S-882152AMH-M3BTFU
S-882152AMH-M3BTFU
    ABLIC(艾普凌科)
    SOT23-6
    IC REG CHARGE PUMP 5.2V SOT23-6W
S-882152AMH-M3BTFU 数据手册
S-8821 Series www.ablic.com VOLTAGE REGULATION BOOST CHARGE PUMP DC-DC CONVERTER Rev.5.2_00 © ABLIC Inc., 2002-2021 The S-8821 series is a CMOS boost charge pump DC-DC converter with a voltage regulation function. The S-8821 series consists of an oscillation circuit, a controller, a reference voltage circuit, an error amplifier circuit, and an output switching transistor, and can regulate the output voltage by PFM control. Since small ceramic capacitors can be used for the pump capacitor, input capacitor, and output capacitor, the mounting area can be minimized.  Features • PFM control CMOS boost charge pump • Power supply voltage: • Output voltage: • Output voltage accuracy: • Built-in soft start circuit: • Output current • Oscillation frequency: • ON/OFF function: • Lead-free, Sn 100%, halogen-free*1 1.6 to 5.0 V 2.5 to 5.5 V, selectable in 0.1 V steps. ±2 % max. 1.0 ms typ. 25 mA (VIN=(VOUT(S) × 0.80) V) 1.0 MHz typ. During standby: 1 μA max. *1. Refer to “ Product Name Structure” for details.  Applications • Lithium ion battery driven applications • Local power supply • Power supply for white LED display backlights  Packages • SOT-23-6W • SNT-8A 1 VOLTAGE REGULATION BOOST CHARGE PUMP DC-DC CONVERTER S-8821 Series Rev.5.2_00  Block Diagram VIN CIN=4.7 μF VOUT SW1 COUT=10 μF Rs C+ SW2 PFM control oscillator circuit (1.0 MHz) Switch control circuit CPUMP=0.10 μF C− Rf - SW3 SW4 Soft start circuit ON/OFF circuit ON/OFF Figure 1 2 + Reference voltage GND VOLTAGE REGULATION BOOST CHARGE PUMP DC-DC CONVERTER S-8821 Series Rev.5.2_00  Product Name Structure • The output voltage and packages for the S-8821 Series can be selected at the user’s request. Refer to the “Product name” for the meanings of the characters in the product name, “Package” regarding the package drawings and “Product name list” for the full product names. 1. Product name (1) SOT-23-6W S-8821 xx A MH - xxx TF x Environmental code S: Lead-free, halogen-free G: Lead-free (Contact our sales representatives for details) U: Lead-free (Sn 100%), halogen-free IC direction in tape specifications*1 Product name (abbreviation)*2 Package name (abbreviation) MH: SOT-23-6W Output voltage 25 to 55 (E.g., when the output voltage is 2.5 V, it is expressed as 25.) *1. Refer to the tape specifications at the end of this book. *2. Refer to the product name list. (2) SNT-8A S-8821 xx A PH - xxx TF U Environmental code U: Lead-free (Sn 100%), halogen-free IC direction in tape specifications*1 Product name (abbreviation)*2 Package name (abbreviation) PH: SNT-8A Output voltage 25 to 55 (E.g., when the output voltage is 2.5 V, it is expressed as 25.) *1. Refer to the tape specifications at the end of this book. *2. Refer to the product name list. 2. Package Package Name SOT-23-6W SNT-8A Drawing Code Package Tape Reel MP006-B-P-SD PH008-A-P-SD MP006-B-C-SD PH008-A-C-SD MP006-B-R-SD PH008-A-R-SD Land ⎯ PH008-A-L-SD 3 VOLTAGE REGULATION BOOST CHARGE PUMP DC-DC CONVERTER S-8821 Series Rev.5.2_00 3. Product name list Table 1 Output Voltage SOT-23-6W SNT-8A S-882125APH-M2ATFU 2.5 V S-882125AMH-M2ATF ⎯ 3.0 V S-882130AMH-M2FTF ⎯ 3.3 V S-882133AMH-M2ITF ⎯ 3.5 V S-882135AMH-M2KTF ⎯ 3.6 V S-882136AMH-M2LTF ⎯ 4.0 V S-882140AMH-M2PTF ⎯ 4.5 V S-882145AMH-M2UTF S-882150APH-M2ZTFU 5.0 V S-882150AMH-M2ZTF ⎯ 5.2 V S-882152AMH-M3BTF ⎯ 5.5 V S-882155AMH-M3ETF Remark 1. Please contact our sales representatives for products other than the above. 