FR604GTA
FR604GTA
    SMCDIODESOLUTIONS(桑德斯)
    R-6
    DIODE GPP 400V 6A R-6
FR604GTA 数据手册
FR601G-FR607G Technical Data Data Sheet N1002, Rev. A FR601G THRU FR607G GLASS PASSIVATED FAST RECOVERY RECTIFIERS Reverse Voltage - 50 to 1000 Volts Forward Current - 6.0 Amperes Features      R-6    Circuit Diagram The plastic package carries Underwriters Laboratory Flammability Classification 94V-0 Fast switching for high efficiency Low reverse leakage High forward surge current capability High temperature soldering guaranteed: 260 C/10 seconds,0.375”(9.5mm) lead length, 5 lbs. (2.3kg) tension This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Data       Case: R-6 molded plastic Terminals: Plated axial leads, solderable per MILSTD-202, Method 208 Polarity: Color band denotes cathode end Mounting Position: Any Weight: 2.1 grams Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified Single phase half-wave 60Hz, resistive or inductive load, for capacitive load current derate by 20%. Characteristic Symbol Maximum repetitive peak reverse voltage Maximum DC blocking voltage VRRM VDC Maximum RMS voltage VRMS Maximum average forward rectified current 0.375”(9.5mm) lead length at @TA =75°C Peak forward surge current 8.3ms single half sinewave superimposed on rated load (JEDEC Method) FR FR FR 601G 602G 603G 5 1 50 100 200 3 7 35 70 140 FR 604G 2 400 1 280 FR 605G 4 600 2 420 FR FR 606G 607G 6 8 800 1000 4 5 560 700 Units 1 V 1 V I(AV) 6.0 A IFSM 300 A Maximum instantaneous forward voltage at 6.0A VF 1.3 V Maximum DC reverse current At Rated DC Blocking Voltage IRM 10 200 µA @TA = 25°C @TA = 100°C Maximum reverse recovery time (Note 1) trr 150 250 Typical Junction Capacitance (Note 2) Typical Thermal Resistance Junction to Ambient (Note 3) Operating junction temperature range CJ 150 pF RθJA 10 °C/W TJ -65 to +150 °C Operating storage temperature range TSTG -65 to +150 °C *Glass passivated forms are available upon request Note: 1. Reverse recovery condition IF=0.5A, IR=1.0A, Irr=0.25A 2. Measured at 1MHz and applied reverse voltage of 4.0V D.C. 3. Thermal resistance from junction to ambient at 0.375”(9.5mm)lead length, P.C.B. mounted  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  500 ns FR601G-FR607G Technical Data Data Sheet N1002, Rev. A Ratings and Characteristics Curves  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  FR601G-FR607G Technical Data Data Sheet N1002, Rev. A Mechanical Dimensions R-6 SYMBOL Ordering Information Device FR601G-FR607G Inches Min. Max. Min. Max. A 25.4 - 1.000 - B 8.60 9.10 0.340 0.360 C 1.2 1.3 0.048 0.052 D 8.60 9.10 0.340 0.360 Marking Diagram Package R-6 (Pb-Free) Millimeters Shipping Where XXXXX is YYWWL FR601G SSG YY WW L 500pcs / reel For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging specification. = Part Name = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Carrier Tape Specification R-6 SYMBOL Millimeters Min. Max. A 9.50 10.50 B 50.9 53.9 Z - 1.20 T 5.60 6.40 E - 0.80 IL1-L2I - 1.0  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  FR601G-FR607G Technical Data Data Sheet N1002, Rev. A DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
FR604GTA 价格&库存
很抱歉,暂时无法提供与“FR604GTA”相匹配的价格&库存,您可以联系我们找货
