialize the ADPU bit to its reset condition and therefore does not power down the module. This except allows the module to remain active for other test operations. 19.9.7 PORTAD Port Data Register The input data port associated with the ATD module is input-only. The port pins are shared with the analog A/D inputs. PORTAD0/PORTAD1 — Port AD Data Input Register RESET: Bit 7 PADx7 - 6 PADx6 - 5 PADx5 - 4 PADx4 - $006F/$01EF 3 PADx3 - 2 PADx2 - 1 PADx1 - Bit 0 PADx0 - PADx[7:0] — Port AD Data Input Bits Reset: These pins reflect the state of the input pins. The ATD input ports may be used for general purpose digital input. When the port data registers are read, they contain the digital levels appearing on the input pins at the time of the read. Input pins with signal potentials not meeting V IL or V IH specifications will have an indeterminate value. Use of any Port pin for digital input does not preclude the use of any other Port pin for analog input. Writes to this register have no meaning at any time. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Analog-to-Digital Converter 393 Analog-to-Digital Converter 19.9.8 ADRx A/D Conversion Result Registers (ADR0-15) ADRx0H — A/D Converter Result Register 0 ADRx0L — A/D Converter Result Register 0 ADRx1H — A/D Converter Result Register 1 ADRx1L — A/D Converter Result Register 1 ADRx2H — A/D Converter Result Register 2 ADRx2L — A/D Converter Result Register 2 ADRx3H — A/D Converter Result Register 3 ADRx3L — A/D Converter Result Register 3 ADRx4H — A/D Converter Result Register 4 ADRx4L — A/D Converter Result Register 4 ADRx5H — A/D Converter Result Register 5 ADRx5L — A/D Converter Result Register 5 ADRx6H — A/D Converter Result Register 6 ADRx6L — A/D Converter Result Register 6 ADRx7H — A/D Converter Result Register 7 ADRx7L — A/D Converter Result Register 7 ADRxxH ADRxxL RESET: $0070/$01F0 $0071/$01F1 $0072/$01F2 $0073/$01F3 $0074/$01F4 $0075/$01F5 $0076/$01F6 $0077/$01F7 $0078/$01F8 $0079/$01F9 $007A/$01FA $007B/$01FB $007C/$01FC $007D/$01FD $007E/$01FE $007F/$01FF Bit 15 6 5 4 3 2 1 Bit 8 Bit 7 0 Bit 6 0 0 0 0 0 0 0 0 0 0 0 0 0 The A/D conversion results are stored in 8 result registers. These registers are designated ADR0 through ADR7. The result data is formatted using the DJM control bit in ATDCTL2. For 8-bit result data, the result data maps between the high (left justified) and low (right justified) order bytes of the result register. For 10-bit result data, the result data maps between bits 6-15 (left justified) and bits 0-9 (right justified) of the result register. These registers are normally read-only. Technical Data 394 MC68HC912DT128A — Rev 4.0 Analog-to-Digital Converter MOTOROLA Technical Data — MC68HC912DT128A Section 20. Development Support 20.1 Contents 20.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 395 20.3 Instruction Queue . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .395 20.4 Background Debug Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . .397 20.5 Breakpoints. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 412 20.6 Instruction Tagging . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 419 20.2 Introduction Development support involves complex interactions between MC68HC912DT128A resources and external development systems. The following section concerns instruction queue and queue tracking signals, background debug mode, and instruction tagging. 20.3 Instruction Queue The CPU12 instruction queue provides at least three bytes of program information to the CPU when instruction execution begins. The CPU12 always completely finishes executing an instruction before beginning to execute the next instruction. Status signals IPIPE[1:0] provide information about data movement in the queue and indicate when the CPU begins to execute instructions. This makes it possible to monitor CPU activity on a cycle-by-cycle basis for debugging. Information available on the IPIPE[1:0] pins is time multiplexed. External circuitry can latch data movement information on rising edges of the E-clock signal; execution start information can be latched on falling edges. Table 20-1 shows the meaning of data on the pins. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Development Support 395 Development Support Table 20-1. IPIPE Decoding Data Movement — IPIPE[1:0] Captured at Rising Edge of E Clock(1) IPIPE[1:0] Mnemonic Meaning 0:0 — No Movement 0:1 LAT Latch Data From Bus 1:0 ALD Advance Queue and Load From Bus 1:1 ALL Advance Queue and Load From Latch Execution Start — IPIPE[1:0] Captured at Falling Edge of E Clock(2) IPIPE[1:0] Mnemonic Meaning 0:0 — No Start 0:1 INT Start Interrupt Sequence 1:0 SEV Start Even Instruction 1:1 SOD Start Odd Instruction 1. Refers to data that was on the bus at the previous E falling edge. 2. Refers to bus cycle starting at this E falling edge. Program information is fetched a few cycles before it is used by the CPU. In order to monitor cycle-by-cycle CPU activity, it is necessary to externally reconstruct what is happening in the instruction queue. Internally the MCU only needs to buffer the data from program fetches. For system debug it is necessary to keep the data and its associated address in the reconstructed instruction queue. The raw signals required for reconstruction of the queue are ADDR, DATA, R/W, ECLK, and status signals IPIPE[1:0]. The instruction queue consists of two 16-bit queue stages and a holding latch on the input of the first stage. To advance the queue means to move the word in the first stage to the second stage and move the word from either the holding latch or the data bus input buffer into the first stage. To start even (or odd) instruction means to execute the opcode in the high-order (or low-order) byte of the second stage of the instruction queue. Technical Data 396 MC68HC912DT128A — Rev 4.0 Development Support MOTOROLA Development Support Background Debug Mode 20.4 Background Debug Mode Background debug mode (BDM) is used for system development, incircuit testing, field testing, and programming. BDM is implemented in on-chip hardware and provides a full set of debug options. Because BDM control logic does not reside in the CPU, BDM hardware commands can be executed while the CPU is operating normally. The control logic generally uses CPU dead cycles to execute these commands, but can steal cycles from the CPU when necessary. Other BDM commands are firmware based, and require the CPU to be in active background mode for execution. While BDM is active, the CPU executes a firmware program located in a small on-chip ROM that is available in the standard 64-Kbyte memory map only while BDM is active. The BDM control logic communicates with an external host development system serially, via the BKGD pin. This single-wire approach minimizes the number of pins needed for development support. 20.4.1 Enabling BDM Firmware Commands BDM is available in all operating modes, but must be made active before firmware commands can be executed. BDM is enabled by setting the ENBDM bit in the BDM STATUS register via the single wire interface (using a hardware command; WRITE_BD_BYTE at $FF01). BDM must then be activated to map BDM registers and ROM to addresses $FF00 to $FFFF and to put the MCU in active background mode. After the firmware is enabled, BDM can be activated by the hardware BACKGROUND command, by the BDM tagging mechanism, or by the CPU BGND instruction. An attempt to activate BDM before firmware has been enabled causes the MCU to resume normal instruction execution after a brief delay. BDM becomes active at the next instruction boundary following execution of the BDM BACKGROUND command, but tags activate BDM before a tagged instruction is executed. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Development Support 397 Development Support In special single-chip mode, background operation is enabled and active immediately out of reset. This active case replaces the M68HC11 boot function, and allows programming a system with blank memory. While BDM is active, a set of BDM control registers are mapped to addresses $FF00 to $FF06. The BDM control logic uses these registers which can be read anytime by BDM logic, not user programs. Refer to BDM Registers for detailed descriptions. Some on-chip peripherals have a BDM control bit which allows suspending the peripheral function during BDM. For example, if the timer control is enabled, the timer counter is stopped while in BDM. Once normal program flow is continued, the timer counter is re-enabled to simulate real-time operations. 20.4.2 BDM Serial Interface The BDM serial interface requires the external controller to generate a falling edge on the BKGD pin to indicate the start of each bit time. The external controller provides this falling edge whether data is transmitted or received. BKGD is a pseudo-open-drain pin that can be driven either by an external controller or by the MCU. Data is transferred MSB first at 16 BDMCLK cycles per bit (nominal speed). The interface times out if 512 BDMCLK cycles occur between falling edges from the host. The hardware clears the command register when a time-out occurs. The BKGD pin can receive a high or low level or transmit a high or low level. The following diagrams show timing for each of these cases. Interface timing is synchronous to MCU clocks but asynchronous to the external host. The internal clock signal is shown for reference in counting cycles. Figure 20-1 shows an external host transmitting a logic one or zero to the BKGD pin of a target MC68HC912DT128A MCU. The host is asynchronous to the target so there is a 0-to-1 cycle delay from the hostgenerated falling edge to where the target perceives the beginning of the bit time. Ten target B cycles later, the target senses the bit level on the BKGD pin. Typically the host actively drives the pseudo-open-drain Technical Data 398 MC68HC912DT128A — Rev 4.0 Development Support MOTOROLA Development Support Background Debug Mode BKGD pin during host-to-target transmissions to speed up rising edges. Since the target does not drive the BKGD pin during this period, there is no need to treat the line as an open-drain signal during host-to-target transmissions. BDMCLK (TARGET MCU) HOST TRANSMIT 1 HOST TRANSMIT 0 PERCEIVED START OF BIT TIME TARGET SENSES BIT EARLIEST START OF NEXT BIT 10 CYCLES SYNCHRONIZATION UNCERTAINTY HC12A4 BDM HOST TO TARGET TIM Figure 20-1. BDM Host to Target Serial Bit Timing BDMCLK (TARGET MCU) HOST DRIVE TO BKGD PIN HIGH-IMPEDANCE TARGET MCU SPEEDUP PULSE HIGH-IMPEDANCE PERCEIVED START OF BIT TIME HIGH-IMPEDANCE R-C RISE BKGD PIN 10 CYCLES 10 CYCLES HOST SAMPLES BKGD PIN EARLIEST START OF NEXT BIT HC12A4 BDM TARGET TO HOST TIM 1 Figure 20-2. BDM Target to Host Serial Bit Timing (Logic 1) MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Development Support 399 Development Support Figure 20-2 shows the host receiving a logic one from the target MC68HC912DT128A MCU. Since the host is asynchronous to the target MCU, there is a 0-to-1 cycle delay from the host-generated falling edge on BKGD to the perceived start of the bit time in the target MCU. The host holds the BKGD pin low long enough for the target to recognize it (at least two target B cycles). The host must release the low drive before the target MCU drives a brief active-high speed-up pulse seven cycles after the perceived start of the bit time. The host should sample the bit level about ten cycles after it started the bit time. BDMCLK (TARGET MCU) HOST DRIVE TO BKGD PIN HIGH-IMPEDANCE SPEEDUP PULSE TARGET MCU DRIVE AND SPEEDUP PULSE PERCEIVED START OF BIT TIME BKGD PIN 10 CYCLES 10 CYCLES HOST SAMPLES BKGD PIN EARLIEST START OF NEXT BIT HC12A4 BDM TARGET TO HOST TIM 0 Figure 20-3. BDM Target to Host Serial Bit Timing (Logic 0) Technical Data 400 MC68HC912DT128A — Rev 4.0 Development Support MOTOROLA Development Support Background Debug Mode Figure 20-3 shows the host receiving a logic zero from the target MC68HC912DT128A MCU. Since the host is asynchronous to the target MCU, there is a 0-to-1 cycle delay from the host-generated falling edge on BKGD to the start of the bit time as perceived by the target MCU. The host initiates the bit time but the target MC68HC912DT128A finishes it. Since the target wants the host to receive a logic zero, it drives the BKGD pin low for 13 BDMCLK cycles, then briefly drives it high to speed up the rising edge. The host samples the bit level about ten cycles after starting the bit time. 20.4.3 BDM Commands The BDM command set consists of two types: hardware and firmware. Hardware commands allow target system memory to be read or written.Target system memory includes all memory that is accessible by the CPU12 including EEPROM, on-chip I/O and control registers, and external memory that is connected to the target HC12 MCU.Hardware commands are implemented in hardware logic and do not require the HC12 MCU to be in BDM mode for execution.The control logic watches the CPU12 buses to find a free bus cycle to execute the command so the background access does not disturb the running application programs. If a free cycle is not found within 128 BDMCLK cycles, the CPU12 is momentarily frozen so the control logic can steal a cycle.Commands implemented in BDM control logic are listed in Table 20-2. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Development Support 401 Development Support Table 20-2. Hardware Commands(1) Command BACKGROUND Opcode (Hex) 90 Data None READ_BD_BYTE(1) E4 16-bit address 16-bit data out READ_BD_WORD(1) EC 16-bit address 16-bit data out READ_BYTE E0 16-bit address 16-bit data out READ_WORD E8 16-bit address 16-bit data out WRITE_BD_BYTE(1) C4 16-bit address 16-bit data in WRITE_BD_WORD(1) CC 16-bit address 16-bit data in WRITE_BYTE C0 16-bit address 16-bit data in WRITE_WORD C8 16-bit address 16-bit data in Description Enter background mode if firmware enabled. Read from memory with BDM in map (may steal cycles if external access) data for odd address on low byte, data for even address on high byte. Read from memory with BDM in map (may steal cycles if external access). Must be aligned access. Read from memory with BDM out of map (may steal cycles if external access) data for odd address on low byte, data for even address on high byte. Read from memory with BDM out of map (may steal cycles if external access). Must be aligned access. Write to memory with BDM in map (may steal cycles if external access) data for odd address on low byte, data for even address on high byte. Write to memory with BDM in map (may steal cycles if external access). Must be aligned access. Write to memory with BDM out of map (may steal cycles if external access) data for odd address on low byte, data for even address on high byte. Write to memory with BDM out of map (may steal cycles if external access). Must be aligned access. 