BAT43X
Taiwan Semiconductor
200mA, 30V Schottky Barrier Diode
FEATURES
Low forward voltage drop
Fast switching time
Surface mounted device
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF(AV)
200
mA
VRRM
30
V
IFSM
4
A
VF at IF=200mA
1
V
TJ Max.
125
°C
d
KEY PARAMETERS
APPLICATIONS
SOD-523F
Package
de
● Portable consumer electronic devices
MECHANICAL DATA
e co
mm
Case: SOD-523F
Molding compound meets UL 94 V-0 flammability rating
Moisture sensitivity level: level 1, per J-STD-020
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 1A whisker test
Polarity: Indicated by cathode band
Weight: 1.3mg (approximately)
No
tR
Single die
en
Configuration
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Marking code on the device
SYMBOL
BAT43X
UNIT
S8
Repetitive peak reverse voltage
VRRM
30
V
Maximum dc blocking voltage
Forward current
Peak forward surge current @t
很抱歉,暂时无法提供与“BAT43X RSG”相匹配的价格&库存,您可以联系我们找货
