S-25A640B0A-J8T2U3
S-25A640B0A-J8T2U3
    ABLIC(艾普凌科)
    SOP-8
    IC EEPROM 64KBIT SPI 8SOPJ
S-25A640B0A-J8T2U3 数据手册
S-25A640A, S-25A640B FOR AUTOMOTIVE 125°C OPERATION SPI SERIAL E2PROM www.ablic.com www.ablicinc.com Rev.3.2_02 © ABLIC Inc., 2008-2014 2 This IC is a SPI serial E PROM which operates under the high temperature, at high speed, with the wide range operation for automotive components. This IC has the capacity of 64 K-bit and the organization of 8192 words  8-bit. Page write and Sequential read are available. Caution Before using the product in automobile control unit or medical equipment, contact to ABLIC Inc. is indispensable.  Features  Packages  Operating voltage range Read: 2.5 V ~ 5.5 V Write: 2.5 V ~ 5.5 V  Operation frequency S-25A640A: 5.0 MHz max. S-25A640B: 6.5 MHz max.  Write time S-25A640A: 4.0 ms max. S-25A640B: 5.0 ms max.  SPI mode (0, 0) and (1, 1)  Page write: 32 bytes / page  Sequential read  Write protect: Software, Hardware Protect area: 25%, 50%, 100%  Monitoring of a write memory state by the status register  Function to prevent malfunction by monitoring clock pulse  Write protect function during the low power supply voltage  CMOS schmitt input ( CS , SCK, SI, WP , HOLD )  Endurance*1 S-25A640A: 106 cycle / word*2 (Ta = 25C) 5  105 cycle / word*2 (Ta = 125C) S-25A640B: 106 cycle / word*2 (Ta = 25C) 3  105 cycle / word*2 (Ta = 125C)  Data retention: 100 years (Ta = 25C) 50 years (Ta = 125C)  Memory capacity: 64 K-bit  Initial delivery state: FFh, SRWD = 0, BP1 = 0, BP0 = 0  Burn-in specification: Wafer level burn-in  Operation temperature range: Ta = 40°C to 125°C  Lead-free (Sn 100%), halogen-free*3  AEC-Q100 qualified*4 *1. *2. *3. *4.  8-Pin SOP (JEDEC) 5 8 4 1 (5.0  6.0  t1.75 mm)  8-Pin TSSOP 8 5 1 4 (3.0  6.4  t1.1 mm)  TMSOP-8 8 5 4 1 (2.9  4.0  t0.8 mm) Refer to " Endurance" for details. For each address (Word: 8-bit) Refer to " Product Name Structure" for details. Contact our sales office for details. Remark Refer to "3. Product name list" in " Product Name Structure" for details of package and product. 1 FOR AUTOMOTIVE 125°C OPERATION SPI SERIAL E2PROM S-25A640A, S-25A640B Rev.3.2_02  Block Diagram Step-up Circuit Voltage Detector SCK SI HOLD WP Clock Counter Mode Decoder Data Register Address Register Memory Cell Array Status Memory Cell Array Status Register Output Control Circuit SO X Decoder Input Control Circuit CS Page Latch Y Decoder Read Circuit VCC GND Figure 1  AEC-Q100 Qualified This IC supports AEC-Q100 for operation temperature grade 1. Contact our sales office for details of AEC-Q100 reliability specification.  Product Name Structure 1. Product name 1. 1 S-25A640A S-25A640A 0A  J8T2 U D Fixed Environmental code U: Lead-free (Sn 100%), halogen-free Package name (abbreviation) and IC packing specification*1 J8T2: 8-Pin SOP (JEDEC), Tape Fixed Product name S-25A640A: 2 64 K-bit FOR AUTOMOTIVE 125°C OPERATION SPI SERIAL E2PROM S-25A640A, S-25A640B Rev.3.2_02 1. 2 S-25A640B S-25A640B 0A  xxxx U 3 Fixed Environmental code U: Lead-free (Sn 100%), halogen-free Package name (abbreviation) and IC packing specification*1 J8T2: 8-Pin SOP (JEDEC), Tape T8T2: 8-Pin TSSOP, Tape K8T2: TMSOP-8, Tape Fixed Product name S-25A640B: *1. 64 K-bit Refer to the tape drawing. Remark This IC is wafer level burn-in specification. 2. Packages Table 1 Package Drawing Codes Package Name 8-Pin SOP (JEDEC) 8-Pin TSSOP TMSOP-8 3. Dimension Tape Reel FJ008-A-P-SD FT008-A-P-SD FM008-A-P-SD FJ008-D-C-SD FT008-E-C-SD FM008-A-C-SD FJ008-D-R-S2 FT008-E-R-S2 FM008-A-R-SD Product name list Table 2 Product Name Capacity Package Quantity S-25A640A0A-J8T2UD 64 K bit 8-Pin SOP (JEDEC) 2000 pcs / reel S-25A640B0A-J8T2U3 64 K bit 8-Pin SOP (JEDEC) 4000 pcs / reel S-25A640B0A-T8T2U3 64 K bit 8-Pin TSSOP 4000 pcs / reel S-25A640B0A-K8T2U3 64 K bit TMSOP-8 4000 pcs / reel Remark 1. Please contact our sales office for products with product name structure other than those specified above. 2. This IC is wafer level burn-in specification. 3 FOR AUTOMOTIVE 125°C OPERATION SPI SERIAL E2PROM S-25A640A, S-25A640B Rev.3.2_02  Pin Configurations 1. 8-Pin SOP (JEDEC) Table 3 Top view Pin No. 8 2 7 2 SO 3 6 3 4 5 6 WP GND SI*1 SCK*1 7 HOLD *1 8 VCC 4 5 Figure 2 2. Symbol 1 1 CS *1 *1 Write protect input Ground Serial data input Serial clock input Hold input Power supply 8-Pin TSSOP Table 4 1 2 3 4 8 7 6 5 Figure 3 Pin No. 1 Symbol CS *1 2 SO 3 4 5 6 WP GND SI*1 SCK*1 7 HOLD *1 8 VCC Description Chip select input Serial data output *1 Write protect input Ground Serial data input Serial clock input Hold input Power supply TMSOP-8 Table 5 Top view 1 2 3 4 8 7 6 5 Figure 4 *1. 