SKL13B
Taiwan Semiconductor
1A, 30V Schottky Barrier Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Low power loss, high efficiency
Ideal for automated placement
Guard ring for over-voltage protection
High surge current capability
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
1
A
VRRM
30
V
IFSM
50
A
TJ MAX
125
°C
Package
DO-214AA (SMB)
Configuration
Single die
Switching mode power supply (SMPS)
Adapters
Monitor
TV
MECHANICAL DATA
Case: DO-214AA (SMB)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.093g (approximately)
DO-214AA (SMB)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
SKL13B
UNIT
SKL13B
Repetitive peak reverse voltage
VRRM
30
V
Reverse voltage, total rms value
VR(RMS)
21
V
Forward current
Surge peak forward current, 8.3ms single half
sine-wave superimposed on rated load
Junction temperature
IF
1
A
IFSM
50
A
TJ
- 55 to +125
°C
Storage temperature
TSTG
- 55 to +150
°C
1
Version: J2102
SKL13B
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-lead thermal resistance
RӨJL
30
°C/W
Junction-to-ambient thermal resistance
RӨJA
85
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
(1)
Reverse current @ rated VR
IF = 1A, TJ = 25°C
(2)
TJ = 25°C
SYMBOL
TYP
MAX
UNIT
VF
0.39
V
200
µA
50
mA
IR
TJ = 100°C
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE
PACKAGE
PACKING
SKL13B
DO-214AA (SMB)
3,000 / Tape & Reel
2
Version: J2102
SKL13B
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
1000
CAPACITANCE (pF)
AVERAGE FORWARD CURRENT (A)
2
1
100
f=1.0MHz
Vslg=50mVp-p
50
75
100
10
125
0.1
1
Fig.4 Typical Forward Characteristics
10
TJ=125°C
1
TJ=75°C
0.01
TJ=25°C
0.001
40
50
60
70
80
90
100
10
10
TJ=125°C
1
TJ=25°C
0.1
0.01
0.001
0.3
0.1
0.2
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
UF1DLW
1
(A)
100
INSTANTANEOUS FORWARD CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
Fig.3 Typical Reverse Characteristics
10
100
REVERSE VOLTAGE (V)
LEAD TEMPERATURE(°C)
0.1
10
0.4
0.3
0.5
0.4
0.6
0.7
0.5
Pulse width
Pulse width 300μs
1% duty cycle
0.8
0.9
1
1.1
0.6
0.7
0.8
FORWARD VOLTAGE (V)
3
Version: J2102
1.2
SKL13B
Fig.5 Maximum Non-Repetitive Forward Surge Current
PEAK FORWARD SURGE CURRENT (A)
60
8.3ms single half sine wave
50
40
30
10
100
NUMBER OF CYCLES AT 60 Hz
4
Version: J2102
SKL13B
PACKAGE OUTLINE DIMENSIONS
DO-214AA (SMB)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Version: J2102
SKL13B
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: J2102
很抱歉,暂时无法提供与“SKL13BHM4G”相匹配的价格&库存,您可以联系我们找货