2. : G, S or U 3. Please select products of environmental code = U for Sn 100%, halogen-free products. 4 VOLTAGE REGULATION BOOST CHARGE PUMP DC-DC CONVERTER S-8821 Series Rev.5.2_00  Pin Configurations Table 2 SOT-23-6W Top view 6 1 5 2 Pin No. 1 4 3 Symbol VIN 2 C+ 3 C− 4 ON/OFF 5 6 GND VOUT Pin Description Voltage input pin Charge-pump pump capacitor connection pin (positive pin) Charge-pump pump capacitor connection pin (negative pin) Shutdown pin High level (H) : normal operation (boost) Low level (L) : boost halt (all circuit halt) GND pin Voltage output pin Figure 2 SNT-8A Top view Table 3 1 8 2 7 3 6 4 5 Figure 3 Pin Description Charge-pump pump capacitor connection pin 1 C+ (positive pin) 2 VIN Voltage input pin 3 NC*1 No connection 4 VOUT Voltage output pin Shutdown pin 5 ON/OFF High level (H) : normal operation (boost) Low level (L) : boost halt (all circuit halt) 6 GND GND pin 7 NC*1 No connection Charge-pump pump capacitor connection pin 8 C− (negative pin) *1. The NC pin is electrically open. The NC pin can be connected to VIN or GND. Pin No. Symbol 5 VOLTAGE REGULATION BOOST CHARGE PUMP DC-DC CONVERTER S-8821 Series Rev.5.2_00  Absolute Maximum Ratings Table 4 Items Symbols VC+ VC− VIN VOUT VON/OFF C+ pin voltage C− pin voltage VIN pin voltage VOUT pin voltage ON/OFF pin voltage Power dissipation SOT-23-6W (Ta=25°C unless otherwise specified) Absolute Maximum Ratings Units V VGND−0.3 to VGND+7.5 V VGND−0.3 to VGND+7 V VGND−0.3 to VGND+5.5 V VGND−0.3 to VGND+7 V VGND−0.3 to VIN+0.3 300 (When not mounted on board) mW 650*1 mW 450*1 mW −40 to +85 °C −40 to +125 °C PD SNT-8A Operating ambient temperature Topr Storage temperature Tstg *1. When mounted on board [Mounted board] (1) Board size: 114.3 mm × 76.2 mm × t1.6 mm (2) Board name: JEDEC STANDARD51-7 Caution The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions. (2) When not mounted on board 400 Power Dissipation PD (mW) Power Dissipation PD (mW) (1) When mounted on board 800 700 600 SOT-23-6W 500 400 300 SNT-8A 200 100 0 0 50 100 150 Ambient Temperature Ta (°C) 350 300 250 200 150 100 50 0 0 50 150 Ambient Temperature Ta (°C) Figure 4 Power Dissipation of Package 6 100 VOLTAGE REGULATION BOOST CHARGE PUMP DC-DC CONVERTER S-8821 Series Rev.5.2_00  Electrical Characteristics Table 5 (VIN=(VOUT(S) × 0.60) V*1, Ta=25°C unless otherwise specified) Items Symbols Conditions VOUT(S) ≤ 2.9 V Operation input voltage VIN Output voltage*2 VOUT(E) Output current IOUT Line regulation ΔVOUT1 Load regulation Ripple voltage*4 Maximum oscillation frequency ΔVOUT2 VRIP Efficiency*5 η *3 fosc VOUT(S) > 2.9 V IOUT=10 mA VIN=(VOUT(S) × 0.54) V*6 VIN=(VOUT(S) × 0.60) V*1 VIN=(VOUT(S) × 0.80) V VIN=(VOUT(S) × 0.60) V*1 to (VOUT(S) − 