1. Use these commands only for reading/writing to BDM locations.The BDM firmware ROM and BDM registers are not normally in the HC12 MCU memory map.Since these locations have the same addresses as some of the normal application memory map, there needs to be a way to decide which physical locations are being accessed by the hardware BDM commands.This gives rise to needing separate memory access commands for the BDM locations as opposed to the normal application locations.In logic, this is accomplished by momentarily enabling the BDM memory resources, just for the access cycles of the READ_BD and WRITE_BD commands.This logic allows the debugging system to unobtrusively access the BDM locations even if the application program is running out of the same memory area in the normal application memory map. The second type of BDM commands are called firmware commands implemented in a small ROM within the HC12 MCU.The CPU must be in background mode to execute firmware commands. The usual way to get to background mode is by the hardware command BACKGROUND. The BDM ROM is located at $FF20 to $FFFF while BDM is active. There are also seven bytes of BDM registers located at $FF00 to $FF06 while BDM is active. The CPU executes code in the BDM firmware to perform the requested operation. The BDM firmware watches for serial commands Technical Data 402 MC68HC912DT128A — Rev 4.0 Development Support MOTOROLA Development Support Background Debug Mode and executes them as they are received. The firmware commands are shown in Table 20-3. Table 20-3. BDM Firmware Commands Command READ_NEXT READ_PC READ_D READ_X READ_Y READ_SP WRITE_NEXT WRITE_PC WRITE_D WRITE_X WRITE_Y WRITE_SP GO TRACE1 TAGGO Opcode (Hex) 62 63 64 65 66 67 42 43 44 45 46 47 08 10 18 Data 16-bit data out 16-bit data out 16-bit data out 16-bit data out 16-bit data out 16-bit data out 16-bit data in 16-bit data in 16-bit data in 16-bit data in 16-bit data in 16-bit data in None None None Description X = X + 2; Read next word pointed to by X Read program counter Read D accumulator Read X index register Read Y index register Read stack pointer X = X + 2; Write next word pointed to by X Write program counter Write D accumulator Write X index register Write Y index register Write stack pointer Go to user program Execute one user instruction then return to BDM Enable tagging and go to user program Each of the hardware and firmware BDM commands start with an 8-bit command code (opcode). Depending upon the commands, a 16-bit address and/or a 16-bit data word is required as indicated in the tables by the command. All the read commands output 16-bits of data despite the byte/word implication in the command name. The external host should wait 150 BDMCLK cycles for a non-intrusive BDM command to execute before another command is sent. This delay includes 128 BDMCLK cycles for the maximum delay for a free cycle.For data read commands, the host must insert this delay between sending the address and attempting to read the data.In the case of a write command, the host must delay after the data portion, before sending a new command, to be sure the write has finished. The external host should delay about 32 target BDMCLK cycles between a firmware read command and the data portion of these commands. This allows the BDM firmware to execute the instructions needed to get the requested data into the BDM SHIFTER register. The external host should delay about 32 target BDMCLK cycles after the data portion of firmware write commands to allow BDM firmware to MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Development Support 403 Development Support complete the requested write operation before a new serial command disturbs the BDM SHIFTER register. The external host should delay about 64 target BDMCLK cycles after a TRACE1 or GO command before starting any new serial command. This delay is needed because the BDM SHIFTER register is used as a temporary data holding register during the exit sequence to user code. BDM logic retains control of the internal buses until a read or write is completed.If an operation can be completed in a single cycle, it does not intrude on normal CPU12 operation.However, if an operation requires multiple cycles, CPU12 clocks are frozen until the operation is complete. 20.4.4 BDM Lockout The access to the MCU resources by BDM may be prevented by enabling the BDM lockout feature. When enabled, the BDM lockout mechanism prevents the BDM from being active. In this case the BDM ROM is disabled and does not appear in the MCU memory map. The BDM lockout is enabled by clearing NOBDML bit of EEMCR register. The NOBDML bit is loaded at reset from the SHADOW word of EEPROM module. Modifying the state of the NOBDML and corresponding EEPROM SHADOW bit is only possible in special modes. Please refer to EEPROM Memory for NOBDML information. 20.4.4.1 Enabling the BDM lockout Enabling the BDM lockout feature is only possible in special modes (SMODN=0) and is accomplished by the following steps. 1. Remove the SHADOW word protection by clearing SHPROT bit in EEPROT register. 2. Clear NOSHW bit in EEMCR register to make the SHADOW word visible at $0FC0-$0FC1. 3. Program bit 7 of the high byte of the SHADOW word like a regular EEPROM location at address $0FC0 (write $7F into address $0FC0). Do not program other bits of the high byte of the Technical Data 404 MC68HC912DT128A — Rev 4.0 Development Support MOTOROLA Development Support Background Debug Mode SHADOW word (location $0FC0); otherwise some regular EEPROM array locations will not be visible. At the next reset, the high byte of the SHADOW word is loaded into the EEMCR register. NOBDML bit in EEMCR will be cleared and BDM will not be operational. 4. Protect the SHADOW word by setting SHPROT bit in EEPROT register. 20.4.4.2 Disabling the BDM lockout Disabling the BDM lockout is only possible in special modes (SMODN=0) except in special single chip. Follow the same steps as for enabling the BDM lockout, but erase the SHADOW word. At the next reset, the high byte of SHADOW word is loaded into the EEMCR register. NOBDML bit in EEMCR will be set and BDM becomes operational. NOTE: When the BDM lockout is enabled it is not possible to run code from the reset vector in special single chip mode. 20.4.5 BDM Registers Seven BDM registers are mapped into the standard 64-Kbyte address space when BDM is active. Mapping is shown in Table 20-4. Table 20-4. BDM registers Address Register $FF00 BDM Instruction Register $FF01 BDM Status Register $FF02 – $FF03 BDM Shift Register $FF04 – $FF05 BDM Address Register $FF06 BDM CCR Holding Register The content of the INSTRUCTION register is determined by the type of background command being executed.The STATUS register indicates BDM operating conditions.The SHIFT register contains data being received or transmitted via the serial interface. The ADDRESS register MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Development Support 405 Development Support is temporary storage for BDM commands.The CCRSAV register preserves the content of the CPU12 CCR while BDM is active. The only registers of interest to users are the STATUS register and the CCRSAV register.The other BDM registers are only used by the BDM firmware to execute commands.The registers are accessed by means of the hardware READ_BD and WRITE_BD commands, but should not be written during BDM operation (except the CCRSAV register which could be written to modify the CCR value). 20.4.5.1 STATUS The STATUS register is read and written by the BDM hardware as a result of serial data shifted in on the BKGD pin. Read: all modes. Write: Bits 3 through 5, and bit 7 are writable in all modes. Bit 6, BDMACT, can only be written if bit 7 H/F in the INSTRUCTION register is a zero. Bit 2, CLKSW, can only be written if bit 7 H/F in the INSTRUCTION register is a one. A user would never write ones to bits 3 through 5 because these bits are only used by BDM firmware. STATUS— BDM Status Register(1) RESET: RESET: $FF01 BIT 7 ENBDM 6 BDMACT 5 ENTAG 4 SDV 3 TRACE 2 CLKSW 1 - BIT 0 - 0 (NOTE 1) 0 1 0 0 0 0 0 0 Special Single Chip & Periph 0 0 0 0 0 0 0 All other modes 1. ENBDM is set to 1 by the firmware in Special Single Chip mode. ENBDM — Enable BDM (permit active background debug mode) 0 = BDM cannot be made active (hardware commands still allowed). 1 = BDM can be made active to allow firmware commands. BDMACT — Background Mode Active Status Technical Data 406 MC68HC912DT128A — Rev 4.0 Development Support MOTOROLA Development Support Background Debug Mode BDMACT becomes set as active BDM mode is entered so that the BDM firmware ROM is enabled and put into the map. BDMACT is cleared by a carefully timed store instruction in the BDM firmware as part of the exit sequence to return to user code and remove the BDM memory from the map. This bit has 4 clock cycles write delay. 0 = BDM is not active. BDM ROM and registers are not in map. 1 = BDM is active and waiting for serial commands. BDM ROM and registers are in map The user should be careful that the state of the BDMACT bit is not unintentionally changed with the WRITE_NEXT firmware command. If it is unintentionally changed from 1 to 0, it will cause a system runaway because it would disable the BDM firmware ROM while the CPU12 was executing BDM firmware. The following two commands show how BDMACT may unintentionally get changed from 1 to 0. WRITE_X with data $FEFE WRITE_NEXT with data $C400 The first command writes the data $FEFE to the X index register. The second command writes the data $C4 to the $FF00 INSTRUCTION register and also writes the data $00 to the $FF01 STATUS register. ENTAG — Tagging Enable Set by the TAGGO command and cleared when BDM mode is entered. The serial system is disabled and the tag function enabled 16 cycles after this bit is written. 0 = Tagging not enabled, or BDM active. 1 = Tagging active. BDM cannot process serial commands while tagging is active. SDV — Shifter Data Valid Shows that valid data is in the serial interface shift register. Used by the BDM firmware. 0 = No valid data. Shift operation is not complete. 1 = Valid Data. Shift operation is complete. TRACE — Asserted by the TRACE1 command CLKSW — BDMCLK Clock Switch 0 = BDM system operates with BCLK. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Development Support 407 Development Support 1 = BDM system operates with ECLK. The WRITE_BD_BYTE@FF01 command that changes CLKSW including 150 cycles after the data portion of the command should be timed at the old speed. Beginning with the start of the next BDM command, the new clock can be used for timing BDM communications. If ECLK rate is slower than BDMCLK rate, CLKSW is ignored and BDM system is forced to operate with ECLK. 20.4.5.2 INSTRUCTION - Hardware Instruction Decode The INSTRUCTION register is written by the BDM hardware as a result of serial data shifted in on the BKGD pin. It is readable and writable in Special Peripheral mode on the parallel bus. It is discussed here for two conditions: when a hardware command is executed and when a firmware command is executed. Read and write: all modes . The hardware clears the INSTRUCTION register if 512 BDMCLK cycles occur between falling edges from the host. INSTRUCTION— BDM Instruction Register (hardware command explanation) RESET: BIT 7 H/F 0 6 DATA 0 5 R/W 0 4 BKGND 0 3 W/B 0 2 BD/U 0 $FF00 1 0 0 BIT 0 0 0 The bits in the BDM instruction register have the following meanings when a hardware command is executed. H/F — Hardware/Firmware Flag 0 = Firmware command 1 = Hardware command Technical Data 408 MC68HC912DT128A — Rev 4.0 Development Support MOTOROLA Development Support Background Debug Mode DATA — Data Flag - Shows that data accompanies the command. 0 = No data 1 = Data follows the command R/W — Read/Write Flag 0 = Write 1 = Read BKGND — Hardware request to enter active background mode 0 = Not a hardware background command 1 = Hardware background command (INSTRUCTION = $90) W/B — Word/Byte Transfer Flag 0 = Byte transfer 1 = Word transfer BD/U — BDM Map/User Map Flag Indicates whether BDM registers and ROM are mapped to addresses $FF00 to $FFFF in the standard 64-Kbyte address space. Used only by hardware read/write commands. 0 = BDM resources not in map 1 = BDM ROM and registers in map INSTRUCTION — BDM Instruction Register (firmware command bit explanation) Bit 7 H/F 6 DATA 5 R/W 4 3 TTAGO 2 1 REGN $FF00 Bit 0 The bits in the BDM instruction register have the following meanings when a firmware command is executed. H/F — Hardware/Firmware Flag 0 = Firmware command 1 = Hardware command DATA — Data Flag – Shows that data accompanies the command. 0 = No data 1 = Data follows the command MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Development Support 409 Development Support R/W — Read/Write Flag 0 = Write 1 = Read TTAGO — Trace, Tag, Go Field Table 20-5. TTAGO Decoding TTAGO Value Instruction 00 — 01 GO 10 TRACE1 11 TAGGO REGN — Register/Next Field Indicates which register is being affected by a command. In the case of a READ_NEXT or WRITE_NEXT command, index register X is preincriminated by 2 and the word pointed to by X is then read or written. Table 20-6. REGN Decoding REGN Value Instruction 000 — 001 — 010 READ/WRITE NEXT 011 PC 100 D 101 X 110 Y 111 SP Technical Data 410 MC68HC912DT128A — Rev 4.0 Development Support MOTOROLA Development Support Background Debug Mode 20.4.5.3 SHIFTER This 16-bit shift register contains data being received or transmitted via the serial interface. It is also used by the BDM firmware for temporary storage. Read: all modes (but not normally accessed by users) Write: all modes (but not normally accessed by users) SHIFTER — BDM Shift Register – High Byte RESET: $FF02 BIT 15 S15 14 S14 13 S13 12 S12 11 S11 10 S10 9 S9 BIT 8 S8 X X X X X X X X SHIFTER — BDM Shift Register – Low Byte RESET: $FF03 BIT 7 S7 6 S6 5 S5 4 S4 3 S3 2 S2 1 S1 BIT 0 S0 X X X X X X X X 20.4.5.4 ADDRESS This 16-bit address register is temporary storage for BDM hardware and firmware commands. Read: all modes (but not normally accessed by users) Write: only by BDM hardware (state machine) ADDRESS — BDM Address Register – High Byte RESET: $FF04 BIT 15 A15 14 A14 13 A13 12 A12 11 A11 10 A10 9 A9 BIT 8 A8 X X X X X X X X ADDRESS — BDM Address Register – High Byte RESET: $FF05 BIT 7 A7 6 A6 5 A5 4 A4 3 A3 2 A2 1 A1 BIT 0 A0 X X X X X X X X MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Development Support 411 Development Support 20.4.5.5 CCRSAV The CCRSAV register is used to save the CCR of the users program when entering BDM. It is also used for temporary storage in the BDM firmware. Read and write: all modes CCRSAV— BDM CCR Holding Register $FF06 BIT 7 CCR7 6 CCR6 5 CCR5 4 CCR4 3 CCR3 2 CCR2 1 CCR1 BIT 0 CCR0 X X X X X X X X RESET: NOTE 1 (1) 1. Initialized to equal the CPU12 CCR register by the firmware. 