ASNT5144-KHC
ASNT5144-KHC
    ADSANTEC(先进科技)
    CQFN24
    35G AUTOMATIC FREQUENCY DOUBLER
ASNT5144-KHC 数据手册
Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ASNT5144-KHC 8-35GHz Automatic Frequency Doubler  High-speed frequency doubler with automatic output duty cycle correction.  Output duty cycle always 50% with internal feedback turned on.  Manual output duty cycle control available.  Exhibits low jitter and limited temperature variation over industrial temperature range.  Ideal for high speed proof-of-concept prototyping.  Fully differential CML input interfaces.  Fully differential CML output interface with 600mV single-ended swing.  Single +3.3V or -3.3V power supply.  Power consumption: 660mW.  Fabricated in SiGe for high performance, yield, and reliability.  Custom CQFN 24-pin package Rev.1.0.2 1 April 2021 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com DESCRIPTION Fig. 1. Functional Block Diagram The temperature stable ASNT5144-KHC SiGe IC provides broadband frequency multiplication, and is intended for use in high-speed measurement / test equipment. The IC shown in Fig. 1 can receive a highspeed clock input signal ip/in, and deliver a high-speed double-frequency clock output signal outp/outn. There are two duty cycle correction feedback loops. The first loop adjusts the duty cycle of the input signal, and the second loop controls the final output signal duty cycle. Activation of the loops is controlled via the onfb control port as shown in Table 1. Table 1. Feedback Loops Activation by onfb fbon Input FB loop Output FB loop off off vee off on vcc not connected (nc) on on When both feedback loops are activated, the output clock’s duty cycle is automatically kept at about 50%. To ensure correct operation of the feedback block within a wide range of frequencies, the optional control port crl can be set to vee/vcc/nc according to Table 2. The duty cycle may also be adjusted manually via tuning ports icntp/icntn when feedback is turned off. Table 2. Frequency Ranges at crl settings crl Frequency Range (GHz) 4.3 - 12.9 vee 6.6 - 19.7 vcc not connected (nc) 13 - 38.9 The part’s I/O’s support the CML logic interface with on chip 50Ohm termination to vcc, and may be used differentially, AC/DC coupled, single-ended, or in any combination (also see POWER SUPPLY CONFIGURATION). In the DC-coupling mode, the input signal’s common mode voltage should comply with the specifications shown in ELECTRICAL CHARACTERISTICS. In the AC-coupling mode, the input termination provides the required common mode voltage automatically. The differential DC signaling mode is recommended for optimal performance. Rev.1.0.2 2 April 2021 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com POWER SUPPLY CONFIGURATION The part can operate with either a negative supply (vcc = 0.0V = ground and vee = −3.3V), or a positive supply (vcc = +3.3V and vee = 0.0V = ground). In case of the positive supply, all I/Os need AC termination when connected to any devices with 50Ohm termination to ground. Different PCB layouts will be needed for each different power supply combination. All the characteristics detailed below assume vcc = 0.0V and vee = -3.3V. ABSOLUTE MAXIMUM RATINGS Caution: Exceeding the absolute maximum ratings shown in Table 3 may cause damage to this product and/or lead to reduced reliability. Functional performance is specified over the recommended operating conditions for power supply and temperature only. AC and DC device characteristics at or beyond the absolute maximum ratings are not assumed or implied. All min and max voltage limits are referenced to ground. Table 3. Absolute Maximum Ratings. Parameter Supply Voltage (vee) Supply current RF Input Voltage Swing (SE) Case Temperature Storage Temperature Operational Humidity Storage Humidity Min -40 10 10 Max -3.6 200 1.0 +90 +100 98 98 Units V mA V ºC ºC % % TERMINAL FUNCTIONS TERMINAL Name No. Type ip in outp outn onfb crl icntp icntn Name vcc vee Rev.1.0.2 DESCRIPTION High-Speed I/Os 21 CML input Differential clock inputs with internal SE 50Ohm termination to vcc. 23 11 CML output Differential clock outputs with internal SE 50Ohm termination to vcc. Require external SE 50Ohm termination to vcc. 9 15 3.3V CMOS Digital Control Signal with 6.6KOhm termination to vee 17 3.3V CMOS 3-State Digital Control Signal with 4.6KOhm termination to vee and 6.6KOhm termination to vcc 3 CML input Differential tuning ports with internal 100Ohm termination to vcc. 5 Supply and Termination Voltages Description Pin Number Positive power supply. (+3.3V or 0) 2, 4, 6, 8, 10, 12, 14, 16, 18, 20, 22, 24 Negative power supply. (0V or -3.3V) 3 1, 7, 13, 19 April 2021 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ELECTRICAL CHARACTERISTICS PARAMETER vee vcc Ivee Power consumption Junction temperature Frequency Swing CM Voltage Level Frequency Logic “1” level Logic “0” level Rise/Fall times Output Jitter Duty cycle onfb crl Bandwidth Swing CM Voltage Level Rev.1.0.2 MIN TYP MAX UNIT COMMENTS General Parameters -3.1 -3.3 -3.5 V ±6% 0.0 V External ground 200 mA 660 mW -40 25 125 °C HS Input Clock (ip/in) 4 17.5 GHz 0.05 1.0 V Differential or SE, p-p vcc-0.8 vcc V Must match for both inputs HS Output Clock (outp/outn) 8 35 GHz V vcc vcc-0.6 V With external 50Ohm DC termination 6 8 10 ps 20%-80% 1 ps Peak-to-peak 50 % For clock signal with feedback on CMOS Control Ports (onfb, crl) 0 3.3 V See Table 1 0 nc 3.3 V See Table 2 Tuning Ports (icntp/icntn) DC 100 MHz vcc-0.4 V Differential vcc-0.4 vcc V Must match for both inputs 4 April 2021 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com PACKAGE INFORMATION The chip die is housed in a custom 24-pin CQFN package shown in Error! Reference source not found.. The package provides a center heat slug located on its back side to be used for heat dissipation. ADSANTEC recommends for this section to be soldered to the vcc plain, which is ground for a negative supply, or power for a positive supply. Fig. 2. CQFN 24-Pin Package Drawing (All Dimensions in mm) Rev.1.0.2 5 April 2021 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com The part’s identification label is ASNT5144-KHC. The first 8 characters of the name before the dash identify the bare die including general circuit family, fabrication technology, specific circuit type, and part version while the 3 characters after the dash represent the package’s manufacturer, type, and pin out count. This device complies with Commission Delegated Directive (EU) 2015/863 of 4 June 2015 amending Annex II to Directive 2011/65/EU of the European Parliament and of the Council as regards the list of restricted substances (Text with EEA relevance) on the restriction of the use of certain hazardous substances in electrical and electronics equipment (RoHS Directive) in accordance with the definitions set forth in the directives for all ten substances. REVISION HISTORY Revision 1.0.2 Rev.1.0.2 Date 04-2021 Changes First release 6 April 2021
ASNT5144-KHC 价格&库存
很抱歉,暂时无法提供与“ASNT5144-KHC”相匹配的价格&库存,您可以联系我们找货