0.10) V, IOUT=10 mA IOUT=0.1 mA to 10 mA IOUT=10 mA VOUT=(VOUT(S) × 0.60) V, Measure waveform at C− pin VIN=(VOUT(S) × 0.54) V, VOUT(S) ≥ 3.0 V, IOUT=5 mA VIN=VOUT(S), VOUT=(VOUT(S) + 0.5) V VIN=(VOUT(S) × 0.54) V*6 to 5.0 V, VON/OFF=0 V Min. Typ. Max. ⎯ 1.6 5.0 VOUT(S) × ⎯ 5.0 0.54 VOUT(S) × VOUT(S) × VOUT(S) 0.98 1.02 ⎯ ⎯ 5 ⎯ ⎯ 15 ⎯ ⎯ 25 Units Test circuits V 2 V 2 V 2 mA mA mA 2 2 2 ⎯ 50 100 mV 2 ⎯ ⎯ 40 70 80 ⎯ mV mVp−p 2 2 800 1000 1200 kHz 2 ⎯ 90 ⎯ % 1 Operation consumption ISS1 ⎯ μA 35 60 current Standby consumption ISSS ⎯ μA 0.3 1.0 current ON/OFF pin input VSH VIN=(VOUT(S) × 0.54) V*6 to 5.0 V ⎯ ⎯ 1.5 V voltage (high level) ON/OFF pin input VSL VIN=(VOUT(S) × 0.54) V*6 to 5.0 V ⎯ ⎯ 0.3 V voltage (low level) ON/OFF pin input ISH VIN=(VOUT(S) × 0.54) V*6 to 5.0 V −0.1 ⎯ μA 0.1 current (high level) ON/OFF pin input ISL VIN=(VOUT(S) × 0.54) V*6 to 5.0 V −0.1 ⎯ μA 0.1 current (low level) Soft start time tSS IOUT=10 mA 0.2 1.0 4.0 ms *1. In case of VOUT ≤ 3.3 V, VIN=2.0 V *2. VOUT(E): Actual output voltage VOUT(S): Specified output voltage *3. The output current at which the output voltage becomes 97 % of VOUT(E) after gradually increasing the output current. *4. Design assurance *5. The ideal efficiency is indicated by the following expression. Efficiency (η)=(VOUT × IOUT) / (2.0 × VIN × IOUT) *6. In case of VOUT ≤ 2.9 V, VIN=1.6 V 2 1 1 1 1 1 1 7 VOLTAGE REGULATION BOOST CHARGE PUMP DC-DC CONVERTER S-8821 Series  Test Circuits 1. 4.7 μF A A VIN VOUT C+ GND C− ON/OFF A A A Figure 5 2. 0.1 μF 4.7 μF VIN VOUT C+ GND C− ON/OFF A A Figure 6 8 10 μF Rev.5.2_00 VOLTAGE REGULATION BOOST CHARGE PUMP DC-DC CONVERTER S-8821 Series Rev.5.2_00  Operation 1. Basic operation Figure 7 shows the block diagram of the S-8821 Series. The S-8821 series controls the output voltage by using the pulse frequency modulation (PFM) method. The SW1 to SW4 switching transistors are switched ON/OFF with the clock generated by the internal oscillator circuit, and operates the boost charge pump. The output voltage is fed back and the voltage split by feedback resistances Rs and Rf and reference voltage (Vref) are compared by a comparator. This comparator signal is used to modulate the oscillation pulse frequency in order to keep the output voltage constant. VIN CIN=4.7 μF VOUT SW1 COUT=10 μF Rs C+ SW2 PFM control oscillator circuit (1.0 MHz) Switch control circuit CPUMP=0.10 μF C− + Rf - SW3 SW4 Soft start circuit ON/OFF circuit ON/OFF Reference voltage GND Figure 7 9 VOLTAGE REGULATION BOOST CHARGE PUMP DC-DC CONVERTER S-8821 Series Rev.5.2_00 2. Boost Charge Pump The boost charge pump boosts the voltage by switching ON/OFF of the SW1 to SW4 switching transistors. First, in order to charge the pump capacitance (CPUMP), set SW1 to OFF, SW2 to ON, SW3 to OFF, and SW4 to ON (charge cycle). Following charging the electricity, in order to discharge the charged electricity to the output capacitance (COUT), SW1 set the switches as to ON, SW2 to OFF, SW3 to ON, and SW4 to OFF (discharge cycle). The input voltage can be boosted to a constant voltage value by repeating this charge cycle and discharge cycle. Figure 8 shows the