1N4148 / 1N4448 / 1N914B
Taiwan Semiconductor
500mW, High Speed Switching Diode
FEATURES
KEY PARAMETERS
Low power loss, high efficiency
Ideal for automated placement
High surge current capability
Compliant to RoHS directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
● Halogen-free according to IEC 61249-2-21
APPLICATIONS
● Switching mode power supply (SMPS)
PARAMETER
VALUE
UNIT
IF
150
mA
VRRM
100
V
IFSM
2
A
VF at IF=100mA
1
V
TJ MAX
150
°C
Package
DO-35
Configuration
Singal die
MECHANICAL DATA
● Case: DO-35
● Packing code with suffix "G" means green compound
(halogen-free)
● Terminal: Matte tin plated leads, solderable per J-STD-002
● Polarity: Indicated by cathode band
● Weight: 125 ± 4 mg
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Power dissipation
SYMBOL
1N4148
1N4448
1N914B
UNIT
PD
500
mW
VRRM
100
V
IFSM
2
A
Forward current
IFM
IF
450
150
mA
mA
Junction temperature range
TJ
-65 to +150
°C
Storage temperature range
TSTG
-65 to +150
°C
SYMBOL
TYP
UNIT
RӨJA
240
°C/W
Repetitive peak reverse voltage
Non-Repetitive peak forward surge current
Pluse width = 1μs, Square wave
Non-Repetitive peak forward current
THERMAL PERFORMANCE
PARAMETER
Junction-to-ambient thermal resistance
1
Version:J1804
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
1N4448,1N914B
Forward voltage
per diode
(1)
MIN
MAX
0.62
0.72
1.00
1.00
100
75
25
nA
5
μA
CJ
4
pF
trr
4
ns
IF = 5 mA,
TJ = 25°C
IF = 10 mA,
1N4148
VF
TJ = 25°C
1N4448,1N914B
Reverse voltage
SYMBOL
IF = 100 mA,
TJ = 25°C
IR = 100 μA, TJ = 25°C
VR
(2)
IR = 5 μA, TJ = 25°C
Reverse current
VR = 20 V, TJ = 25°C
VR = 75 V, TJ = 25°C
capacitance
Reverse
V
V
IR
(2)
Junction
UNIT
1 MHz, VR=0V
IF= 10mA , VR=6V, RL= 100Ω ,
recovery time
IRR= 1mA
Notes:
1. Pulse test with PW=0.3 ms
2. Pulse test with PW=30 ms
ORDERING INFORMATION
PART NO.
PACKAGE
PACKING
1N4148 R0G
DO-35
10K / 14" Reel
1N4148 R0
DO-35
10K / 14" Reel
1N4148 A0G
DO-35
5K / Box(Ammo)
1N4148 A0
DO-35
5K / Box(Ammo)
1N4448 R0G
DO-35
10K / 14" Reel
1N4448 R0
DO-35
10K / 14" Reel
1N4448 A0G
DO-35
5K / Box(Ammo)
1N4448 A0
DO-35
5K / Box(Ammo)
1N914B R0G
DO-35
10K / 14" Reel
1N914B R0
DO-35
10K / 14" Reel
1N914B A0G
DO-35
5K / Box(Ammo)
1N914B A0
DO-35
5K / Box(Ammo)
2
Version:J1804
CHARACTERISTICS CURVES
Fig.1 Typical Forward Characteristics
Fig. 2 Reverse Current VS. Reverse Voltage
10000
1
TA=25°C
Reverse Current :lR (nA)
Forward Current (A)
100°C
0.1
0.01
0.001
1000
70°C
100
50°C
TA=25°C
10
1
0.4
0.6
0.8
1
1.2
1.4
1.6
Forward Voltage (V)
Fig.3 Admissible Power Dissipation Curve
60
80
100
120
Fig.4 Typical Junction Capacitance
500
1.5
400
1.2
Junction Capacitance (pF)
Power Dissipation (mW)
40
Reverse Voltage : VR (V)
300
200
100
f=1.0 MHz
0.9
0.6
0.3
50
75
100
125
150
175
200
o
Ambient Temperature ( C)
5
10
15
30
Reverse Voltage (V)
3
Version:J1804
PACKAGE OUTLINE DIMENSION
DO-35
DIM.
Unit (mm)
Unit (inch)
Min
Max
Min
Max
A
0.34
0.60
0.013
0.024
B
2.90
5.08
0.114
0.200
C
25.40
38.10
1.000
1.500
D
1.30
2.28
0.051
0.090
MARKING DIAGRAM
4
Version:J1804
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
5
Version:J1804
很抱歉,暂时无法提供与“1N914B A0G”相匹配的价格&库存,您可以联系我们找货