4 Chip select input Serial data output Top view 3. Description Do not use it in "High-Z". Pin No. 1 Symbol CS *1 Description Chip select input 2 SO Serial data output 3 4 5 6 WP *1 GND SI*1 SCK*1 Ground Serial data input Serial clock input 7 HOLD *1 8 VCC Write protect input Hold input Power supply FOR AUTOMOTIVE 125°C OPERATION SPI SERIAL E2PROM S-25A640A, S-25A640B Rev.3.2_02  Absolute Maximum Ratings Table 6 Item Absolute Maximum Rating S-25A640A S-25A640B 0.3 to 7.0 0.3 to 6.5 0.3 to 7.0 0.3 to 6.5 0.3 to VCC  0.3 40 to 125 65 to 150 Symbol Power supply voltage Input voltage Output voltage Operation ambient temperature Storage temperature VCC VIN VOUT Topr Tstg Unit V V V °C °C Caution The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions.  Recommended Operating Conditions Table 7 Item Read Ta = 40C to 125C Min. Max. 2.5 5.5 Write 2.5 5.5 V 0.7  VCC 0.3 VCC  1.0 0.3  VCC V V Symbol Power supply voltage VCC High level input voltage Low level input voltage VIH VIL Condition VCC = 2.5 V to 5.5 V VCC = 2.5 V to 5.5 V Unit V  Pin Capacitance Table 8 Item Symbol Input capacitance CIN Output capacitance COUT Condition (Ta = 25°C, f = 1.0 MHz, VCC = 5.0 V) Min. Max. Unit VIN = 0 V ( CS , SCK, SI, WP , HOLD ) VOUT = 0 V (SO) - 8 pF - 10 pF  Endurance 1. S-25A640A Item Endurance *1. 2. Symbol NW Table 9 Operation Ambient Temperature Ta = 40°C to 85°C Ta = 40°C to 105°C Ta = 40°C to 125°C Min. 6 10 8  105 5  105 Max. - - - Unit *1 cycle / word *1 cycle / word *1 cycle / word Table 10 Operation Ambient Temperature Ta = 25°C Ta = 40°C to 85°C Ta = 40°C to 105°C Ta = 40°C to 125°C Min. 6 10 7  105 5  105 3  105 Max. - - - - Unit *1 cycle / word *1 cycle / word *1 cycle / word *1 cycle / word Table 11 Operation Ambient Temperature Ta = 25°C Ta = 40°C to 125°C Min. 100 50 Max. - - Unit year year For each address (Word: 8-bit) S-25A640B Item Endurance *1. Symbol NW For each address (Word: 8-bit)  Data Retention Item Data retention Symbol - 5 FOR AUTOMOTIVE 125°C OPERATION SPI SERIAL E2PROM S-25A640A, S-25A640B Rev.3.2_02  DC Electrical Characteristics 1. S-25A640A Table 12 Item Symbol Condition No load at SO pin Current consumption ICC1 (read) Ta = 40°C to 125°C VCC = 2.5 V to 3.0 V VCC = 3.0 V to 4.5 V VCC = 4.5 V to 5.5 V Unit fSCK = 2.5 MHz fSCK = 3.5 MHz fSCK = 5.0 MHz Min. Max. Min. Max. Min. Max. - - 1.5 - 2.0 2.5 mA Table 13 Item Symbol Condition No load at SO pin Current consumption ICC2 (write) VCC = 2.5 V to 3.0 V fSCK = 2.5 MHz Min. Max. - Ta = 40°C to 125°C VCC = 3.0 V to 4.5 V VCC = 4.5 V to 5.5 V Unit fSCK = 3.5 MHz fSCK = 5.0 MHz Min. Max. Min. Max. - 4.0 - 5.0 6.0 mA Table 14 Item Standby current consumption Input leakage current Output leakage current Low level output voltage High level output voltage 6 Symbol Condition ISB CS = VCC, SO = Open Other inputs are VCC or GND ILI ILO VOL1 VOL2 VOH1 VOH2 VIN = GND to VCC VOUT = GND to VCC IOL = 2.0 mA IOL = 1.5 mA IOH = 2.0 mA IOH = 0.4 mA Ta = 40°C to 125°C VCC = 2.5 V to 4.5 V VCC = 4.5 V to 5.5 V Min. Max. Min. Max. Unit - 8.0 - 10.0 A - - - - - 0.8  VCC 2.0 2.0 - 0.4 - - - - - - 0.8  VCC 0.8  VCC 2.0 2.0 0.4 0.4 - - A A V V V V FOR AUTOMOTIVE 125°C OPERATION SPI SERIAL E2PROM S-25A640A, S-25A640B Rev.3.2_02 2. S-25A640B Table 15 Item Symbol Ta = 40°C to 125°C VCC = 2.5 V to 4.5 V VCC = 4.5 V to 5.5 V fSCK = 6.5 MHz fSCK = 6.5 MHz Min. Max. Min. Max. Condition Current consumption ICC1 (read) No load at SO pin - - 2.0 2.5 Unit mA Table 16 Item Symbol Current consumption (write) ICC2 Condition Ta = 40°C to 125°C VCC = 2.5 V to 5.5 V fSCK = 6.5 MHz Min. Max. - No load at SO pin 4.0 Unit mA Table 17 Item Standby current consumption Input leakage current Output leakage current Low level output voltage High level output voltage Symbol Condition ISB CS = VCC, SO = Open Other inputs are VCC or GND ILI ILO VOL1 VOL2 VOH1 VOH2 VIN = GND to VCC VOUT = GND to VCC IOL = 2.0 mA IOL = 1.5 mA IOH = 2.0 mA IOH = 0.4 mA Ta = 40°C to 125°C VCC = 2.5 V to 4.5 V VCC = 4.5 V to 5.5 V Min. Max. Min. Max. Unit - 8.0 - 10.0 A - - - - - 0.8  VCC 2.0 2.0 - 0.4 - - - - - - 0.8  VCC 0.8  VCC 2.0 2.0 0.4 0.4 - - A A V V V V 7 FOR AUTOMOTIVE 