BAV19WS-G RRG
BAV19WS-G RRG
    TAIWANSEMICONDUCTOR(台湾半导体)
    SC76
    100V 200MA
BAV19WS-G RRG 数据手册
BAV19WS-G/BAV20WS-G/BAV21WS-G Taiwan Semiconductor Small Signal Product 200mA, 120V - 250V Switching Diodes FEATURES - Fast Switching Speed - Surface Mount Package Ideally Suited For Automatic Insertion - High Conductance - Packing code with suffix "G" means green compound (halogen-free) - Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC SOD-323 - Halogen-free according to IEC 61249-2-21 APPLICATION Surface mount fast switching diode General purpose small signal switching MECHANICAL DATA - Case: SOD-323 small outline plastic package - Moisture sensitivity level 1 - Polarity: Indicated by cathode band - Weight: 4.36 ± 0.5 mg MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25°C unless otherwise noted) PARAMETER SYMBOL BAV19WS-G BAV20WS-G BAV21WS-G UNIT Average Rectified Output Current IO 200 mA Repetitive Peak Reverse Voltage VRRM 120 200 250 V VR 100 150 200 V DC Reverse Voltage Non-Repetitive Peak Forward Surge Current Pulse Width = 1 μs Pulse Width = 1 s Repetitive Peak Forward Surge Current Power Dissipation Thermal Resistance Junction to Ambient Junction and Storage Temperature Range PARAMETER Breakdown Voltage (Note 1) Forward Voltage Reverse Leakage Current (Note 2) Junction Capacitance 625 mA PD 200 mW RθJA 625 °C/W TJ , TSTG -65 to 150 °C MIN MAX 120 - 200 - 250 - - 1.00 - 1.25 IR - 100 nA CJ - 5 pF trr - 50 ns BAV19WS-G V(BR)R BAV21WS-G IF=100mA IF=200mA A 0.5 IFRM SYMBOL BAV20WS-G 2.5 IFSM VF UNIT V V BAV19WS-G BAV20WS-G BAV21WS-G VR=0, f=1.0MHz Reverse Recovery Time (Note 3) Note 1: Test condition : IR= 100μA Note 2: Test condition : BAV19WS-G @ VR=100V, BAV20WS-G @ VR=150V, BAV21WS-G @ VR=200V Note 3: Test condition : IF= IR= 30mA , RL=100Ω , Irr=0.1xIR Document Number: DS_S0000021 Version: A15 BAV19WS-G/BAV20WS-G/BAV21WS-G Taiwan Semiconductor Small Signal Product RATINGS AND CHARACTERISTICS CURVES (TA=25°C unless otherwise noted) Fig. 1 Typical Forward Characteristics Fig. 2 Typical Reverse Characteristics 100 IR, Instantaneous Reverse Current (μA) IF,Instantaneous Forward Current (A) 1 TA=150oC TA=125oC TA=75oC TA=25oC TA=0oC TA=-40oC 0.1 0.01 0.001 0 0.2 0.4 0.6 0.8 1 1.2 10 TA=125oC 1 TA=75oC 0.1 TA=25oC 0.01 TA=0oC 0.001 TA=-40oC TA=150oC 0.0001 0 1.4 50 100 150 200 250 VR, Instantaneous Reverse Voltage (V) VF, Instantaneous Forward Voltage (V) Fig. 4 Power Derating Curve Fig. 3 Typical Capacitance VS. Reverse Voltage 250 4.0 200 3.0 f=1.0 MHz PD, Power Dissipation (mW) CT, Total Capacitance (pF) 3.5 2.5 2.0 1.5 1.0 0.5 150 100 50 0 0.0 0 10 20 VR, Reverse Voltage (V) Document Number: DS_S0000021 30 40 0 40 80 120 160 200 TA, ambient Temperature (oC) Version: A15 BAV19WS-G/BAV20WS-G/BAV21WS-G Taiwan Semiconductor Small Signal Product ORDERING INFORMATION PART NO. PACKING CODE BAVxxWS-G (Note 1, 2) RR PACKING CODE SUFFIX PACKAGE PACKING SOD-323 3K / 7" Reel G Note 1: "xx" is Device Code from "BAV19WS-G" to "BAV21WS-G". Note 2: Whole series with green compound EXAMPLE PREFERRED P/N PART NO. PACKING CODE BAV19WS-G RRG BAV19WS-G RR PACKING CODE DESCRIPTION SUFFIX G Green compound DIMENSIONS SOD-323 B DIM. A C D E Unit (mm) Unit (inch) Min Max Min Max A 1.150 1.400 0.045 0.055 B 2.300 2.700 0.091 0.106 C 0.250 0.450 0.010 0.018 D 1.600 1.800 0.063 0.071 E 0.800 1.000 0.031 0.039 F 0.050 0.177 0.002 0.007 G 0.475 REF 0.019 REF H - - 0.100 0.004 H F G SUGGESTED PAD LAYOUT Unit (mm) Unit (inch) Typ. Typ. G 1.600 0.063 X 0.630 0.025 X1 2.850 0.112 Y 0.830 0.033 DIM. Note: The suggested land pattern dimensions have been provided for reference only, as actual pad layouts may vary depending on application MARKING Part No. Marking BAV19WS-G A8 BAV20WS-G T2 BAV21WS-G T3 Document Number: DS_S0000021 Version: A15 BAV19WS-G/BAV20WS-G/BAV21WS-G Taiwan Semiconductor Small Signal Product Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. Document Number: DS_S0000021 Version: A15
BAV19WS-G RRG 价格&库存
很抱歉,暂时无法提供与“BAV19WS-G RRG”相匹配的价格&库存,您可以联系我们找货
BAV19WS-G RRG
  • 3000+0.350933000+0.04556
  • 9000+0.293149000+0.03806
库存:8995
BAV19WS-G RRG
  • 1+1.757091+0.22810
  • 10+1.0830110+0.14060
  • 50+0.7714250+0.10015
  • 100+0.66844100+0.08678
  • 500+0.48594500+0.06309
库存:8995