charge cycle, and Figure 9 shows the discharge cycle. SW 2: ON V IN Current flow SW 1: OFF C PUMP 0.10 μF SW 4: ON C OUT 10 μF SW 3: OFF Figure 8 SW 2: OFF V IN SW 1: ON C PUMP 0.10 μF C OUT 10 μF Current flow SW 4: OFF Figure 9 10 SW 3: ON Rev.5.2_00 VOLTAGE REGULATION BOOST CHARGE PUMP DC-DC CONVERTER S-8821 Series 3. Shutdown Pin (ON/OFF Pin) Setting the ON/OFF pin to the Low level ("L") causes the voltage of the VOUT pin to change to the GND level and simultaneously the operation of all the internal circuit to stop. At this time, the consumption current is largely reduced, to a level of approximately 0.3 μA. The structure of the ON/OFF pin is as shown in Figure 10. Since the ON/OFF pin is neither pulled down nor pulled up internally, do not use it in the floating state. When the ON/OFF pin is not used, connect it to the VIN pin. Table 6 ON/OFF pin “H”: Power on “L”: Power off Internal circuit Operating Stop VIN VOUT pin voltage Set value VGND level VIN ON/OFF GND Figure 10 4. Soft Start Function The S-8821 Series features a built-in soft start circuit. Upon power application or when the ON/OFF pin is switched from "L" to "H", the output voltage gradually rises over the soft start time, and the output current is gradually output as a result. This soft start function reduces the input current rush. 11 VOLTAGE REGULATION BOOST CHARGE PUMP DC-DC CONVERTER S-8821 Series Rev.5.2_00  External Capacitor Selection 1. Input and Output Capacitors (CIN, COUT) The input capacitor (CIN) lowers the power supply impedance and averages the input current. The CIN value is selected according to the impedance of the power supply that is used. Select a ceramic capacitor with a small equivalent series resistance (ESR). Although this figure varies according to the impedance of the power supply that is used as well as the load current value, it is generally in the range of 4.7 μF to 10 μF. For the output capacitor (COUT), select a ceramic capacitor with a small ESR for smoothing the ripple voltage. A value of 10 μF is recommended for the capacitance value. Use of a capacitor with a capacitance lower than 10 μF results in a larger ripple voltage. Conversely, use of a capacitor with a capacitance greater than 10 μF results in the output voltage not being able to rise up to setting value and the impossibility to obtain the desired output current. 2. Pump Capacitor (CPUMP) The pump capacitor (CPUMP) is required for boosting the voltage. Select a ceramic capacitor with a small ESR. A capacitance value of 0.10 μF is recommended. Use of a capacitor with a capacitance greater than 0.10 μF results in a larger ripple voltage. Conversely, use of a capacitor with a capacitance lower than 0.10 μF results in the output voltage not being able to raise up to setting value and the impossibility to obtain the desired output current. 