SK22A – SK215A
Taiwan Semiconductor
2A, 20V - 150V Schottky Barrier Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Low power loss, high efficiency
Ideal for automated placement
Guard ring for over-voltage protection
High surge current capability
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
2
A
VRRM
20 - 150
V
IFSM
50
A
TJ MAX
125, 150
°C
APPLICATIONS
Package
DO-214AC (SMA)
Configuration
Single die
Switching mode power supply (SMPS)
Adapters
Lighting application
Converter
MECHANICAL DATA
Case: DO-214AC (SMA)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.070g (approximately)
DO-214AC (SMA)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
Repetitive peak reverse voltage
VRRM
SK
22A
SK
22A
Reverse voltage, total rms value
VR(RMS)
14
PARAMETER
SYMBOL
Marking code on the device
Forward current
Surge peak forward current,
8.3ms single half sine-wave
superimposed on rated load
Non-repetitive peak reverse
avalanche energy, L = 40mH
Critical rate of rise of off-state
voltage
Junction temperature
Storage temperature
SK
23A
SK
23A
30
SK
24A
SK
24A
40
SK
25A
SK
25A
50
SK
26A
SK
26A
60
21
28
35
42
SK
SK
SK
UNIT
29A 210A 215A
SK
SK
SK
29A 210A 215A
90
100
150
V
63
70
105
V
IF
2
A
IFSM
50
A
ERSM
mJ
dV/dt
10,000
V/µs
TJ
- 55 to +125
TSTG
- 55 to +150
- 55 to +150
1
°C
°C
Version: Q2102
SK22A – SK215A
THERMAL PERFORMANCE
PARAMETER
Junction-to-ambient thermal resistance
SYMBOL
TYP
UNIT
RӨJA
88
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
(1)
Reverse current @ rated VR
(2)
(2)
(2)
SK22A
SK23A
SK24A
SK25A
SK26A
SK29A
SK210A
SK215A
SK22A
SK23A
SK24A
SK25A
SK26A
SK29A
SK210A
SK215A
SK22A
SK23A
SK24A
SK25A
SK26A
SK29A
SK210A
SK215A
SK22A
SK23A
SK24A
SK25A
SK26A
SK29A
SK210A
SK215A
IF = 2A, TJ = 25°C
TJ = 25°C
SYMBOL
VF
TYP
MAX
UNIT
0.50
V
0.70
V
0.85
V
0.95
V
0.5
mA
0.1
mA
10
mA
5
mA
mA
mA
2
mA
IR
TJ = 100°C
IR
TJ = 125°C
IR
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
SK2xA
DO-214AC (SMA)
7,500 / Tape & Reel
Notes:
1. “x” defines voltage from 20V(SK22A) to 150V(SK215A)
2
Version: Q2102
SK22A – SK215A
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
1000
SK22A - SK26A
CAPACITANCE (pF)
2
SK22A - SK25A
1
100
SK29A - SK215A
10
SK26A - SK215A
50
75
100
125
f=1.0MHz
Vsig=50mVp-p
1
150
0.1
1
LEAD TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
10
TJ=125°C
1
TJ=75°C
0.1
0.01
TJ=25°C
0.001
100
Fig.4 Typical Forward Characteristics
100
10 20 30 40 50 60 70 80 90 100 110 120
100 10
SK22A - SK24A
10
1
UF1DLW
SK25A
- SK26A
TJ=125°C
TJ=25°C
0.1
SK215A
1
SK29A - SK210A
0.01
0.1
0.001
0.1
0.3
0.5
0.7
0.3
0.4
0.5
0.6
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Pulse width 300μs
1% duty cyclePulse width
0.9
0.7
1.1
0.8
1.3
0.9
1.5
1
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
50
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
Fig.3 Typical Reverse Characteristics
SK22A - SK24A
SK25A - SK26A
SK29A - SK215A
10
REVERSE VOLTAGE (V)
(A)
AVERAGE FORWARD CURRENT (A)
3
8.3ms single half sine wave
40
30
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: Q2102
1.2
SK22A – SK215A
Fig.6 Typical Transient Thermal Characteristics
TRANSIENT THERMAL IMPEDANCE (°C/W)
100
10
1
0.01
0.1
1
10
100
PULSE DURATION (s)
4
Version: Q2102
SK22A – SK215A
PACKAGE OUTLINE DIMENSIONS
DO-214AC (SMA)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Version: Q2102
SK22A – SK215A
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: Q2102
很抱歉,暂时无法提供与“SK25AHR3G”相匹配的价格&库存,您可以联系我们找货
