TSSA5U50
TSSA5U50
    TAIWANSEMICONDUCTOR(台半)
    DO214AC
    DIODE SCHOTTKY 50V 5A DO214AC
TSSA5U50 数据手册
TSSA5U50 – TSSA5U60 Taiwan Semiconductor 5A, 50V - 60V Trench Schottky Surface Mount Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS Patented Trench Schottky technology Low power loss, high efficiency Ideal for automated placement High forward surge capability Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS PARAMETER VALUE UNIT IF 5 A VRRM 50 - 60 V IFSM 75 A TJ MAX 150 °C Package DO-214AC (SMA) Configuration Single die ● Trench Schottky barrier rectifier is designed for high frequency miniature switched mode power supplies such as adapters, lighting and on-board DC/DC converters. ● MECHANICAL DATA ● ● ● ● ● ● Case: DO-214AC (SMA) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.060g (approximately) DO-214AC (SMA) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device TSSA5U50 TSSA5U60 5U50 5U60 UNIT Repetitive peak reverse voltage VRRM 50 60 V Reverse voltage, total rms value VR(RMS) 35 42 V Forward current Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load Junction temperature IF 5 A IFSM 75 A TJ - 55 to +150 °C Storage temperature TSTG - 55 to +150 °C 1 Version: E2102 TSSA5U50 – TSSA5U60 Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL Junction-to-lead thermal resistance TSSA5U50 TSSA5U60 Junction-to-ambient thermal resistance TYP UNIT 25 °C/W 28 °C/W 70 °C/W RӨJL RӨJA ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS TSSA5U50 Forward voltage (1) TSSA5U60 TSSA5U50 TSSA5U60 Reverse current @ rated VR (2) SYMBOL IF = 5A, TJ = 25°C VF IF = 5A, TJ = 125°C TJ = 25°C IR TJ = 125°C TYP MAX UNIT 0.44 0.54 V 0.48 0.56 V 0.39 0.49 V 0.44 0.52 V - 300 µA - 50 mA Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING TSSA5Ux DO-214AC (SMA) 7,500 / Tape & Reel Notes: 1. “x” defines voltage from 50V(TSSA5U50) to 60V(TSSA5U60) 2 Version: E2102 TSSA5U50 – TSSA5U60 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 10000 TSSA5U50 5 CAPACITANCE (pF) 4 TSSA5U60 3 2 1 1000 100 With heat sink 5mm x 5mm Cu-pad f=1.0MHz Vsig=50mVp-p 10 0 50 75 100 125 0.1 150 1 LEAD TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.4 Typical Forward Characteristics 100 TSSA5U50 TJ=150°C TJ=125°C 1 TJ=100°C 0.1 0.01 TJ=25°C 0.001 10 20 30 40 50 60 70 80 90 100 10 10 TSSA5U50 1 1 0.1 UF1DLW TJ=150°C TJ=125°C TJ=125°C TJ=100°C 0.1 0.001 0.0 0.1 0.2 0.3 0.3 0.4 0.5 0.6 INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) TSSA5U60 TJ=125°C TJ=100°C 0.1 0.01 TJ=25°C 0.001 10 20 30 40 50 60 70 80 90 0.4 0.7 0.5 0.8 0.6 0.9 0.7 1 1.1 1.2 1.1 1.2 Fig.6 Typical Forward Characteristics 100 1 Pulse width 300μs 1% duty cycle Pulse width FORWARD VOLTAGE (V) Fig.5 Typical Reverse Characteristics 10 TJ=25°C TJ=25°C 0.01 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) TJ=150°C 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 10 10 (A) 25 100 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 10 10 TSSA5U60 1 10.1 UF1DLW TJ=150°C TJ=125°C TJ=125°C TJ=100°C TJ=25°C (A) AVERAGE FORWARD CURRENT (A) 6 TJ=25°C 0.01 0.1 0.001 0.0 0.1 0.2 0.3 0.3 0.4 0.5 0.6 Pulse width 300μs 1% duty cycle Pulse width 0.4 0.7 0.5 0.8 0.6 0.9 0.7 1 FORWARD VOLTAGE (V) 3 Version: E2102 TSSA5U50 – TSSA5U60 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.7 Maximum Non-Repetitive Forward Surge Current PEAK FORWARD SURGE CURRENT (A) 80 70 8.3ms single half sine wave 60 50 40 30 20 10 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 4 Version: E2102 TSSA5U50 – TSSA5U60 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-214AC (SMA) SUGGESTED PAD LAYOUT MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YW = Date Code F = Factory Code Version: E2102 TSSA5U50 – TSSA5U60 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: E2102
TSSA5U50 价格&库存
很抱歉,暂时无法提供与“TSSA5U50”相匹配的价格&库存,您可以联系我们找货