12 Rev.5.2_00 VOLTAGE REGULATION BOOST CHARGE PUMP DC-DC CONVERTER S-8821 Series  Precautions • Regarding the wiring to the VIN pin, VOUT pin, C+ pin, C− pin and GND pin, be careful to perform pattern wiring so as to obtain low impedance. • Always connect a capacitor to the VOUT pin, C+ pin, and C− pin. • Connect CIN and COUT in the vicinity of the IC and sufficiently strengthen the wiring for GND pin and VIN pin in order to lower the impedance of the wiring resistance, etc. High impedance may cause unstable operation. Moreover, in selecting CIN and COUT, perform a full evaluation of the actual usage conditions. • Connect CPUMP in the vicinity of the IC and sufficiently strengthen the wiring for the C+ pin and C− pin in order to lower the impedance of the wiring resistance, etc. High impedance may cause instable operation. Moreover, in selecting CPUMP, perform a full evaluation of the actual usage conditions. • The ON/OFF pin is configured as shown in Figure 9 and is neither pulled up or down internally, so do not use this pin in a floating state. When not using the ON/OFF pin, connect it to the VIN pin. Moreover, please do not apply voltage higher than VIN + 0.3 V to an ON/OFF pin. Current flows for a VIN pin through the protection diode inside IC. • Since this IC consists of double boost circuits, it cannot set more than twice voltage of VIN to VOUT(S). • Be careful about the usage conditions for the input/output voltages and output current to make sure that dissipation within the IC does not exceed the allowable power dissipation of the package. For reference, the calculation of the power consumption in this IC is shown below. PD=(VIN × 2.0 − VOUT) × (IOUT) Reference: VIN=4.2 V, VOUT=5.5 V, IOUT=10 mA PD=(4.2 × 2.0 − 5.5) × 0.010=29 mW • Since the information described herein is subject to change without notice, confirm that this is the latest one before using. • Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit. • ABLIC Inc. claims no responsibility for any and all disputes arising out of or in connection with any infringement of the products including this IC upon patents owned by a third party. 13 VOLTAGE REGULATION BOOST CHARGE PUMP DC-DC CONVERTER S-8821 Series Rev.5.2_00  Characteristics (Typical Data) (1) Output voltage vs. Operation input voltage S-882133A S-882150A IOUT=10 mA, Ta=25°C IOUT=10 mA, Ta=25°C 3.50 3.45 5.30 5.20 5.10 3.35 VOUT [V] VOUT [V] 3.40 3.30 3.25 3.20 5.00 4.90 4.80 3.15 3.10 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 4.70 1.5 2.0 5.5 2.5 3.0 VIN [V] 3.5 4.0 4.5 5.0 5.5 VIN [V] (2) Output voltage vs. Output current S-882150A S-882133A VIN=2.0 V, Ta=25°C VIN=3.0 V, Ta=25°C 5.30 5.20 3.40 3.35 5.10 VOUT [V] VOUT [V] 3.50 3.45 3.30 3.25 3.20 4.90 4.80 3.15 3.10 5.00 0 5 15 10 20 25 4.70 30 0 5 15 10 IOUT [mA] 20 25 30 IOUT [mA] (3) Operation consumption vs. Operation input voltage S-882133A S-882150A 50 45 40 35 40 30 25 35 30 25 20 20 15 15 10 1.5 2.0 2.5 3.0 3.5 VIN [V] 14 Ta=25°C 50 45 ISS1 [μ A] ISS1 [μ A] Ta=25°C 4.0 4.5 5.0 5.5 10 1.5 2.0 2.5 3.0 3.5 VIN [V] 4.0 4.5 5.0 5.5 VOLTAGE REGULATION BOOST CHARGE PUMP DC-DC CONVERTER S-8821 Series Rev.5.2_00 (4) Ripple voltage vs. Operation input voltage S-882133A S-882150A IOUT=10 mA, Ta=25°C 100 100 80 80 VRIP [mVp-p] VRIP [mVp-p] IOUT=10 mA, Ta=25°C 60 40 40 20 20 0 1.5 2.0 60 2.5 3.0 4.0 3.5 4.5 5.0 0 1.5 2.0 5.5 2.5 3.0 VIN [V] 3.5 4.0 4.5 5.0 5.5 VIN [V] (5) Efficiency*1 