TSSA5U50 – TSSA5U60
Taiwan Semiconductor
5A, 50V - 60V Trench Schottky Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Patented Trench Schottky technology
Low power loss, high efficiency
Ideal for automated placement
High forward surge capability
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
5
A
VRRM
50 - 60
V
IFSM
75
A
TJ MAX
150
°C
Package
DO-214AC (SMA)
Configuration
Single die
● Trench Schottky barrier rectifier is designed for high frequency
miniature switched mode power supplies such as adapters, lighting
and on-board DC/DC converters.
● MECHANICAL DATA
Case: DO-214AC (SMA)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.060g (approximately)
DO-214AC (SMA)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
TSSA5U50
TSSA5U60
5U50
5U60
UNIT
Repetitive peak reverse voltage
VRRM
50
60
V
Reverse voltage, total rms value
VR(RMS)
35
42
V
Forward current
Peak forward surge current, 8.3ms single half
sine-wave superimposed on rated load
Junction temperature
IF
5
A
IFSM
75
A
TJ
- 55 to +150
°C
Storage temperature
TSTG
- 55 to +150
°C
1
Version: E2102
TSSA5U50 – TSSA5U60
THERMAL PERFORMANCE
PARAMETER
SYMBOL
Junction-to-lead thermal resistance
TSSA5U50
TSSA5U60
Junction-to-ambient thermal resistance
TYP
UNIT
25
°C/W
28
°C/W
70
°C/W
RӨJL
RӨJA
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
TSSA5U50
Forward voltage
(1)
TSSA5U60
TSSA5U50
TSSA5U60
Reverse current @ rated VR
(2)
SYMBOL
IF = 5A, TJ = 25°C
VF
IF = 5A, TJ = 125°C
TJ = 25°C
IR
TJ = 125°C
TYP
MAX
UNIT
0.44
0.54
V
0.48
0.56
V
0.39
0.49
V
0.44
0.52
V
300
µA
50
mA
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
TSSA5Ux
DO-214AC (SMA)
7,500 / Tape & Reel
Notes:
1. “x” defines voltage from 50V(TSSA5U50) to 60V(TSSA5U60)
2
Version: E2102
TSSA5U50 – TSSA5U60
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
10000
TSSA5U50
5
CAPACITANCE (pF)
4
TSSA5U60
3
2
1
1000
100
With heat sink
5mm x 5mm Cu-pad
f=1.0MHz
Vsig=50mVp-p
10
75
100
125
0.1
150
1
LEAD TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
Fig.4 Typical Forward Characteristics
100
TSSA5U50
TJ=150°C
TJ=125°C
1
TJ=100°C
0.1
0.01
TJ=25°C
0.001
10
40
50
60
70
80
90
100
10 10
TSSA5U50
1
1
0.1
UF1DLW
TJ=150°C
TJ=125°C
TJ=125°C
TJ=100°C
0.1
0.001
0.0
0.1
0.2
0.3
0.3
0.4
0.5
0.6
TSSA5U60
TJ=125°C
TJ=100°C
0.1
0.01
TJ=25°C
0.001
10
40
50
60
70
80
90
0.4
0.7
0.5
0.8
0.6
0.9
0.7
1
1.1
1.2
1.1
1.2
Fig.6 Typical Forward Characteristics
100
1
Pulse width 300μs
1% duty cycle
Pulse width
FORWARD VOLTAGE (V)
Fig.5 Typical Reverse Characteristics
10
TJ=25°C
TJ=25°C
0.01
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
TJ=150°C
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
10
10
(A)
25
100
10 10
TSSA5U60
1
10.1
UF1DLW
TJ=150°C
TJ=125°C
TJ=125°C
TJ=100°C
TJ=25°C
(A)
AVERAGE FORWARD CURRENT (A)
6
TJ=25°C
0.01
0.1
0.001
0.0
0.1
0.2
0.3
0.3
0.4
0.5
0.6
Pulse width 300μs
1% duty cycle
Pulse width
0.4
0.7
0.5
0.8
0.6
0.9
0.7
1
FORWARD VOLTAGE (V)
3
Version: E2102
TSSA5U50 – TSSA5U60
Fig.7 Maximum Non-Repetitive Forward Surge Current
PEAK FORWARD SURGE CURRENT (A)
80
70
8.3ms single half sine wave
60
50
40
30
10
100
NUMBER OF CYCLES AT 60 Hz
4
Version: E2102
TSSA5U50 – TSSA5U60
PACKAGE OUTLINE DIMENSIONS
DO-214AC (SMA)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Version: E2102
TSSA5U50 – TSSA5U60
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: E2102
很抱歉,暂时无法提供与“TSSA5U60”相匹配的价格&库存,您可以联系我们找货