20.5 Breakpoints Hardware breakpoints are used to debug software on the MC68HC912DT128A by comparing actual address and data values to predetermined data in setup registers. A successful comparison will place the CPU in background debug mode (BDM) or initiate a software interrupt (SWI). Breakpoint features designed into the MC68HC912DT128A include: • Mode selection for BDM or SWI generation • Program fetch tagging for cycle of execution breakpoint • Second address compare in dual address modes • Range compare by disable of low byte address • Data compare in full feature mode for non-tagged breakpoint • Byte masking for high/low byte data compares • R/W compare for non-tagged compares • Tag inhibit on BDM TRACE Technical Data 412 MC68HC912DT128A — Rev 4.0 Development Support MOTOROLA Development Support Breakpoints 20.5.1 Breakpoint Modes Three modes of operation determine the type of breakpoint in effect. • Dual address-only breakpoints, each of which will cause a software interrupt (SWI) • Single full-feature breakpoint which will cause the part to enter background debug mode (BDM) • Dual address-only breakpoints, each of which will cause the part to enter BDM Breakpoints will not occur when BDM is active. 20.5.1.1 SWI Dual Address Mode In this mode, dual address-only breakpoints can be set, each of which cause a software interrupt. This is the only breakpoint mode which can force the CPU to execute a SWI. Program fetch tagging is the default in this mode; data breakpoints are not possible. In the dual mode each address breakpoint is affected by the BKPM bit and the BKALE bit. The BKxRW and BKxRWE bits are ignored. In dual address mode the BKDBE becomes an enable for the second address breakpoint. The BKSZ8 bit will have no effect when in a dual address mode. 20.5.1.2 BDM Full Breakpoint Mode A single full feature breakpoint which causes the part to enter background debug mode. BDM mode may be entered by a breakpoint only if an internal signal from the BDM indicates background debug mode is enabled. • Breakpoints are not allowed if the BDM mode is already active. Active mode means the CPU is executing out of the BDM ROM. • BDM should not be entered from a breakpoint unless the ENABLE bit is set in the BDM. This is important because even if the ENABLE bit in the BDM is negated the CPU actually does execute the BDM ROM code. It checks the ENABLE and returns if not set. If the BDM is not serviced by the monitor then the breakpoint would be re-asserted when the BDM returns to normal CPU flow. MC68HC912DT128A — Rev 4.0 Technical Data MOTOROLA Development Support 413 Development Support • There is no hardware to enforce restriction of breakpoint operation if the BDM is not enabled. 20.5.1.3 BDM Dual Address Mode Dual address-only breakpoints, each of which cause the part to enter background debug mode. In the dual mode each address breakpoint is affected, consistent across modes, by the BKPM bit, the BKALE bit, and the BKxRW and BKxRWE bits. In dual address mode the BKDBE becomes an enable for the second address breakpoint. The BKSZ8 bit will have no effect when in a dual address mode. BDM mode may be entered by a breakpoint only if an internal signal from the BDM indicates background debug mode is enabled. • BKDBE will be used as an enable for the second address only breakpoint. • Breakpoints are not allowed if the BDM mode is already active. Active mode means the CPU is executing out of the BDM ROM. • BDM should not be entered from a breakpoint unless the ENABLE bit is set in the BDM. This is important because even if the ENABLE bit in the BDM is negated the CPU actually does execute the BDM ROM code. It checks the ENABLE and returns if not set. If the BDM is not serviced by the monitor then the breakpoint would be re-asserted when the BDM returns to normal CPU flow. There is no hardware to enforce restriction of breakpoint operation if the BDM is not enabled. 20.5.2 Breakpoint Registers Breakpoint operation consists of comparing data in the breakpoint address registers (BRKAH/BRKAL) to the address bus and comparing data in the breakpoint data registers (BRKDH/BRKDL) to the data bus. The breakpoint data registers can also be compared to the address bus. The scope of comparison can be expanded by ignoring the least significant byte of address or data matches. The scope of comparison can be limited to program data only by setting the BKPM bit in breakpoint control register 0. Technical Data 414 MC68HC912DT128A — Rev 4.0 Development Support MOTOROLA Development Support Breakpoints To trace program flow, setting the BKPM bit causes address comparison of program data only. Control bits are also available that allow checking read/write matches. BRKCT0 — Breakpoint Control Register 0 RESET: $0020 Bit 7 6 5 4 3 2 1 Bit 0 BKEN1 BKEN0 BKPM 0 BK1ALE BK0ALE 0 0 0 0 0 0 0 0 0 0 Read and write anytime. This register is used to control the breakpoint logic. BKEN1, BKEN0 — Breakpoint Mode Enable Table 20-7. Breakpoint Mode Control BKEN1 BKEN0 Mode Selected 0 0 Breakpoints Off 0 1 SWI — Dual Address Mode 1 0 BDM — Full Breakpoint Mode 1 1 BDM — Dual Address Mode BRKAH/L Usage BRKDH/L Usage — — Address Match Address Match Address Match Data Match Address Match Address Match R/W — No Yes Yes Range — Yes Yes Yes BKPM — Break on Program Addresses This bit controls whether the breakpoint will cause a break on a match (next instruction boundary) or on a match that will be an executable opcode. Data and non-executed opcodes cannot cause a break if this bit is set. This bit has no meaning in SWI dual address mode. The SWI mode only performs program breakpoints. 0 = On match, break at the next instruction boundary 1 = On match, break if the match is an instruction that will be executed. This uses tagging as its breakpoint mechanism. BK1ALE — Breakpoint 1 Range Control Only valid in dual address mode. 0 = BRKDL will not be used to compare to the address bus. 1 = BRKDL will be used to compare to the address bus. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Development Support 415 Development Support BK0ALE — Breakpoint 0 Range Control Valid in all modes. 0 = BRKAL will not be used to compare to the address bus. 1 = BRKAL will be used to compare to the address bus. Table 20-8. Breakpoint Address Range Control BK1ALE BK0ALE Address Range Selected – 0 Upper 8-bit address only for full mode or dual mode BKP0 – 1 Full 16-bit address for full mode or dual mode BKP0 0 – Upper 8-bit address only for dual mode BKP1 1 – Full 16-bit address for dual mode BKP1 BRKCT1 — Breakpoint Control Register 1 $0021 Bit 7 6 5 4 3 2 1 Bit 0 0 BKDBE BKMBH BKMBL BK1RWE BK1RW BK0RWE BK0RW 0 0 0 0 0 0 0 0 RESET: This register is read/write in all modes. BKDBE — Enable Data Bus Enables comparing of address or data bus values using the BRKDH/L registers. 0 = The BRKDH/L registers are not used in any comparison 1 = The BRKDH/L registers are used to compare address or data (depending upon the mode selections BKEN1,0) BKMBH — Breakpoint Mask High Disables the comparing of the high byte of data when in full breakpoint mode. Used in conjunction with the BKDBE bit (which should be set) 0 = High byte of data bus (bits 15:8) are compared to BRKDH 1 = High byte is not used to in comparisons Technical Data 416 MC68HC912DT128A — Rev 4.0 Development Support MOTOROLA Development Support Breakpoints BKMBL — Breakpoint Mask Low Disables the matching of the low byte of data when in full breakpoint mode. Used in conjunction with the BKDBE bit (which should be set) 0 = Low byte of data bus (bits 7:0) are compared to BRKDL 1 = Low byte is not used to in comparisons. BK1RWE — R/W Compare Enable Enables the comparison of the R/W signal to further specify what causes a match. This bit is NOT useful in program breakpoints or in full breakpoint mode. This bit is used in conjunction with a second address in dual address mode when BKDBE=1. 0 = R/W is not used in comparisons 1 = R/W is used in comparisons BK1RW — R/W Compare Value When BK1RWE = 1, this bit determines the type of bus cycle to match. 0 = A write cycle will be matched 1 = A read cycle will be matched BK0RWE — R/W Compare Enable Enables the comparison of the R/W signal to further specify what causes a match. This bit is not useful in program breakpoints. 0 = R/W is not used in the comparisons 1 = R/W is used in comparisons BK0RW — R/W Compare Value When BK0RWE = 1, this bit determines the type of bus cycle to match on. 0 = Write cycle will be matched 1 = Read cycle will be matched MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Development Support 417 Development Support Table 20-9. Breakpoint Read/Write Control BK1RWE BK1RW BK0RWE BK0RW – – 0 X – – 0 1 1 – – X 0 1 1 1 – – – 0 1 – – – Read/Write Selected R/W is don’t care for full mode or dual mode BKP0 R/W is write for full mode or dual mode BKP0 R/W is read for full mode or dual mode BKP0 R/W is don’t care for dual mode BKP1 R/W is write for dual mode BKP1 R/W is read for dual mode BKP1 BRKAH — Breakpoint Address Register, High Byte $0022 Bit 7 6 5 4 3 2 1 Bit 0 Bit 15 14 13 12 11 10 9 Bit 8 0 0 0 0 0 0 0 0 RESET: These bits are used to compare against the most significant byte of the address bus. BRKAL — Breakpoint Address Register, Low Byte $0023 Bit 7 6 5 4 3 2 1 Bit 0 Bit 7 6 5 4 3 2 1 Bit 0 0 0 0 0 0 0 0 0 RESET: These bits are used to compare against the least significant byte of the address bus. These bits may be excluded from being used in the match if BK0ALE = 0. BRKDH — Breakpoint Data Register, High Byte $0024 Bit 7 6 5 4 3 2 1 Bit 0 Bit 15 14 13 12 11 10 9 Bit 8 0 0 0 0 0 0 0 0 RESET: These bits are compared to the most significant byte of the data bus or the most significant byte of the address bus in dual address modes. BKEN[1:0], BKDBE, and BKMBH control how this byte will be used in the breakpoint comparison. Technical Data 418 MC68HC912DT128A — Rev 4.0 Development Support MOTOROLA Development Support BRKDL — Breakpoint Data Register, Low Byte $0025 Bit 7 6 5 4 3 2 1 Bit 0 Bit 7 6 5 4 3 2 1 Bit 0 0 0 0 0 0 0 0 0 RESET: These bits are compared to the least significant byte of the data bus or the least significant byte of the address bus in dual address modes. BKEN[1:0], BKDBE, BK1ALE, and BKMBL control how this byte will be used in the breakpoint comparison. 20.6 Instruction Tagging The instruction queue and cycle-by-cycle CPU activity can be reconstructed in real time or from trace history that was captured by a logic analyzer. However, the reconstructed queue cannot be used to stop the CPU at a specific instruction, because execution has already begun by the time an operation is visible outside the MCU. A separate instruction tagging mechanism is provided for this purpose. Executing the BDM TAGGO command configures two MCU pins for tagging. The TAGLO signal shares a pin with the LSTRB signal, and the TAGHI signal shares a pin with the BKGD signal. Tagging information is latched on the falling edge of ECLK. Table 20-10 shows the functions of the two tagging pins. The pins operate independently - the state of one pin does not affect the function of the other. The presence of logic level zero on either pin at the fall of ECLK performs the indicated function. Tagging is allowed in all modes. Tagging is disabled when BDM becomes active and BDM serial commands are not processed while tagging is active. Technical Data 419 MC68HC912DT128A — Rev 4.0 Development Support MOTOROLA Development Support Table 20-10. Tag Pin Function TAGHI TAGLO Tag 1 1 no tag 1 0 low byte 0 1 high byte 0 0 both bytes The tag follows program information as it advances through the queue. When a tagged instruction reaches the head of the queue, the CPU enters active background debugging mode rather than execute the instruction. Technical Data 420 MC68HC912DT128A — Rev 4.0 Development Support MOTOROLA Technical Data — MC68HC912DT128A Section 21. Electrical Specifications 21.1 Contents 21.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 421 21.3 Tables of Data . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 422 21.2 Introduction The MC68HC912DT128A microcontroller unit (MCU) is a16-bit device composed of standard on-chip peripherals including a 16-bit central processing unit (CPU12), 128-Kbyte flash EEPROM, 8K byte RAM, 2K byte EEPROM, two asynchronous serial communications interfaces (SCI), a serial peripheral interface (SPI), an 8-channel, 16-bit timer, two16-bit pulse accumulators and 16-bit down counter (ECT), two 10-bit analog-to-digital converter (ADC), a four-channel pulse-width modulator (PWM), an IIC interface module, and three MSCAN modules. The chip is the first 16-bit microcontroller to include both byte-erasable EEPROM and flash EEPROM on the same device. System resource mapping, clock generation, interrupt control and bus interfacing are managed by the Lite integration module (LIM). The MC68HC912DT128A has full 16bit data paths throughout, however, the multiplexed external bus can operate in an 8-bit narrow mode so single 8-bit wide memory can be interfaced for lower cost systems. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Electrical Specifications 421 Electrical Specifications 21.3 Tables of Data Table 21-1. Maximum Ratings(1) Rating Symbol Value Unit VDD, VDDA, VDDX −0.3 to +6.5 V Input voltage VIN −0.3 to +6.5 V Operating temperature range TA(2) TL to TH −40 to +85 −40 to +105 −40 to +125 °C Storage temperature range Tstg −55 to +150 °C IIN ±25 mA VDD−VDDX 6.5 V Supply voltage Current drain per pin(3) Excluding VDD and VSS VDD differential voltage 1. Permanent damage can occur if maximum ratings are exceeded. Exposures to voltages or currents in excess of recommended values affects device reliability. Device modules may not operate normally while being exposed to electrical extremes. 2. Please refer to Table 1-1 to identify part numbers associated with each temperature range. 