vs. Operation input voltage S-882133A S-882150A IOUT=10 mA, Ta=25°C 100 100 80 80 η [%] η [%] IOUT=10 mA, Ta=25°C 60 40 40 20 1.5 2.0 60 2.5 3.0 3.5 4.0 4.5 5.0 20 1.5 2.0 5.5 2.5 3.0 VIN [V] 3.5 4.0 4.5 5.0 5.5 VIN [V] *1. The ideal efficiency is indicated by the following expression. Efficiency (η)=(VOUT × IOUT) / (2.0 × VIN × IOUT) (6) Maximum oscillation frequency vs. Operation input voltage S-882150A S-882133A Ta=25°C 1300 1300 1200 1200 1100 1100 fOSC [kHz] fOSC [kHz] Ta=25°C 1000 900 800 700 1.5 2.0 1000 900 800 2.5 3.0 3.5 VIN [V] 4.0 4.5 5.0 5.5 700 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 VIN [V] 15 VOLTAGE REGULATION BOOST CHARGE PUMP DC-DC CONVERTER S-8821 Series Rev.5.2_00 (7) Load fluctuation S-882133A S-882150A VIN=2.0 V CH1 VIN=3.0 V CH1 10 mA 10 mA CH2 CH2 1 mA 1 mA [1 ms/div.] [1 ms/div.] CH1: VOUT [20 mV/div.] CH2: IOUT [2 mA/div.] CH1: VOUT [20 mV/div.] CH2: IOUT [2 mA/div.] (8) Input voltage fluctuation S-882133A S-882150A IOUT=10 mA CH1 CH1 3.3 V CH2 5.0 V CH2 3.0 V 1.8 V [1 ms/div.] CH1: VOUT [20 mV/div.] CH2: VIN [1 V/div.] 16 IOUT=10 mA [1 ms/div.] CH1: VOUT [20 mV/div.] CH2: VIN [1 V/div.] 2.9±0.2 1.9±0.2 6 4 5 1 0.95 2 +0.1 0.15 -0.08 3 0.95 +0.1 0.4 -0.05 No. MP006-B-P-SD-2.1 TITLE SOT236-B-PKG Dimensions No. MP006-B-P-SD-2.1 ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches:40.0±0.2) +0.1 ø1.5 -0 +0.2 ø1.0 -0 2.0±0.05 0.25±0.1 4.0±0.1 1.4±0.2 3.2±0.2 3 2 1 4 5 6 Feed direction No. MP006-B-C-SD-1.0 TITLE SOT236-B-Carrier Tape No. MP006-B-C-SD-1.0 ANGLE UNIT mm ABLIC Inc. 12.5max. 9.0±0.3 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. MP006-B-R-SD-1.0 TITLE SOT236-B-Reel No. MP006-B-R-SD-1.0 QTY ANGLE UNIT mm ABLIC Inc. 3,000 1.97±0.03 8 7 6 5 3 4 +0.05 1 0.5 2 0.08 -0.02 0.48±0.02 0.2±0.05 No. PH008-A-P-SD-2.1 TITLE SNT-8A-A-PKG Dimensions No. PH008-A-P-SD-2.1 ANGLE UNIT mm ABLIC Inc. +0.1 ø1.5 -0 2.25±0.05 4.0±0.1 2.0±0.05 ø0.5±0.1 0.25±0.05 0.65±0.05 4.0±0.1 4 321 5 6 78 Feed direction No. PH008-A-C-SD-2.0 TITLE SNT-8A-A-Carrier Tape No. PH008-A-C-SD-2.0 ANGLE UNIT mm ABLIC Inc. 12.5max. 9.0±0.3 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. PH008-A-R-SD-1.0 TITLE SNT-8A-A-Reel No. PH008-A-R-SD-1.0 QTY. ANGLE UNIT mm ABLIC Inc. 5,000 0.52 2.01 2 0.52 0.2 0.3 1. 2. 1 (0.25 mm min. / 0.30 mm typ.) (1.96 mm ~ 2.06 mm) 1. 2. 3. 4. 0.03 mm SNT 1. Pay attention to the land pattern width (0.25 mm min. / 0.30 mm typ.). 2. Do not widen the land pattern to the center of the package (1.96 mm to 2.06mm). Caution 1. Do not do silkscreen printing and solder printing under the mold resin of the package. 2. The thickness of the solder resist on the wire pattern under the package should be 0.03 mm or less from the land pattern surface. 3. Match the mask aperture size and aperture position with the land pattern. 4. Refer to "SNT Package User's Guide" for details. 1. 2. (0.25 mm min. / 0.30 mm typ.) (1.96 mm ~ 2.06 mm) TITLE No. PH008-A-L-SD-4.1 SNT-8A-A -Land Recommendation PH008-A-L-SD-4.1 No. ANGLE UNIT mm ABLIC Inc. Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-882152AMH-M3BTFU 价格&库存
很抱歉,暂时无法提供与“S-882152AMH-M3BTFU”相匹配的价格&库存,您可以联系我们找货