125°C OPERATION SPI SERIAL E2PROM S-25A640A, S-25A640B Rev.3.2_02  AC Electrical Characteristics 1. S-25A640A Table 18 Measurement Conditions Input pulse voltage Output reference voltage Output load 0.2  VCC to 0.8  VCC 0.5  VCC 100 pF Table 19 SCK clock frequency Ta = 40°C to 125°C Symbol VCC = 2.5 V to 5.5 V VCC = 3.0 V to 5.5 V VCC = 4.5 V to 5.5 V Unit Min. Max. Min. Max. Min. Max. fSCK 2.5 3.5 5.0 MHz - - - CS setup time during CS falling tCSS.CL 120 - 90 - 90 - ns CS setup time during CS rising tCSS.CH 120 - 90 - 90 - ns CS deselect time tCDS 210 - 160 - 140 - ns CS hold time during CS falling tCSH.CL 120 - 90 - 90 - ns CS hold time during CS rising SCK clock time "H"*1 SCK clock time "L"*1 Rising time of SCK clock*2 Falling time of SCK clock*2 SI data input setup time SI data input hold time tCSH.CH 120 - 90 - 90 - ns tHIGH tLOW tRSK tFSK tDS tDH 160 160 - - 30 40 - - 1 1 - - 125 125 - - 20 30 - - 1 1 - - 95 95 - - 20 30 - - 1 1 - - ns ns s s ns ns SCK "L" hold time during HOLD rising tSKH.HH 90 - 70 - 70 - ns SCK "L" hold time during HOLD falling tSKH.HL 50 - 40 - 40 - ns SCK "L" setup time during HOLD falling tSKS.HL 0 - 0 - 0 - ns SCK "L" setup time during HOLD rising Disable time of SO output*2 Delay time of SO output Hold time of SO output Rising time of SO output*2 Falling time of SO output*2 tSKS.HH 0 - 0 - 0 - ns tOZ tOD tOH tRO tFO - - 0 - - 130 160 - 110 110 - - 0 - - 100 120 - 80 80 - - 0 - - 100 90 - 80 80 ns ns ns ns ns Disable time of SO output during HOLD falling*2 tOZ.HL - 130 - 100 - 100 ns Delay time of SO output during HOLD rising*2 tOD.HH - 110 - 80 - 80 ns WP setup time tWS1 0 - 0 - 0 - ns WP hold time tWH1 0 - 0 - 0 - ns WP release / setup time tWS2 0 - 0 - 0 - ns tWH2 200 - 150 - 150 - Item ns WP release / hold time *1. The clock cycle of the SCK clock (frequency fSCK) is 1 / fSCK s. This clock cycle is determined by a combination of several AC characteristics. Note that the clock cycle cannot be set as (1 / fSCK) = tLOW (min.)  tHIGH (min.) by minimizing the SCK clock cycle time. *2. These are values of sample and not 100% tested. Table 20 Item Write time 8 Symbol tPR Ta = 40°C to 125°C VCC = 2.5 V to 5.5 V Min. Max. - 4.0 Unit ms FOR AUTOMOTIVE 125°C OPERATION SPI SERIAL E2PROM S-25A640A, S-25A640B Rev.3.2_02 2. S-25A640B Table 21 Measurement Conditions Input pulse voltage Output reference voltage Output load 0.2  VCC to 0.8  VCC 0.5  VCC 100 pF Table 22 Item Symbol Ta = 40°C to 125°C VCC = 2.5 V to 5.5 V Min. Max. Unit SCK clock frequency fSCK - 6.5 MHz CS setup time during CS falling tCSS.CL 65 - ns 65 - ns 65 - ns ns tCSS.CH CS setup time during CS rising tCDS CS deselect time CS hold time during CS falling tCSH.CL 65 - CS hold time during CS rising tCSH.CH 65 - ns SCK clock time "H" *1 SCK clock time "L"*1 Rising time of SCK clock*2 Falling time of SCK clock*2 SI data input setup time SI data input hold time tHIGH tLOW tRSK tFSK tDS tDH 65 65 - - 15 20 - - 1 1 - - ns ns s s ns ns SCK "L" hold time during HOLD rising tSKH.HH 45 - ns ns SCK "L" hold time during HOLD falling tSKH.HL 30 - SCK "L" setup time during HOLD falling tSKS.HL 0 - ns SCK "L" setup time during HOLD rising tSKS.HH 0 - ns tOZ tOD tOH tRO tFO - - 0 - - 75 50 - 30 30 ns ns ns ns ns tOZ.HL - 75 ns Delay time of SO output during HOLD rising tOD.HH - 50 ns WP setup time tWS1 0 - ns WP hold time tWH1 0 - ns WP release / setup time tWS2 0 - ns WP release / hold time tWH2 20 - ns *2 Disable time of SO output Delay time of SO output Hold time of SO output *2 Rising time of SO output Falling time of SO output*2 Disable time of SO output during HOLD falling*2 *2 *1. The clock cycle of the SCK clock (frequency fSCK) is 1 / fSCK s. This clock cycle is determined by a combination of several AC characteristics. Note that the clock cycle cannot be set as (1 / fSCK) = tLOW (min.)  tHIGH (min.) by minimizing the SCK clock cycle time. *2. These are values of sample and not 100% tested. Table 23 Item Write time Symbol tPR Ta = 40°C to 125°C VCC = 2.5 V to 5.5 V Min. Max. - 5.0 Unit ms 9 FOR AUTOMOTIVE 125°C OPERATION SPI SERIAL E2PROM S-25A640A, S-25A640B Rev.3.2_02 tCDS CS tCSH.CL tCSS.CH tCSH.CH tCSS.CL SCK tDS SI SO tDH tRSK MSB IN tFSK LSB IN High-Z Figure 5 Serial Input Timing CS tSKS.HL tSKH.HL tSKH.HH SCK tSKS.HH SI tOZ.HL tOD.HH SO HOLD Figure 6 10 Hold Timing FOR AUTOMOTIVE 125°C OPERATION SPI SERIAL E2PROM S-25A640A, S-25A640B