3. One pin at a time, observing maximum power dissipation limits. Internal circuitry protects the inputs against damage caused by high static voltages or electric fields; however, normal precautions are necessary to avoid application of any voltage higher than maximum-rated voltages to this high-impedance circuit. Extended operation at the maximum ratings can adversely affect device reliability. Tying unused inputs to an appropriate logic voltage level (either GND or VDD) enhances reliability of operation. NOTE: Four pins (VRL0, VRH0, VRL1, and VRH1) show ESD susceptibility below the Motorola standards. Care should be exercised in handling these pins. Technical Data 422 MC68HC912DT128A — Rev 4.0 Electrical Specifications MOTOROLA Electrical Specifications Tables of Data Table 21-2. Thermal Characteristics Characteristic Symbol Value Unit Average junction temperature TJ TA + (PD × ΘJA) °C Ambient temperature TA User-determined °C ΘJA 40 °C/W Package thermal resistance (junction-to-ambient) 112-pin quad flat pack (QFP) PINT + PI/O or (1) PD K -------------------------T J + 273°C W Device internal power dissipation PINT IDD × VDD W I/O pin power dissipation(2) PI/O User-determined W K PD × (TA + 273°C) + ΘJA × PD2 W · °C Total power dissipation A constant(3) 1. This is an approximate value, neglecting PI/O. 2. For most applications PI/O « PINT and can be neglected. 3. K is a constant pertaining to the device. Solve for K with a known TA and a measured PD (at equilibrium). Use this value of K to solve for PD and TJ iteratively for any value of TA. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Electrical Specifications 423 Electrical Specifications Table 21-3. DC Electrical Characteristics VDD = 5.0 Vdc ±10%, VSS = 0 Vdc, TA = TL to TH, unless otherwise noted Characteristic Symbol Min Max Unit Input high voltage, all inputs VIH 0.7 × VDD VDD + 0.3 V Input low voltage, all inputs VIL VSS−0.3 0.2 × VDD V VOH VDD − 0.2 VDD − 0.8 — — V V VDD − 0.2 VDD − 0.8 — — V V — — VSS+0.2 VSS+0.4 V V — — VSS+0.2 VSS+0.4 V V Output high voltage, all I/O and output pins except XTAL Normal drive strength IOH = −10.0 µA IOH = −0.8 mA Reduced drive strength IOH = −4.0 µA IOH = −0.3 mA Output low voltage, all I/O and output pins except XTAL Normal drive strength IOL = 10.0 µA IOL = 1.6 mA Reduced drive strength IOL = 3.6 µA IOL = 0.6 mA VOL Input leakage current(1) Vin = VDD or VSSAll input only pins except IRQ, ATD(2) and VFP Vin = VDD or VSSIRQ Iin — — ±2.5 ±10 µA µA Three-state leakage, I/O ports, BKGD, and RESET IOZ — ±2.5 µA Input capacitance All input pins and ATD pins (non-sampling) ATD pins (sampling) All I/O pins Cin — — — 10 15 20 pF pF pF Output load capacitance All outputs except PS[7:4] PS[7:4] when configured as SPI CL — — 90 200 pF pF Programmable active pull-up/pull-down current IRQ, XIRQ, DBE, LSTRB, R/W. ports A, B, H, J, K, P, S, T MODA, MODB active pull down during reset BKGD passive pull up IAPU 50 50 50 500 500 500 µA µA µA RAM standby voltage, power down VSB 1.5 — V RAM standby current ISB — 50 µA 1. Specification is for parts in the -40 to +85°C range. Higher temperature ranges will result in increased current leakage. 2. See Table 21-5. Technical Data 424 MC68HC912DT128A — Rev 4.0 Electrical Specifications MOTOROLA Electrical Specifications Tables of Data Table 21-4. Supply Current VDD = 5.0 Vdc ±10%, VSS = 0 Vdc, TA = TL to TH, unless otherwise noted Frequency of Operation (E-clock) Characteristic Symbol Maximum total supply current RUN: Single-chip mode Expanded mode 4 MHz(1) 8 MHz 20 30 30 50 55 90 mA mA 3 4 5 6.5 10 15 mA mA 150 150 150 µA IDD WAIT: (All peripheral functions shut down) Single-chip mode Expanded mode Unit 2 MHz(1) WIDD SIDD STOP: Single-chip mode, no clocks 1. Devices only tested at 8MHz (worst case conditions) Table 21-5. ATD DC Electrical Characteristics VDD = 5.0 Vdc ±10%, VSS = 0 Vdc, TA = TL to TH, ATD Clock = 2 MHz, unless otherwise noted Characteristic Symbol Min Max Unit Analog supply voltage VDDA 4.5 5.5 V Analog supply currentNormal operation STOP IDDA 1.0 10 mA µA Reference voltage, low VRL VSSA VDDA/2 V Reference voltage, high VRH VDDA/2 VDDA V VRH−VRL 4.5 5.5 V VINDC VSSA VDDA V VREF differential reference voltage(1) Input voltage(2) Input current, off channel(3) IOFF 100 nA Reference supply current IREF 250 µA Input capacitanceNot Sampling Sampling CINN CINS 10 15 pF pF 1. Accuracy is guaranteed at VRH − VRL = 5.0V ±10%. 2. To obtain full-scale, full-range results, VSSA ≤ VRL ≤ VINDC ≤ VRH ≤ VDDA. 3. Maximum leakage occurs at maximum operating temperature. Current decreases by approximately one-half for each 10°C decrease from maximum temperature. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Electrical Specifications 425 Electrical Specifications Table 21-6. Analog Converter Characteristics (Operating) VDD = 5.0 Vdc ±10%, VSS = 0 Vdc, TA = TL to TH, ATD Clock = 2 MHz, unless otherwise noted Characteristic Symbol 8-bit resolution(1) Min Typical 1 count 8-bit absolute error,(2)2, 4, 8, and 16 ATD sample clocks 10-bit resolution(1) 20 −1 AE 5 AE –2.5 Unit mV +1 1 count 10-bit absolute error(2) 2, 4, 8, and 16 ATD sample clocks Max count mV 2.5 count 1. At VRH – VRL = 5.12V, one 8-bit count = 20 mV, and one 10-bit count = 5mV. 2. These values include quantization error which is inherently 1/2 count for any A/D converter. Absolute errors only guaranteed when VRL=VSS, VRH=VDD and when external source impedence is close to zero. Table 21-7. ATD AC Characteristics (Operating) VDD = 5.0 Vdc ±10%, VSS = 0 Vdc, TA = TL to TH, ATD Clock = 2 MHz, unless otherwise noted Characteristic ATD operating clock frequency Conversion time per channel 0.5 MHz ≤ fATDCLK ≤ 2 MHz 16 ATD clocks 30 ATD clocks Symbol Min Max Unit fATDCLK 0.5 2.0 MHz 8.0 15.0 32.0 60.0 µs µs 10 µs tCONV Stop and ATD power up recovery time(1)VDDA = 5.0V tSR 1. From the time ADPU is asserted until the time an ATD conversion can begin. Technical Data 426 MC68HC912DT128A — Rev 4.0 Electrical Specifications MOTOROLA Electrical Specifications Tables of Data Table 21-8. ATD Maximum Ratings Characteristic Symbol Value Units ATD reference voltage VRH ≤ VDDA VRL ≥ VSSA VRH VRL −0.3 to +6.5 −0.3 to +6.5 V V VSS differential voltage |VSS−VSSA| 0.1 V VDD differential voltage VDD−VDDA VDDA−VDD 6.5 0.3 V V Reference to supply differential voltage VDDA−VRH VRH−VDDA VDDA−VRL VRL−VDDA 6.5 0.3 6.5 0.3 V VDDA−VINDC VINDC−VDDA 6.5 0.3 V Analog input differential voltage Table 21-9. EEPROM Characteristics VDD = 5.0 Vdc ±10%, VSS = 0 Vdc, TA = TL to TH, unless otherwise noted Characteristic Symbol Min Minimum programming clock frequency fPROG 250K Programming time tPROG 10 ms Clock recovery time, following STOP, to continue programming tCRSTOP tPROG+ 1 ms Erase time tERASE 10 ms Write/erase endurance Data retention Max Unit hz 10,000 cycles 10(1) years EEPROM Programming Maximum Time to ‘AUTO’ Bit Set — — 500 µs EEPROM Erasing Maximum Time to ‘AUTO’ Bit Set — — 10 ms 1. Based on the average life time operating temperature of 70°C. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Electrical Specifications 427 Electrical Specifications Table 21-10. Flash EEPROM Characteristics VDD = 5.0 Vdc ±10%, VSS = 0 Vdc, TA = TL to TH, unless otherwise noted Characteristic Symbol Min Max Units — 64 64 Bytes Read bus clock frequency fREAD 32K 8M hz Erase time tERAS 8 — ms PGM/ERAS to HVEN set up time tNVS 10 — µs High-voltage hold time tNVH 5 — µs High-voltage hold time (erase) tNVHL 100 — µs Program hold time tPGS 5 — µs tFPGM 30 40 µs Return to read time tRCV 1 — µs Cumulative program hv period tHV — 8 ms Row program/erase endurance — 100 cycles Data retention — 10(1) years Bytes per row Program time 1. Based on the average life time operating temperature of 70°C. Table 21-11. Pulse Width Modulator Characteristics VDD = 5.0 Vdc ±10%, VSS = 0 Vdc, TA = TL to TH, unless otherwise noted Characteristic Symbol Min Max Unit E-clock frequency feclk 0.004 8.0 MHz A-clock frequency Selectable faclk feclk Hz BCLK frequency Selectable fbclk feclk Hz Left-aligned PWM frequency 8-bit 16-bit flpwm feclk/1M feclk/256M feclk/2 feclk/2 Hz Hz Left-aligned PWM resolution rlpwm feclk/4K feclk Hz Center-aligned PWM frequency 8-bit 16-bit fcpwm feclk/2M feclk/512M feclk feclk Hz Hz Center-aligned PWM resolution rcpwm feclk/4K feclk Hz Technical Data 428 feclk/128 feclk/128 MC68HC912DT128A — Rev 4.0 Electrical Specifications MOTOROLA Electrical Specifications Tables of Data Table 21-12. Control Timing Characteristic Symbol 8.0 MHz Unit Min Max fo 0.004 8.0 MHz E-clock period tcyc 0.125 250 µs External oscillator frequency feo 0.5 16.0(1) MHz Processor control setup time tPCSU = tcyc/2+ 30 tPCSU 92 — PWRSTL 32 2 — — tcyc tcyc Mode programming setup time tMPS 4 — tcyc Mode programming hold time tMPH 20 — ns PWIRQ 270 — ns tWRS — 4 cycles PWTIM 270 — ns Frequency of operation Reset input pulse width To guarantee external reset vector Minimum input time (can be preempted by internal reset) Interrupt pulse width, IRQ edge-sensitive mode PWIRQ = 2tcyc + 20 Wait recovery startup time Timer input capture pulse width ns 1. When using a resonator (quartz or ceramic), see Table 21-17 for allowable values. NOTE: RESET is recognized during the first clock cycle it is held low. Internal circuitry then drives the pin low for 16 clock cycles, releases the pin, and samples the pin level 9 cycles later to determine the source of the interrupt. PT[7:0]1 PWTIM PT[7:0]2 PT71 PWPA PT72 NOTES: 1. Rising edge sensitive input 2. Falling edge sensitive input Figure 21-1. Timer Inputs MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Electrical Specifications 429 430 Technical Data Electrical Specifications FFFE 4098 tcyc NOTE: Reset timing is subject to change. INTERNAL ADDRESS MODA, MODB RESET ECLK EXTAL VDD FFFE FREE 1ST PIPE 2ND PIPE 3RD PIPE tPCSU 1ST EXEC FFFE FFFE tMPS PWRSTL FFFE FREE tMPH 1ST PIPE 2ND PIPE 3RD PIPE 1ST EXEC Electrical Specifications Figure 21-2. POR and External Reset Timing Diagram MC68HC912DT128A — Rev 4.0 MOTOROLA MOTOROLA MC68HC912DT128A — Rev 4.0 Electrical Specifications SP-6 SP-6 SP-8 SP-8 SP-9 SP-9 PWIRQ NOTES: 1. Edge Sensitive IRQ pin (IRQE bit = 1) 2. Level sensitive IRQ pin (IRQE bit = 0) 3. tSTOPDELAY = 4098 tcyc if DLY bit = 1 or 2 tcyc if DLY = 0. 4. XIRQ with X bit in CCR = 1. 5. IRQ or (XIRQ with X bit in CCR = 0). ADDRESS5 ADDRESS4 ECLK IRQ or XIRQ IRQ1 INTERNAL CLOCKS tSTOPDELAY3 FREE FREE OPT FETCH 1ST EXEC FREE 1ST PIPE 2ND PIPE 3RD PIPE 1ST EXEC Resume program with instruction which follows the STOP instruction. VECTOR FREE Electrical Specifications Tables of Data Figure 21-3. STOP Recovery Timing Diagram Technical Data 431 432 Technical Data Electrical Specifications SP – 2 NOTE: RESET also causes recovery from WAIT. R/W ADDRESS IRQ, XIRQ, OR INTERNAL INTERRUPTS ECLK SP – 6 . . . SP – 9 PC, IY, IX, B:A, , CCR STACK REGISTERS SP – 4 SP – 9 SP – 9 . . . SP – 9 SP – 9 tPCSU VECTOR ADDRESS tWRS FREE 1ST PIPE 2ND PIPE 3RD PIPE 1ST EXEC Electrical Specifications Figure 21-4. WAIT Recovery Timing Diagram MC68HC912DT128A — Rev 4.0 MOTOROLA MOTOROLA MC68HC912DT128A — Rev 4.0 Electrical Specifications VECT DATA NOTES: 1. Edge sensitive IRQ pin (IRQE bit = 1) 2. Level sensitive IRQ pin (IRQE bit = 0) R/W VECTOR ADDR PWIRQ tPCSU ADDRESS OR INTERNAL INTERRUPT IRQ2, XIRQ, IRQ 1 ECLK PC SP – 2 PROG FETCH 1ST PIPE IY SP – 4 IX SP – 6 PROG FETCH 2ND PIPE B:A SP – 8 CCR SP – 9 PROG FETCH 3RD PIPE 1ST EXEC Electrical Specifications Tables of Data Figure 21-5. Interrupt Timing Diagram Technical Data 433 Electrical Specifications Table 21-13. Peripheral Port Timing 8.0 MHz Characteristic Symbol Unit Min Max fo 0.004 8.0 MHz tcyc 0.125 250 µs Peripheral data setup time MCU read of ports tPDSU 81 — ns Peripheral data hold time MCU read of ports tPDH 0 — ns Delay time, peripheral data write MCU write to ports except Port CAN tPWD — 40 ns Delay time, peripheral data write MCU write to Port CAN tPWD — 71 ns Frequency of operation (E-clock frequency) E-clock period MCU READ OF PORT ECLK tPDSU tPDH PORTS PORT RD TIM Figure 21-6. Port Read Timing Diagram MCU WRITE TO PORT ECLK tPWD PORT A PREVIOUS PORT DATA NEW DATA VALID PORT WR TIM Figure 21-7. Port Write Timing Diagram Technical Data 434 MC68HC912DT128A — Rev 4.0 Electrical Specifications MOTOROLA Electrical Specifications Tables of Data Table 21-14. Multiplexed Expansion Bus Timing VDD = 5.0 Vdc ± 10%, VSS = 0 Vdc, TA = TL to TH, unless otherwise noted Characteristic(1), (2), (3), (4) Num Delay Frequency of operation (E-clock frequency) Symbol 8 MHz Unit Min Max fo 0.004 8.0 MHz 250 µs 1 Cycle timetcyc = 1/fo — tcyc 0.125 2 Pulse width, E lowPWEL = tcyc/2 + delay −2 PWEL 60 ns 3 Pulse width, E high(5)PWEH = tcyc/2 + delay −2 PWEH 60 ns 5 Address delay timetAD = tcyc/4 + delay 14 tAD 7 Address valid time to ECLK risetAV = PWEL − tAD — tAV 15 ns 8 Multiplexed address hold timetMAH = tcyc/4 + delay −16 tMAH 15 ns 9 Address Hold to Data Valid — tAHDS 5 ns 10 Data Hold to High ZtDHZ = tAD − 20 — tDHZ 11 Read data setup time — tDSR 38 ns 12 Read data hold time — tDHR 0 ns 13 Write data delay timetDDW = tcyc/4 + delay 14 tDDW 14 Write data hold timetDHW = tcyc/4 + delay −11 tDHW 20 ns 15 Write data setup time(5)tDSW = PWEH − tDDW — tDSW 15 ns 16 Read/write delay timetRWD = tcyc/4 + delay 19 tRWD 17 Read/write valid time to E risetRWV = PWEL − tRWD — tRWV 10 ns 18 Read/write hold timetRWH = tcyc/4 + delay −26 tRWH 5 ns 19 Low strobe(6) delay timetLSD = tcyc/4 + delay 26 tLSD 20 Low strobe(6) valid time to E risetLSV = PWEL − tLSD — tLSV 3 ns 21 Low strobe(6) hold timetLSH = tcyc/4 + delay −26 tLSH 5 ns 22 Address access time(5)tACCA = tcyc − tAD − tDSR — tACCA 26 ns 23 Access time from E rise(5)tACCE = PWEH − tDSR — tACCE 22 ns 24 DBE delay from ECLK rise(5)tDBED = tcyc/4 + delay 20 tDBED 51 ns 25 DBE valid timetDBE = PWEH − tDBED — tDBE 9 26 DBE hold time from ECLK fall tDBEH 0 45 20 45 50 57 ns ns ns ns ns ns 10 ns 1. All timings are calculated for normal port drives. 2. Crystal input is required to be within 45% to 55% duty. 3. Reduced drive must be off to meet these timings. 4. Unequalled loading of pins will affect relative timing numbers. 5. This characteristic is affected by clock stretch. Add N × tcyc where N = 0, 1, 2, or 3, depending on the number of clock stretches. 6. Without TAG enabled. