FR302GTA
FR302GTA
    SMCDIODESOLUTIONS(桑德斯)
    DO-201AD
    DIODE GPP 100V 3A DO201AD
FR302GTA 数据手册
FR301G-FR307G Technical Data Data Sheet N0449, Rev. A FR301G THRU FR307G GLASS PASSIVATED FAST RECOVERY RECTIFIERS Features          DO-201AD Circuit Diagram Glass passivated Die Construction High Current Capability Low Forward Voltage Drop, High Efficiency Low Power Loss Fast Recovery Time High Surge Current Capability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Data       Case: DO-201AD molded plastic body Terminals: Plated axial leads, solderable per MILSTD-750, Method 2026 Polarity: Color band denotes cathode end Mounting Position: Any Weight: 0.04 ounce, 1.10 grams Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified Single phase half-wave 60Hz, resistive or inductive load, for capacitive load current derate by 20%. Characteristic Symbol Maximum repetitive peak reverse voltage Maximum DC blocking voltage VRRM VDC Maximum RMS voltage VRMS Maximum average forward rectified current 0.375”(9.5mm) lead length at @TL =75°C Peak forward surge current 8.3ms single half sinewave superimposed on rated load (JEDEC Method) FR FR FR 301G 302G 303G 5 1 50 100 200 3 7 35 70 140 FR 304G 2 400 1 280 FR 305G 4 600 2 420 FR FR 306G 307G 6 8 800 1000 4 5 560 700 Units 1 V 1 V I(AV) 3.0 A IFSM 125 A Maximum instantaneous forward voltage at 3.0A VF 1.3 V Maximum DC reverse current At Rated DC Blocking Voltage IRM 5.0 100 µA @TA = 25°C @TA = 125°C Maximum reverse recovery time (Note 1) trr 150 250 Typical Junction Capacitance (Note 2) CJ 60 pF Typical Thermal Resistance Junction to Ambient (Note 3) RθJA 20 °C/W Operating junction temperature range TJ -65 to +150 °C Operating storage temperature range TSTG -65 to +150 °C Note: 1. Reverse recovery condition IF=0.5A, IR=1.0A, Irr=0.25A 2. Measured at 1MHz and applied reverse voltage of 4.0V D.C. 3. Thermal resistance from junction to ambient at 0.375”(9.5mm)lead length, P.C.B. mounted  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  500 ns FR301G-FR307G Technical Data Data Sheet N0449, Rev. A Ratings and Characteristics Curves  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  FR301G-FR307G Technical Data Data Sheet N0449, Rev. A Mechanical Dimensions DO-201AD SYMBOL Ordering Information Device FR301G-FR307G Package DO-201AD (Pb-Free) Millimeters Inches Min. Max. Min. Max. A 25.4 - 1.000 - B 7.2 9.5 0.285 0.375 C 1.2 1.3 0.048 0.052 D 5.0 5.6 0.197 0.220 Marking Diagram Shipping Where XXXXX is YYWWL FR301G SSG YY WW L 1250pcs / tape For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging specification. = Part Name = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Carrier Tape Specification DO-201AD SYMBOL Millimeters Min. Max. A 9.50 10.50 B 50.9 53.9 Z - 1.20 T 5.60 6.40 E - 0.80 IL1-L2I - 1.0  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  FR301G-FR307G Technical Data Data Sheet N0449, Rev. A DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
FR302GTA
- 物料型号:FR301G-FR307G - 器件简介:这些是玻璃钝化快速恢复二极管,具有高电流能力、低正向电压降、高效率、低功耗、快速恢复时间和高浪涌电流能力。 - 引脚分配:文档中提到了极性,色带表示阴极端。 - 参数特性:包括最大重复峰值反向电压(VRRM)、最大直流阻断电压(Voc)、最大有效值电压(VRMS)、最大平均前向整流电流(I(AV))、峰值前向浪涌电流(IFSM)、最大瞬时前向电压(VF)、最大直流反向电流(IRM)、最大反向恢复时间(tr)、典型结电容(CJ)和典型结到环境的热阻(ReJA)。 - 功能详解:文档中提供了关于器件特性、测试电路图和导热特性的详细描述。 - 应用信息:适用于单相半波60Hz、阻性或感性负载,对于电容性负载,电流需要降低20%。 - 封装信息:DO-201AD塑封体,镀层轴向引脚,可按MIL-STD-750方法2026焊接。
FR302GTA 价格&库存
很抱歉,暂时无法提供与“FR302GTA”相匹配的价格&库存,您可以联系我们找货
