TSP10U100S – TSP10U120S
Taiwan Semiconductor
10A, 100V - 120V Low VF Trench Schottky Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Patented Trench Schottky technology
Excellent high temperature stability
Low forward voltage
Low power loss / high efficiency
High forward surge capability
Ideal for automated placement
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
10
A
VRRM
100 - 120
V
IFSM
140
A
TJ MAX
150
°C
Package
TO-277A (SMPC)
Configuration
Single die
APPLICATIONS
● Switching mode power supply (SMPS)
● Adapters
● DC to DC converters
MECHANICAL DATA
Case: TO-277A (SMPC)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.095g (approximately)
TO-277A (SMPC)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
TSP10U100S
TSP10U120S
10U100
10U120
UNIT
Repetitive peak reverse voltage
VRRM
100
120
V
Reverse voltage, total rms value
VR(RMS)
70
84
V
Forward current
Surge peak forward current, 8.3ms single half sine
wave superimposed on rated load
Junction temperature
IF
10
A
IFSM
140
A
TJ
-55 to +150
°C
Storage temperature
TSTG
-55 to +150
°C
1
Version: F2103
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJL
11
°C/W
Junction-to-lead thermal resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
TSP10U100S
TSP10U120S
IF = 5A, TJ = 25°C
TSP10U100S
Forward voltage
(1)
TSP10U120S
IF = 10A, TJ = 25°C
VF
TSP10U100S
TSP10U120S
IF = 5A, TJ = 125°C
TSP10U100S
TSP10U120S
Reverse current @ rated VR
(2)
IF = 10A, TJ = 125°C
TJ = 25°C
IR
TJ = 125°C
TYP
MAX
UNIT
0.51
V
0.56
V
0.60
0.68
V
0.68
0.78
V
0.42
V
0.49
V
0.52
0.60
V
0.57
0.67
V
150
µA
30
mA
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
TSP10UxS
TO-277A (SMPC)
6,000 / Tape & Reel
Notes:
1. “x” defines voltage from 100V(TSP10U100S) to 120V(TSP10U120S)
2
Version: F2103
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
10000
10
CAPACITANCE (pF)
8
6
4
1000
2
75
100
125
100
150
0.1
1
LEAD TEMPERATURE (°C)
100
10
TJ=150°C
1
TJ=125°C
0.1
TJ=100°C
0.01
0.001
TJ=25°C
0.0001
10
40
50
60
70
80
90
100
100 10
TSP10H100S
10
UF1DLW
TJ=150°C
1
TJ=125°C
TJ=125°C
TJ=100°C
1
TJ=25°C
0.01
0.1
0.001
0.1
Pulse width 300μs
1% duty cycle
Pulse width
0.2 0.3
0.3
0.4
INSTANTANEOUS FORWARD CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
TSP10H120S
TJ=150°C
1
TJ=125°C
TJ=100°C
0.01
TJ=25°C
0.0001
10
40
50
60
70
80
90
0.5 0.6 0.7 0.8 0.9
0.6
0.7
0.8
0.9
1.0
1
1.1
1.2
1.1
1.2
Fig.6 Typical Forward Characteristics
100
0.001
0.4
0.5
FORWARD VOLTAGE (V)
Fig.5 Typical Reverse Characteristics
0.1
TJ=25°C
0.1
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
10
100
Fig.4 Typical Forward Characteristics
Fig.3 Typical Reverse Characteristics
TSP10H100S
10
REVERSE VOLTAGE (V)
(A)
25
f=1.0MHz
Vsig=50mVp-p
100
100 10
10
TSP10H120S
1
UF1DLW
T =150°C
J
TJ=125°C
TJ=125°C
TJ=25°C
0.1
TJ=100°C
1
TJ=25°C
0.01
0.1
0.001
0.1
(A)
AVERAGE FORWARD CURRENT (A)
12
Pulse width 300μs
1% duty cycle
Pulse width
0.2 0.3 0.4
0.3
0.4
0.5
0.5 0.6 0.7 0.8 0.9
0.6
0.7
0.8
0.9
1.0
1
FORWARD VOLTAGE (V)
3
Version: F2103
Fig.7 Maximum Non-Repetitive Forward Surge Current
PEAK FORWARD SURGE CURRENT (A)
160
140
8.3ms single half sine wave
120
100
80
60
40
10
100
NUMBER OF CYCLES AT 60 Hz
4
Version: F2103
PACKAGE OUTLINE DIMENSIONS
TO-277A (SMPC)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
P/N
YW
F
5
= Marking Code
= Date Code
= Factory Code
Version: F2103
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: F2103
很抱歉,暂时无法提供与“TSP10U120S S1G”相匹配的价格&库存,您可以联系我们找货