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Electrical Specifications 435 Electrical Specifications 1 2 3 ECLK 16 17 18 19 20 21 R/W LSTRB (W/O TAG ENABLED) 5 23 7 11 22 10 READ 12 ADDRESS ADDRESS/DATA MULTIPLEXED DATA 9 8 13 WRITE ADDRESS 15 14 DATA 24 25 26 DBE NOTE: Measurement points shown are 20% and 70% of VDD Figure 21-8. Multiplexed Expansion Bus Timing Diagram Technical Data 436 MC68HC912DT128A — Rev 4.0 Electrical Specifications MOTOROLA Electrical Specifications Tables of Data Table 21-15. SPI Timing (VDD = 5.0 Vdc ±10%, VSS = 0 Vdc, TA = TL to TH , 200 pF load on all SPI pins)(1) Function Symbol Min Max Unit Operating Frequency Master Slave fop 1/256 1/256 1/2 1/2 feclk SCK Period Master Slave tsck 2 2 256 — tcyc tcyc Enable Lead Time Master Slave tlead 1/2 1 — — tsck tcyc Enable Lag Time Master Slave tlag 1/2 1 — — tsck tcyc twsck tcyc − 30 tcyc − 30 128 tcyc — ns ns Sequential Transfer Delay Master Slave ttd 1/2 1 — — tsck tcyc Data Setup Time (Inputs) Master Slave tsu 30 30 — — ns ns Data Hold Time (Inputs) Master Slave thi 0 30 — — ns ns Slave Access Time ta — 1 tcyc Slave MISO Disable Time tdis — 1 tcyc Data Valid (after SCK Edge) Master Slave tv — — 50 50 ns ns Data Hold Time (Outputs) Master Slave tho 0 0 — — ns ns Rise Time Input Output tri tro — — tcyc − 30 30 ns ns Fall Time Input Output tfi tfo — — tcyc − 30 30 ns ns Num Clock (SCK) High or Low Time Master Slave 1. All AC timing is shown with respect to 20% VDD and 70% VDD levels unless otherwise noted. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Electrical Specifications 437 Electrical Specifications SS1 (OUTPUT) 5 2 1 SCK (CPOL = 0) (OUTPUT) 3 12 4 4 13 SCK (CPOL = 1) (OUTPUT) 6 7 MISO (INPUT) MSB IN2 BIT 6 . 10 . . 1 LSB IN 10 MOSI (OUTPUT) MSB OUT2 11 BIT 6 . . . 1 LSB OUT 1. SS output mode (DDS7 = 1, SSOE = 1). 2. LSBF = 0. For LSBF = 1, bit order is LSB, bit 1, ..., bit 6, MSB. A) SPI Master Timing (CPHA = 0) SS1 (OUTPUT) 5 1 2 13 12 12 13 3 SCK (CPOL = 0) (OUTPUT) 4 4 SCK (CPOL = 1) (OUTPUT) 6 MISO (INPUT) 7 MSB IN2 . . 1 LSB IN 11 10 MOSI (OUTPUT) PORT DATA BIT 6 . MASTER MSB OUT2 BIT 6 . . . 1 MASTER LSB OUT PORT DATA 1. SS output mode (DDS7 = 1, SSOE = 1). 2. LSBF = 0. For LSBF = 1, bit order is LSB, bit 1, ..., bit 6, MSB. B) SPI Master Timing (CPHA = 1) Figure 21-9. SPI Timing Diagram (1 of 2) Technical Data 438 MC68HC912DT128A — Rev 4.0 Electrical Specifications MOTOROLA Electrical Specifications Tables of Data SS (INPUT) 5 1 13 12 12 13 3 SCK (CPOL = 0) (INPUT) 4 2 4 SCK (CPOL = 1) (INPUT) 9 8 MISO (OUTPUT) 10 MSB OUT SLAVE 6 MOSI (INPUT) 11 11 BIT 6 . . . BIT 6 . . . 1 SLAVE LSB OUT SEE NOTE 7 MSB IN 1 LSB IN NOTE: Not defined but normally MSB of character just received. A) SPI Slave Timing (CPHA = 0) SS (INPUT) 5 3 1 2 13 12 12 13 SCK (CPOL = 0) (INPUT) 4 4 SCK (CPOL = 1) (INPUT) MISO (OUTPUT) SEE NOTE 8 MOSI (INPUT) SLAVE 6 9 11 10 MSB OUT BIT 6 . . . 1 SLAVE LSB OUT 7 MSB IN BIT 6 . . . 1 LSB IN NOTE: Not defined but normally LSB of character just received. SPI SLAVE CPHA1 B) SPI Slave Timing (CPHA = 1) Figure 21-10. SPI Timing Diagram (2 of 2) MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Electrical Specifications 439 Electrical Specifications Table 21-16. CGM Characteristics 5.0 Volts +/- 10% Characteristic Symbol Min. Max. Unit PLL reference frequency fREF 0.5 8 MHz Bus frequency fBUS 0.004 8 MHz VCO range fVCO 2.5 8 MHz fVCOMIN 0.5 2.5 MHz ∆trk 3% 4% — ∆Lock 0% 1.5% — Un-Lock Detection ∆unl 0.5% 2.5% — Lock Detector transition from Tracking to Acquisition mode ∆unt 6% 8% — VCO Limp-Home frequency Lock Detector transition from Acquisition to Tracking mode Lock Detection PLLON Stabilization delay(1) PLLON Total Stabilization delay(2) tstab 3 ms PLLON Acquisition mode stabilization delay(3) tacq 1 ms tal 2 ms PLLON Tracking mode stabilization delay(3) 1. PLL stabilization delay is highly dependent on operational requirement and external component values (e.e. crystal, XFC filter component values). Note (2) shows typical delay values for a typical configuration. Appropriate XFC filter values should be chosen based on operational requirement of system. 2. fREF = 4MHz, fSYS = 8MHz (REFDV = #$00, SYNR = #$01), XFC: Cs = 33nF, Cp - 3.3nF, Rs = 2.7KΩ. Table 21-17. Oscillator Characteristics MC68HC912DT128A MC68HC912Dx128C MC68HC912Dx128P Unit Input buffer hysteresis(1) Min Max 0 50 75 350 75 350 mV Resonator Frequency(2) (VDDPLL=VDD) Min Max 0.5 8 0.5 8 0.5 8 MHz Resonator Frequency(2) (VDDPLL=0V) Min Max 4 10 4 10 0.5 16 MHz 1. These values are dervied from design simulation and are not tested 2. Specifications apply to quartz or ceramic resonators only Table 21-18. STOP Key Wake-up Filter Characteristic Symbol Min. Max. STOP Key Wake-Up Filter time STOP Key Wake-Up Filter pulse interval tKWSTP 2 10 µs tKWSP 20 - µs Technical Data 440 Unit MC68HC912DT128A — Rev 4.0 Electrical Specifications MOTOROLA Technical Data — MC68HC912DT128A Section 22. Appendix: Changes from MC68HC912DG128 22.1 Contents 22.2 22.2.1 22.2.2 22.2.3 22.2.4 22.2.5 22.2.6 22.2.7 Significant changes from the MC68HC912DG128 (non-suffix device) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .441 Flash. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .441 EEPROM . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .442 STOP mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 443 WAIT mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 444 KWU Filter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .444 Port ADx . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 444 ATD . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 444 22.2 Significant changes from the MC68HC912DG128 (non-suffix device) 22.2.1 Flash 22.2.1.1 Flash Architecture The flash arrays are made from a new non-volatile memory (NVM) technology. An external VFP is no longer used. Programming is now carried out on a whole row (64 bytes) at a time. Erasing is still a bulk erase of the entire array. 22.2.1.2 Flash Control Register The Flash Control Register (FEECTL) is in the same location. However, the individual bit functions have changed significantly to support the new technology. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Appendix: Changes from MC68HC912DG128 441 Appendix: Changes from MC68HC912DG128 22.2.1.3 Flash Programming Procedure Programming of the flash is greatly simplified over previous HC12s. The read / verify / re-pulse programming algorithm is replaced by a much simpler method. 22.2.1.4 Flash Programming Time The most significant change resulting from the new flash technology is that the bulk erase and program times are now fixed. The erase time is at least twice as fast while the word programming time is at least 20% faster. 22.2.1.5 Flash External Programming Voltage The new flash does not require an external high voltage supply. All voltages required for programming and erase are now generated internally. Pin 97 that was the VFP pin on the 68HC912DG128 is now a factory TEST pin. On ealy production devices it is recommended that this pin is not connected within the application, but it may be connected to VSS or 5.5V max without issue. 22.2.2 EEPROM 22.2.2.1 EEPROM Architecture Like the flash, the EEPROM is also made from this new NVM technology. The architecture and basic programming and erase operations are unchanged. However, there is a new optional programming method that allows faster programming of the EEPROM. 22.2.2.2 EEPROM Clock Source and Pre-scaler The first major difference on the new EEPROM is that it requires a constant time base source to ensure secure programming and erase operations. The clock source that is going to drive the clock divider input is the external clock input, EXTALi. The divide ratio from this source has Technical Data 442 MC68HC912DT128A — Rev 4.0 Appendix: Changes from MC68HC912DG128 MOTOROLA Appendix: Changes from MC68HC912DG128 Significant changes from the MC68HC912DG128 (non-suffix device) to be set by programming an 10-bit time base pre-scalar into bits spread over two new registers, EEDIVH and EEDIVL. The EEDIVH and EEDIVL registers are volatile. However, they are loaded upon reset by the contents of the non-volatile SHADOW word much in the same way as the EEPROM module control register (EEMCR) bits interact with the SHADOW word for configuration control on the existing revision. 22.2.2.3 EEPROM AUTO programming & erasing The second major change to the EEPROM is the inclusion in the EEPROM control register (EEPROG) of an AUTO function using the previously unused bit 5 of this register. The AUTO function enables the logic of the MCU to automatically use the optimum programming or erasing time for the EEPROM. If using AUTO, the user does not need to wait for the normal minimum specified programming or erasing time. After setting the EEPGM bit as normal the user just has to poll that bit again, waiting for the MCU to clear it indicating that programming or erasing is complete. 22.2.2.4 EEPROM Selective Write More Zeros For some applications it may be advantageous to track more than 10k events with a single byte of EEPROM by programming one bit at a time. For that purpose, a special selective bit programming technique is available. When this technique is utilized, a program / erase cycle is defined as multiple writes (up to eight) to a unique location followed by a single erase sequence. 22.2.3 STOP mode This new version will correctly exit STOP mode without having to synchronize the start of STOP with the RTI clock. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Appendix: Changes from MC68HC912DG128 443 Appendix: Changes from MC68HC912DG128 22.2.4 WAIT mode This new version will correctly exit WAIT mode using short XIRQ or IRQ inputs. 22.2.5 KWU Filter The KWU filter will now ignore pulses shorter than 2 microseconds. 22.2.6 Port ADx Power must be applied to VDDA at all times even if the ADC is not being used. This is necessary for port AD0 and port AD1 to function correctly as digital inputs. 22.2.7 ATD 22.2.7.1 Channel Selection Any channel can be selected for the first conversion of a multiple channel conversion. Bits CA, CB & CC in ATDxCTL5 do not get masked but are used to select which channel is used to start the sequential conversion sequence. For compatibilty, ensure that the appropriate bits are cleared in the software. See Table 19-8. Bit CC of ATDxCTL5 is not masked when bit S8CM = 1. 22.2.7.2 CD bit Bit CD in ATDxCTL5 is renamed SC to differentiate it from extended functionality of bits CA, CB & CC. Functionality is unchanged as it still selects conversion from the internal reference sources but when doing a multiple channel scan, bits CA, CB & CC must be cleared as appropriate for compatible reference selection. Technical Data 444 MC68HC912DT128A — Rev 4.0 Appendix: Changes from MC68HC912DG128 MOTOROLA Appendix: Changes from MC68HC912DG128 Significant changes from the MC68HC912DG128 (non-suffix device) 22.2.7.3 Additional Features ATD flexibility has been increased with additional signed result, data justification, single conversion selection and results location FIFO features. DJM & DSGN bits have been added to ATDxCTL2 register. Default values are compatible with MC68HC912DG128 functionality. FIFO & S1C bits have been added to ATDxCTL3 register. Default values are compatible with MC68HC912DG128 functionality. 22.2.7.4 S8CM bit Bit S8CM in ATDxCTL5 is renamed S8C. Functionality is compatible with S8CM but can now be modified by the new S1C bit in ATDxCTL3. The default is compatible with MC68HC912DG128 functionality. 22.2.7.5 Writing to ATDxCTL4 Writing to ATDxCTL4 aborts any ongoing conversion sequence and initiates a new conversion sequence. Previously it only aborted ongoing sequences leaving the ATD in idle mode (no conversion sequences being processed). Writing to ATDxCTL2 or ADTxCTL3 also does not abort an ongoing conversion sequence. Previously writing these registers also aborted any ongoing sequence leaving the ATD in idle mode . This is unlikely to be a compatibility issue as applications mostly write these registers to configure the ATD, closely followed by a write to ATDxCTL5 to initiate a new conversion sequence which does abort any ongoing conversion sequence and resets the appropriate flags. To ensure compatibility, the application should not rely on ongoing conversions being aborted. Also any interrupts from the completion of an ongoing sequence should be masked and/or handled correctly. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Appendix: Changes from MC68HC912DG128 445 Appendix: Changes from MC68HC912DG128 22.2.7.6 SCF bit In SCAN mode (SCAN bit = 1 in ATDxCTL5) the Sequence Complete Flag (SCF bit in ATDSTATx) is set after completion of each conversion sequence. Previously it was only set at the end of the first conversion sequence. To ensure compatibility the application should not rely on this flag being set only once per SCAN mode. 22.2.7.7 ATDTESTx Reading the ATDTESTx register in nornal modes returns the value of the Successive Approximation Register (SAR). Previously it always read as zero. The RST bit in the ATDTESTx register can be written in normal modes (in order to reset the ATD). Previously it was read only. To ensure compatibility this register should not be read or written to. Technical Data 446 MC68HC912DT128A — Rev 4.0 Appendix: Changes from MC68HC912DG128 MOTOROLA Technical Data — MC68HC912DT128A Section 23. Appendix: CGM Practical Aspects 23.1 Contents 23.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 447 23.3 Practical Aspects For The PLL Usage . . . . . . . . . . . . . . . . . .447 23.4 Printed Circuit Board Guidelines. . . . . . . . . . . . . . . . . . . . . . .453 23.2 Introduction This sections provides useful and practical pieces of information concerning the implementation of the CGM module. 23.3 Practical Aspects For The PLL Usage 23.3.1 Synthesized Bus Frequency Starting from a ceramic resonator or quartz crystal frequency FXTAL, if ‘refdv’ and ‘synr’ are the decimal content of the REFDV and SYNR registers respectively, then the MCU bus frequency will simply be: F XTAL ⋅ ( synr + 1 ) F BUS = F VCO = ----------------------------------------------( refdv + 1 ) synr ∈ { 0,1,2,3...63} refdv ∈ { 0,1,2,3...7} NOTE: It is not allowed to synthesize a bus frequency that is lower than the crystal frequency, as the correct functioning of some internal MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Appendix: CGM Practical Aspects 447 Appendix: CGM Practical Aspects synchronizers would be jeopardized (e.g. the MCLK and XCLK clock generators). 