Rev.3.2_02 tSCK CS tOZ tHIGH SCK tLOW ADDR SI LSB IN tOD tOH tOD tOH SO LSB OUT tRO tFO Figure 7 Serial Output Timing tWS1 tWH1 CS WP Figure 8 Valid Timing in Write Protect tWS2 tWH2 CS WP Figure 9 Invalid Timing in Write Protect 11 FOR AUTOMOTIVE 125°C OPERATION SPI SERIAL E2PROM S-25A640A, S-25A640B Rev.3.2_02  Pin Functions 1. CS (chip select input) pin This is an input pin to set a chip in the select status. In the "H" input level, this IC is in the non-select status and its output is "High-Z". This IC is in standby as long as it is not in write inside. This IC goes in active by setting the chip select to "L". Input any instruction code after power-on and a falling of chip select. 2. SI (serial data input) pin This pin is to input serial data. This pin receives an instruction code, an address and write data. This pin latches data at rising edge of serial clock. 3. SO (serial data output) pin This pin is to output serial data. The data output changes at falling edge of serial clock. 4. SCK (serial clock input) pin This is a clock input pin to set the timing of serial data. An instruction code, an address and write data are received at a rising edge of clock. Data is output during falling edge of clock. 5. WP (write protect input) pin Write protect is purposed to protect the area size against the write instruction (BP1, BP0 in the status register). Fix this pin "H" or "L" not to set it in the floating state. Refer to " Protect Operation" for details. 6. HOLD (hold input) pin This pin is used to pause serial communications without setting this IC in the non-select status. In the hold status, the serial output goes in "High-Z", the serial input and the serial clock go in "Don't care". During the hold operation, be sure to set this IC in active by setting the chip select ( CS pin) to "L". Refer to " Hold Operation" for details.  Initial Delivery State Initial delivery state of all addresses is "FFh". Moreover, initial delivery state of the status register nonvolatile memory is as follows.    12 SRWD = 0 BP1 = 0 BP0 = 0 FOR AUTOMOTIVE 125°C OPERATION SPI SERIAL E2PROM S-25A640A, S-25A640B Rev.3.2_02  Instruction Set Table 24 is the list of instruction for This IC. The instruction is able to be input by changing the CS pin "H" to "L". Input the instruction in the MSB first. Each instruction code is organized with 1-byte as shown below. If This IC receives any invalid instruction code, this IC goes in the non-select status. Table 24 Instruction Set Instruction Code Instruction Operation SCK Input Clock 1 to 8 WREN WRDI Address SCK Input Clock 9 to 16 - - Data SCK Input Clock 17 to 24 - - Write enable 0000 0110 Write disable 0000 0100 Read the status - b7 to b0 output*1 0000 0101 RDSR register Write in the status - 0000 0001 b7 to b0 input WRSR register A15 to A8*2 READ Read memory data 0000 0011 A7 to A0 A15 to A8*2 WRITE Write memory data 0000 0010 A7 to A0 *1. Sequential data reading is possible. *2. The higher addresses A15 to A13 = Don't care. *3. After outputting data in the specified address, data in the following address is output. SCK Input Clock 25 to 32 - - - - D7 to D0 output*3 D7 to D0 input  Operation 1. Status register The status register's organization is below. The status register can write and read by a specific instruction. b7 b6 b5 b4 b3 b2 b1 b0 SRWD 0 0 0 BP1 BP0 WEL WIP Status Register Write Disable Block Protect Write Enable Latch Write In Progress Figure 10 Organization of Status Register The status / control bits of the status register are as follows. 1. 1 SRWD (b7) : Status Register Write Disable Bit SRWD operates in conjunction with the write protect signal ( WP ). With a combination of bit SRWD and signal WP (SRWD = "1", WP = "L"), this IC goes in Hardware Protect status. In this case, the bits composed of the nonvolatile memory in the status register (SRWD, BP1, BP0) go in read only, so that the WRSR instruction is not be performed. 13 FOR AUTOMOTIVE 125°C OPERATION SPI SERIAL E2PROM S-25A640A, S-25A640B 1. 2 Rev.3.2_02 BP1, BP0 (b3, b2) : Block Protect Bit BP1 and BP0 are composed of the nonvolatile memory. The area size of Software Protect against WRITE instruction is defined by them. Rewriting these bits is possible by the WRSR instruction. To protect the memory area against the WRITE instruction, set either or both of bit BP1 and BP0 to "1". Rewriting bit BP1 and BP0 is possible unless they are in Hardware Protect mode. Refer to " Protect Operation" for details of Block Protect. 