TM1062HUXB
TM1062HUXB
    INRCORE
    SMD-16P
TM1062HUXB 数据手册
IEEE 1394B Fire wire 1.062Gb Transceiver Line Interface Module Copperhead Series Low power dissipation Low transmit/receive jitter Recommended for distances up to 20 meters IC grade transfer-molded package withstands 225°C peak temperature profile. Small package incorporating active transmit and passive receive circuits with integrated isolation transformers TRANSMITTER — Electrical Specifications @ 25 °C — Operating Temperature -55°C to +125 °C Input Data Voltage - VIL Part Input Data Voltage - VIH (V) (V) Input Voltage Differential - VIN (mV) Input Current - IIL Input Current - IIH Differential Signal Level - VOUT (µA) (µA) MIN TYP MAX MIN TYP MAX MIN TYP MAX MAX MAX MIN TYP MAX TM1062DUXB 1.35 1.63 1.88 2.07 2.33 2.58 150 800 1200 40 150 1200 1300 1500 TM1062HUXB 1.35 1.63 1.88 2.07 2.33 2.58 150 800 1200 500 750 1200 1300 1500 TM1062DU3XB 1.35 1.63 1.88 2.07 2.33 2.58 150 800 1200 500 750 1200 1300 1500 TM125TXHUA 1.35 1.63 1.88 2.07 2.33 2.58 150 800 1200 500 750 1200 1300 1500 Number (mV) TRANSMITTER — Additional Electrical Specifications @ 25 °C — Operating Temperature -55 °C to +125 °C Part Number Power Dissipation (mW) Ɵja (°C/W) Input Voltage (V) Data Rate - DR Total P-P Transmit Jitter * (pS) (Mb/s) Output Rise-Fall Time (20-80%) * (pS) Return Loss (dB) TYP @85°C @125°C TYP MIN MAX TYP MAX TYP MAX MIN TM1062DUXB 232 41 39 3.3V 246 1062 62 94 275 400 -12 TM1062HUXB 232 41 39 3.3V 246 1062 62 94 275 400 -12 TM1062DU3XB 700 34 30 3.3V 246 1062 62 94 275 400 -12 TM125TXHUA 232 41 39 3.3V 98 246 62 94 275 400 -12 TM125TX3DUA 700 41 39 3.3V 98 246 62 94 275 400 -12 TRANSMITTER — Additional Electrical Specifications @ 25 Turns Ratio Primary Inductance - LM (µH) TYP MIN MAX MIN TM1062DUXB 1:1 4.5 300 TM1062HUXB 1:1 4.5 TM1062DU3XB 1:1 TM125TXHUA TM125TX3DUA 1:1 1:1 Part Number °C — Operating Temperature -55 °C to +125 °C Insertion Loss (dB) (dB) MAX Winding Resistance - DCR (Ÿ) TYP MAX MAX 246 1062 0.2 -2 MAX -12 MIN 300 246 1062 0.2 -2 MAX -12 MIN 4.5 300 246 1062 0.2 -2 MAX -12 MIN 44 44 300 300 98 98 246 246 0.2 0.2 -2 MAX -2 MAX -12 MIN -12 MIN Data Rate - DR Rise Time (20%-80%) (pS) (Mb/s) Return Loss Notes: To order RoHS complient part, add the suffix “Z” to the part number (i.e.TM1062DUXBZ). Part Limited to 225°C Max Reflow Temperature. * At 1062 Mb/s Data Rate 1 www.inrcore.com M186.G (07/20) IEEE 1394B Fire wire 1.062Gb Transceiver Line Interface Module Mechanicals TM1062DUXB/TM1062DU3XB/TM125TX3DUA TM1062HUXB/TM125TXHUA Inches mm Unless otherwise specified, all tolerences are ± .005 0,13 Dimensions: 2 www.inrcore.com M186.G (07/20) IEEE 1394B Fire wire 1.062Gb Transceiver Line Interface Module Electrical Schematics TM1062HUXB/TM125TXHUA TM1062DUXB 3 www.inrcore.com M186.G (07/20) IEEE 1394B Fire wire 1.062Gb Transceiver Line Interface Module Electrical Schematics TM1062DU3XB/TM125TX3DUA For More Information Global Sales Representatives and Lo cations: http://www.inrcore.com iNRCORE,LLC 311 Sinclair Road Bristol, PA 19007-6812 U.S.A Tel: + 1.215.781.6400 Fax: +1.215.7816430 Performance warranty of products offered on this data sheet is limited to the parameters specified. Data is subject to change without notice. Other brand and product names mentioned herein may be trademarks or registered trademarks of their respective owners. © Copyright, 2020. iNRCORE, LLC. All rights reserved. 4 www.inrcore.com M186.G (07/20)
TM1062HUXB 价格&库存
很抱歉,暂时无法提供与“TM1062HUXB”相匹配的价格&库存,您可以联系我们找货