23.3.2 Operation Under Adverse Environmental Conditions The normal operation for the PLL is the so-called ‘automatic bandwidth selection mode’ which is obtained by having the AUTO bit set in the PLLCR register. When this mode is selected and as the VCO frequency approaches its target, the charge pump current level will automatically switch from a relatively high value of around 40 µA to a lower value of about 3 µA. It can happen that this low level of charge pump current is not enough to overcome leakages present at the XFC pin due to adverse environmental conditions. These conditions are frequently encountered for uncoated PCBs in automotive applications. The main symptom for this failure is an unstable characteristic of the PLL which in fact ‘hunts’ between acquisition and tracking modes. It is then advised for the running software to place the PLL in manual, forced acquisition mode by clearing both the AUTO and the ACQ bits in the PLLCR register. Doing so will maintain the high current level in the charge pump constantly and will permit to sustain higher levels of leakages at the XFC pin. This latest revision of the Clock Generator Module maintains the lock detection feature even in manual bandwidth control, offering then to the application software the same flexibility for the clocking control as the automatic mode. 23.3.3 Filter Components Selection Guide 23.3.3.1 Equations Set These equations can be used to select a set of filter components. Two cases are considered: 1. The ‘tracking’ mode. This situation is reached normally when the PLL operates in automatic bandwidth selection mode (AUTO=1 in the PLLCR register). 2. The ‘acquisition’ mode. This situation is reached when the PLL operates in manual bandwidth selection mode and forced Technical Data 448 MC68HC912DT128A — Rev 4.0 Appendix: CGM Practical Aspects MOTOROLA Appendix: CGM Practical Aspects Practical Aspects For The PLL Usage acquisition (AUTO=0, ACQ=0 in the PLLCR register). In both equations, the power supply should be 5V. Start with the target loop bandwidth as a function of the other parameters, but obviously, nothing prevents the user from starting with the capacitor value for example. Also, remember that the smoothing capacitor is always assumed to be one tenth of the series capacitance value. So with: m: R: C: Fbus: ζ: Fc: the multiplying factor for the reference frequency (i.e. (synr+1)) the series resistance of the low pass filter in Ω the series capacitance of the low pass filter in nF the target bus frequency expressed in MHz the desired damping factor the desired loop bandwidth expressed in Hz for the ‘tracking’ mode: 9 2 – F bus⎞ ⎛ 1.675 ---------------------------⎝ 10.795 ⎠ 2 ⋅ 10 ⋅ ζ 37.78 ⋅ e ⋅R F c = ------------------------- = -----------------------------------------------------π⋅R⋅C 2⋅π⋅m and for the ‘acquisition’ mode: 9 2 – F bus⎞ ⎛ 1.675 ---------------------------⎝ 10.795 ⎠ 415.61 ⋅ e 2 ⋅ 10 ⋅ ζ ⋅R F c = ------------------------- = --------------------------------------------------------π⋅R⋅C 2⋅π⋅m 23.3.3.2 Particular Case of an 8MHz Synthesis Assume that a desired value for the damping factor of the second order system is close to 0.9 as this leads to a satisfactory transient response. Then, derived from the equations above, Table 23-1 and Table 23-2 suggest sets of values corresponding to several loop bandwidth possibilities in the case of an 8MHz synthesis for the two cases mentioned above. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Appendix: CGM Practical Aspects 449 Appendix: CGM Practical Aspects The filter components values are chosen from standard series (e.g. E12 for resistors). The operating voltage is assumed to be 5V (although there is only a minor difference between 3V and 5V operation). The smoothing capacitor Cp in parallel with R and C is set to be 1/10 of the value of C. The reference frequencies mentioned in this table correspond to the output of the fine granularity divider controlled by the REFDV register. This means that the calculations are irrespective of the way the reference frequency is generated (directly for the crystal oscillator or after division). The target frequency value also has an influence on the calculations of the filter components because the VCO gain is NOT constant over its operating range. The bandwidth limit corresponds to the so-called Gardner’s criteria. It corresponds to the maximum value that can be chosen before the continuous time approximation ceases to be justified. It is of course advisable to stay far away from this limit. Technical Data 450 MC68HC912DT128A — Rev 4.0 Appendix: CGM Practical Aspects MOTOROLA Appendix: CGM Practical Aspects Practical Aspects For The PLL Usage Table 23-1. Suggested 8MHz Synthesis PLL Filter Elements (Tracking Mode) Reference [MHz] SYNR Fbus [MHz] C [nF] R [kΩ] Loop Bandwidth [kHz] Bandwidth Limit [kHz] 0.614 $0C 7.98 100 4.3 1.1 157 0.614 $0C 7.98 4.7 20 5.3 157 0.614 $0C 7.98 1 43 11.5 157 0.614 $0C 7.98 0.33 75 20 157 0.8 $09 8.00 220 2.7 0.9 201 0.8 $09 8.00 10 12 4.2 201 0.8 $09 8.00 2.2 27 8.6 201 0.8 $09 8.00 0.47 56 19.2 201 1 $07 8.00 220 2.4 1 251 1 $07 8.00 10 11 4.7 251 1 $07 8.00 2.2 24 9.9 251 1 $07 8.00 0.47 51 21.4 251 1.6 $05 8.00 330 1.5 1 402 1.6 $05 8.00 10 9.1 5.9 402 1.6 $05 8.00 3.3 15 10.2 402 1.6 $05 8.00 1 27 18.6 402 2 $03 8.00 470 1.1 0.96 502 2 $03 8.00 22 5.1 4.4 502 2 $03 8.00 4.7 11 9.6 502 2 $03 8.00 1 24 20.8 502 2.66 $02 8.00 220 1.5 1.6 668 2.66 $02 8.00 22 4.7 5.1 668 2.66 $02 8.00 4.7 10 11 668 2.66 $02 8.00 1 22 24 668 4 $01 8.00 220 1.2 1.98 1005 4 $01 8.00 33 3 5.1 1005 4 $01 8.00 10 5.6 9.3 1005 4 $01 8.00 2.2 12 19.8 1005 MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Appendix: CGM Practical Aspects 451 Appendix: CGM Practical Aspects Table 23-2. Suggested 8MHz Synthesis PLL Filter Elements (Acquisition Mode) Reference [MHz] SYNR Fbus [MHz] C [nF] R [kΩ] Loop Bandwidth [kHz] Bandwidth Limit [kHz] 0.614 $0C 7.98 1000 0.43 1.2 157 0.614 $0C 7.98 47 2 5.5 157 0.614 $0C 7.98 10 4.3 12 157 0.614 $0C 7.98 3.3 7.5 21 157 0.8 $09 8.00 2200 0.27 0.9 201 0.8 $09 8.00 100 1.2 4.4 201 0.8 $09 8.00 22 2.4 9.3 201 0.8 $09 8.00 4.7 5.6 20.1 201 1 $07 8.00 2200 0.22 1 251 1 $07 8.00 100 1 4.8 251 1 $07 8.00 2. 2.2 10.4 251 1 $07 8.00 4.7 4.7 22.5 251 1.6 $05 8.00 3300 0.15 1.1 402 1.6 $05 8.00 100 0.82 6.2 402 1.6 $05 8.00 33 1.5 10.7 402 1.6 $05 8.00 10 2.7 19.5 402 2 $03 8.00 4700 0.1 1 502 2 $03 8.00 220 0.51 4.6 502 2 $03 8.00 47 1 10 502 2 $03 8.00 10 2.4 21.8 502 2.66 $02 8.00 2200 0.12 1.7 668 2.66 $02 8.00 220 0.43 5.3 668 2.66 $02 8.00 47 1 11.6 668 2.66 $02 8.00 10 2 25.1 668 4 $01 8.00 2200 0.1 2.1 1005 4 $01 8.00 330 0.27 5.4 1005 4 $01 8.00 100 0.51 9.7 1005 4 $01 8.00 22 1 20.8 1005 Technical Data 452 MC68HC912DT128A — Rev 4.0 Appendix: CGM Practical Aspects MOTOROLA Appendix: CGM Practical Aspects Printed Circuit Board Guidelines 23.4 Printed Circuit Board Guidelines Printed Circuit Boards (PCBs) are the board of choice for volume applications. If designed correctly, a very low noise system can be built on a PCB with consequently good EMI/EMC performances. If designed incorrectly, PCBs can be extremely noisy and sensitive modules, and the CGM could be disrupted. Some common sense rules can be used to prevent such problems. • Use a ‘star’ style power routing plan as opposed to a ‘daisy chain’. Route power and ground from a central location to each chip individually, and use the widest trace practical (the more the chip draws current, the wider the trace). NEVER place the MCU at the end of a long string of serially connected chips. • When using PCB layout software, first direct the routing of the power supply lines as well as the CGM wires (crystal oscillator and PLL). Layout constraints must be then reported on the other signals and not on these ‘hot’ nodes. Optimizing the ‘hot’ nodes at the end of the routing process usually gives bad results. • Avoid notches in power traces. These notches not only add resistance (and are not usually accounted for in simulations), but they can also add unnecessary transmission line effects. • Avoid ground and power loops. This has been one of the most violated guidelines of PCB layout. Loops are excellent noise transmitters and can be easily avoided. When using multiple layer PCBs, the power and ground plane concept works well but only when strictly adhered to (do not compromise the ground plane by cutting a hole in it and running signals on the ground plane layer). Keep the spacing around via holes to a minimum (but not so small as to add capacitive effects). • Be aware of the three dimensional capacitive effects of multilayered PCBs. • Bypass (decouple) the power supplies of all chips as close to the chip as possible. Use one decoupling capacitor per power supply pair (VDD/VSS, VDDX/VSSX...). Two capacitors with a ratio of about 100 sometimes offer better performances over a broader MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Appendix: CGM Practical Aspects 453 Appendix: CGM Practical Aspects spectrum. This is especially the case for the power supply pins close to the E port, when the E clock and/or the calibration clock are used. • On the general VDD power supply input, a ‘T’ low pass filter LCL can be used (e.g. 10µH-47µF-10µH). The ‘T’ is preferable to the ‘Π’ version as the exhibited impedance is more constant with respect to the VDD current. Like many modular micro controllers, HC12 devices have a power consumption which not only varies with clock edges but also with the functioning modes. • Keep high speed clock and bus trace length to a minimum. The higher the clock speed, the shorter the trace length. If noisy signals are sent over long tracks, impedance adjustments should be considered at both ends of the line (generally, simple resistors suffice). • Bus drivers like the CAN physical interface should be installed close to their connector, with dedicated filtering on their power supply. • Mount components as close to the board as possible. Snip excess lead length as close to the board as possible. Preferably use Surface Mount Devices (SMDs). • Mount discrete components as close to the chip that uses them as possible. • Do not cross sensitive signals ON ANY LAYER. If a sensitive signal must be crossed by another signal, do it as many layers away as possible and at right angles. • Always keep PCBs clean. Solder flux, oils from fingerprints, humidity and general dirt can conduct electricity. Sensitive circuits can easily be disrupted by small amounts of leakage. • Choose PCB coatings with care. Certain epoxies, paints, gelatins, plastics and waxes can conduct electricity. If the manufacturer cannot provide the electrical characteristics of the substance, do not use it. Technical Data 454 MC68HC912DT128A — Rev 4.0 Appendix: CGM Practical Aspects MOTOROLA Appendix: CGM Practical Aspects Printed Circuit Board Guidelines In addition to the above general pieces of advice, the following guidelines should be followed for the CGM pins (but also more generally for any sensitive analog circuitry): • Parasitic capacitance on EXTAL is absolutely critical – probably the most critical layout consideration. The XTAL pin is not as sensitive. All routing from the EXTAL pin through the resonator and the blocking cap to the actual connection to VSS must be considered. • For minimum capacitance there should ideally be no ground / power plane around the EXTAL pin and associated routing. However, practical EMC considerations obviously should be taken into consideration for each application. • The clock input circuitry is sensitive to noise so excellent supply routing and decoupling is mandatory. Connect the ground point of the oscillator circuit directly to the VSSPLL pin. • Good isolation of PLL / Oscillator Power supply is critical. Use 1nF+ 100nF and keep tracks as low impedance as possible • Load capacitors should be low leakage and stable across temperature – use NPO or C0G types. • The load capacitors may ‘pull’ the target frequency by a few ppm. Crystal manufacturer specs show symmetrical values but the series device capacitance on EXTAL and XTAL are not symmetrical. It may be possible to adjust this by changing the values of the load capacitors – start-up conditions should be evaluated. • Keep the adjacent Port H / Port E and RESET signals noise free. Don’t connect these to external signals and / or add series filtering – a series resistor is probably adequate. • Any DC-blocking capacitor should be as low ESR as possible – for the range of crystals we are looking at anything over 1 Ohm is too much. • Mount oscillator components on MCU side of board – avoid using vias in the oscillator circuitry. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Appendix: CGM Practical Aspects 455 Appendix: CGM Practical Aspects • Mount the PLL filter and oscillator components as close to the MCU as possible. • Do not allow the EXTAL and XTAL signals to interfere with the XFC node. Keep these tracks as short as possible. • Do not cross the CGM signals with any other signal on any level. • Remember that the reference voltage for the XFC filter is VDDPLL. • As the return path for the oscillator circuitry is VSSPLL, it is extremely important to CONNECT VSSPLL to VSS even if the PLL is not to be powered. Surface mount components reduce the susceptibility of signal contamination. Technical Data 456 MC68HC912DT128A — Rev 4.0 Appendix: CGM Practical Aspects MOTOROLA Technical Data — MC68HC912DT128A Section 24. Appendix: Information on MC68HC912DT128A Mask Set Changes 24.1 Contents 24.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 457 24.3 Oscillator – Major Changes . . . . . . . . . . . . . . . . . . . . . . . . . .457 24.4 Flash Protection Feature . . . . . . . . . . . . . . . . . . . . . . . . . . . . 458 24.5 Clock Circuitry. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .458 24.6 Pseudo Stop Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 458 24.7 Oscillator – Minor Changes . . . . . . . . . . . . . . . . . . . . . . . . . .459 24.8 PLL . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 459 24.2 Introduction The following improvements were made to create the 1L05H mask set (MC68HC912Dx128C) and the 2L05H mask set (MC68HC912Dx128P). Previous MC68HC912DT128A mask sets 3K91D (TSMC wafer fab.) and 0L05H (Motorola TSC6 wafer fab.) are equivalent with the only change being the wafer fab location. 24.3 Oscillator – Major Changes The following are the primary differences between the previous Colpitts ("A") and the new Colpitts ("C") oscillator configurations. 1. Optimisation of the bias current to the amplifier for less process variation. 2. Addition of hysteresis to the clock input buffer to reduce sensitivity to noise. MC68HC912DT128A — Rev 4.0 MOTOROLA Appendix: Information on MC68HC912DT128A Mask Set Changes Technical Data 457 Appendix: Information on MC68HC912DT128A 3. Change to the input ESD resistor from EXTAL to the gate of the oscillator amplifier to provide a parallel path, reducing parasitic phase shift in the oscillator. Additionally a new Pierce ("P") oscillator configurations has been added. See Section 13. Oscillator for full details. 24.4 Flash Protection Feature A flash protection bit has been added to the EEMCR register to protect the Flash memory from accidental program or erasure. This bit is loaded from the EEPROM Shadow word at reset, so that the flash can be protected before any software is executed. See EEPROM and Flash sections for more details. 