1. 3 WEL (b1) : Write Enable Latch Bit WEL shows the status of internal Write Enable Latch. Bit WEL is set by the WREN instruction only. If bit WEL is "1", this is the status that Write Enable Latch is set. If bit WEL is "0", Write Enable Latch is in reset, so that this IC does not receive the WRITE or WRSR instruction. Bit WEL is reset after these operations;      1. 4 The power supply voltage is dropping At power-on After performing WRDI After the completion of write operation by the WRSR instruction After the completion of write operation by the WRITE instruction WIP (b0) : Write In Progress Bit WIP is read only and shows whether the internal memory is in the write operation or not by the WRITE or WRSR instruction. Bit WIP is "1" during the write operation but "0" during any other status. Figure 11 shows the usage example. CS WRITE or WRSR instruction RDSR instruction D2 D1 D0 SI RDSR instruction RDSR RDSR S R W D SO RDSR instruction RDSR S R W D BB PP 1 0 000 000 11 S R W D BB PP 1 0 11 WEL, WIP WEL, WIP BB PP 1 0 000 00 WEL, WIP tPR Figure 11 2. Usage Example of WEL, WIP Bits during Write Write enable (WREN) Before writing data (WRITE and WRSR), be sure to set bit Write Enable Latch (WEL). This instruction is to set bit WEL. Its operation is below. After selecting this IC by the chip select ( CS ), input the instruction code from serial data input (SI). To set bit WEL, set this IC in the non-select status by CS at the 8th clock of the serial clock (SCK). To cancel the WREN instruction, input the clock different from a specified value (n = 8 clock) while CS is in "L". 14 FOR AUTOMOTIVE 125°C OPERATION SPI SERIAL E2PROM S-25A640A, S-25A640B Rev.3.2_02 CS WP High / Low SCK 1 2 3 4 5 6 7 8 Instruction SI High-Z SO Figure 12 3. WREN Operation Write disable (WRDI) The WRDI instruction is one of ways to reset bit Write Enable Latch (WEL). After selecting this IC by the chip select ( CS ), input the instruction code from serial data input (SI). To reset bit WEL, set this IC in the non-select status by CS at the 8th clock of the serial clock. To cancel the WRDI instruction, input the clock different from a specified value (n = 8 clock) while CS is in "L". Bit WEL is reset after the operations shown below.      The power supply voltage is dropping At power-on After performing WRDI After the completion of write operation by the WRSR instruction After the completion of write operation by the WRITE instruction CS WP SCK High / Low 1 2 3 4 5 6 7 8 Instruction SI High-Z SO Figure 13 WRDI Operation 15 FOR AUTOMOTIVE 125°C OPERATION SPI SERIAL E2PROM S-25A640A, S-25A640B 4. Rev.3.2_02 Read the status register (RDSR) Reading data in the status register is possible by the RDSR instruction. During the write operation, it is possible to confirm the progress by checking bit WIP. Set the chip select ( CS ) "L" first. After that, input the instruction code from serial data input (SI). The status of bit in the status register is output from serial data output (SO). Sequential read is available for the status register. To stop the read cycle, set CS to "H". It is possible to read the status register always. The bits in it are valid and can be read by RDSR even in the write cycle. The 2 bits WEL and WIP are updated during the write cycle. The updated nonvolatile bits SRWD, BP1 and BP0 can be acquired by performing a new RDSR instruction after verifying the completion of the write cycle. CS WP SCK High / Low 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 Instruction SI Outputs Data in the Status Register SO High-Z Figure 14 5. b7 b6 b5 b4 b3 b2 b1 b0 b7 RDSR Operation Write in the status register (WRSR) The values of status register (SRWD, BP1, BP0) can be rewritten by inputting the WRSR instruction. But b6, b5, b4, b1, b0 of status register cannot be rewritten. b6 to 4 are always data "0" when reading the status register. Before inputting the WRSR instruction, set bit WEL by the WREN instruction. The operation of WRSR is shown below. Set the chip select ( CS ) "L" first. After that, input the instruction code and data from serial data input (SI). To start WRSR write (tPR), set the chip select ( CS ) to "H" after inputting data or before inputting a rising of the next serial clock. It is possible to confirm the operation status by reading the value