SB120TA
SB120TA
    SMCDIODESOLUTIONS(桑德斯)
    DO-204AL
    DIODE SCHOTTKY 20V 1A DO41
SB120TA 数据手册
SB120 THRU SB160 Technical Data Data Sheet N0869, Rev. C SB120 THRU SB160 SCHOTTKY RECTIFIER Features           DO-41 Circuit Diagram Schottky Barrier Chip Guard Ring Die Construction for Transient Protection High Current Capability Low Power Loss, High Efficiency High Surge Current Capability For Use in Low Voltage, High Frequency Inverters, Free Wheeling, and Polarity Protection Applications Green Products in Compliance with the RoHS Directive This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Data      Case: JEDEC DO-41 molded plastic body Terminals: Plated axial leads, solderable per MIL-STD750,Method 2026 Polarity: Color band denotes cathode end Mounting Position: Any Weight:0.012 ounce, 0.34 grams Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified Characteristics Symbol Maximum repetitive peak reverse voltage Maximum DC blocking voltage Maximum RMS voltage Maximum average forward rectified current 0.375"( 9.5mm ) lead length at TL=100℃ Peak forward surge current 8.3ms single half sine-wave superimposed on rated load ( JEDEC Method) Maximum instantaneous forward voltage at 1.0A VRRM VDC VRMS SB130 SB140 SB150 SB160 Units 20 30 40 50 60 V 14 21 28 35 42 V I(AV) 1.0 A IFSM 40 A VF Maximum DC reverse current TA=25℃ at rated DC blocking voltage TA=100℃ IR Typical junction capacitance ( Note 1) CJ Typical thermal resistance junction to lead Typical thermal resistance junction to ambient( Note 2) Operating junction and storage temperature range SB120 0.55 0.70 0.5 10 110 V mA 80 pF RθJL 15 ℃/W RθJA 50.0 ℃/W TJ,TSTG -65 to +125 ℃ Note: 1. Measured at 1MHz and applied reverse voltage of 4.0V D.C. 3. Thermal resistance from junction to ambient at 0.375”(9.5mm) lead length, P.C.B mounted.  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SB120 THRU SB160 Technical Data Data Sheet N0869, Rev. C Ratings and Characteristics Curves  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SB120 THRU SB160 Technical Data Data Sheet N0869, Rev. C Mechanical Dimensions DO-41 Millimeters SYMBOL Ordering Information Device SB120 THRU SB160 Inches Min. Max. Min. Max. A 25.4 - 1.000 - B 4.06 5.21 0.160 0.205 C 0.71 0.864 0.028 0.034 D 2.00 2.72 0.079 0.107 Marking Diagram Package Shipping DO-41(Pb-Free) 5000pcs / tape For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging specification. SB120 = Part Name Carrier Tape Specification DO-41 SYMBOL Millimeters Min. Max. A 4.50 5.50 B 50.9 53.9 Z - 1.20 T 5.60 6.40 E - 0.80 IL1-L2I - 1.0  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SB120 THRU SB160 Technical Data Data Sheet N0869, Rev. C DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
SB120TA 价格&库存
很抱歉,暂时无法提供与“SB120TA”相匹配的价格&库存,您可以联系我们找货