24.5 Clock Circuitry The crystal oscillator output is now frozen when Limp Home (LH) mode is entered to prevent rapid switching between crystal and LH clocks. Improvements have been made to the bus clock switching circuitry to eliminate the potential for glitches to appear on the internal clock line. The duration of the clock monitor pulses was increased to reduce sensitivity of the clock monitor circuit to short clock pulses. 24.6 Pseudo Stop Mode Oscillator amplifier drive is now not reduced in Pseudo Stop mode. When exiting Pseudo Stop mode, the device will now not go into Limp Home Mode since the crystal is already running. Technical Data 458 MC68HC912DT128A — Rev 4.0 Appendix: Information on MC68HC912DT128A Mask Set Changes MOTOROLA Appendix: Information on MC68HC912DT128A Mask Set Changes Oscillator – Minor Changes 24.7 Oscillator – Minor Changes The Automatic Level Control (ALC) capacitor reference was changed from VDD to VSS in the crystal oscillator circuit to improve noise immunity. Parasitic capacitance on internal signal lines has been decreased, thus decreasing sensitivity to external capacitance changes. NOTE: For best oscillator performance, it is recommended that the load capacitor selection is verified on changing to the new mask. A reduction was made to the gain of the Operational Transconductance Amplifier (OTA) to reduce the amplification of any noise on the EXTAL pin. 24.8 PLL The limp Home clock frequency has been re-alligned to the specification values to reduce sensitivity to system noise and hence reduce PLL jitter. Note: It is advisable to verify the XFC filter components and PLL lock time due to the above changes. VCO start-up will now be at the minimum frequency whilst the power up sequence of the current controlled oscillator has been improved. The XFC pin is now preconditioned to VDDPLL when PLL is deselected so XFC doesn’t float. This ensures the PLL starts up at low frequency and ramps up to the desired frequency. MC68HC912DT128A — Rev 4.0 MOTOROLA Appendix: Information on MC68HC912DT128A Mask Set Changes Technical Data 459 Appendix: Information on MC68HC912DT128A Technical Data 460 MC68HC912DT128A — Rev 4.0 Appendix: Information on MC68HC912DT128A Mask Set Changes MOTOROLA Technical Data — MC68HC912DT128A Glossary A — See “accumulators (A and B or D).” accumulators (A and B or D) — Two 8-bit (A and B) or one 16-bit (D) general-purpose registers in the CPU. The CPU uses the accumulators to hold operands and results of arithmetic and logic operations. acquisition mode — A mode of PLL operation with large loop bandwidth. Also see ’tracking mode’. address bus — The set of wires that the CPU or DMA uses to read and write memory locations. addressing mode — The way that the CPU determines the operand address for an instruction. The M68HC12 CPU has 15 addressing modes. ALU — See “arithmetic logic unit (ALU).” analogue-to-digital converter (ATD) — The ATD module is an 8-channel, multiplexed-input successive-approximation analog-to-digital converter. arithmetic logic unit (ALU) — The portion of the CPU that contains the logic circuitry to perform arithmetic, logic, and manipulation operations on operands. asynchronous — Refers to logic circuits and operations that are not synchronized by a common reference signal. ATD — See “analogue-to-digital converter”. B — See “accumulators (A and B or D).” baud rate — The total number of bits transmitted per unit of time. BCD — See “binary-coded decimal (BCD).” MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Glossary 461 Glossary binary — Relating to the base 2 number system. binary number system — The base 2 number system, having two digits, 0 and 1. Binary arithmetic is convenient in digital circuit design because digital circuits have two permissible voltage levels, low and high. The binary digits 0 and 1 can be interpreted to correspond to the two digital voltage levels. binary-coded decimal (BCD) — A notation that uses 4-bit binary numbers to represent the 10 decimal digits and that retains the same positional structure of a decimal number. For example, 234 (decimal) = 0010 0011 0100 (BCD) bit — A binary digit. A bit has a value of either logic 0 or logic 1. branch instruction — An instruction that causes the CPU to continue processing at a memory location other than the next sequential address. break module — The break module allows software to halt program execution at a programmable point in order to enter a background routine. breakpoint — A number written into the break address registers of the break module. When a number appears on the internal address bus that is the same as the number in the break address registers, the CPU executes the software interrupt instruction (SWI). break interrupt — A software interrupt caused by the appearance on the internal address bus of the same value that is written in the break address registers. bus — A set of wires that transfers logic signals. bus clock — See "CPU clock". byte — A set of eight bits. CAN — See "Motorola scalable CAN." CCR — See “condition code register.” central processor unit (CPU) — The primary functioning unit of any computer system. The CPU controls the execution of instructions. Technical Data 462 MC68HC912DT128A — Rev 4.0 Glossary MOTOROLA Glossary CGM — See “clock generator module (CGM).” clear — To change a bit from logic 1 to logic 0; the opposite of set. clock — A square wave signal used to synchronize events in a computer. clock generator module (CGM) — The CGM module generates a base clock signal from which the system clocks are derived. The CGM may include a crystal oscillator circuit and/or phase-locked loop (PLL) circuit. comparator — A device that compares the magnitude of two inputs. A digital comparator defines the equality or relative differences between two binary numbers. computer operating properly module (COP) — A counter module that resets the MCU if allowed to overflow. condition code register (CCR) — An 8-bit register in the CPU that contains the interrupt mask bit and five bits that indicate the results of the instruction just executed. control bit — One bit of a register manipulated by software to control the operation of the module. control unit — One of two major units of the CPU. The control unit contains logic functions that synchronize the machine and direct various operations. The control unit decodes instructions and generates the internal control signals that perform the requested operations. The outputs of the control unit drive the execution unit, which contains the arithmetic logic unit (ALU), CPU registers, and bus interface. COP — See "computer operating properly module (COP)." CPU — See “central processor unit (CPU).” CPU12 — The CPU of the MC68HC12 Family. CPU clock — Bus clock select bits BCSP and BCSS in the clock select register (CLKSEL) determine which clock drives SYSCLK for the main system, including the CPU and buses. When EXTALi drives the SYSCLK, the CPU or bus clock frequency (fo) is equal to the EXTALi frequency divided by 2. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Glossary 463 Glossary CPU cycles — A CPU cycle is one period of the internal bus clock, normally derived by dividing a crystal oscillator source by two or more so the high and low times will be equal. The length of time required to execute an instruction is measured in CPU clock cycles. CPU registers — Memory locations that are wired directly into the CPU logic instead of being part of the addressable memory map. The CPU always has direct access to the information in these registers. The CPU registers in an M68HC12 are: • A (8-bit accumulator) • B (8-bit accumulator) – D (16-bit accumulator formed by concatenation of accumulators A and B) • IX (16-bit index register) • IY (16-bit index register) • SP (16-bit stack pointer) • PC (16-bit program counter) • CCR (8-bit condition code register) cycle time — The period of the operating frequency: tCYC = 1/fOP. D — See “accumulators (A and B or D).” decimal number system — Base 10 numbering system that uses the digits zero through nine. duty cycle — A ratio of the amount of time the signal is on versus the time it is off. Duty cycle is usually represented by a percentage. ECT — See “enhanced capture timer.” EEPROM — Electrically erasable, programmable, read-only memory. A nonvolatile type of memory that can be electrically erased and reprogrammed. EPROM — Erasable, programmable, read-only memory. A nonvolatile type of memory that can be erased by exposure to an ultraviolet light source and then reprogrammed. enhanced capture timer (ECT) — The HC12 Enhanced Capture Timer module has the features of the HC12 Standard Timer module enhanced by additional features in order to enlarge the field of applications. exception — An event such as an interrupt or a reset that stops the sequential execution of the instructions in the main program. Technical Data 464 MC68HC912DT128A — Rev 4.0 Glossary MOTOROLA Glossary fetch — To copy data from a memory location into the accumulator. firmware — Instructions and data programmed into nonvolatile memory. free-running counter — A device that counts from zero to a predetermined number, then rolls over to zero and begins counting again. full-duplex transmission — Communication on a channel in which data can be sent and received simultaneously. hexadecimal — Base 16 numbering system that uses the digits 0 through 9 and the letters A through F. high byte — The most significant eight bits of a word. illegal address — An address not within the memory map illegal opcode — A nonexistent opcode. index registers (IX and IY) — Two 16-bit registers in the CPU. In the indexed addressing modes, the CPU uses the contents of IX or IY to determine the effective address of the operand. IX and IY can also serve as a temporary data storage locations. input/output (I/O) — Input/output interfaces between a computer system and the external world. A CPU reads an input to sense the level of an external signal and writes to an output to change the level on an external signal. instructions — Operations that a CPU can perform. Instructions are expressed by programmers as assembly language mnemonics. A CPU interprets an opcode and its associated operand(s) and instruction. inter-IC bus (I2C) — A two-wire, bidirectional serial bus that provides a simple, efficient method of data exchange between devices. interrupt — A temporary break in the sequential execution of a program to respond to signals from peripheral devices by executing a subroutine. interrupt request — A signal from a peripheral to the CPU intended to cause the CPU to execute a subroutine. I/O — See “input/output (I/0).” jitter — Short-term signal instability. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Glossary 465 Glossary latch — A circuit that retains the voltage level (logic 1 or logic 0) written to it for as long as power is applied to the circuit. latency — The time lag between instruction completion and data movement. least significant bit (LSB) — The rightmost digit of a binary number. logic 1 — A voltage level approximately equal to the input power voltage (VDD). logic 0 — A voltage level approximately equal to the ground voltage (VSS). low byte — The least significant eight bits of a word. M68HC12 — A Motorola family of 16-bit MCUs. mark/space — The logic 1/logic 0 convention used in formatting data in serial communication. mask — 1. A logic circuit that forces a bit or group of bits to a desired state. 2. A photomask used in integrated circuit fabrication to transfer an image onto silicon. MCU — Microcontroller unit. See “microcontroller.” memory location — Each M68HC12 memory location holds one byte of data and has a unique address. To store information in a memory location, the CPU places the address of the location on the address bus, the data information on the data bus, and asserts the write signal. To read information from a memory location, the CPU places the address of the location on the address bus and asserts the read signal. In response to the read signal, the selected memory location places its data onto the data bus. memory map — A pictorial representation of all memory locations in a computer system. MI-Bus — See "Motorola interconnect bus". microcontroller — Microcontroller unit (MCU). A complete computer system, including a CPU, memory, a clock oscillator, and input/output (I/O) on a single integrated circuit. modulo counter — A counter that can be programmed to count to any number from zero to its maximum possible modulus. most significant bit (MSB) — The leftmost digit of a binary number. Technical Data 466 MC68HC912DT128A — Rev 4.0 Glossary MOTOROLA Glossary Motorola interconnect bus (MI-Bus) — The Motorola Interconnect Bus (MI Bus) is a serial communications protocol which supports distributed real-time control efficiently and with a high degree of noise immunity. Motorola scalable CAN (msCAN) — The Motorola scalable controller area network is a serial communications protocol that efficiently supports distributed real-time control with a very high level of data integrity. msCAN — See "Motorola scalable CAN". MSI — See "multiple serial interface". multiple serial interface — A module consisting of multiple independent serial I/O sub-systems, e.g. two SCI and one SPI. multiplexer — A device that can select one of a number of inputs and pass the logic level of that input on to the output. nibble — A set of four bits (half of a byte). object code — The output from an assembler or compiler that is itself executable machine code, or is suitable for processing to produce executable machine code. opcode — A binary code that instructs the CPU to perform an operation. open-drain — An output that has no pullup transistor. An external pullup device can be connected to the power supply to provide the logic 1 output voltage. operand — Data on which an operation is performed. Usually a statement consists of an operator and an operand. For example, the operator may be an add instruction, and the operand may be the quantity to be added. oscillator — A circuit that produces a constant frequency square wave that is used by the computer as a timing and sequencing reference. OTPROM — One-time programmable read-only memory. A nonvolatile type of memory that cannot be reprogrammed. overflow — A quantity that is too large to be contained in one byte or one word. page zero — The first 256 bytes of memory (addresses $0000–$00FF). MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Glossary 467 Glossary parity — An error-checking scheme that counts the number of logic 1s in each byte transmitted. In a system that uses