of bit WIP during WRSR write. Bit WIP is "1" during write, "0" during any other status. Bit WEL is reset when write is completed. With the WRSR instruction, the values of BP1 and BP0; which determine the area size the users can handle as the read only memory; can be changed. Besides bit SRWD can be set or reset by the WRSR instruction depending on the status of write protect ( WP ). With a combination of bit SRWD and write protect ( WP ), this IC can be set in Hardware Protect mode (HPM). In this case, the WRSR instruction is not be performed (Refer to " Protect Operation"). Bit SRWD and BP1, BP0 keep the value which is the one prior to the WRSR instruction during the WRSR instruction. The newly updated value is changed when the WRSR instruction has completed. To cancel the WRSR instruction, input the clock different from a specified value (n = 16 clock) while CS is in "L". 16 FOR AUTOMOTIVE 125°C OPERATION SPI SERIAL E2PROM S-25A640A, S-25A640B Rev.3.2_02 CS WP High / Low SCK 1 2 3 4 5 6 7 9 8 Instruction 11 12 13 14 15 16 Inputs Data in the Status Register b7 SI b6 b5 b4 b3 b2 b1 b0 High-Z SO Figure 15 6. 10 WRSR Operation Read memory data (READ) The READ operation is shown below. Input the instruction code and the address from serial data input (SI) after inputting "L" to the chip select ( CS ). The input address is loaded to the internal address counter, and data in the address is output from the serial data output (SO). Next, by inputting the serial clock (SCK) keeping the chip select ( CS ) in "L", the address is automatically incremented so that data in the following address is sequentially output. The address counter rolls over to the first address by increment in the last address. To finish the read cycle, set CS to "H". It is possible to raise the chip select always during the cycle. During write, the READ instruction code is not be accepted or operated. CS WP High / Low SCK 1 2 3 4 5 6 Instruction 7 8 9 10 11 21 23 24 25 26 27 28 29 30 31 32 16-bit Address A15 A14 A13 SI 22 A3 A2 A1 A0 Outputs the First Byte High-Z SO Remark D7 D6 D5 D4 D3 D2 D1 D0 Outputs the Second D7 The higher addresses A15 to A13 = Don't care. Figure 16 READ Operation 17 FOR AUTOMOTIVE 125°C OPERATION SPI SERIAL E2PROM S-25A640A, S-25A640B 7. Rev.3.2_02 Write memory data (WRITE) Figure 17 shows the timing chart when inputting 1-byte data. Input the instruction code, the address and data from serial data input (SI) after inputting "L" to the chip select ( CS ). To start WRITE (tPR), set the chip select ( CS ) to "H" after inputting data or before inputting a rising of the next serial clock. Bit WIP and WEL are reset to "0" when write has completed. This IC can Page write of 32 bytes. Its function to transmit data is as same as Byte write basically, but it operates Page write by receiving sequential 8-bit write data as much data as page size has. Input the instruction code, the address and data from serial data input (SI) after inputting “L” in CS , as the WRITE operation (page) shown in Figure 18. Input the next data while keeping CS in “L”. After that, repeat inputting data of 8-bit sequentially. At the end, by setting CS to “H”, the WRITE operation starts (tPR). 5 of the lower bits in the address are automatically incremented every time when receiving write data of 8-bit. Thus, even if write data exceeds 32 bytes, the higher bits in the address do not change. And 5 of lower bits in the address roll over so that write data which is previously input is overwritten. These are cases when the WRITE instruction is not accepted or operated.    Bit WEL is not set to "1" (not set to "1" beforehand immediately before the WRITE instruction) During WRITE operation The address to be written is in the protect area by BP1 and BP0 To cancel the WRITE instruction, input the clock different from a specified value (n = 24  m  8 clock) while CS is in "L". CS WP High / Low SCK 1 2 3 4 5 6 7 8 9 11 A15 A14 A13 SI 21 22 23 24 25 16-bit Address Instruction Remark The higher addresses A15 to A13 = Don't care. Figure 17 26 27 28 29 30 31 32 Data Byte 1 A3 A2 A1 A0 D7 D6 D5 D4 D3 D2 D1 D0 High-Z SO 18 10 WRITE Operation (1 Byte) FOR AUTOMOTIVE 125°C OPERATION SPI SERIAL E2PROM S-25A640A, S-25A640B Rev.3.2_02 CS WP High / Low 1 2 3 4 5 6 7 8 9 10 11 22 23 24 25 26 27 28 29 30 31 32 SCK Instruction A15 A14 A13 SI Data Byte (n) 16-bit Address (n) A2 A1 A0 D7 D6 D5 D4 D3 D2 D1 D0 Data Byte (n + x) D4 D3 D2 D1 D0 High-Z SO Remark The higher addresses A15 to A13 = Don't care. Figure 18 WRITE Operation (Page)  Protect Operation Table 25 shows the block settings of write protect. Table 26 shows the protect operation for this IC. As long as bit SRWD, the Status Register Write Disable bit, in the status register is reset to "0" (it is in reset before the shipment), the value of status register can be changed. These are two statues when bit SRWD is set to "1".  