GPA801 – GPA807
Taiwan Semiconductor
8A, 50V - 1000V Standard Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Glass passivated chip junction
High efficiency, Low VF
High current capability
High reliability
High surge current capability
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
8
A
VRRM
50 - 1000
V
IFSM
150
A
TJ MAX
150
°C
Package
TO-220AC
Configuration
Single die
APPLICATIONS
● DC to DC converter
● Switching mode converters and inverters
● General purpose
MECHANICAL DATA
Case: TO-220AC
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.80g (approximately)
TO-220AC
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
Repetitive peak reverse voltage
VRRM
GPA
801
GPA
801
50
Reverse voltage, total rms value
VR(RMS)
35
PARAMETER
SYMBOL
Marking code on the device
GPA
802
GPA
802
100
GPA
803
GPA
803
200
GPA
804
GPA
804
400
GPA
805
GPA
805
600
GPA
806
GPA
806
800
70
140
280
420
560
GPA
UNIT
807
GPA
807
1000
V
700
V
Forward current
Surge peak forward current
8.3ms single half sine wave
superimposed on rated load
Junction temperature
IF
8
A
IFSM
150
A
TJ
-55 to +150
°C
Storage temperature
TSTG
-55 to +150
°C
1
Version: G2103
GPA801 – GPA807
THERMAL PERFORMANCE
PARAMETER
Junction-to-case thermal resistance
SYMBOL
TYP
UNIT
RӨJC
2.5
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
(1)
Reverse current @ rated VR
(2)
Junction capacitance
CONDITIONS
SYMBOL
TYP
MAX
UNIT
IF = 8A, TJ = 25°C
VF
1.1
V
5
µA
100
µA
50
pF
TJ = 25°C
TJ = 125°C
1MHz, VR = 4.0V
IR
CJ
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
GPA8x
TO-220AC
50 / Tube
GPA8xH
TO-220AC
50 / Tube
Notes:
1. “x” defines voltage from 50V(GPA801) to 1000V(GPA807)
2. “H” means AEC-Q101 qualified
2
Version: G2103
GPA801 – GPA807
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
1000
8
CAPACITANCE (pF)
6
4
100
10
2
f=1.0MHz
Vsig=50mVp-p
1
25
50
75
100
125
150
0.1
1
CASE TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
TJ=125°C
10
1
TJ=25°C
0.1
30
40
50
60
70
80
90
100
100 10
10
UF1DLW
1
TJ=125°C
TJ=25°C
0.1
1
0.01
0.1
0.001
0.6
Pulse width 300μs
1% duty cycle
Pulse width
0.3
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
0.8
0.4
1.0
0.5
1.2
1.4
0.6
0.7
0.8
1.6
0.9
1.8
1
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
180
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (uA)
Fig.4 Typical Forward Characteristics
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
10
10
(A)
AVERAGE FORWARD CURRENT (A)
10
150
120
90
60
30
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: G2103
1.2
GPA801 – GPA807
PACKAGE OUTLINE DIMENSIONS
TO-220AC
MARKING DIAGRAM
4
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: G2103
GPA801 – GPA807
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
5
Version: G2103
很抱歉,暂时无法提供与“GPA801 C0G”相匹配的价格&库存,您可以联系我们找货