odd parity, every byte is expected to have an odd number of logic 1s. In an even parity system, every byte should have an even number of logic 1s. In the transmitter, a parity generator appends an extra bit to each byte to make the number of logic 1s odd for odd parity or even for even parity. A parity checker in the receiver counts the number of logic 1s in each byte. The parity checker generates an error signal if it finds a byte with an incorrect number of logic 1s. PC — See “program counter (PC).” peripheral — A circuit not under direct CPU control. phase-locked loop (PLL) — A clock generator circuit in which a voltage controlled oscillator produces an oscillation which is synchronized to a reference signal. PLL — See "phase-locked loop (PLL)." pointer — Pointer register. An index register is sometimes called a pointer register because its contents are used in the calculation of the address of an operand, and therefore points to the operand. polarity — The two opposite logic levels, logic 1 and logic 0, which correspond to two different voltage levels, VDD and VSS. polling — Periodically reading a status bit to monitor the condition of a peripheral device. port — A set of wires for communicating with off-chip devices. prescaler — A circuit that generates an output signal related to the input signal by a fractional scale factor such as 1/2, 1/8, 1/10 etc. program — A set of computer instructions that cause a computer to perform a desired operation or operations. program counter (PC) — A 16-bit register in the CPU. The PC register holds the address of the next instruction or operand that the CPU will use. pull — An instruction that copies into the accumulator the contents of a stack RAM location. The stack RAM address is in the stack pointer. Technical Data 468 MC68HC912DT128A — Rev 4.0 Glossary MOTOROLA Glossary pullup — A transistor in the output of a logic gate that connects the output to the logic 1 voltage of the power supply. pulse-width — The amount of time a signal is on as opposed to being in its off state. pulse-width modulation (PWM) — Controlled variation (modulation) of the pulse width of a signal with a constant frequency. push — An instruction that copies the contents of the accumulator to the stack RAM. The stack RAM address is in the stack pointer. PWM period — The time required for one complete cycle of a PWM waveform. RAM — Random access memory. All RAM locations can be read or written by the CPU. The contents of a RAM memory location remain valid until the CPU writes a different value or until power is turned off. RC circuit — A circuit consisting of capacitors and resistors having a defined time constant. read — To copy the contents of a memory location to the accumulator. register — A circuit that stores a group of bits. reserved memory location — A memory location that is used only in special factory test modes. Writing to a reserved location has no effect. Reading a reserved location returns an unpredictable value. reset — To force a device to a known condition. SCI — See "serial communication interface module (SCI)." serial — Pertaining to sequential transmission over a single line. serial communications interface module (SCI) — A module that supports asynchronous communication. serial peripheral interface module (SPI) — A module that supports synchronous communication. set — To change a bit from logic 0 to logic 1; opposite of clear. shift register — A chain of circuits that can retain the logic levels (logic 1 or logic 0) written to them and that can shift the logic levels to the right or left through adjacent circuits in the chain. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Glossary 469 Glossary signed — A binary number notation that accommodates both positive and negative numbers. The most significant bit is used to indicate whether the number is positive or negative, normally logic 0 for positive and logic 1 for negative. The other seven bits indicate the magnitude of the number. software — Instructions and data that control the operation of a microcontroller. software interrupt (SWI) — An instruction that causes an interrupt and its associated vector fetch. SPI — See "serial peripheral interface module (SPI)." stack — A portion of RAM reserved for storage of CPU register contents and subroutine return addresses. stack pointer (SP) — A 16-bit register in the CPU containing the address of the next available storage location on the stack. start bit — A bit that signals the beginning of an asynchronous serial transmission. status bit — A register bit that indicates the condition of a device. stop bit — A bit that signals the end of an asynchronous serial transmission. subroutine — A sequence of instructions to be used more than once in the course of a program. The last instruction in a subroutine is a return from subroutine (RTS) instruction. At each place in the main program where the subroutine instructions are needed, a jump or branch to subroutine (JSR or BSR) instruction is used to call the subroutine. The CPU leaves the flow of the main program to execute the instructions in the subroutine. When the RTS instruction is executed, the CPU returns to the main program where it left off. synchronous — Refers to logic circuits and operations that are synchronized by a common reference signal. timer — A module used to relate events in a system to a point in time. toggle — To change the state of an output from a logic 0 to a logic 1 or from a logic 1 to a logic 0. tracking mode — A mode of PLL operation with narrow loop bandwidth. Also see ‘acquisition mode.’ two’s complement — A means of performing binary subtraction using addition techniques. The most significant bit of a two’s complement number indicates the sign of the number (1 indicates negative). The two’s complement negative of a number is obtained by inverting each bit in the number and then adding 1 to the result. Technical Data 470 MC68HC912DT128A — Rev 4.0 Glossary MOTOROLA Glossary unbuffered — Utilizes only one register for data; new data overwrites current data. unimplemented memory location — A memory location that is not used. Writing to an unimplemented location has no effect. Reading an unimplemented location returns an unpredictable value. variable — A value that changes during the course of program execution. VCO — See "voltage-controlled oscillator." vector — A memory location that contains the address of the beginning of a subroutine written to service an interrupt or reset. voltage-controlled oscillator (VCO) — A circuit that produces an oscillating output signal of a frequency that is controlled by a dc voltage applied to a control input. waveform — A graphical representation in which the amplitude of a wave is plotted against time. wired-OR — Connection of circuit outputs so that if any output is high, the connection point is high. word — A set of two bytes (16 bits). write — The transfer of a byte of data from the CPU to a memory location. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Glossary 471 Glossary Technical Data 472 MC68HC912DT128A — Rev 4.0 Glossary MOTOROLA Technical Data — MC68HC912DT128A Revision History This section lists the revision history of the document since the first release. Data for previous internal drafts is unavailable. 24.9 Changes in Rev. 4.0 Section Page (in Rev 3.0) Electrical Specifications 437 Description of change Clock (SCK) High or Low Time, Master, twsck changed from tcyc − 60 to tcyc − 30. 24.10 Changes from Rev 2.0 to Rev 3.0 Section Page (in Rev 3.0) 42, 43 Pinout and Signal Descriptions Note about TEST pin updated 46 PLL loop filter connections diagram (Figure 3-4) updated 48 Note added about consideration of crystal selection due to EMC emissions 54 Description of TEST pin added as new section and to Table 3-2 55, 60 Registers Description of change Text added in Table 3-2 and Port CAN pin descriptions about nonconnection of RxCAN pins when MSCAN modules are not used. 68 FPOPEN bit added to EEMCR register 116 New paragraph added to overview about flash protection via FPOPEN bit 117 Last part of FEEMCR opening paragraph changed to ‘if HVEN or PGM or ERAS in the FEECTL register is set’ 120 Changes made to the Flash programming description for clarification of aligned words 122 New section 7.11 Flash protection bit FPOPEN added Flash Memory MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Revision History 473 Revision History Section Page (in Rev 3.0) 128, 129 EEPROM Memory Description of change FPOPEN bit added to EEMCR register 132 Paragraph added to the EEPGM description to clarify block protection 159 Note added about consideration of crystal selection due to EMC emissions 159 Opening paragraphs of PLL description changed for clarification 163 In the section on clock loss during normal operation, description of operation in limp home mode has been expanded for clarification 182 In Figure 12-6, MSCAN clock source selection via CLKSRC bit corrected 339 First two bullets of sleep mode description updated 352 SLPRQ = 1 description updated Clock Functions MSCAN Controller Analog-to-Digital Converter Major rewrite of entire section for clarification Clock for the BDM has been renamed as BDMCLK, to differentiaite it from another internal signal, BCLK Development Support Electrical Specifications Appendix: Changes from MC68HC912DG128 Appendix: CGM Practical Aspects Appendix: Information on MC68HC912DT128A Mask Set Changes 425 Units for IOFF corrected to nA 427 Reference to supply differential voltage values updated. VREF differential voltage row removed Analog input differential voltage row added 429 fXTAL removed 429 Footnote added restricting external oscillator operating frequency to 8MHz when using a quartz crystal 440 Table footnote removed from Table 21-16 regarding VDDPLL 444 Additional paragraphs added describing ATD differences from the non A suffix device 447 Section 23.3 A Few Hints For The CGM Crystal Oscillator Application removed. All points are covered in new Oscillator section 455 Extra bullets added New Section Technical Data 474 MC68HC912DT128A — Rev 4.0 Revision History MOTOROLA Revision History Changes from Rev 1.0 to Rev 2.0 24.11 Changes from Rev 1.0 to Rev 2.0 Section Page (in Rev 2.0) 30, 31 Description of change Figures 4 and 5, pin 97 changed to TEST and note added. 33 Note added about connection of power supplies. 35 Note about non-standard oscillator circuit expanded. 35 Additional paragraphs added covering DC bias. Registers 55 CD bit name corrected in ATD0CTL5. EEPROM 104 New section added ‘EEPROM Selective Write More Zeros’ Pinout and Signal Descriptions 143 to 153 Major rewrite of Limp Home and Fast STOP Recovery section. 160 System Clock Frequency Formulae updated for clarification. 161 Figure 18 modified for clarification. 164 Figure 21 modified for clarification. ECT 194 Figure 28 modified for clarification. ATD 321 Shading removed from CC bit in table 52. CD bit name corrected. Clock Functions 353, 354 Preliminary notes removed. 361 EEPROM Programming Maximum Time to ‘AUTO’ Bit Set and EEPROM Erasing Maximum Time to ‘AUTO’ Bit Set added to table 71. 369 Several values in table 76 updated. Appendix A 377 New section added ‘2d. EEPROM Selective Write More Zeros’. New section added ‘6. Port ADx’. New section added ‘7. ATD’. Appendix B 380 New section added ‘DC Bias’. Electrical Characteristics 24.12 Changes from first version (internal release, no revision number) to Rev 1.0 Section Page (in Rev 1.0) Description of change General Description 21 Ordering Information updated. EEPROM 109 Addition of Caution regarding attempts to erase or program protected locations. MC68HC912DT128A — Rev 4.0 MOTOROLA Technical Data Revision History 475 Revision History Section Page (in Rev 1.0) MSI 236 Description of change Clarification of SP0DR register state on reset. Technical Data 476 MC68HC912DT128A — Rev 4.0 Revision History MOTOROLA HOW TO REACH US: USA/EUROPE/LOCATIONS NOT LISTED: Motorola Literature Distribution; P.O. Box 5405, Denver, Colorado 80217 1-303-675-2140 or 1-800-441-2447 JAPAN: Motorola Japan Ltd.; SPS, Technical Information Center, 3-20-1, Minami-Azabu Minato-ku, Tokyo 106-8573 Japan 81-3-3440-3569 ASIA/PACIFIC: Motorola Semiconductors H.K. Ltd.; Silicon Harbour Centre, 2 Dai King Street, Tai Po Industrial Estate, Tai Po, N.T., Hong Kong 852-26668334 Information in this document is provided solely to enable system and software implementers to use Motorola products. There are no express or implied copyright licenses granted hereunder to design or fabricate any integrated circuits or integrated circuits based on the information in this document. TECHNICAL INFORMATION CENTER: Motorola reserves the right to make changes without further notice to any products 1-800-521-6274 herein. Motorola makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does Motorola assume any HOME PAGE: http://www.motorola.com/semiconductors liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation consequential or incidental damages. “Typical” parameters which may be provided in Motorola data sheets and/or specifications can and do vary in different applications and actual performance may vary over time. All operating parameters, including “Typicals” must be validated for each customer application by customer’s technical experts. Motorola does not convey any license under its patent rights nor the rights of others. Motorola products are not designed, intended, or authorized for use as components in systems intended for surgical implant into the body, or other applications intended to support or sustain life, or for any other application in which the failure of the Motorola product could create a situation where personal injury or death may occur. Should Buyer purchase or use Motorola products for any such unintended or unauthorized application, Buyer shall indemnify and hold Motorola and its officers, employees, subsidiaries, affiliates, and distributors harmless against all claims, costs, damages, and expenses, and reasonable attorney fees arising out of, directly or indirectly, any claim of personal injury or death associated with such unintended or unauthorized use, even if such claim alleges that Motorola was negligent regarding the design or manufacture of the part. Motorola and the Stylized M Logo are registered in the U.S. Patent and Trademark Office. digital dna is a trademark of Motorola, Inc. All other product or service names are the property of their respective owners. Motorola, Inc. is an Equal Opportunity/Affirmative Action Employer. © Motorola, Inc. 2003 MC912DT128A/D
MC912DT128ACPV 价格&库存
很抱歉,暂时无法提供与“MC912DT128ACPV”相匹配的价格&库存,您可以联系我们找货