Write in the status register is possible; write protect ( WP ) is in "H".  Write in the status register is impossible; write protect ( WP ) is in "L". Therefore the write protect area which is set by protect bit (BP1, BP0) in the status register cannot be changed. These operations are to set Hardware Protect (HPM).  After setting bit SRWD, set write protect ( WP ) to "L".  Set bit SRWD completed setting write protect ( WP ) to "L". The timing during the cycle write to the status register is showed in "Figure 8 "Figure 9 Invalid Timing in Write Protect". Valid Timing in Write Protect" and By inputting "H" to write protect ( WP ), Hardware Protect (HPM) is released. If the write protect ( WP ) is "H", Hardware Protect (HPM) does not function, Software Protect (SPM) which is set by the protect bits in the status register (BP1, BP0) only works. 19 FOR AUTOMOTIVE 125°C OPERATION SPI SERIAL E2PROM S-25A640A, S-25A640B Table 25 BP1 0 0 1 1 Block Settings of Write Protect Status Register BP0 0 1 0 1 Area of Write Protect Address of Write Protect Block 0% 25% 50% 100% None 1800h to 1FFFh 1000h to 1FFFh 0000h to 1FFFh Table 26 Mode Software Protect (SPM) Hardware Protect (HPM) Rev.3.2_02 Protect Operation WP Pin 1 1 X X 0 Bit SRWD Bit WEL Write Protect Block General Block Status Register X X 0 0 1 0 1 0 1 0 0 1 1 Write disable Write disable Write disable Write disable Write disable Write disable Write disable Write enable Write disable Write enable Write disable Write enable Write disable Write enable Write disable Write enable Write disable Write disable Remark X = Don't care  Hold Operation The hold operation is used to pause serial communications without setting this IC in the non-select status. In the hold status, the serial data output goes in "High-Z", and both of the serial data input and the serial clock go in "Don't care". Be sure to set the chip select ( CS ) to "L" to set this IC in the select status during the hold status. Generally, during the hold status, this IC holds the select status. But if setting this IC in the non-select status, the users can finish the operation even in progress. Figure 19 shows the hold operation. These are two statuses when the serial clock (SCK) is set to "L".  If setting hold ( HOLD ) to "L", hold ( HOLD ) is switched at the same time the hold status starts.  If setting hold ( HOLD ) to "H", hold ( HOLD ) is switched at the same time the hold status ends. These are two statuses when the serial clock (SCK) is set to "H".  If setting hold ( HOLD ) to "L", the hold status starts when the serial clock goes in "L" after hold ( HOLD ) is switched.  If setting hold ( HOLD ) to "H", the hold status ends when the serial clock goes in "L" after hold ( HOLD ) is switched. Hold status Hold status SCK HOLD Figure 19 20 Hold Operation FOR AUTOMOTIVE 125°C OPERATION SPI SERIAL E2PROM S-25A640A, S-25A640B Rev.3.2_02  Write Protect Function during the Low Power Supply Voltage This IC has a built-in detection circuit which operates with the low power supply voltage. This IC cancels the write operation (WRITE, WRSR) when the power supply voltage drops and power-on, at the same time, goes in the write protect status (WRDI) automatically to reset bit WEL. To operate write, after the power supply voltage dropped once but rose to the voltage level which allows write again, be sure to set the Write Enable Latch bit (WEL) before operating write (WRITE, WRSR). In the write operation, data in the address written during the low power supply voltage is not assured. In the S-25A640A, the detection voltage is 1.20 V typ., the release voltage is 1.35 V typ., and its hysteresis is approx. 0.15 V (Refer to Figure 20). In the S-25A640B, the detection and the release voltages are 1.20 V typ. (Refer to Figure 21). Hysteresis approx. 