HS5M M6G
HS5M M6G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO214AB
    DIODE GEN PURP 5A DO214AB
HS5M M6G 数据手册
HS5A – HS5M Taiwan Semiconductor 5A, 50V - 1000V High Efficient Surface Mount Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS Glass passivated chip junction Ideal for automated placement Low forward voltage drop Low profile package Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS PARAMETER VALUE UNIT IF 5 A VRRM 50 - 1000 V IFSM 150 A TJ MAX 150 °C Package DO-214AB (SMC) Configuration Single die ● High frequency rectification ● Freewheeling application ● Switching mode converters and inverters in computer and telecommunication MECHANICAL DATA ● ● ● ● ● ● Case: DO-214AB (SMC) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.210g (approximately) DO-214AB (SMC) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER Marking code on the device Repetitive peak reverse voltage Reverse voltage, total rms value Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Junction temperature Storage temperature SYMBOL HS5A HS5B HS5D HS5F HS5G HS5J HS5K HS5M UNIT HS5A HS5B HS5D HS5F HS5G HS5J HS5K HS5M VRRM 50 100 200 300 400 600 800 1000 V VR(RMS) 35 70 140 210 280 420 560 700 V IF 5 A IFSM 150 A TJ - 55 to +150 °C TSTG - 55 to +150 °C 1 Version: K2102 HS5A – HS5M Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJA 60 °C/W Junction-to-ambient thermal resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage (1) Reverse current @ rated VR (2) Junction capacitance Reverse recovery time CONDITIONS HS5A HS5B HS5D HS5F I = 3A, TJ = 25°C HS5G F HS5J HS5K HS5M HS5A HS5B HS5D HS5F I = 5A, TJ = 25°C HS5G F HS5J HS5K HS5M TJ = 25°C TJ = 125°C HS5A HS5B HS5D HS5F 1MHz, VR = 4.0V HS5G HS5J HS5K HS5M HS5A HS5B HS5D HS5F IF = 0.5A, IR = 1.0A, HS5G Irr = 0.25A HS5J HS5K HS5M SYMBOL VF VF IR TYP MAX UNIT - - V - - V - 1.35 V - 1.00 V - 1.30 V - 1.70 V - 10 µA - 250 µA 80 - pF 50 - pF - 50 ns - 75 ns CJ trr Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING HS5x DO-214AB (SMC) 3,000 / Tape & Reel Notes: 1. “x” defines voltage from 50V(HS5A) to 1000V(HS5M) 2 Version: K2102 HS5A – HS5M Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.2 Typical Junction Capacitance 6 175 5 150 CAPACITANCE (pF) 4 3 2 1 125 100 HS5A - HS5G 75 50 HS5J - HS5M 25 f=1.0MHz Vsig=50mVp-p 0 0 25 50 75 100 125 0.1 150 1 LEAD TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) 100 TJ=125°C 10 TJ=25°C 1 30 40 50 60 70 80 90 100 10 10 HS5A - HS5D UF1DLW 1 TJ=125°C 1 0.1 TJ=25°C HS5G HS5J - HS5M 0.01 0.1 0.001 0.4 0.3 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Pulse width 300μs 1% duty cycle Pulse width 0.6 0.4 0.5 0.8 0.6 1.0 0.7 0.8 1.2 0.9 1.4 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 200 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (μA) Fig.4 Typical Forward Characteristics 1000 20 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 10 10 (A) AVERAGE FORWARD CURRENT (A) Fig.1 Forward Current Derating Curve 8.3ms single half sine wave 150 100 50 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: K2102 1.2 HS5A – HS5M Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: K2102 HS5A – HS5M Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-214AB (SMC) SUGGESTED PAD LAYOUT MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YW = Date Code F = Factory Code Version: K2102 HS5A – HS5M Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: K2102
HS5M M6G
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路不受外部干扰。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚集电极,4脚发射极,5脚GND,6脚VCC。
4. 参数特性:工作温度范围为-40℃至85℃,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现信号传输,具有高速响应和低功耗特点。
6. 应用信息:广泛应用于工业控制、医疗设备、通信设备等领域。
7. 封装信息:采用DIP6封装,尺寸为9.1mm x 3.6mm。
HS5M M6G 价格&库存
很抱歉,暂时无法提供与“HS5M M6G”相匹配的价格&库存,您可以联系我们找货