0.15 V Power supply voltage Detection voltage (−VDET) 1.20 V typ. Release voltage (+VDET) 1.35 V typ. Cancel the write instruction Set in write protect (WRDI) automatically Figure 20 Operation during the Low Power Supply Voltage (S-25A640A) Power supply voltage Detection voltage (−VDET) 1.20 V typ. Release voltage (+VDET) 1.20 V typ. Cancel the write instruction Set in write protect (WRDI) automatically Figure 21 Operation during the Low Power Supply Voltage (S-25A640B)  Input Pin and Output Pin 1. Connection of input pin All input pins in this IC have the CMOS structure. Do not set these pins in "High-Z" during operation when you design. Especially, set the CS input pin in the non-select status "H" during power-on/off and standby. The error write does not occur as long as the CS pin is in the non-select status "H". Set the CS pin to VCC via a resistor (the pull-up resistor of 10 k to 100 k). If the CS pin and the SCK pin change from "L" to "H" simultaneously, data may be input from the SI pin. To prevent the error for sure, it is recommended to pull down the SCK pin to GND. In addition, it is recommended to pull up the SI pin, the WP pin and the HOLD pin to VCC, or pull down these pins to GND, respectively. Connecting the WP pin and the HOLD pin to VCC directly is also possible when these pins are not in use. 2. Equivalent circuit of input pin and output pin Figure 22 and Figure 23 show the equivalent circuits of input pins in this IC. A pull-up and pull-down elements are not included in each input pin, pay attention not to set it in the floating state when you design. Figure 24 shows the equivalent circuit of the output pin. This pin has the tri-state output of "H" / "L" / "High-Z". 21 FOR AUTOMOTIVE 125°C OPERATION SPI SERIAL E2PROM S-25A640A, S-25A640B 2. 1 Rev.3.2_02 Input pin CS, SCK Figure 22 CS , SCK Pin SI, WP, HOLD Figure 23 2. 2 SI, WP , HOLD Pin Output pin VCC SO Figure 24 SO Pin  Precautions  Absolute maximum ratings: Do not operate these ICs in excess of the absolute maximum ratings (as listed on the data sheet). Exceeding the supply voltage rating can cause latch-up. Perform operations after confirming the detailed operation condition in the data sheet.  Operations with moisture on this IC's pins may occur malfunction by short-circuit between pins. Especially, in occasions like picking this IC up from low temperature tank during the evaluation. Be sure that not remain frost on this IC's pins to prevent malfunction by short-circuit. Also attention should be paid in using on environment, which is easy to dew for the same reason.  Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit.  ABLIC Inc. claims no responsibility for any and all disputes arising out of or in connection with any infringement of the products including this IC upon patents owned by a third party. 22 5.02±0.2 8 5 1 4 1.27 0.20±0.05 0.4±0.05 No. FJ008-A-P-SD-2.2 TITLE SOP8J-D-PKG Dimensions FJ008-A-P-SD-2.2 No. ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches:40.0±0.2) 2.0±0.05 ø1.55±0.05 0.3±0.05 ø2.0±0.05 8.0±0.1 2.1±0.1 6.7±0.1 1 8 4 5 Feed direction No. FJ008-D-C-SD-1.1 TITLE SOP8J-D-Carrier Tape No. FJ008-D-C-SD-1.1 ANGLE UNIT mm ABLIC Inc. 60° 2±0.5 13.5±0.5 Enlarged drawing in the central part ø21±0.8 2±0.5 ø13±0.2 No. FJ008-D-R-S2-1.0 TITLE SOP8J-D-Reel No. FJ008-D-R-S2-1.0 ANGLE UNIT mm ABLIC Inc. +0.3 3.00 -0.2 8 5 1 4 0.17±0.05 0.2±0.1 0.65 No. FT008-A-P-SD-1.2 TITLE TSSOP8-E-PKG Dimensions No. FT008-A-P-SD-1.2 ANGLE UNIT mm ABLIC Inc. 4.0±0.1 2.0±0.05 ø1.55±0.05 0.3±0.05 +0.1 8.0±0.1 ø1.55 -0.05 (4.4) +0.4 6.6 -0.2 1 8 4 5 Feed direction No. FT008-E-C-SD-1.0 TITLE TSSOP8-E-Carrier Tape FT008-E-C-SD-1.0 No. ANGLE UNIT mm ABLIC Inc. 13.4±1.0 17.5±1.0 Enlarged drawing in the central part ø21±0.8 2±0.5 ø13±0.5 No. FT008-E-R-S2-1.0 TITLE TSSOP8-E-Reel No. FT008-E-R-S2-1.0 ANGLE UNIT mm ABLIC Inc. 2.90±0.2 8 5 1 4 0.13±0.1 0.2±0.1 0.65±0.1 No. FM008-A-P-SD-1.2 TITLE TMSOP8-A-PKG Dimensions No. FM008-A-P-SD-1.2 ANGLE UNIT mm ABLIC Inc. 2.00±0.05 4.00±0.1 4.00±0.1 1.00±0.1 +0.1 1.5 -0 1.05±0.05 0.30±0.05 3.25±0.05 4 1 5 8 Feed direction No. FM008-A-C-SD-2.0 TITLE TMSOP8-A-Carrier Tape FM008-A-C-SD-2.0 No. ANGLE UNIT mm ABLIC Inc. 16.5max. 13.0±0.3 Enlarged drawing in the central part 13±0.2 (60°) (60°) No. FM008-A-R-SD-1.0 TITLE TMSOP8-A-Reel No. FM008-A-R-SD-1.0 QTY. ANGLE UNIT mm ABLIC Inc. 4,000 Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-25A640B0A-J8T2U3 价格&库存
很抱歉,暂时无法提供与“S-25A640B0A-J8T2U3”相匹配的价格&库存,您可以联系我们找货
